Results 1 to 8 of 8
Thread: Audi a3 . 8P ABS problem fault code ;16352
    Oct 2019
    Morocco
    HELLO ; I have an audi a3 8P
    I have a problem in the module ABS
    Thursday,14,November,2019,20:47:20:13605
    VIN: WAUZZZ8P19A079654   License Plate: A3
    Mileage: 172680km-107298mi   Repair Order:
    Chassis Type: 8P-AU35 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WAUZZZ8P19A079654   Mileage: 172680km-107298miles
    Address 01: Engine        Labels: 03G-906-021-BLS.clb
       Part No SW: 03G 906 056 R    HW: 03G 906 021 AB
       Component: R4 1,9L EDC G000SG  2916
       Revision: --H09---    Serial number: AUX7Z0HNFNI00P
       Coding: 0000071
       Shop #: WSC 80093 222 69422
       VCID: 36352622E4442FE723B-8062
    001025 - EGR System
                   P0401 - 000 - Insufficient Flow - Intermittent
                        Fault Status: 00110000
                        Mileage: 172662 km
                        Date: 2019.11.11
                        Time: 22:32:08
                        RPM: 1890 /min
                        Speed: 31.0 km/h
                        Load: 27.5 %
                        Duty Cycle: 14.6 %
                        Duty Cycle: 95.1 %
                        Mass Air / Rev.: 240.0 mg/str
                        Mass Air / Rev.: 465.0 mg/str
    000564 - Boost Pressure Regulation
                   P0234 - 000 - Limit Exceeded (Overboost Condition) - MIL ON
                        Fault Status: 11110000
                        Mileage: 172674 km
                        Date: 2019.11.12
                        Time: 12:41:25
                        RPM: 2604 /min
                        Speed: 105.0 km/h
                        Load: 79.2 %
                        Voltage: 14.29 V
                        Bin. Bits: 00101000
                        Absolute Pres.: 2029.8 mbar
                        Absolute Pres.: 2539.8 mbar
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
       Coding: 1142201209290003881104E9901D00413800
       Shop #: WSC 06314 123 12345
       VCID: 74B1DC2ABEB87DF7DDF-8020
    16352 - Control Module - Electrical Error
                        Fault Status: 00101110
                        Reset counter: 24
                        Mileage: 172657 km
                        Date: 2019.11.11
                        Time: 10:26:12
                        Count: 4
                        Count: 12800
                        Count: 98
                        Count: 49411
                        Count: 2
                        Reset counter: 24
                        Mileage: 172657 km
                        Date: 2019.11.11
                        Time: 10:26:34
                        Count: 7
                        Count: 12800
                        Count: 104
                        Count: 50449
                        Count: 1
                        Reset counter: 24
                        Mileage: 172657 km
                        Date: 2019.11.11
                        Time: 09:32:57
                        Count: 3
                        Count: 2
                        Count: 12288
                        Count: 320
                        Count: 43776
                        Count: 1
       Part No: 8P0 820 047 B
       Component: J255  Klima Man H07 0030
       VCID: 2F3B13461B1E1E2F60D-807A
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
       Component: Bordnetz-SG     H54 2801
       Revision: 00H54000    Serial number: 00000009116967
       Coding: 10A82F8190141380EF00001C0000000000094A156401040300A800000000
       Shop #: WSC 06314 000 08192
       VCID: 48C958DA9EB0A917417-801C
       Subsystem 1 - Part No: 8P1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H10 0040
       Coding: 00064784
       Shop #: WSC 06314
    9 Faults Found:
                        Fault Status: 00101100
                        Reset counter: 61
                        Mileage: 172518 km
                        Date: 2019.10.25
                        Time: 00:56:00
                        Voltage: 12.10 V
    01502 - Bulb for Rear Fog; Left (L46)
                        Reset counter: 61
                        Mileage: 172518 km
                        Date: 2019.10.25
                        Time: 00:52:00
                        Voltage: 12.30 V
    00906 - Horn (H1)
                        Fault Status: 00101001
                        Reset counter: 64
                        Mileage: 172648 km
                        Date: 2019.11.11
                        Time: 20:39:00
                        Voltage: 12.60 V
    01516 - Terminal 30; Left
                        Fault Status: 00101011
                        Reset counter: 64
                        Mileage: 172648 km
                        Date: 2019.11.11
                        Time: 20:39:00
                        Voltage: 12.65 V
    01064 - Terminal 58d; Interior Dimming
                        Fault Status: 00100111
                        Reset counter: 64
                        Mileage: 172648 km
                        Date: 2019.11.11
                        Time: 20:39:00
                        Voltage: 12.65 V
    00926 - Terminal 30
                        Reset counter: 64
                        Mileage: 172648 km
                        Date: 2019.11.11
                        Time: 20:40:00
                        Voltage: 5.00 V
    00927 - Terminal 30 (Right)
                        Reset counter: 64
                        Mileage: 172656 km
                        Date: 2019.11.11
                        Time: 00:00:00
                        Voltage: 12.55 V
                        Reset counter: 61
                        Mileage: 172518 km
                        Date: 2019.10.25
                        Time: 00:24:00
                        Voltage: 11.90 V
    00984 - Left Tail Light (M4)
                        Reset counter: 61
                        Mileage: 172518 km
                        Date: 2019.10.25
                        Time: 00:12:00
                        Voltage: 11.85 V
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
       Component: Airbag AU1042 H06 0090
       Revision: --------    Serial number: 003000000000
       Coding: 303142383038303030354A55304C38503053
       Shop #: WSC 06314 000 00000
       ROD: EV_Airba10AURB4.rod
       VCID: 49CF5DDE893A501F5E9-801C
       Serial number: 3572DRB400008424B8F
       Serial number: 3582DRB4000084207ADV
       Serial number: 35128RB4000047174569
       Serial number: 35228RB40000471D4FBV
       Serial number: 35547RB4000048ABE9E7
       Serial number: 35647RB4000048ABEDFD
    13636864 - Control Module for ABS Brakes
              U1015 00 [008] - No Communications
              [Lost Communication With Vehicle Dynamics Control Module]
                        Reset counter: 64
                        Mileage: 172656 km
                        Date: 2019.11.11
                        Time: 00:24:09
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0000042
       VCID: 41DF45FEBD8A985F869-8014
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 931 S    HW: 8P0 920 931 S
       Component: KOMBIINSTR. VDO H18 0830
       Revision: D0H18006    Serial number: 224NH006056422
       Coding: 0004128
       VCID: 43D34FF6A7968A4F945-8016
       Component: J533__Gateway   H16 0210
       Revision:   H16       Serial number: 3400K08B140407
       Coding: E9807F06000202002102
       VCID: 372B2B26E34ED6EF38D-8062
                        Reset counter: 64
                        Mileage: 172656 km
                        Date: 2019.11.11
                        Time: 09:18:17
                        Fault Frequency: 119
                        Reset counter: 24
                        Mileage: 172656 km
                        Date: 2019.11.11
                        Time: 09:18:18
    01304 - Radio
                        Reset counter: 24
                        Mileage: 172656 km
                        Date: 2019.11.11
                        Time: 09:18:21
       Revision: D0H18006    Serial number: AUX7Z0HNFNI00P
    16346 - Control Module - ROM Error
                014 - Defective
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
       Component: Tuer-SG         H03 0060
       Coding: 0000148
    00912 - Window Regulator Switch; Front Left (E40)
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 232    2301
       Revision: 00H15000
       VCID: 2A0D025220FC7B07B73-807E
                        Reset counter: 74
                        Mileage: 172656 km
                        Date: 2019.11.11
                        Time: 09:16:21
                        Voltage: 12.13 V
                            DU
                        Temperature: 26.0C
                        Speed: 50.0 km/h
                        Speed: 50.0 km/h
       Part No: 8P0 959 433 L
       Component:    KSG          H11 0080
       Coding: 1880200002186D0985054C8F0167
       VCID: 45D751EEA9A2B47FBA1-8010
       Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
       Coding: 0000148
       VCID: 44D14CEAA2988D77ADF-8010
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
    Address 56: Radio
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
       Component: Tuer-SG         H04 0040
       Coding: 0000144
       Shop #: WSC 06314 000 1012544
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
       Coding: 0000144
       VCID: 42DD4AF2B88C83479F3-8016
    End----------(Elapsed Time: 01:19, VBatt start/end: 12.3V/12.3V)-----------
    Did you check for warranty safety recall yet for free repair?
    Oct 2019
    Morocco
    no its warranty run out . I check all abs system the code in the first post
    Jul 2017
    Kenya
    Quote Originally Posted by ahmed ait siaddi View Post
    Replace ABS/ESP control 1K0 907 379AD
  5. Likes ahmed ait siaddi liked this post
    Oct 2016
    Quote Originally Posted by Fredrick Awuor View Post
    Check fuses first. If not agree replace abs module
    Sep 2016
    Riga, Latvia
    Quote Originally Posted by Radiosolutions View Post
    In addition I'd suggest not only fuses but load test all power and ground wires to ABS/ESP unit.
    From my experience: I have solved a lot of cases where other workshops have replaced ABS modules but the same fault codes are still here
    I most especially like when I get my customers a free or reimbursable repair, wouldn't you?
    I agree with Mr. X he knows his shit!
    I would like to add, that often a bad ignition switch, can indeed result in such an ABS fault too and wouldn't you know it, that's a known defect too; & often covered by campaign?
  9. Likes Uwe liked this post
  10. #8
    Oct 2019
    Morocco
    thanx guys for your time . i will double check the fuses and the wires . i was looking for an abs modules to replace it i found some but not the same module
