Good evening
Whilst out in the car today my battery light came on. I wasn't too far from home so decided to continue. I turned off the heated seats etc to reduce the load and also monitored the battery level on the MMI (it stayed at 100% although I wonder how accurate it is). About five minutes later the EPS light also came on. As I got near to home both lights went out!
I put a multi-meter on the battery once at home - it was showing 13.8 v at idle and 13.5 v with all the electrical equipment on.
The VCDS scan is below. I assume the issues I experienced relate to the issues that are logged from today:
- 053255 - Please check Fault Memory in Battery Monitoring Module
- 009783 - Torque Management Feedback Signal A
- 18265 - Load Signal
- 02252 - Generator (looking at the times this seemed to happen first)
- 02479 - Partial Consumer Shut-Off Active
I'd appreciate any thoughts on what might be wrong. Some research suggests it might be the regulator?
Saturday,16,November,2019,13:02:07:57775
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4505.4
VIN: WAUZZZ4F96N032034 License Plate:
Mileage: 261010km-162184mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 69 72 76 77
VIN: WAUZZZ4F96N032034 Mileage: 261010km-162184miles
Address 01: Engine Labels: User\059-907-401-ASB.clb
Part No SW: 4F0 910 401 A HW: 4F0 907 401 B
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 00656 210 83209
VCID: 1A6EDA72E091A32724D-804E
004118 - Valve for Air Filter Bypass Flap (N275)
P1016 - 001 - Open Circuit
Fault Status: 01110001
Torque: 269.1 Nm
Temperature: 7.2°C
Temperature: 9.9°C
Mass Air / Rev.: 0.0 mg/str
U1007 - 001 - - Intermittent
Fault Status: 00110001
Mileage: 261003 km
Date: 2019.11.16
Time: 11:52:37
RPM: 1344 /min
Torque: 113.1 Nm
Speed: 57.1 km/h
(no units): 943.5
Voltage: 11.32 V
Temperature: 7.2°C
(no units): 4.0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 B HW: 09L 927 156 A
Component: AG6 09L 3.0lTDI RdW 0030
Revision: --H01--- Serial number: 4042590
Shop #: WSC 02325 785 00200
VCID: 2310E796D7DBE2EFF7B-8076
P2637 - 000 - - Intermittent
Reset counter: 40
Mileage: 261003 km
Date: 2019.11.16
Time: 11:52:39
RPM: 1312 /min
RPM: 1280 /min
RPM: 1472 /min
(no units): 37.0
(no units): 25.0
Temperature: 52.0°C
T.B. Angle: 7.8°
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Coding: 0004488
VCID: 2D0401AE811F249F51F-8078
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Reset counter: 87
Mileage: 261003 km
Date: 2019.11.16
Time: 11:52:37
Hex Value: 0x3A00
Hex Value: 0x4006
Hex Value: 0x0028
Hex Value: 0x018D
Hex Value: 0x00FF
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300187560
Coding: 0000147
VCID: 6390A796975BA2EFB7B-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H44 0070
Component: FBSAUDIC6 IDG H39 0040
00956 - Key 2
Fault Status: 00110010
Reset counter: 86
Mileage: 260899 km
Date: 2019.11.10
Time: 18:12:35
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 730 F HW: 4E0 035 729
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 350FR057568631
Coding: 0001002
Shop #: WSC 02335 785 00200
VCID: 2412E48AD2D5E5D78E1-8070
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H03 0010
Subsystem 2 - Serial number: 00000000174279
Subsystem 3 - Serial number: 0107.06.050000000100010725ÿ
Subsystem 4 - Serial number: 010725ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F2 820 043 J
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000148896
Coding: 0001302
VCID: 5BE09F76AF2B9A2FFFB-800E
003 - Mechanical Failure
Fault Status: 01100011
Fault Frequency: 49
Reset counter: 47
Mileage: 260699 km
Date: 2019.11.07
Time: 15:50:58
Voltage: 13.50 V
Temperature: 13.0°C
(no units): 212.0
(no units): 217.0
Temperature: 9.0°C
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Coding: 0002121
VCID: 6696BE826469D7C7505-8032
Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H11 0040
Coding: 00022800
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00141886
Shop #: WSC 02335
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7177922
VCID: 1C62DC6AEAA5DD17361-8048
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD08B5N5
Coding: 0013382
VCID: 290CF5BEB5F738BFBD7-807C
Subsystem 1 - Serial number: 6332CSME0A384F179
Subsystem 2 - Serial number: 6342CSME0A2C7B76H
Subsystem 3 - Serial number: 6352QSME0518293DI
Subsystem 4 - Serial number: 6362QSME05033145%
Subsystem 5 - Serial number: 63734SME02082E43Y
Subsystem 6 - Serial number: 63834SME05192F7DB
Part No SW: 4F0 910 549 HW: 4F0 953 549 B
Component: Lenksäulenmodul H09 0230
Revision: 00H09000 Serial number: 90025080100101
Coding: 0102142
Shop #: WSC 00656 210 88563
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 980 M
Component: KOMBIINSTR. M73 H15 0630
Revision: 01000000 Serial number: 4PX35PL55
Coding: 2049443
Shop #: WSC 60457 001 1048576
VCID: 211CED9ECDC7F0FFE57-8074
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 12008055288084
Coding: EDFE73C41B3104
VCID: 2708F386A3E30ECFAB3-8072
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 C
Component: MNS ECE H44 0850
Revision: 00000000 Serial number: 305EU057594249
VCID: 3B203FF64F6BBA2FDFB-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00000000 Serial number: ‰3q
Coding: 0003610
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01004778620000
Coding: 0131835
VCID: 2E0606A28C195F87685-807A
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 D HW: 4F0 035 223 D
Component: DSP-High C6 H09 0170
Revision: PROD_01 Serial number: 00000000788056
Coding: 0000113
VCID: 1F18EB66FBB3C60FD33-804A
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000101129
Coding: 0001103
Shop #: WSC 02323 785 00200
VCID: 5EE69662BC398F07985-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00000000 Serial number: "Hq
Coding: 0003610
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
Shop #: WSC 02334 785 00200
VCID: 5DE4916EB13F941F81F-8008
Part No: 8P0 907 357 C
Coding: 0000003
VCID: 3A2E3AF240518327C4D-806E
00070 - Starting Battery Voltage
Reset counter: 33
Mileage: 259320 km
Date: 2019.10.02
Time: 18:15:55
Part No SW: 4E0 910 541 L HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0560
Revision: 00000000 Serial number: 394F/057555766
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000137903
Component: von VA0 1506010929
Coding: 344630393135313035442056413031353036303130393239
02252 - Generator
Fault Status: 00101100
Fault Frequency: 14
Reset counter: 87
Mileage: 260981 km
Date: 2019.11.16
Time: 11:33:25
Mileage: 260994 km
Date: 2019.11.16
Time: 11:45:16
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0003074
VCID: 698CB5BE7577F8BF7D7-803C
Address 69: Trailer Labels: 4F0-910-383.lbl
Part No SW: 4F0 910 383 HW: 4F0 907 383
Component: ANHAENGERELEKTR H02 0020
Coding: 0000331
VCID: 629EA2928841ABE7BCD-8036
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0003074
Part No SW: 4F0 910 283 C HW: 4F0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 11820515401776
Coding: 0211016
Part No SW: 4E0 910 336 F HW: 4E0 862 335
Component: Handyvorb2 H10 0580
Revision: 00000000 Serial number: 00000007558494
Coding: 0010900
VCID: 2514F98ED9EF1CDF99F-8070
End----------(Elapsed Time: 01:50, VBatt start/end: 12.6V/13.9V)-----------
