Results 1 to 10 of 10
Thread: NO EPB 53 CONTROLLER
    Verified VCDS-User The Doodster's Avatar
    Jan 2019
    Cornwall, UK
    I'm trying to open the EPB in service mode and followed the online video but there is no 53 parking brake function so can't open the calipers to change the discs and pads. Also get ROD error when running autoscan. Any help would be appreciated.
    Scott (Doodster)
    Sunday,17,November,2019,10:37:21:44739
    VCDS Version: 19.6.2.0
    Dealer/Shop Name: DOODY CARS
    VIN: WVWZZZAUZEW411135   License Plate:
    Mileage: 117414km-72957mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZEW411135   Mileage: 117414km-72957miles
       Part No SW: 04L 906 021 M    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 5517
       Revision: 84H22---
       Coding: 01110012032515092000
       ASAM Dataset: EV_ECM16TDI01104L906021M 002009
       ROD: EV_ECM16TDI01104L906021P.rod
       VCID: 2F6DC09D76B38F370E-807A
       Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
       Component: ESC           H31 0472
       Revision: 00000000    Serial number: 61044000000595
       Coding: 01FA8AA11421096D0378060341C82580512890C06082A4F300400074C002
       VCID: 071D483DBE83F777E6-8052
       Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
       Component: AC Manuell    H01 0705
       Revision: 00001K06
       Coding: 00120104202100001000000000000000
       VCID: 3561F2F594EFB5E744-8060
    Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
       Part No SW: 5Q0 937 084 AB    HW: 5Q0 937 084 AB
       Component: BCM MQBAB B   H16 0124
       Serial number: 00011411300168
       Coding: 03000842C20100530BA44000000403081000000000000000000000000000
       ROD: EV_BCMBOSCH_012.rod
       VCID: 78FF3BC1C37D888F9F-802C
       Component: WWS    140417  042 0551
       Serial number:         140422065742
       Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0142
       Revision: --------    Serial number: 39331412305401
       Coding: 0031051001
       VCID: 3E73EDD9A1D976BF95-806A
       Component: AirbagVW20    014 0385
       Serial number: 003F6R0742K+
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 41899625D0270947E8-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 002 504 14
       Serial number: 35767000000C5C518F00
       Subsystem 2 - Part No SW: -----------    HW: 480 002 304 14
       Serial number: 358670000001AB399F01
       Subsystem 3 - Part No SW: -----------    HW: 480 401 704 14
       Serial number: 3516502AF157E995713M
       Subsystem 4 - Part No SW: -----------    HW: 480 402 204 14
       Serial number: 35265029F1529DF2534K
       Subsystem 5 - Part No SW: -----------    HW: 480 402 204 14
       Serial number: 3556502AF157E99210DQ
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 DJ    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 23041404220889
       Coding: 1604
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 0109562590A7C947A8-8054
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
       Part No SW: 5G0 920 951 A    HW: 5G0 920 951 A
       Component: KOMBI         152 2210
       Coding: 27A402002300260001080800040000
       VCID: 275D28BD5E43D777C6-8072
       Part No SW: 5Q0 907 530 N    HW: 5Q0 907 530 D
       Component: GW MQB Low    123 1164
       Revision: --------    Serial number: 0001920881
       Coding: 030000040B087300EF000048080E00010001000000000000000000000000
       ROD: EV_GatewLear_010.rod
       VCID: 3C77E7D1B7C564AFBB-8068
       Subsystem 2 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Serial number: 5265803203
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 27041401101586
       Coding: 003002208001040100001000
       Coding: 0103
       ROD: EV_SteerAssisMQB_010.rod
       Serial number: 24041403110413
       Coding: 003000208E01040100801000
       VCID: 3F8D90DDA6D37FB79E-806A
       Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
       Component: MU-S-D-ER     040 0421
       Serial number: V5C01904142812
       Coding: 02730000FF00000021111201000800001F0100060100010001
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 1F4D305D06131FB7BE-804A
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H60 0030
       Serial number: VWZ8Z9PS20142A
    End-------------------------(Elapsed Time: 02:58)--------------------------
    Feb 2018
    As you drove a MQB based car, you should have a look in ECU3 (Brake Electronics)
    Jan 2019
    Cornwall, UK
    I don't have that option
    Feb 2018
    You have to look in Basic Setting or Adaptions in Brake electronics
    Jan 2019
    Cornwall, UK
    Unfortunatly, it will not load as it keeps coming up with unable to load ROD file.
    I've managed to do it with a Snap on Solus edge now as I needed the car done but thanks for trying anyway.
    Try using the legitimate cable that your registered with us in September of last year rather than the clone you got that data with; I'm confident it will work more better.
  7. Likes MartinsX, Boki Ar, PetrolDave liked this post
    Jan 2019
    Cornwall, UK
    Oh! Bugger! I thought I'd binned it. Just checked and its in the bottom of the bag.
    Many thanks Uwe
  9. #8
    Jan 2019
    Cornwall, UK
    Just updated the code in the first post to the correct cable. Still no EPB controller 53 but managed to find it in the ABS controller.
  10. Likes Uwe liked this post
  11. #9
    Quote Originally Posted by The Doodster View Post
    That one works a whole lot better, doesn't it?
    Your ABS is "MK100IPB". IPB stands for "Integrated Parking Brake".
    The pad-change procedure can be found here.
  12. Likes PetrolDave liked this post
  13. #10
    Jan 2019
    Cornwall, UK
    That's great, thanks for the info Uwe, and for the record, the other cable has
    gone in the bin
