The following information is from a 2018 A4 SilverCar. For some reason, I was under the impression it was a 2019. Supposedly, Silvercar will be phasing out the Audi A4 models and keeping the Q5 as the base vehicle.
ref:
Vehicle Identification No. WAUENAF47JA147898
Model Audi A4 qu. 2,0
A4
Date of production 02.03.2018
Model year 2018
Sales type 8W25NY
Engine Code CYMC
Transmission Code TBR
Axle drive 7A
Auto-Scan and again, these vehicles are full of fault codes.
Auto-Scan after some testing and clearing the fault codes.
Maps..................
blockmap-17-8W5-920-890-D
adpmap-17-8W5-920-890-D
blockmap-19-8W6-907-468-F
adpmap-19-8W6-907-468-F
ref:
A4
Model year 2018
Sales type 8W25NY
Engine Code CYMC
Axle drive 7A
Sunday,10,November,2019,17:36:11:27784
VCDS Version: 19.9.3.0 (x64) HEX-NET CB: 0.4516.4
Data version: 20190930 DS314.0
VIN: WAUENAF47JA147898 License Plate: HN2_USB_001
Mileage: 32501km-20195mi Repair Order:
Chassis Type: F4-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F 6C
81 A5 BB BC CA CF D6 D7
VIN: WAUENAF47JA147898 Mileage: 32501km-20195miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC) Labels:. 06K-907-425-V2.clb
Part No SW: 8W0 906 259 J HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0002
Revision: --H15---
Coding: 0A2500322326010E34280000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
ROD: EV_ECM20TFS0208W0906259J.rod
VCID: 48C2336AA24533C7569-801C
19861 - Implausible Data Received from Body Control Module A (Central Electric 2)
U0431 00 [032] - -
23126 - Fuel Level Sensor Circuit
P0461 00 [096] - Implausible Signal
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 BA HW: 0CJ 927 156
Component: 0CL 20TFSINAR H05 0001
Revision: --H05--- Serial number: 0000003009
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU49.rod
VCID: 0154EE4EC1FFC28FD17-8054
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180039002726
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 K HW: 8W0 907 379 J
Component: ESP9 Plus H10 0766
Coding: 18AA409928A60A9D11A6489A00855292E4259A180214508812004A4927A459
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 4DCC027E4D27D6EF65F-8018
7 Faults Found:
15371776 - Databus
U1121 00 [032] - Missing Message
[ComScl:_Signal_Group_SG_AEB_01_-_Timeout_error]
15385344 - Databus
U1122 00 [040] - Implausible Message
[ComScl:_Signal_Group_SG_Klemmen_Status_01-_Checksum_error]
Mileage: 31452 km
Date: 2019.10.24
Time: 11:08:55
83 40 80 00 CA 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 02
420352 - TPMS Warning; Front Left Tire
C1054 00 [040] - Pressure too Low
Mileage: 32039 km
Date: 2019.11.04
Time: 13:11:34
92 00 80 2B 88 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 1E
416768 - TPMS Warning; Front Right Tire
C1056 00 [040] - Pressure too Low
Mileage: 32039 km
Date: 2019.11.04
Time: 13:11:34
417024 - TPMS Warning; Rear Right Tire
C105A 00 [040] - Pressure too Low
Mileage: 32039 km
Date: 2019.11.04
Time: 13:11:34
419584 - TPMS Warning; Rear Left Tire
C1059 00 [032] - Flat
419840 - TPMS Warning; Rear Right Tire
C105B 00 [032] - Flat
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0210
Coding: 140805095544000D10000100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44DA275A9E6D17A7BA1-8010
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002173732
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 92A0141900PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
459025 - Databus
Reset counter: 57
Mileage: 20527 km
Date: 2019.06.28
Time: 12:24:51
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07500363E0081CCD0515871518AC98BB110B3D08000000000000000020001A010A690122025705
Shop #: WSC 06325 790 00001
VCID: 0256E142C4F9D997C8D-8056
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 180129 043 0813
Serial number: 89435300301802906266
Coding: 5BC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 21162035X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AK HW: 4M0 941 531 AK
Component: E1 - LDS H06 0008
Serial number: 10 01 2018 01257092
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z003102
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20180123021932 00039
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE114121723610576
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CJ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00692010
Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2817000303921002
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 G HW: 8W0 959 655 G
Component: Airbag10.44 H05 0107
Serial number: 003UQ002EM7I
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705G0051S01321
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706J0051S01931
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J180008XIW801
Subsystem 4 - Part No SW: ----------- HW: 442 061 102 18
Serial number: 3577Y00BD28937B3E22C
Subsystem 5 - Part No SW: ----------- HW: 442 061 102 18
Serial number: 3587Y00BB28937B15343
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 901 18
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700C9291FA26820D
Subsystem 7 - Part No SW: ----------- HW: 442 0B2 901 18
Serial number: 352770099292F3F0B28N
Subsystem 8 - Part No SW: ----------- HW: 442 0C3 001 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B529A8BE1536O
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C3 001 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B529A8BE3411J
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GB HW: 4M0 907 129 GB
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76BE8D929831F537F45-8022
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 890 D HW: 8W5 920 890 D
Component: FBenUSA H18 0373
Coding: 09E651C12888CF050223E9601800000008000000
ASAM Dataset: EV_DashBoardAU736 001027
Part No SW: 8W6 907 468 F HW: 8W6 907 468 E
Component: Gateway H43 0123
Revision: 7B000002 Serial number: 0287B774018222
Coding: 030100010000064029070000005900124C180007100000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180221031542 20435
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 8410526904
131723 - Body Control Module (Central Electric 2)
U0141 00 [008] - No Communications
[Timeout_Node_0x8B_DiagAdress_46_BCM2]
Reset counter: 117
Mileage: 31478 km
Date: 2019.10.24
Time: 17:59:25
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Electric_current_Upper_Limit_Value_Exceeded]
Reset counter: 126
Mileage: 30955 km
Date: 2019.10.18
Time: 19:25:27
Total static current-current total quiescent current: 124 mA
Total static current-Total time quiescent current exceeded: 1.0 H
EM_vehicle_state: 00 00
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
VCID: 78A283AA92258347E69-802C
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0042
Serial number: 00000305815222
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
VCID: 79A486AEA92F9A4F997-802C
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 363E4D92D8B1B537345-8062
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0129
Serial number: 0000305797478
Coding: 005F1B205E001080000100B2
VCID: 43D824469B63109F83B-8016
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 42D621428479199788D-8016
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 EC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 025 0387
Coding: 013400004FB00080650FA0002E01000233024000810026502F0400000B04803F001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY18023449Y
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099769943
Subsystem 3 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: >1218533
131086 - Antenna for Keyless Entry System; Interior Antenna 1
B1172 13 [008] - Open Circuit
Fault Frequency: 14
Reset counter: 149
Mileage: 30955 km
Date: 2019.10.18
Time: 18:24:00
Supply voltages-Supply voltage: Terminal 30: 12.582 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.609 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.609 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 80
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
antenna_freeze_frame: 00011001 00000000 00000000 01011101
65896 - Databus
[Climatronic control module: Klima_03: no signal/communication]
Reset counter: 154
Mileage: 15391 km
Date: 2019.04.11
Time: 14:20:21
Supply voltages-Supply voltage: Terminal 30: 13.044 V
Supply voltages-Supply voltage Terminal 30 - 2: 13.071 V
Supply voltages-Supply voltage Terminal 30 - 3: 13.071 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 02 98
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAHJA03N4WL
Coding: 0194010800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0129
Serial number: 0000305562655
Coding: 005F1B205E001080000100B0
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 880 B HW: 8W5 035 880
Component: MU-P-LNS-US 034 1178
Serial number: A798B0JB086239
Coding: 019401020000000053220002041A00102F0002E501700904FE
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
VCID: 3E2E55B2F0817D77EC5-806A
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Subsystem 2 - Part No SW: 8W0 919 605 HW: 8W0 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9HBJ04JGJ
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK129011800020023
Component: Gracenote2 --- 3012
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Coding: 0294010102002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: 33387486CBC3A01F13B-8066
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 G HW: 8W1 713 041 J
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 18022046117960
ROD: EV_GSMWaehlZFAU736.rod
VCID: 37204096DFBB4C3F2F3-8062
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 C HW: 8W0 907 217 C
Component: BVS H17 0050
Coding: 0404090100000201022023A2A50000FC00F0C020C000
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 3C2A5FBAE69D6F67C21-8068
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS 005 0129
Serial number: 0000306272232
Coding: 000F1B2000001080400000A0
VCID: 45DC3A5E95572EAFADF-8010
Component: TSG HBFS 005 0129
Serial number: 0000306282348
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 H HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 2A8000049100
VCID: 3B285CA6E393685FCBB-806E
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
ROD: EV_LEDModLeftMELCOAU736_AU37.rod
VCID: 167EAD12B8715537145-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
End----------(Elapsed Time: 01:55, VBatt start/end: 13.2V/13.2V)-----------
Sunday,10,November,2019,21:15:32:27784
Revision: --H15---
VCID: C8C2B36A2245B3C7D69-809C
Readiness: 1010 0101
Coding: 000001
VCID: 81546E4E41FF428F517-80D4
VCID: CDCC827ECD2756EFE5F-8098
VCID: C4DAA75A1E6D97A73A1-8090
VCID: 8256614244F9599748D-80D6
Coding: 5BC7F7
Coding: 02005D
Light switch:
Coding: 350000
Coding: 80000D
Coding: 80000D
Occupant Detection:
VCID: F6BE0D9218317537745-80A2
VCID: F8A203AA12250347669-80AC
VCID: F9A406AE292F1A4F197-80AC
Revision: --------
Coding: 0E8002
VCID: B63ECD9258B13537B45-80E2
VCID: C3D8A4461B63909F03B-8096
VCID: C2D6A1420479999708D-8096
65896 - Databus
Reset counter: 154
Mileage: 32501 km
Date: 2019.11.10
Time: 20:47:45
Supply voltages-Supply voltage: Terminal 30: 12.663 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.691 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.677 V
VCID: BE2ED5B27081FD776C5-80EA
VCID: B338F4864BC3201F93B-80E6
VCID: B720C0965FBBCC3FAF3-80E2
VCID: BC2ADFBA669DEF67421-80E8
VCID: C5DCBA5E1557AEAF2DF-8090
VCID: BB28DCA66393E85F4BB-80EE
Revision: --------
Coding: 0E8002
VCID: 967E2D123871D537945-80C2
End----------(Elapsed Time: 02:02, VBatt start/end: 13.2V/13.2V)-----------
;SW:8W5-920-890-D HW:8W5-920-890-D --- Instruments
;Component:FBenUSA H18 0373, Coding:09E651C12888CF050223E9601800000008000000
;EV_DashBoardAU736,001027,EV_DashBoardAU736_AU49.rod
;Sunday,10,November,2019,20:19:20:01617
;VCDS Version: Release 19.6.2 (x64) Data version: 20190930 DS308.0
;VCID: C4CB4F564F9D0E6F43-8090
Group,Description,Actual
IDE00019,Voltage terminal 30,13.10, V
IDE00021,Engine speed,801, /min
IDE00025,Coolant temperature,90.00, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00191,Charge air pressure: actual value,0.00, %
IDE00196,Engine oil temperature,90, °C
IDE00301,Distance,32501, km
IDE00310,Outside air temperature,27.00, °C
IDE00316-IDE00500,Time-Hour,20, H
IDE00316-IDE00501,Time-Minute,19, min
IDE00316-MAS00111,Time-Seconds,21, s
IDE00317-IDE00502,Date-Year,2019, yr
IDE00317-IDE00503,Date-Month,11, mon
IDE00317-IDE00504,Date-Day,10, d
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00510,ESI: distance driven from inspection,2700, km
IDE00511,ESI: time from inspection,31, d
IDE00512,ESI: minimum value km-driving distance/inspection,14500, km
IDE00513,ESI: maximum value km-driving distance/inspection,14500, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,5300, km
IDE00520,Phototransistor,2,
IDE00695,ESI: service exceedance in km,Not available,
IDE00696,ESI: service exceedance in days,Not available,
IDE00697,ESI: remaining distance,13220, km
IDE00698,ESI: remaining running time,334, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,618, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,1990, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2046, mm
IDE00935,ESI: Theoretical service interval,26300, km
IDE01076,Time since ignition off,4663, s
IDE01153,SIA: maximum value of distance to service,16000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01285,Counter of component protection malfunctions,0,
IDE01985-ENG101043,FAZIT identification test sum-Checksum,0D 31 AF 2C,
IDE01985-ENG99027,FAZIT identification test sum-Version,81,
IDE02642,Outside temp.: displayed value,25.50, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,3A,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,3A,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,3A,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,2,
IDE03349,FIX: Max. distance until next mileage-related inspection,32032, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,17100, km
IDE03352,FIX: Time since last time-dependent inspection,213, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-ENG126401,Vehicle configuration-intelligent_park_assist,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,43.30, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,58.00, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,61.00, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,43.40, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,49.00, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,58.00, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,57.80, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,48.10, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,16.50, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,58.00, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,61.40, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,17.30, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,38.00, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,58.00, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,60.50, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,37.70, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,32250, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,32170, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,32070, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,31720, km
IDE03474-IDE00304,Calculated volume-Fuel level,33.70, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,63, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,267, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,not_available,
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,not_available,
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,33.20, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,1.00, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,not_available,
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,not_available,
IDE03474-IDE00802,Calculated volume-Full volume,58.00, l
IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,34.20, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,1.00, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,not_available,
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,not_available,
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.00,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.00,
IDE03474-ENG102894,Calculated volume-averaged_volume,34.20, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,34.20, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,34.20, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,1.00,
IDE03474-ENG99553,Calculated volume-linking,0.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.16, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,35.10, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.00,
IDE03474-ENG99683,Calculated volume-version_of_application,12,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0008316,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03475-MAS12387,Control button in instrument cluster-Button for daily distance driven,not active,
IDE03477-IDE00500,GPS time-Hour,20, H
IDE03477-IDE00500,GPS time-Hour,19, H
IDE03477-IDE00501,GPS time-Minute,50, min
IDE03477-IDE00501,GPS time-Minute,19, min
IDE03477-IDE00502,GPS time-Year,2019, yr
IDE03477-IDE00503,GPS time-Month,11, mon
IDE03477-IDE00504,GPS time-Day,10, d
IDE03477-MAS00111,GPS time-Seconds,31, s
IDE03477-MAS00111,GPS time-Seconds,16, s
IDE03477-MAS03493,GPS time-last synchronization year,2019, yr
IDE03506,Distance: high resolution,01 EF ED 6B,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 AD,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0F,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0F,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 AD,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,6F F0 00 AD,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,2F F0 00 0F,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,4F F0 01 95,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,0F F0 3C 1F,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,8F F0 3C 1F,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,CF F0 01 95,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,6F F0 02 4B,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,2F F0 74 12,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04649-ENG128738,Activation for housing fan-PWM_FAN,0, %
IDE04649-ENG128737,Activation for housing fan-source_max_PWM_requested,none,
IDE04649-ENG98933,Activation for housing fan-Status,OFF,
IDE04649-ENG128733,Activation for housing fan-temperature_Boost,50, °C
IDE04649-ENG128734,Activation for housing fan-temperature_chipled,49, °C
IDE04649-ENG128736,Activation for housing fan-temperature_GPU,56, °C
IDE04649-ENG128735,Activation for housing fan-temperature_KI,50, °C
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,1095, d
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-IDE06026,Roller test bench mode: functional-Adaptation of brake pedal path sensor,not activated,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06924,Performance display,0,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE07578-MAS00138,Operating range consumption with electric drive-1,0.00,
IDE07578-MAS00139,Operating range consumption with electric drive-2,65534,
IDE07578-ENG04221,Operating range consumption with electric drive-ERW_Energieinhalt,0.00,
IDE07578-ENG114651,Operating range consumption with electric drive-s_erw_rw_batterie,65534, km
IDE07578-ENG114652,Operating range consumption with electric drive-s_erw_rw_batterie_anz,65534, km
IDE07578-ENG114648,Operating range consumption with electric drive-s_erw_rwds,0.00, A
IDE07578-ENG114640,Operating range consumption with electric drive-s_erw_rwds_high,10.00, A
IDE07578-ENG114644,Operating range consumption with electric drive-s_erw_rwds_low,10.00, A
IDE07578-ENG114637,Operating range consumption with electric drive-s_erw_rwdv_antrieb_high_unclass,2.50, kWh/100 km
IDE07578-ENG114641,Operating range consumption with electric drive-s_erw_rwdv_antrieb_low_unclass,25.00,
IDE07578-ENG114645,Operating range consumption with electric drive-s_erw_rwdv_antrieb_unclass,0.00,
IDE07578-ENG114638,Operating range consumption with electric drive-s_erw_rwdv_dcdc_high_unclass,0.20, kWh/100 km
IDE07578-ENG114642,Operating range consumption with electric drive-s_erw_rwdv_dcdc_low_unclass,0.20,
IDE07578-ENG114646,Operating range consumption with electric drive-s_erw_rwdv_dcdc_unclass,0.00,
IDE07578-ENG114639,Operating range consumption with electric drive-s_erw_rwdv_tme_high_unclass,0.50,
IDE07578-ENG114643,Operating range consumption with electric drive-s_erw_rwdv_tme_low_unclass,0.50,
IDE07578-ENG114647,Operating range consumption with electric drive-s_erw_rwdv_tme_unclass,0.00,
IDE07578-ENG114649,Operating range consumption with electric drive-s_erw_rwdv_unclass,0.00,
IDE07646-ENG114675,Consumption for road-specif. range with electric drive-s_erw_endsteigung,0.00, %
IDE07646-ENG114667,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_0,0.00, kWh/100 km
IDE07646-ENG114668,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_1,0.00, kWh/100 km
IDE07646-ENG114669,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_2,0.00, kWh/100 km
IDE07646-ENG114670,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_3,0.00, kWh/100 km
IDE07646-ENG114671,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_4,0.00, kWh/100 km
IDE07646-ENG114672,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_5,0.00, kWh/100 km
IDE07646-ENG114673,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_6,0.00, kWh/100 km
IDE07646-ENG114653,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_0,25.00, kWh/100 km
IDE07646-ENG114654,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_1,25.00, kWh/100 km
IDE07646-ENG114655,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_2,25.00, kWh/100 km
IDE07646-ENG114656,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_3,25.00, kWh/100 km
IDE07646-ENG114657,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_4,25.00, kWh/100 km
IDE07646-ENG114658,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_5,25.00, kWh/100 km
IDE07646-ENG114659,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_6,25.00, kWh/100 km
IDE07646-ENG04222,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_low_class,25.00, kWh/100 km
IDE07646-ENG114674,Consumption for road-specif. range with electric drive-s_erw_str_klasse,0,
IDE08343,Immobilizer Challenge,C6 E5 49 B4,
IDE08701-MAS07266,ESI: Status-Oil change: unit of dist. travelled,miles,
IDE08701-MAS07267,ESI: Status-Oil change: dist. travelled,8300,
IDE08701-MAS07268,ESI: Status-Oil change: stat. of dist. travelled,Service in,
IDE08701-MAS07269,ESI: Status-Oil change: stat. of time,Service in,
IDE08701-MAS07270,ESI: Status-Inspection: stat. of dist. travelled,Service in,
IDE08701-MAS07271,ESI: Status-Inspection: unit of dist. travelled,miles,
IDE08701-MAS07272,ESI: Status-Inspection: dist. travelled,9300,
IDE08701-MAS07273,ESI: Status-Inspection: time,517,
IDE08701-MAS07274,ESI: Status-Oil change warning,no warning,
IDE08701-MAS07277,ESI: Status-Inspections warning,no warning,
IDE08701-MAS07305,ESI: Status-Oil change: time,334,
IDE08701-MAS07308,ESI: Status-Inspection: status time,Service in,
IDE08701-MAS10768,ESI: Status-Daily mileage,80,
IDE08775-MAS01390,Active driver info.-Block 1,DF 00 A4 44,
IDE08775-MAS01391,Active driver info.-Block 2,A2 1F 00 00,
IDE08775-MAS01392,Active driver info.-Block 3,00 00 00 00,
IDE08775-MAS01393,Active driver info.-Block 4,00 00 00 00,
IDE08775-MAS01394,Active driver info.-Block 5,00 00 00 00,
IDE08775-MAS01395,Active driver info.-Block 6,00 00 00 00,
IDE08775-MAS01396,Active driver info.-Block 7,00 00 00 00,
IDE08775-MAS01397,Active driver info.-Block 8,00 00 00 00,
IDE08775-MAS01398,Active driver info.-Block 9,00 00 00 00,
IDE08775-MAS01399,Active driver info.-Block 10,00 00 00 00,
IDE08775-MAS01400,Active driver info.-Block 11,00 00 00 00,
IDE08775-MAS01401,Active driver info.-Block 12,00 00 00 00,
IDE08775-MAS01402,Active driver info.-Block 13,00 00 00 00,
IDE08775-MAS01403,Active driver info.-Block 14,00 00 00 00,
IDE08775-MAS01404,Active driver info.-Block 15,00 00 00 00,
IDE08775-MAS01405,Active driver info.-Block 16,00 00 00 00,
IDE08775-MAS01406,Active driver info.-Block 17,00 00 00 00,
IDE08775-MAS01407,Active driver info.-Block 18,00 00 00 00,
IDE08775-MAS01408,Active driver info.-Block 19,00 00 00 00,
IDE08775-MAS01409,Active driver info.-Block 20,00 00 00 00,
IDE08776-MAS01390,Key-relevant driver information-Block 1,A4 44 00 00,
IDE08776-MAS01391,Key-relevant driver information-Block 2,00 00 00 00,
IDE08776-MAS01392,Key-relevant driver information-Block 3,00 00 00 00,
IDE08776-MAS01393,Key-relevant driver information-Block 4,00 00 00 00,
IDE08776-MAS01394,Key-relevant driver information-Block 5,00 00 00 00,
IDE08776-MAS01395,Key-relevant driver information-Block 6,00 00 00 00,
IDE08776-MAS01396,Key-relevant driver information-Block 7,00 00 00 00,
IDE08776-MAS01397,Key-relevant driver information-Block 8,00 00 00 00,
IDE08776-MAS01398,Key-relevant driver information-Block 9,00 00 00 00,
IDE08776-MAS01399,Key-relevant driver information-Block 10,00 00 00 00,
IDE08777-MAS00106,History memory: driver info.-Year,2019,
IDE08777-MAS00107,History memory: driver info.-Month,11,
IDE08777-MAS00108,History memory: driver info.-Day,10,
IDE08777-MAS00109,History memory: driver info.-Hours,19,
IDE08777-MAS00110,History memory: driver info.-Minutes,50,
IDE08777-MAS00111,History memory: driver info.-Seconds,25,
IDE08777-MAS01390,History memory: driver info.-Block 1,A2 1F,
IDE10117-MAS11870,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 1,33.20, l
IDE10117-MAS11871,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 2,1.00, l
IDE10117-MAS11872,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 3,not_available,
IDE10117-MAS11873,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 4,not_available,
IDE10347-ENG118215,Trip distance challenge-Challenge,32 00 00 00 00 37 DE C9 8E 00 17 01 00 00 00 57 41 55 45 4E 41 46 34 37 4A 41 31 34 37 38 39 38 BC 13 44 04 B1 46 76 1F 00 00,
IDE10348-ENG98502,Trip distance data-Data,32 00 00 00 00 00 00 00 00 00 17 01 00 00 00 57 41 55 45 4E 41 46 34 37 4A 41 31 34 37 38 39 38 A4 7D EB 94 C4 DD BE 2C 00 14 00 03 00 F5 7E 00 F6 7E 00 00 00 00 00 00 00 00 00 00 00 00,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG126262-ENG114675,Consumption_for_distance_on_map-s_erw_endsteigung,0.00, %
ENG126262-ENG114674,Consumption_for_distance_on_map-s_erw_str_klasse,0,
ENG126262-ENG128739,Consumption_for_distance_on_map-s_vkmrw_rwdv_antrieb_low_class,7.20, l/100km
ENG126262-ENG126309,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_0,7.30, l/100km
ENG126262-ENG126310,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_1,9.80, l/100km
ENG126262-ENG126311,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_2,9.80, l/100km
ENG126262-ENG126312,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_3,9.80, l/100km
ENG126262-ENG126313,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_4,9.80, l/100km
ENG126262-ENG126314,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_5,9.80, l/100km
ENG126262-ENG126315,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_6,9.80, l/100km
ENG126262-ENG126302,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_0,7.30, l/100km
ENG126262-ENG126303,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_1,10.00, l/100km
ENG126262-ENG126304,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_2,10.00, l/100km
ENG126262-ENG126305,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_3,10.00, l/100km
ENG126262-ENG126306,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_4,10.00, l/100km
ENG126262-ENG126307,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_5,10.00, l/100km
ENG126262-ENG126308,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_6,10.00, l/100km
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,88, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,17, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,7, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,7, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,7, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,80, km
ENG107920-ENG98868,onboard_computer-Range,406, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,7.50, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,0.00, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,0.00, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,0.00, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,7.50, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,7.00, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,0.00, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,0.00, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,0.00, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,65534, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,65534, km
ENG107920-ENG119791,onboard_computer-range_display_value,406, km
ENG107920-ENG126299,onboard_computer-range_lpg,65534, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,65534, km
ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,151,
ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
ENG109340-ENG104056,tank_validation-s_vali_abs_active,not active,
ENG109340-ENG102652,tank_validation-s_vali_abs_display_0,not active,
ENG109340-ENG102994,tank_validation-s_vali_abs_distance/mileage,not active,
ENG109340-ENG101149,tank_validation-s_vali_abs_rough,not active,
ENG109340-ENG101740,tank_validation-s_vali_active,not active,
ENG109340-ENG101355,tank_validation-s_vali_consumption_deq,3276.80, l
ENG109340-ENG100596,tank_validation-s_vali_consumption_deq_abs,3276.80, l
ENG109340-ENG102770,tank_validation-s_vali_display_0,not active,
ENG109340-ENG99133,tank_validation-s_vali_needle_vol_ref,not active,
ENG109340-ENG99562,tank_validation-s_vali_rough,not active,
ENG109340-ENG100160,tank_validation-s_vali_status,2, l
ENG109340-ENG103691,tank_validation-s_vali_vol_delta_gef,3276.80, l
ENG109340-ENG100615,tank_validation-s_vali_vol_delta_roh,3277.00, l
ENG109340-ENG99506,tank_validation-s_vali_vol_g1_vg,3310.00, l
ENG109340-ENG103928,tank_validation-s_vali_vol_g2_vg,3277.80, l
ENG109340-ENG101476,tank_validation-s_vali_vol_g3_vg,3276.80, l
ENG109340-ENG101237,tank_validation-s_vali_vol_g4_vg,3276.80, l
ENG109340-ENG101103,tank_validation-s_vali_vol_ref_gew,3310.80, l
ENG109340-ENG100543,tank_validation-s_vali_vol_ref_vg,3316.10, l
ENG109340-ENG100079,tank_validation-s_vali_vol_total_vg,3311.00, l
Elapsed Time: 00:29
;Sunday,10,November,2019,20:19:49:01617
IDE00001-Production mode,not active ,3
IDE00301-Distance,32501 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,US English ,1
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,20 H,1
IDE00501-Minute,19 min,1
IDE00502-Year,2019 yr,2
IDE00503-Month,11 mon,1
IDE00504-Day,10 d,1
IDE00510-ESI: distance driven from inspection,2700 km,3
IDE00511-ESI: time from inspection,31 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,14500 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,14500 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,5300 km,2
IDE00819-Day counter,618 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,16000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,0.00 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-1.00 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,0.00 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5
IDE03329-Driving profiled for range remaining,7.50 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,miles ,3
IDE03346-MAS01230-Units adjusted-Date,yy_mm_dd ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,°F ,3
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03348-Speed warning-,not active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,32032 km,3
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,17100 km,3
IDE03352-FIX: Time since last time-dependent inspection,213 d,2
IDE03372-Source for synchronization of time,GPS ,1
IDE03867-Deactivate seat belt warning,No ,1
IDE04169-Display correction of consumption and operating range: gas,100 %,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,1095 d,2
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,No display ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE07221-Cylinder shut-off,No display ,1
IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage,10.00 A,8
IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive,25 ,8
IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer,0.20 ,8
IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer,0.50 ,8
IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0,25.00 ,14
IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1,25.00 ,14
IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2,25.00 ,14
IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3,25.00 ,14
IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4,25.00 ,14
IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5,25.00 ,14
IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6,25.00 ,14
IDE08140-Driving profiled for range remaining CNG,0.00 kg/100 km,2
IDE08247-Driving profile for range remaining LPG,0.00 l/100km,2
IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
IDE10693-Initialize sensor for fuel level,No ,1
IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,7.30 l/100km,14
IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 l/100km,14
IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 l/100km,14
IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 l/100km,14
IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 l/100km,14
IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 l/100km,14
IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 l/100km,14
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE12050-Acoustic: drive position R,active ,1
MAS03555-Lap counter,No display ,1
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,21
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,21
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,21
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,21
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,21
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,21
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,21
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,500ms ,21
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,50ms ,21
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,50ms ,21
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,21
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,21
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,21
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,21
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,100ms ,21
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,21
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,21
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,21
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,21
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,21
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,21
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,21
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,21
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,21
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,21
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,21
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,21
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,21
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,21
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,21
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,21
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,21
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,21
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,21
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,21
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,500ms ,21
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,500ms ,21
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,21
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,100ms ,21
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,100ms ,21
ENG128731-MAS01129-designvariant_activation-Version 1,not active ,2
ENG128731-MAS01130-designvariant_activation-Version 2,not active ,2
ENG128731-MAS01131-designvariant_activation-Version 3,not active ,2
ENG128731-MAS03101-designvariant_activation-Version 4,not active ,2
ENG128731-MAS03102-designvariant_activation-Version 5,not active ,2
ENG128731-MAS03103-designvariant_activation-Version 6,not active ,2
ENG128731-MAS03104-designvariant_activation-Version 7,not active ,2
ENG128731-MAS03105-designvariant_activation-Version 8,not active ,2
ENG99320-Developers_menu,not active ,1
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00 ,12
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC ,12
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,50 ,12
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,02 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,02 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,14 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,1E ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,32 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,46 ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,64 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,00 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,14 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,1E ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,32 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,46 ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,02 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,02 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,06 ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,0A ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,50 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,50 ,12
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
ENG126283-parameter_hmi,41 43 56 03 05 FF 1E 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
ENG135292-phev_stat_intervall-,5.00 ,3
ENG135292-phev_stat_intervall-,100 m,3
ENG135292-phev_stat_intervall-,0 min,3
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.50 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,1.40 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,active ,4
Elapsed Time: 00:26
blockmap-19-8W6-907-468-F
;SW:8W6-907-468-F HW:8W6-907-468-E --- CAN Gateway
;Component:Gateway H43 0123, Coding:030100010000064029070000005900124C180007100000000175078E10000000
;EV_CGateCONTIAU491,003111,EV_CGateCONTIAU491_003_AU49.rod
;Sunday,10,November,2019,20:20:19:01617
;VCID: CDDD6A729CD7CF279C-8098
IDE00009,Date of manufacture,18 02 22,
IDE00010,Serial number,0287B774018222,
IDE00019,Voltage terminal 30,13.20, V
IDE00020-MAS00044,Terminal 15 status-Supply voltage: Terminal 15,13.20, V
IDE00020-MAS03680,Terminal 15 status-Terminal 15 status measured,On,
IDE00020-MAS05562,Terminal 15 status-Terminal 15 resulting,On,
IDE00020-MAS07720,Terminal 15 status-Terminal 15 via CAN,On,
IDE00020-MAS08946,Terminal 15 status-Terminal 15 via comparator,On,
IDE00056,History data 1,000*2019-01-24-15:13*00.2*01**,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00**,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00*00000**,
IDE00056,History data 1,000*2019-01-24-21:33*03.9*01*00165**,
IDE00056,History data 1,000*2019-01-24-12:33*01.0*01**,
IDE00056,History data 1,000*2019-01-23-20:19*05.6*01**,
IDE00056,History data 1,000*2019-01-24-14:19*00.1*01**,
IDE00056,History data 1,000*2019-01-24-16:52*01.7*01**,
IDE00057,History data 2,134*2019-03-08-19:24*0001.0*051*00101*0000*01**,
IDE00057,History data 2,172*2019-11-01-09:58*0001.1*051*00236*0000*01*00049**,
IDE00057,History data 2,134*2019-03-08-15:15*0001.0*052*00099*0000*01**,
IDE00057,History data 2,134*2019-03-07-18:25*0001.0*054*00114*0000*01**,
IDE00057,History data 2,066*2019-10-18-19:25*0001.0*047*00124*0000*01**,
IDE00057,History data 2,172*2019-11-01-07:35*0002.2*049*00223*0000*01**,
IDE00057,History data 2,184*2019-03-14-02:38*0002.0*055*00099*0000*01**,
IDE00057,History data 2,017*2018-12-25-02:51*0004.0*052*00237*0000*01**,
IDE00057,History data 2,166*2018-12-10-07:53*0003.0*054*00119*0000*01**,
IDE00057,History data 2,017*2018-12-25-06:53*0001.7*055*00267*0000*01**,
IDE00058,History data 3,027*2018-08-06-08:40*T*0*0*061*043*0000*0*00.0*00.0**,
IDE00058,History data 3,032*2018-08-22-08:49*T*0*0*090*069*0000*0*00.0*00.0**,
IDE00058,History data 3,030*2018-08-09-11:32*T*0*0*099*076*0000*0*00.0*00.0**,
IDE00058,History data 3,028*2018-08-07-11:45*T*0*0*089*067*0010*0*00.0*00.0**,
IDE00058,History data 3,031*2018-08-13-12:09*T*0*0*095*072*0010*0*00.0*00.0**,
IDE00058,History data 3,033*2018-08-22-13:06*T*0*0*085*065*0010*0*00.0*00.0**,
IDE00058,History data 3,029*2018-08-09-11:32*T*0*0*099*076*0000*0*00.0*00.0**,
IDE00059,History data 4,000*2000-01-01-00:00*00*000*00*000*0000000000*00000*00000*000.0*000.0*000.0**,
IDE00059,History data 4,009*2018-03-02-04:50*01*075*01*JCB*280225P0F4*10008*04247*000.0*000.0*000.0**,
IDE00060,History data 5,000*2000-01-01-00:00*0*000000*0000*00.0*000*00*-00.0*00000*00000*0000*00000000*000*00.0*00.0*0000.0**,
IDE00061,History data 6,008*2019-11-10-18:26*049*+26*+000.1*0000*00*00.01**,
IDE00061,History data 6,000*2019-11-09-17:02*053*+30*+001.1*0000*00*00.40**,
IDE00061,History data 6,002*2019-11-10-12:55*049*+23*+000.1*0000*00*00.01**,
IDE00061,History data 6,004*2019-11-10-17:31*049*+25*+001.1*0000*00*00.43**,
IDE00061,History data 6,003*2019-11-10-16:15*048*+25*+000.2*0000*00*00.01**,
IDE00061,History data 6,252*2019-11-08-23:06*046*+34*+000.9*0000*00*00.03**,
IDE00061,History data 6,005*2019-11-10-18:16*049*+26*+000.2*0000*00*00.11**,
IDE00061,History data 6,005*2019-11-10-17:57*049*+26*+000.4*0000*00*00.30**,
IDE00061,History data 6,254*2019-11-09-11:02*054*+29*+001.6*0032*02*00.83**,
IDE00061,History data 6,009*2019-11-10-18:28*049*+26*+000.0*0000*00*00.06**,
IDE00061,History data 6,252*2019-11-09-10:55*049*+29*+000.1*0079*01*00.11**,
IDE00061,History data 6,249*2019-11-08-22:47*047*+34*-000.1*0095*02*00.08**,
IDE00061,History data 6,006*2019-11-10-18:24*049*+26*+000.0*0000*00*00.03**,
IDE00061,History data 6,254*2019-11-09-12:10*054*+29*+001.2*0002*01*02.41**,
IDE00061,History data 6,001*2019-11-09-19:29*051*+29*+000.6*0000*00*00.31**,
IDE00062,History data 7,003*2019-11-10-16:16*048*-000.5*00.0*00.0*0001.2**,
IDE00062,History data 7,250*2019-11-08-22:54*046*-000.5*00.0*00.0*0000.1**,
IDE00062,History data 7,247*2019-11-08-19:39*046*-000.7*00.0*00.0*0002.3**,
IDE00062,History data 7,254*2019-11-09-11:53*052*-000.9*00.0*00.0*0000.2**,
IDE00062,History data 7,251*2019-11-08-23:05*046*-000.2*00.0*00.0*0000.0**,
IDE00062,History data 7,009*2019-11-10-18:32*050*-000.6*00.0*00.0*0001.2**,
IDE00062,History data 7,002*2019-11-10-12:57*049*-000.5*00.0*00.0*0003.1**,
IDE00062,History data 7,000*2019-11-09-17:27*051*-000.7*00.0*00.0*0001.9**,
IDE00062,History data 7,007*2019-11-10-18:26*049*-000.1*00.0*00.0*0000.0**,
IDE00062,History data 7,255*2019-11-09-14:36*053*-001.2*00.0*00.0*0002.3**,
IDE00062,History data 7,252*2019-11-08-23:09*052*-001.5*00.0*00.0*0010.4**,
IDE00062,History data 7,001*2019-11-09-19:49*049*-001.8*00.0*00.0*0016.6**,
IDE00062,History data 7,249*2019-11-08-22:52*047*-000.3*00.0*00.0*0000.0**,
IDE00062,History data 7,248*2019-11-08-22:46*046*-000.2*00.0*00.0*0000.0**,
IDE00062,History data 7,246*2019-11-08-19:30*045*-000.5*00.0*00.0*0000.0**,
IDE00063,History data 8,000*2018-08-06-08:45*1*+37.1*13.2*061*+29**,
IDE00063,History data 8,026*2018-03-01-22:44*1*+09.8*13.9*097*+22**,
IDE00063,History data 8,000*2018-08-06-09:17*1*+28.5*13.4*062*+30*12*00*00*05*00*00*000*000*00**,
IDE00063,History data 8,000*2018-03-02-00:05*1*+06.2*14.2*097*+23**,
IDE00063,History data 8,000*2018-08-06-09:12*1*+35.3*13.3*061*+29**,
IDE00063,History data 8,000*2018-03-01-23:59*1*+11.5*14.0*096*+22**,
IDE00064,History data 9,000*2019-07-17-07:51*086*089*075*051*02961*03.6*+29*09.5*02.9*00348*01770**,
IDE00064,History data 9,000*2019-01-13-05:22*085*093*053*033*01269*03.6*+21*09.2*03.0*00214*01077**,
IDE00064,History data 9,162*2019-08-16-23:26*087*090*078*054*03357*03.4*+34*09.6*03.0*00371*01886**,
IDE00064,History data 9,000*2019-05-16-18:39*090*091*070*050*02344*03.2*+31*09.6*03.0*00318*01616**,
IDE00064,History data 9,000*2019-06-16-08:11*086*090*084*059*02603*03.2*+28*09.8*03.0*00329*01684**,
IDE00064,History data 9,000*2018-12-13-11:20*082*091*077*050*00979*03.2*+26*09.9*02.8*00160*00800**,
IDE00064,History data 9,000*2019-02-12-22:32*092*094*073*055*01470*03.0*+27*09.7*02.9*00240*01201**,
IDE00064,History data 9,000*2019-04-15-17:20*087*092*068*046*02154*03.4*+29*09.7*03.0*00314*01595**,
IDE00064,History data 9,094*2019-09-16-13:35*082*086*075*052*03664*03.4*+38*09.4*02.9*00411*02068**,
IDE00064,History data 9,000*2000-01-01-00:00*000*000*000*000*00000*00.0*+00*02.0*00.0*00000*00000**,
IDE00064,History data 9,196*2019-03-15-15:50*092*093*074*055*01770*03.4*+26*09.6*02.9*00253*01282**,
IDE00064,History data 9,000*2019-10-17-11:56*084*088*074*049*03996*03.4*+30*09.6*03.0*00460*02335**,
IDE00065,History data 10,000*2000-01-01-00:00*00**,
IDE00065,History data 10,245*2019-10-02-20:22*2*079*051*+29*03*30*-28*10.8*6*00000*00027*00000**,
IDE00065,History data 10,243*2019-07-22-02:43*80*00000*00000*00000*00010*00000*00000*00000*00039**,
IDE00065,History data 10,000*2000-01-01-00:00*00*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00065,History data 10,243*2019-07-22-02:43*2*064*048*+38*03*30*-27*11.9*6**,
IDE00065,History data 10,116*2019-07-06-21:24*2*074*051*+30*03*30*-64*11.9*6**,
IDE00065,History data 10,230*2019-07-21-17:14*88**,
IDE00065,History data 10,070*2019-07-30-19:01*2*074*051*+38*03*30*-28*11.6*6**,
IDE00065,History data 10,213*2019-07-20-22:22*2*067*047*+41*03*30*-28*11.1*6**,
IDE00065,History data 10,233*2019-07-21-17:24*88**,
IDE00065,History data 10,233*2019-07-21-17:23*88**,
IDE00065,History data 10,243*2019-07-22-02:43*80**,
IDE00065,History data 10,220*2019-07-21-01:43*80**,
IDE00066,History data 11,009*2019-11-10-18:28*000*000*000*000*0000*004*00.1*00.1*077*049*077*049*00*00679*00789*01742*03407*00000**,
IDE00066,History data 11,004*2019-11-10-17:31*000*000*000*000*0000*026*00.2*01.3*076*048*076*049*00**,
IDE00066,History data 11,005*2019-11-10-18:16*000*000*000*000*0000*007*00.1*00.3*077*049*077*049*00**,
IDE00066,History data 11,006*2019-11-10-18:24*000*000*000*000*0000*002*00.1*00.1*077*049*077*049*00**,
IDE00066,History data 11,008*2019-11-10-18:26*000*000*000*000*0000*001*00.1*00.2*077*049*077*049*00**,
IDE00066,History data 11,005*2019-11-10-17:57*000*000*000*000*0000*018*00.1*00.5*076*049*077*049*00**,
IDE00067,History data 12,091*2019-10-21-15:13*0002*24*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,105*2019-09-18-10:12*0002*23*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,166*2019-10-31-10:53*0002*25*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,228*2019-08-30-08:16*0002*22*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,145*2019-08-07-23:47*0002*21*00*0000*00*00*0000*00*00**,
IDE00068,History data 13,254*2019-11-09-11:21*2*00.30*000*255*000*000*000*000*032**,
IDE00068,History data 13,254*2019-11-09-11:15*2*00.20*000*255*000*000*000*000*032**,
IDE00068,History data 13,253*2019-11-09-11:01*2*00.10*000*255*000*000*000*000*032**,
IDE00068,History data 13,255*2019-11-09-12:16*2*00.00*000*255*000*000*000*000*032**,
IDE00068,History data 13,249*2019-11-08-22:51*2*00.00*000*255*000*000*000*000*032**,
IDE00069,History data 14,000*2000-01-01-00:00*0*00.00*000*000*000*000*000*000*000**,
IDE00070,History data 15,000*2000-01-01-00:00*0*000*00.00*000*000*000**,
IDE00071,History data 16,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE00102,Control Module temperature,50, °C
IDE00322,Status of basic setting,was not yet started,
IDE00667,Microphone status,Electrical OK,
IDE00668,Microphone current consumption,6.10, mA
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button,Not available,
IDE00725,Manufacturer's test stand number,0032,
IDE00726,Subassembly and series number,0240,
IDE00767-ENG05080,No. of unscheduled ECU resets-KL30_Reset_Counter,6,
IDE00767-ENG05081,No. of unscheduled ECU resets-Last_Main_Controller_Reset_Reason,00 04,
IDE00767-ENG05078,No. of unscheduled ECU resets-Last_WD_Reset_Reason,00,
IDE00767-ENG05082,No. of unscheduled ECU resets-Main_Controller_Reset_Counter,1,
IDE00767-ENG05079,No. of unscheduled ECU resets-Wd_Reset_Counter,0,
IDE00767-ENG33384,No. of unscheduled ECU resets-Z0_Reset_Counter,0,
IDE01215,Terminal 58d dimmer,23.03, %
IDE01285,Counter of component protection malfunctions,00 00,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,-81709794,
IDE01712-MAS01780,GPS Position-Width,26245484,
IDE01712-MAS02230,GPS Position-Height,-10, m
IDE01713-MAS01632,Status GPS reception-Status,Not available,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,0,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,0,
IDE01715,Status terminal S,On,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,0, mA
IDE01803,History data 17,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE01804,History data 18,008*2019-11-10-18:26*1*001*00.01*000400*999*999*999**,
IDE01804,History data 18,005*2019-11-10-17:57*1*018*00.30*000400*999*999*999**,
IDE01804,History data 18,009*2019-11-10-18:28*1*004*00.06*000400*999*999*999**,
IDE01804,History data 18,007*2019-11-10-18:24*1*002*00.03*000400*999*999*999**,
IDE01804,History data 18,006*2019-11-10-18:16*1*007*00.11*000400*999*999*999**,
IDE01805,History data 19,000*2000-01-01-00:00*0000*0000.0*0000.0*0000.0*0000*00000000*000*000*000**,
IDE01805,History data 19,008*2018-03-02-00:57*0013*0001.9*0000.6*0000.7*0180*0103003D*000*000*002**,
IDE01805,History data 19,028*2018-03-01-23:18*0012*0031.5*0000.3*0030.3*0080*0103003D*000*000*001**,
IDE01806,History data 20,000*2000-01-01-00:00*0000*000*000*+0000000*+0000000**,
IDE01806,History data 20,034*2018-08-22-14:50*3938*057*073*-55D4A80*-ABA9500**,
IDE01807,History data 21,01318*05865*00190*00301**,
IDE01807,History data 21,01212*00298*00183**,
IDE01807,History data 21,00000*00000*00000*00000*00000**,
IDE01807,History data 21,00121*00006*00001**,
IDE01807,History data 21,032501**,
IDE01807,History data 21,02566*00028*00004*00003**,
IDE01807,History data 21,00034*00301*02233*00030*00005**,
IDE01807,History data 21,00015*00009*00009*00215**,
IDE01807,History data 21,00701*00354*00265*00186*00176*00129*00247*00155*00111*00241*00000**,
IDE01807,History data 21,01264*00725*00509**,
IDE01807,History data 21,00000*00000*00000*00000**,
IDE01807,History data 21,00707*00750*00325*00716**,
IDE01807,History data 21,00000*00000*00000**,
IDE01807,History data 21,,
IDE01808,History data 22,004*2019-11-10-17:38*2*0*003*000*075*075*0*00732*00289**,
IDE01808,History data 22,211*2019-11-05-07:52*2*0*004*000*072*072*0**,
IDE01808,History data 22,227*2019-11-06-22:48*2*0*009*000*075*075*0**,
IDE01808,History data 22,220*2019-11-05-13:44*2*0*003*000*071*070*0**,
IDE01808,History data 22,235*2019-11-08-06:48*2*0*003*000*071*071*0**,
IDE01809,History data 23,000*2000-01-01-00:00*0*00000*00000**,
IDE01810,History data 24,000*2000-01-01-00:00*0*0000*0000*0000*00000*00000*00000**,
IDE01811,History data 25,001*2000-00-00-00:00*000.1*001*000*000**,
IDE01811,History data 25,000*2000-01-01-00:00*000.0*000*000*001*00000*000.0*000*000*000**,
IDE01811,History data 25,000*2000-00-00-01:01*000.0*000*000*000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000**,
IDE01812,History data 26,009*2018-03-02-04:50*0040*00000*00000*00000*00000*00000*00000*00001*00000*00000*00000*00000*00000**,
IDE01816,History data 30,000*2000-00-00-00:00*0*0*0*0*0*000.00*000.00*-40**,
IDE01817,History data 31,,
IDE01817,History data 31,Nur für BEV ,
IDE01817,History data 31, ,
IDE01818,History data 32,000*2000-00-00-00:00*0*000*000*00.0*00.0*000*000*00.0*00.0*00000**,
IDE01819,History data 33,000*2000-00-00-00:00*0*000*000*000*000*00000*00000**,
IDE01820,History data 34,000*2000-00-00-00:00*0*0*000*000.0*00.0*00.0*000.0*00.0**,
IDE01821,History data 35,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01822,History data 36,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01823,History data 37,*0*0*0*0**000*2000-01-01-00:00*0*0*0*0*0,
IDE01823,History data 37,0*2000-01-01-00:00*0*0*0*0*0*0**,
IDE01823,History data 37,*0**000*2000-01-01-00:00*0*0*0*0*0*0**00,
IDE01823,History data 37,000*2000-01-01-00:00*0*0*0*0*0*0**000*20,
IDE01823,History data 37,01-00:00*0*0*0*0*0*0**000*2000-01-01-00:,
IDE01823,History data 37,00-01-01-00:00*0*0*0*0*0*0**000*2000-01-,
IDE01823,History data 37,00*0*0*0*0*0*0**000*2000-01-01-00:00*0*0,
IDE01823,History data 37,,
IDE01824,History data 38,000*2000-01-01-00:00*0*+000*000*0**,
IDE01825,History data 39,000*2019-11-10-17:29*000*001*000**,
IDE01825,History data 39,,
IDE01825,History data 39,000*2019-11-10-12:55*000*001*000**,
IDE01825,History data 39,000*2019-11-10-16:14*000*001*000**,
IDE01825,History data 39,000*2019-11-10-07:34*000*001*000**,
IDE01825,History data 39,000*2019-11-10-11:39*000*001*000**,
IDE01825,History data 39,000*2019-11-10-14:44*000*001*000**,
IDE01825,History data 39,000*2019-11-10-19:49*000*001*000**,
IDE01825,History data 39,000*2019-11-10-09:30*000*001*000**,
IDE01826,History data 40,000*2000-01-01-00:00*0*0*0*0*0*000.00*000.00*-50**,
IDE01827,Generator specified voltage value,13.5, V
IDE01828,Generator DF Signal,41.950, %
IDE01829,Generator exciter current,1.65, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Denso,
IDE01831-MAS06310,Generator variant-Generator identifier,110A - 150A MOSFET,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,1,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01833-MAS06105,Battery variant-Rated battery capacity,75, Ah
IDE01833-MAS06106,Battery variant-Battery technology,Fleece,
IDE01833-MAS06107,Battery variant-Battery manufacturer,JCI,
IDE01834,Battery voltage,13.303, V
IDE01836,Battery current,0.835, A
IDE01837,Temperature of battery sensor,29, °C
IDE01838,Battery temperature,28, °C
IDE01839,Battery charge condition,77, %
IDE01841,Battery internal resistance,3.8, mOhm
IDE01842,Usable battery charge,51, Ah
IDE01843,Battery voltage at rest,12.5, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shutdown level,Deactivation stage 0,
IDE01847-MAS01577,Auxiliary heater activation restriction request-Parking heater,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Previous journey energy summary,0.80, Ah
IDE01849,Previous journey duration,0.50, H
IDE01850,Total energy summary,10009.10, Ah
IDE01851,Total energy throughput,4248.1, Ah
IDE01852,Static current measurement: result,13, mA
IDE01853,Static current measurement: status,Cancel,
IDE01854-MAS09891,Energy reclamation request-recuperation active,active,
IDE01854-MAS09892,Energy reclamation request-Charge contingent for feedback,2880, As
IDE01855,Generator current,40.7, A
IDE01864-MAS03179,Status of current bus communication-Local data bus 2,active: local wakeup event,
IDE01864-MAS03180,Status of current bus communication-Local data bus,active: local wakeup event,
IDE01864-MAS05972,Status of current bus communication-Local data bus 3,not installed,
IDE01864-MAS10445,Status of current bus communication-Data bus CAN 1,active: local wakeup event,
IDE01864-MAS10446,Status of current bus communication-Data bus CAN 2,not installed,
IDE01864-MAS10447,Status of current bus communication-Data bus CAN 3,active: local wakeup event,
IDE01864-MAS10448,Status of current bus communication-Data bus CAN 4,active: local wakeup event,
IDE01864-MAS10449,Status of current bus communication-Data bus CAN 5,active: local wakeup event,
IDE01864-MAS10450,Status of current bus communication-Data bus CAN 6,active: local wakeup event,
IDE01864-MAS11107,Status of current bus communication-Data bus CAN 7,not installed,
IDE01864-MAS11108,Status of current bus communication-FlexRay star 3,not installed,
IDE01864-MAS11244,Status of current bus communication-FlexRay star 1,active: local wakeup event,
IDE01864-MAS11245,Status of current bus communication-FlexRay star 2,not installed,
IDE01948,Battery internal resistance not normed,3.6, mOhm
IDE01971,Lowest recorded control module temperature,33, °C
IDE01972,Highest recorded control module temperature,50, °C
IDE01992-IDE14867,Installation list: current installations-Subgateway as firewall control module,Not available,
IDE01992-SFT00001,Installation list: current installations-Engine Control Module 1,Available,
IDE01992-SFT00002,Installation list: current installations-Transmission Control Module,Available,
IDE01992-SFT00006,Installation list: current installations-Seat Adjustment Passenger Side,Not available,
IDE01992-SFT00007,Installation list: current installations-Display Control Unit,Not available,
IDE01992-SFT00008,Installation list: current installations-Air Conditioning,Available,
IDE01992-SFT00009,Installation list: current installations-Central Electrics,Available,
IDE01992-SFT00012,Installation list: current installations-Rear Axle Steering 2,Not available,
IDE01992-SFT00017,Installation list: current installations-Engine Control Module 2,Not available,
IDE01992-SFT00019,Installation list: current installations-Adaptive Cruise Control,Not available,
IDE01992-SFT00022,Installation list: current installations-Steering Column Electronics,Available,
IDE01992-SFT00023,Installation list: current installations-Dash Board,Available,
IDE01992-SFT00024,Installation list: current installations-Auxiliary Parking Heater,Not available,
IDE01992-SFT00025,Installation list: current installations-Gateway,Available,
IDE01992-SFT00027,Installation list: current installations-Active Steering,Not available,
IDE01992-SFT00032,Installation list: current installations-High Beam Assistance,Not available,
IDE01992-SFT00033,Installation list: current installations-Battery Energy Control Module 2,Not available,
IDE01992-SFT00034,Installation list: current installations-All Wheel Control,Not available,
IDE01992-SFT00035,Installation list: current installations-Brake Boost,Not available,
IDE01992-SFT00038,Installation list: current installations-Electronic Roof Control,Not available,
IDE01992-SFT00039,Installation list: current installations-Display Control Unit Rear,Not available,
IDE01992-SFT00040,Installation list: current installations-Climate Control Unit Rear,Not available,
IDE01992-SFT00042,Installation list: current installations-Control Unit Wireless Charging,Not available,
IDE01992-SFT00043,Installation list: current installations-Steering Column Locking,Not available,
IDE01992-SFT00048,Installation list: current installations-Special Function 2,Not available,
IDE01992-SFT00050,Installation list: current installations-Lock Electronics,Not available,
IDE01992-SFT00054,Installation list: current installations-Seat Adjustment Driver Side,Available,
IDE01992-SFT00061,Installation list: current installations-Special Function,Not available,
IDE01992-SFT00066,Installation list: current installations-Door Electronics Driver Side,Available,
IDE01992-SFT00068,Installation list: current installations-Steering Assistance,Available,
IDE01992-SFT00070,Installation list: current installations-Central Module Comfort System,Available,
IDE01992-SFT00072,Installation list: current installations-Seat Adjustment Rear Driver Side,Not available,
IDE01992-SFT00074,Installation list: current installations-Rear light,Not available,
IDE01992-SFT00077,Installation list: current installations-Löschkandidat_Datenübertragung Car2X,Not available,
IDE01992-SFT00080,Installation list: current installations-Seat Adjustment 3rd Row,Not available,
IDE01992-SFT00081,Installation list: current installations-Drive Motor Control Module,Not available,
IDE01992-SFT00082,Installation list: current installations-Door Electronics Passenger Side,Available,
IDE01992-SFT00090,Installation list: current installations-Longitudinal control,Not available,
IDE01992-SFT00091,Installation list: current installations-Seat Adjustment Rear Passenger Side,Not available,
IDE01992-SFT00095,Installation list: current installations-Information Control Unit 1,Available,
IDE01992-SFT00101,Installation list: current installations-Tire Pressure Monitoring 1,Not available,
IDE01992-SFT00105,Installation list: current installations-Trailer Function,Not available,
IDE01992-SFT00107,Installation list: current installations-Aerodynamics Control Unit,Not available,
IDE01992-SFT00108,Installation list: current installations-Camera System Rear View,Available,
IDE01992-SFT00109,Installation list: current installations-Deck Lid Control Unit,Not available,
IDE01992-SFT00116,Installation list: current installations-Chassis Control,Not available,
IDE01992-SFT00118,Installation list: current installations-Parking Assistance,Not available,
IDE01992-SFT00127,Installation list: current installations-Information Control Unit 2,Not available,
IDE01992-SFT00128,Installation list: current installations-Battery Regulation Auxiliary Accumulator 1,Not available,
IDE01992-SFT00129,Installation list: current installations-Gear Shift Control Module,Available,
IDE01992-SFT00130,Installation list: current installations-Head Up Display,Not available,
IDE01992-SFT00132,Installation list: current installations-Night Vision,Not available,
IDE01992-SFT00139,Installation list: current installations-Adaptive Cruise Control 2,Not available,
IDE01992-SFT00140,Installation list: current installations-Battery Energy Control Module,Not available,
IDE01992-SFT00166,Installation list: current installations-Microphone Control Unit,Not available,
IDE01992-SFT00169,Installation list: current installations-Actuator For Structure-borne Sound,Not available,
IDE01992-SFT00172,Installation list: current installations-Reductant Control Module,Not available,
IDE01992-SFT00183,Installation list: current installations-Access Startsystem Interface,Not available,
IDE01992-SFT00186,Installation list: current installations-Assembly Mounting,Not available,
IDE01992-SFT00192,Installation list: current installations-Actuator For Exterior Noise,Not available,
IDE01992-SFT00195,Installation list: current installations-Drive Motor Control Module 3,Not available,
IDE01992-SFT00196,Installation list: current installations-DC/DC Converter Control Module,Not available,
IDE01992-SFT00197,Installation list: current installations-Thermal management,Not available,
IDE01992-SFT00198,Installation list: current installations-Battery Charger Control Module,Not available,
IDE01992-SFT00203,Installation list: current installations-Rear Axle Steering,Not available,
IDE01992-SFT00205,Installation list: current installations-Laser Scanner,Not available,
IDE01992-SFT00206,Installation list: current installations-Drive Motor Control Module 2,Not available,
IDE01992-SFT00208,Installation list: current installations-Front Axle Lift System,Not available,
IDE01992-SFT00219,Installation list: current installations-Front Corner Radar 1,Not available,
IDE01992-SFT00220,Installation list: current installations-Front Corner Radar 2,Not available,
IDE01992-SFT00221,Installation list: current installations-Control Module 2 For Sunroof,Not available,
IDE01992-SFT33031,Installation list: current installations-Antenna Control Module,Not available,
IDE01992-SFT33232,Installation list: current installations-Central control for digital matrix light,Not available,
IDE01992-SFT09760,Installation list: current installations-Sun Roof,Available,
IDE01993-IDE14867,Control module reference number-Subgateway as firewall control module,00,
IDE01993-SFT00001,Control module reference number-Engine Control Module 1,76,
IDE01993-SFT00002,Control module reference number-Transmission Control Module,77,
IDE01993-SFT00003,Control module reference number-Brakes 1,13,
IDE01993-SFT00003,Control module reference number-Brakes 1,00,
IDE01993-SFT00006,Control module reference number-Seat Adjustment Passenger Side,4D,
IDE01993-SFT00007,Control module reference number-Display Control Unit,8E,
IDE01993-SFT00008,Control module reference number-Air Conditioning,46,
IDE01993-SFT00009,Control module reference number-Central Electrics,0E,
IDE01993-SFT00012,Control module reference number-Rear Axle Steering 2,00,
IDE01993-SFT00017,Control module reference number-Engine Control Module 2,78,
IDE01993-SFT00019,Control module reference number-Adaptive Cruise Control,57,
IDE01993-SFT00021,Control module reference number-Airbag,00,
IDE01993-SFT00021,Control module reference number-Airbag,15,
IDE01993-SFT00022,Control module reference number-Steering Column Electronics,0C,
IDE01993-SFT00023,Control module reference number-Dash Board,14,
IDE01993-SFT00024,Control module reference number-Auxiliary Parking Heater,6A,
IDE01993-SFT00025,Control module reference number-Gateway,10,
IDE01993-SFT00027,Control module reference number-Active Steering,16,
IDE01993-SFT00032,Control module reference number-High Beam Assistance,30,
IDE01993-SFT00033,Control module reference number-Battery Energy Control Module 2,9C,
IDE01993-SFT00034,Control module reference number-All Wheel Control,0F,
IDE01993-SFT00035,Control module reference number-Brake Boost,3B,
IDE01993-SFT00038,Control module reference number-Electronic Roof Control,2D,
IDE01993-SFT00039,Control module reference number-Display Control Unit Rear,93,
IDE01993-SFT00040,Control module reference number-Climate Control Unit Rear,1A,
IDE01993-SFT00042,Control module reference number-Control Unit Wireless Charging,8F,
IDE01993-SFT00043,Control module reference number-Steering Column Locking,31,
IDE01993-SFT00048,Control module reference number-Special Function 2,2B,
IDE01993-SFT00050,Control module reference number-Lock Electronics,1E,
IDE01993-SFT00054,Control module reference number-Seat Adjustment Driver Side,4C,
IDE01993-SFT00060,Control module reference number-Lane Change Assistant,4E,
IDE01993-SFT00060,Control module reference number-Lane Change Assistant,00,
IDE01993-SFT00061,Control module reference number-Special Function,2C,
IDE01993-SFT00066,Control module reference number-Door Electronics Driver Side,4A,
IDE01993-SFT00068,Control module reference number-Steering Assistance,12,
IDE01993-SFT00070,Control module reference number-Central Module Comfort System,8B,
IDE01993-SFT00072,Control module reference number-Seat Adjustment Rear Driver Side,87,
IDE01993-SFT00074,Control module reference number-Rear light,00,
IDE01993-SFT00077,Control module reference number-Löschkandidat_Datenübertragung Car2X,00,
IDE01993-SFT00080,Control module reference number-Seat Adjustment 3rd Row,95,
IDE01993-SFT00081,Control module reference number-Drive Motor Control Module,03,
IDE01993-SFT00081,Control module reference number-Drive Motor Control Module,7C,
IDE01993-SFT00082,Control module reference number-Door Electronics Passenger Side,4B,
IDE01993-SFT00090,Control module reference number-Longitudinal control,94,
IDE01993-SFT00091,Control module reference number-Seat Adjustment Rear Passenger Side,88,
IDE01993-SFT00095,Control module reference number-Information Control Unit 1,73,
IDE01993-SFT00101,Control module reference number-Tire Pressure Monitoring 1,0B,
IDE01993-SFT00105,Control module reference number-Trailer Function,47,
IDE01993-SFT00107,Control module reference number-Aerodynamics Control Unit,24,
IDE01993-SFT00108,Control module reference number-Camera System Rear View,69,
IDE01993-SFT00109,Control module reference number-Deck Lid Control Unit,23,
IDE01993-SFT00116,Control module reference number-Chassis Control,80,
IDE01993-SFT00118,Control module reference number-Parking Assistance,00,
IDE01993-SFT00127,Control module reference number-Information Control Unit 2,00,
IDE01993-SFT00128,Control module reference number-Battery Regulation Auxiliary Accumulator 1,AE,
IDE01993-SFT00129,Control module reference number-Gear Shift Control Module,53,
IDE01993-SFT00130,Control module reference number-Head Up Display,1B,
IDE01993-SFT00132,Control module reference number-Night Vision,27,
IDE01993-SFT00139,Control module reference number-Adaptive Cruise Control 2,56,
IDE01993-SFT00140,Control module reference number-Battery Energy Control Module,7B,
IDE01993-SFT00165,Control module reference number-Front Sensors Driver Assistance System,00,
IDE01993-SFT00165,Control module reference number-Front Sensors Driver Assistance System,4F,
IDE01993-SFT00166,Control module reference number-Microphone Control Unit,63,
IDE01993-SFT00169,Control module reference number-Actuator For Structure-borne Sound,1C,
IDE01993-SFT00172,Control module reference number-Reductant Control Module,2A,
IDE01993-SFT00183,Control module reference number-Access Startsystem Interface,00,
IDE01993-SFT00186,Control module reference number-Assembly Mounting,2E,
IDE01993-SFT00192,Control module reference number-Actuator For Exterior Noise,64,
IDE01993-SFT00195,Control module reference number-Drive Motor Control Module 3,00,
IDE01993-SFT00196,Control module reference number-DC/DC Converter Control Module,41,
IDE01993-SFT00197,Control module reference number-Thermal management,42,
IDE01993-SFT00198,Control module reference number-Battery Charger Control Module,44,
IDE01993-SFT00203,Control module reference number-Rear Axle Steering,60,
IDE01993-SFT00205,Control module reference number-Laser Scanner,00,
IDE01993-SFT00206,Control module reference number-Drive Motor Control Module 2,00,
IDE01993-SFT00207,Control module reference number-Control Unit Lane Change Assistant 2,00,
IDE01993-SFT00207,Control module reference number-Control Unit Lane Change Assistant 2,8A,
IDE01993-SFT00208,Control module reference number-Front Axle Lift System,00,
IDE01993-SFT00219,Control module reference number-Front Corner Radar 1,00,
IDE01993-SFT00220,Control module reference number-Front Corner Radar 2,00,
IDE01993-SFT00221,Control module reference number-Control Module 2 For Sunroof,A0,
IDE01993-SFT33031,Control module reference number-Antenna Control Module,00,
IDE01993-SFT33232,Control module reference number-Central control for digital matrix light,00,
IDE01993-SFT09760,Control module reference number-Sun Roof,84,
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,0, mA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,-113.00,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,Not available,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,Not available,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,Not available,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,Not available,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02384-IDE14867,Status of event memory-Subgateway as firewall control module,OK,
IDE02384-SFT00001,Status of event memory-Engine Control Module 1,OK,
IDE02384-SFT00002,Status of event memory-Transmission Control Module,OK,
IDE02384-SFT00003,Status of event memory-Brakes 1,OK,
IDE02384-SFT00006,Status of event memory-Seat Adjustment Passenger Side,OK,
IDE02384-SFT00007,Status of event memory-Display Control Unit,OK,
IDE02384-SFT00008,Status of event memory-Air Conditioning,OK,
IDE02384-SFT00009,Status of event memory-Central Electrics,OK,
IDE02384-SFT00012,Status of event memory-Rear Axle Steering 2,OK,
IDE02384-SFT00017,Status of event memory-Engine Control Module 2,OK,
IDE02384-SFT00019,Status of event memory-Adaptive Cruise Control,OK,
IDE02384-SFT00021,Status of event memory-Airbag,OK,
IDE02384-SFT00022,Status of event memory-Steering Column Electronics,OK,
IDE02384-SFT00023,Status of event memory-Dash Board,OK,
IDE02384-SFT00024,Status of event memory-Auxiliary Parking Heater,OK,
IDE02384-SFT00025,Status of event memory-Gateway,OK,
IDE02384-SFT00027,Status of event memory-Active Steering,OK,
IDE02384-SFT00032,Status of event memory-High Beam Assistance,OK,
IDE02384-SFT00033,Status of event memory-Battery Energy Control Module 2,OK,
IDE02384-SFT00034,Status of event memory-All Wheel Control,OK,
IDE02384-SFT00035,Status of event memory-Brake Boost,OK,
IDE02384-SFT00038,Status of event memory-Electronic Roof Control,OK,
IDE02384-SFT00039,Status of event memory-Display Control Unit Rear,OK,
IDE02384-SFT00040,Status of event memory-Climate Control Unit Rear,OK,
IDE02384-SFT00042,Status of event memory-Control Unit Wireless Charging,OK,
IDE02384-SFT00043,Status of event memory-Steering Column Locking,OK,
IDE02384-SFT00048,Status of event memory-Special Function 2,OK,
IDE02384-SFT00050,Status of event memory-Lock Electronics,OK,
IDE02384-SFT00054,Status of event memory-Seat Adjustment Driver Side,OK,
IDE02384-SFT00060,Status of event memory-Lane Change Assistant,OK,
IDE02384-SFT00061,Status of event memory-Special Function,OK,
IDE02384-SFT00066,Status of event memory-Door Electronics Driver Side,OK,
IDE02384-SFT00068,Status of event memory-Steering Assistance,OK,
IDE02384-SFT00070,Status of event memory-Central Module Comfort System,OK,
IDE02384-SFT00072,Status of event memory-Seat Adjustment Rear Driver Side,OK,
IDE02384-SFT00074,Status of event memory-Rear light,OK,
IDE02384-SFT00077,Status of event memory-Löschkandidat_Datenübertragung Car2X,OK,
IDE02384-SFT00080,Status of event memory-Seat Adjustment 3rd Row,OK,
IDE02384-SFT00081,Status of event memory-Drive Motor Control Module,OK,
IDE02384-SFT00082,Status of event memory-Door Electronics Passenger Side,OK,
IDE02384-SFT00090,Status of event memory-Longitudinal control,OK,
IDE02384-SFT00091,Status of event memory-Seat Adjustment Rear Passenger Side,OK,
IDE02384-SFT00095,Status of event memory-Information Control Unit 1,OK,
IDE02384-SFT00101,Status of event memory-Tire Pressure Monitoring 1,OK,
IDE02384-SFT00105,Status of event memory-Trailer Function,OK,
IDE02384-SFT00107,Status of event memory-Aerodynamics Control Unit,OK,
IDE02384-SFT00108,Status of event memory-Camera System Rear View,OK,
IDE02384-SFT00109,Status of event memory-Deck Lid Control Unit,OK,
IDE02384-SFT00116,Status of event memory-Chassis Control,OK,
IDE02384-SFT00118,Status of event memory-Parking Assistance,OK,
IDE02384-SFT00127,Status of event memory-Information Control Unit 2,OK,
IDE02384-SFT00128,Status of event memory-Battery Regulation Auxiliary Accumulator 1,OK,
IDE02384-SFT00129,Status of event memory-Gear Shift Control Module,OK,
IDE02384-SFT00130,Status of event memory-Head Up Display,OK,
IDE02384-SFT00132,Status of event memory-Night Vision,OK,
IDE02384-SFT00139,Status of event memory-Adaptive Cruise Control 2,OK,
IDE02384-SFT00140,Status of event memory-Battery Energy Control Module,OK,
IDE02384-SFT00165,Status of event memory-Front Sensors Driver Assistance System,OK,
IDE02384-SFT00166,Status of event memory-Microphone Control Unit,OK,
IDE02384-SFT00169,Status of event memory-Actuator For Structure-borne Sound,OK,
IDE02384-SFT00172,Status of event memory-Reductant Control Module,OK,
IDE02384-SFT00183,Status of event memory-Access Startsystem Interface,OK,
IDE02384-SFT00186,Status of event memory-Assembly Mounting,OK,
IDE02384-SFT00192,Status of event memory-Actuator For Exterior Noise,OK,
IDE02384-SFT00195,Status of event memory-Drive Motor Control Module 3,OK,
IDE02384-SFT00196,Status of event memory-DC/DC Converter Control Module,OK,
IDE02384-SFT00197,Status of event memory-Thermal management,OK,
IDE02384-SFT00198,Status of event memory-Battery Charger Control Module,OK,
IDE02384-SFT00203,Status of event memory-Rear Axle Steering,OK,
IDE02384-SFT00205,Status of event memory-Laser Scanner,OK,
IDE02384-SFT00206,Status of event memory-Drive Motor Control Module 2,OK,
IDE02384-SFT00207,Status of event memory-Control Unit Lane Change Assistant 2,OK,
IDE02384-SFT00208,Status of event memory-Front Axle Lift System,OK,
IDE02384-SFT00219,Status of event memory-Front Corner Radar 1,OK,
IDE02384-SFT00220,Status of event memory-Front Corner Radar 2,OK,
IDE02384-SFT00221,Status of event memory-Control Module 2 For Sunroof,OK,
IDE02384-SFT33031,Status of event memory-Antenna Control Module,OK,
IDE02384-SFT33232,Status of event memory-Central control for digital matrix light,OK,
IDE02384-SFT09760,Status of event memory-Sun Roof,OK,
IDE02578-IDE05118,Play protection status-Counter for function calls,0,
IDE02578-MAS02040,Play protection status-Play protection,not active,
IDE02744-MAS02311,Steering wheel heater-Steering wheel heating button,not activated,
IDE02744-MAS09775,Steering wheel heater-Steering wheel temp.,Initializing,
IDE03008-MAS02193,Stop process prevented-Outside air temperature,not active,
IDE03008-MAS04055,Stop process prevented-Usable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery charge condition too low,not active,
IDE03008-MAS04059,Stop process prevented-Battery temperature,not active,
IDE03008-MAS04060,Stop process prevented-Other reasons active,not active,
IDE03008-MAS04061,Stop process prevented-Idle speed increase active,not active,
IDE03008-MAS04062,Stop process prevented-Possible service life too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS09832,Stop process prevented-Intermittent operation,not active,
IDE03009-MAS01478,Start process requested-Insuff. voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04055,Start process requested-Usable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery charge condition too low,not active,
IDE03009-MAS04058,Start process requested-Service life expired,not active,
IDE03009-MAS04060,Start process requested-Other reasons active,not active,
IDE03009-MAS06003,Start process requested-Charging contingent,not active,
IDE03009-MAS06004,Start process requested-Special start requirements,not active,
IDE03010-MAS02193,Number of prevented stop processes-Outside air temperature,0,
IDE03010-MAS04055,Number of prevented stop processes-Usable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery charge condition too low,39,
IDE03010-MAS04059,Number of prevented stop processes-Battery temperature,0,
IDE03010-MAS04060,Number of prevented stop processes-Other reasons active,0,
IDE03010-MAS04061,Number of prevented stop processes-Idle speed increase active,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible service life too short,10,
IDE03010-MAS06001,Number of prevented stop processes-Energy management special veto,0,
IDE03010-MAS09832,Number of prevented stop processes-Intermittent operation,0,
IDE03011-MAS01478,Number of requested start processes-Insuff. voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04055,Number of requested start processes-Usable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery charge condition too low,0,
IDE03011-MAS04058,Number of requested start processes-Service life expired,0,
IDE03011-MAS04060,Number of requested start processes-Other reasons active,0,
IDE03011-MAS06003,Number of requested start processes-Charging contingent,0,
IDE03011-MAS06004,Number of requested start processes-Special start requirements,0,
IDE03150-IDE14867,Readiness for bus sleep mode-Subgateway as firewall control module,Sleep mode,
IDE03150-SFT00001,Readiness for bus sleep mode-Engine Control Module 1,active,
IDE03150-SFT00002,Readiness for bus sleep mode-Transmission Control Module,Sleep mode,
IDE03150-SFT00003,Readiness for bus sleep mode-Brakes 1,Sleep mode,
IDE03150-SFT00006,Readiness for bus sleep mode-Seat Adjustment Passenger Side,Sleep mode,
IDE03150-SFT00007,Readiness for bus sleep mode-Display Control Unit,Sleep mode,
IDE03150-SFT00008,Readiness for bus sleep mode-Air Conditioning,Sleep mode,
IDE03150-SFT00009,Readiness for bus sleep mode-Central Electrics,active,
IDE03150-SFT00012,Readiness for bus sleep mode-Rear Axle Steering 2,Sleep mode,
IDE03150-SFT00017,Readiness for bus sleep mode-Engine Control Module 2,Sleep mode,
IDE03150-SFT00019,Readiness for bus sleep mode-Adaptive Cruise Control,Sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,Sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,active,
IDE03150-SFT00022,Readiness for bus sleep mode-Steering Column Electronics,active,
IDE03150-SFT00023,Readiness for bus sleep mode-Dash Board,active,
IDE03150-SFT00024,Readiness for bus sleep mode-Auxiliary Parking Heater,Sleep mode,
IDE03150-SFT00025,Readiness for bus sleep mode-Gateway,active,
IDE03150-SFT00027,Readiness for bus sleep mode-Active Steering,Sleep mode,
IDE03150-SFT00032,Readiness for bus sleep mode-High Beam Assistance,Sleep mode,
IDE03150-SFT00033,Readiness for bus sleep mode-Battery Energy Control Module 2,Sleep mode,
IDE03150-SFT00034,Readiness for bus sleep mode-All Wheel Control,Sleep mode,
IDE03150-SFT00035,Readiness for bus sleep mode-Brake Boost,Sleep mode,
IDE03150-SFT00038,Readiness for bus sleep mode-Electronic Roof Control,Sleep mode,
IDE03150-SFT00039,Readiness for bus sleep mode-Display Control Unit Rear,Sleep mode,
IDE03150-SFT00040,Readiness for bus sleep mode-Climate Control Unit Rear,Sleep mode,
IDE03150-SFT00042,Readiness for bus sleep mode-Control Unit Wireless Charging,Sleep mode,
IDE03150-SFT00043,Readiness for bus sleep mode-Steering Column Locking,Sleep mode,
IDE03150-SFT00048,Readiness for bus sleep mode-Special Function 2,Sleep mode,
IDE03150-SFT00050,Readiness for bus sleep mode-Lock Electronics,Sleep mode,
IDE03150-SFT00054,Readiness for bus sleep mode-Seat Adjustment Driver Side,Sleep mode,
IDE03150-SFT00060,Readiness for bus sleep mode-Lane Change Assistant,Sleep mode,
IDE03150-SFT00061,Readiness for bus sleep mode-Special Function,Sleep mode,
IDE03150-SFT00066,Readiness for bus sleep mode-Door Electronics Driver Side,active,
IDE03150-SFT00068,Readiness for bus sleep mode-Steering Assistance,active,
IDE03150-SFT00070,Readiness for bus sleep mode-Central Module Comfort System,active,
IDE03150-SFT00072,Readiness for bus sleep mode-Seat Adjustment Rear Driver Side,Sleep mode,
IDE03150-SFT00074,Readiness for bus sleep mode-Rear light,Sleep mode,
IDE03150-SFT00077,Readiness for bus sleep mode-Löschkandidat_Datenübertragung Car2X,Sleep mode,
IDE03150-SFT00080,Readiness for bus sleep mode-Seat Adjustment 3rd Row,Sleep mode,
IDE03150-SFT00081,Readiness for bus sleep mode-Drive Motor Control Module,Sleep mode,
IDE03150-SFT00082,Readiness for bus sleep mode-Door Electronics Passenger Side,Sleep mode,
IDE03150-SFT00090,Readiness for bus sleep mode-Longitudinal control,Sleep mode,
IDE03150-SFT00091,Readiness for bus sleep mode-Seat Adjustment Rear Passenger Side,Sleep mode,
IDE03150-SFT00095,Readiness for bus sleep mode-Information Control Unit 1,active,
IDE03150-SFT00101,Readiness for bus sleep mode-Tire Pressure Monitoring 1,Sleep mode,
IDE03150-SFT00105,Readiness for bus sleep mode-Trailer Function,Sleep mode,
IDE03150-SFT00107,Readiness for bus sleep mode-Aerodynamics Control Unit,Sleep mode,
IDE03150-SFT00108,Readiness for bus sleep mode-Camera System Rear View,active,
IDE03150-SFT00109,Readiness for bus sleep mode-Deck Lid Control Unit,Sleep mode,
IDE03150-SFT00116,Readiness for bus sleep mode-Chassis Control,Sleep mode,
IDE03150-SFT00118,Readiness for bus sleep mode-Parking Assistance,Sleep mode,
IDE03150-SFT00127,Readiness for bus sleep mode-Information Control Unit 2,Sleep mode,
IDE03150-SFT00128,Readiness for bus sleep mode-Battery Regulation Auxiliary Accumulator 1,Sleep mode,
IDE03150-SFT00129,Readiness for bus sleep mode-Gear Shift Control Module,active,
IDE03150-SFT00130,Readiness for bus sleep mode-Head Up Display,Sleep mode,
IDE03150-SFT00132,Readiness for bus sleep mode-Night Vision,Sleep mode,
IDE03150-SFT00139,Readiness for bus sleep mode-Adaptive Cruise Control 2,Sleep mode,
IDE03150-SFT00140,Readiness for bus sleep mode-Battery Energy Control Module,Sleep mode,
IDE03150-SFT00165,Readiness for bus sleep mode-Front Sensors Driver Assistance System,Sleep mode,
IDE03150-SFT00166,Readiness for bus sleep mode-Microphone Control Unit,Sleep mode,
IDE03150-SFT00169,Readiness for bus sleep mode-Actuator For Structure-borne Sound,Sleep mode,
IDE03150-SFT00172,Readiness for bus sleep mode-Reductant Control Module,Sleep mode,
IDE03150-SFT00183,Readiness for bus sleep mode-Access Startsystem Interface,Sleep mode,
IDE03150-SFT00186,Readiness for bus sleep mode-Assembly Mounting,Sleep mode,
IDE03150-SFT00192,Readiness for bus sleep mode-Actuator For Exterior Noise,Sleep mode,
IDE03150-SFT00195,Readiness for bus sleep mode-Drive Motor Control Module 3,Sleep mode,
IDE03150-SFT00196,Readiness for bus sleep mode-DC/DC Converter Control Module,Sleep mode,
IDE03150-SFT00197,Readiness for bus sleep mode-Thermal management,Sleep mode,
IDE03150-SFT00198,Readiness for bus sleep mode-Battery Charger Control Module,Sleep mode,
IDE03150-SFT00203,Readiness for bus sleep mode-Rear Axle Steering,Sleep mode,
IDE03150-SFT00205,Readiness for bus sleep mode-Laser Scanner,Sleep mode,
IDE03150-SFT00206,Readiness for bus sleep mode-Drive Motor Control Module 2,Sleep mode,
IDE03150-SFT00207,Readiness for bus sleep mode-Control Unit Lane Change Assistant 2,Sleep mode,
IDE03150-SFT00207,Readiness for bus sleep mode-Control Unit Lane Change Assistant 2,active,
IDE03150-SFT00208,Readiness for bus sleep mode-Front Axle Lift System,Sleep mode,
IDE03150-SFT00219,Readiness for bus sleep mode-Front Corner Radar 1,Sleep mode,
IDE03150-SFT00220,Readiness for bus sleep mode-Front Corner Radar 2,Sleep mode,
IDE03150-SFT00221,Readiness for bus sleep mode-Control Module 2 For Sunroof,Sleep mode,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna Control Module,Sleep mode,
IDE03150-SFT33232,Readiness for bus sleep mode-Central control for digital matrix light,Sleep mode,
IDE03150-SFT09760,Readiness for bus sleep mode-Sun Roof,Sleep mode,
IDE03205,Manufacturer code,SME,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03477-MAS00106,GPS time-Year,Not available,
IDE03477-MAS00107,GPS time-Month,Not available,
IDE03477-MAS00108,GPS time-Day,Not available,
IDE03477-MAS00109,GPS time-Hours,Not available,
IDE03477-MAS00110,GPS time-Minutes,Not available,
IDE03477-MAS00111,GPS time-Seconds,Not available,
IDE03477-MAS01632,GPS time-Status,invalid,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery malfunction,no error,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,no error,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,no error,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,no error,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,no error,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,no error,
IDE04186,Battery terminal recognition,connected,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,A1 3C 3F 3E DB 3B C7 26 46 C8 A4 60 86 76 E2 B2 7C 49 E0 E1 7A 1D 94 D7 C5 3B C1 67 2D A4 14 CC CE 63 6F 13 57 0D FE 90 D7 72 D3 56 2B 8C 68 43 6E 73 E2 EE 50 F7 11 EE 51 46 49 F7 16 0E CB 5B 98 D2 66 93 17 79 C4 43 92 9A A9 A5 57 8A EC F1 CD FC 78 C7 97 B0 84 0E A8 B0 B0 FF 3C 28 8C 12 45 E1 7D 0E 3B 73 4E DD DF 49 90 9E 8E 8C 19 6A A7 F7 AC D9 2C 26 5D B5 E4 B2 68 17 B3 C3 76 73 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-IDE14867,Bus identification-Subgateway as firewall control module,Unknown,
IDE04343-SFT00001,Bus identification-Engine Control Module 1,Data bus Flexray A,
IDE04343-SFT00002,Bus identification-Transmission Control Module,Data bus Flexray A,
IDE04343-SFT00003,Bus identification-Brakes 1,Unknown,
IDE04343-SFT00003,Bus identification-Brakes 1,Data bus Flexray A,
IDE04343-SFT00006,Bus identification-Seat Adjustment Passenger Side,Comfort data bus,
IDE04343-SFT00007,Bus identification-Display Control Unit,Data bus Sensor/Hybrid,
IDE04343-SFT00008,Bus identification-Air Conditioning,Data bus Sensor/Hybrid,
IDE04343-SFT00009,Bus identification-Central Electrics,Comfort data bus,
IDE04343-SFT00012,Bus identification-Rear Axle Steering 2,Unknown,
IDE04343-SFT00017,Bus identification-Engine Control Module 2,Data bus Flexray A,
IDE04343-SFT00019,Bus identification-Adaptive Cruise Control,Data bus Flexray A,
IDE04343-SFT00021,Bus identification-Airbag,Unknown,
IDE04343-SFT00021,Bus identification-Airbag,Data bus Flexray A,
IDE04343-SFT00022,Bus identification-Steering Column Electronics,Data bus Flexray A,
IDE04343-SFT00023,Bus identification-Dash Board,Databus Infotainment,
IDE04343-SFT00024,Bus identification-Auxiliary Parking Heater,Databus extended,
IDE04343-SFT00025,Bus identification-Gateway,Busmaster,
IDE04343-SFT00027,Bus identification-Active Steering,Data bus Flexray A,
IDE04343-SFT00032,Bus identification-High Beam Assistance,Databus extended,
IDE04343-SFT00033,Bus identification-Battery Energy Control Module 2,Data bus Sensor/Hybrid,
IDE04343-SFT00034,Bus identification-All Wheel Control,Data bus Flexray A,
IDE04343-SFT00035,Bus identification-Brake Boost,Data bus Flexray A,
IDE04343-SFT00038,Bus identification-Electronic Roof Control,Comfort data bus,
IDE04343-SFT00039,Bus identification-Display Control Unit Rear,Data bus Sensor/Hybrid,
IDE04343-SFT00040,Bus identification-Climate Control Unit Rear,Data bus Sensor/Hybrid,
IDE04343-SFT00042,Bus identification-Control Unit Wireless Charging,Data bus Sensor/Hybrid,
IDE04343-SFT00043,Bus identification-Steering Column Locking,Comfort data bus,
IDE04343-SFT00048,Bus identification-Special Function 2,Comfort data bus,
IDE04343-SFT00050,Bus identification-Lock Electronics,Data bus Flexray A,
IDE04343-SFT00054,Bus identification-Seat Adjustment Driver Side,Comfort data bus,
IDE04343-SFT00060,Bus identification-Lane Change Assistant,Databus extended,
IDE04343-SFT00060,Bus identification-Lane Change Assistant,Unknown,
IDE04343-SFT00061,Bus identification-Special Function,Comfort data bus,
IDE04343-SFT00066,Bus identification-Door Electronics Driver Side,Comfort data bus,
IDE04343-SFT00068,Bus identification-Steering Assistance,Data bus Flexray A,
IDE04343-SFT00070,Bus identification-Central Module Comfort System,Comfort data bus,
IDE04343-SFT00072,Bus identification-Seat Adjustment Rear Driver Side,Comfort data bus,
IDE04343-SFT00074,Bus identification-Rear light,Unknown,
IDE04343-SFT00077,Bus identification-Löschkandidat_Datenübertragung Car2X,Unknown,
IDE04343-SFT00080,Bus identification-Seat Adjustment 3rd Row,Comfort data bus,
IDE04343-SFT00081,Bus identification-Drive Motor Control Module,Data bus Flexray A,
IDE04343-SFT00081,Bus identification-Drive Motor Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00082,Bus identification-Door Electronics Passenger Side,Comfort data bus,
IDE04343-SFT00090,Bus identification-Longitudinal control,Data bus Flexray A,
IDE04343-SFT00091,Bus identification-Seat Adjustment Rear Passenger Side,Comfort data bus,
IDE04343-SFT00095,Bus identification-Information Control Unit 1,Databus Infotainment,
IDE04343-SFT00101,Bus identification-Tire Pressure Monitoring 1,Databus extended,
IDE04343-SFT00105,Bus identification-Trailer Function,Comfort data bus,
IDE04343-SFT00107,Bus identification-Aerodynamics Control Unit,Comfort data bus,
IDE04343-SFT00108,Bus identification-Camera System Rear View,Databus extended,
IDE04343-SFT00109,Bus identification-Deck Lid Control Unit,Comfort data bus,
IDE04343-SFT00116,Bus identification-Chassis Control,Data bus Flexray A,
IDE04343-SFT00118,Bus identification-Parking Assistance,Unknown,
IDE04343-SFT00127,Bus identification-Information Control Unit 2,Unknown,
IDE04343-SFT00128,Bus identification-Battery Regulation Auxiliary Accumulator 1,Data bus Sensor/Hybrid,
IDE04343-SFT00129,Bus identification-Gear Shift Control Module,Databus Infotainment,
IDE04343-SFT00130,Bus identification-Head Up Display,Databus Infotainment,
IDE04343-SFT00132,Bus identification-Night Vision,Databus extended,
IDE04343-SFT00139,Bus identification-Adaptive Cruise Control 2,Data bus Flexray A,
IDE04343-SFT00140,Bus identification-Battery Energy Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00165,Bus identification-Front Sensors Driver Assistance System,Unknown,
IDE04343-SFT00165,Bus identification-Front Sensors Driver Assistance System,Data bus Flexray A,
IDE04343-SFT00166,Bus identification-Microphone Control Unit,Databus Infotainment,
IDE04343-SFT00169,Bus identification-Actuator For Structure-borne Sound,Databus extended,
IDE04343-SFT00172,Bus identification-Reductant Control Module,Databus extended,
IDE04343-SFT00183,Bus identification-Access Startsystem Interface,Unknown,
IDE04343-SFT00186,Bus identification-Assembly Mounting,Data bus Sensor/Hybrid,
IDE04343-SFT00192,Bus identification-Actuator For Exterior Noise,Databus extended,
IDE04343-SFT00195,Bus identification-Drive Motor Control Module 3,Unknown,
IDE04343-SFT00196,Bus identification-DC/DC Converter Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00197,Bus identification-Thermal management,Data bus Sensor/Hybrid,
IDE04343-SFT00198,Bus identification-Battery Charger Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00203,Bus identification-Rear Axle Steering,Data bus Flexray A,
IDE04343-SFT00205,Bus identification-Laser Scanner,Unknown,
IDE04343-SFT00206,Bus identification-Drive Motor Control Module 2,Unknown,
IDE04343-SFT00207,Bus identification-Control Unit Lane Change Assistant 2,Unknown,
IDE04343-SFT00207,Bus identification-Control Unit Lane Change Assistant 2,Databus extended,
IDE04343-SFT00208,Bus identification-Front Axle Lift System,Unknown,
IDE04343-SFT00219,Bus identification-Front Corner Radar 1,Unknown,
IDE04343-SFT00220,Bus identification-Front Corner Radar 2,Unknown,
IDE04343-SFT00221,Bus identification-Control Module 2 For Sunroof,Unknown,
IDE04343-SFT33031,Bus identification-Antenna Control Module,Unknown,
IDE04343-SFT33232,Bus identification-Central control for digital matrix light,Unknown,
IDE04343-SFT09760,Bus identification-Sun Roof,Comfort data bus,
IDE04605-IDE01712,Navigation: Corrected position-GPS Position,Not available,
IDE04605-MAS01779,Navigation: Corrected position-Length,2D 38 31 37 30 39 37 39 34 00 00 00 00 00,
IDE04605-MAS01780,Navigation: Corrected position-Width,32 36 32 34 35 34 38 34 00 00 00 00 00 00,
IDE04605-MAS04183,Navigation: Corrected position-Position error,0, m
IDE04750-MAS03876,SIM cards-active SIM card,internal,
IDE04750-MAS03877,SIM cards-SIM ID,148630001515359,
IDE04750-MAS03878,SIM cards-SIM IMSI,310170205372938,
IDE04750-MAS04226,SIM cards-Telephone number,,
IDE04750-MAS08401,SIM cards-SIM intern,Available,
IDE04750-MAS08402,SIM cards-SIM extern,Not available,
IDE04790,Call for help button,Not available,
IDE04806-MAS10929,Driving profile selection button-Button for load profile selection,not activated,
IDE04806-MAS10937,Driving profile selection button-Driving profile selection button 1,not activated,
IDE04806-MAS10938,Driving profile selection button-Driving profile selection button 2,not activated,
IDE04806-MAS10939,Driving profile selection button-Drive profile selection rotary switch,no function,
IDE05430,Telephone serial number,148630001515359,
IDE05583-IDE09851,Pause recommendation-Function active,Yes,
IDE05583-MAS03095,Pause recommendation-Function status,not installed,
IDE05583-MAS04622,Pause recommendation-Break recommend. message,No display,
IDE05583-MAS13273,Pause recommendation-deactivation status,not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,D9 56 E9 EC A2,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,no entry,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,Engine Control Module (ECM),
IDE06007-MAS00106,Driving profile history data 1-Year,2000, yr
IDE06007-MAS00107,Driving profile history data 1-Month,0, m
IDE06007-MAS00108,Driving profile history data 1-Day,0, d
IDE06007-MAS00109,Driving profile history data 1-Hours,0, H
IDE06007-MAS00110,Driving profile history data 1-Minutes,0, min
IDE06007-MAS00111,Driving profile history data 1-Seconds,0, s
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initializing,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,no entry,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,Start-stop,
IDE06008-MAS00106,Driving profile history data 2-Year,2000, yr
IDE06008-MAS00107,Driving profile history data 2-Month,0, m
IDE06008-MAS00108,Driving profile history data 2-Day,0, d
IDE06008-MAS00109,Driving profile history data 2-Hours,0, H
IDE06008-MAS00110,Driving profile history data 2-Minutes,0, min
IDE06008-MAS00111,Driving profile history data 2-Seconds,0, s
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initializing,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,no entry,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,no entry,
IDE06009-MAS00106,Driving profile history data 3-Year,2000, yr
IDE06009-MAS00107,Driving profile history data 3-Month,0, m
IDE06009-MAS00108,Driving profile history data 3-Day,0, d
IDE06009-MAS00109,Driving profile history data 3-Hours,0, H
IDE06009-MAS00110,Driving profile history data 3-Minutes,0, min
IDE06009-MAS00111,Driving profile history data 3-Seconds,0, s
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initializing,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,no entry,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,no entry,
IDE06010-MAS00106,Driving profile history data 4-Year,2000, yr
IDE06010-MAS00107,Driving profile history data 4-Month,0, m
IDE06010-MAS00108,Driving profile history data 4-Day,0, d
IDE06010-MAS00109,Driving profile history data 4-Hours,0, H
IDE06010-MAS00110,Driving profile history data 4-Minutes,0, min
IDE06010-MAS00111,Driving profile history data 4-Seconds,0, s
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initializing,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,Profile 2,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,Profile 1,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-ENG118695,Driving profile selection statistics-Profile_1,1930542892, min
IDE06165-ENG126249,Driving profile selection statistics-profile_10,0, min
IDE06165-ENG126250,Driving profile selection statistics-profile_11,0, min
IDE06165-ENG127921,Driving profile selection statistics-profile_12,0, min
IDE06165-ENG04216,Driving profile selection statistics-profile_13,0, min
IDE06165-ENG04217,Driving profile selection statistics-profile_14,0, min
IDE06165-ENG04218,Driving profile selection statistics-profile_15,0, min
IDE06165-ENG118696,Driving profile selection statistics-Profile_2,15534, min
IDE06165-ENG118697,Driving profile selection statistics-Profile_3,17864, min
IDE06165-ENG118698,Driving profile selection statistics-Profile_4,0, min
IDE06165-ENG118699,Driving profile selection statistics-Profile_5,0, min
IDE06165-ENG118700,Driving profile selection statistics-Profile_6,0, min
IDE06165-ENG118701,Driving profile selection statistics-Profile_7,3124, min
IDE06165-ENG118702,Driving profile selection statistics-Profile_8,0, min
IDE06165-ENG126248,Driving profile selection statistics-profile_9,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2000, yr
IDE06230-MAS00107,Break recommend.: last message-Month,1, m
IDE06230-MAS00108,Break recommend.: last message-Day,1, d
IDE06230-MAS00109,Break recommend.: last message-Hours,0, H
IDE06230-MAS00110,Break recommend.: last message-Minutes,0, min
IDE06230-MAS00111,Break recommend.: last message-Seconds,0, s
IDE06230-MAS03095,Break recommend.: last message-Function status,Initializing,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,no warning,
IDE06264-IDE09057,Deep discharge protection-HV battery charge state,ERROR,
IDE06264-MAS04721,Deep discharge protection-Minimum charge level,ERROR,
IDE06264-MAS13070,Deep discharge protection-High-voltage energy management shut-down stage,not active,
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,7,
IDE06307-MAS00108,Stop prevention history data-Day,22,
IDE06307-MAS00109,Stop prevention history data-Hours,2,
IDE06307-MAS00110,Stop prevention history data-Minutes,43,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Battery charge condition too low,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,1,
IDE06308-MAS00108,Start request history data-Day,1,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE06522,Temperature of phone unit,40, °C
IDE06577,Supplier Identification,Conti Temic microelectronic GmbH,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06805-MAS09523,Status of voltage freedom-Transformer for electrical drive,Initializing,
IDE06805-MAS09524,Status of voltage freedom-Hybrid Battery Management,Initializing,
IDE06805-MAS09525,Status of voltage freedom-Ctrl. mod. for contactless charging,Initializing,
IDE06805-MAS09526,Status of voltage freedom-High-voltage battery charger,Initializing,
IDE06805-MAS11874,Status of voltage freedom-Overall status,Initializing,
IDE06805-SFT00195,Status of voltage freedom-Drive Motor Control Module 3,Initializing,
IDE06805-SFT00206,Status of voltage freedom-Drive Motor Control Module 2,Initializing,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,not activated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,3,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,0,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,0,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07427-IDE04447,Status: driving profile selection for power steering-Function status,engaged,
IDE07427-IDE06260,Status: driving profile selection for power steering-ID number,0,
IDE07427-MAS01156,Status: driving profile selection for power steering-Communication status,OK,
IDE07427-MAS01447,Status: driving profile selection for power steering-Act.val.,2,
IDE07428-IDE04447,Status: driving profile selection for damping adjustment-Function status,not engaged,
IDE07428-IDE06260,Status: driving profile selection for damping adjustment-ID number,0,
IDE07428-MAS01156,Status: driving profile selection for damping adjustment-Communication status,OK,
IDE07428-MAS01447,Status: driving profile selection for damping adjustment-Act.val.,0,
IDE07429-IDE04447,Status: driving profile selection for A/C-Function status,engaged,
IDE07429-IDE06260,Status: driving profile selection for A/C-ID number,251,
IDE07429-MAS01156,Status: driving profile selection for A/C-Communication status,OK,
IDE07429-MAS01447,Status: driving profile selection for A/C-Act.val.,0,
IDE07430-IDE04447,Status: driving profile selection for adaptive cruise control-Function status,not engaged,
IDE07430-IDE06260,Status: driving profile selection for adaptive cruise control-ID number,249,
IDE07430-MAS01156,Status: driving profile selection for adaptive cruise control-Communication status,OK,
IDE07430-MAS01447,Status: driving profile selection for adaptive cruise control-Act.val.,0,
IDE07431-IDE04447,Status: driv prof.select.for corn.light & headlamp range ctrl-Function status,not engaged,
IDE07431-IDE06260,Status: driv prof.select.for corn.light & headlamp range ctrl-ID number,0,
IDE07431-MAS01156,Status: driv prof.select.for corn.light & headlamp range ctrl-Communication status,OK,
IDE07431-MAS01447,Status: driv prof.select.for corn.light & headlamp range ctrl-Act.val.,0,
IDE07432-IDE04447,Status: driving profile selection for structure-borne noise-Function status,not engaged,
IDE07432-IDE06260,Status: driving profile selection for structure-borne noise-ID number,0,
IDE07432-MAS01156,Status: driving profile selection for structure-borne noise-Communication status,OK,
IDE07432-MAS01447,Status: driving profile selection for structure-borne noise-Act.val.,0,
IDE07433-IDE04447,Status: driving profile selection for ambient lighting-Function status,engaged,
IDE07433-IDE06260,Status: driving profile selection for ambient lighting-ID number,35,
IDE07433-MAS01156,Status: driving profile selection for ambient lighting-Communication status,OK,
IDE07433-MAS01447,Status: driving profile selection for ambient lighting-Act.val.,0,
IDE07434-IDE04447,Status: driving profile selection for belt tensioner-Function status,engaged,
IDE07434-IDE06260,Status: driving profile selection for belt tensioner-ID number,0,
IDE07434-MAS01156,Status: driving profile selection for belt tensioner-Communication status,OK,
IDE07434-MAS01447,Status: driving profile selection for belt tensioner-Act.val.,2,
IDE07436-IDE04447,Status: driving profile selection for free-running hub-Function status,not engaged,
IDE07436-IDE06260,Status: driving profile selection for free-running hub-ID number,0,
IDE07436-MAS01156,Status: driving profile selection for free-running hub-Communication status,OK,
IDE07436-MAS01447,Status: driving profile selection for free-running hub-Act.val.,0,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stoppage time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,5, A
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.50, V
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognized,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognized,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,1.10, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,1.15, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,ERROR,
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,728, A
IDE07847-MAS00976,Start stop requests without reason-Counter,38417,
IDE07873-MAS06193,FPA enabled profiles-Profile 1,Comfort,
IDE07873-MAS06194,FPA enabled profiles-Profile 2,AUTO,
IDE07873-MAS06195,FPA enabled profiles-Profile 3,Dynamic,
IDE07873-MAS06196,FPA enabled profiles-Profile 4,Not Used,
IDE07873-MAS06197,FPA enabled profiles-Profile 5,Not Used,
IDE07873-MAS06198,FPA enabled profiles-Profile 6,Not Used,
IDE07873-MAS06199,FPA enabled profiles-Profile 7,INDIVIDUAL,
IDE07873-MAS06200,FPA enabled profiles-Profile 8,Not Used,
IDE07873-MAS08875,FPA enabled profiles-Profile 9,Not Used,
IDE07873-MAS08876,FPA enabled profiles-Profile 10,Not Used,
IDE07873-MAS08877,FPA enabled profiles-Profile 11,Not Used,
IDE07873-MAS08878,FPA enabled profiles-Profile 12,Not Used,
IDE07873-MAS08879,FPA enabled profiles-Profile 13,Not Used,
IDE07873-MAS08880,FPA enabled profiles-Profile 14,Not Used,
IDE07873-MAS08881,FPA enabled profiles-Profile 15,Not Used,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status GSG,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ELV,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,257,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08251-MAS01483,Configuration immobilizer-Softwareversion,00 00 00,
IDE08251-MAS02832,Configuration immobilizer-Malfunction status,00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,05,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,0E,
IDE08251-MAS06850,Configuration immobilizer-Supported power class 2,00,
IDE08251-MAS06851,Configuration immobilizer-Supported power class 3,00,
IDE08251-MAS06852,Configuration immobilizer-Supported power class 4,00,
IDE08251-MAS06853,Configuration immobilizer-Supported power class 5,00,
IDE08343,Immobilizer Challenge,85 A6 7F 2C,
IDE08355-IDE04447,Status: driving profile selection for external noise actuator-Function status,not engaged,
IDE08355-IDE06260,Status: driving profile selection for external noise actuator-ID number,0,
IDE08355-MAS01156,Status: driving profile selection for external noise actuator-Communication status,OK,
IDE08355-MAS01447,Status: driving profile selection for external noise actuator-Act.val.,0,
IDE08490,Activation of diagnosis via ethernet,not active,
IDE08530-MAS00106,Connection status online basic services-Year,2019, yr
IDE08530-MAS00107,Connection status online basic services-Month,11, m
IDE08530-MAS00108,Connection status online basic services-Day,10, d
IDE08530-MAS00109,Connection status online basic services-Hours,21, H
IDE08530-MAS00110,Connection status online basic services-Minutes,15, min
IDE08530-MAS00111,Connection status online basic services-Seconds,3, s
IDE08530-MAS07130,Connection status online basic services-Number of ID steps,14,
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,30,
IDE08531-MAS00106,Connection status online license services-Year,Not available,
IDE08531-MAS00107,Connection status online license services-Month,Not available,
IDE08531-MAS00108,Connection status online license services-Day,Not available,
IDE08531-MAS00109,Connection status online license services-Hours,Not available,
IDE08531-MAS00110,Connection status online license services-Minutes,Not available,
IDE08531-MAS07132,Connection status online license services-Code status,1792255,
IDE08531-MAS07133,Connection status online license services-No. of license serv.,14,
IDE08531-MAS07134,Connection status online license services-ID services,8704,
IDE08531-MAS07135,Connection status online license services-Activation status,Not available,
IDE08531-MAS07136,Connection status online license services-Exp. year,Not available,
IDE08531-MAS07137,Connection status online license services-Exp. month,Not available,
IDE08531-MAS07138,Connection status online license services-Exp. day,1, d
IDE08600-IDE04447,Status drive profile selec. for rear-wheel drive-Function status,not engaged,
IDE08600-IDE06260,Status drive profile selec. for rear-wheel drive-ID number,5,
IDE08600-MAS01156,Status drive profile selec. for rear-wheel drive-Communication status,OK,
IDE08600-MAS01447,Status drive profile selec. for rear-wheel drive-Act.val.,0,
IDE08601-IDE04447,Drive profile selection for actuator for exterior noise-Function status,engaged,
IDE08601-IDE06260,Drive profile selection for actuator for exterior noise-ID number,0,
IDE08601-MAS01156,Drive profile selection for actuator for exterior noise-Communication status,OK,
IDE08601-MAS01447,Drive profile selection for actuator for exterior noise-Act.val.,0,
IDE08602-IDE04447,Status drive profile selec. for active steering-Function status,not engaged,
IDE08602-IDE06260,Status drive profile selec. for active steering-ID number,2,
IDE08602-MAS01156,Status drive profile selec. for active steering-Communication status,OK,
IDE08602-MAS01447,Status drive profile selec. for active steering-Act.val.,0,
IDE08605-IDE04447,Status drive profile for level control system-Function status,not engaged,
IDE08605-IDE06260,Status drive profile for level control system-ID number,12,
IDE08605-MAS01156,Status drive profile for level control system-Communication status,OK,
IDE08605-MAS01447,Status drive profile for level control system-Act.val.,0,
IDE08611-IDE04447,Status drive profile for stabilizer-Function status,engaged,
IDE08611-IDE06260,Status drive profile for stabilizer-ID number,0,
IDE08611-MAS01156,Status drive profile for stabilizer-Communication status,OK,
IDE08611-MAS01447,Status drive profile for stabilizer-Act.val.,0,
IDE08614-IDE04447,Status drive profile for engine operating conditions-Function status,not engaged,
IDE08614-IDE06260,Status drive profile for engine operating conditions-ID number,0,
IDE08614-MAS01156,Status drive profile for engine operating conditions-Communication status,OK,
IDE08614-MAS01447,Status drive profile for engine operating conditions-Act.val.,0,
IDE08687-IDE04447,Status: driving profile select. for brake ctrl. sys.-Function status,not engaged,
IDE08687-IDE06260,Status: driving profile select. for brake ctrl. sys.-ID number,0,
IDE08687-MAS01156,Status: driving profile select. for brake ctrl. sys.-Communication status,OK,
IDE08687-MAS01447,Status: driving profile select. for brake ctrl. sys.-Act.val.,2,
IDE08796-IDE04447,Status: driving profile selec. for hill descent control-Function status,not engaged,
IDE08796-IDE06260,Status: driving profile selec. for hill descent control-ID number,0,
IDE08796-MAS01156,Status: driving profile selec. for hill descent control-Communication status,OK,
IDE08796-MAS01447,Status: driving profile selec. for hill descent control-Act.val.,0,
IDE08798-IDE04447,Status: drive profile for Matrix-Beam-Function status,engaged,
IDE08798-IDE06260,Status: drive profile for Matrix-Beam-ID number,0,
IDE08798-MAS01156,Status: drive profile for Matrix-Beam-Communication status,OK,
IDE08798-MAS01447,Status: drive profile for Matrix-Beam-Act.val.,0,
IDE08799-IDE04447,Status: driv. profile selec. for rear spoiler-Function status,not engaged,
IDE08799-IDE06260,Status: driv. profile selec. for rear spoiler-ID number,0,
IDE08799-MAS01156,Status: driv. profile selec. for rear spoiler-Communication status,OK,
IDE08799-MAS01447,Status: driv. profile selec. for rear spoiler-Act.val.,0,
IDE08804-IDE04447,Status: driv. profile selec. for ctr. differential-Function status,not engaged,
IDE08804-IDE06260,Status: driv. profile selec. for ctr. differential-ID number,0,
IDE08804-MAS01156,Status: driv. profile selec. for ctr. differential-Communication status,OK,
IDE08804-MAS01447,Status: driv. profile selec. for ctr. differential-Act.val.,0,
IDE08956-MAS08051,H-V power distro-Power quota: thermal management,6400, W
IDE08956-MAS08052,H-V power distro-Power quota: 12 V electrical system,1500, W
IDE08956-MAS08054,H-V power distro-Power quota: comfort loads,3000, W
IDE08956-MAS13094,H-V power distro-Power allocation by engine electronics,ERROR,
IDE08956-MAS13095,H-V power distro-Power allocation by high-voltage battery charger,ERROR,
IDE08956-MAS13096,H-V power distro-Power allocation by hybrid battery management,ERROR,
IDE08956-MAS13097,H-V power distro-Power drawn by voltage transformer for electric drive,ERROR,
IDE08956-MAS13098,H-V power distro-Power drawn by thermal management,ERROR,
IDE09074-MAS01078,Vehicle properties-Vehicle type,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,36700,
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),18.00,
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,7.00, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,23.00,
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,39.00, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,1000, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,800, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,6.00,
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,10.00, l/100km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,456, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,25, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,456, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,456, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,ERROR,
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,ERROR,
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,ERROR,
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,285, km
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,285, km
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,not installed,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,8.00, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,7.00, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,6.00, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,7.00, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,6.00, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,6.00, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,7.00, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,23.00,
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,23.00,
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,23.00,
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,23.00,
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,23.00,
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,23.00,
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,23.00,
IDE09080-MAS12005,Energy storage unit-Tank capacity with conventional fuel for range calculation,32.00, l
IDE09080-MAS12006,Energy storage unit-Energy content of HV battery for range calculation,0,
IDE09080-MAS12007,Energy storage unit-Tank capacity with CNG for range calculation,0.00, l
IDE09080-MAS12008,Energy storage unit-Tank capacity with LPG for range calculation,0.00, l
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,Electrical OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,0, mA
IDE09293-MAS04344,Status of antenna 2 for phone-Reception level antenna 2,-113.00,
IDE09467,MAC address,00 36 F8 3C C0 EB,
IDE09468-MAS01390,IPv4 address-Block 1,0,
IDE09468-MAS01391,IPv4 address-Block 2,0,
IDE09468-MAS01392,IPv4 address-Block 3,0,
IDE09468-MAS01393,IPv4 address-Block 4,0,
IDE09469-MAS01390,IPv6 address-Block 1,00 00,
IDE09469-MAS01391,IPv6 address-Block 2,00 00,
IDE09469-MAS01392,IPv6 address-Block 3,00 00,
IDE09469-MAS01393,IPv6 address-Block 4,00 00,
IDE09469-MAS01394,IPv6 address-Block 5,00 00,
IDE09469-MAS01395,IPv6 address-Block 6,00 00,
IDE09469-MAS01396,IPv6 address-Block 7,00 00,
IDE09469-MAS01397,IPv6 address-Block 8,00 00,
IDE09891-SFT00081,Voltage converter for electric drive: status of electric drive-Drive Motor Control Module,Initializing,
IDE09891-SFT00195,Voltage converter for electric drive: status of electric drive-Drive Motor Control Module 3,Initializing,
IDE09891-SFT00206,Voltage converter for electric drive: status of electric drive-Drive Motor Control Module 2,Initializing,
IDE09892-MAS02832,Hybrid battery management: status of electric drive-Malfunction status,Initializing,
IDE09892-MAS03001,Hybrid battery management: status of electric drive-Mode,Initializing,
IDE09893-MAS17071,High voltage battery charger: status of electric drive-High-voltage charging management: current mode,Initializing,
IDE09893-MAS17072,High voltage battery charger: status of electric drive-High-voltage charging management: error status,Initializing,
IDE09894-MAS13356,Thermal management: status of electric drive-Error status additional air heating,Initializing,
IDE09894-MAS13357,Thermal management: status of electric drive-Mode additional air heating,Initializing,
IDE09894-MAS13358,Thermal management: status of electric drive-Error status A/C compressor,Initializing,
IDE09894-MAS13359,Thermal management: status of electric drive-Mode A/C compressor,Initializing,
IDE09895-MAS13099,Engine electronics: status of electric drive-Error status electric drive,Initializing,
IDE09895-MAS13100,Engine electronics: status of electric drive-Electric drive mode,Initializing,
IDE09895-MAS13101,Engine electronics: status of electric drive-Error status of electric machine,Initializing,
IDE09895-MAS13102,Engine electronics: status of electric drive-Electric machine mode,255,
IDE09896-MAS02832,Ctrl. module for contactless charging: status of electric drive-Malfunction status,Initializing,
IDE09896-MAS03001,Ctrl. module for contactless charging: status of electric drive-Mode,Initializing,
IDE09897-MAS02246,Volt. converter for elec. drive: high-volt. activ. restrict.-Timeout,not active,
IDE09897-MAS09518,Volt. converter for elec. drive: high-volt. activ. restrict.-Safety line,not active,
IDE09897-MAS09519,Volt. converter for elec. drive: high-volt. activ. restrict.-Message error,not active,
IDE09897-MAS09542,Volt. converter for elec. drive: high-volt. activ. restrict.-Error status init. error,not active,
IDE09897-MAS09544,Volt. converter for elec. drive: high-volt. activ. restrict.-No component function,not active,
IDE09897-MAS09546,Volt. converter for elec. drive: high-volt. activ. restrict.-Voltage disconnect. init. error,not active,
IDE09897-MAS12345,Volt. converter for elec. drive: high-volt. activ. restrict.-Active discharge fault,not active,
IDE09898-MAS02246,Hybrid batt. management: H-V activ. restriction-Timeout,not active,
IDE09898-MAS03123,Hybrid batt. management: H-V activ. restriction-Reduced performance,not active,
IDE09898-MAS09513,Hybrid batt. management: H-V activ. restriction-Insulation test stage 1 failed,not active,
IDE09898-MAS09514,Hybrid batt. management: H-V activ. restriction-Insulation test stage 2 failed,not active,
IDE09898-MAS09518,Hybrid batt. management: H-V activ. restriction-Safety line,not active,
IDE09898-MAS09519,Hybrid batt. management: H-V activ. restriction-Message error,not active,
IDE09898-MAS09520,Hybrid batt. management: H-V activ. restriction-Safety connector,not active,
IDE09898-MAS09541,Hybrid batt. management: H-V activ. restriction-Act. mode init. error,not active,
IDE09898-MAS09542,Hybrid batt. management: H-V activ. restriction-Error status init. error,not active,
IDE09898-MAS09543,Hybrid batt. management: H-V activ. restriction-Operating mode error,not active,
IDE09898-MAS09544,Hybrid batt. management: H-V activ. restriction-No component function,not active,
IDE09898-MAS09545,Hybrid batt. management: H-V activ. restriction-Sequence error,not active,
IDE09898-MAS09546,Hybrid batt. management: H-V activ. restriction-Voltage disconnect. init. error,not active,
IDE09898-MAS12351,Hybrid batt. management: H-V activ. restriction-HV voltage measurement error,not active,
IDE09898-MAS13068,Hybrid batt. management: H-V activ. restriction-HV voltage measurement initialization error,not active,
IDE09899-MAS02246,Eng. electronics: H-V activ. restriction-Timeout,not active,
IDE09899-MAS09519,Eng. electronics: H-V activ. restriction-Message error,not active,
IDE09899-MAS09541,Eng. electronics: H-V activ. restriction-Act. mode init. error,not active,
IDE09899-MAS09545,Eng. electronics: H-V activ. restriction-Sequence error,not active,
IDE09899-MAS09547,Eng. electronics: H-V activ. restriction-Error status drive motor: init. error,not active,
IDE09899-MAS09548,Eng. electronics: H-V activ. restriction-Error status drive: init. error,not active,
IDE09899-MAS09549,Eng. electronics: H-V activ. restriction-Drive condition: init. error,not active,
IDE09899-MAS09550,Eng. electronics: H-V activ. restriction-Safety line power electronics,not active,
IDE09899-MAS09551,Eng. electronics: H-V activ. restriction-Part. oper.,not active,
IDE09899-MAS09552,Eng. electronics: H-V activ. restriction-HV shut-down due to operating strategy,not active,
IDE09899-MAS09553,Eng. electronics: H-V activ. restriction-no component function drive motor,not active,
IDE09899-MAS09554,Eng. electronics: H-V activ. restriction-no component function drive,not active,
IDE09900-MAS02246,H-V batt. charger H-V activ. restriction-Timeout,not active,
IDE09900-MAS09519,H-V batt. charger H-V activ. restriction-Message error,not active,
IDE09900-MAS09546,H-V batt. charger H-V activ. restriction-Voltage disconnect. init. error,not active,
IDE09901-MAS02246,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Timeout,not active,
IDE09901-MAS09518,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Safety line,not active,
IDE09901-MAS09519,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Message error,not active,
IDE09901-MAS09541,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Act. mode init. error,not active,
IDE09901-MAS09542,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Error status init. error,not active,
IDE09901-MAS09543,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Operating mode error,not active,
IDE09901-MAS09544,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-No component function,not active,
IDE09901-MAS09546,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Voltage disconnect. init. error,not active,
IDE09901-MAS12351,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-HV voltage measurement error,not active,
IDE09901-MAS13068,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-HV voltage measurement initialization error,not active,
IDE09902-MAS02246,A/C compressor: H-V activ. restriction-Timeout,not active,
IDE09902-MAS09518,A/C compressor: H-V activ. restriction-Safety line,not active,
IDE09902-MAS09519,A/C compressor: H-V activ. restriction-Message error,not active,
IDE09902-MAS09541,A/C compressor: H-V activ. restriction-Act. mode init. error,not active,
IDE09902-MAS09542,A/C compressor: H-V activ. restriction-Error status init. error,not active,
IDE09902-MAS09544,A/C compressor: H-V activ. restriction-No component function,not active,
IDE09902-MAS09545,A/C compressor: H-V activ. restriction-Sequence error,not active,
IDE09902-MAS12351,A/C compressor: H-V activ. restriction-HV voltage measurement error,not active,
IDE09903-MAS02246,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Timeout,not active,
IDE09903-MAS09518,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Safety line,not active,
IDE09903-MAS09519,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Message error,not active,
IDE09903-MAS09541,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Act. mode init. error,not active,
IDE09903-MAS09542,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Error status init. error,not active,
IDE09903-MAS09544,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-No component function,not active,
IDE09903-MAS09545,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Sequence error,not active,
IDE09903-MAS12351,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-HV voltage measurement error,not active,
IDE09904-MAS00799,Airbag: H-V activ. restriction-Airbag control module,not active,
IDE09904-MAS02246,Airbag: H-V activ. restriction-Timeout,not active,
IDE09904-MAS09519,Airbag: H-V activ. restriction-Message error,not active,
IDE09904-MAS09521,Airbag: H-V activ. restriction-Light accident detected,not active,
IDE09904-MAS09522,Airbag: H-V activ. restriction-Severe accident detected,not active,
IDE09905-MAS00799,H-V activ. restriction-Airbag control module,not active,
IDE09905-MAS08044,H-V activ. restriction-Thermal management,not active,
IDE09905-MAS09516,H-V activ. restriction-Engine Electronics,not active,
IDE09905-MAS09523,H-V activ. restriction-Transformer for electrical drive,not active,
IDE09905-MAS09524,H-V activ. restriction-Hybrid Battery Management,not active,
IDE09905-MAS09525,H-V activ. restriction-Ctrl. mod. for contactless charging,not active,
IDE09905-MAS09526,H-V activ. restriction-High-voltage battery charger,not active,
IDE09905-MAS09555,H-V activ. restriction-HV activation prohibited due to accident,not active,
IDE09905-MAS09557,H-V activ. restriction-HV activation prohibited due to de-activation,not active,
IDE09905-MAS09558,H-V activ. restriction-HV activation prohibited due to blocking,not active,
IDE09905-MAS12352,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 1,not active,
IDE09905-MAS12353,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 2,not active,
IDE10084-MAS03950,Hybrid drive operating mode-Combustion engine: status,Engine running,
IDE10084-MAS09828,Hybrid drive operating mode-Status of drive readiness hybrid,not active,
IDE10084-MAS09829,Hybrid drive operating mode-Engine start in start-stop mode active,not active,
IDE10084-MAS09830,Hybrid drive operating mode-Engine stop in start-stop mode active,not active,
IDE10084-MAS09831,Hybrid drive operating mode-Engine running or driver readiness at engine stop,active,
IDE10341-SFT09757,Install. list of subsystems: act. install.-Alternator,Available,
IDE10341-SFT09777,Install. list of subsystems: act. install.-Multi Function Steering Wheel Control Module,Available,
IDE10341-SFT09783,Install. list of subsystems: act. install.-Battery Monitoring Control Module,Available,
IDE10341-SFT09833,Install. list of subsystems: act. install.-Power Converter DC AC,Not available,
IDE10341-SFT09960,Install. list of subsystems: act. install.-Starter Generator Control Module Sub,Not available,
IDE10341-SFT10046,Install. list of subsystems: act. install.-Control module for steering wheel touch recognition,Not available,
IDE10342-IDE02068,Standard - ambient data 1: status-Time stamp,Current,
IDE10342-MAS00711,Standard - ambient data 1: status-Odometer reading,Current,
IDE10365-MAS10445,Message mirroring: bus allocation-Data bus CAN 1,Comfort data bus,
IDE10365-MAS10446,Message mirroring: bus allocation-Data bus CAN 2,not installed,
IDE10365-MAS10447,Message mirroring: bus allocation-Data bus CAN 3,Data bus Sensor/Hybrid,
IDE10365-MAS10448,Message mirroring: bus allocation-Data bus CAN 4,Databus Infotainment,
IDE10365-MAS10449,Message mirroring: bus allocation-Data bus CAN 5,Databus extended,
IDE10365-MAS10450,Message mirroring: bus allocation-Data bus CAN 6,Data bus diagnostics,
IDE10365-MAS11107,Message mirroring: bus allocation-Data bus CAN 7,not installed,
IDE10505,History data 45,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE10506,History data 46,000*2000-01-01-00:00*0*000*+0000*00.00*000.00*00.00*00.00*00.00*00.00*0000.00*00000**,
IDE10510-MAS00106,History data 50-Year,2018,
IDE10510-MAS00107,History data 50-Month,3,
IDE10510-MAS00108,History data 50-Day,2,
IDE10510-MAS00109,History data 50-Hours,1, H
IDE10510-MAS00110,History data 50-Minutes,0, min
IDE10510-MAS01632,History data 50-Status,activated,
IDE10510-ENG05061,History data 50-Activation_Bus_Knock_Out,activated,
IDE10510-ENG05062,History data 50-Activation_Cluster_Sleep,activated,
IDE10510-ENG05063,History data 50-Activation_Cluster_Start,activated,
IDE10510-ENG05064,History data 50-Activation_FUNC_Monitoring,activated,
IDE10510-ENG05058,History data 50-Activation_Keeping_Awake,activated,
IDE10510-ENG05059,History data 50-Activation_Logical_Wakeup,activated,
IDE10510-ENG05060,History data 50-Activation_Physical_Wakeup,activated,
IDE10510-ENG05065,History data 50-Activation_Subbus_Monitoring,activated,
IDE10510-ENG06839,History data 50-Aktivitaetsstatus_Busaktivitaet,activated,
IDE10510-ENG118680,History data 50-Cycle_Counter,10,
IDE10510-ENG06840,History data 50-Status_Activation_Car_Wake_Up,activated,
IDE10510-ENG118681,History data 50-Time_Since_Clamp_15_Off,0.00, H
IDE10510-ENG05057,History data 50-Total_Cycle_Counter,2606,
IDE10511-MAS03174,History data 51-Comfort data bus,1.10, H
IDE10511-MAS03175,History data 51-Databus extended,0.00, H
IDE10511-MAS03177,History data 51-Databus Infotainment,1.30, H
IDE10511-MAS03179,History data 51-Local data bus 2,0.10, H
IDE10511-MAS03180,History data 51-Local data bus,0.00, H
IDE10511-MAS03181,History data 51-Flexray databus,0.00, H
IDE10511-MAS05686,History data 51-Data bus diagnostics,0.00, H
IDE10511-MAS05972,History data 51-Local data bus 3,0.00, H
IDE10511-MAS07380,History data 51-Data bus Sensor/Hybrid,0.00, H
IDE10511-MAS10036,History data 51-Data bus diagnosis 2,0.00, H
IDE10511-MAS12183,History data 51-Convenience data bus 2,0.00, H
IDE10511-MAS14086,History data 51-Instrument panel data bus,0.00, H
IDE10511-ENG118679,History data 51-Total_Bus_Active,2.20, H
IDE10512-MAS03174,History data 52-Comfort data bus,32173,
IDE10512-MAS03175,History data 52-Databus extended,1,
IDE10512-MAS03177,History data 52-Databus Infotainment,13,
IDE10512-MAS03179,History data 52-Local data bus 2,0,
IDE10512-MAS03180,History data 52-Local data bus,0,
IDE10512-MAS03181,History data 52-Flexray databus,20,
IDE10512-MAS05686,History data 52-Data bus diagnostics,0,
IDE10512-MAS05972,History data 52-Local data bus 3,0,
IDE10512-MAS07380,History data 52-Data bus Sensor/Hybrid,7,
IDE10512-MAS10036,History data 52-Data bus diagnosis 2,0,
IDE10512-MAS12183,History data 52-Convenience data bus 2,0,
IDE10512-MAS14086,History data 52-Instrument panel data bus,0,
IDE10513-MAS03174,History data 53-Comfort data bus,5484,
IDE10513-MAS03175,History data 53-Databus extended,0,
IDE10513-MAS03177,History data 53-Databus Infotainment,201,
IDE10513-MAS03179,History data 53-Local data bus 2,0,
IDE10513-MAS03180,History data 53-Local data bus,0,
IDE10513-MAS03181,History data 53-Flexray databus,19,
IDE10513-MAS05686,History data 53-Data bus diagnostics,0,
IDE10513-MAS05972,History data 53-Local data bus 3,0,
IDE10513-MAS07380,History data 53-Data bus Sensor/Hybrid,747,
IDE10513-MAS10036,History data 53-Data bus diagnosis 2,0,
IDE10513-MAS12183,History data 53-Convenience data bus 2,0,
IDE10513-MAS14086,History data 53-Instrument panel data bus,0,
IDE10514-MAS03174,History data 54-Comfort data bus,26594,
IDE10514-MAS03175,History data 54-Databus extended,0,
IDE10514-MAS03177,History data 54-Databus Infotainment,1465,
IDE10514-MAS03179,History data 54-Local data bus 2,0,
IDE10514-MAS03180,History data 54-Local data bus,0,
IDE10514-MAS03181,History data 54-Flexray databus,2524,
IDE10514-MAS05686,History data 54-Data bus diagnostics,0,
IDE10514-MAS05972,History data 54-Local data bus 3,0,
IDE10514-MAS07380,History data 54-Data bus Sensor/Hybrid,9,
IDE10514-MAS10036,History data 54-Data bus diagnosis 2,0,
IDE10514-MAS12183,History data 54-Convenience data bus 2,0,
IDE10514-MAS14086,History data 54-Instrument panel data bus,0,
IDE10515-MAS03174,History data 55-Comfort data bus,0,
IDE10515-MAS03175,History data 55-Databus extended,0,
IDE10515-MAS03177,History data 55-Databus Infotainment,5736,
IDE10515-MAS03179,History data 55-Local data bus 2,0,
IDE10515-MAS03180,History data 55-Local data bus,0,
IDE10515-MAS03181,History data 55-Flexray databus,12,
IDE10515-MAS05686,History data 55-Data bus diagnostics,0,
IDE10515-MAS05972,History data 55-Local data bus 3,0,
IDE10515-MAS07380,History data 55-Data bus Sensor/Hybrid,0,
IDE10515-MAS10036,History data 55-Data bus diagnosis 2,0,
IDE10515-MAS12183,History data 55-Convenience data bus 2,0,
IDE10515-MAS14086,History data 55-Instrument panel data bus,0,
IDE10516-ENG05046,History data 56-Cluster_1_Start_Error_Counter,41438,
IDE10516-ENG30616,History data 56-Cluster_10_Counter,0,
IDE10516-ENG30617,History data 56-Cluster_10_Sleep_Error_Counter,0,
IDE10516-ENG30618,History data 56-Cluster_10_Start_Error_Counter,0,
IDE10516-ENG05047,History data 56-Cluster_2_Sleep_Error_Counter,0,
IDE10516-ENG05048,History data 56-Cluster_3_Counter,22716,
IDE10516-ENG05050,History data 56-Cluster_3_Sleep_Error_Counter,0,
IDE10516-ENG05049,History data 56-Cluster_3_Start_Error_Counter,24701,
IDE10516-ENG05051,History data 56-Cluster_4_Counter,29721,
IDE10516-ENG05053,History data 56-Cluster_4_Sleep_Error_Counter,3374,
IDE10516-ENG05052,History data 56-Cluster_4_Start_Error_Counter,34007,
IDE10516-ENG05054,History data 56-Cluster_5_Counter,46103,
IDE10516-ENG05056,History data 56-Cluster_5_Sleep_Error_Counter,10219,
IDE10516-ENG05055,History data 56-Cluster_5_Start_Error_Counter,11183,
IDE10516-ENG30619,History data 56-Cluster_6_Counter,27855,
IDE10516-ENG30620,History data 56-Cluster_6_Sleep_Error_Counter,19965,
IDE10516-ENG30621,History data 56-Cluster_6_Start_Error_Counter,9596,
IDE10516-ENG30622,History data 56-Cluster_7_Counter,22722,
IDE10516-ENG30623,History data 56-Cluster_7_Sleep_Error_Counter,19965,
IDE10516-ENG30624,History data 56-Cluster_7_Start_Error_Counter,9596,
IDE10516-ENG30625,History data 56-Cluster_8_Counter,26390,
IDE10516-ENG30626,History data 56-Cluster_8_Sleep_Error_Counter,19965,
IDE10516-ENG30627,History data 56-Cluster_8_Start_Error_Counter,9596,
IDE10516-ENG30628,History data 56-Cluster_9_Counter,26282,
IDE10516-ENG30629,History data 56-Cluster_9_Sleep_Error_Counter,0,
IDE10516-ENG30630,History data 56-Cluster_9_Start_Error_Counter,0,
IDE10516-ENG05045,History data 56-Cluster_Sleep_1_Error_Counter,25,
IDE10516-ENG05043,History data 56-Cluster_Start_1_Counter,4041,
IDE10516-ENG05044,History data 56-Cluster_Start_1_Error_Counter,54081,
IDE10516-ENG06838,History data 56-Cluster_Start_2_Counter,37811,
IDE10517-MAS00106,History data 57-Year,2019, yr
IDE10517-MAS00107,History data 57-Month,11, m
IDE10517-MAS00108,History data 57-Day,10, d
IDE10517-MAS00109,History data 57-Hours,19, H
IDE10517-MAS00110,History data 57-Minutes,50, min
IDE10517-ENG20570,History data 57-Bus_1,Unknown (0),
IDE10517-ENG20572,History data 57-Bus_2,Unknown (0),
IDE10517-ENG20574,History data 57-Bus_3,Unknown (0),
IDE10517-ENG20576,History data 57-Bus_4,Unknown (0),
IDE10517-ENG20578,History data 57-Bus_5,Unknown (0),
IDE10517-ENG20571,History data 57-Bus_Active_Time_1,0.00, H
IDE10517-ENG20573,History data 57-Bus_Active_Time_2,0.00, H
IDE10517-ENG20575,History data 57-Bus_Active_Time_3,0.00, H
IDE10517-ENG20577,History data 57-Bus_Active_Time_4,0.00, H
IDE10517-ENG20579,History data 57-Bus_Active_Time_5,0.00, H
IDE10517-ENG118680,History data 57-Cycle_Counter,9,
IDE10517-ENG118681,History data 57-Time_Since_Clamp_15_Off,0.00, H
IDE10518-ENG28832,History data 58-Awake_Time_ECU_1,0.00, H
IDE10518-ENG28835,History data 58-Awake_Time_ECU_2,0.00, H
IDE10518-ENG28838,History data 58-Awake_Time_ECU_3,0.00, H
IDE10518-ENG28841,History data 58-Awake_Time_ECU_4,0.00, H
IDE10518-ENG28844,History data 58-Awake_Time_ECU_5,0.00, H
IDE10518-ENG28833,History data 58-Bus_ECU_1,0,
IDE10518-ENG28836,History data 58-Bus_ECU_2,0,
IDE10518-ENG28839,History data 58-Bus_ECU_3,0,
IDE10518-ENG28842,History data 58-Bus_ECU_4,0,
IDE10518-ENG28845,History data 58-Bus_ECU_5,0,
IDE10518-ENG28834,History data 58-Cluster_ECU_1,00 00 00,
IDE10518-ENG28837,History data 58-Cluster_ECU_2,00 00 00,
IDE10518-ENG28840,History data 58-Cluster_ECU_3,00 00 00,
IDE10518-ENG28843,History data 58-Cluster_ECU_4,00 00 00,
IDE10518-ENG28846,History data 58-Cluster_ECU_5,00 00 00,
IDE10518-ENG118680,History data 58-Cycle_Counter,9,
IDE10518-ENG106038,History data 58-ECU_1,0,
IDE10518-ENG106039,History data 58-ECU_2,0,
IDE10518-ENG28620,History data 58-ECU_3,0,
IDE10518-ENG106040,History data 58-ECU_4,0,
IDE10518-ENG106041,History data 58-ECU_5,0,
IDE10518-ENG28618,History data 58-Repeat_Counter_ECU_1,0,
IDE10518-ENG28619,History data 58-Repeat_Counter_ECU_2,0,
IDE10518-ENG28621,History data 58-Repeat_Counter_ECU_3,0,
IDE10518-ENG28622,History data 58-Repeat_Counter_ECU_4,0.00,
IDE10518-ENG28623,History data 58-Repeat_Counter_ECU_5,0,
IDE10519-ENG28833,History data 59-Bus_ECU_1,15,
IDE10519-ENG28836,History data 59-Bus_ECU_2,15,
IDE10519-ENG28839,History data 59-Bus_ECU_3,15,
IDE10519-ENG28842,History data 59-Bus_ECU_4,0,
IDE10519-ENG28845,History data 59-Bus_ECU_5,0,
IDE10519-ENG28834,History data 59-Cluster_ECU_1,00 00 00,
IDE10519-ENG28837,History data 59-Cluster_ECU_2,00 00 00,
IDE10519-ENG28840,History data 59-Cluster_ECU_3,00 00 00,
IDE10519-ENG28843,History data 59-Cluster_ECU_4,00 00 00,
IDE10519-ENG28846,History data 59-Cluster_ECU_5,00 00 00,
IDE10519-ENG118680,History data 59-Cycle_Counter,9,
IDE10519-ENG106038,History data 59-ECU_1,139,
IDE10519-ENG106039,History data 59-ECU_2,74,
IDE10519-ENG28620,History data 59-ECU_3,132,
IDE10519-ENG106040,History data 59-ECU_4,0,
IDE10519-ENG106041,History data 59-ECU_5,0,
IDE10519-ENG28847,History data 59-Logical_Wakeup_ECU_1,2,
IDE10519-ENG28848,History data 59-Logical_Wakeup_ECU_2,1,
IDE10519-ENG28849,History data 59-Logical_Wakeup_ECU_3,1,
IDE10519-ENG28850,History data 59-Logical_Wakeup_ECU_4,0,
IDE10519-ENG28851,History data 59-Logical_Wakeup_ECU_5,0,
IDE10520-ENG28833,History data 60-Bus_ECU_1,15,
IDE10520-ENG28836,History data 60-Bus_ECU_2,0,
IDE10520-ENG28839,History data 60-Bus_ECU_3,0,
IDE10520-ENG28842,History data 60-Bus_ECU_4,0,
IDE10520-ENG28845,History data 60-Bus_ECU_5,0,
IDE10520-ENG28834,History data 60-Cluster_ECU_1,00 00 2B,
IDE10520-ENG28837,History data 60-Cluster_ECU_2,00 00 00,
IDE10520-ENG28840,History data 60-Cluster_ECU_3,00 00 00,
IDE10520-ENG28843,History data 60-Cluster_ECU_4,00 00 00,
IDE10520-ENG28846,History data 60-Cluster_ECU_5,00 00 00,
IDE10520-ENG118680,History data 60-Cycle_Counter,9,
IDE10520-ENG106038,History data 60-ECU_1,139,
IDE10520-ENG106039,History data 60-ECU_2,0,
IDE10520-ENG28620,History data 60-ECU_3,0,
IDE10520-ENG106040,History data 60-ECU_4,0,
IDE10520-ENG106041,History data 60-ECU_5,0,
IDE10520-ENG28852,History data 60-Physical_Wakeup_ECU_1,1,
IDE10520-ENG28853,History data 60-Physical_Wakeup_ECU_2,0,
IDE10520-ENG28854,History data 60-Physical_Wakeup_ECU_3,0,
IDE10520-ENG28855,History data 60-Physical_Wakeup_ECU_4,0,
IDE10520-ENG28856,History data 60-Physical_Wakeup_ECU_5,0,
IDE10521-ENG28833,History data 61-Bus_ECU_1,18,
IDE10521-ENG28836,History data 61-Bus_ECU_2,0,
IDE10521-ENG28839,History data 61-Bus_ECU_3,0,
IDE10521-ENG28842,History data 61-Bus_ECU_4,0,
IDE10521-ENG28845,History data 61-Bus_ECU_5,0,
IDE10521-ENG28857,History data 61-Bus_Knock_Out_ECU_1,1,
IDE10521-ENG30432,History data 61-Bus_Knock_Out_ECU_2,0,
IDE10521-ENG28858,History data 61-Bus_Knock_Out_ECU_3,0,
IDE10521-ENG28859,History data 61-Bus_Knock_Out_ECU_4,0,
IDE10521-ENG28860,History data 61-Bus_Knock_Out_ECU_5,0,
IDE10521-ENG118680,History data 61-Cycle_Counter,9,
IDE10521-ENG106038,History data 61-ECU_1,20,
IDE10521-ENG106039,History data 61-ECU_2,0,
IDE10521-ENG28620,History data 61-ECU_3,0,
IDE10521-ENG106040,History data 61-ECU_4,0,
IDE10521-ENG106041,History data 61-ECU_5,0,
IDE10522-ENG28833,History data 62-Bus_ECU_1,15,
IDE10522-ENG28836,History data 62-Bus_ECU_2,18,
IDE10522-ENG28839,History data 62-Bus_ECU_3,15,
IDE10522-ENG28842,History data 62-Bus_ECU_4,15,
IDE10522-ENG28845,History data 62-Bus_ECU_5,15,
IDE10522-ENG28861,History data 62-Car_Wake_Up_Counter_ECU_1,2,
IDE10522-ENG28863,History data 62-Car_Wake_Up_Counter_ECU_2,1,
IDE10522-ENG28865,History data 62-Car_Wake_Up_Counter_ECU_3,1,
IDE10522-ENG28867,History data 62-Car_Wake_Up_Counter_ECU_4,1,
IDE10522-ENG28869,History data 62-Car_Wake_Up_Counter_ECU_5,1,
IDE10522-ENG28862,History data 62-Car_Wake_Up_Time_ECU_1,0.00, H
IDE10522-ENG28864,History data 62-Car_Wake_Up_Time_ECU_2,0.00, H
IDE10522-ENG28866,History data 62-Car_Wake_Up_Time_ECU_3,0.00, H
IDE10522-ENG28868,History data 62-Car_Wake_Up_Time_ECU_4,0.00, H
IDE10522-ENG28870,History data 62-Car_Wake_Up_Time_ECU_5,0.00, H
IDE10522-ENG118680,History data 62-Cycle_Counter,9,
IDE10522-ENG106038,History data 62-ECU_1,14,
IDE10522-ENG106039,History data 62-ECU_2,20,
IDE10522-ENG28620,History data 62-ECU_3,74,
IDE10522-ENG106040,History data 62-ECU_4,76,
IDE10522-ENG106041,History data 62-ECU_5,139,
IDE10523-ENG28833,History data 63-Bus_ECU_1,23,
IDE10523-ENG28836,History data 63-Bus_ECU_2,15,
IDE10523-ENG28839,History data 63-Bus_ECU_3,15,
IDE10523-ENG28842,History data 63-Bus_ECU_4,15,
IDE10523-ENG28845,History data 63-Bus_ECU_5,23,
IDE10523-ENG28871,History data 63-Cluster_Sleep_ECU_1,255,
IDE10523-ENG28872,History data 63-Cluster_Sleep_ECU_2,4,
IDE10523-ENG28873,History data 63-Cluster_Sleep_ECU_3,4,
IDE10523-ENG28874,History data 63-Cluster_Sleep_ECU_4,3,
IDE10523-ENG28875,History data 63-Cluster_Sleep_ECU_5,2,
IDE10523-ENG118680,History data 63-Cycle_Counter,9,
IDE10523-ENG106038,History data 63-ECU_1,21,
IDE10523-ENG106039,History data 63-ECU_2,14,
IDE10523-ENG28620,History data 63-ECU_3,139,
IDE10523-ENG106040,History data 63-ECU_4,74,
IDE10523-ENG106041,History data 63-ECU_5,12,
IDE10524-ENG28833,History data 64-Bus_ECU_1,15,
IDE10524-ENG28836,History data 64-Bus_ECU_2,15,
IDE10524-ENG28839,History data 64-Bus_ECU_3,3955,
IDE10524-ENG28842,History data 64-Bus_ECU_4,0,
IDE10524-ENG28845,History data 64-Bus_ECU_5,8,
IDE10524-ENG28876,History data 64-Cluster_1_Start,0,
IDE10524-ENG28877,History data 64-Cluster_2_Start,0,
IDE10524-ENG28878,History data 64-Cluster_3_Start,0,
IDE10524-ENG28879,History data 64-Cluster_4_Start,0,
IDE10524-ENG28880,History data 64-Cluster_5_Start,0,
IDE10524-ENG28881,History data 64-Cluster_Start_ECU_1,5,
IDE10524-ENG28882,History data 64-Cluster_Start_ECU_2,3,
IDE10524-ENG28883,History data 64-Cluster_Start_ECU_3,3,
IDE10524-ENG28884,History data 64-Cluster_Start_ECU_4,530,
IDE10524-ENG28885,History data 64-Cluster_Start_ECU_5,0,
IDE10524-ENG118680,History data 64-Cycle_Counter,9,
IDE10524-ENG106038,History data 64-ECU_1,132,
IDE10524-ENG106039,History data 64-ECU_2,75,
IDE10524-ENG28620,History data 64-ECU_3,76,
IDE10524-ENG106040,History data 64-ECU_4,0,
IDE10524-ENG106041,History data 64-ECU_5,0,
IDE10525-ENG28887,History data 65-Awake_Time_FUNC_1,0.00, H
IDE10525-ENG28890,History data 65-Awake_Time_FUNC_2,0.10, H
IDE10525-ENG28893,History data 65-Awake_Time_FUNC_3,0.10, H
IDE10525-ENG28896,History data 65-Awake_Time_FUNC_4,0.00, H
IDE10525-ENG28899,History data 65-Awake_Time_FUNC_5,0.00, H
IDE10525-ENG118680,History data 65-Cycle_Counter,9,
IDE10525-ENG28886,History data 65-FUNC_1,2,
IDE10525-ENG28889,History data 65-FUNC_2,17,
IDE10525-ENG28892,History data 65-FUNC_3,18,
IDE10525-ENG28895,History data 65-FUNC_4,14,
IDE10525-ENG28898,History data 65-FUNC_5,11,
IDE10525-ENG28888,History data 65-Physical_Wakeup_FUNC_1,255,
IDE10525-ENG28891,History data 65-Physical_Wakeup_FUNC_2,255,
IDE10525-ENG28894,History data 65-Physical_Wakeup_FUNC_3,255,
IDE10525-ENG28897,History data 65-Physical_Wakeup_FUNC_4,112,
IDE10525-ENG28900,History data 65-Physical_Wakeup_FUNC_5,78,
IDE10526-MAS00106,History data 66-Year,2000,
IDE10526-MAS00107,History data 66-Month,1,
IDE10526-MAS00108,History data 66-Day,1,
IDE10526-MAS00109,History data 66-Hours,0, H
IDE10526-MAS00110,History data 66-Minutes,0, min
IDE10526-ENG28832,History data 66-Awake_Time_ECU_1,0.00, H
IDE10526-ENG28835,History data 66-Awake_Time_ECU_2,0.00, H
IDE10526-ENG28838,History data 66-Awake_Time_ECU_3,0.00, H
IDE10526-ENG28841,History data 66-Awake_Time_ECU_4,0.00, H
IDE10526-ENG28844,History data 66-Awake_Time_ECU_5,0.00, H
IDE10526-ENG28833,History data 66-Bus_ECU_1,0,
IDE10526-ENG28836,History data 66-Bus_ECU_2,0,
IDE10526-ENG28839,History data 66-Bus_ECU_3,0,
IDE10526-ENG28842,History data 66-Bus_ECU_4,0,
IDE10526-ENG28845,History data 66-Bus_ECU_5,0,
IDE10526-ENG28834,History data 66-Cluster_ECU_1,00 00 00,
IDE10526-ENG28837,History data 66-Cluster_ECU_2,00 00 00,
IDE10526-ENG28840,History data 66-Cluster_ECU_3,00 00 00,
IDE10526-ENG28843,History data 66-Cluster_ECU_4,00 00 00,
IDE10526-ENG28846,History data 66-Cluster_ECU_5,00 00 00,
IDE10526-ENG118680,History data 66-Cycle_Counter,0,
IDE10526-ENG106038,History data 66-ECU_1,0,
IDE10526-ENG106039,History data 66-ECU_2,0,
IDE10526-ENG28620,History data 66-ECU_3,0,
IDE10526-ENG106040,History data 66-ECU_4,0,
IDE10526-ENG106041,History data 66-ECU_5,0,
IDE10526-ENG28618,History data 66-Repeat_Counter_ECU_1,0,
IDE10526-ENG28619,History data 66-Repeat_Counter_ECU_2,0,
IDE10526-ENG28621,History data 66-Repeat_Counter_ECU_3,0,
IDE10526-ENG28622,History data 66-Repeat_Counter_ECU_4,0,
IDE10526-ENG28623,History data 66-Repeat_Counter_ECU_5,0,
IDE10526-ENG118681,History data 66-Time_Since_Clamp_15_Off,0.00, H
IDE10527-MAS00106,History data 67-Year,2000,
IDE10527-MAS00107,History data 67-Month,1,
IDE10527-MAS00108,History data 67-Day,1,
IDE10527-MAS00109,History data 67-Hours,0, H
IDE10527-MAS00110,History data 67-Minutes,0, min
IDE10527-ENG28833,History data 67-Bus_ECU_1,0,
IDE10527-ENG28836,History data 67-Bus_ECU_2,0,
IDE10527-ENG28839,History data 67-Bus_ECU_3,0,
IDE10527-ENG28842,History data 67-Bus_ECU_4,0,
IDE10527-ENG28845,History data 67-Bus_ECU_5,0,
IDE10527-ENG28834,History data 67-Cluster_ECU_1,00 00 00,
IDE10527-ENG28837,History data 67-Cluster_ECU_2,00 00 00,
IDE10527-ENG28840,History data 67-Cluster_ECU_3,00 00 00,
IDE10527-ENG28843,History data 67-Cluster_ECU_4,00 00 00,
IDE10527-ENG28846,History data 67-Cluster_ECU_5,00 00 00,
IDE10527-ENG118680,History data 67-Cycle_Counter,0,
IDE10527-ENG106038,History data 67-ECU_1,0,
IDE10527-ENG106039,History data 67-ECU_2,0,
IDE10527-ENG28620,History data 67-ECU_3,0,
IDE10527-ENG106040,History data 67-ECU_4,0,
IDE10527-ENG106041,History data 67-ECU_5,0,
IDE10527-ENG28847,History data 67-Logical_Wakeup_ECU_1,0,
IDE10527-ENG28848,History data 67-Logical_Wakeup_ECU_2,0,
IDE10527-ENG28849,History data 67-Logical_Wakeup_ECU_3,0,
IDE10527-ENG28850,History data 67-Logical_Wakeup_ECU_4,0,
IDE10527-ENG28851,History data 67-Logical_Wakeup_ECU_5,0,
IDE10527-ENG118681,History data 67-Time_Since_Clamp_15_Off,0.00, H
IDE10528-MAS00106,History data 68-Year,2018,
IDE10528-MAS00107,History data 68-Month,9,
IDE10528-MAS00108,History data 68-Day,1,
IDE10528-MAS00109,History data 68-Hours,7, H
IDE10528-MAS00110,History data 68-Minutes,19, min
IDE10528-ENG28833,History data 68-Bus_ECU_1,15,
IDE10528-ENG28836,History data 68-Bus_ECU_2,16,
IDE10528-ENG28839,History data 68-Bus_ECU_3,0,
IDE10528-ENG28842,History data 68-Bus_ECU_4,0,
IDE10528-ENG28845,History data 68-Bus_ECU_5,0,
IDE10528-ENG28834,History data 68-Cluster_ECU_1,00 00 00,
IDE10528-ENG28837,History data 68-Cluster_ECU_2,00 00 00,
IDE10528-ENG28840,History data 68-Cluster_ECU_3,00 00 00,
IDE10528-ENG28843,History data 68-Cluster_ECU_4,00 00 00,
IDE10528-ENG28846,History data 68-Cluster_ECU_5,00 00 00,
IDE10528-ENG118680,History data 68-Cycle_Counter,42,
IDE10528-ENG106038,History data 68-ECU_1,139,
IDE10528-ENG106039,History data 68-ECU_2,255,
IDE10528-ENG28620,History data 68-ECU_3,0,
IDE10528-ENG106040,History data 68-ECU_4,0,
IDE10528-ENG106041,History data 68-ECU_5,0,
IDE10528-ENG28852,History data 68-Physical_Wakeup_ECU_1,255,
IDE10528-ENG28853,History data 68-Physical_Wakeup_ECU_2,20,
IDE10528-ENG28854,History data 68-Physical_Wakeup_ECU_3,0,
IDE10528-ENG28855,History data 68-Physical_Wakeup_ECU_4,0,
IDE10528-ENG28856,History data 68-Physical_Wakeup_ECU_5,0,
IDE10528-ENG118681,History data 68-Time_Since_Clamp_15_Off,1.30, H
IDE10529-MAS00106,History data 69-Year,2018,
IDE10529-MAS00107,History data 69-Month,9,
IDE10529-MAS00108,History data 69-Day,18,
IDE10529-MAS00109,History data 69-Hours,21, H
IDE10529-MAS00110,History data 69-Minutes,9, min
IDE10529-ENG28833,History data 69-Bus_ECU_1,18,
IDE10529-ENG28836,History data 69-Bus_ECU_2,0,
IDE10529-ENG28839,History data 69-Bus_ECU_3,0,
IDE10529-ENG28842,History data 69-Bus_ECU_4,0,
IDE10529-ENG28845,History data 69-Bus_ECU_5,0,
IDE10529-ENG28857,History data 69-Bus_Knock_Out_ECU_1,38,
IDE10529-ENG30432,History data 69-Bus_Knock_Out_ECU_2,0,
IDE10529-ENG28858,History data 69-Bus_Knock_Out_ECU_3,0,
IDE10529-ENG28859,History data 69-Bus_Knock_Out_ECU_4,0,
IDE10529-ENG28860,History data 69-Bus_Knock_Out_ECU_5,0,
IDE10529-ENG118680,History data 69-Cycle_Counter,54,
IDE10529-ENG106038,History data 69-ECU_1,20,
IDE10529-ENG106039,History data 69-ECU_2,0,
IDE10529-ENG28620,History data 69-ECU_3,0,
IDE10529-ENG106040,History data 69-ECU_4,0,
IDE10529-ENG106041,History data 69-ECU_5,0,
IDE10529-ENG118681,History data 69-Time_Since_Clamp_15_Off,0.00, H
IDE10530-MAS00106,History data 70-Year,2018,
IDE10530-MAS00107,History data 70-Month,9,
IDE10530-MAS00108,History data 70-Day,18,
IDE10530-MAS00109,History data 70-Hours,21, H
IDE10530-MAS00110,History data 70-Minutes,9, min
IDE10530-ENG28833,History data 70-Bus_ECU_1,15,
IDE10530-ENG28836,History data 70-Bus_ECU_2,0,
IDE10530-ENG28839,History data 70-Bus_ECU_3,0,
IDE10530-ENG28842,History data 70-Bus_ECU_4,0,
IDE10530-ENG28845,History data 70-Bus_ECU_5,0,
IDE10530-ENG28861,History data 70-Car_Wake_Up_Counter_ECU_1,35,
IDE10530-ENG28863,History data 70-Car_Wake_Up_Counter_ECU_2,0,
IDE10530-ENG28865,History data 70-Car_Wake_Up_Counter_ECU_3,0,
IDE10530-ENG28867,History data 70-Car_Wake_Up_Counter_ECU_4,0,
IDE10530-ENG28869,History data 70-Car_Wake_Up_Counter_ECU_5,0,
IDE10530-ENG28862,History data 70-Car_Wake_Up_Time_ECU_1,0.00, H
IDE10530-ENG28864,History data 70-Car_Wake_Up_Time_ECU_2,0.00, H
IDE10530-ENG28866,History data 70-Car_Wake_Up_Time_ECU_3,0.00, H
IDE10530-ENG28868,History data 70-Car_Wake_Up_Time_ECU_4,0.00, H
IDE10530-ENG28870,History data 70-Car_Wake_Up_Time_ECU_5,0.00, H
IDE10530-ENG118680,History data 70-Cycle_Counter,54,
IDE10530-ENG106038,History data 70-ECU_1,14,
IDE10530-ENG106039,History data 70-ECU_2,0,
IDE10530-ENG28620,History data 70-ECU_3,0,
IDE10530-ENG106040,History data 70-ECU_4,0,
IDE10530-ENG106041,History data 70-ECU_5,0,
IDE10530-ENG118681,History data 70-Time_Since_Clamp_15_Off,0.00, H
IDE10531-MAS00106,History data 71-Year,2019,
IDE10531-MAS00107,History data 71-Month,11,
IDE10531-MAS00108,History data 71-Day,10,
IDE10531-MAS00109,History data 71-Hours,19, H
IDE10531-MAS00110,History data 71-Minutes,50, min
IDE10531-ENG28833,History data 71-Bus_ECU_1,23,
IDE10531-ENG28836,History data 71-Bus_ECU_2,0,
IDE10531-ENG28839,History data 71-Bus_ECU_3,0,
IDE10531-ENG28842,History data 71-Bus_ECU_4,0,
IDE10531-ENG28845,History data 71-Bus_ECU_5,0,
IDE10531-ENG28871,History data 71-Cluster_Sleep_ECU_1,255,
IDE10531-ENG28872,History data 71-Cluster_Sleep_ECU_2,0,
IDE10531-ENG28873,History data 71-Cluster_Sleep_ECU_3,0,
IDE10531-ENG28874,History data 71-Cluster_Sleep_ECU_4,0,
IDE10531-ENG28875,History data 71-Cluster_Sleep_ECU_5,0,
IDE10531-ENG118680,History data 71-Cycle_Counter,9,
IDE10531-ENG106038,History data 71-ECU_1,21,
IDE10531-ENG106039,History data 71-ECU_2,0,
IDE10531-ENG28620,History data 71-ECU_3,0,
IDE10531-ENG106040,History data 71-ECU_4,0,
IDE10531-ENG106041,History data 71-ECU_5,0,
IDE10531-ENG118681,History data 71-Time_Since_Clamp_15_Off,0.00, H
IDE10532-MAS00106,History data 72-Year,2019,
IDE10532-MAS00107,History data 72-Month,10,
IDE10532-MAS00108,History data 72-Day,5,
IDE10532-MAS00109,History data 72-Hours,16, H
IDE10532-MAS00110,History data 72-Minutes,53, min
IDE10532-ENG28833,History data 72-Bus_ECU_1,15,
IDE10532-ENG28836,History data 72-Bus_ECU_2,15,
IDE10532-ENG28839,History data 72-Bus_ECU_3,0,
IDE10532-ENG28842,History data 72-Bus_ECU_4,0,
IDE10532-ENG28845,History data 72-Bus_ECU_5,0,
IDE10532-ENG28876,History data 72-Cluster_1_Start,0,
IDE10532-ENG28877,History data 72-Cluster_2_Start,0,
IDE10532-ENG28878,History data 72-Cluster_3_Start,0,
IDE10532-ENG28879,History data 72-Cluster_4_Start,0,
IDE10532-ENG28880,History data 72-Cluster_5_Start,0,
IDE10532-ENG28834,History data 72-Cluster_ECU_1,0,
IDE10532-ENG28837,History data 72-Cluster_ECU_2,0,
IDE10532-ENG28840,History data 72-Cluster_ECU_3,0,
IDE10532-ENG28843,History data 72-Cluster_ECU_4,0,
IDE10532-ENG28846,History data 72-Cluster_ECU_5,0,
IDE10532-ENG28881,History data 72-Cluster_Start_ECU_1,255,
IDE10532-ENG28882,History data 72-Cluster_Start_ECU_2,38,
IDE10532-ENG28883,History data 72-Cluster_Start_ECU_3,0,
IDE10532-ENG28884,History data 72-Cluster_Start_ECU_4,0,
IDE10532-ENG28885,History data 72-Cluster_Start_ECU_5,0,
IDE10532-ENG118680,History data 72-Cycle_Counter,14,
IDE10532-ENG106038,History data 72-ECU_1,132,
IDE10532-ENG106039,History data 72-ECU_2,76,
IDE10532-ENG28620,History data 72-ECU_3,0,
IDE10532-ENG106040,History data 72-ECU_4,0,
IDE10532-ENG106041,History data 72-ECU_5,0,
IDE10532-ENG118681,History data 72-Time_Since_Clamp_15_Off,0.00, H
IDE10533-MAS00106,History data 73-Year,2000,
IDE10533-MAS00107,History data 73-Month,1,
IDE10533-MAS00108,History data 73-Day,1,
IDE10533-MAS00109,History data 73-Hours,0, H
IDE10533-MAS00110,History data 73-Minutes,0, min
IDE10533-ENG28907,History data 73-Activetime_MIB,0.00, H
IDE10533-ENG28904,History data 73-Activetime_MOST,0.00, H
IDE10533-ENG28901,History data 73-Activetime_MU,0.00, H
IDE10533-ENG118680,History data 73-Cycle_Counter,0,
IDE10533-ENG28903,History data 73-State_MMI,3,
IDE10533-ENG28906,History data 73-State_MOST,1,
IDE10533-ENG118681,History data 73-Time_Since_Clamp_15_Off,0.00, H
IDE10533-ENG28905,History data 73-WakeUps_MOST,1,
IDE10533-ENG28902,History data 73-WakeUps_MU,1,
IDE10534-MAS00106,History data 74-Year,2019,
IDE10534-MAS00107,History data 74-Month,11,
IDE10534-MAS00108,History data 74-Day,10,
IDE10534-MAS00109,History data 74-Hours,19, H
IDE10534-MAS00110,History data 74-Minutes,50, min
IDE10534-ENG28887,History data 74-Awake_Time_FUNC_1,0.00, H
IDE10534-ENG28890,History data 74-Awake_Time_FUNC_2,0.10, H
IDE10534-ENG28893,History data 74-Awake_Time_FUNC_3,0.10, H
IDE10534-ENG28896,History data 74-Awake_Time_FUNC_4,0.00, H
IDE10534-ENG28899,History data 74-Awake_Time_FUNC_5,0.00, H
IDE10534-ENG118680,History data 74-Cycle_Counter,9,
IDE10534-ENG28886,History data 74-FUNC_1,2,
IDE10534-ENG28889,History data 74-FUNC_2,17,
IDE10534-ENG28892,History data 74-FUNC_3,18,
IDE10534-ENG28895,History data 74-FUNC_4,14,
IDE10534-ENG28898,History data 74-FUNC_5,11,
IDE10534-ENG28888,History data 74-Physical_Wakeup_FUNC_1,255,
IDE10534-ENG28891,History data 74-Physical_Wakeup_FUNC_2,255,
IDE10534-ENG28894,History data 74-Physical_Wakeup_FUNC_3,255,
IDE10534-ENG28897,History data 74-Physical_Wakeup_FUNC_4,112,
IDE10534-ENG28900,History data 74-Physical_Wakeup_FUNC_5,78,
IDE10534-ENG118681,History data 74-Time_Since_Clamp_15_Off,0.00, H
IDE10535-MAS03174,History data 75-Comfort data bus,0,
IDE10535-MAS03175,History data 75-Databus extended,0,
IDE10535-MAS03177,History data 75-Databus Infotainment,0,
IDE10535-MAS03179,History data 75-Local data bus 2,0,
IDE10535-MAS03180,History data 75-Local data bus,0,
IDE10535-MAS03181,History data 75-Flexray databus,0,
IDE10535-MAS05686,History data 75-Data bus diagnostics,0,
IDE10535-MAS05972,History data 75-Local data bus 3,0,
IDE10535-MAS07380,History data 75-Data bus Sensor/Hybrid,0,
IDE10535-MAS10036,History data 75-Data bus diagnosis 2,0,
IDE10535-MAS12183,History data 75-Convenience data bus 2,0,
IDE10535-MAS14086,History data 75-Instrument panel data bus,0,
IDE10623-IDE04447,Status drive profile for roll stabilization-Function status,engaged,
IDE10623-IDE06260,Status drive profile for roll stabilization-ID number,0,
IDE10623-MAS01156,Status drive profile for roll stabilization-Communication status,OK,
IDE10623-MAS01447,Status drive profile for roll stabilization-Act.val.,0,
IDE10624-IDE04447,Status: driving profile selection for sport differential-Function status,engaged,
IDE10624-IDE06260,Status: driving profile selection for sport differential-ID number,0,
IDE10624-MAS01156,Status: driving profile selection for sport differential-Communication status,OK,
IDE10624-MAS01447,Status: driving profile selection for sport differential-Act.val.,0,
IDE10625-IDE04447,Stat.driv.profile select.for warn.in case of. risk of collision-Function status,not engaged,
IDE10625-IDE06260,Stat.driv.profile select.for warn.in case of. risk of collision-ID number,0,
IDE10625-MAS01156,Stat.driv.profile select.for warn.in case of. risk of collision-Communication status,OK,
IDE10625-MAS01447,Stat.driv.profile select.for warn.in case of. risk of collision-Act.val.,0,
IDE10626-IDE04447,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-Function status,not engaged,
IDE10626-IDE06260,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-ID number,0,
IDE10626-MAS01156,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-Communication status,OK,
IDE10626-MAS01447,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-Act.val.,0,
IDE10627-IDE04447,Status driving profile selection for hybrid battery management-Function status,engaged,
IDE10627-IDE06260,Status driving profile selection for hybrid battery management-ID number,0,
IDE10627-MAS01156,Status driving profile selection for hybrid battery management-Communication status,OK,
IDE10627-MAS01447,Status driving profile selection for hybrid battery management-Act.val.,0,
IDE10628-IDE04447,Status: driving profile selection for emerg. brake assistance-Function status,engaged,
IDE10628-IDE06260,Status: driving profile selection for emerg. brake assistance-ID number,0,
IDE10628-MAS01156,Status: driving profile selection for emerg. brake assistance-Communication status,OK,
IDE10628-MAS01447,Status: driving profile selection for emerg. brake assistance-Act.val.,2,
IDE10629-IDE04447,Status: driving profile select. for rear axle differential lock-Function status,not engaged,
IDE10629-IDE06260,Status: driving profile select. for rear axle differential lock-ID number,0,
IDE10629-MAS01156,Status: driving profile select. for rear axle differential lock-Communication status,OK,
IDE10629-MAS01447,Status: driving profile select. for rear axle differential lock-Act.val.,0,
IDE10644-MAS06193,Driving profile selection: statistics distance driven-Profile 1,6985, km
IDE10644-MAS06194,Driving profile selection: statistics distance driven-Profile 2,4293924539, km
IDE10644-MAS06195,Driving profile selection: statistics distance driven-Profile 3,13998, km
IDE10644-MAS06196,Driving profile selection: statistics distance driven-Profile 4,0, km
IDE10644-MAS06197,Driving profile selection: statistics distance driven-Profile 5,0, km
IDE10644-MAS06198,Driving profile selection: statistics distance driven-Profile 6,0, km
IDE10644-MAS06199,Driving profile selection: statistics distance driven-Profile 7,1940, km
IDE10644-MAS06200,Driving profile selection: statistics distance driven-Profile 8,0, km
IDE10644-MAS08875,Driving profile selection: statistics distance driven-Profile 9,0, km
IDE10644-MAS08876,Driving profile selection: statistics distance driven-Profile 10,0, km
IDE10644-MAS08877,Driving profile selection: statistics distance driven-Profile 11,0, km
IDE10644-MAS08878,Driving profile selection: statistics distance driven-Profile 12,0, km
IDE10644-MAS08879,Driving profile selection: statistics distance driven-Profile 13,0, km
IDE10644-MAS08880,Driving profile selection: statistics distance driven-Profile 14,0, km
IDE10644-MAS08881,Driving profile selection: statistics distance driven-Profile 15,0, km
IDE10655-MAS00106,Pause recommendation: hist. data-Year,2019, yr
IDE10655-MAS00107,Pause recommendation: hist. data-Month,11, m
IDE10655-MAS00108,Pause recommendation: hist. data-Day,9, d
IDE10655-MAS00109,Pause recommendation: hist. data-Hours,19, H
IDE10655-MAS00110,Pause recommendation: hist. data-Minutes,49, min
IDE10655-MAS00111,Pause recommendation: hist. data-Seconds,25, s
IDE10655-MAS03401,Pause recommendation: hist. data-Parameter 1,0.40,
IDE10655-MAS03402,Pause recommendation: hist. data-Parameter 2,1.00,
IDE10655-MAS03403,Pause recommendation: hist. data-Parameter 3,4.07,
IDE10655-MAS03404,Pause recommendation: hist. data-Parameter 4,4.23,
IDE10655-MAS03405,Pause recommendation: hist. data-Parameter 5,0, %
IDE10655-MAS10985,Pause recommendation: hist. data-Overall drive duration,18, min
IDE10655-MAS10986,Pause recommendation: hist. data-Drive duration in active speed range,7, min
IDE10655-MAS10987,Pause recommendation: hist. data-Drive duration with warning readiness,3, min
IDE10655-MAS10988,Pause recommendation: hist. data-No. of warnings issued,00,
IDE10655-MAS14091,Pause recommendation: hist. data-Travel duration until first warning,0, min
IDE10656-MAS10989,Pause recommended: use-No. of drives with activated pause recommendation,02 2F,
IDE10656-MAS10990,Pause recommended: use-No. of drives with deactivated pause recommendation,01 B3,
IDE10669-MAS11003,Internal SIM card: identification-ICCID,89011702272053729387,
IDE10669-MAS11004,Internal SIM card: identification-UICCID,8949320000292358119F,
IDE10927-MAS11760,Total static current-current total quiescent current,0, mA
IDE10927-MAS11761,Total static current-Total time quiescent current exceeded,0.0, H
IDE10973,Generator voltage,13.5, V
IDE10974,12 V elec. system: error status,no error,
IDE11191-MAS12370,Open circuit detection: H-V lines-Wiring circuit 1,Mode not active,
IDE11191-MAS12371,Open circuit detection: H-V lines-Wiring circuit 2,Mode not active,
IDE11282-IDE00704,Battery for emergency call module-Charge level,99, %
IDE11282-MAS00362,Battery for emergency call module-Battery voltage,3341, mV
IDE11282-MAS02201,Battery for emergency call module-Temperature,38, °C
IDE11282-MAS02476,Battery for emergency call module-install,installed,
IDE11282-MAS08415,Battery for emergency call module-Battery condition,01,
IDE11282-MAS12544,Battery for emergency call module-Charge status,was not charged,
IDE11284-MAS00106,Sending status of online functions: history data-Year,2255, yr
IDE11284-MAS00107,Sending status of online functions: history data-Month,15, m
IDE11284-MAS00108,Sending status of online functions: history data-Day,31, d
IDE11284-MAS00109,Sending status of online functions: history data-Hours,31, H
IDE11284-MAS00110,Sending status of online functions: history data-Minutes,63, min
IDE11284-MAS00111,Sending status of online functions: history data-Seconds,63, s
IDE11284-MAS07134,Sending status of online functions: history data-ID services,ID_OTV,
IDE11284-MAS12545,Sending status of online functions: history data-Send attempt: status,not OK,
IDE11286-MAS01737,Crash signal: status-Diagnosis,not active,
IDE11286-MAS03849,Crash signal: status-Crash signal,not active,
IDE11286-MAS11203,Crash signal: status-Output DTM,not active,
IDE11295-MAS12548,Mobile radio network ident.-Country recognition of mobile radio network,36,
IDE11295-MAS12549,Mobile radio network ident.-Operator recognition of mobile radio network,9A,
IDE11378,Mobile radio network: registration status,registered,
IDE11485-MAS02832,HV voltage converter: status for electric drive-Malfunction status,Initializing,
IDE11485-MAS03001,HV voltage converter: status for electric drive-Mode,Initializing,
IDE11486-MAS02246,HV battery charge management: HV activation restriction-Timeout,not active,
IDE11486-MAS09518,HV battery charge management: HV activation restriction-Safety line,not active,
IDE11486-MAS09519,HV battery charge management: HV activation restriction-Message error,not active,
IDE11486-MAS09541,HV battery charge management: HV activation restriction-Act. mode init. error,not active,
IDE11486-MAS09542,HV battery charge management: HV activation restriction-Error status init. error,not active,
IDE11486-MAS09543,HV battery charge management: HV activation restriction-Operating mode error,not active,
IDE11486-MAS09544,HV battery charge management: HV activation restriction-No component function,not active,
IDE11486-MAS09545,HV battery charge management: HV activation restriction-Sequence error,not active,
IDE11486-MAS12351,HV battery charge management: HV activation restriction-HV voltage measurement error,not active,
IDE11486-MAS13068,HV battery charge management: HV activation restriction-HV voltage measurement initialization error,not active,
IDE11586-IDE04447,Status drive profile selection for integral steering-Function status,not engaged,
IDE11586-IDE06260,Status drive profile selection for integral steering-ID number,0,
IDE11586-MAS01156,Status drive profile selection for integral steering-Communication status,OK,
IDE11586-MAS01447,Status drive profile selection for integral steering-Act.val.,0,
IDE11661-IDE06930,Autonomous operation states-Voltage converter: status: Status,ERROR,
IDE11661-IDE08958,Autonomous operation states-H-V system: start request,active,
IDE11661-MAS07605,Autonomous operation states-Charge request,ERROR,
IDE11661-MAS08040,Autonomous operation states-Automatic recharging of starter battery,active,
IDE11661-MAS13088,Autonomous operation states-Preconditioning of the interior,ERROR,
IDE11661-MAS13089,Autonomous operation states-High-voltage vehicle electrical system: status,not active,
IDE11662-MAS13090,H-V power distribution-Energy allocation thermal management,12700, Wh
IDE11662-MAS13091,H-V power distribution-Energy allocation12-volt electrical system,102300, Wh
IDE11662-MAS13092,H-V power distribution-Energy content of the high-voltage battery,ERROR,
IDE11663,H-V energy management mode,Standby-mode,
IDE11664,Requirement to recharge the H-V battery charging management,not active,
IDE11671-MAS02246,H-V power transformers: prohibition on turning-on H-V-Timeout,not active,
IDE11671-MAS09518,H-V power transformers: prohibition on turning-on H-V-Safety line,not active,
IDE11671-MAS09519,H-V power transformers: prohibition on turning-on H-V-Message error,not active,
IDE11671-MAS09541,H-V power transformers: prohibition on turning-on H-V-Act. mode init. error,not active,
IDE11671-MAS09542,H-V power transformers: prohibition on turning-on H-V-Error status init. error,not active,
IDE11671-MAS09543,H-V power transformers: prohibition on turning-on H-V-Operating mode error,not active,
IDE11671-MAS09544,H-V power transformers: prohibition on turning-on H-V-No component function,not active,
IDE11671-MAS09545,H-V power transformers: prohibition on turning-on H-V-Sequence error,not active,
IDE11671-MAS12351,H-V power transformers: prohibition on turning-on H-V-HV voltage measurement error,not active,
IDE11671-MAS13068,H-V power transformers: prohibition on turning-on H-V-HV voltage measurement initialization error,not active,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11675-MAS02246,Roll stabilization: prohibition on turning-on 48V-Timeout,not active,
IDE11675-MAS09519,Roll stabilization: prohibition on turning-on 48V-Message error,not active,
IDE11675-MAS09541,Roll stabilization: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11675-MAS09542,Roll stabilization: prohibition on turning-on 48V-Error status init. error,not active,
IDE11675-MAS09543,Roll stabilization: prohibition on turning-on 48V-Operating mode error,not active,
IDE11675-MAS09544,Roll stabilization: prohibition on turning-on 48V-No component function,not active,
IDE11675-MAS09545,Roll stabilization: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11682-IDE04447,Status of driving profile selection for exhaust flaps-Function status,engaged,
IDE11682-IDE06260,Status of driving profile selection for exhaust flaps-ID number,0,
IDE11682-MAS01156,Status of driving profile selection for exhaust flaps-Communication status,OK,
IDE11682-MAS01447,Status of driving profile selection for exhaust flaps-Act.val.,0,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,Initializing,
IDE11683-MAS13708,Engine electronics: status of 48V network-Error status of electrical compressor,Initializing,
IDE11683-MAS13715,Engine electronics: status of 48V network-Electro compressor mode,Initializing,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,Initializing,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,Initializing,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,255,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initializing,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initializing,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initializing,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initializing,
IDE11686-MAS02832,Anti-roll stabilization: status for 48V power-Malfunction status,Initializing,
IDE11686-MAS03001,Anti-roll stabilization: status for 48V power-Mode,Initializing,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery Energy Control Module 2,not active,
IDE11911-SFT00196,48V activation restriction-DC/DC Converter Control Module,not active,
IDE11911-SFT09769,48V activation restriction-Control module for auxiliary air heater,not active,
IDE11911-SFT09997,48V activation restriction-Electrical Charger,not active,
IDE12084-MAS14046,Status of component protection slaves-Node address of the immobilizer master,00 8B,
IDE12084-MAS14047,Status of component protection slaves-Generation of the immobilizer master,Generation 2,
IDE12084-MAS14048,Status of component protection slaves-Authentication status of the immobilizer master,valid authentication,
IDE12084-MAS14053,Status of component protection slaves-Status of start authentication,switched on,
IDE12084-MAS14054,Status of component protection slaves-Start authentication can be deactivated,No,
IDE12084-MAS14055,Status of component protection slaves-Immobilizer master sends authentication request,Yes,
IDE12084-MAS14056,Status of component protection slaves-Status of the IKA key for immobilizer master,IKA key stored,
IDE12084-MAS14059,Status of component protection slaves-Node address of the component protection participant,00 6F,
IDE12084-MAS14060,Status of component protection slaves-Prioritized participant,No,
IDE12084-MAS14061,Status of component protection slaves-Authentication status of the component protection participant,valid authentication,
IDE12084-MAS14062,Status of component protection slaves-Participant extended start authentication,No,
IDE12084-MAS14063,Status of component protection slaves-Component protection participant sends authentication request,No,
IDE12084-MAS14064,Status of component protection slaves-Status of the IKA key for component protection participants,IKA key stored,
IDE12581-ENG28833,History data 76-Bus_ECU_1,0,
IDE12581-ENG28836,History data 76-Bus_ECU_2,0,
IDE12581-ENG28839,History data 76-Bus_ECU_3,0,
IDE12581-ENG28842,History data 76-Bus_ECU_4,0,
IDE12581-ENG28845,History data 76-Bus_ECU_5,0,
IDE12581-ENG118680,History data 76-Cycle_Counter,9,
IDE12581-ENG106038,History data 76-ECU_1,0,
IDE12581-ENG106039,History data 76-ECU_2,0,
IDE12581-ENG28620,History data 76-ECU_3,0,
IDE12581-ENG106040,History data 76-ECU_4,0,
IDE12581-ENG106041,History data 76-ECU_5,0,
IDE12581-ENG30992,History data 76-ECU_Knock_Out_ECU_1,0, min
IDE12581-ENG30993,History data 76-ECU_Knock_Out_ECU_2,0, min
IDE12581-ENG30994,History data 76-ECU_Knock_Out_ECU_3,0, min
IDE12581-ENG30995,History data 76-ECU_Knock_Out_ECU_4,0, min
IDE12581-ENG30996,History data 76-ECU_Knock_Out_ECU_5,0, min
IDE12581-ENG31201,History data 76-Fkt_Ausloesung_ECU_1,0,
IDE12581-ENG31202,History data 76-Fkt_Ausloesung_ECU_2,0,
IDE12581-ENG31203,History data 76-Fkt_Ausloesung_ECU_3,0,
IDE12581-ENG31204,History data 76-Fkt_Ausloesung_ECU_4,0,
IDE12581-ENG31205,History data 76-Fkt_Ausloesung_ECU_5,0,
IDE12581-ENG32787,History data 76-Sub_System_Aktiv_ECU_1,0,
IDE12581-ENG32788,History data 76-Sub_System_Aktiv_ECU_2,0,
IDE12581-ENG32789,History data 76-Sub_System_Aktiv_ECU_3,0,
IDE12581-ENG32790,History data 76-Sub_System_Aktiv_ECU_4,0,
IDE12581-ENG32791,History data 76-Sub_System_Aktiv_ECU_5,0,
IDE12581-ENG33300,History data 76-Veto_Aktiv_ECU_1,0,
IDE12581-ENG33301,History data 76-Veto_Aktiv_ECU_2,0,
IDE12581-ENG33302,History data 76-Veto_Aktiv_ECU_3,0,
IDE12581-ENG33303,History data 76-Veto_Aktiv_ECU_4,0,
IDE12581-ENG33304,History data 76-Veto_Aktiv_ECU_5,0,
IDE12583-MAS00106,History data 77-Year,2000, yr
IDE12583-MAS00107,History data 77-Month,1, m
IDE12583-MAS00108,History data 77-Day,1, d
IDE12583-MAS00109,History data 77-Hours,0, H
IDE12583-MAS00110,History data 77-Minutes,0, min
IDE12583-ENG28833,History data 77-Bus_ECU_1,0,
IDE12583-ENG28836,History data 77-Bus_ECU_2,0,
IDE12583-ENG28839,History data 77-Bus_ECU_3,0,
IDE12583-ENG28842,History data 77-Bus_ECU_4,0,
IDE12583-ENG28845,History data 77-Bus_ECU_5,0,
IDE12583-ENG118680,History data 77-Cycle_Counter,0,
IDE12583-ENG106038,History data 77-ECU_1,0,
IDE12583-ENG106039,History data 77-ECU_2,0,
IDE12583-ENG28620,History data 77-ECU_3,0,
IDE12583-ENG106040,History data 77-ECU_4,0,
IDE12583-ENG106041,History data 77-ECU_5,0,
IDE12583-ENG30992,History data 77-ECU_Knock_Out_ECU_1,0, min
IDE12583-ENG30993,History data 77-ECU_Knock_Out_ECU_2,0, min
IDE12583-ENG30994,History data 77-ECU_Knock_Out_ECU_3,0, min
IDE12583-ENG30995,History data 77-ECU_Knock_Out_ECU_4,0, min
IDE12583-ENG30996,History data 77-ECU_Knock_Out_ECU_5,0, min
IDE12583-ENG31201,History data 77-Fkt_Ausloesung_ECU_1,0,
IDE12583-ENG31202,History data 77-Fkt_Ausloesung_ECU_2,0,
IDE12583-ENG31203,History data 77-Fkt_Ausloesung_ECU_3,0,
IDE12583-ENG31204,History data 77-Fkt_Ausloesung_ECU_4,0,
IDE12583-ENG31205,History data 77-Fkt_Ausloesung_ECU_5,0,
IDE12583-ENG32787,History data 77-Sub_System_Aktiv_ECU_1,0,
IDE12583-ENG32788,History data 77-Sub_System_Aktiv_ECU_2,0,
IDE12583-ENG32789,History data 77-Sub_System_Aktiv_ECU_3,0,
IDE12583-ENG32790,History data 77-Sub_System_Aktiv_ECU_4,0,
IDE12583-ENG32791,History data 77-Sub_System_Aktiv_ECU_5,0,
IDE12583-ENG118681,History data 77-Time_Since_Clamp_15_Off,0.00, H
IDE12583-ENG33300,History data 77-Veto_Aktiv_ECU_1,0,
IDE12583-ENG33301,History data 77-Veto_Aktiv_ECU_2,0,
IDE12583-ENG33302,History data 77-Veto_Aktiv_ECU_3,0,
IDE12583-ENG33303,History data 77-Veto_Aktiv_ECU_4,0,
IDE12583-ENG33304,History data 77-Veto_Aktiv_ECU_5,0,
IDE13018-MAS02246,Electrical drive 2: high-voltage switch on prevention-Timeout,not active,
IDE13018-MAS09518,Electrical drive 2: high-voltage switch on prevention-Safety line,not active,
IDE13018-MAS09519,Electrical drive 2: high-voltage switch on prevention-Message error,not active,
IDE13018-MAS09542,Electrical drive 2: high-voltage switch on prevention-Error status init. error,not active,
IDE13018-MAS09544,Electrical drive 2: high-voltage switch on prevention-No component function,not active,
IDE13018-MAS09546,Electrical drive 2: high-voltage switch on prevention-Voltage disconnect. init. error,not active,
IDE13018-MAS12345,Electrical drive 2: high-voltage switch on prevention-Active discharge fault,not active,
IDE13019-MAS02246,Electrical drive 3: high-voltage switch on prevention-Timeout,not active,
IDE13019-MAS09518,Electrical drive 3: high-voltage switch on prevention-Safety line,not active,
IDE13019-MAS09519,Electrical drive 3: high-voltage switch on prevention-Message error,not active,
IDE13019-MAS09542,Electrical drive 3: high-voltage switch on prevention-Error status init. error,not active,
IDE13019-MAS09544,Electrical drive 3: high-voltage switch on prevention-No component function,not active,
IDE13019-MAS09546,Electrical drive 3: high-voltage switch on prevention-Voltage disconnect. init. error,not active,
IDE13019-MAS12345,Electrical drive 3: high-voltage switch on prevention-Active discharge fault,not active,
IDE13032,Emergency call module: start condition status,Not available,
IDE13033-MAS15531,Communication status of emergency call module: analysis-Components 1,Not available,
IDE13033-MAS15532,Communication status of emergency call module: analysis-Components 2,Not available,
IDE13033-MAS15533,Communication status of emergency call module: analysis-Components 3,Not available,
IDE13033-MAS15534,Communication status of emergency call module: analysis-Components 4,Available,
IDE13033-MAS15535,Communication status of emergency call module: analysis-Components 5,Available,
IDE13057-MAS15615,Lithium ions starter battery-Battery: fault status,no error,
IDE13057-MAS15620,Lithium ions starter battery-Battery cut-out element: fault status,no error,
IDE13140,History data 78,,
IDE13140,History data 78,*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0C000000*00000000*00000000*00000000*00**,
IDE13140,History data 78,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0C000000*00000000*00000000*00000000*00**,
IDE13140,History data 78,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00,
IDE13141,History data 79,1048574*2000-00-00-00:00:00**,
IDE13141,History data 79,,
IDE13142,History data 80,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0C000000*00000000*00000000*00000000*00**,
IDE13142,History data 80,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00,
IDE13142,History data 80,,
IDE13142,History data 80,*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0C000000*00000000*00000000*00000000*00**,
IDE13398-ENG39192,Driving profile history data 5-Battery_Charge,0, min
IDE13398-ENG39193,Driving profile history data 5-Battery_Hold,0, min
IDE13398-ENG39289,Driving profile history data 5-EV,0, min
IDE13398-ENG98636,Driving profile history data 5-Hybrid,0, min
IDE13402-MAS06193,Driving profile history data 6-Profile 1,0, km
IDE13402-MAS06194,Driving profile history data 6-Profile 2,0, km
IDE13402-MAS06195,Driving profile history data 6-Profile 3,0, km
IDE13402-MAS06196,Driving profile history data 6-Profile 4,0, km
IDE13573-IDE11095,Advanced StartStop display version-Rqmt. spec. version,,
IDE13573-MAS01483,Advanced StartStop display version-Softwareversion,,
IDE13673,Microphone 2 status,Not available,
IDE13674,Microphone 2 voltage consumption,0.00, mA
IDE13754-MAS03095,Diagnosis filter: status-Function status,Function is not active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755,Diagnosis filter: history data,,
IDE13848-MAS06568,Onboard network components: medium-voltage-Auxiliary Heater,not installed,
IDE13848-MAS10933,Onboard network components: medium-voltage-Roll stabilization,not installed,
IDE13848-MAS11243,Onboard network components: medium-voltage-Battery Management 48V,not installed,
IDE13848-MAS16949,Onboard network components: medium-voltage-Active setup verification,not installed,
IDE13848-MAS16953,Onboard network components: medium-voltage-Belt driven starter generator 48V,not installed,
IDE13848-MAS17010,Onboard network components: medium-voltage-48V Vehicle Electrical System Storage Capacitor,not installed,
IDE13848-SFT00196,Onboard network components: medium-voltage-DC/DC Converter Control Module,not installed,
IDE13848-SFT09997,Onboard network components: medium-voltage-Electrical Charger,not installed,
IDE13849-IDE12114,Onboard network diagnosis 48V 1-48V vehicle electrical system diagnosis,requested,
IDE13849-MAS01867,Onboard network diagnosis 48V 1-Measurement,OK,
IDE13849-MAS15721,Onboard network diagnosis 48V 1-Battery management 48V power supply battery,Initializing,
IDE13850-MAS01867,Onboard network diagnosis 48V 2-Measurement,OK,
IDE13850-MAS06864,Onboard network diagnosis 48V 2-Generator actual voltage,Initializing,
IDE13850-MAS15119,Onboard network diagnosis 48V 2-48V vehicle electrical system,not active,
IDE13850-MAS15722,Onboard network diagnosis 48V 2-Battery management 48V: actual voltage,Initializing,
IDE13850-MAS16957,Onboard network diagnosis 48V 2-Electrically driven compressor: current voltage,Initializing,
IDE13850-MAS16958,Onboard network diagnosis 48V 2-Voltage converter: current voltage,Initializing,
IDE13850-MAS16959,Onboard network diagnosis 48V 2-Roll stabilization front axis current voltage,Initializing,
IDE13850-MAS16960,Onboard network diagnosis 48V 2-Roll stabilization rear axis current voltage,Initializing,
IDE13850-MAS16961,Onboard network diagnosis 48V 2-Active setup verification front axle current voltage,Initializing,
IDE13850-MAS16962,Onboard network diagnosis 48V 2-Active setup verification rear axle current voltage,Initializing,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,0E,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,11,
MAS00464-MAS00108,Standard - ambient data 1-Day,10,
MAS00464-MAS00109,Standard - ambient data 1-Hours,20,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,25,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,47,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,114,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,32501,
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,not activated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,not activated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,3,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,Audi,
MAS00769-MAS01288,Multifunction steering wheel control module-Signal horn,not activated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Unknown (0),
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Unknown (0),
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,9,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,not activated,
MAS01758-IDE00500,Date/time-Hour,1, H
MAS01758-IDE00501,Date/time-Minute,25, min
MAS01758-IDE00502,Date/time-Year,2019, yr
MAS01758-IDE00503,Date/time-Month,11, m
MAS01758-IDE00504,Date/time-Day,11, d
MAS01758-MAS00111,Date/time-Seconds,47, s
MAS01758-MAS02238,Date/time-Current,Winter time,
MAS01758-MAS03617,Date/time-Time zone,0.00, H
MAS04394-IDE03580,Connection status-Country code for mobile network,310,
MAS04394-IDE07699,Connection status-Mobile network operator,410,
MAS04394-MAS03991,Connection status-Reception level antenna 1,18.91, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,Unknown (19),
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-MAS13670,Connection status-Mobile radio cell identification,59013,
MAS04394-ENG123308,Connection status-TCP_Connection_State,not active,
MAS06413,Audio signal output,Electrical OK,
MAS08178-IDE02493,Crash information-Automatic door unlocking,Not available,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08178-MAS08956,Crash information-Automatic emergency call activated:Fuel shut-off,Not available,
MAS08200,Emergency call speaker status,Electrical OK,
ENG06732-ENG06827,12V_zustart_prohibition-12V_start_system_error,00 04,
ENG06732-ENG06826,12V_zustart_prohibition-12V_zustart_prohibition_on_drive,00 58,
ENG06732-ENG06825,12V_zustart_prohibition-12V_zustart_prohibition_on_stop,00 00,
ENG08764-MAS01867,48V_overvoltage_check-Measurement,OK,
ENG08764-ENG09344,48V_overvoltage_check-Bms_48V_actual_voltage,Initializing,
ENG08764-ENG09345,48V_overvoltage_check-Bms_48V_Soc,Initializing,
ENG08769-MAS11874,48V_Zero_potential_status-Overall status,Initializing,
ENG04784,Break_Recommendation_Index,1.00,
ENG04785-ENG126257,Break_Recommendation_TTNR-TTNR_DS,0,
ENG04785-ENG126256,Break_Recommendation_TTNR-TTNR_SW,60042,
ENG06743,Challenge_KS,65 45 3D 03,
ENG06744-MAS06854,Checksumme_KS-Version,81,
ENG06744-MAS06855,Checksumme_KS-Test sum,E2 F8 DF 7C,
ENG08767-ENG09366,coldstart_requirement_engine-requirement_12V_start,active,
ENG08767-ENG09367,coldstart_requirement_engine-requirement_48V_start,not active,
ENG118785-ENG118741,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Error_Indication,0,
ENG118785-ENG118742,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Indication_State,0,
ENG118785-ENG118743,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State,0,
ENG118785-ENG118744,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State_Value,0,
ENG118784-ENG05030,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Active_Body_Control,not active,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG05036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Autonomous_Emergency_Breaking,not active,
ENG118784-ENG05035,Driv._Prof._Sel._Coord._Retry_State-Retry_State_battery_management,not active,
ENG118784-ENG118738,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Beam_Control,not active,
ENG118784-ENG05018,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG05023,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Centre_and_rear_axle_differential,not active,
ENG118784-ENG118735,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Climatronic,not active,
ENG118784-ENG05029,Driv._Prof._Sel._Coord._Retry_State-Retry_State_corner_assist,not active,
ENG118784-ENG05032,Driv._Prof._Sel._Coord._Retry_State-Retry_State_cruise_control,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG05024,Driv._Prof._Sel._Coord._Retry_State-Retry_State_e_quattro,not active,
ENG118784-ENG05031,Driv._Prof._Sel._Coord._Retry_State-Retry_State_E_Sound,not active,
ENG118784-ENG05038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Differential_Lock,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG05037,Driv._Prof._Sel._Coord._Retry_State-Retry_State_engine_operating_state,not active,
ENG118784-ENG05021,Driv._Prof._Sel._Coord._Retry_State-Retry_State_exhaust_gas_flaps,not active,
ENG118784-ENG05039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Forward_Collision_Warning_Objects,not active,
ENG118784-ENG05040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Forward_Collision_Warning_Pedestrian,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG05041,Driv._Prof._Sel._Coord._Retry_State-Retry_State_integral_steering,not active,
ENG118784-ENG05034,Driv._Prof._Sel._Coord._Retry_State-Retry_State_lift_control_unit,not active,
ENG118784-ENG05025,Driv._Prof._Sel._Coord._Retry_State-Retry_State_matrixbeam,not active,
ENG118784-ENG05022,Driv._Prof._Sel._Coord._Retry_State-Retry_State_middle_differential,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG05015,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Rear_Axle_Differential,not active,
ENG118784-ENG05027,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_axle_steering,not active,
ENG118784-ENG05017,Driv._Prof._Sel._Coord._Retry_State-Retry_State_ride-height_control_system,not active,
ENG118784-ENG118740,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Routing_Adaption,not active,
ENG118784-ENG05020,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sailing_suggestion,not active,
ENG118784-ENG05033,Driv._Prof._Sel._Coord._Retry_State-Retry_State_servo_tronic,not active,
ENG118784-ENG05019,Driv._Prof._Sel._Coord._Retry_State-Retry_State_sidepanel_seat,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG05026,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Spoiler_Control_Unit,not active,
ENG118784-ENG05028,Driv._Prof._Sel._Coord._Retry_State-Retry_State_stabilisation_control_unit,not active,
ENG118784-ENG118731,Driv._Prof._Sel._Coord._Retry_State-Retry_State_StartStop,not active,
ENG118784-ENG05016,Driv._Prof._Sel._Coord._Retry_State-Retry_State_steering_control_unit,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognized,
ENG118786-ENG05042,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile_BMA,not recognized,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,3,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG06742-MAS02832,eABC_48V_status-Malfunction status,Initializing,
ENG06742-MAS03001,eABC_48V_status-Mode,Initializing,
ENG118766,eASS_operation_status,active,
ENG06152-ENG112328,eCall Active Cell ID-CID,0D DA E6 85,
ENG06150,eCall_Current_Heading,118, °
ENG06149-MAS01779,eCall_Current_Position-Length,81, °
ENG06149-MAS01780,eCall_Current_Position-Width,26, °
ENG06151-ENG06150,eCall_Current_Position_Confidence-eCall_Current_Heading,100, m
ENG06154-MAS01779,eCall_Last_Valid_Position-Length,81, °
ENG06154-MAS01780,eCall_Last_Valid_Position-Width,26, °
ENG06153-ENG98842,eCall_Position_Confidence-Position,100, m
ENG04786-ENG05075,Ehr_segment_load-attribute_pool,0.00,
ENG04786-ENG05074,Ehr_segment_load-segment_pool,0.00,
ENG04786-ENG05076,Ehr_segment_load-speedlimit_pool,0.00,
ENG106121-ENG101157,EM_Battery_charge_discharge-BZE_Q_Elad,4248.1, Ah
ENG106121-ENG100159,EM_Battery_charge_discharge-BZE_Q_Lad,4336.3, Ah
ENG04782,EM_bdm_error_state,0,
ENG106123,EM_blAlternator On,On,
ENG26761,EM_Current_Control,active,
ENG118437,EM_IAlternatorReserve,98.3, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,650, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,85, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,81, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,Release,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,Release,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,Release,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,Release,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,Release,
ENG118780-ENG04973,EM_Recuperation_Precondition-battery_disconnected,Release,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,Release,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,Release,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,Release,
ENG118780-ENG30744,EM_Recuperation_Precondition-dc_source_activity,Release,
ENG118780-ENG30745,EM_Recuperation_Precondition-dc_source_diagnosis,Release,
ENG118780-ENG118444,EM_Recuperation_Precondition-generator_workload,Release,
ENG118780-ENG31832,EM_Recuperation_Precondition-hv_cutoff_level,Release,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,Release,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,Release,
ENG118780-ENG32123,EM_Recuperation_Precondition-mv_cutoff_level,Release,
ENG118780-ENG102605,EM_Recuperation_Precondition-outside_temperature,Release,
ENG118780-ENG104256,EM_Recuperation_Precondition-production_mode,Release,
ENG118780-ENG04974,EM_Recuperation_Precondition-trailer_dedection,Release,
ENG118780-ENG111086,EM_Recuperation_Precondition-Transport_Mode,Release,
ENG106169,EM_valHlkLevelRequirement,500, W
ENG106169,EM_valHlkLevelRequirement,Stage 1,
ENG06717,EM_vehicle_bus_state,01 03 00 3D,
ENG04777,EM_vehicle_state,02 14,
ENG04779-ENG04996,EM_voltage_control_state-EM_das_control_state,0,
ENG04779-ENG04995,EM_voltage_control_state-EM_gas_control_state,1,
ENG04779-ENG04997,EM_voltage_control_state-EM_ras_control_state,0,
ENG04779-ENG04998,EM_voltage_control_state-EM_Ureg_control_state,5,
ENG04776,EMZ_state,6,
ENG04775,engine_identifier,3,
ENG04780,freewheel_info,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,160101,
ENG118782-ENG05091,Gateway app. software identification-software_version_cGW,090025,
ENG118782-ENG05083,Gateway app. software identification-software_version_cha,250300,
ENG118782-ENG05090,Gateway app. software identification-software_version_eHorizont,130600,
ENG118782-ENG05085,Gateway app. software identification-software_version_HvEm,120800,
ENG118782-ENG05086,Gateway app. software identification-software_version_HvK,120800,
ENG118782-ENG05092,Gateway app. software identification-software_version_MvEM,120800,
ENG118782-ENG05093,Gateway app. software identification-software_version_MVK,120800,
ENG118782-ENG05084,Gateway app. software identification-software_version_NvEm,120800,
ENG118782-ENG05087,Gateway app. software identification-software_version_ObDc,080524,
ENG118782-ENG05088,Gateway app. software identification-software_version_PE,060610,
ENG118782-ENG05089,Gateway app. software identification-software_version_range,100105,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,110201,
ENG04773-ENG04886,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x03,00 00 00,
ENG04773-ENG31556,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x04,00 00 00,
ENG04773-ENG31557,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x05,00 00 00,
ENG04773-ENG31558,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x06,00 00 00,
ENG04773-ENG31559,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x07,00 00 00,
ENG04773-ENG31560,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x08,00 00 00,
ENG04773-ENG04887,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0A,00 00 00,
ENG04773-ENG04888,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0B,00 00 00,
ENG04773-ENG04889,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0C,00 00 00,
ENG04773-ENG04890,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0E,00 00 00,
ENG04773-ENG04891,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0F,00 00 00,
ENG04773-ENG04892,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x12,00 00 00,
ENG04773-ENG04893,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x13,00 00 00,
ENG04773-ENG04894,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x14,00 00 00,
ENG04773-ENG04895,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x15,00 00 00,
ENG04773-ENG04896,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x16,00 00 00,
ENG04773-ENG04897,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1A,00 00 00,
ENG04773-ENG04898,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1B,00 00 00,
ENG04773-ENG04899,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1C,00 00 00,
ENG04773-ENG04900,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1E,00 00 00,
ENG04773-ENG04901,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x23,10 00 00,
ENG04773-ENG04902,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x24,00 00 00,
ENG04773-ENG04903,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x27,04 00 00,
ENG04773-ENG04904,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2A,00 00 00,
ENG04773-ENG04905,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2B,00 00 00,
ENG04773-ENG04906,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2C,00 00 00,
ENG04773-ENG04907,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2D,00 00 00,
ENG04773-ENG04908,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2E,00 00 00,
ENG04773-ENG04909,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x30,00 00 00,
ENG04773-ENG04910,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x31,00 00 00,
ENG04773-ENG04911,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x32,00 00 00,
ENG04773-ENG04912,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x3B,00 00 00,
ENG04773-ENG04913,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x41,00 00 00,
ENG04773-ENG04914,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x42,00 00 00,
ENG04773-ENG31561,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x43,00 00 00,
ENG04773-ENG04915,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x44,00 01 00,
ENG04773-ENG04916,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x46,00 00 00,
ENG04773-ENG04917,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x47,02 00 00,
ENG04773-ENG116879,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x49,00 00 00,
ENG04773-ENG04918,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4A,00 00 00,
ENG04773-ENG04919,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4B,01 00 00,
ENG04773-ENG04920,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4C,08 00 00,
ENG04773-ENG04921,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4D,08 00 00,
ENG04773-ENG04922,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4E,00 00 00,
ENG04773-ENG04923,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4F,00 00 00,
ENG04773-ENG04924,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x53,00 00 00,
ENG04773-ENG04925,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x56,00 00 00,
ENG04773-ENG04926,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x57,00 00 00,
ENG04773-ENG31562,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x59,00 00 00,
ENG04773-ENG04927,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x5A,00 00 00,
ENG04773-ENG04928,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x60,00 00 00,
ENG04773-ENG31563,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x61,00 00 00,
ENG04773-ENG04929,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x63,00 00 00,
ENG04773-ENG04930,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x64,00 00 00,
ENG04773-ENG04931,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x69,00 00 00,
ENG04773-ENG04932,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x6A,00 00 00,
ENG04773-ENG04933,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x73,E0 00 00,
ENG04773-ENG04934,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x76,00 00 00,
ENG04773-ENG04935,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x77,00 00 00,
ENG04773-ENG04936,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x78,00 00 00,
ENG04773-ENG04937,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x7B,00 00 00,
ENG04773-ENG04938,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x7C,00 00 00,
ENG04773-ENG04939,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x80,00 00 00,
ENG04773-ENG04940,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x84,10 00 00,
ENG04773-ENG04941,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x87,08 00 00,
ENG04773-ENG04942,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x88,08 00 00,
ENG04773-ENG31564,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x89,00 00 00,
ENG04773-ENG04943,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8A,00 00 00,
ENG04773-ENG04944,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8B,00 00 00,
ENG04773-ENG04945,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8E,00 00 00,
ENG04773-ENG04946,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8F,00 00 00,
ENG04773-ENG04947,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x93,00 00 00,
ENG04773-ENG04948,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x94,00 00 00,
ENG04773-ENG04949,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x95,08 00 00,
ENG04773-ENG04950,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9B,00 00 00,
ENG04773-ENG04951,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9C,00 00 00,
ENG04773-ENG04952,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9D,00 00 00,
ENG04773-ENG04953,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9E,00 00 00,
ENG04773-ENG04954,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xA0,10 00 00,
ENG04773-ENG08116,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xAD,00 00 00,
ENG04773-ENG31565,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xAE,00 00 00,
ENG04773-ENG31566,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xB8,00 00 00,
ENG04773-ENG31567,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xBB,00 00 00,
ENG04773-ENG116981,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF3,00 00 00,
ENG04772-ENG04819,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x03,00,
ENG04772-ENG04833,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x1E,00,
ENG04772-ENG04843,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x32,00,
ENG04772-ENG04878,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x93,00,
ENG04772-ENG04879,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x94,00,
ENG04772-ENG04880,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x95,00,
ENG04772-ENG04881,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x9B,00,
ENG04772-ENG04882,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x9C,00,
ENG04772-ENG31568,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x04,00,
ENG04772-ENG31569,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x05,00,
ENG04772-ENG31570,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x06,00,
ENG04772-ENG31571,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x07,00,
ENG04772-ENG31572,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x08,00,
ENG04772-ENG04820,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0A,00,
ENG04772-ENG04821,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0B,00,
ENG04772-ENG04822,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0C,02,
ENG04772-ENG04823,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0E,02,
ENG04772-ENG04824,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0F,00,
ENG04772-ENG04825,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x12,02,
ENG04772-ENG04826,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x13,02,
ENG04772-ENG04827,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x14,02,
ENG04772-ENG04828,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x15,02,
ENG04772-ENG04829,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x16,00,
ENG04772-ENG04830,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1A,00,
ENG04772-ENG04831,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1B,00,
ENG04772-ENG04832,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1C,00,
ENG04772-ENG04834,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x23,00,
ENG04772-ENG06781,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x24,00,
ENG04772-ENG04835,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x27,00,
ENG04772-ENG04836,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2A,00,
ENG04772-ENG04837,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2B,00,
ENG04772-ENG04838,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2C,00,
ENG04772-ENG04839,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2D,00,
ENG04772-ENG04840,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2E,00,
ENG04772-ENG04841,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x30,00,
ENG04772-ENG04842,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x31,00,
ENG04772-ENG04844,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x3B,00,
ENG04772-ENG04845,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x41,00,
ENG04772-ENG04846,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x42,00,
ENG04772-ENG31573,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x43,00,
ENG04772-ENG04847,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x44,00,
ENG04772-ENG04848,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x46,02,
ENG04772-ENG04849,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x47,00,
ENG04772-ENG116935,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x49,00,
ENG04772-ENG04850,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4A,02,
ENG04772-ENG04851,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4B,02,
ENG04772-ENG04852,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4C,02,
ENG04772-ENG04853,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4D,00,
ENG04772-ENG04854,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4E,02,
ENG04772-ENG31574,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4F,00,
ENG04772-ENG04856,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x53,02,
ENG04772-ENG04857,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x56,00,
ENG04772-ENG04858,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x57,00,
ENG04772-ENG31575,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x59,00,
ENG04772-ENG04859,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x5A,00,
ENG04772-ENG04860,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x60,00,
ENG04772-ENG31576,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x61,00,
ENG04772-ENG06782,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x63,00,
ENG04772-ENG04861,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x64,00,
ENG04772-ENG04862,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x69,02,
ENG04772-ENG04863,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x6A,00,
ENG04772-ENG04864,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x73,02,
ENG04772-ENG04865,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x76,02,
ENG04772-ENG04866,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x77,02,
ENG04772-ENG04867,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x78,00,
ENG04772-ENG04868,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7B,00,
ENG04772-ENG04869,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7C,00,
ENG04772-ENG04870,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x80,00,
ENG04772-ENG04871,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x84,02,
ENG04772-ENG04872,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x87,00,
ENG04772-ENG04873,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x88,00,
ENG04772-ENG31577,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x89,00,
ENG04772-ENG04874,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8A,02,
ENG04772-ENG04875,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8B,02,
ENG04772-ENG04876,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8E,00,
ENG04772-ENG04877,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8F,00,
ENG04772-ENG04883,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9D,00,
ENG04772-ENG04884,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9E,00,
ENG04772-ENG04885,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xA0,00,
ENG04772-ENG08115,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xAD,00,
ENG04772-ENG31578,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xAE,00,
ENG04772-ENG31579,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB8,00,
ENG04772-ENG31580,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xBB,00,
ENG04772-ENG117001,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF3,00,
ENG117867-ENG06211,GPS_Count_Satellite_Phase_Lock_Counter-count_sattelite_phase_lock,0,
ENG123212-ENG123347,GPS_Dilution_of_precision-geometric_dilution_of_precision,00 00,
ENG123212-ENG123346,GPS_Dilution_of_precision-horizontal_dilution_of_precision,00 00,
ENG123212-ENG123296,GPS_Dilution_of_precision-Initiation,not initialized,
ENG123212-ENG123348,GPS_Dilution_of_precision-positional_dilution_of_precision,00 00,
ENG123212-ENG123345,GPS_Dilution_of_precision-time_dilution_of_precision,00 00,
ENG123212-ENG123344,GPS_Dilution_of_precision-vertical_dilution_of_precision,00 00,
ENG117868-ENG06212,GPS_Satellite_Code_Lock_Counter-count_sattelite_code_lock,0,
ENG06145-ENG06200,hvk_high_voltag_total_discharge_prevention-dcdc_target_mode,0,
ENG06145-ENG06199,hvk_high_voltag_total_discharge_prevention-hvk_total_discharge_prevention_state,0,
ENG06145-ENG06201,hvk_high_voltag_total_discharge_prevention-tme_ekk_target_mode,0,
ENG06145-ENG06202,hvk_high_voltag_total_discharge_prevention-tme_hvptc_target_mode,0,
ENG06144-ENG30377,hvk_high_voltage_zero_potential-awc_zero_potential,0,
ENG06144-ENG06195,hvk_high_voltage_zero_potential-bms_failure_state,7,
ENG06144-ENG06192,hvk_high_voltage_zero_potential-bms_zero_potential,0,
ENG06144-ENG06194,hvk_high_voltage_zero_potential-em1_zero_potential,0,
ENG06144-ENG39295,hvk_high_voltage_zero_potential-Flexray_status,1,
ENG06144-ENG39330,hvk_high_voltage_zero_potential-HCAN_status,1,
ENG06144-ENG06198,hvk_high_voltage_zero_potential-hvk_total_zero_potential,0,
ENG06144-ENG06196,hvk_high_voltage_zero_potential-hvlm_connector_plug_state,0,
ENG06144-ENG06193,hvk_high_voltage_zero_potential-lad_zero_potential,0,
ENG123205,Incoming_call_line_state,Idle,
ENG26975-ENG30888,MFLe_LIN-DI_Emblem,OFF,
ENG26975-ENG46163,MFLe_LIN-DI_KL_50xs,58,
ENG26975-ENG46164,MFLe_LIN-DI_KL_58xt,58,
ENG26975-ENG30921,MFLe_LIN-Dimmung_01_gueltig,invalid,
ENG26975-ENG31890,MFLe_LIN-Klemme_15_MFL,On,
ENG26975-ENG31892,MFLe_LIN-KLR_Modusanforderung,Normal_mode,
ENG26975-ENG31980,MFLe_LIN-LR_HZG_Freigabe,no_restriction,
ENG26975-ENG31981,MFLe_LIN-LR_HZG_on_off,OFF,
ENG26975-ENG32052,MFLe_LIN-MFLe_Anzeige_LaunchControl,display_off,
ENG26975-ENG32053,MFLe_LIN-MFLe_Anzeige_MAP,OFF,
ENG26975-ENG32054,MFLe_LIN-MFLe_Anzeige_Sport,display_off,
ENG26975-ENG32055,MFLe_LIN-MFLe_Anzeige_Sport_Plus,display_off,
ENG26975-ENG32056,MFLe_LIN-MFLe_Tastencode_alt_neu,apply_keycode_new,
ENG26975-ENG32226,MFLe_LIN-P_Mode_MFL,OFF,
ENG06740,MVEM_dc_current_Mv,204.0, A
ENG06739,MVEM_dc_power_desired,0, W
ENG06734,MVEM_DC_voltage_desired,63.50, V
ENG06741,MVEM_dc_voltage_Mv,63.25, V
ENG06736-ENG09198,MVEM_Derating_voltage-Derating_group_A,63.50, V
ENG06736-ENG09199,MVEM_Derating_voltage-Derating_group_B,63.50, V
ENG06736-ENG09200,MVEM_Derating_voltage-Derating_group_C,63.50, V
ENG06736-ENG09337,MVEM_Derating_voltage-Derating_Umax_feedback,63.5, V
ENG06738,MVEM_EMG_level_of_capacity,100.000, %
ENG06737,MVEM_Emg_voltage_desired,63.50, V
ENG06733,MVEM_Mv_current,-11, A
ENG08763-ENG09342,MVEM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG08763-ENG09343,MVEM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG08762-ENG09338,MVEM_release-12V_coldstart_release,No enabling,
ENG08762-ENG09339,MVEM_release-12V_warmstart_release,No enabling,
ENG08762-ENG09340,MVEM_release-48V_coldstart_release,No enabling,
ENG08762-ENG09341,MVEM_release-start_stopp_support_release,No enabling,
ENG06735,MVEM_RSG_maximal_current,508, A
ENG08761-ENG09336,MVEM_RSG_maximal_voltage-RSG_maximal_voltage,63.50, V
ENG06718-ENG06799,NVEM_12Vrsg_input_parameter-rsg_cutoff_ rotation_speed,3000, /min
ENG06718-ENG06798,NVEM_12Vrsg_input_parameter-rsg_exciter current_limit,16.0, A
ENG06718-ENG06800,NVEM_12Vrsg_input_parameter-rsg_load_response_time,3, s
ENG06718-ENG06801,NVEM_12Vrsg_input_parameter-rsg_target_mode,0,
ENG06718-ENG06797,NVEM_12Vrsg_input_parameter-rsg_voltage_desired,10.6, V
ENG04778-ENG55511,NVEM_Hlr_release-Release_FlHz_hl,No enabling,
ENG04778-ENG55512,NVEM_Hlr_release-Release_FlHz_hr,No enabling,
ENG04778-ENG55513,NVEM_Hlr_release-Release_FlHz_rest_seat,No enabling,
ENG04778-ENG55514,NVEM_Hlr_release-Release_FlHz_vl,No enabling,
ENG04778-ENG55515,NVEM_Hlr_release-Release_FlHz_vr,No enabling,
ENG04778-ENG04987,NVEM_Hlr_release-Release_FSH,OFF,
ENG04778-ENG04986,NVEM_Hlr_release-Release_HSH,No enabling,
ENG04778-ENG04989,NVEM_Hlr_release-Release_KRH_vl,No enabling,
ENG04778-ENG04988,NVEM_Hlr_release-Release_KRH_vr,No enabling,
ENG04778-ENG04990,NVEM_Hlr_release-Release_LRH,No enabling,
ENG04778-ENG04991,NVEM_Hlr_release-Release_PTC,No enabling,
ENG04778-ENG04992,NVEM_Hlr_release-Release_PTC_linear,0, W
ENG04778-ENG04975,NVEM_Hlr_release-Release_SIH_Fond,Release,
ENG04778-ENG04979,NVEM_Hlr_release-Release_SIH_hl,No enabling,
ENG04778-ENG04978,NVEM_Hlr_release-Release_SIH_hr,No enabling,
ENG04778-ENG04977,NVEM_Hlr_release-Release_SIH_vl,No enabling,
ENG04778-ENG04976,NVEM_Hlr_release-Release_SIH_vr,No enabling,
ENG04778-ENG04983,NVEM_Hlr_release-Release_SIL_hl,No enabling,
ENG04778-ENG04982,NVEM_Hlr_release-Release_SIL_hr,No enabling,
ENG04778-ENG04981,NVEM_Hlr_release-Release_SIL_vl,No enabling,
ENG04778-ENG04980,NVEM_Hlr_release-Release_SIL_vr,No enabling,
ENG04778-ENG04985,NVEM_Hlr_release-Release_Sp_heatin_codriver,No enabling,
ENG04778-ENG04984,NVEM_Hlr_release-Release_Sp_heatin_driver,No enabling,
ENG04778-ENG32447,NVEM_Hlr_release-Release_TCH,No enabling,
ENG06726,NVEM_Hv_DcDc_voltage_desired_nv,10.6, V
ENG04783,NVEM_hybrid_info,3,
ENG06730,NVEM_Mv_DcDc_voltage_desired_nv,10.6, V
ENG04774-ENG06796,NVEM_Voltage_Request-Voltage_Request_BCM,not active,
ENG04774-ENG04969,NVEM_Voltage_Request-Voltage_Request_ClimatControl,not active,
ENG04774-ENG04968,NVEM_Voltage_Request-Voltage_Request_engine,Stage 1,
ENG04774-ENG04966,NVEM_Voltage_Request-Voltage_Request_EPS,not active,
ENG04774-ENG04967,NVEM_Voltage_Request-Voltage_Request_ESP,not active,
ENG04774-ENG04970,NVEM_Voltage_Request-Voltage_Request_GearControl,not active,
ENG04774-ENG04971,NVEM_Voltage_Request-Voltage_Request_Reduction_Alternator_Load,not active,
ENG04788-ENG98667,operation_hours-Kilometers,904,
ENG123204,Outgoing_call_line_state,line_free,
ENG08771-ENG09431,Stack_Size_Max-Stack_Size_Max_ISR,10, %
ENG08771-ENG09408,Stack_Size_Max-Stack_Size_Max_Task_01,0, %
ENG08771-ENG09409,Stack_Size_Max-Stack_Size_Max_Task_02,25, %
ENG08771-ENG09410,Stack_Size_Max-Stack_Size_Max_Task_03,0, %
ENG08771-ENG09411,Stack_Size_Max-Stack_Size_Max_Task_04,0, %
ENG08771-ENG09412,Stack_Size_Max-Stack_Size_Max_Task_05,0, %
ENG08771-ENG09413,Stack_Size_Max-Stack_Size_Max_Task_06,16, %
ENG08771-ENG09414,Stack_Size_Max-Stack_Size_Max_Task_07,0, %
ENG08771-ENG09415,Stack_Size_Max-Stack_Size_Max_Task_08,53, %
ENG08771-ENG09416,Stack_Size_Max-Stack_Size_Max_Task_09,16, %
ENG08771-ENG09417,Stack_Size_Max-Stack_Size_Max_Task_10,31, %
ENG08771-ENG09418,Stack_Size_Max-Stack_Size_Max_Task_11,31, %
ENG08771-ENG09419,Stack_Size_Max-Stack_Size_Max_Task_12,57, %
ENG08771-ENG09420,Stack_Size_Max-Stack_Size_Max_Task_13,50, %
ENG08771-ENG09421,Stack_Size_Max-Stack_Size_Max_Task_14,0, %
ENG08771-ENG09422,Stack_Size_Max-Stack_Size_Max_Task_15,0, %
ENG08771-ENG09423,Stack_Size_Max-Stack_Size_Max_Task_16,0, %
ENG08771-ENG09424,Stack_Size_Max-Stack_Size_Max_Task_17,0, %
ENG08771-ENG09425,Stack_Size_Max-Stack_Size_Max_Task_18,0, %
ENG08771-ENG09426,Stack_Size_Max-Stack_Size_Max_Task_19,0, %
ENG08771-ENG09427,Stack_Size_Max-Stack_Size_Max_Task_20,0, %
ENG08771-ENG09428,Stack_Size_Max-Stack_Size_Max_Task_21,0, %
ENG08771-ENG09429,Stack_Size_Max-Stack_Size_Max_Task_22,0, %
ENG08771-ENG09430,Stack_Size_Max-Stack_Size_Max_Task_23,15, %
ENG04781,StartStop_info,0,
ENG08770-ENG09376,State_Dataset_AuxFunktions-Datensatz_0,not_valid,
ENG08770-ENG09377,State_Dataset_AuxFunktions-Datensatz_1,valid,
ENG08770-ENG09392,State_Dataset_AuxFunktions-Datensatz_10,not_valid,
ENG08770-ENG09393,State_Dataset_AuxFunktions-Datensatz_11,not_valid,
ENG08770-ENG09394,State_Dataset_AuxFunktions-Datensatz_12,not_valid,
ENG08770-ENG09395,State_Dataset_AuxFunktions-Datensatz_13,not_valid,
ENG08770-ENG09396,State_Dataset_AuxFunktions-Datensatz_14,not_valid,
ENG08770-ENG09397,State_Dataset_AuxFunktions-Datensatz_15,not_valid,
ENG08770-ENG09398,State_Dataset_AuxFunktions-Datensatz_16,not_valid,
ENG08770-ENG09399,State_Dataset_AuxFunktions-Datensatz_17,not_valid,
ENG08770-ENG09400,State_Dataset_AuxFunktions-Datensatz_18,not_valid,
ENG08770-ENG09401,State_Dataset_AuxFunktions-Datensatz_19,not_valid,
ENG08770-ENG09402,State_Dataset_AuxFunktions-Datensatz_1A,valid,
ENG08770-ENG09403,State_Dataset_AuxFunktions-Datensatz_1B,valid,
ENG08770-ENG09404,State_Dataset_AuxFunktions-Datensatz_1C,valid,
ENG08770-ENG09405,State_Dataset_AuxFunktions-Datensatz_1D,valid,
ENG08770-ENG09406,State_Dataset_AuxFunktions-Datensatz_1E,valid,
ENG08770-ENG09407,State_Dataset_AuxFunktions-Datensatz_1F,valid,
ENG08770-ENG09378,State_Dataset_AuxFunktions-Datensatz_2,not_valid,
ENG08770-ENG09379,State_Dataset_AuxFunktions-Datensatz_3,not_valid,
ENG08770-ENG09380,State_Dataset_AuxFunktions-Datensatz_4,not_valid,
ENG08770-ENG09381,State_Dataset_AuxFunktions-Datensatz_5,not_valid,
ENG08770-ENG09382,State_Dataset_AuxFunktions-Datensatz_6,not_valid,
ENG08770-ENG09383,State_Dataset_AuxFunktions-Datensatz_7,not_valid,
ENG08770-ENG09384,State_Dataset_AuxFunktions-Datensatz_8,not_valid,
ENG08770-ENG09385,State_Dataset_AuxFunktions-Datensatz_9,not_valid,
ENG08770-ENG09386,State_Dataset_AuxFunktions-Datensatz_A,not_valid,
ENG08770-ENG09387,State_Dataset_AuxFunktions-Datensatz_B,not_valid,
ENG08770-ENG09388,State_Dataset_AuxFunktions-Datensatz_C,not_valid,
ENG08770-ENG09389,State_Dataset_AuxFunktions-Datensatz_D,not_valid,
ENG08770-ENG09390,State_Dataset_AuxFunktions-Datensatz_E,not_valid,
ENG08770-ENG09391,State_Dataset_AuxFunktions-Datensatz_F,not_valid,
ENG06146-MAS00106,Status_to_a_agree_a_appointment_online-Year,2000,
ENG06146-MAS00107,Status_to_a_agree_a_appointment_online-Month,0,
ENG06146-MAS00108,Status_to_a_agree_a_appointment_online-Day,0,
ENG06146-MAS00109,Status_to_a_agree_a_appointment_online-Hours,0,
ENG06146-MAS00110,Status_to_a_agree_a_appointment_online-Minutes,0,
ENG06146-MAS00111,Status_to_a_agree_a_appointment_online-Seconds,0,
ENG06146-ENG28929,Status_to_a_agree_a_appointment_online-Status_OTV_remind_Flag,no_Set,
ENG06146-ENG28928,Status_to_a_agree_a_appointment_online-Status_OTV_Trigger,no_Set,
ENG08634-ENG120595,Transportmode_Status-Transport_Protection,not activated,
ENG08634-ENG98982,Transportmode_Status-Transportmode,not activated,
ENG04789-ENG05094,Voltage_Comfort_CAN-Voltage_CAN_High,1.30, V
ENG04789-ENG05095,Voltage_Comfort_CAN-Voltage_CAN_Low,1.16, V
ENG04792-ENG05094,Voltage_Extended_CAN-Voltage_CAN_High,1.30, V
ENG04792-ENG05095,Voltage_Extended_CAN-Voltage_CAN_Low,1.20, V
ENG04790-ENG05094,Voltage_Hybrid_CAN-Voltage_CAN_High,1.28, V
ENG04790-ENG05095,Voltage_Hybrid_CAN-Voltage_CAN_Low,1.14, V
ENG04791-ENG05094,Voltage_Infotainment_CAN-Voltage_CAN_High,1.36, V
ENG04791-ENG05095,Voltage_Infotainment_CAN-Voltage_CAN_Low,1.14, V
Elapsed Time: 07:34
adpmap-19-8W6-907-468-F
;SW:8W6-907-468-F HW:8W6-907-468-E --- CAN Gateway
;Component:Gateway H43 0123, Coding:030100010000064029070000005900124C180007100000000175078E10000000
;EV_CGateCONTIAU491,003111,EV_CGateCONTIAU491_003_AU49.rod
;Sunday,10,November,2019,20:27:53:01617
;VCDS Version: Release 19.6.2 (x64) Data version: 20190930 DS308.0
;VCID: CDDD6A729CD7CF279C-8098
IDE00001-IDE00332-Production mode-Buttons for multi-function steering wheel,Deactivating ,3
IDE00001-IDE10279-Production mode-Onboard data collector,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS11109-Production mode-Wireless network connection,Deactivating ,3
IDE00002-Transport mode,not activated ,1
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE01211-Static current measuring mode,not activated ,1
IDE01996-IDE14867-Installation list: specified installations-Subgateway as firewall control module,Not coded ,32
IDE01996-MAS00796-Installation list: specified installations-Engine Control Module (ECM),coded ,32
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00007-Installation list: specified installations-Display Control Unit,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00012-Installation list: specified installations-Rear Axle Steering 2,Not coded ,32
IDE01996-SFT00017-Installation list: specified installations-Engine Control Module 2,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,coded ,32
IDE01996-SFT00027-Installation list: specified installations-Active Steering,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00039-Installation list: specified installations-Display Control Unit Rear,Not coded ,32
IDE01996-SFT00040-Installation list: specified installations-Climate Control Unit Rear,Not coded ,32
IDE01996-SFT00042-Installation list: specified installations-Control Unit Wireless Charging,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded ,32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,coded ,32
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00070-Installation list: specified installations-Central Module Comfort System,coded ,32
IDE01996-SFT00072-Installation list: specified installations-Seat Adjustment Rear Driver Side,Not coded ,32
IDE01996-SFT00074-Installation list: specified installations-Rear light,Not coded ,32
IDE01996-SFT00077-Installation list: specified installations-Löschkandidat_Datenübertragung Car2X,Not coded ,32
IDE01996-SFT00080-Installation list: specified installations-Seat Adjustment 3rd Row,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00090-Installation list: specified installations-Longitudinal control,Not coded ,32
IDE01996-SFT00091-Installation list: specified installations-Seat Adjustment Rear Passenger Side,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
IDE01996-SFT00107-Installation list: specified installations-Aerodynamics Control Unit,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00113-Installation list: specified installations-Battery Charger,Not coded ,32
IDE01996-SFT00116-Installation list: specified installations-Chassis Control,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded ,32
IDE01996-SFT00127-Installation list: specified installations-Information Control Unit 2,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00129-Installation list: specified installations-Gear Shift Control Module,coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00132-Installation list: specified installations-Night Vision,Not coded ,32
IDE01996-SFT00139-Installation list: specified installations-Adaptive Cruise Control 2,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00172-Installation list: specified installations-Reductant Control Module,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded ,32
IDE01996-SFT00186-Installation list: specified installations-Assembly Mounting,Not coded ,32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
IDE01996-SFT00195-Installation list: specified installations-Drive Motor Control Module 3,Not coded ,32
IDE01996-SFT00196-Installation list: specified installations-DC/DC Converter Control Module,Not coded ,32
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
IDE01996-SFT00203-Installation list: specified installations-Rear Axle Steering,Not coded ,32
IDE01996-SFT00205-Installation list: specified installations-Laser Scanner,Not coded ,32
IDE01996-SFT00206-Installation list: specified installations-Drive Motor Control Module 2,Not coded ,32
IDE01996-SFT00208-Installation list: specified installations-Front Axle Lift System,Not coded ,32
IDE01996-SFT00219-Installation list: specified installations-Front Corner Radar 1,Not coded ,32
IDE01996-SFT00220-Installation list: specified installations-Front Corner Radar 2,Not coded ,32
IDE01996-SFT00221-Installation list: specified installations-Control Module 2 For Sunroof,Not coded ,32
IDE01996-SFT33031-Installation list: specified installations-Antenna Control Module,Not coded ,32
IDE01996-SFT33232-Installation list: specified installations-Central control for digital matrix light,Not coded ,32
IDE01996-SFT271904-Installation list: specified installations-Sun Roof,coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,75 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,280225P0F4 ,15
IDE03903-Production process data 1,00 00 00 A2 AA AA ,6
IDE04159-Deactivation of start-stop function,regular operation ,1
IDE06748-Pause recommendation,activated ,1
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,10.20 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,40.10 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,100 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,10 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,990 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,24 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,23.10 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,23.10 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,23.10 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,23.10 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,23.10 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,23.10 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),24.10 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,10.30 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,23.30 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,23.10 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,6.10 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,10.20 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,10.20 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,10.20 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,10.20 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,10.20 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,10.20 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,10.20 l/100km,48
IDE10351-MAS05767-Message mirroring-port,00 00 ,21
IDE10351-MAS09111-Message mirroring-IP address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,21
IDE10351-MAS10445-Message mirroring-Data bus CAN 1,not active ,21
IDE10351-MAS10446-Message mirroring-Data bus CAN 2,not active ,21
IDE10351-MAS10447-Message mirroring-Data bus CAN 3,not active ,21
IDE10351-MAS10448-Message mirroring-Data bus CAN 4,not active ,21
IDE10351-MAS10449-Message mirroring-Data bus CAN 5,not active ,21
IDE10351-MAS10450-Message mirroring-Data bus CAN 6,not active ,21
IDE10351-MAS10451-Message mirroring-Data bus Flexray A,not active ,21
IDE10351-MAS10452-Message mirroring-Data bus LIN 1,not active ,21
IDE10351-MAS10453-Message mirroring-Data bus LIN 2,not active ,21
IDE10351-MAS10454-Message mirroring-Data bus LIN 3,not active ,21
IDE10351-MAS10460-Message mirroring-Target bus,not active ,21
IDE10351-MAS11107-Message mirroring-Data bus CAN 7,not active ,21
IDE10351-MAS13143-Message mirroring-FlexRay B data bus,not active ,21
IDE10351-MAS17841-Message mirroring-Data bus CAN 8,not active ,21
IDE11209-MAS12388-Vehicle condition report: settings-Send report after terminal 15 off wait time,3C ,5
IDE11209-MAS12389-Vehicle condition report: settings-After terminal 15 off: also wait for bus inactivity,OFF ,5
IDE11209-MAS12390-Vehicle condition report: settings-Send report after terminal 15 on wait time,3C ,5
IDE11209-MAS12391-Vehicle condition report: settings-Send report after bus inactivity wait time,05 ,5
IDE11209-MAS12392-Vehicle condition report: settings-Send report upon reaching BEM shutdown level,OFF ,5
IDE11688-IDE08958-Autonomous operation request-H-V system: start request,regular operation ,3
IDE11688-MAS08040-Autonomous operation request-Automatic recharging of starter battery,regular operation ,3
IDE11688-MAS13088-Autonomous operation request-Preconditioning of the interior,regular operation ,3
IDE13338-Basic functions connect,Deactivating ,4
IDE13756-Diagnosis filter: activation,not active ,1
IDE13757-MAS16868-Diagnosis filter: kilometer thresholds-Kilometer threshold: production,200 km,2
IDE13757-MAS16869-Diagnosis filter: kilometer thresholds-Kilometer threshold: customer service,20 km,2
ENG137256-Adaption_high_voltage_zero_potential,regular operation ,1
ENG137852-Backup_Power_Threshold,0 %,1
ENG153689-Counter_for_inconsistent_conditions,20 ,2
ENG153814-download_eem,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,256
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,13
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120 ,13
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,13
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,13
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,13
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,13
ENG118777-ENG136172-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Number_of_Keys,1 ,13
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,13
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,500 ms,13
ENG118777-ENG136168-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_1,800 ms,13
ENG118777-ENG136169-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_2,1000 ms,13
ENG118777-ENG136170-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_3,0 ms,13
ENG118777-ENG136171-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_4,0 ms,13
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,6000 ms,13
ENG118775-energy_management_deactiv_stage,regular operation ,1
ENG137255-HVK_Warning,regular operation ,1
ENG118451-ENG118685-Switch_on_ban_independent_car_heater-Set_point_target_time,80 min,2
ENG118451-ENG118684-Switch_on_ban_independent_car_heater-Switch_on_ban_activation,regular operation ,2
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,2
ENG118774-ENG136195-WakeUpMonitor_Activation-Activation_Bus_Activity,activated ,2
ENG118774-ENG136134-WakeUpMonitor_Activation-Activation_Cluster_Sleep,activated ,2
ENG118774-ENG136135-WakeUpMonitor_Activation-Activation_Cluster_Start,activated ,2
ENG118774-ENG136197-WakeUpMonitor_Activation-Activation_CWUP,activated ,2
ENG118774-ENG136130-WakeUpMonitor_Activation-Activation_Keeping_Awake,activated ,2
ENG118774-ENG136196-WakeUpMonitor_Activation-Activation_Knock_Out,activated ,2
ENG118774-ENG136131-WakeUpMonitor_Activation-Activation_Logical_Wakeup,activated ,2
ENG118774-ENG136198-WakeUpMonitor_Activation-Activation_NFU,activated ,2
ENG118774-ENG136132-WakeUpMonitor_Activation-Activation_Physical_Wakeup,activated ,2
ENG118774-ENG136199-WakeUpMonitor_Activation-Activation_SBU,activated ,2
ENG118773-ENG136190-WakeUpMonitor_Configuration-Max_Num_Cluster_Sleep,20 counts,13
ENG118773-ENG136191-WakeUpMonitor_Configuration-Max_Num_Cluster_Start,20 counts,13
ENG118773-ENG136192-WakeUpMonitor_Configuration-Max_Num_CWUP,30 counts,13
ENG118773-ENG136189-WakeUpMonitor_Configuration-Max_Num_Knock_Out,3 counts,13
ENG118773-ENG136187-WakeUpMonitor_Configuration-Max_Num_Logical_Wakeup,40 counts,13
ENG118773-ENG136193-WakeUpMonitor_Configuration-Max_Num_NF,20 min,13
ENG118773-ENG136188-WakeUpMonitor_Configuration-Max_Num_Physical_Wakeup,10 counts,13
ENG118773-ENG136194-WakeUpMonitor_Configuration-Max_Num_Sb,20 min,13
ENG118773-ENG136186-WakeUpMonitor_Configuration-Max_Time_Keeping_Awake,20 min,13
ENG118773-ENG109064-WakeUpMonitor_Configuration-Start_Delay,0 s,13
ENG118773-ENG136185-WakeUpMonitor_Configuration-Wake_Delay,20 min,13
Elapsed Time: 00:27
