Results 1 to 2 of 2
Thread: No response from controller 46-Central Conv.
    Nov 2019
    Norway
    Red face No response from controller 46-Central Conv.
    So I have issue with 46-Central Conv.
    When I try to open it, it shows - No Response from controller. I have used Ross tech program in this summer to adapt my new keys and locking system with key fob. So this time I activated immobilizer to new key and it works great, the only issue is now that I can't get in this 46- Central Conv. and activated also buttons on the key fob.
    I have 2 similar VW Passats 3BG 2004 models. I used this programm for both passats to adapts keys, on that another passat everything is just working fine. No issues with program or anything else. So I am confused, why this program worked before also on this passat and isn't working now perfectly.
    I hope someone can help me with this problem, and I hope you understand my problem.
    https://imgshare.io/image/U14bx
    https://imgshare.io/image/U1Vx7
    https://imgshare.io/image/U1gtg
    Monday,18,November,2019,01:30:38:07860
    VIN: WVWZZZ3BZ4E261269   License Plate: XK11765
    Mileage: 265030km-164682mi   Repair Order:
    VIN: WVWZZZ3BZ4E261269   Mileage: 265030km-164682miles
    Address 01: Engine        Labels: 038-906-019-AVF.lbl
       Part No: 038 906 019 KD
       Component: 1,9l R4 EDC 0000SG  4897
       Coding: 00002
       Shop #: WSC 05314
       VCID: 6393AD296244535FB45-4AE0
       Part No: 4B0 614 517 H
       Component: ABS/ESP allrad      3428
       Coding: 04255
       Shop #: WSC 00940
       VCID: 2615F43D51F6E67793B-51A8
       Part No: 3B1 907 044 K
       Component: CLIMATRONIC B5GP    0010
       Coding: 17000
       Shop #: WSC 05311
       VCID: 290FFF0140E8C90FBE9-5160
       Part No: 1C0 909 605 B
       Component: 0R AIRBAG VW51 04   0008
       Coding: 12370
       Shop #: WSC 05311
       VCID: 2313ED2922C4135FF45-50F4
       Part No: 3B0 920 829 A
       Component: KOMBI+WEGFAHRSP VDO V04
       Coding: 05115
       VCID: 2411EE3527CA14678DF-50F4
       WVWZZZ3BZ4E261269     VWZ7Z0C8705168
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 05311
       VCID: 70B9D265A3B2F8C7397-50F4
       Part No: 4Z7 907 357
       Coding: 00008
       Shop #: WSC 05314
       VCID: 04518EB5870AF467EDF-4B3C
    00774 - Level Control System Sensor; Rear Left (G76)
    00776 - Level Control System Sensor; Left Front (G78)
    Address 76: Park Assist        Labels: 3B0-919-283.lbl
       Part No: 3B0 919 283
       Component: Parkingsyst. PA RDW D01
       Coding: 00114
       Shop #: WSC 05314
       VCID: 6597B3316C702D6F5A1-5118
    01545 - Sensor for Parking Aid; Rear Left (G203)
                37-00 - Faulty
    End----------(Elapsed Time: 04:20, VBatt start/end: 12.2V/12.4V)-----------
    VCDS Release 19.6.2:  SRI Reset
    Control Module Part Number: 3B0 920 829 A       Labels:  3B0-920-xx5-17.lbl
    Component:KOMBI+WEGFAHRSP VDO V04, Coding:05115
    Channel  	Description                                       	Unit      	Current val.  	New val.
    02       	Service Reminder Status                           	          	0             	---
    40       	Distance since Service                            	km x100   	37            	---
    41       	Time since Service                                	Days      	92            	---
    42       	Minimum Distance to Service                       	km x1000  	15            	---
    43       	Maximum Distance to Service                       	km x1000  	15            	---
    44       	Maximum Time to Service                           	Days      	365           	---
    45       	Oil Quality                                       	          	1             	---
    47       	Soot Quantity                                     	km x100   	85            	---
    48       	Thermal Load                                      	km x100   	28            	---
    49       	Minimum Time to Service                           	---       	---           	---
    Try power-cycling it. Under normal conditions, the CCM is never really powered down; it's always alive listening for remotes and such.
    Either disconnect it from the car, or disconnect the car's battery for a while.
