Replacement windshield wiper switch cruise control and wiper module VW Passat B7 2013
kaleon
Poland
C?ID=376848
Hello everyone.
This is my "almost" first message ;-)
My English will not always be perfect and I apologize for any mistakes :-)
I recently have a VW PASSAT B7 Variant (365) 1.4 TSI EcoFuel from 2013 + DSG in a high version but I miss a few things that I would like to modernize successively.
I have already managed to encode some of them in the original VCDS version.
Now let's deal with my problem.
The main thing he does is install the active cruise control (ACC). In my version I have to replace and add a few things.
I started by replacing the MF Cruise Control Stalk Wiper Switch & Module - 5K0953569T
After the exchange, I made the basic setting of the steering angle according to the instructions in WIKI.
There are several errors that I can't deal with and I need help. At the very bottom I will post a full scan but before that I would like to tell you about the next stages that I plan.
After replacing and getting rid of any errors, I would like to run the normal cruise control until I replace the ABS pump and mount the radar and harness.
I did CCS coding but it doesn't work properly. I checked in the measuring blocks of group 66 and after switching on ON the following value appears to me 00000001 and I read somewhere that there should be two ones at the end, i.e. 00000011
I wonder if CCS does not work because of these errors or something is faulty and to be replaced?
Let's deal with the first liquidation of errors and then the launch of CCS and the subsequent stages to launch ACC
I would also like to activate the tire pressure sensor. I have installed sensors in the wheels but the system is not working properly. I need to find out if my car has a TPMS driver module - 3AA907273D. If it is not present, can someone show me the location where it should be mounted and should there be a bundle in this place or should I pull the cables?
Thursday,14,November,2019,22:07:11:24806VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VIN: WVWZZZ3CZDE143770   License Plate:
Mileage:    Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 37 42 44 46 4C 4F 52 53
          55 56 5C 61 62 65 6C 72 77 A5
VIN: WVWZZZ3CZDE143770   Mileage:
5C-Lane Maintain. -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Cannot be reached 1100
Address 01: Engine (CDG)       Labels: 03C-906-021-CDG.clb
   Part No SW: 03C 906 021 Q    HW: 03C 907 309 D
   Component: 4414 CNG 14K31  G   6368
   Revision: E8H06---    Serial number: VWZCZ000000000
   Coding: 0000077
   Shop #: WSC 27360 000 1048576
   VCID: 291AEBE98099C407D0-807C
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 000 -  - Intermittent
                    Mileage: 205965 km
                    Date: 2014.04.06
                    Time: 00:03:24
                    RPM: 740 /min
                    Load: 12.2 %
                    Temperature: 83.0°C
                    Temperature: 44.0°C
                    Absolute Pres.: 950.0 mbar
                    Voltage: 12.700 V
001384 - Cruise Control Switch (E45)
               P0568 - 000 - Implausible Signal - Intermittent
                    Mileage: 205965 km
                    Date: 2014.04.06
                    Time: 00:27:13
                    RPM: 720 /min
                    Load: 20.0 %
                    Temperature: 90.0°C
                    Temperature: 56.0°C
                    Voltage: 13.208 V
050217 - Implausible Data Received from Steering Column Control Module
               U0429 - 000 -  - Intermittent
                    Fault Frequency: 9
                    Mileage: 205965 km
                    Date: 2014.04.06
                    Time: 00:27:17
                    RPM: 735 /min
                    Load: 20.8 %
                    Temperature: 90.0°C
                    Temperature: 54.0°C
                    Voltage: 13.970 V
Readiness: 0010 0001
   Part No SW: 0AM 300 058 P    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5279
   Revision: 00043014    Serial number: CU501505296123
   Shop #: WSC 30268 001 1048576
   VCID: 3E3028B5691753BF95-806A
   Part No SW: 3AA 614 109 AQ    HW: 3AA 614 109 AQ
   Component: J104   C2 450M VD47 0030
   Revision: --H07---    Serial number: 00000006844616
   Coding: 0132465
   Shop #: WSC 21354 231 45312
   VCID: 7CB4E2BD3F8B81AFFB-8028
   Part No SW: 3AA 907 044 AJ    HW: 3AA 907 044 AJ
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0014004802
   VCID: 78BCFEADC3B3AD8F9F-802C
   Part No SW: 3AA 937 087 Q    HW: 3AA 937 087 Q
   Component: BCM PQ47 H+   422 0474
   Revision: BC422001
   Coding: 000A000000000000009802887400297427D54B88636DAD60E48046240041
   VCID: 48DC4E6DFBD31D0F2F-801C
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 25021  10  0603
   Coding: 00B795
   Component: RLS 150313 05  54  0403
   Coding: 06302A
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261307502042
   Coding: 348106
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000.rod
   VCID: 44C45A5DCFFB396FC3-8010
   Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
   Component: J234__10H VW10 HI   2318
   Revision: 27019000    Serial number: 003N5P3LW76$
   Coding: 0012360
   Shop #: WSC 05311 000 00000
   VCID: 004C964D5363E54FA7-8054
   Subsystem 1 - Serial number: 6332MTS630410633
   Subsystem 2 - Serial number: 6342MTS621680633
   Subsystem 3 - Serial number: 6351HTS620FCRBKR
   Subsystem 4 - Serial number: 6361HTS6CJ52RBKJ
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Component: LENKS.MODUL   009 0135
   Revision: FF010036    Serial number: 20100703201071
   Coding: 399A250001
   VCID: 75A2F799D4A1D0E784-8020
   Coding: E30000
   Part No SW: 3AA 920 880 J    HW: 3AA 920 880 J
   Component: KOMBI         H05 0505
   Coding: 161F01
   VCID: 3A3824A5BD3F7F9FA9-806E
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Reifendrucküberwachung: keine Kommunikation]
                    Reset counter: 70
                    Mileage: 205982 km
                    Date: 2019.11.14
                    Time: 01:19:42
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 5K0 963 272 B
   Component: Standheizer     022 3907
   Revision: 00022000    Serial number: 09020188000000
   Coding: 0031032
   Shop #: WSC 35410 001 1048576
   VCID: 2F2E05F1BE7DAA370E-807A
   Part No SW: 7N0 907 530 AJ    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1634
   Revision:   H51       Serial number: 200313F1003004
   Coding: 462006
   VCID: 78BCFEADCBB3AD8F9F-802C
                    Reset counter: 70
                    Mileage: 205982 km
                    Date: 2014.04.06
                    Time: 01:19:47
02797 - Control Module for Directional Stabilization Assistance (J759)
                    Reset counter: 70
                    Mileage: 205982 km
                    Date: 2014.04.06
                    Time: 01:19:43
   Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
   Component:    IMMO         043 0404
   VCID: 383C3EAD4B336D8F5F-806C
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 P
   Component: RNS-MID       H11 5274
   Revision: AB001001    Serial number: VWZ6Z7T0094028
   Coding: 04000402040000A02011
   Shop #: WSC 35104 001 1048576
   VCID: 3B3621A1BA054697B2-806E
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V9  7918
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0006733303
   Coding: 0010FF
   Shop #: WSC 05311 115 00000
   VCID: 35223799942190E744-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703 B    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0503
   Serial number: 00000003385025
   Coding: 0100D8
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.309 1401
   Revision: 1BH04739    Serial number: 00151970032101
   Coding: 0000258
   VCID: 41CA534918E92C47E8-8014
   Component:    KSG PQ47 ELV 043 0638
   Coding: 00910A0052830E76340A941570084F0B605800
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
   Component: EZE_2         H51 1634
   Coding: 050B0508
   VCID: 6FAEC5F1BEFDEA374E-803A
   Component: J245EE20SKB13  H05 0220
   Component: J394EE20SKB13  H05 0220
   Subsystem 3 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0006724988
   Coding: 0010FE
   VCID: 3620309589279BFF4D-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704 B    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0503
   Serial number: 00000003365562
   Coding: 0100D8
   Revision:   H19       Serial number: 00000000866854
   Coding: 0022157
   VCID: 3620309541279BFF4D-8062
   Component: AFS-ECU       H04 0111
   Coding: 021200000B000200
   VCID: 373E3D918E2D62F756-8062
   Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0012
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0012
   Coding: 230000
Address 5C: Lane Maintain.
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AJ
   Component: Batt.regelung H51 1634
   Coding: 33260864
   VCID: 71AAC389A8C9FCC758-8024
   Component: J367-BDM  H07 0180
   Serial number: 40082527551490303795
Address 65: Tire Pressure
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Component: J772__Rearview      0020
   Revision: 00H13000    Serial number: 525PA8-J4Z0185
   Coding: 0020007
   VCID: 689CAEED5B133D0F0F-803C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 70
                    Mileage: 205982 km
                        Reverse OFF
                    Count: 3
   Part No SW: 3C8 035 730 C    HW: 3C8 035 730 C
   Component: Telefon       012 0822
   Revision: --------    Serial number: 35909603550691
   Coding: 020100000000000000000000
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_UHVPremi A02705
   ROD: EV_UHVPremi_A02.rod
   VCID: 2306F9C12AB51E579A-8076
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H09 0300
   Serial number: 0193033225
   Coding: 010101010102020D0200000000010000
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: 393A3BA9B8397487A0-806C
End----------(Elapsed Time: 01:56, VBatt start/end: 12.1V/12.0V)-----------
Thank you in advance to everyone for your support and good word that will direct the solution.
Maciej
siLc
Tallinn, Estonia
C?ID=330192
AFAIK you don't have to change the steering wheel controller if you already have normal cruise and steering wheel buttons. Only the stalks with ACC buttons will suffice.
TPMS module is installed under the rear bumper on the right side and you don't have it. You will also need the mounting frame 3AA907538. See article for exact location -> https://www.drive2.ru/l/500238759049035913/
You can untick module 5C in CAN gateway installation list as this car doesn't have this module.
kaleon
Poland
C?ID=376848
Thanks for the answer.
Unfortunately, but I had to replace the steering wheel controller because my previous one had no levers at all. It was quicker to replace the whole "spider".
TPMS - will this location be identical for the car with the original CNG installation?
I still have to buy the mounting frame you wrote about.
One more question.
When replacing the steering wheel controller, my steering wheel housing will not fit because there is no cutout for the cruise control handle. Does anyone have a part number somewhere that I need to buy?
best regards
Maciej
siLc
Tallinn, Estonia
C?ID=330192
Yes, the TPMS position is exactly the same. I have the same CNG model and have done this retrofit.
Lower steering column trim with CCS is part number 3C0858559J 1QB.
kaleon
Poland
C?ID=376848
Everything's great. I only have a problem with the availability of used parts.
but we can do it.
Is there anyone able to help me fix the problems in the car and remove errors that have appeared?
One more question.
I would like to mount a DYNAUDIO speaker set and ask if it is a complete set or something is missing to make it complete.
2X Speaker front low / medium tones 3C0035454B
2X Speaker front highs 3C0035411D IN CASE WITH DYNAUDIO LOGO
2X Speaker rear low tones 3C0035453B
2X Speaker rear highs 3C0035411E
1X Amplifier 3AA035456A
1X Amplifier harness
Does the amplifier have any specific place? In several photos I saw that they mount in place for a spare wheel but in my I have CNG cylinders installed there and I wonder where there is a good place for mounting this amplifier.
In the near future I would like to install side assist and electric flaps but that's another topic for another time.
siLc
Tallinn, Estonia
C?ID=330192
Factory location for amplifier is under the driver's seat. If you are planning on upgrading the radio eventually to Discover Media PQ, get the 3AA035466 model of Dynaudio amplifier, which is compatible with it.
Most of the parts I used in my retrofits are from allegro.pl, so you should get everything eventually.
kaleon
Poland
C?ID=376848
Dude, you're great :):):)
I was planning to install Discover Media PQ. Do you have a list of the things you need to buy? what version of radio should I buy and would I have to mention something else by the way? so I quickly took a look and wrote about the reversing camera and parktronic jets and do I need to change anything in my particular car?
I found two models 5C0035680C and 5C0035680D on the Allegro.
For me, I have a high version webcam with swivel lines, so theoretically you do not need to replace it, but you probably need some adapters or I would not need to change it?
Do you know any page where someone described what needs to be replaced and how to do it and encode it to work properly?
So to sum up the purchase of DYNAUDIO, I have to find the amplifier No. 3AA035466 and is everything else OK?
I put beer for you!
siLc
Tallinn, Estonia
C?ID=330192
No problem!
For DM PQ, start with changing the CAN gateway out with version at least 7N0907530BC. Simply buying a vanilla DM PQ won't get you anywhere - Component Protection will kick in after 8 hours and it will not play sound anymore. Buying a patched unit would prevent this. I have a contact, a fellow countryman of yours, who can certainly help with this. PM if you want his contact.
680C and 680D are pretty much the same thing but the former also has DAB radio capability. A, C, E and G have DAB. B, D and F do not. If you can, obtain either F or G - they are the newest revisions.
For highline rear view camera, you will definetly have to swap the camera itself (this worked for me) and camera module for 7N0907441B. You will need someone with VCP to upload the correct parameters to the camera module and calibrate it (either by actually calibrating or writing calibration values straight into the module EEPROM). The newer camera module will have a different connector, so you'll have to replace the current camera module connector. Also you will have to run a new coaxial video cable from DM PQ to the camera module.
You will need to also replace the park assist module 10 with module 1K8919475D and also have it parameterized with VCP. The new module will also have different connectors but a converter is available (you'll also have to add some pins to the converter as it's normally for 8K PDC, you have 12K PLA 2.0). You will gain auto-activation of the parking sensors while slowly driving forward, like on Golf 7 and Passat B8.
As for Dynaudio, AFAIK everything else looks OK. But keep in mind, the door wiring harnesses in cars with a factory amp (VW Sound System and Dynaudio) are way different than cars without one. Amplified systems will have all the door speakers (tweeter, midrange, midbass) connected directly to the amplifier via seperate wires, while the unamplified system will have only a single pair of wires go into the door (tweeter, midbass). Either you will have to run extra wires for midrange speaker and tweeter or replace the door wiring harnesses in full.
kaleon
Poland
C?ID=376848
Hi siLc
I got the ACC on and everything works great.
I would now like to return to the topic of DM PQ exchange.
You described everything to me great, but I miss the information about the front camera on the windshield and the assistants who use it. Does it also need to be replaced? if so, what model?
Will there still be Line Assist, road signs, automatic lights?
Is it enough to save the old coding to replace the CAN gateway or do you need to make some adaptation?
you talked about version 7N0907530BC - is it enough for other future modifications? is it better to choose another newer model?
siLc
Tallinn, Estonia
C?ID=330192
In conjunction with DM PQ, only the traffic sign recognition requires the Passat B8 front camera (module A5). So you will lose it if you don't change the camera but you gain a much better Lane Assist. Suitable A5 model is 3Q0980654F. You will also need to change the camera connector plug and buy an adapter for the camera.
https://3d-print.jomatik.de/object.php?id=2119
https://3d-print.jomatik.de/object.php?id=2070
I changed my CAN some 3 years ago, don't exactly remember anymore - coding mainly and maybe a few adaptations. BC is simply the minimum CAN gateway model for future retrofits - you can also get BG and BL.
kaleon
Poland
C?ID=376848
These adapters are a cool thing :-)
What is the code of this new plug and you may have a list somewhere, what to connect where?
I will want to do PLA 2.5 in the next step, i.e. replacing the PDC module and the converter you wrote about.
and the exchange of Gateway for 7N0907530BC or BG, BL
and during this time I have to look for a radio. Is it certain when buying e.g. 5C0035680G - will it always have App Connect and Android Auto applications? I am mainly interested in firing while driving google maps navigation and some google music or spotify.
And I'm also interested in where I get the radio from? from a phone that is paired via BT or USB is it possible to connect a SIM card somewhere in the radio where I have internet? There is wifi in this radio and I wonder how it works :-)
siLc
Tallinn, Estonia
C?ID=330192
8E0972112 is the plug. There are several versions of it with different suffixes - this non-suffix one is the most suitable.
A fellow countryman of yours can provide a patched DM PQ. PM me for number.
kaleon
Poland
C?ID=376848
I already got the number from you on PM thanks. We will be looking for something because he is currently out of stock with WV and he found SEAT ALHAMBRA 7N5035680E and says that he will convert them to WV :-)
We will cover this topic only when he returns from vacation in about two weeks.
Until then, I have to gather all the components needed to replace the DM.
And I have two topics to cover.
1. PDC module to run PLA 2.5 - I know that I need the 1K8919475D driver but I can't get it anywhere. Somewhere I read that you can buy a different model and flash it - do you know what can be a replacement?
2. Reversing camera - high version
I need to replace what I currently have and there are several options to use an adapter - https://www.car-tronic.pl/adapter-d...umbusrcd510-linie-skretne -version-high-p7618
but it is terribly expensive and it would be better to buy a high camera under the B8 - am I right? if so, what number do I need to buy and I need to pull a new harness to the camera?
Someone else recommends such a camera but I do not know if it is suitable and if it is good or better to switch to the camera from the B8 High.
https://pl.aliexpress.com/item/32845418960.html?spm=a2g0s.9042311.0.0.1ec65c0faQa4hU
If you need to pull a new beam under the webcam, I will decide to immediately throw the beam under the side assist to the radars in the bumper and I would like to fold the electric hook and the TPMS sensor so I still have some topics to cover :-D and maybe I will throw the beam immediately under the automatic opening trunk - I do not know if they follow the same path, but when I remove the upholstery, I will do the cables immediately.
siLc
Tallinn, Estonia
C?ID=330192
1. You can use VCP or ODIS to flash 5Q0919298K with HW index of H12 to 1K8919475D. Also CC parameters will need to be uploaded to the module with VCP.
2. You will need to replace the camera and camera control module. I've done a DM PQ install and appropriate camera conversion on a B7 and you don't need this adapter. Simply change the camera in the hatch, change the camera module, rewire the camera module plug and run the new camera signal wire to the back of the radio. The seperate camera plug from the RNS510 will be unused.
You can pretty much get all the stuff needed here -> https://allegro.pl/oferta/vw-sharan-kamera-cofania-7n0827566-7n0907441b-2017-8468900154
But since this is from a Sharan, the camera would probably need to be calibrated afterwards as the picture could be distorted.
I didn't quite understand that last paragraph...
kaleon
Poland
C?ID=376848
The point is, how should I connect a new signal cable to the camera,
I will immediately want to insert new signal cables to other modifications on the back of the car, eg Side Assist, electric hook, opening trunk and tpms sensor which should be in the rear bumper.
I have to look for wires on the Allegro but I do not know their markings.
Please write to me what the rear camera number under B7 looked like to work with DM PQ
siLc
Tallinn, Estonia
C?ID=330192
I see.
Wiring on Allegro is usually sold with the modules, not seperately. Even finding complete wiring for stuff other than the electric trailer hitch is a surprise - usually you Poles discard such stuff when the donor vehicle is dismantled. You can certainly find the electric trailer hitch with complete wiring and module. Since this B7 does not have kessy, Easy Open is no-go for you. You could retrofit the electrically opening hatch though.
If you want only wiring, then Aliexpress will help. This is the only wiring needed to be run for the DM PQ camera module conversion -> https://www.aliexpress.com/item/32948058703.html?spm=2114.12010612.8148356.27.2d0b7697oN9VHY
You will also find wiring for your other retrofits from this seller. Most of my wiring is from there.
My highline camera after installation:
ACtC-3eU0phyLdkyjjjmnuJWFdAKuIJ1Z8VXGpMmQl9DYBoy-LSltsqlb_6gDX___eVXSk3lxMEYmXuyUu7HNHsCcrXFdBuINaoK_NME4jTz7j88a0p1Sfpy4YbgDKnTqFBVVopwCldlQO4S840DZ8yRQEBtGA=w1731-h1298-no
kaleon
Poland
C?ID=376848
Thank you :-)
I will buy a cable. Now I need to buy cameras. Which camera should I buy in the High version to fit the B7 and the DM PQ radio?
Out of curiosity :-)
can I install kessy? Worth it?
kaleon
Poland
C?ID=376848
Maybe you have access to the file with these parameters?
siLc
Tallinn, Estonia
C?ID=330192
I do have VCP, but my files are no use to you because of VCP's copy protection scheme. But lets not talk about VCP - this is a forum for VCDS ;)
