Results 1 to 4 of 4
Thread: '01 Jetta 1.8T 00562 Sensor for Oil Level/Temperature
    Jun 2019
    CA, USA
    29-10 - Short to Ground - Intermittent
    Putting vehicle back together after serious dose of repair by Sir Jack: an immobilized ECU and fixed mess of a cluster. Before I connect the battery, I'm attempting to check/correct 00562.
    ECU is installed, battery has NOT been connected. The oil level sensor on the 1.8T is located at the bottom of the oil pan.......NOPE.
    I see the location, I see the three location holes, but the level sensor location on the pan has never been punched out. I don't seem to have an oil level sensor.
    Yet when the car broke down, I received an 00562 DTC as one of the faults.
    There is an oil PRESSURE sensor (single wire), coming out of the oil filter/cooler housing. Pulled connector off, No short from connector wire to ground. Wiggled harness, no short.
    With connector removed and engine off I'm reading infinity ohms from ground to sensor tip. I was expecting a high impedance but not infinite impedance. If the sensor is not allowing a signal, I'd receive
    an "open fault".
    Maybe the code was triggered by a messed up cluster?
    I'm posting the last scan prior to the ECU and cluster repair:
    Saturday,02,November,2019,17:12:44:23523
    VIN: 3VWSD69M81M169829   License Plate: 4SVK087
    Mileage: 69940km-43458mi   Repair Order: 11-2-2019
    Chassis Type: 9M - VW Jetta IV (1998 > 2014)
              75 76
       Mileage: 69940km-43458miles
    Address 01: Engine        Labels: 06A-906-032-AWW.lbl
       Part No: 06A 906 032 DL
       Component: 1.8L R4/5VT     G   0006
       Coding: 07500
       Shop #: WSC 22110
       VCID: 6B83C6759A904E6F0C5-5184
    17584 - Bank1: O2 (Lambda) Correction Behind Catalyst
                P1176 - 35-10 - Control Limit Reached - Intermittent
    17978 - Engine Start Blocked by Immobilizer
                P1570 - 35-00 -
                P1602 - 35-10 - Voltage too Low - Intermittent
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
       Part No: 1C0 907 379 D
       Component: ASR FRONT MK60      0103
       Coding: 0018945
       Shop #: WSC 00066 000 00000
       VCID: 2B0306755F108E6F4C5-5184
       Part No: 6Q0 909 605 F
       Component: 04 AIRBAG VW6  0202 0004
       Coding: 12340
       Shop #: WSC 00066
       VCID: 3A2D3331A54A27E7C73-4B3C
       Part No: 1j0 920 905 j
       Component: A4-KOMBIINSTR. VDO V53
       Coding: 10432
       Shop #: WSC 00098
       VCID: 6E85CF61A982BB472BB-5184
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: VwZ7Z0A3253560
       IMMO-IDENTNR: VwZ7Z0A3253560
                00-00 - -
    01128 - Immobilizer Pickup Coil (D2)
                35-10 - - - Intermittent
    01176 - Key
                65-10 - Unauthorized - Intermittent
    01177 - Engine Control Unit
    Address 19: CAN Gateway        Labels: None
       Part No: 6n0 909 901
       Coding: 04102
       Shop #: WSC 08258
       VCID: 1079B199D376CDB7597-5184
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AJ
       Component: 61 Zentral-SG Komf. 0001
       Coding: 04096
       Shop #: WSC 00066
       VCID: 065597C1A1329307F3B-4B1E
       Subsystem 1 - Part No: 1J1959801C
       Component: 61 Tőrsteuerger. FS0002r
       Subsystem 2 - Part No: 1J1959802D
       Component: 61 Tőrsteuerger. BF0002r
       Subsystem 3 - Part No: 1J4959811C
       Component: 61 Tőrsteuerger. HL0002r
       Subsystem 4 - Part No: 1J4959812C
       Component: 61 Tőrsteuerger. HR0002r
    01358 - Internal Central Locking Switch; Driver Side (E150)
       Part No: 1JM 035 157 A
       Component:  Radio DE2         0005
       Coding: 02043
       Shop #: WSC 22503
       VCID: 3E253F21B9620BC7FBB-51F2
    00856 - Radio Antenna
                36-10 - Open Circuit - Intermittent
    End----(Elapsed Time: 05:30, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Sep 2016
    Riga, Latvia
    If Your car does not have this sensor You have to disable oil level/temperature sensor option in Your IPC coding, or ask Jack to do it for You. In case fault is still present after repairs.
    Post a fresh scan, please.
  3. Likes Uwe liked this post
    Eric,
    That is why they call them oil PSI switches no?
    Did you install equipment yet and scan for faults after cleared to see what is displayed?
    Is it running yet?
    Did you know all coding's were matched to your legacy scan?
    Why are you relying on data from a FUBAR eeprom and bullshit scan data, get your shit together man?
    Did you go back to your original thread & compare yet?
    Jun 2019
    CA, USA
    It's alive its alive. (need to do some adaptations this weekend). Will report final scan.
    I got a day job and mama needs a new pair of shoes.....
  6. Likes Uwe, Jack@European_Parts liked this post
