Results 1 to 10 of 12
Thread: Fault code C10E2
    New User
    Aug 2015
    Fault code C10E2
    I have a fault code on a 2013 1.2Tsi Golf C10E2 54 (008) - Missing calibration/Basic Setting Intermittent.
    Basically the hsa sometimes wont release. I did replaced the engine battery and 4days later this issue started. Not sure if that has any relationship to the issue.
    Can someone explain how to calibrate the Hsa using VCDS please?
    Many thanks,
    Secondaaaa
    Oct 2017
    Northwest UK
    Can you please post an autoscan. If you're not sure how to, see my signature.
    New User
    Aug 2015
    Thanks for getting back to me so fast. I will do as you have asked in a day or two as I need to get the car to do the scan.
    Thanks again,
    New User
    Aug 2015
    2013 Golf 1.2 TSI C10E2 Missing Calibration
    The HSA is often not releasing.
    Please can someone explain how to calibrate this?
    Many thanks,
    Secondaaaa
    Tuesday,19,November,2019,08:25:35:28900
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZAUZDP028678   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZDP028678   Mileage: 94583km-58771miles
    Address 01: Engine (J623-CJZB)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 E    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   H08 7695
       Revision: WAH08---
       Coding: 01110012230411082000
       Shop #: WSC 47161 001 1048576
       ASAM Dataset: EV_ECM12TFS01104E906016E 001011
       ROD: EV_ECM12TFS01104E906016H.rod
       VCID: 2447A4902FAB1B6FE3-8070
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 01FA8AA120222A74037D060701CB2580510454C06080A4F300280028C0
       Shop #: WSC 00028 028 00308
       ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
       VCID: 7DF1B1F4EC818AA7CC-8028
    32951 - Control Module for Electronic Parking Brake
              C10E2 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 96
                        Mileage: 94223 km
                        Date: 2019.11.07
                        Time: 12:51:06
    Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
       Part No SW: 5G0 907 426 J    HW: 5G0 907 426 J
       Component: AC Manuell    H01 0503
       Revision: 00001K06
       Coding: 00120004200100001000000000000000
       ASAM Dataset: EV_ACManueBHBVW37X 002017
       ROD: EV_ACManueBHBVW37X_002_VW37.rod
       VCID: 326B52C8655F85DF61-8066
    Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
       Part No SW: 5Q0 937 084 M    HW: 5Q0 937 084 M
       Component: BCM MQBAB B   H14 0106
       Serial number: 00011232500772
       Coding: 03000842C20100530FA44000000403081000000000000000000000000000
       ROD: EV_BCMBOSCH_010.rod
       VCID: 428B0208D5FF355FF1-8016
       Component: WWS    121113  042 0551
       Serial number:         121114152013
       Coding: 0E4DD5
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Serial number: 003F5R01FL01
       Shop #: WSC 00028 028 00059
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 408F0800DBF3274FE7-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 002 111 12
       Serial number: 35767000000416583C0O
       Subsystem 2 - Part No SW: -----------    HW: 480 002 111 12
       Serial number: 35867000000154C84C0W
       Subsystem 3 - Part No SW: -----------    HW: 480 401 112 12
       Serial number: 3516502AD0D46473518A
       Subsystem 4 - Part No SW: -----------    HW: 480 401 112 12
       Serial number: 3526502AD0CD5EC5635Z
       Subsystem 5 - Part No SW: -----------    HW: 480 400 412 12
       Serial number: 3556502AF0D5D621914J
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
       Revision: --------    Serial number: 05121208490046
       Coding: 0600
       Shop #: WSC 40195 333 37120
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 76E3AED8C9B7D9FF8D-8022
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
       Part No SW: 5G0 920 950     HW: 5G0 920 950
       Component: KOMBI         136 0555
       Coding: 27A402002380260001082800040000
       VCID: 65C1F9946411226734-8030
       Part No SW: 5Q0 907 530 D    HW: 5Q0 907 530 D
       Component: GW MQB Low    120 1109
       Revision: --------    Serial number: 0000166131
       Coding: 030000042B086400EF000048080E00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
       Serial number: 4221688601
       Part No SW: 5Q4 959 393     HW: 5Q4 959 393
       Component: TSG FS        007 0006
       Serial number: 0000045007537
       Coding: 003002208001020100001000
       VCID: 55A1C9543471B2E7A4-8000
       Coding: 01
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D7171F4AC014AA78C-8068
       Part No SW: 5Q4 959 392     HW: 5Q4 959 392
       Component: TSG BFS       007 0006
       Serial number: 0000046062703
       Coding: 003000208001020100801000
       VCID: 7F0D4BFCE68D98B7DE-802A
       Part No SW: 5G0 035 820     HW: 5G0 035 820
       Component: MU-S-D-ER     038 0130
       Serial number: V5C01012120690
       Coding: 02730000FF0000002111120100A800001F0100060100010001
       ASAM Dataset: EV_MUStd4CPASE 002036
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 5EB3D678414771BFF5-800A
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H44 0020
       Serial number: VWZ8Z9M24012AF
    End-------------------------(Elapsed Time: 03:22)--------------------------
    New User
    Aug 2015
       Revision: WAH08---
                        Reset counter: 96
                        Mileage: 94223 km
                        Date: 2019.11.07
                        Time: 12:51:06
       Revision: 00001K06
       Coding: 0E4DD5
       Coding: 0600
       Coding: 01
    Sep 2015
    This procedure might help: https://forums.ross-tech.com/showthr...l=1#post104517
    At least worth trying.
  7. #7
    New User
    Aug 2015
    Thanks but I have already tried this & it did not work.
    Secondaaaa
  8. #8
    Threads merged. We do not need or want two threads with the same question about the same car.
  9. #9
    Quote Originally Posted by Secondaaaa View Post
    Many thanks,
    Secondaaaa
    Secondaaaaaaaaaaaaaaaaaaaaa................. !!! Hi.
    I'm not sure how to address your problem (other than myounus suggestion) - but in respect of your suspicion regarding the battery replacement, my belief is that this is not the case because of the supporting records in your DTC.
    The time date stamp on the DTC is Date: 2019.11.07 Time: 12:51:06. . This means that the fault was first recorded 12 days before the date of your auto-scan (i.e. 8 days before the battery replacement). The further record Fault Frequency: 2 also indicates that since first appearing, the fault has only re-occurred once more.
    So, without intending any offense, or implication - what was the car doing @ around mid-day-ish on 7th November? Perhaps have a look @ the AdpLog.CSV & CodingLog.CSV files in the c:\Ross-Tech\VCDS\Debug sub-directory on your laptop for records around this time- maybe?
  10. Likes Uwe, MartinsX liked this post
  11. #10
    New User
    Aug 2015
    Secondaaaa
    I do apologize Uwe. I am new to these forums & am finding how to use it a bit difficult and would ask to be forgiven for my mistakes.
    Many thanks,
    Secondaaaa
  12. Likes Uwe liked this post
