ESP FRONT MK60 ABS Coding (not EC1!)
Cronus7
C?ID=387435
Hi Uwe, thanks for the prompt response.
Full Autoscan below.
Chassis Type: 1T (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ5W071731   Mileage: 237080km-147314miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 016 CD    HW: 028 101 194 5
   Component: R4 1,9L EDC 0000SG  6246
   Revision: 12345678    Serial number: VWZ7Z0D0585769
   Coding: 0000072
   Shop #: WSC 01286 386 08256
   VCID: 67D7F8FB56C0627706-8032
18058 - Powertrain Data Bus
            P1650 - 000 - Missing Message from Instrument Cluster
                    Torque: 222.0 Nm
                    Voltage: 11.32 V
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    (no units): 0.0
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 000 -  - Intermittent
                    RPM: 798 /min
                    Torque: 40.0 Nm
                    Speed: 6.0 km/h
                    Voltage: 14.21 V
                    Temperature: 9.0°C
                    Temperature: 33.3°C
                    Temperature: 22.5°C
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0000000
   Shop #: WSC 01324 785 00200
   VCID: 3A71718F75F22F9FA9-806E
00810 - Sensor 1/2 for Brake Pressure
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000539124
   Coding: 00884F0200041000000000000000000000
   VCID: 377768BB46E032F756-8062
   Subsystem 1 - Part No: 2K2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer VW357  011  0302
   Coding: 00065493
9 Faults Found:
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 P    HW: 6Q0 909 605 P
   Component: 01 AIRBAG VW52  022 2300
   Revision: 03022000    Serial number: 0035ED0282DH
   Coding: 0012337
   Shop #: WSC 35110 377 00162
   VCID: 448D0F770736696FC3-8010
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   Shop #: WSC 35110 377 00191
   VCID: 6FE790DB7E30BA374E-803A
   Part No: 1T0 920 951 C
   Component: KOMBIINSTRUMENT VDD 0716
   Coding: 0002403
   Shop #: WSC 00194 067 57207
   VCID: 326159AFAD82D7DF61-8066
00003 - Control Module
            014 - Defective
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 21001041072FBA
   Coding: 3D0F0140079001
   VCID: 2757B8FB9640A277C6-8072
                    Reset counter: 86
                    Mileage: 237013 km
                    Time: 06:28:29
01304 - Radio
                    Reset counter: 86
                    Mileage: 237013 km
                    Time: 06:28:33
                    Reset counter: 125
                    Time: 05:29:20
   Component: IMMO            VDD 0716
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1T0 959 701 C
   Component: Tuer-SG         024 2486
   Coding: 0000628
00120 - Outside Warning Light/Door exit Light Driver Side
00109 - Left Mirror Turn Signal Lamp (L131)
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
   Part No: 1K2 909 144 E
   Component: EPS_ZFLS Kl.14      1202
   VCID: 2E594DDFB9BAF33F05-807A
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 T
   Component: 01 KSG              0560
   Coding: 008B0C087F2D8C0C085A010000
   Shop #: WSC 08224 211 56823
   VCID: 4183066318247C47E8-8014
02483 - Module for Locking of Rear Lid (F327)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Component: Tuersteuergeraet 09 0130
   Coding: 0000052
   VCID: 75EBA2B31C6C80E784-8020
Address 56: Radio
End-------------------------(Elapsed Time: 01:39)--------------------------
                Address 03: ABS Brakes       Labels: 1K0-907-379-MK60-F.LBL
Control Module Part Number: 1K0 907 379 K
  Component and/or Version: ESP FRONT MK60      0103
           Software Coding: 0000000
            Work Shop Code: WSC 01324 785 00200
Thanks in advance.
Kindest Regards,
Joe
Jef
HQ
Try 0021190 for the ABS coding.
Cronus7
C?ID=387435
Thanks Jeff, I’ll try this code then upload the results.
I’ve started a new thread in the relevant section.
Kindest Regards,
Joe
Why? They are both in the same Car Repair Section. We do not need/want two threads for the same problem/question in the same car.
Your new thread is going away.
Cronus7
C?ID=387435
Split from the How to Get Verified thread, where I explicitly asked you to start a new thread.??
Hi Uwe, I’m just getting used to posting on here. Sorry for the duplicate threads, I thought that’s what you explicitly asked of me?.
Kindest Regards,
Joe
I did ask that. But since you didn't do that, I split this from the How to Get Verified Thread, thereby creating a new thread for you. ;)
Cronus7
C?ID=387435
Hi Jef, thank you for the code. Coding was accepted. Happy customer.
Much appreciated.
Kindest Regards,
Joe
