Results 1 to 3 of 3
Thread: A5 2.0l TFSI 2019 Unknown Error Code
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Scanned this vehicle today and found unknown fault code with few other fault codes as well can some body please tell me what tis fault codes could be for...
    1) 5456 - Unknown Error Code
    P06E9 00 [175] - -
    2) 9458950 - Telematics Module
    U13EB 00 [009] - Flight mode activated
    [eCall_activation_service_mode]
    The other thing is when I start the vehicle I get a warning on dash which says (Drive System Active. Please Switch Off Ignition) what does this means...........?
    Below is the full Auto Scan...........
    Saturday,16,November,2019,11:27:56:07075
    VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
    VIN: WAUZZZF55KA031663   License Plate: I B M A5 BLUE
    Mileage: 22469km-13961mi   Repair Order:
    Chassis Type: F5-AU49 (8W5)
    Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 80 81
              A5 BB BC D6 D7
    VIN: WAUZZZF55KA031663   Mileage: 22469km-13961miles
    80-Batt. reg. aux. accum. -- Status: OK 0000
    Address 01: Engine (J623-DLVA)       Labels: None
       Part No SW: 8W0 907 115 Q    HW: 06L 907 309 E
       Component: R4 2.0l TFSI  H31 0003
       Revision: 1HH31000
       Coding: 1A2540132324050334082000000000000000000000000000
       Shop #: WSC 06314 790 00001
       ASAM Dataset: EV_ECM20TFS0118W0907115Q 001005
       ROD: EV_ECM20TFS0118W0907115Q.rod
       VCID: C7DEC3467EB6D777A6-8092
              P06E9 00 [175] - -
                        Fault Frequency: 15
                        Mileage: 22455 km
                        Date: 2019.11.14
                        Time: 18:19:33
                        Coolant temperature: 88 °C
                        Intake air temperature: 51 °C
                        Voltage terminal 30: 11.680 V
                        Starter control: terminal 50 acknowledgment-Bits 0-7: 39
                        Starter control: relay 1-Bits 0-7: 3
                        Starter control: release conditions-Bits 0-7: 0
                        Starter control: release conditions-Bits 0-7: 4
                        Starter control: shut-off conditions 1-Bits 0-7: 0
                        Number of manual engine starts: 1542
                        Number of automatic engine starts: 0
    2822 - Bank 1; System Too Rich off Idle
              P2178 00 [096] - -
                        Mileage: 22459 km
                        Date: 2019.11.15
                        Time: 09:57:37
                        Engine speed: 2364.00 /min
                        Normed load value: 22.4 %
                        Vehicle speed: 43 km/h
                        Coolant temperature: 82 °C
                        Intake air temperature: 10 °C
                        Voltage terminal 30: 14.640 V
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    5667 - Mass Air Flow Sensor (G70)
              P0101 00 [237] - Implausible Signal
                        Mileage: 22459 km
                        Date: 2019.11.15
                        Time: 09:57:37
                        Vehicle speed: 44 km/h
                        Voltage terminal 30: 14.620 V
    Readiness: 0010 0001
       Part No SW: 8W2 927 155 DS    HW: 0HK 927 156 B
       Component: B9 2.0T 140kW H01 0001
       Revision: --H01---    Serial number: 0000003020
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002031
       ROD: EV_TCMDL382021_AU49.rod
       VCID: 9562590E749AB5E7E4-80C0
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
       Component: V553 MTFP  003 0576
       Serial number: 75145041190010000335
       Part No SW: 8W0 907 379 AF    HW: 8W0 907 379 J
       Component: ESP9 Plus     H16 0777
       Coding: 04AA089A14A50A9711A4489700805292F5B5D2201028508812004A49AFAD4B
       Shop #: WSC 06334 790 00001
       ASAM Dataset: EV_ESP9BOSCHCMP 002013
       ROD: EV_ESP9BOSCHCMP_002.rod
       VCID: 895A057E2822610770-80DC
    12845363 - Implausible Data Received from Engine Control Module
              U0401 00 [175] - -
              [Signal_MO_QBit_Motormomente_invalid_(1)]
                        Fault Frequency: 10
                        Mileage: 22459 km
                        Date: 2019.11.15
                        Time: 09:57:37
                        95 00 80 17 8C 24 00 00 00 00
                        Unlearning counter according OBD-OBD unlearning counter: 28
    13772320 - Engine Control Module
              U1226 00 [044] - Implausible Message
              [Signal_MO_QBit_Motormomente_invalid_(1)_or_PDU_Motor_11_not_received_correctly_(combination_of_Timeout:_CS:_AC)]
                        Fault Frequency: 9
                        Mileage: 22463 km
                        Date: 2019.11.15
                        Time: 10:21:32
                        8E 00 82 00 46 24 00 50 20 20
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
       Component: Klima Zone 3  H60 0251
       Coding: 140900095544440D02000100080000000000000000000000000000000000
       Shop #: WSC 06335 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: C4C4D44A4F80FC6F43-8090
       Subsystem 1 - Part No SW: 4M2 820 021 C    HW: 4M2 820 021 C
       Component: J126 FLuftV  H09 0004
       Serial number: 00000000000003220106
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 4F911A8900PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: E265 Kli Fond  H40 0080
    262914 - High Pressure Sensor
              B10AE 21 [009] - Signal Amplitude Too Low
                        Reset counter: 128
                        Mileage: 22458 km
                        Date: 2019.11.15
                        Time: 09:56:13
                        Outside air temperature: 7.50 °C
                        Engine speed: 1460 /min
                        Compressor current: actual value: 0.00 A
                        Temperature after evaporator: 11.50 °C
    328003 - Motor for Recirculation Flap
              B1092 07 [009] - Mechanical Failure
                        Reset counter: 127
                        Mileage: 22455 km
                        Date: 2019.11.14
                        Time: 18:17:50
                        Recirc. air flap motor: spec.value: 11884
                        Recirculation air flap motor: actual value: 10006
                        System run time-Terminal 15 on: 563 s
                        Recirculation air flap motor: diagnostic-Last operating state: No routine started
                        Recirculation air flap motor: diagnostic-Operating condition: Blocking handling
                        Voltage terminal 30: 11.93 V
                        Outside air temperature: 13.00 °C
    328179 - Motor for Rear Air Distribution
              B1093 07 [008] - Mechanical Failure
                        Reset counter: 168
                        Mileage: 22455 km
                        Date: 2019.11.14
                        Time: 18:17:50
                        Rear air distr.flap mot.:spec.val: 16629
                        Rear air distribution flap motor: actual value: 10005
                        Rear air distribution flap motor: diagnosis-Last operating state: No routine started
                        Rear air distribution flap motor: diagnosis-Operating condition: Blocking handling
                        Voltage terminal 30: 11.91 V
       Part No SW: 8W0 907 063 DG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0313
       Coding: 07501143E17900CD051587141BAC80F9110B3108000000000000000020001A810A450122025601
       ASAM Dataset: EV_BCM1BOSCHAU736 019008
       ROD: EV_BCM1BOSCHAU736_019.rod
       VCID: 834617560A0E3B573A-80D6
       Subsystem 1 - Part No SW: 8W6 955 119 C    HW: 8W6 955 119 A
       Component: 494 RL 181024  036 0481
       Serial number: 00000001810180302471
       Coding: FFC7F7
       Serial number: 22347093X81A955555A0
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
       Component: E1 - LDS  H06 0008
       Serial number: 16 10 2018  01681896
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE119101823811165
       Coding: 210000
       Interior Light Module:
       Subsystem 5 - Part No SW: 4K0 947 135 B    HW: 4K0 947 135 B
       Component: Dachmodul  H42 0413
       Serial number: C00165105
       Coding: 0D0104
       Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2818000185652001
    196758 - Databus
              [Brake control module: received error value in signal ESP system status]
                        Fault Frequency: 10
                        Reset counter: 128
                        Mileage: 22459 km
                        Date: 2019.11.15
                        Time: 09:57:38
                        average_Voltage_terminals: 14.80 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 7.50 °C
                        interior_temperature: 10.50 °C
                        Vehicle speed: 53.55 km/h
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
       Component: Airbag10.44   H03 0107
       Serial number: 003UP00NJMA3
       Coding: AACCF0C00CA00000585400F3D0CC00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 006016
       ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
       VCID: CCD4FC6A67D0342F8B-8098
       Subsystem 1 - Part No SW: -----------    HW: 442 060 601 19
       Serial number: 3577Y00C92B6E570F16F
       Subsystem 2 - Part No SW: -----------    HW: 442 060 601 19
       Serial number: 3587Y00B92B03AB29343
       Subsystem 3 - Part No SW: -----------    HW: 442 0B1 101 19
       Serial number: 3517700B32D9C90272EL
       Subsystem 4 - Part No SW: -----------    HW: 442 0B1 101 19
       Serial number: 3527700A92ED42D3C2F.
       Subsystem 5 - Part No SW: -----------    HW: 442 0C0 201 19
       Serial number: 3557500A12E1335491E6
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C0 201 19
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500A12E13357129+
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C0 201 19
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500C92E13363724/
       Subsystem 8 - Part No SW: -----------    HW: 442 430 204 19
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00C32FFCA50833U
       Subsystem 9 - Part No SW: -----------    HW: 442 430 204 19
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M00C32FFCA5451F%
       Part No SW: 4N0 907 129 S    HW: 4N0 907 129 S
       ROD: EV_SMLSKLOAU736_007_AU49.rod
       VCID: C1CADD5E5092E94768-8094
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 790 E    HW: 8W5 920 790 E
       Component: FBenRDW       H19 0417
       Coding: 25A440D6288006000120E9601000000000000000
       ASAM Dataset: EV_DashBoardAU736 001032
       Part No SW: 8W5 907 468 H    HW: 8W5 907 468 G
       Component: Gateway       H43 0145
       Revision: AS010003    Serial number: 038AS093719117
       Coding: 0201000100208640298700000059001248180007100000000175078E10000000
       ASAM Dataset: EV_CGateCONTIAU491 003170
       ROD: EV_CGateCONTIAU491_003_AU49.rod
       VCID: CED0F66291CC063FE5-809A
       Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0004
       Serial number: 20190117032000 20468
       Subsystem 2 - Part No SW: 8W0 915 181 A    HW: 8W0 915 181 A
       Serial number: 5314740105
                        Mileage: 22455 km
                        Date: 2019.11.14
                        Time: 18:18:20
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
       Component: LCM_MLBevoH05 0024
       VCID: F7BE73864ED667F716-80A2
       Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
       Component: ELV-MLBevo    H05 0020
       Serial number: 18000392962008
       Coding: 8800000000000000
       ROD: EV_ELVMarqMQBA0_AU37.rod
       VCID: B424848A1F204CEFF3-80E0
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
       Component: TSG FS        009 0130
       Serial number: 0000361815592
       Coding: 001FCA625001000000001402
       VCID: CFEEEB6696C60F37EE-809A
       Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0410
       Coding: 09000380800000
       ASAM Dataset: EV_EPSZFAU49X 003023
       ROD: EV_EPSZFAU49X_003.rod
       VCID: C2C8D2525594F25F71-8096
    17664 - Databus
              [KFC_ESP_22_SNA]
                        Fault Frequency: 10
                        Reset counter: 128
                        Mileage: 22459 km
                        Date: 2019.11.15
                        Time: 09:57:37
                        Expanded ambient data 1-Engine running: Engine_Running_Stable
                        Expanded ambient data 1-Supply voltage: 0.00 V
                        Expanded ambient data 1-Temperature: -70 °C
                        Expanded ambient data 1-System status: 5
                        Expanded ambient data 1: 00
                        Expanded ambient data 1-driving_direction: 0
                        Expanded ambient data 1-KFA: 0
                        Expanded ambient data 1-KFC: 69
                        Expanded ambient data 1-Ready_To_Drive_Bit: 0
                        Expanded ambient data 1-StartStop Info: 0
                        Expanded ambient data 1-Steering_Angle_Calculated: 14 °
                        Expanded ambient data 1-Steering_Angle_Calculated_Sign: 1
                        Expanded ambient data 1-Steering_torque: 0.10 Nm
                        Expanded ambient data 1-Steering_Torque_Sign: 1
                        Expanded ambient data 15-MsgStateFifo_Byte0: 00 00 00 00
                        Expanded ambient data 15-MsgStateFifo_Byte1: 00 00 00 00
                        Expanded ambient data 15-MsgStateFifo_Byte2: 00 00 00 00
                        Expanded ambient data 15-MsgStateFifo_Byte3: 00 00 00 00
                        Expanded ambient data 15-NumOfMsgCntFaults: 00
                        Expanded ambient data 15-NumOfMsgCrcFaults_2: 00
                        Expanded ambient data 15-NumOfMsgNoFaults_3: 00
                        Expanded ambient data 15-NumOfMsgTimoFaults_1: 00
       Part No SW: 8W0 907 064 GB    HW: 8W0 907 064 DB
       Component: BCM2 MLBevo   025 0424
       Coding: 013500002FB100406309A0000400080211020010804306502F04000000040030001F0001000010
       ASAM Dataset: EV_BCM2HellaAU736 016016
       ROD: EV_BCM2HellaAU736_016_AU49.rod
       VCID: 824812521514325F31-80D6
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY183300MEJ
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000046139534
       Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
       Component: TSG BFS       009 0130
       Serial number: 0000361753614
       Coding: 001FCA225C01000000001400
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
       Part No SW: 8W5 035 035 C    HW: 8W5 035 035
       Component: MU-P-LND-EU   035 1329
       Serial number: A829A0KB091451
       Coding: 01940301FF0A000053111101000A00312F000DE701700100DE
       VCID: B73EB3860E56A7F7D6-80E2
       Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Subsystem 2 - Part No SW: 8W8 919 605     HW: 8W8 919 605
       Component: DU High AU49x  H32 0170
       Serial number: TPO00123101800820594
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
       Serial number: APVAK122111800040058
       Component: Gracenote2  --- 1017
       Part No SW: 8W8 959 107 D    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0170
       Revision: --------    Serial number: A2-C744-8781-0
       Coding: 0610
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       VCID: CAD8FA726DA42A1FB9-809E
    Address 80: Batt. reg. aux. accum. (A1)       Labels: None
       Part No SW: 8W0 915 101 A    HW: 8W0 915 101 A
       Component: MQ-BMS        H20 0126
       Serial number: 18000063875001
       ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
       ROD: EV_BMS12VLiIonSDIAU49X.rod
       VCID: B12A8D9EE03279C798-80E4
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W2 713 041 N    HW: 8W2 713 041 K
       Component: GSM-LL        H10 0077
       Revision: 0L0D5012    Serial number: 19010750424800
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: BFCEDBA626669FB71E-80EA
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 8W6 907 217 B    HW: 8W6 907 217 A
       Component: BVS           H17 0052
       Coding: 0404090300000403024023A0A50000FC00F0C020C020
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
    1123173 - Databus
              [ESP_21_ESP_Systemstatus]
                        Fault Frequency: 10
                        Reset counter: 128
                        Mileage: 22459 km
                        Date: 2019.11.15
                        Time: 09:57:38
                        Control Module temperature: 16 °C
                        Voltage terminal 15: 14.60 V
       Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
       Component: TSG HFS       009 0130
       Serial number: 0000362292035
       Coding: 000FC8220001000000001000
       VCID: D1EAED1E80F219C7F8-8084
       Component: TSG HBFS      009 0130
       Serial number: 0000362292037
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 977E53066E9687F7F6-80C2
       Component: LED1R         H09 0008
    End----------(Elapsed Time: 02:00, VBatt start/end: 13.8V/13.7V)-----------
    P06E9: Engine Starter Malfunction
    Considering this is a 2019 car with only ~14,000 miles on it and you have other engine faults one of which has the MIL on, I would take it to the dealer and have them address those issues under warranty.
    Telematics Module - Flight mode activated
    I see no Telematics module in this car. I suppose it's possible that functionality has been integrated into one of the modules?
    The GW does have this channel:
    IDE13338-MAS16261 -- Basic functions connect - Flight mode (Deactivating / Activate)
    Have a look; my guess is Flight Mode is activated there and you could de-activate it (if the owner likes to be tracked).
  3. Likes Ashraf6119 liked this post
    Dec 2015
    Hi Uwe,
    Thanks for the reply I did forgot to mention the this vehicle was bought from the action with a front end damaged but, there were NO any airbag deployed and now its fully repaired and this where the only fault codes stored.........
    I will have a look in GW module for IDE13338-MAS16261 -- Basic functions connect - Flight mode (Deactivating / Activate and report back........
    This car starts fine than how come this P06E9: Engine Starter Malfunction will not clear it keeps coming back as soon as I clear it...
