Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Default Dashboard cluster turn off a3 8p
    Unverified
    Nov 2019
    it is all faulty codes some are because im recently have problem with accu winter and i dont use car often
    i notice when i start car and cluster reset . cluster didnt rise mileage
    Address 01: Engine
    18058 - Powertrain Data Bus
    P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
    RPM: 1680 /min
    Torque: 0.0 Nm
    Speed: 59.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Bin. Bits: 00101000
    Torque: 172.0 Nm
    Torque: 0.0 Nm
    17056 - Cylinder 2 Glow Plug Circuit (Q11)
    P0672 - 000 - Electrical Fault
    Torque: 172.0 Nm
    Load: 0.0 %
    Voltage: 11.40 V
    Bin. Bits: 00101000
    Temperature: 7.2°C
    Bin. Bits: 00110000
    Address 03: ABS Brakes
    Address 08: Auto HVAC
    0601 - Potentiometer On Positioning Motor for Central Flap (G112)
    Fault Status: 00101010
    Reset counter: 160
    Mileage: 202546 km
    Date: 2019.06.22
    Time: 00:00:19
    Voltage: 14.40 V
    (no units): 255.0
    Temperature: 5.5°C
    Address 09: Cent. Elect
    Address 19: CAN Gateway
    Fault Frequency: 35
    Reset counter: 163
    Date: 2019.06.22
    Time: 00:32:27
    00381 - Databus Instrument Cluster
    Fault Status: 00101110
    Fault Frequency: 18
    Reset counter: 163
    Time Indication: 15
    Address 44: Steering Assist
    02546 - Steering Limit Stop
    Mileage: 2520 km
    Temperature: 4.0°C
    Voltage: 10.90 V
    Voltage: 10.70 V
    Address 52: Door Elect, Pass.
    00106 - Signal Central Locking SAVE/LOCK Passenger Side
    Address 56: Radio
    Fault Frequency: 17
    Reset counter: 163
    Time Indication: 15
    Bin. Bits: 10
    Reset counter: 163
    Time Indication: 15
  2. #12
    Sep 2016
    Riga, Latvia
  3. Likes Uwe, PetrolDave liked this post
  4. #13
    Unverified
    Nov 2019
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
    VIN: WAUZZZ8PX4A0XXXXX                         Mileage: 202550km/125858miles
  5. #14
    Jun 2014
    I like that game
  6. Likes MartinsX, Mike@Gendan, Uwe, NZDubNurd liked this post
  7. #15
    Jun 2014
    Swansea, UK
    Quote Originally Posted by dark41 View Post
    That's a gateway installation list.
    We need the FULL UNEDITED AUTO-SCAN
  8. Likes PetrolDave liked this post
  9. #16
  10. #17
    Jun 2014
    Swansea, UK
  11. Likes Uwe, PetrolDave, NZDubNurd liked this post
  12. #18
  13. Likes NZDubNurd liked this post
