Just want to share what I found in a Caddy Tdi from -08
Orchid70
Sweden
C?ID=354348
Engine light lit
Fault code on fuel temperature sensor (G81) - P0183
The sensor did not cost much so I changed it - same fault code
I already had purhaged Fluke PRO3000 thanks to the tip in here and got it to use.....
This is what I found under the air filter box where the sound got silent on one of the wires to G81:
The arrows points at two places:
The worst injury:
...was found here:
And this:
Thanks!
Zenerdiode
Newcastle, England
C?ID=24330
Aww, can’t see your photos. Have you embedded them correctly?
*Edit* You may have to add ‘.jpg’ after your imgur tags...
Orchid70
Sweden
C?ID=354348
Thanks Zenerfiode =)
ALways wondered why the pics came later - some must have edited them for me before =P
I have just clicked on the copy button on Imgur......
Know I know how to to it.
Orchid70
Sweden
C?ID=354348
This pic shows what did it:
Zenerdiode
Newcastle, England
C?ID=24330
At first I thought rodent damage; but then I thought the nicks in the insulation looked too round and too regular. So that corrogated protective conduit - doesn't?!
MartinsX
Riga, Latvia
C?ID=268515
I have repaired hundreds of similar... Golf 5, Passat B6, Caddy, Octavia, A3, Leon etc.
It's because after 2000. VAG started to save money on insulating tape. No tape where wires are in corrugated tubes...
Orchid70
Sweden
C?ID=354348
Yes - right Zenerdiode and MartinX ;)
In my book, these are tighten too tight (dont know what to call them in English so I drew the red ring on it) and yes not much electric tape under the plastic tube:
Orchid70
Sweden
C?ID=354348
Im going to take in our neighbors Caddy from 2008 and see that all looks good.
Martin - do you see this happening in diesels only or in petrol cars too? Do I need to check our Passat from 2000?
NZDubNurd
New Zealand
C?ID=230482
WOW. That's pretty severe wear.
Broken wires there is a pretty common thing - especially on diesels. The engine mounts go soft after a short time too, and the engine wobbles even more.
The wear there is interesting - I thought normally the conductors simply break from flexing.
Orchid70
Sweden
C?ID=354348
^^^Thats what I thought too.... Now we know better =)
Guess what the third pic from the top is for? Its one of the glow plug wires.....
Dunwood
CA, USA
C?ID=370890
For you DIY-Home Gamers (like me), who don't have access to Wurth or similar automotive specialty suppliers or wholesale electrical suppliers, you can find 3M friction tape at your nearest big orange box (HD).
Part number: 3407NA-BA-6 It's $2.97 per roll of 3/4" wide.
(friction tape is that nice cotton wrap anti-abrasion tape).
Orchid70
Sweden
C?ID=354348
Thanks Dunwood - had no idea what that "cloth" tape was called - but thats what I used, abundantly. Im going to need to buy a new roll after this =)
Do any of you guys have seen this in petrol cars too?
Not a nice job to do in vain.....
MartinsX
Riga, Latvia
C?ID=268515
Yes, last week have repaired Skoda Fabia 1,2l 3-cyl gas. One wire for fuel injector was completely cut and some 7-8 another wires partially damaged in the same place.
MartinsX
Riga, Latvia
C?ID=268515
MY 2000 is Passat B5 - different wiring layout, different materials used, mainly wires wrapped with tape, including looms fitted in corrugated tubes.
