AFS wiring
Qlasiq
New Member
Utah, USA
Hey all,
Thank you in advance for any help/advice you are able to give me.
Im just finishing up retrofitting Bi-Xenons with AFS on my 2016 Facelift Tiguan R.
My question is how is the AFS module wired to the CAN BUS?
My wiring diagrams show that Pins 2 and 3 of the AFS module are connected to both the Can Bus extended High/Low connections and the Powertrain Can bus High/Low connections.
Where are these two located? I know that one is the J533 to which im supposed to connect to pin 7 and 17, where is the other located?
Thank you again for any help.
Geremy
    Car: Volkswagen Tiguan R-line
    Year: 2016
    Body type: SUV
    Engine: CCTA 147 kW (200 HP) 2.0 l
    Mileage: 153590 KM
01 Engine Control Module 1
    System description: MED17.5.2 TFSI 2 07
    Software number: 06J906027JP
    Software version: 1335
    Hardware number: 06J907309A
    Long coding: 0423010A190F0160
    Trouble codes:
        No trouble codes found
02 Transmission Control Module
    System description: AQ 250 6F
    Software number: 09G927750NK
    Software version: 2627
    Hardware number: 09G927750NK
    Coding: 0000840
    Trouble codes:
03 Brakes 1
    System description: J104   C6 450M VDD9
    Software number: 5N0614109BN
    Software version: 0021
    Hardware number: 5N0614109BN
    Hardware version: K03
    Serial number: 00000008878449
    Coding: 0005161
    Trouble codes:
04 Steering Angle Sender
    Trouble codes:
05 Kessy
    System description: VWKESSYPQ35GP
    Software number: 5K0959434E
    Software version: 1202
    Hardware number: 5K0959434
    Hardware version: 092
    Serial number: 0369728431
    ODX name: EV_KESSYPQ35G
    ODX version: A02717
    Long coding: 030C0C
    Trouble codes:
08 Air Conditioning
    System description: AC Manuell
    Software number: 561907426G
    Software version: 0506
    Hardware number: 561907426G
    Hardware version: H03
    ODX name: EV_ACManuaElectGen2BHTC
    ODX version: 001002
    Long coding: 0010001002
    Trouble codes:
09 Central Electrics
    System description: BCM PQ35 M
    Software number: 5K0937086AB
    Software version: 0183
    Hardware number: 5K0937086AB
    Hardware version: 122
    Long coding: EF1A0A1B80232EC4018800C1140009EC4E7CAE86566D8DF0E4844000A040
    Subsystems:
        System description: WWS316 040515
        Software number: 5N1955119B
        Software version: 0664
        Hardware version: 24
        Long coding: 009795
        System description: RLS 010615 05
        Software number: 1K0955559AH
        Software version: 0403
        Hardware version: 54
        Long coding: 02304D
    Trouble codes:
        02912 - Right rear side marker lamp bulb Open circuit/short circuit to B+
            static
                Priority:  3
                Frequency counter:  1
                Driving cycle: 217
                Mileage: 153591 km
15 Airbag
    System description: J234__005 VW10 HI
    Software number: 5N0959655AB
    Software version: 5418
    Hardware number: 5N0959655AB
    Hardware version: 003
    Serial number: 003MAPA9V1Q8
    Coding: 0012341
    Subsystems:
        System description: BF-Gewichtsens. 003
        Software number: 5N0959339B
        Software version: 0001
    Trouble codes:
16 Steering Column Electronics
    System description: LENKS.MODUL
    Software number: 5K0953569AL
    Software version: 0180
    Hardware number: 5K0953569AL
    Hardware version: 016
    Serial number: 20151118100641
    ODX name: EV_VW360SteerWheelUDS
    ODX version: A03004
    Long coding: 111A140000
    Subsystems:
        System description: E221__MFL-TAS
        Software number: 5K0959542B
        Software version: 0036
        Hardware version: H30
        Serial number: 0195793
        Long coding: 830000
    Trouble codes:
17 Dash Board
    System description: KOMBI
    Software number: 5N0920973L
    Software version: 1007
    Hardware number: 5N0920973L
    Hardware version: H04
    ODX name: EV_Kombi_UDS_VDD_RM09
    ODX version: A05730
    Long coding: 211F010000
    Trouble codes:
        U111100 - Function limitation due to missing message
            static
                Date: 2049-12-31 00:05:22
                Mileage: 153591 km
                Priority: 6
                Malfunction frequency counter: 1
                Unlearning counter: 217
19 Gateway
    System description: J533  Gateway
    Software number: 7N0907530AT
    Software version: 1663
    Hardware number: 7N0907530AK
    Hardware version: H57
    Serial number: 250515F1000552
    Long coding: 356022
    Trouble codes:
        01771 - Headlamp range control module No signal/communication
            static
                Priority:  2
                Driving cycle: 217
                Mileage: 153591 km
1C Vehicle Position Detection
    Trouble codes:
22 All Wheel Control
    System description: Haldex4Motion
    Software number: 0AY907554J
    Software version: 7531
    Hardware number: 0CQ525130
    Hardware version: H52
    Serial number: HA1-00002.04.1500010676
    ODX name: EV_AllWheelContrHA1VW37X
    ODX version: 002015
    Long coding: 0001
    Trouble codes:
        C111204 - Haldex clutch pump Faulty
            static
                Date: 2049-12-31 00:05:26
                Mileage: 153591 km
                Priority: 1
                Unknown ambient data: 4F0000000B028A
25 Immobilizer
    System description: IMMO
    Software number: 5K0953234
    Hardware number: 5K0953234
    ODX name: EV_Immo_UDS_VDD_RM09
    ODX version: A03710
    Long coding: 000007
    Trouble codes:
2B Steering Column Locking
    System description: ELV-PQ35
    Software number: 5K0905861C
    Software version: 0240
    Hardware number: 5K0905861C
    Hardware version: H21
    Serial number: 15000138909004
    ODX name: EV_ELVMarquMPVW36X
    ODX version: A01001
    Long coding: 4900000000000000
    Trouble codes:
42 Door Electronics Driver Side
    System description: TUER-SG FT
    Software number: 5N0959701F
    Software version: 0503
    Hardware number: 3C0959793B
    Hardware version: 002
    Serial number: 0009757309
    ODX name: EV_TSGFPQ35BRFVW46X
    ODX version: A04001
    Long coding: 0004B4
    Subsystems:
        System description: J388__TSG-HL
        Software number: 5N0959703G
        Software version: 1504
        Hardware version: 009
        Serial number: 00000009374822
        Long coding: 000490
    Trouble codes:
        B11FD01 - Turn signal in exterior rear-view mirror Electrical error
            static
                Date: 2049-12-31 00:15:54
                Mileage: 153591 km
                Priority: 2
44 Steering Assistance
    System description: J500__APA-BS KL.286
    Software number: 5N1909144R
    Software version: 1401
    Hardware number: 5N1909148J  *
    Serial number: 00151380044801
    Coding: 0000258
    Trouble codes:
46 Central Module Comfort System
    Trouble codes:
4C Tire Pressure Monitoring 2
    Trouble codes:
52 Door Electronics Passenger Side
    System description: TUER-SG BT
    Software number: 5N0959702F
    Hardware number: 3C0959792B
    Serial number: 0009763339
    ODX name: EV_TSGBPQ35BRFVW46X
    ODX version: A04001
    Long coding: 0004B4
    Subsystems:
        System description: J389__TSG-HR
        Software number: 5N0959704G
        Serial number: 00000009400078
        Long coding: 000490
    Trouble codes:
53 Parking Brake
    System description: J540 EPB4  VW-63206
    Software number: 3AA907801J
    Software version: 0012
    Hardware number: 3AA907801J
    Serial number: 00000000726907
    Coding: 0026156
    Trouble codes:
55 Headlight Regulation
    Trouble codes:
5F Information Control Unit 1
    System description: MU-S-S-US
    Software number: 5C0035200
    Software version: 0245
    Hardware number: 5C0035200
    Serial number: VWZAZ2R0145505
    ODX name: EV_MUStd4CTSAT
    ODX version: 001022
    Long coding: 02130600FF00000051220001001808001F0106D40020010002
    Trouble codes:
        B201A00 - Checking software version management
            static
                Date: 2049-12-31 00:05:32
                Mileage: 153591 km
                Priority: 6
                Dynamic environmental data: 02868A100200
62 Door Electronics Rear Left
    Trouble codes:
72 Door Electronics Rear Right
    Trouble codes:
75 Telematics Communication Unit
    System description: OCULowUSA
    Software number: 561035285A
    Software version: 0156
    Hardware number: 561035285A
    Hardware version: 020
    Serial number: 00000355414053889691
    ODX name: EV_OCULow
    ODX version: 002009
    Long coding: 02130602C21612107F1606C20000
    Trouble codes:
Viking
C?ID=151455
Do you have an Autoscan of the car generated with VCDS? Im not sure what tool you used to create the scan you've posted, but this being a VCDS forum it's a requirement to use VCDS for posting a scan.
Qlasiq
New Member
Utah, USA
Hey thanks for the reply. I'm temporarily using a friends "other tool" until I can get an actual VCDS!
downtime
C?ID=280813
Both CAN buses are gateway module J533.
Or for easier access, driver side footwell just below a pillar there’s a connection point where you’ll find both drivertrain and extended can wires.
siLc
Tallinn, Estonia
C?ID=330192
Look closer, this vehicle is the older PQ platform Tiguan - no footwell connection point in those :)
Someone omitted an important detail from the schematic. See the *5 in the AFS module CAN wiring? In the complete schematic, this asterisk has a description of "According to equipment" which in itself doesn't say much but logic dictates there shouldn't be a need to wire the AFS module to BOTH Drivetrain and Extended CAN busses. The Extended bus is essentially the extension to the Drivetrain bus.
downtime
C?ID=280813
You’re right :) didn’t pay that much attention to that. Just looked that yes, two can’s. Did wonder for a minute though that why two :)
I did the AFS bixenon retrofit to our former Golf Plus which shares a lot of components with Tiguan. That only had drive or powertrain CAN connection to range module.
Qlasiq
New Member
Utah, USA
Ok interesting.
I currently have it wired from the AFS module just into pins 7 and 17 and I’m still getting the fault that there’s no communication between the Gateway and the AFS Module... 01771 - Headlamp range control module No signal/communication. I’ve checked all my wires and everything else minus this question I had seems to be wired correctly so I’m just not quite sure why it’s not communicating!
siLc
Tallinn, Estonia
C?ID=330192
What is the part number of the AFS module?
I wouldn't be so sure the CAN gateway even supports the Extended CAN. So having wired the AFS into CAN pins 7 and 17 - were the pins vacant? If yes, then probably a CAN gateway swap is in order. If no, verify +12V and GND at the AFS.
Qlasiq
New Member
Utah, USA
Part number is 5M0-907-357-F-Z0W
I’ll go back in and connect to pin 6 and 16 and check for continuity on my power and ground wires as well!
