Results 1 to 10 of 18
Thread: Default Dashboard cluster turn off a3 8p
    Unverified
    Nov 2019
    hi,
    I have a problem with my audi a3 8p 2003 2.0tdi
    Dashboard cluster constantly turn off (witch radio i must enter code) for few seconds. In 15 minute period it can turn off 5 times depends on weather (when colder it turn off more often, but it can be coincidence)
    strange thing is when I start engine and do nothing dashboard cluster works fine but when i try to move dashboard cluster start to turn off
    vcds : 18058
    Please post an Auto-Scan for context.
    Unverified
    Nov 2019
    I will get back my diagnoistic cable in few weeks but cluster 17- instruments have no faulty only faulty code tied to cluster is 18058 p1650 - 000 -
    I notice clsuter start turn off always when i move car and cluster always reset to the same time and trip odometer
    is it posibble ecu has different data than cluster how to check it witch diagnostic cable ?
    sorry for my english i not native speaker
    It sounds to me like you have a connection problem if the cluster turns off when you move the car...
    Unverified
    Nov 2019
    i checked wiring is ok,
  6. #6
    Jun 2014
    Swansea, UK
    That Auto-Scan Uwe asked to see needs to be your first step...
  7. Likes Uwe, PetrolDave liked this post
    Jun 2014
    Quote Originally Posted by dark41 View Post
    take a look your message .....
    cluster turn off when you move car ... so must be a vibation issue
    how you check wires - look on it from 1m ?...come one
    simple pull new wires (GND, KL30, KL15) ....COMPLETLY NEW ...to baypass old one
    once you baypass old loom, you can say - is no wire issue
    then look into cluster inside , or swap cluster
  9. Likes PetrolDave, MartinsX liked this post
  10. #8
    Unverified
    Nov 2019
    ok but if it is vibration it will hapen when i pull wire in cluster i tried and nothing hapened i will tray buy new wiring
    but strange is that cluster works fine all the time when i start the car and dont move. when I move car cluster will start to reset even why I stop the car and for a while do nothing, if it is vibration or Soldering defects it will happen all the time thanks
  11. #9
    Jun 2014
    Swansea, UK
    You seem oddly reluctant to post an Auto-Scan though?
  12. Likes Uwe, PetrolDave liked this post
  13. #10
    I think we should all wait for the Auto-Scan before making any further suggestions
  14. Likes Uwe, Spacewalker liked this post
