2013 S5 Central Control Module
Dave_Loeppky
C?ID=384794
I just purchased this car (62,000 miles). The previous owner had the card at the Audi dealer to advise the car needed a new Central Control Module. I purchased Ross-Tech and confirmed the Central Control Modul had faults (and the horn, A/C and rear park sensors were not working). I copied the current coding from the original Central Control Code, installed a used Central Control Module (that I purchased from an AUDI auto salvage company), and copied and programed the same code into the new (used) Central Control Module. The current coding is:
26000091863CAFE02C0048C300003D0D0F9C9388A209022100000800000007
The original problems are now fixed (Horn works, A/C works, rear park sensors are working). But there are new problems:
- error codes below
- interior lights do not work.
- dash lights are on dim and are not adjustable.
- the adaptive light error light appears on my dash.
Any advice or suggestions are most welcome.
Sunday,17,November,2019,17:02:20:55671
VIN: WAU3GAFR6DA013904   License Plate:
Chassis Type: FR-AU48 (8R0)
Scan: 01 03 05 06 08 09 14 15 16 17 19 22 36 3C 42 44 46 47 52 53
          56 5F 6C A9
VIN: WAU3GAFR6DA013904   Mileage: 100940km-62721miles
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---
   Coding: 1A190034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: 38292FAA32DE1CB7317-806C
Readiness: 0010 0100
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Coding: 281D1A
   Shop #: WSC 06325 000 00000
   VCID: 04518B5A3E168857EDF-8050
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H11 0621
   Coding: 0F804000000000000000
   VCID: 015F824E21049D7FC69-8054
   Serial number: 2312000137367006
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000033367052
   Coding: 00037025002C00000000
   VCID: 45D7565E75AC715FBA1-8010
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01010720120132
   Coding: 6602228000
   VCID: 392F2AAE095405BFCE9-806C
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000765052001
   Coding: 26000091863CAFE02C0048C300003D0D0F9C9388A2090221000008000000070200020030000000
   Shop #: WSC 06325 123 104857
   VCID: 7AADF5A24CD2CEA7873-802E
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 260612  H15 0080
   Serial number: SWF12060260585
   Coding: 00FD11
   Serial number: 20372889
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002106121592
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R24F602
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 43A88636000000000001
                    Reset counter: 24
                    Mileage: 100938 km
                    Date: 2019.11.17
                    Time: 10:15:23
02658 - Power Output Stage for Left Headlight (J667); Incorrectly Coded
                    Reset counter: 24
                    Mileage: 100940 km
                    Date: 2019.11.17
                    Time: 12:38:04
02659 - Power Output Stage for Right Headlight (J668); Incorrectly Coded
                    Reset counter: 24
                    Mileage: 100940 km
                    Date: 2019.11.17
                    Time: 12:38:04
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 20061204830002
   Coding: 010181
   VCID: 3A2D35A20C520EA7C73-806E
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD90DE8D
   Coding: 303343334830303030304A55304C38543053
   VCID: 4ACD65625C329E27573-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R1200009FR4
   Serial number: 6334MSME6F455428M
   Serial number: 6344MSME6F407336I
   Serial number: 6352QSME2F14235CL
   Serial number: 6362QSME1A1C4450F
   Serial number: 63732SME28171270R
   Serial number: 63832SME25170446T
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20120704000888
   Coding: 000016
   VCID: 51FF720EB1E4ADFF169-8004
   Component: E221 - MFL  H03 0003
   Part No SW: 8T0 920 983 P    HW: 8T0 920 983 P
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RAU77JW6D
   Coding: 8BB501009B01D705020000
   VCID: 4BC3606653C8872F6C5-801E
   Part No SW: 8R0 907 468 J    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0051
   Revision: 1Z090025    Serial number: 2541Z1261000EE
   Coding: 80C303FF00
   VCID: 46D5515248AA7A47B3B-8012
   Serial number: 1847867701
                    Reset counter: 23
                    Mileage: 100938 km
                    Date: 2019.11.17
                    Time: 10:45:21
                    Bin. Bits:    11111
                    Voltage: 12.20 V
                    Count: 6
                    Text: 3F73748E04828104
                    Text: 0000000000000000
                    Raw, Form. N/A: 000 000 000
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 002206120001016
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
   VCID: 2F3B14F6C790DB0F60D-807A
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000033369926
   Coding: 001B7B25002C00000000
   Part No SW: 8T0 907 566 A    HW: 8T0 907 566
   Component: SWA Master    H17 0040
   Serial number: 0179325956
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: 3E2539B210FA2287FBB-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
   Component: SWA Slave  H17 0040
   Serial number: 0179335352
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13224E00120102
   VCID: 56F58112980ACAC7C3B-8002
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0013651286
   Coding: 100000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311B9A2EB6F8D71DF-8060
   Revision: 00002001    Serial number: 0179750233
   Coding: 0106029A00FA404580B0003200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000540837
   Component: J245EE20SKB13  H03 0220
   Revision: 00005001    Serial number: 94813004331602
   VCID: 2D070EFECD1CA91F521-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55F7861E850CC1DFCA1-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000067422
   ROD: EV_ParkiBrake_AU48.rod
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156G10C7610959
   Coding: 020007010000000001
   VCID: 211FE2CE81C47D7FE69-8074
   Part No SW: 8R1 035 746 B    HW: 8R1 035 746 B
   Component: H-BNT-NA      H43 0552
   Revision: --------    Serial number: 204GO0C7507301
   Coding: 140200020206A1EF55028B4E00000403140000000000000000
   VCID: 36352192384AEAC723B-8062
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Component: DU7 High  H41 0104
   Serial number: A130G$0CS201801
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001202139
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Revision: --H07---    Serial number: 525PA8-J2493W9
   Coding: 1000008
   VCID: 38292FAA3E5E1CB7317-806C
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 120612200528
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72BDDD821422B6E7CF3-8026
End----------(Elapsed Time: 01:49, VBatt start/end: 12.3V/12.2V)-----------
"Component Protection" will have to be dealt with by the dealer (or an independent with the requisite credentials to access the VW/Audi corporate server).
Do you have a scan from a time when the original module was still in the car?
DrPeter
16.4905° S, 151.7375° W
Just throwing this out, but it seems that many dealerships are not willing or able to run the 'SVM / Actual vs. Specified test plans' with used controllers.
You could go in there and ask them to try it? but unknown if they will? On the other hand you could drop it off and tell them the light is on and see what happens.
You could also check the Adaptation channels of the old controller and make changes to the new/used controller as needed, see if that helps.
Hope it works out for you,
drpeter
Dave_Loeppky
C?ID=384794
Thank you. I will ask a Certifed Audi Repair to take care of the "Component Protection".
As for the original module scan, I do have one = however - only as pdf (below), not as a csv that I can put between the quotes.
Thank you for your help.
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Release 19.6.2(x64) Data version: 20190930 DS308.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Tuesday,29,October,2019,21:40:30:55671
VIN: WAU3GAFR6DA013904   License Plate: SJ 00109 Mileage: 99900km-62074mi   Repair Order: Sharon
Chassis Type: FR-AU48 (8R0) Scan: 01 03 05 06 08 09 14 15 16 17 19 22 36 3C 42 44 46 47 52 53          56 5F 6C A9
VIN: WAU3GAFR6DA013904   Mileage: 99900km-62074miles
01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 14-Susp. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 A9-Struct. Borne Sound -- Status: OK 0000 ------------------------------------------------------------------------------Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A   Component: 3.0l V6 TFSIH07 0004     Revision: --H07---       Coding: 1A190034052600060000   Shop #: WSC 06208 000 00000   ASAM Dataset: EV_ECM30TFS0218K5907551E 001004   ROD: EV_ECM30TFS0218K5907551E.rod   VCID: 38292FAA32DE1CB7317-806C
No fault code found. Readiness: 0000 0000
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 2
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK   Component: ESP8 quattro  H09 0100     Revision: --------    Serial number: -------------   Coding: 281D1A   Shop #: WSC 06325 000 00000   VCID: 04518B5A3E168857EDF-8050
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 3
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM   Component: BCM2 2.0      H11 0621     Revision: 00002001       Coding: 0F804000000000000000   Shop #: WSC 06325 000 00000   VCID: 015F824E21049D7FC69-8054
   Subsystem 1 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E   Component: J764 ELV MLB  H40 0046    Serial number: 2312000137367006
3 Faults Found: 01330 - Central Control Module for Central Convenience (J393)         013 - Check DTC Memory         Freeze Frame:                Fault Status: 01101101                Fault Priority: 6                Fault Frequency: 2                Reset counter: 250                Mileage: 93939 km                Time Indication: 0                Date: 2019.06.18                Time: 17:12:49
02823 - Requirements for Locking the Steering Column Lock not met         000 -          Freeze Frame:                Fault Status: 01100000                Fault Priority: 5                Fault Frequency: 1                Reset counter: 250                Mileage: 93939 km                Time Indication: 0                Date: 2019.06.19                Time: 10:33:46
00955 - Key 1         002 - Lower Limit Exceeded         Freeze Frame:                Fault Status: 01100010                Fault Priority: 3                Fault Frequency: 1                Reset counter: 224                Mileage: 99527 km                Time Indication: 0                Date: 2019.10.22                Time: 08:52:03
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 4
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E   Component: MEM-BFS       H10 0076     Revision: AA000000    Serial number: 00000033367052   Coding: 00037025002C00000000   Shop #: WSC 06325 000 00000   VCID: 45D7565E75AC715FBA1-8010
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 5
Address 08: Auto HVAC (J255)       Labels: Redir Fail!   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T   Component: KLIMA 3 ZONEN H04 0121     Revision: C1000000    Serial number: 01010720120132   Coding: 6602228000   Shop #: WSC 06325 000 00000   VCID: 392F2AAE095405BFCE9-806C
3 Faults Found: 00898 - Control Circuit A/C compressor         008 - Implausible Signal - Intermittent         Freeze Frame:                Fault Status: 00101000                Fault Priority: 6                Fault Frequency: 72                Reset counter: 25                Mileage: 96738 km                Time Indication: 0                Date: 2019.10.04                Time: 17:00:45
         Freeze Frame:                Current: 0.630 A                Current: 0.000 A                Voltage: 13.80 V
00457 - Central Electronics Control Module / BCM (J519)         013 - Check DTC Memory - Intermittent         Freeze Frame:                Fault Status: 00101101                Fault Priority: 6                Fault Frequency: 1                Reset counter: 252                Mileage: 99178 km                Time Indication: 0                Date: 2019.10.14                Time: 20:12:58
00256 - A/C Pressure/Temperature Sensor (G395)         008 - Implausible Signal - Intermittent         Freeze Frame:                Fault Status: 00101000                Fault Priority: 7                Fault Frequency: 1                Reset counter: 252                Mileage: 99178 km                Time Indication: 0                Date: 2019.10.14                Time: 20:12:58
         Freeze Frame:                Temperature: 14.0°C
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 6
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 7
Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ   Component: BCM1 1.0      H16 0103     Revision: 09016001    Serial number: 00000439069902   Coding: 26000091863CAFE02C0048C300003D0D0F9C9388A2090221000008000000070200020030000000   Shop #: WSC 42927 001 1048576   VCID: 7AADF5A24CD2CEA7873-802E
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB   Component: WWS 260612  H15 0080    Serial number: SWF12060260585         Coding: 00FD11
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB   Component: G397_RLFS  H06 0002    Serial number: 20372889               Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS   Component: E1 - LDS  H03 0031    Serial number: 00000000002106121592
   Subsystem 4 - Part No SW: 4G0 907 410 A    HW: 4H0 907 410 A   Component: USHL4.2  H30 0030    Serial number: 0000002274555R24F602
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329 H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329 H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658    Component: AQ_Hum_Sensor  H03 0003    Serial number: 43A88636000000000001
7 Faults Found: 00910 - Indicator Lamp for Emergency Flashers (K6)         012 - Electrical Fault in Circuit         Freeze Frame:                Fault Status: 01101100                Fault Priority: 2                Fault Frequency: 1                Reset counter: 250                Mileage: 93939 km                Time Indication: 0                Date: 2019.06.18                Time: 17:12:51
01232 - A/C Compressor Regulator Valve (N280)         012 - Electrical Fault in Circuit - Intermittent         Freeze Frame:
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 8
                Fault Status: 00101100                Fault Priority: 2                Fault Frequency: 19                Reset counter: 25                Mileage: 96738 km                Time Indication: 0                Date: 2019.10.04                Time: 17:00:42
02638 - Enabling Steering Column Lock         012 - Electrical Fault in Circuit         Freeze Frame:                Fault Status: 01101100                Fault Priority: 2                Fault Frequency: 1                Reset counter: 250                Mileage: 93939 km                Time Indication: 0                Date: 2019.06.18                Time: 17:23:48
01543 - Parking Aid Warning Chime (H15)         009 - Open or Short to Ground         Freeze Frame:                Fault Status: 01101001                Fault Priority: 3                Fault Frequency: 254                Reset counter: 240                Mileage: 93939 km                Time Indication: 0                Date: 2019.06.18                Time: 19:41:31
03266 - Control Circuit for Signal Horn         012 - Electrical Fault in Circuit         Freeze Frame:                Fault Status: 01101100                Fault Priority: 2                Fault Frequency: 1                Reset counter: 250                Mileage: 93939 km                Time Indication: 0                Date: 2019.06.19                Time: 09:10:15
00256 - A/C Pressure/Temperature Sensor (G395)         004 - No Signal/Communication - Intermittent         Freeze Frame:                Fault Status: 00100100                Fault Priority: 3                Fault Frequency: 1                Reset counter: 252
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 9
02894 - Valet Parking Indicator Lamp (K159)         012 - Electrical Fault in Circuit         Freeze Frame:                Fault Status: 01101100                Fault Priority: 2                Fault Frequency: 1                Reset counter: 223                Mileage: 99470 km                Time Indication: 0                Date: 2019.10.21                Time: 12:42:12
------------------------------------------------------------------------------Address 14: Susp. Elect. (J250)       Labels: None   Part No SW: 8R0 907 364 C    HW: 8K0 907 364    Component: DAEMPFUNGS-SG H09 0054     Revision: 00000000    Serial number: 20061204830002   Coding: 010181   Shop #: WSC 06325 000 00000   VCID: 3A2D35A20C520EA7C73-806E
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 10
Address 15: Airbags (J234)       Labels:* 8K0-959-655.clb   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P   Component: AirbagVW-AU10 H45 0610     Serial number: 003KJD90DE8D     Coding: 303343334830303030304A55304C38543053   Shop #: WSC 06325 000 00000   ASAM Dataset: EV_AirbaECUVWAUDI010 003010   ROD: EV_AirbaECUVWAUDI010_003_AU48.rod   VCID: 4ACD65625C329E27573-801E
   Seat occupied recognition:    Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A   Component: BF-Gewichtss.  H02 0060    Serial number: 5810000R1200009FR4
   Crash sensor for side airbag: driver side:    Serial number: 6334MSME6F455428M
   Crash sensor for side airbag: front passenger side:    Serial number: 6344MSME6F407336I
   Crash sensor for side airbag: rear: driver side:    Serial number: 6352QSME2F14235CL
   Crash sensor for side airbag: rear: passenger side:    Serial number: 6362QSME1A1C4450F
   Crash sensor for front airbag: driver side:    Serial number: 63732SME28171270R
   Crash sensor for front airbag: front passenger side:    Serial number: 63832SME25170446T
------------------------------------------------------------------------------Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S   Component: Lenks.Modul   H07 0171     Revision: 00000000    Serial number: 20120704000888   Coding: 000016   Shop #: WSC 06325 000 00000   VCID: 51FF720EB1E4ADFF169-8004
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 11
Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb   Part No SW: 8T0 920 983 P    HW: 8T0 920 983 P   Component: KOMBIINSTR.   H35 0553     Revision: 00000000    Serial number: RAU77JW6D        Coding: 8BB501009B01D705020000   Shop #: WSC 06325 000 00000   VCID: 4BC3606653C8872F6C5-801E
------------------------------------------------------------------------------Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb   Part No SW: 8R0 907 468 J    HW: 8R0 907 468 D   Component: GW-BEM 5CAN-M H11 0051     Revision: 1Z090025    Serial number: 2541Z1261000EE   Coding: 80C303FF00   Shop #: WSC 06325 000 00000   VCID: 46D5515248AA7A47B3B-8012
   Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181    Component: J367-BDMHella  H03 8041    Serial number: 1847867701
------------------------------------------------------------------------------Address 22: AWD (J492)       Labels: 8K0-907-163.clb   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A   Component: 4 Wheel Drive H13 0100     Serial number: 002206120001016   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019   ROD: EV_AllWheelDiffeQSPCAN.rod   VCID: 2F3B14F6C790DB0F60D-807A
------------------------------------------------------------------------------Address 36: Seat Mem. Drvr (J136)       Labels:. 8T0-959-760.clb   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E   Component: MEM-FS        H10 0076     Revision: AA000000    Serial number: 00000033369926   Coding: 001B7B25002C00000000   Shop #: WSC 06325 000 00000   VCID: 45D7565E75AC715FBA1-8010
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 12
Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb   Part No SW: 8T0 907 566 A    HW: 8T0 907 566    Component: SWA Master    H17 0040     Serial number: 0179325956   Coding: 010211   Shop #: WSC 06324 000 00000   ASAM Dataset: EV_LaneChangAssis 001020   ROD: EV_LaneChangAssis_AU21.rod   VCID: 3E2539B210FA2287FBB-806A
   Lane Change Assistant 2:    Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568    Component: SWA Slave  H17 0040    Serial number: 0179335352             Coding: 010211
------------------------------------------------------------------------------Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G   Component: TSG FA        H09 0304     Revision: --------    Serial number: -------------   Coding: 011C13224E00120102   Shop #: WSC 06325 000 00000   VCID: 56F58112980ACAC7C3B-8002
1 Fault Found: 02113 - Switch for Inside Lock         008 - Implausible Signal - Intermittent         Freeze Frame:                Fault Status: 00101000                Fault Priority: 3                Fault Frequency: 1                Reset counter: 247                Mileage: 96904 km                Time Indication: 0                Date: 2019.10.11                Time: 12:18:18
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 13
Address 44: Steering Assist (J500)       Labels:| 8K0-909-144.clb   Part No SW: 8K0 909 144 F    HW: 8K0 909 144 B   Component: RCEPS         H36 0507     Revision: 00001000    Serial number: 0013651286   Coding: 100000010001   Shop #: WSC 06324 000 00000   ASAM Dataset: EV_RCEPSAU48X 008014   ROD: EV_RCEPSAU48X_008.rod   VCID: 34311B9A2EB6F8D71DF-8060
------------------------------------------------------------------------------Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM   Component: BCM2 2.0      H11 0621     Revision: 00002001    Serial number: 0179750233       Coding: 0106029A00FA404580B0003200000000   Shop #: WSC 06324 000 00000   VCID: 015F824E21049D7FC69-8054
   Subsystem 1 - Part No SW: 8K0 959 719 B    HW: 8K0 959 719    Component: GTO BF  H01 0080    Serial number: 00000000000000540837
   Subsystem 2 - Part No: 1K0 951 605 C   Component: LIN BACKUP HO  H05 1501
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591    Component: J245EE20SKB13  H03 0220    Serial number: 0123456789ABCDEFGHIJ
1 Fault Found: 00457 - Central Electronics Control Module / BCM (J519)         013 - Check DTC Memory         Freeze Frame:                Fault Status: 01101101                Fault Priority: 6                Fault Frequency: 2                Reset counter: 250                Mileage: 93939 km                Time Indication: 0                Date: 2019.06.18                Time: 17:12:48
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:31:55671 Page 14
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOM.clb   Part No SW: 8T1 035 223 A    HW: 8T1 035 223 A   Component: DSP Prem      H05 0030     Revision: 00005001    Serial number: 94813004331602   VCID: 2D070EFECD1CA91F521-8078
------------------------------------------------------------------------------Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G   Component: TSG BF        H09 0304     Revision: --------    Serial number: -------------   Coding: 011C13224E00120102   Shop #: WSC 06325 000 00000   VCID: 55F7861E850CC1DFCA1-8000
------------------------------------------------------------------------------Address 53: Parking Brake (----)       Labels: 8K0-907-801-V2.clb   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J   Component: EPB-4         H01 0003     Revision: --------    Serial number: 10000000067422   ASAM Dataset: EV_ParkiBrake 001027   ROD: EV_ParkiBrake_AU48.rod   VCID: 38292FAA32DE1CB7317-806C
------------------------------------------------------------------------------Address 56: Radio (R)       Labels: Redir Fail!   Part No SW: 4G0 035 082 D    HW: 4G0 035 082    Component: Radio U SIRIU H60 0112     Revision: AB001007    Serial number: 156G10C7610959   Coding: 020007010000000001   Shop #: WSC 06325 000 00000   VCID: 211FE2CE81C47D7FE69-8074
VCDS Self-Diagnosis Log Tuesday,29,October,2019,21:40:32:55671 Page 15
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb   Part No SW: 8R1 035 746 B    HW: 8R1 035 746 B   Component: H-BNT-NA      H43 0552     Revision: --------    Serial number: 204GO0C7507301   Coding: 140200020206A1EF55028B4E00000403140000000000000000   Shop #: WSC 06325 000 00000   VCID: 36352192384AEAC723B-8062
   Subsystem 1 - Part No: 8R0 060 884 AM   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604    Component: DU7 High  H41 0104    Serial number: A130G$0CS201801
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C   Component: E0380 Bedient  H02 0020    Serial number: 00000001202139
   Subsystem 4 - Part No: 8R0 060 961 D   Component: CD-Database  4353
------------------------------------------------------------------------------Address 6C: Back-up Cam.        Labels: 8T0-907-441.clb   Part No SW: 8T0 907 441 C    HW: 4L0 907 441 B   Component: J772__Rearview      0040     Revision: --H07---    Serial number: 525PA8-J2493W9   Coding: 1000008   Shop #: WSC 06325 000 00000   VCID: 38292FAA3E5E1CB7317-806C
------------------------------------------------------------------------------Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb   Part No SW: 8K0 907 159     HW: 4H0 907 159 A   Component: SAS-GEN 2     H06 0005     Serial number: 120612200528   ASAM Dataset: EV_SoundActuaGen2AU64X 002005   ROD: EV_SoundActuaGen2AU64X_002.rod   VCID: 72BDDD821422B6E7CF3-8026
End----(Elapsed Time: 01:55, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-
Please look in your Scans sub-folder. It should be there in its original .txt format, which is much easier to read than the mangled (for printing) stuff above.
Let's see if I can clean up 09 from there enough to make sense of it:
It certainly looks the same.
I'm not sure what to make of the coding faults for J667 and J668, but since it has to go to the dealer anyway, they should be able to correct that at the same time they remove CP.
