2015 Audi A6 AdBlue System fault No restart in 1000km
CuturiloD
Serbia
C?ID=361908
Hello guys,
I have problem with AdBlue sistem.
Yesterday a notice appeared on my dashboard : AdBlue System fault No restart in 1000km.
First I was read some posts and after this I was read fault codes and filled my tank with additional 10 liter adblue.
Fault code was: 28653- Reductant System Performance Bank 1 P204F 00 - Malfunction
After this I was clear fault codes, and in this moment I don't have any fault code in all modules in car.
Here is last scan:
 Friday,15,November,2019,16:22:34:48786
VIN: WAUZZZ4GXFN075726   License Plate: SU106US 1511
Mileage: 154158km-95789mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 36 3B 3C 42 44 46 52
          53 55 5F 62 6C 6D 72 85 8B 8E 8F 90 AC
VIN: WAUZZZ4GXFN075726   Mileage: 154158km-95789miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 0655
   Revision: 85H23---
   Coding: 0A25401A234401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79AFEF19E952BBEF8E9-802C
Address 02: Auto Trans (J217)       Labels:| 0CJ-927-156.clb
   Part No SW: 4G0 927 153 L    HW: 0CK 927 156 Q
   Component: 0CK 20TDI RdW H01 0002
   Revision: --H01---    Serial number: 0000000191
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002014
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 323D183574A488B70F3-8066
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 06A29E49604579929B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FDB4101B7F655DFF0D-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01A8700E000000000000
   VCID: 7AADF015ECD4B0F7873-802E
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 02031500110355
   Coding: 34110908250000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 619FA77961C2432FA69-8034
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001021731202
   Coding: 0105001440349FE2C1014083A0001800CF9CC3082E08020100000494E10114020040002C030000
   VCID: 71BFD739B1A2F3AF369-8024
   Component: WWS57X 150211  H37 0080
   Serial number:         150216124312
   Coding: 0045F7
   Serial number: 23783453
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 26 02 2015  00000172
   Serial number: 70884397000000000001
   Component: ACC3          H21 0053
   Coding: 7A04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 290FFF595972CB6FBE9-807C
   Revision: --------    Serial number: 003P1003J2GQ
   Coding: 30333130313630323437554A304C34473053
   VCID: 3B233511A3EE49FFDC5-806E
   Serial number: 3575HRB405R33HNKA83Q
   Serial number: 3585HRB4055373K63137
   Serial number: 3515JRB405V35IMQ80V9
   Serial number: 3525JRB405136K44BPC
   Serial number: 3554VRB4055352USNH2
   Serial number: 3564VRB405L352USD9A2
   Revision: --------    Serial number: 90372OC40003T
   Coding: 0000DC
   VCID: 372B29219F466D9F38D-8062
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
   Serial number: 14 02 2015  B0046748
   Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
   Component: TDieRdwAcc    H08 0043
   Revision: 04001037    Serial number: 658050315596015
   Coding: 138E0A004F452008010400
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 33331D318BBE81BF045-8066
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20140912135011
   Coding: 5D3F01
   VCID: 2615F46548ECE41793B-8072
   Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001752716
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 001024
   VCID: 73B3DD31CB3EC1BFC45-8026
   Serial number: 6114185803
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 1412220000000000033D
   Revision: AA001002
   Coding: 04018264747464545425363E00
   VCID: 7CA1F60DE6E08EC795F-8028
   Revision: AA000000    Serial number: 00000138195316
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77ABE921DFC6AD9FF8D-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA82093LMG
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3635242598CC949723B-8062
   Component: SWA Master    H06 0060
   Serial number: 0366301422
   Coding: 040311
   VCID: 392F2F19A9D27BEFCE9-806C
   Component: SWA Slave  H06 0060
   Serial number: 0367089970
   Coding: 040311
   Component: TSG FA        H04 0507
   Coding: 011F17015E00628002080013
   VCID: 45D753E9D5AA0F0FBA1-8010
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0020537707
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0362711599
   Coding: 0100063800B93080C32008840C010E470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00011413809
   Coding: 011F17015E00628002080002
   VCID: 46D554E5E8AC0417B3B-8012
   Revision: --------    Serial number: 00000001381341
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070B496D9AD74F521-8078
   Coding: 04FA02102A600200
   VCID: 34311E2D8EB086871DF-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 193 A    HW: 4G1 035 193 A
   Component: RMC Cnct Nav  H61 0139
   Coding: 0100000101D5DF474F2B060301010000000001
   VCID: 221DE87524C41837FF3-8076
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464B/0F2705992
   Subsystem 3 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
   Serial number: 90349OC50006O
   Coding: 010F15004000628002080002
   VCID: 49CF5FD9F9B2EB6F5E9-801C
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 027502010201000300
   Shop #: WSC 79104 790 00000
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914_VW51.rod
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 044500038
   Coding: 111104C000
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   Component: DPC-SG        H27 0081
   Coding: 7A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01064D5680DE4745F-8078
   Coding: 7A04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 270BF9614F66FD1FA8D-8072
   Component: BV-SG         H33 0090
   Serial number: 005000620503157
   Coding: 04C099181211
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 00660600031F0376000308014248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F173971A2B3AF769-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150360032
   ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 02:02, VBatt start/end: 12.4V/12.5V)-----------
But,unfortunately message still on dashboard.
Pleasse help if anyone have some advice or solution for mine problem.
MartinsX
Riga, Latvia
C?ID=268515
Look in adaptation channels, there are some related to AdBlue fill reset and fault reset. If not sure, post admap here before touching those.
Or it was in basic settings? Not sure. Just a week ago did it on friend's Sharan...
Basic Settings.
I would think either:
IDE04567 -- Resetting of SCR tank level detection
or
IDE04730 -- Reset SCR lock
MartinsX
Riga, Latvia
C?ID=268515
Basic Settings.
or
:thumbs:
Some kind of offtopic and questions to Uwe:
Is it possible to make a map from all available Basic Settings channels like Adaptations and MV?
I understand that encrypted label files are made for Ross-Tech to protect their own work but would be nice possibility to load label file into VCDS without being connected to real module. Some kind of simulation mode. Lets say it it will work only with genuine RT interface connected to computer as a security dongle.
CuturiloD
Serbia
C?ID=361908
Hi guys, thank You for fast answer.
Here is the admap engine module:
 	SW:04L-906-021-FQ   HW:04L-907-309 ---  Engine
	Component:R4 2,0L EDC   H23 0655, Coding:0A25401A234401080000
	EV_ECM20TDI01104L906021FQ,002002,EV_ECM20TDI01104L906021FQ_002.rod
	Saturday,16,November,2019,17:49:57:48786
	VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
IDE00259-Idle RPM correction,0.0 /min,2
IDE00263-Injector 1 correction value,8AG3DEA ,7
IDE00264-Injector 2 correction value,AAAGE5B ,7
IDE00265-Injector 3 correction value,ASSUGSC ,7
IDE00266-Injector 4 correction value,81ACCSC ,7
IDE01637-Service regeneration of particulate filter while driving,0 ,1
IDE01711-Blocking of particle filter regeneration,not active ,1
IDE01945-Engine run-in oil pressure,not active ,1
IDE02248-Individually adjustable maximum speed limit,300.0 km/h,2
IDE02332-Deactivate production mode,00 00 00 ,3
IDE02637-Adaptation for metering quantity measurement,04 ,1
IDE04158-Activation of start-stop function,active ,1
IDE04617-Protective function,Enabled ,1
IDE07903-Adaptation of ash mass,0.00 g,2
IDE08287-Bleeding of coolant circuit,not active ,1
IDE09219-Reduction of dew point for belt end test,not active ,1
ENG105853-MAS04051-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation for precontrol and damping,Not blocked ,1
ENG105853-MAS04052-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation of pressure sensor,Not blocked ,1
Elapsed Time: 00:04
Here is the admap from Reductant Control modul:
 	SW:4H0-907-355-D   HW:4G0-907-355-B ---  Reductant Control
	Component:SCR-Stg-G2    H10 0012, Coding:
	EV_RDCMA00100,008040,EV_RDCMA00100_008.rod
	Saturday,16,November,2019,17:52:50:48786
IDE00820-ENG98469-Activating and deactivating all development messages-CCP,not activated ,4
IDE00820-ENG114699-Activating and deactivating all development messages-Intern_fault_number,00 00 ,4
IDE00820-ENG110578-Activating and deactivating all development messages-S_100,not activated ,4
IDE00820-ENG110579-Activating and deactivating all development messages-S_101,not activated ,4
IDE00820-ENG110580-Activating and deactivating all development messages-S_102,not activated ,4
IDE00820-ENG114688-Activating and deactivating all development messages-S_103,not activated ,4
IDE00820-ENG114689-Activating and deactivating all development messages-S_104,not activated ,4
IDE00820-ENG114690-Activating and deactivating all development messages-S_105,not activated ,4
IDE00820-ENG114691-Activating and deactivating all development messages-S_106,not activated ,4
IDE00820-ENG114692-Activating and deactivating all development messages-S_107,not activated ,4
IDE00820-ENG114693-Activating and deactivating all development messages-S_108,not activated ,4
IDE00820-ENG114694-Activating and deactivating all development messages-S_109,not activated ,4
IDE00820-ENG114695-Activating and deactivating all development messages-S_110,not activated ,4
IDE00820-ENG114696-Activating and deactivating all development messages-S_111,not activated ,4
IDE00820-ENG114697-Activating and deactivating all development messages-S_112,not activated ,4
IDE00820-ENG114698-Activating and deactivating all development messages-S_113,not activated ,4
Elapsed Time: 00:00
Already I was try yesterday to do what is Uwe said, I was do IDE04567 -- Resetting of SCR tank level detection and IDE04730 -- Reset SCR lock, but without success.
Here is foto with basic setings for engine module:
Maybe something more I can to try?
MartinsX
Riga, Latvia
C?ID=268515
I'd suggest to drive while DPF regeneration starts or run DPF service regeneration. Two results are possible: if everything is ok, warning light/message will disappear; if something is wrong fault code will be stored.
golfi_vend
Tartu, Estonia
C?ID=195131
Verify TPI-s that there aren't any for AdBlue fault regarding software issue. I see that there is higher SW version available for this ECU SW.
No, I don't think this is feasible. Measuring Values and Adaptation channels can be read non-invasively, i.e. without anything in the module changing. But some Basic Settings start actively doing things the moment you touch them.
CuturiloD
Serbia
C?ID=361908
I was try to perform regeneration but I can’t.
I have message Aborted-Safety reason.
I was following all instruction, temp eas above 70, gear position was i N position, etc.
CuturiloD
Serbia
C?ID=361908
Hi guys,
I have new info and new scan.
This morning when I went to work, regeneration was activated. I drove the car until the regeneration was complete.
Unfortunately the information on the dashboard still stands, but now I also have two errors in the channel gate.
Here is the new auto scan:
 Monday,18,November,2019,16:58:02:48786
VIN: WAUZZZ4GXFN075726   Mileage: 154220km-95827miles
   Revision: 85H23---
   Coding: 100001
   Coding: 0045F7
   Coding: 02006D
   Coding: 7A04010202
   Coding: 0000DC
   Coding: 5D3F01
   Coding: C0CD074418
   Voltage stabilizer:
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 42
                    Mileage: 154194 km
                    Date: 2019.11.18
                    Time: 07:11:33
                    Voltage terminal 30: 12.6 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 13 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
5603 - No Communication with Control Module for SRC Reductant
          U010E 00 [008] - -
                    Reset counter: 42
                    Mileage: 154194 km
                    Date: 2019.11.18
                    Time: 07:07:27
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
   Revision: AA001002
   ROD: EV_SARA2.rod
   Coding: 040311
   Coding: 040311
   Coding: E01E00
   Coding: E01E00
   Coding: 111104C000
   Coding: 7A060000
   Coding: 7A04010202
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:02, VBatt start/end: 12.3V/12.3V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
Hi guys,
That is because deleting AdBlue fault, instead of fixing them causes this.
As I told You, You have older SW and I checked TPI-s for You. You need SW update for ECU and then efficiency test or long enough trip for system to recognize the SCR working.
PS!
Active recall on Oil pressure switch!
CuturiloD
Serbia
C?ID=361908
Tomorrow I will go to guy to update my ECU SW to 1649.
CuturiloD
Serbia
C?ID=361908
Hi guys,
As planned, today I went to a service to do an update of the software version.
When i went out of town and made the first 20km, the warning from the instrument panel disappeared.
I called the service and told them the warning was gone.
At the service, they told me to drive the car for a couple of days so we could talk to each other afterwards.
In this moment I don't have any fault code in car.
Thanks all for support and time.
