Results 1 to 9 of 9
Thread: Heated Seat MQB retrofit
    Jan 2019
    Saturday,16,November,2019,20:51:12:18214
    VIN: WVWZZZAUZJW194866   License Plate: SEATS
    Mileage: 30975km-19246mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZJW194866   Mileage: 30975km-19246miles
    Address 01: Engine (J623-DCYA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 RJ    HW: 04L 907 309 R
       Component: R4 2.0l TDI   X24 4381
       Revision: B5X24---
       Coding: 01250012036401082000
       Shop #: WSC 92521 052 12345
       ASAM Dataset: EV_ECM20TDI01104L906026RJ 004001
       ROD: EV_ECM20TDI01104L906026RH.rod
       VCID: 03538CE6CB916A7FD45-8056
       Part No SW: 0GC 300 042 G    HW: 0GC 927 711 G
       Component: GSG DQ381     H06 1404
       Revision: 00H06V07
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061_VW37.rod
       VCID: 2A0D01420C7B5B37B73-807E
       Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
       Component: ESC           H25 0523
       Revision: 00000000    Serial number: 60268000001939
       Coding: 01FA8AA124290970477F060660C92980512490E26006947338625078C209430B00000012121212B835351919323200
       Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
       Revision: 00001K08
       Coding: 0012010420211001100500400010102A
       VCID: 72BDD922E42B53F7CF3-8026
       Part No SW: 5Q0 937 084 CN    HW: 5Q0 937 084 CE
       Component: BCM MQBAB M   H36 0253
       Serial number: 01001802300636
       ROD: EV_BCMBOSCH_018.rod
       VCID: 065595F2F8A35F57F3B-8052
       Component: WWS    171231  042 0551
       Serial number:         180105095307
       Coding: 0E4DFD
       Component: RLHS  047 0105
       Serial number: TAY18M01D31H14M25S45
       Coding: 06A8DD
       Serial number: 000000000ZY173512DD7
       Serial number: 00000000000000064173
    133899 - Voltage Supply; Terminal 30 for Seat Heaters
              B1411 13 [009] - Open Circuit
                        Reset counter: 248
                        Mileage: 30975 km
                        Date: 2019.11.16
                        Time: 20:49:09
    461833 - Enable for Seat Heating
              B1339 14 [009] - Open or Short to Ground
                        Reset counter: 248
                        Mileage: 30975 km
                        Date: 2019.11.16
                        Time: 20:49:09
       Serial number: 000308418918017
       Coding: 0471151811
       VCID: 4BC364C6A341623F6C5-801E
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 3300678159FFC728949C810580400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: 3E253D12E0F3C797FBB-806A
       Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
       Serial number: 003VWR3U0KHY
       Coding: 98CCC000000000005C0000CF008800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 094F9ECEE9BD302F9E9-805C
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169677E27011840670
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169676E26011841274
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 003 001 18
       Serial number: 3570000000025DA03B2I
       Subsystem 4 - Part No SW: -----------    HW: 480 002 801 18
       Serial number: 35800000000CEC251B2W
       Subsystem 5 - Part No SW: -----------    HW: 480 402 901 18
       Serial number: 3510001C928C22E17441
       Subsystem 6 - Part No SW: -----------    HW: 480 402 901 18
       Serial number: 3520001AD28A2CC452DI
       Subsystem 7 - Part No SW: -----------    HW: 480 402 701 18
       Serial number: 3550001C728B2FC3C7DW
       Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 26011808491156
       Coding: 0410
       VCID: 025D89E2D48B6377DF3-8056
       Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
       Component: KOMBI         408 3195
       Coding: 23AD4108278006000181FF011401000000000000
       Component: GW MQB High   436 4326
       Revision: --------    Serial number: 0007326874
       Coding: 030100045F086800FB00025C1C0F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF.rod
       VCID: 38292B0AC2D7F9A7317-806C
       Serial number: 29170003015970058017
       Coding: 2DFFFF
       Serial number: 3074226604
       Serial number: 091217EL710241
       Coding: 003B0220D001048000001000
       VCID: 43D34CE68B11AA7F945-8016
       Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000018863765
       Coding: 0D0000
       Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  131 1081
       Coding: 81170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 73B3DC269B315AFFC45-8026
       Serial number: 221217ELM13014
       Coding: 003B0020DE01048000801000
       VCID: 42DD49E2940BA3779F3-8016
       Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000018848885
       Coding: 150000
       Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
       Component: MU-S-ND-ER    851 0867
       Coding: 02731001FF00000051110101008808001F0107F601200000CF
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 323D192224AB13F70F3-8066
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZHV0132160
       Subsystem 2 - Part No SW: 5NA 919 866 H    HW: -----------
       Component: ECE1 2019/20  --- 1115
    1586 - invalid data record
              B2005 00 [009] - -
              [Control module (data record download) - invalid data record for speed shutoff thresholds]
                        Reset counter: 248
                        Mileage: 30975 km
                        Date: 2019.11.16
                        Time: 20:49:09
                        Voltage terminal 30: 11.7 V
    End----(Elapsed Time: 01:25, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
    Heated seats aren’t working. These 2 faults show up.
    Mk7.5 Golf 2018 R-Line.
    Coded it in via adaptions. Fitted a kufatec wiring harnesses. Not sure what the issue could be. Is my BCM compatible?
    Moving to Retrofits.
    May 2016
    I think so to do with wiring. Have you add wires?
    Jan 2019
    Yeah. I’ve added a harness into 2 of the 3 BCM plugs.
    Into the seat plugs too.
    Does this just mean there’s a cable not plugged in properly?
    Apr 2018
    ITALY
    you have a Medium BCM, it does not support heated seat you need a Mid+ or a High. of course if replacing go for the High.
    the swap will require the dealer, Component Protection will kick in.
    it's a bummer, I have been there.
    a little later I will tell you the exact part number you need.
    my Golf came out of the factory with 13 ECUs. now she has 19. and counting
  6. Likes DV52, Uwe, myounus liked this post
    ^^^ what darkchina said - eyeball the module socket on the mating pins that you installed on the harness for your current BCM. I think that you will find that the actual module pins for seat heating (which are large when fitted) are missing.
  8. Likes Uwe, myounus liked this post
    Apr 2018
    ITALY
    you need 5Q0 937 084 CQ, that's the High BCM for your VIN. buy it used online and possibly taken out from a Golf.
    step by step replacement, if BCM comes from Golf:
    1) create RAW HEX adaptations map of module 09 and don't lose it;
    2) disconnect battery and replace BCM;
    3) reconnect battery and switch ignition on;
    DON'T FREAK OUT, CLUSTER WILL ACT LIKE XMAS TREE, SEVERAL THINGS LIKE INTERIOR LIGHTS AND WIPERS MIGHT NOT WORK, KEYFOB WON'T DEFINITELY WORK BUT KEY WILL STILL SWITCH ENGINE ON.
    4) restore module 09 admap created at beginning;
    5) cycle ignition, drive around the courtyard a bit making sure you fully turn the steering wheel both ways a couple of times each way. cycle ignition and clear all errors by accessing one module at a time. you should be left with only Component Protection errors (not sure about the error you have in 5F, that might stay);
    6) go to dealer (bring ALL keyfobs) and have him clear Component Protection and re-learn keyfobs;
    7) you're done, enjoy!
    step by step replacement, if BCM comes from any other car model or brand:
    1) arrange appointment with dealer (bring ALL keyfobs and your VCDS laptop) and just outside the garage, create RAW HEX adaptations map of module 09 and don't lose it;
    2) disconnect battery and replace BCM; reconnect battery and start car;
    3) enter dealer garage and have him clear Component Protection and re-learn keyfobs, plus perform full SVM with code XCHG09A001 for module 09;
    4) using your VCDS, restore module 09 admap created at beginning;
    6) cycle ignition, drive around a bit making sure you fully turn the steering wheel both ways a couple of times each way. cycle ignition and clear all errors by accessing one module at a time.
    7) you're done, enjoy! (again I am not sure about your 5F error)
  10. Likes Uwe, downtime, PetrolDave, DV52, myounus, andyhud, apial liked this post
  11. #8
    Jan 2019
    Part no worked perfectly.
    However your SVM code is not correct - apparently it’s for Audi’s.
    I appreciate the help
  12. #9
    Apr 2018
    ITALY
    well, it comes from an Audi document, I had assumed it works across VAG group. now, I wonder if XCHG09V001 would do, or XCHG09W001. can't be much different, and I bet the A is for Audi.
    what code did the dealer use?
