Results 1 to 10 of 18
Thread: Manual Label Files in LCode
    Mar 2016
    So I've started using the great LCode.exe "offline" on my desktop computer so I can drop in Long Coding strings and then compare against others the bytes/bits etc. Its very useful
    However, historically, I've gone to a car and screengrabbed each of the Long Coding Pages of a Module 1 by 1 so I get all the "Plain text" coding while VCDS is connected to the vehicle. I'm assuming VCDS is pulling this info from the module in real-time (?)
    What I want to do is import those plain text words for each bit so they can be added as label files when using LCode.exe offline on its own. (without being anywhere near a car!)
    I tried to add a label file from my default VCDS install and that worked, but obviously it doesnt have label files for all models and variants which is why I assumed when VCDS is connected to a car its pulling that plain text wording from the module in real-time.
    Is there a way to create label files this way to bring that plain text coding where a default lbl file doesnt exist so it can be used in the LCode.exe offline?
    I hope that makes sense
    Thanks
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dynamic Pack | Matrix Lights | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | N-Vision | BOSE | DVD Changer | Homelink | Soft Door Close | Heat+Sound Ins Glass | Priv Glass | Heated Windscreen | Heated Steer Wheel | Adv Key | Elec Boot Cover | Side Assist | Air Suspension | Ambient Lighting | Heated+Fold Mirrors | Park Assist Pack | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap
  2. Likes MartinsX liked this post
  3. #2
    Jun 2017
    I think you did not understand the way it works.
    Label information for newer cars comes encrypted in either .CLB label files or is extracted from the ASAM data in case of experimental coding.
  4. Likes Uwe liked this post
  5. #3
    Jun 2014
    Is possible decode CLB file to LBL and look / edit as TXT
    you can also make a module simulation, to create part number, and connect VCDS to code that "virtual module"
    Mar 2016
    Thanks Hadez16, appreciate the info.
    I do understand that VCDS extracts the info from the ASAM data in the experimental coding, but what I'm trying to find out is whether its possible to extract that data out to a file that could be imported into LCode.exe when running it "offline" (i.e. not connected to car).
    Other than screengrabbing each page of Experimental long coding and then manually typing that info into a "label file" which could then be loaded into LCode.exe (offline) before dropping in the long coding string to see what is ticked/not ticked etc
    Thats what I'm trying to see if its possible?
    Thanks again
    Andy
    Mar 2016
    Thanks, are you saying this is possible? If so, how do we go about it?
    I dont want to violate any Ross-Tech/VCDS rules at the same time.
    Thanks
    Andy
    Jun 2014
    Quote Originally Posted by andyhud View Post
    Thanks
    Andy
    if you dont want ..... please dont do that
    I gave you 2 options, one is already gone
    Mar 2016
    Thanks, I wasnt trying to be rude, just asking
    I dont know how to "decode" the CBL files to look at them as text. I just want to know if they can be loaded "offline".
    Thankyou
  10. #8
    Allowing them to be loaded "off-line" would defeat the purpose of encrypting them to begin with.
  11. Likes PetrolDave liked this post
  12. #9
    Mar 2016
    Thanks Uwe, thats fine by me. I'm just confused really now, so just after some clarity.
    If I load Lcode.exe on my pc now I've got a button called "read info text file". What "files" can/should I be using with this button then? I'm now under the assumption I can use some files (either ending .lbl or .xpl). Please correct me if I'm wrong.
    However, not all modules have a file ending in .lbl or .xpl so therefore I can't load it. Is that also a correct assumption?
    Pure example - Door controller off a Q7 4M (i.e 4M0959595)
    Sorry, just trying to make sure I fully understand
    Thanks
    Andy
  13. #10
    Yes, that's correct. If the file is plain text, (.LBL or .XPL), then LCode can load it off-line. If the file is encrypted (.CLB), then LCode cannot load it off-line.
