- Joined
- Mar 13, 2018
- Messages
- 22
- Reaction score
- 6
- Location
- Norway
- VCDS Serial number
- C?ID=288196 (NRRT)
Hi. After replacing the central electric module, the central lock has stopped working with the lock button. It also does not lock with a key in the door.
The open button works fine both inside the car and on the remote. But the car will not lock. When I hold the lock button, all the windows are closed.
Before cange:
After change
Before cange:
Monday,18,November,2019,12:40:20:58635
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: TMBHM61Z1B2169085 License Plate: SKODA
Mileage: 125310km-77864mi Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 69 72
77
VIN: TMBHM61Z1B2169085 Mileage: 125310km-77864miles
16-Steering wheel -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 F HW: 03F 906 070 F
Component: SIMOS10.10H03 9837
Revision: -------- Serial number:
Coding: 001900D6230400080000
Shop #: WSC 73430 031 00090
ASAM Dataset: EV_ECM12TFS02103F906070F 003011
ROD: EV_ECM12TFS02103F906070A_003_VW32.rod
VCID: A502721CA4048D6774-80F0
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 113B201C09280003880B04EC901E0040340000
Shop #: WSC 73430 790 00090
VCID: F5A2625C5C24BDE704-80A0
Part No SW: 3T0 907 044 BE HW: 3T0 907 044 BE
Component: Climatronic H16 0402
Revision: 00006001
Coding: 0000000002
VCID: F6A065504922B6FF0D-80A2
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AE
Coding: 40000AB8E00508C040080080510011E4437000AE726D8D605C8540000040
VCID: B83CAB680BB6008FDF-80EC
Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 06051 26 0601
Coding: 00D7B7
Component: RLS 100511 05 54 0403
Coding: 0730ED
18 Faults Found:
Fault Status: 00101010
Reset counter: 53
Mileage: 116930 km
Date: 2021.11.23
Time: 13:17:12
Voltage: 14.50 V
Term 50 Off
00532 - Supply Voltage B+
Reset counter: 53
Mileage: 125310 km
Date: 2022.09.09
Time: 17:03:32
Term 15 Off
Voltage: 7.80 V
Term 50 Off
Fault Status: 00101110
Reset counter: 23
Mileage: 106750 km
Date: 2020.12.04
Time: 16:36:40
Voltage: 14.40 V
Term 50 Off
Reset counter: 53
Mileage: 125311 km
Date: 2019.11.18
Time: 00:00:01
Term 15 Off
Voltage: 17.75 V
Term 50 Off
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.18
Time: 00:00:07
Term 15 Off
Voltage: 14.95 V
Term 50 Off
00154 - Windshield Wiper Motor; Passenger Side (V217)
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.18
Time: 00:00:08
Term 15 Off
Voltage: 14.95 V
Term 50 Off
00447 - Function Limitation due to Over-Voltage
Fault Status: 00100001
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.18
Time: 00:00:07
Term 15 Off
Voltage: 16.00 V
Term 50 Off
Fault Status: 00100111
Fault Frequency: 39
Reset counter: 53
Mileage: 123467 km
Date: 2022.07.23
Time: 21:32:41
Voltage: 14.55 V
Term 50 Off
Fault Status: 00101001
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.19
Time: 00:00:00
Term 15 Off
Voltage: 13.00 V
Term 50 Off
03396 - Supply voltage terminal 30 for central locking
Fault Status: 00101011
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.19
Time: 00:00:01
Term 15 Off
Voltage: 12.95 V
Term 50 Off
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.19
Time: 00:00:00
Term 15 Off
Voltage: 12.85 V
Term 50 Off
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.19
Time: 00:00:00
Term 15 Off
Voltage: 12.85 V
Term 50 Off
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.19
Time: 00:00:00
Term 15 Off
Voltage: 12.85 V
Term 50 Off
01516 - Terminal 30; Left
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.19
Time: 00:00:09
Term 15 Off
Voltage: 12.90 V
Term 50 Off
00927 - Terminal 30 (Right)
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.18
Time: 00:48:25
Term 15 Off
Voltage: 12.55 V
Term 50 Off
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.18
Time: 01:14:05
Term 15 Off
Voltage: 13.00 V
Term 50 Off
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.18
Time: 01:14:05
Term 15 Off
Voltage: 13.00 V
Term 50 Off
01800 - Light Switch (E1)
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.18
Time: 00:15:25
Term 15 Off
Voltage: 12.70 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 32901113001490
Coding: 11000E
Shop #: WSC 13765 790 00090
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000_001.rod
VCID: B3269C441AD0E3D7EA-80E6
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2R1CEJ
Coding: 0020790
VCID: BD32BA7CE49425A70C-80E8
Subsystem 1 - Serial number: 6332MSME5F5211628
Subsystem 2 - Serial number: 6342MSME5F527301A
Subsystem 3 - Serial number: 6351HSME273F531BE
Subsystem 4 - Serial number: 6361HSME273F7276H
Part No SW: 5K0 953 521 BM HW: 5K0 953 569 D
Revision: FF010040 Serial number: 20110507101532
Coding: 108A040000
ROD: EV_SMLSNGVOLWS.rod
VCID: F8BC6B684336C08F1F-80AC
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 820000
Part No SW: 1Z0 920 843 K HW: 1Z0 920 843 K
Component: KOMBI H20 0420
Coding: 110E01
ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
VCID: C0CCC3885B66484F67-8094
13893888 - Function Restricted due to Excessive Voltage
U1401 00 [008] - -
Reset counter: 53
Mileage: 125313 km
Date: 2019.11.18
Time: 00:00:09
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 100511F2001358
Coding: 352302
VCID: B02C9348E3C6D8CF97-80E4
6 Faults Found:
Reset counter: 53
Fault Status: 00110100
Reset counter: 53
Reset counter: 53
Reset counter: 53
Reset counter: 53
Reset counter: 53
Component: IMMO H20 0420
VCID: EA9841200D9A621F99-80BE
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669936773
VCID: A81C7B28DB16900F4F-80FC
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2119
Coding: 0000244
VCID: C8DCDBA8BB56700FAF-809C
02071 - Local Databus
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 67 3201
Revision: 00H20000
VCID: B4249F58D7DEE4EFF3-80E0
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.6 V
PD
Temperature: 17.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000244
VCID: C7DED894B6487F77A6-8092
Component: AFS-Steuergeraet 0148
Coding: 1507354
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000023
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000023
Part No SW: 1Z0 035 161 N HW: 1Z0 035 161 N
Component: Radio-SWING 012 0036
Revision: -----16S Serial number: SKZ4Z2L1238003
Coding: 090004000001
VCID: B93AAE6C30BC198720-80EC
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012570
VCID: B22899402DCAEADFE1-80E6
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000147677039
Coding: 410D000100000000
Reset counter: 53
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: B3269C44D2D0E3D7EA-80E6
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007660005078
Coding: 0200000000010110
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: E2882900F5AA3A5F51-80B6
End----------(Elapsed Time: 01:37, VBatt start/end: 13.5V/13.5V)-----------
After change
Tuesday,19,November,2019,15:30:24:58635
VIN: TMBHM61Z1B2169085 License Plate: SKODA 2
77
Readiness: 0110 0101
Revision: 00H31001
Revision: 00006001
Coding: 0000000002
Part No SW: 1K0 937 087 P HW: 1K0 937 087 P
Component: BCM PQ35 H+ 104 0615
Revision: 00104 AF
Coding: 40000AB8E42508C048080080510011E4437000AE726D8D605C8540000040
VCID: BE30BD7029923EBF15-80EA
Coding: 00D7B7
Coding: 0730ED
Coding: 11000E
Coding: 0020790
Coding: 108A040000
Coding: 820000
Coding: 110E01
Coding: 352302
Coding: 0000244
Revision: 00H20000
Coding: 0000244
Coding: 1507354
Coding: 00000023
Coding: 00000023
Coding: 0000144
Coding: 0000144
ROD: UHVNA.rod
End----------(Elapsed Time: 01:24, VBatt start/end: 12.4V/12.4V)-----------
