VW Passat b7 Fault Codes need help
Mihnea Florin
C?ID=326226
Hello
I have a few fault codes on my vw passat b7 2.0 diesel and I need some help/info how to fix it if possible.
I am more interested in 3 modules with fault. Engine, Auto HVAC and Battery Regulator as I have battery light on.
After scan I saw that batery voltage at start/end it`s 11.6v usually it was over 14v.
Thank you in advance.
Monday,18,November,2019,14:00:52:14860
Dealer/Shop Name:
Workshop Code: 000 00000 000001
VIN: WVWZZZ3CZCE105450   License Plate:
Mileage: 266000km-165284mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61
          62 65 72
VIN: WVWZZZ3CZCE105450   Mileage: 266000km-165284miles
   Part No SW: 03L 906 018 PR    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H25 2291
   Revision: 41H25---    Serial number: 00000000000000
   Coding: 00190012042501080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM20TDI01103L906018PR 003002
   ROD: EV_ECM20TDI01103L906018PR.rod
   VCID: 094F607EC9BAE28F9E9-805C
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [039] - -
          [Data bus on board diagnostic interface - J533Read out DTC]
                    Mileage: 265979 km
                    Date: 2019.11.17
                    Time: 12:44:24
                    Engine speed: 1397.00 /min
                    Normed load value: 49.4 %
                    Vehicle speed: 37 km/h
                    Coolant temperature: 40 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 11.760 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 4
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: -0.024 m/s²
                    Engine status: COENG_RUNNING
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V436 0023
   Revision: --H07---    Serial number: 00000004994546
   Coding: 0002992
   Shop #: WSC 05311 000 00000
   VCID: 71BF289ECDAABA4F369-8024
   Part No SW: 3AA 907 044 B    HW: 3AA 907 044 B
   Component: Climatronic   H03 0101
   Revision: 00001K01
   Coding: 0014004803
   VCID: 2F3BEEE6179EECBF60D-807A
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [008] - Open or Short to Plus
                    Reset counter: 80
                    Mileage: 265761 km
                    Date: 2019.11.05
                    Time: 23:52:14
   Part No SW: 3AA 937 087 G    HW: 3AA 937 087 G
   Component: BCM PQ47 H    421 0464
   Revision: BB421001
   Coding: 000000000000000000180080340081E403714E88416C81606480C7200041
   Shop #: WSC 05311 123 12345
   VCID: 3E25C3A2C0741537FBB-806A
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 02111  26  0612
   Coding: 00BF95
   Component: RLS 161111 05  54  0403
   Coding: 0630ED
01501 - Bulb for Blinkers; Rear Left (M6)
                    Fault Status: 00101010
                    Reset counter: 79
                    Mileage: 265753 km
                    Date: 2014.03.28
                    Time: 12:04:19
                        Term 15 Off
                    Voltage: 12.20 V
02738 - Bulb for Tail/Brake Light; Left
                    Fault Frequency: 10
                    Reset counter: 79
                    Mileage: 265753 km
                    Date: 2014.03.28
                    Time: 11:39:60
                        Term 15 Off
                    Voltage: 12.25 V
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631131800710
   Coding: 108001
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 7CA109AA9668C72795F-8028
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__102 VW10 HI   1918
   Revision: 23016000    Serial number: 003K0PP4FS5$
   Coding: 0012338
   VCID: 4CC1996A8AC8B7A765F-8018
   Subsystem 1 - Serial number: 6332MTS661053011
   Subsystem 2 - Serial number: 6342MTS646682991
   Subsystem 3 - Serial number: 6351HTS6MT1G0AKJ
   Subsystem 4 - Serial number: 6361HTS68TLH1AKJ
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20111031201071
   Coding: 018A250000
   VCID: 72BD2792C42C8157CF3-8026
   Coding: E20000
   Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
   Coding: 160F00
   Shop #: WSC 05314 115 12345
   VCID: 3537DC8EF5C2D66F2A1-8060
   Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway H41 1623
   Revision:   H41       Serial number: 231011F6000130
   Coding: 461007
   Shop #: WSC 05314 000 00000
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   VCID: 76B51B82A4C49D77E3B-8022
   Revision: A1001003    Serial number: 7661294997
   Coding: 020000
   VCID: 290F00FE29FA828FBE9-807C
   Part No SW: 3C0 035 279 G    HW: 3C0 035 279 G
   Component: RNS315-EU   H35 0263
   Serial number: VWZAZ2L3868259
   Coding: 040004010400100000011002
   Shop #: WSC 00015 115 12345
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 270B06C63F6EB4FFA8D-8072
   Component: EUR_W_V9  0069
1048596 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
          [woofer rear right open load]
                    Reset counter: 31
                    Mileage: 265016 km
                    Date: 2019.10.28
                    Time: 07:57:05
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0003845943
   Coding: 0202F7
   Shop #: WSC 05311 115 12345
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002573558
   Coding: 0002D0
67584 - Warning Light for Front Door
          B11F5 01 [008] - Electrical Failure
                    Fault Frequency: 11
                    Reset counter: 91
                    Mileage: 265016 km
                    Date: 2019.10.28
                    Time: 07:57:17
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 195    3301
   Revision: 00H22000
   VCID: 3537DC8EF942D66F2A1-8060
   Component:    KSG PQ47 ELV 043 0634
   Coding: 01910A0002864E763402941D7C08DFCE105C01
   Component: EZE_2         H41 1623
   Coding: 00000008
   VCID: 6FBB2EE6D79EACBF20D-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0003846829
   Coding: 0202F6
   VCID: 3635DB82E8C4DD7723B-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002577191
   Coding: 0002D0
                    Reset counter: 86
                    Mileage: 265837 km
                    Date: 2019.11.10
                    Time: 06:17:11
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000416988
   Coding: 0022167
   Component: Batt.regelung H41 1623
   Coding: 030F185A
   VCID: 71BF289EC1AABA4F369-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900982409
02252 - Generator
                    Reset counter: 54
                    Mileage: 265979 km
                    Date: 2014.04.09
                    Time: 12:43:25
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000076419
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
End----(Elapsed Time: 01:32, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
Check/verify connection between battery regulator module and alternator.
Check/verify connection between HVAC module and A/C compressor.
Mihnea Florin
C?ID=326226
Hi
I will check and come back with findings.
Thank you
Mihnea Florin
C?ID=326226
Hi. It was the alternator at fault and failed to charge the battery. It was changed with new one aftermarket today. After I clear all the DTC`s still remain few faults.
Please see the new auto scan and advice me if can be any major problems. I belive that faults are related to alternator not being OEM part but any help and advice will be much apreciated. Thank you
Tuesday,19,November,2019,15:52:12:14860
Dealer/Shop Name: Florin
Mileage: 266030km-165303mi   Repair Order:
          62 65 72
VIN: WVWZZZ3CZCE105450   Mileage: 266030km-165303miles
          U1008 00 [101] - -
                    Mileage: 266033 km
                    Date: 2019.11.19
                    Time: 15:33:18
                    Engine speed: 830.00 /min
                    Normed load value: 34.9 %
                    Coolant temperature: 65 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 14.020 V
                    Acceleration: 0.000 m/s²
   Component: J104   C2 450M V438 0023
   Coding: 0002992
   Revision: 00001K01
   Coding: 0014004803
   Revision: BB421001
   Coding: 00BF95
   Coding: 0630ED
   Coding: 108001
   Coding: 0012338
   Coding: 018A250000
   Coding: E20000
   Coding: 160F00
   Coding: 461007
03406 - Control Module for Battery Monitoring
                    Reset counter: 56
                    Mileage: 266033 km
                    Date: 2014.04.11
                    Time: 15:32:13
   Coding: 020000
                    Reset counter: 56
                    Mileage: 266033 km
                    Date: 2019.11.19
                    Time: 15:48:28
   Coding: 0202F7
   Slave Driver:
   Coding: 0002D0
   Revision: 00H22000
   Coding: 00000008
   Coding: 0202F6
   Slave Passenger:
   Coding: 0002D0
   Coding: 0022167
   Coding: 030F185A
02071 - Local Databus
                    Reset counter: 56
                    Mileage: 266033 km
                    Date: 2014.04.11
                    Time: 15:32:16
End----------(Elapsed Time: 01:36, VBatt start/end: 13.8V/13.8V)-----------
MartinsX
Riga, Latvia
C?ID=268515
Are You sure the aftermarket alternator is compatible? OE one communicates on LIN and reports it has a problem:
   Coding: 030F185A
02252 - Generator
                    Reset counter: 54
                    Mileage: 265979 km
                    Date: 2014.04.09
                    Time: 12:43:25
Replacement one doesn't communicate:
   Coding: 030F185A
                    Reset counter: 56
                    Mileage: 266033 km
                    Date: 2014.04.11
                    Time: 15:32:16
Mihnea Florin
C?ID=326226
No is not. I will need to find and buy an original alternator. I belived that will work any alternator witch will have same amp and volts. Thanks
Jef
HQ
When I worked at the dealer, I replaced a good number of aftermarket alternators... they just aren't up to par. IMHO, a good used unit (matching part number) is better than the aftermarket junk out there.
Mihnea Florin
C?ID=326226
I ordered a second hand unit with same part number much cheaper than aftermaket one. VW dealer quotet me today with £775 for new alternator and I couldn`t believe...
Becouse of aftermarket alternator stop/star funtion not working anymore. I will try to get a full refund from suplier for giving me wrong alternator.
MartinsX
Riga, Latvia
C?ID=268515
One more possibility is to repair Your original one. If it is Bosch made, a lot of OE Bosch spare parts are available. With Valeo is a bit harder to find needed parts and even more harder to find correct parts list or catalogue with correct part numbers.
Mihnea Florin
C?ID=326226
Thanks MartinX. It is Valeo. I belive that fault in CAN Gateway it's becouse of battery. When mechanic fitted the new alternator he disconected the battery for one hour. You think that battery need to be coded again? I have Halford one and don't have any BEM code on it.
MartinsX
Riga, Latvia
C?ID=268515
If Valeo, it will be easier and maybe even cheaper to replace it with good used original than repair it.
Battery need to be coded only if replaced.
Is fault code in GW returning after cleared?
Mihnea Florin
C?ID=326226
MartinsX I found one Valeo good used with same part number and specifications and also for stop/start. Yes fault in Gateway is returning all the time after cleared. It is possible that fault from Gateway to be becouse of the aftermarket alternator? I coded again same battery today but becouse don't have BEM code I just change one digit to looks like I fitted a new battery but not helps with fault from Gateway.
MartinsX
Riga, Latvia
C?ID=268515
It is possible. With aftermarket alternator shared LIN wire may be shorted to ground or positive = data exchange blocked (connector may be the same but in older type OE and a lot of aftermarket alternators there is DF/DFM signal on the same pin where should be LIN in Yours). I'm too tired to search in WD right now, sorry. Let's go deeper into this if fault remains when correct alternator is fitted ;)
