Reset timing chain stretch adaption and oil pressure break in
Shzeps
C?ID=11561
Is there a way to reset timing chain stretch adaption and oil pressure break in on newer 2.0l FSI AND TFSI engines (ex: CAED, CCTA, etc.) after replacing the timing chain and tensioner? There is a test plan in ODIS for this. I read that this should be reset and someone said that clearing the codes 3x in 10 seconds with VCDS will do this. Is this correct? Are there values to look at to confirm it has been reset sucessfully?
Thanks for any help or info.
Here is an applicable autoscan.
Friday,18,October,2019,13:37:10:57829
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUAFAFL7FN012035   License Plate:
Mileage: 108270km-67275mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
          77
VIN: WAUAFAFL7FN012035   Mileage: 108270km-67275miles
Address 01: Engine (MY15-CAED)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 M    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 4A030013242400062000
   Shop #: WSC 47412 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115M 001006
   ROD: EV_ECM20TFS0118K5907115M.rod
   VCID: BC346E99378AC2AF3B-80E8
8 Faults Found:
4573 - Ignition Control Circuit for Cylinder 3
          P0353 00 [096] - Malfunction
                    Mileage: 108276 km
                    Date: 2019.10.14
                    Time: 08:38:49
                    Engine speed: 1205.50 /min
                    Normed load value: 34.5 %
                    Coolant temperature: 24 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 13.900 V
                    Engine status: COENG_RUNNING
4574 - Ignition Control Circuit for Cylinder 4
          P0354 00 [104] - Malfunction
                    Mileage: 108276 km
                    Date: 2019.10.14
                    Time: 08:36:36
                    Engine speed: 1033.00 /min
                    Normed load value: 19.6 %
                    Coolant temperature: 30 °C
2697 - Fuel Pressure Sensor (G247)
          P0190 00 [032] - Circuit Malfunction
                    Mileage: 108276 km
                    Date: 2019.10.14
                    Time: 07:16:13
                    Coolant temperature: -40 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 14.347 V
                    Engine status: COENG_FINISH
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
2778 - Engine Coolant Temp. Sensor (G62)
          P0118 00 [100] - Signal too High
                    Mileage: 108276 km
                    Date: 2019.10.14
                    Time: 07:16:13
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [237] - -
                    Mileage: 108276 km
                    Date: 2019.10.14
                    Time: 07:16:05
                    Engine speed: 3382.00 /min
                    Normed load value: 52.9 %
                    Coolant temperature: 19 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 13.970 V
10594 - Cylinder 4
          P0304 00 [237] - Misfire Detected
                    Mileage: 108276 km
                    Date: 2019.10.14
                    Time: 07:16:10
10592 - Cylinder 2
          P0302 00 [237] - Misfire Detected
                    Mileage: 108276 km
                    Date: 2019.10.14
                    Time: 08:41:42
                    Engine speed: 816.00 /min
                    Normed load value: 22.7 %
                    Voltage terminal 30: 14.088 V
10205 - Cylinder Disabling
          P130A 00 [032] - -
                    Mileage: 108276 km
                    Date: 2019.10.16
                    Time: 13:55:43
                    Engine speed: 1229.50 /min
                    Normed load value: 44.3 %
                    Vehicle speed: 14 km/h
                    Coolant temperature: 21 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 13.570 V
Readiness: 1110 0101
   Part No SW: 8K9 927 155     HW: 0AW 927 156 K
   Component: 0AW 20TAVSUSA H07 0003
   Revision: --H07---    Serial number: 0000001163
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381.rod
   VCID: F9BAB78D7838378760-80AC
   Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
   Component: ESP8 front    H09 0020
   Coding: 081D1801
   VCID: 875EC17536CC517766-80D2
   Part No SW: 8K0 907 064 JL    HW: 8K0 907 064 JL
   Component: BCM2 2.0      H14 0650
   Coding: 09814040000000000000
   VCID: 8346D56502F47D573A-80D6
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0514000117250002
   Serial number: 0214000151117010
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01250820140505
   Coding: 6400208000
   VCID: F7BEB1B5462C21F716-80A2
                    Reset counter: 65
                    Mileage: 108276 km
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000876672201
   Coding: 26000091863CAFC00000480300003D0D0F1C530822090221000008004000020100000000000000
   VCID: F6A0BCB1412658FF0D-80A2
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA090714  H18 0461
   Serial number: 1407040608225
   Coding: 004577
   Serial number: 23099960
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001208141469
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z0015762C
   Serial number: 2E898147000000000001
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NDD12AS18
   Coding: 303844354730383131304A55304C384B3053
   Shop #: WSC 44670 001 1048576
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: CBD63D456224751782-809E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R140000LB12
   Serial number: 6334MSME7E616A3BV
   Serial number: 6344MSME483B257BP
   Serial number: 6352QSME1544465CI
   Serial number: 6362QSME77442968P
   Serial number: 63732SME07454260R
   Serial number: 63832SME16451F784
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NHQ0009X
   Coding: 000016
   VCID: C8DC02497B529E0FAF-809C
   Part No SW: 8K0 920 951 E    HW: 8K0 920 951 E
   Component: KOMBIINSTR.   H09 0564
   Revision: 00300000    Serial number: ZA1331Z7F
   Coding: 8B9609000301D705020000
   VCID: B22840A1EDCE04DFE1-80E6
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0060
   Revision: 1V090029    Serial number: 2941V14820020D
   Coding: 80C303FF00
   Serial number: 5513134103
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: B93A778D30B8F78720-80EC
   Component: TSG FA        H09 0305
   Coding: 011C03204000410001
   VCID: D6E0DC31A1E638FF2D-8082
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0017876867
   Coding: 100000000001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: B83C728903B2EE8FDF-80EC
   Revision: 00002001    Serial number: 0344882958
   Coding: 0106023A00FA400480B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000873240
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Part No SW: 8R1 035 223 A    HW: 8R1 035 223
   Component: DSP STD       H08 0230
   Revision: 26S00000
   Coding: 0203010102
   VCID: AB165DC5CAE45517A2-80FE
   Component: TSG BF        H09 0305
   VCID: D5E2DB3DBCE033E724-8080
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001530433
   ROD: EV_ParkiBrake_AU48.rod
   VCID: BA3868813DBEFC9F29-80EE
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000003    Serial number: AUZ5Z6N2072460
   Coding: 04020002010185004359070800
   VCID: C3C615654274BD577A-8096
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C03204000210001
   VCID: D9FAD70DD0F8178700-808C
   Component: TSG HR        H07 0305
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005384841
   Coding: 0010370
   VCID: BE306491E996D0BF15-80EA
End----------(Elapsed Time: 01:41, VBatt start/end: 13.9V/14.0V)-----------
Address 01: DTCs cleared
Shzeps
C?ID=11561
Just checking, did I post this in the wrong forum? Please let me know.
Thanks.
NZDubNurd
New Zealand
C?ID=230482
I'm rather unfamiliar, but I wouldn't have thought there'd be an "adaptation" for timing chain stretch per se, just a measurement. The related adaptiation is more likely named something related to "Phase" position or timing.
I believe that just sets the variator to it's end stops while the engine is running and measures the results for each endpoint, then the position is guestimated in between, using the crank and cam position measurement differences.
On my model, you start the adaptation and press the brake and throttle, and the engine clearly changes tone and smoothness while it runs the timing variators/phasers to the endpoints.
Kam
United Kingdom
C?ID=41543
Hi as far as I’m aware on ODIS you can measure the timing chain stretch but only on certain models I believe, but I don’t recall there being a reset for the stretched chain.
However there is basic setting option on variable valve timing.
In workshop manual there is a mechanical measurement that requires the removal of the tensioner and inserting special tool and measure it with a vernier and from memory a measurement of over 76 or 78 mm and the chain needs to be replaced.
