Mk7.5 GTE Euro LED Headlights to Mk7.0 GTI USA Car
I threw a pair of OEM 2019 Golf GTE European market headlights onto a 2015 USA Market GTI, with the correct matching modules etc for the GTE.. The wiring physically plugged in
The headlights could be installed once I installed 7.5 Fenders and a TCR bumper to match
The result was about what I expected from this random experiment : the lowbeam LEDs worked, highbeams did not, turn signals did not.
Here's the scan after this (and while the steering wheel was removed)..:
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: 3VW5T7AU4FM015918 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75 A9 VIN: 3VW5T7AU4FM015918 Mileage: 167326km-103971miles 01-Engine -- Status: Malfunction 0010
Address 01: Engine (J623-CXCA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0004
Revision: --H13---
Coding: 091900122424002F1000
Shop #: WSC 00066 790 00020
ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: AC144E26C747CF2F95-80F8 2 Faults Found:
15188 - Oil Pressure Switch
P164B 00 [032] - Malfunction
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:24 Engine speed: 3315.50 /min
Normed load value: 46.3 %
Vehicle speed: 163 km/h
Coolant temperature: 88 °C
Intake air temperature: 1 °C
Ambient air pressure: 830 mbar
Voltage terminal 30: 14.570 V
Unlearning counter according OBD: 32
Engine: operating status: PL
STATE_LS_SAE[1]: OL_INTR
T_AST_SAE: 0 s
MAP_MES_SAE: 236 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.772 V
FAC_TPS_1_SAE: 86.328125 %
FUP_H_SAE: 17450.0 kPa 19854 - Steering Column Control Module
U0212 00 [047] - No Communications
Fault Frequency: 19
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:24 Engine speed: 3302.00 /min
Normed load value: 37.3 %
Vehicle speed: 162 km/h
Voltage terminal 30: 14.472 V
ECU_STATE: SYN_ENG_IGK_ON
Engine oil temperature: 106.0 °C
Time since engine start: 5233.3 s
T_ES: 0 min
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Main switch CAN: not activated
Cruise control switch actuation-Control component verified: No
STATE_ERR_ABC_PRED: 0 Readiness: 0000 0001 -------------------------------------------------------------------------------
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 51584000001157
Coding: 01FA6BA1342109710080020181CB2980D62C9000408194B400430050C009
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
VCID: C4C406864FD7276F7D-8090 2 Faults Found:
0297 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
Reset counter: 179
Mileage: 167312 km
Date: 2019.11.02
Time: 00:09:48 16390 - Display for Tire Pressure Monitoring
Reset counter: 179
Mileage: 167312 km
Date: 2019.11.02
Time: 00:09:58
Revision: 00021000 Serial number: 0335526990
Coding: 030C0C
VCID: BA38787E3D13619F17-80EE No fault code found. -------------------------------------------------------------------------------
Part No SW: 5G0 907 044 AN HW: 5G0 907 044 AN
Component: Climatronic H03 0907
Revision: 00001K08
Coding: 00020014200100000005000012111800
VCID: F3A6955A5AF9D0D714-80A6 Fresh Air Blower Front: Geber für Kältemitteldruck/Kältemitteltemperatur: Air quality sensor: 3 Faults Found:
459015 - Databus
[Feuchtesensor innen - kein Signal/Kommunikation]
Reset counter: 171
Mileage: 166899 km
Date: 2019.11.01
Time: 07:15:19 263426 - Air Quality Sensor
B10AF 31 [008] - No Signal
Reset counter: 211
Mileage: 167272 km
Date: 2019.11.01
Time: 15:32:03 Voltage terminal 30: 11.8 V
Outside air temperature: 20.5 °C
System run time-Terminal 15 on: 9 s 262658 - High Pressure Sensor
B10AE 31 [008] - No Signal
Reset counter: 211
Mileage: 167272 km
Date: 2019.11.01
Time: 15:32:00 Outside air temperature: 20.5 °C
Engine speed: 0 /min
Temperature after evaporator: 36.0 °C
System run time-Terminal 15 on: 6 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 N HW: 5Q0 937 087 N
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86580207140662
Coding: 00110A464041A2E969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00145
ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
ROD: EV_BCMBOSCH_013.rod
VCID: C6C01C8E79EB157F63-8092 Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140611 043 0581
Serial number: 140712033619
Coding: 0E4DDD Sun Roof:
Subsystem 2 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO2834025+
Coding: 181801 10 Faults Found:
558100 - Databus
[Airbag_02 Datenbus empfangener Fehlerwert]
Fault Frequency: 21
Reset counter: 174
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:22 919560 - Light Switch
B126A 29 [136] - Signal Implausible
Reset counter: 211
Mileage: 167272 km
Date: 2019.11.01
Time: 16:30:09 5130 - Bulb for Front Left Turn Signal
B11E8 15 [009] - Open or Short to Plus
Reset counter: 171
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:37 5386 - Bulb for Front Right Turn Signal
B11EA 15 [009] - Open or Short to Plus
Reset counter: 171
Mileage: 166914 km
Date: 2019.11.01
Time: 07:20:54 15626 - Bulb for Left Brake Lamp / Turn Signal
B1333 15 [008] - Open or Short to Plus
Reset counter: 211
Mileage: 167219 km
Date: 2019.11.01
Time: 10:10:46 18698 - Left LED Module for DRL and Parking Lights
B12EC F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 171
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:24 19210 - Right LED Module for DRL and Parking Lights
B12ED F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 171
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:24 934148 - No Communications with Rain/Light Sensor
U10F6 00 [009] - -
[Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
Reset counter: 171
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:22 939524 - No Communications with Humidity Sensor
U10F5 00 [009] - -
[Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
Reset counter: 171
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:26 329480 - Heated Passenger Seat
B1806 F0 [009] - Safety Shut-Off due to Occupant Detection
Fault Frequency: 30
Reset counter: 179
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:32
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM00FUM2
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: D1EA3FD280A5C2C7C6-8084 Occupant Detection:
Subsystem 1 - Part No SW: ----------- HW: -----------
Component: BF-Gewichtss. --- ----
Serial number: ---0000---000-----09
Coding: 2D2D2D Side Sensor Driver Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 704 14
Serial number: 357000000001D1D46F0P
Coding: 2D2D2D Side Sensor Passenger Front:
Subsystem 3 - Part No SW: ----------- HW: 480 002 105 14
Serial number: 35800000000B20F4EF0Y
Coding: 2D2D2D Side Sensor Driver Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 402 904 14
Serial number: 3510002C7157E9D263BF
Coding: 2D2D2D Side Sensor Passenger Rear:
Subsystem 5 - Part No SW: ----------- HW: 480 402 904 14
Serial number: 3520002C7157E9D1E33F
Coding: 2D2D2D Front Sensor Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 205 14
Serial number: 3550002BB15C4211238X
Coding: 2D2D2D Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 205 14
Serial number: 3560002BB15C421252F1
Coding: 2D2D2D 12 Faults Found:
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:31 9440539 - Driver's Safety Belt Tensioner Igniter 2
B100D 1B [137] - Resistance Too High
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:31 9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:31 9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:31 9438747 - Igniter for Seat Belt Tensioner; Driver's Side
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:31 9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:31 9441051 - Front passenger's safety belt tensioner igniter 2
B100F 1B [137] - Resistance Too High
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:31 9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:31 9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [137] - Resistance Too High
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:31 9444885 - Driver's seat position sensor
B101E 15 [137] - Open or Short to Plus
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:32 9445141 - Passenger's seat position sensor
B101F 15 [137] - Open or Short to Plus
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:31 9445937 - Seat occupied recognition control module
B1022 31 [137] - No Signal
Fault Frequency: 49
Reset counter: 179
Mileage: 163776 km
Date: 2019.10.28
Time: 19:26:34
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0155
Revision: FF028028 Serial number: 20140517400074
Coding: 0400
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 8444C6860F57E76F3D-80D0 No fault code found. -------------------------------------------------------------------------------
Part No SW: 5G1 920 856 HW: 5G1 920 856
Component: KOMBI 342 4270
Coding: 0BAD09122980CF0502087E001000000000000000
VCID: EB968D3A02C90817DC-80BE No fault code found. -------------------------------------------------------------------------------
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 12061410000535
Coding: 0101000820085900EF00022A080F00000001050000000000000000000000
Shop #: WSC 00066 790 00149
ROD: EV_GatewConti_011.rod
VCID: C2C8009E55C3295F4F-8096 Alternator: 2 Faults Found:
131612 - No Communications with Actuator for Structural Accoustics
U10DF 00 [008] - -
[Timeout Knoten 0x1C / A9 - Aktuator für Körperschall]
Reset counter: 211
Mileage: 167272 km
Date: 2019.11.01
Time: 15:32:02 Supply voltage: Terminal 30: 12.3 V
Terminal 15: On 197169 - Controls in Steering Wheel
[MFL (LIN#2) Timeout]
Reset counter: 179
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:30 Supply voltage: Terminal 30: 14.7 V
Terminal 15: On
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000147474001
Coding: 5500000000000000
Shop #: WSC 00066 790 07029
ROD: EV_ELVMarquMQB.rod
VCID: B42456461F7797EFCD-80E0 No fault code found. -------------------------------------------------------------------------------
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 030714060503DV
Coding: 003E13200000040000000000
VCID: C0CC0A965BCF3B4F59-8094 Drivers Door Rear Control Module:
Serial number: 00000000000002833002
Coding: 011000 No fault code found. -------------------------------------------------------------------------------
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
ROD: EV_SteerAssisMQB_010.rod
VCID: B5226B42140D8EE7FA-80E0 2 Faults Found:
12288 - Supply voltage
[Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung]
Reset counter: 40
Mileage: 167326 km
Date: 2019.11.13
Time: 03:08:45 Motor status: 01
Supply voltage: 6.00 V
Temperature: 44.0 °C
KFC: 30
KFA: 00 01
Environmental conditions: 21
uioUdNotFilt_xdu16: 5.17 V
uAdSensI_SwitchedKl30_xdu16: 5.18 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00 16135 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Reset counter: 40
Mileage: 0 km Motor status: 00
Supply voltage: 12.75 V
Temperature: 9.0 °C
KFC: 3F
KFA: 00 07
uioUdNotFilt_xdu16: 12.77 V
uAdSensI_SwitchedKl30_xdu16: 12.76 V
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 040714060500G7
VCID: BFCE096A263144B720-80EA Passengers Rear Door Control Module:
Serial number: 00000000000002814627
Coding: 191000 No fault code found. -------------------------------------------------------------------------------
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021A01010B000400
VCID: C0CC0A965BCF3B4F59-8094 6 Faults Found:
5276144 - Power Output Module for Left Headlamp
C1081 F0 [137] - Not Coded
Reset counter: 171 5276400 - Power Output Module for Right Headlamp
C1082 F0 [137] - Not Coded
Reset counter: 171 13679104 - Local Data Bus
U10BA 00 [137] - No Communication
Fault Frequency: 81
Reset counter: 179
Mileage: 167272 km
Date: 2019.11.01
Time: 18:06:18 5275953 - Power Output Module for Left Headlamp
C1081 31 [008] - No Signal
Fault Frequency: 49
Reset counter: 219
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:31 5276209 - Power Output Module for Right Headlamp
C1082 31 [008] - No Signal
Fault Frequency: 51
Reset counter: 219
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:31 13705478 - Databus
[RLS_01 Datenbus fehlende Botschaft]
Reset counter: 171
Mileage: 166900 km
Date: 2019.11.01
Time: 07:15:31
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 014 0645
Serial number: V7B00806140972
Coding: 027300020000000021220002001800001F0203340100010546
ROD: EV_MUStd4CPASE_VW37.rod
VCID: E99AF73208351A07AE-80BC Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9PS6003PU Data medium:
Subsystem 2 - Part No SW: 5G0 919 866 H HW: -----------
Component: NAR 2014/15 --- 0020
Serial number: -------------------- 1 Fault Found:
7219 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 219
Mileage: 163798 km
Date: 2019.10.30
Time: 15:46:28 Voltage terminal 30: 14.2 V
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 HW: 5QE 035 285
Component: OCULowMQBUS 006 0528
Coding: 02730002C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
VCID: 8248C09E1543E95F0F-80D6 No fault code found. -------------------------------------------------------------------------------
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 140422200134
VCID: EB968D3A02C90817DC-80BE No fault code found. End----------(Elapsed Time: 01:35, VBatt start/end: 12.4V/12.4V)-----------
Can you advise what the OEM lights are - are they genuine VW lights or an aftermarket version?
Which 'correctly mnatching modules' did you plug in? You have module 55 in this scan and I'm pretty sure those light run off a 4b multifunction module.
Post Thanks / Like - 2 Likes
^^^ myounus: all very good questions indeed!! However, interesting dynamic in the auto-scan - the hex55 module in the scan summary is missing from the detailed report - how does this happen (since there is no "communication failure" DTC for this module)? The "recipient" car did have HIDs originally because BCM Byte 2, Bits 0-1 =hex02 and because of the suggestion of a hex55 module in the auto-scan - very odd!!
Plus, interesting DTCs all round - was this car in an accident (air-bag module DTCs)?? Perhaps OP can try deleting ALL DTCs and re-post in an attempt to clean-up the auto-sacan?
Post Thanks / Like - 1 Likes
Originally Posted by
myounus
Thanks for the help!!
The lights are genuine, which were supplied directly from VW AG, using the following part numbers:
GTE LED headlight left - blue stripe 5G1941077B
GTE LED headlight right - blue stripe 5G1941078B
These were the modules I ordered (By my own rushed research on ETKA):
Module 8V0907399D x 2
Module 7P5941572A x 2
DV52
The car is now in a shipping container heading to South America where I'm going to attempt to navigate across the complete continent in under 3 weeks, so no scans until it and I arrive, haha.
I'm going to take it straight to a dealership in Colombia to fix / finish whatever I can before we start the drive proper.
The steering wheel (and seats) were replaced with race versions, to match the roll cage that was installed.
Correct on the car having the OEM 2015 HID lights originally
The only DTC I did *not* expect was the oil pressure switch. I literally scanned the car inside the container as it left, so I'm planning to take a oil pressure gauge with me..
DV52 liked this post
Hi, as long you fitted the correct BCM/FCM/Gateway and wiring is 100% correct, it can be coded with ODIS online to match the coding / correct Parametrization and then with VCDS to match BCM to car preparations.
if you need help, send me a message
Regards
k.barghouthi
VCDS to match
Regards
No it's not that simple. ODIS will not simply paramaterise them but they are not from this VIN. Someone with the knowhow or another tool will be required. VCDS cannot do this.
Well you found the Guy, i did 3 cars like this with ODIS
, we know how to parametrize the control units.
Regards
k.barghouthi
VCDS to match
Regards
I didn't change the BCM, and haven't changed the pins etc on the wiring.. By the time I got to the car it was time to start driving unfortunately. I can log into ELSA and check the wiring for both cars (if I can see the European GTE car - it's often region locked under the USA account).
The car will be at a dealership in Colombia next week, where I have told I can use their ODIS, and I'll have my VCDS of course.
