Maps 2018 Audi A4 - SilverCar Scans and maps
Maps
DrPeter
16.4905° S, 151.7375° W
The following information is from a 2018 A4 SilverCar. For some reason, I was under the impression it was a 2019. Supposedly, Silvercar will be phasing out the Audi A4 models and keeping the Q5 as the base vehicle.
ref:
Vehicle Identification No. WAUENAF47JA147898
Model Audi A4 qu. 2,0
A4
Date of production 02.03.2018
Model year 2018
Sales type 8W25NY
Engine Code CYMC
Transmission Code TBR
Axle drive 7A
Auto-Scan and again, these vehicles are full of fault codes.
Sunday,10,November,2019,17:36:11:27784
VCDS Version: 19.9.3.0 (x64)  HEX-NET CB: 0.4516.4
Data version: 20190930 DS314.0
VIN: WAUENAF47JA147898   License Plate: HN2_USB_001
Mileage: 32501km-20195mi   Repair Order:
Chassis Type: F4-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F 6C
          81 A5 BB BC CA CF D6 D7
VIN: WAUENAF47JA147898   Mileage: 32501km-20195miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC)       Labels:. 06K-907-425-V2.clb
   Part No SW: 8W0 906 259 J    HW: 06L 907 425 C
   Component: 2.0l R4 TFSI  H15 0002
   Revision: --H15---
   Coding: 0A2500322326010E34280000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
   ROD: EV_ECM20TFS0208W0906259J.rod
   VCID: 48C2336AA24533C7569-801C
19861 - Implausible Data Received from Body Control Module A (Central Electric 2)
          U0431 00 [032] - -
23126 - Fuel Level Sensor Circuit
          P0461 00 [096] - Implausible Signal
Address 02: Auto Trans (J217)       Labels:| 0CJ-927-156.clb
   Part No SW: 8W2 927 155 BA    HW: 0CJ 927 156
   Component: 0CL 20TFSINAR H05 0001
   Revision: --H05---    Serial number: 0000003009
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 0154EE4EC1FFC28FD17-8054
   Manual Transmission Fluid Pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180039002726
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 K    HW: 8W0 907 379 J
   Component: ESP9 Plus     H10 0766
   Coding: 18AA409928A60A9D11A6489A00855292E4259A180214508812004A4927A459
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_ESP9BOSCHCMP 002013
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 4DCC027E4D27D6EF65F-8018
7 Faults Found:
15371776 - Databus
          U1121 00 [032] - Missing Message
          [ComScl:_Signal_Group_SG_AEB_01_-_Timeout_error]
15385344 - Databus
          U1122 00 [040] - Implausible Message
          [ComScl:_Signal_Group_SG_Klemmen_Status_01-_Checksum_error]
                    Mileage: 31452 km
                    Date: 2019.10.24
                    Time: 11:08:55
                    83 40 80 00 CA 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 02
420352 - TPMS Warning; Front Left Tire
          C1054 00 [040] - Pressure too Low
                    Mileage: 32039 km
                    Date: 2019.11.04
                    Time: 13:11:34
                    92 00 80 2B 88 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 1E
416768 - TPMS Warning; Front Right Tire
          C1056 00 [040] - Pressure too Low
                    Mileage: 32039 km
                    Date: 2019.11.04
                    Time: 13:11:34
417024 - TPMS Warning; Rear Right Tire
          C105A 00 [040] - Pressure too Low
                    Mileage: 32039 km
                    Date: 2019.11.04
                    Time: 13:11:34
419584 - TPMS Warning; Rear Left Tire
          C1059 00 [032] - Flat
419840 - TPMS Warning; Rear Right Tire
          C105B 00 [032] - Flat
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0210
   Coding: 140805095544000D10000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44DA275A9E6D17A7BA1-8010
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002173732
   Component: AQ_Hum_Sensor  H02 0007
   Serial number: 92A0141900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
459025 - Databus
                    Reset counter: 57
                    Mileage: 20527 km
                    Date: 2019.06.28
                    Time: 12:24:51
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07500363E0081CCD0515871518AC98BB110B3D08000000000000000020001A010A690122025705
   Shop #: WSC 06325 790 00001
   ASAM Dataset: EV_BCM1BOSCHAU736 018006
   ROD: EV_BCM1BOSCHAU736_018_AU49.rod
   VCID: 0256E142C4F9D997C8D-8056
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 180129  043 0813
   Serial number: 89435300301802906266
   Coding: 5BC7F7
   Serial number: 21162035X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AK    HW: 4M0 941 531 AK
   Component: E1 - LDS  H06 0008
   Serial number: 10 01 2018  01257092
   Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600350Z003102
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20180123021932 00039
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE114121723610576
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W0 947 135 CJ    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00692010
   Subsystem 8 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2817000303921002
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 G    HW: 8W0 959 655 G
   Component: Airbag10.44   H05 0107
   Serial number: 003UQ002EM7I
   Coding: BFCCF0C000800000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W0857705G0051S01321
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W0857706J0051S01931
   Coding: 80000D
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J180008XIW801
   Subsystem 4 - Part No SW: -----------    HW: 442 061 102 18
   Component: SideSensor_Df  1E2 0887
   Serial number: 3577Y00BD28937B3E22C
   Subsystem 5 - Part No SW: -----------    HW: 442 061 102 18
   Component: SideSensor_Pf  1E2 0887
   Serial number: 3587Y00BB28937B15343
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 901 18
   Component: SideSensor_Dr  1C7 0148
   Serial number: 3517700C9291FA26820D
   Subsystem 7 - Part No SW: -----------    HW: 442 0B2 901 18
   Component: SideSensor_Pr  1C7 0148
   Serial number: 352770099292F3F0B28N
   Subsystem 8 - Part No SW: -----------    HW: 442 0C3 001 18
   Component: FrontSensor_D  1C5 014A
   Serial number: 3557500B529A8BE1536O
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C3 001 18
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500B529A8BE3411J
   Part No SW: 4M0 907 129 GB    HW: 4M0 907 129 GB
   Component: Lenks.Modul   H11 0009
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76BE8D929831F537F45-8022
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8W5 920 890 D    HW: 8W5 920 890 D
   Component: FBenUSA       H18 0373
   Coding: 09E651C12888CF050223E9601800000008000000
   ASAM Dataset: EV_DashBoardAU736 001027
   ROD: EV_DashBoardAU736_AU49.rod
   Part No SW: 8W6 907 468 F    HW: 8W6 907 468 E
   Component: Gateway       H43 0123
   Revision: 7B000002    Serial number: 0287B774018222
   Coding: 030100010000064029070000005900124C180007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   ROD: EV_CGateCONTIAU491_003_AU49.rod
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20180221031542 20435
   Serial number: 8410526904
131723 - Body Control Module (Central Electric 2)
          U0141 00 [008] - No Communications
          [Timeout_Node_0x8B_DiagAdress_46_BCM2]
                    Reset counter: 117
                    Mileage: 31478 km
                    Date: 2019.10.24
                    Time: 17:59:25
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Electric_current_Upper_Limit_Value_Exceeded]
                    Reset counter: 126
                    Mileage: 30955 km
                    Date: 2019.10.18
                    Time: 19:25:27
                    Total static current-current total quiescent current: 124 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
                    EM_vehicle_state: 00 00
Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   ROD: EV_LCMLeftHELLAAU736_VW48.rod
   VCID: 78A283AA92258347E69-802C
   Part No SW: 4M4 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0042
   Serial number: 00000305815222
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
   VCID: 79A486AEA92F9A4F997-802C
Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 363E4D92D8B1B537345-8062
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0129
   Serial number: 0000305797478
   Coding: 005F1B205E001080000100B2
   ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
   VCID: 43D824469B63109F83B-8016
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42D621428479199788D-8016
   Part No SW: 8W0 907 064 EC    HW: 8W0 907 064 DC
   Component: BCM2 MLBevo   025 0387
   Coding: 013400004FB00080650FA0002E01000233024000810026502F0400000B04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY18023449Y
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099769943
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
   Serial number: >1218533
131086 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 13 [008] - Open Circuit
                    Fault Frequency: 14
                    Reset counter: 149
                    Mileage: 30955 km
                    Date: 2019.10.18
                    Time: 18:24:00
                    Supply voltages-Supply voltage: Terminal 30: 12.582 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.609 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.609 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                    general_additional_freeze_frame-coprocessor_spi_status: 00000000
                    general_additional_freeze_frame-dataflash_status: 00000000
                    general_additional_freeze_frame-interior_temperature: -50.0 °C
                    general_additional_freeze_frame-Operating_Status: 00000000 00000000
                    general_additional_freeze_frame-production_mode: not active
                    general_additional_freeze_frame-reset_cause: 00000000
                    general_additional_freeze_frame-Reset_counter: 0
                    general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                    general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                    general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 80
                    general_additional_freeze_frame-Transport_Mode: not active
                    general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                    antenna_freeze_frame: 00011001 00000000 00000000 01011101
65896 - Databus
          [Climatronic control module: Klima_03: no signal/communication]
                    Reset counter: 154
                    Mileage: 15391 km
                    Date: 2019.04.11
                    Time: 14:20:21
                    Supply voltages-Supply voltage: Terminal 30: 13.044 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 13.071 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 13.071 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 02 98
                    can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAHJA03N4WL
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0129
   Serial number: 0000305562655
   Coding: 005F1B205E001080000100B0
   ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880 B    HW: 8W5 035 880
   Component: MU-P-LNS-US   034 1178
   Serial number: A798B0JB086239
   Coding: 019401020000000053220002041A00102F0002E501700904FE
   ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
   VCID: 3E2E55B2F0817D77EC5-806A
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Subsystem 2 - Part No SW: 8W0 919 605     HW: 8W0 919 605
   Component: AU49x_DU_HIGH  H40 0008
   Serial number: AUZ8Z9HBJ04JGJ
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK129011800020023
   Component: Gracenote2  --- 3012
Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
   Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
   Component: RVC Compact   H12 0250
   Coding: 0294010102002001400040
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 33387486CBC3A01F13B-8066
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 8W1 713 041 G    HW: 8W1 713 041 J
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 18022046117960
   ASAM Dataset: EV_GSMWaehlZFAU736 001017
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 37204096DFBB4C3F2F3-8062
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
   Component: BVS           H17 0050
   Coding: 0404090100000201022023A2A50000FC00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 3C2A5FBAE69D6F67C21-8068
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0129
   Serial number: 0000306272232
   Coding: 000F1B2000001080400000A0
   ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
   VCID: 45DC3A5E95572EAFADF-8010
   Component: TSG HBFS      005 0129
   Serial number: 0000306282348
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
   Part No SW: 4M0 907 594 H    HW: 4M0 907 594
   Coding: 2A8000049100
   VCID: 3B285CA6E393685FCBB-806E
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   ROD: EV_RearRadarS2BoschAU736.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_AU37.rod
   VCID: 167EAD12B8715537145-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 01:55, VBatt start/end: 13.2V/13.2V)-----------
Auto-Scan after some testing and clearing the fault codes.
Sunday,10,November,2019,21:15:32:27784
   Revision: --H15---
   VCID: C8C2B36A2245B3C7D69-809C
Readiness: 1010 0101
   VCID: 81546E4E41FF428F517-80D4
   VCID: CDCC827ECD2756EFE5F-8098
   VCID: C4DAA75A1E6D97A73A1-8090
   VCID: 8256614244F9599748D-80D6
   Coding: 5BC7F7
   Coding: 02005D
   Coding: 350000
   Coding: 80000D
   Coding: 80000D
   Occupant Detection:
   VCID: F6BE0D9218317537745-80A2
   VCID: F8A203AA12250347669-80AC
   VCID: F9A406AE292F1A4F197-80AC
   Revision: --------
   Coding: 0E8002
   VCID: B63ECD9258B13537B45-80E2
   VCID: C3D8A4461B63909F03B-8096
   VCID: C2D6A1420479999708D-8096
65896 - Databus
                    Reset counter: 154
                    Mileage: 32501 km
                    Date: 2019.11.10
                    Time: 20:47:45
                    Supply voltages-Supply voltage: Terminal 30: 12.663 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.691 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.677 V
   VCID: BE2ED5B27081FD776C5-80EA
   VCID: B338F4864BC3201F93B-80E6
   VCID: B720C0965FBBCC3FAF3-80E2
   VCID: BC2ADFBA669DEF67421-80E8
   VCID: C5DCBA5E1557AEAF2DF-8090
   VCID: BB28DCA66393E85F4BB-80EE
   Revision: --------
   Coding: 0E8002
   VCID: 967E2D123871D537945-80C2
End----------(Elapsed Time: 02:02, VBatt start/end: 13.2V/13.2V)-----------
Maps..................
blockmap-17-8W5-920-890-D
;SW:8W5-920-890-D   HW:8W5-920-890-D ---  Instruments
;Component:FBenUSA       H18 0373, Coding:09E651C12888CF050223E9601800000008000000
;EV_DashBoardAU736,001027,EV_DashBoardAU736_AU49.rod
;Sunday,10,November,2019,20:19:20:01617
;VCID: C4CB4F564F9D0E6F43-8090
Group,Description,Actual
IDE00019,Voltage terminal 30,13.10, V
IDE00021,Engine speed,801, /min
IDE00025,Coolant temperature,90.00, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00191,Charge air pressure: actual value,0.00, %
IDE00196,Engine oil temperature,90, °C
IDE00301,Distance,32501, km
IDE00310,Outside air temperature,27.00, °C
IDE00316-IDE00500,Time-Hour,20, H
IDE00316-IDE00501,Time-Minute,19, min
IDE00316-MAS00111,Time-Seconds,21, s
IDE00317-IDE00502,Date-Year,2019, yr
IDE00317-IDE00503,Date-Month,11, mon
IDE00317-IDE00504,Date-Day,10, d
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00510,ESI: distance driven from inspection,2700, km
IDE00511,ESI: time from inspection,31, d
IDE00512,ESI: minimum value km-driving distance/inspection,14500, km
IDE00513,ESI: maximum value km-driving distance/inspection,14500, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,5300, km
IDE00520,Phototransistor,2,
IDE00695,ESI: service exceedance in km,Not available,
IDE00696,ESI: service exceedance in days,Not available,
IDE00697,ESI: remaining distance,13220, km
IDE00698,ESI: remaining running time,334, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,618, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,1990, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2046, mm
IDE00935,ESI: Theoretical service interval,26300, km
IDE01076,Time since ignition off,4663, s
IDE01153,SIA: maximum value of distance to service,16000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01285,Counter of component protection malfunctions,0,
IDE01985-ENG101043,FAZIT identification test sum-Checksum,0D 31 AF 2C,
IDE01985-ENG99027,FAZIT identification test sum-Version,81,
IDE02642,Outside temp.: displayed value,25.50, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,3A,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,3A,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,3A,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,2,
IDE03349,FIX: Max. distance until next mileage-related inspection,32032, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,17100, km
IDE03352,FIX: Time since last time-dependent inspection,213, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-ENG126401,Vehicle configuration-intelligent_park_assist,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,43.30, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,58.00, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,61.00, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,43.40, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,49.00, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,58.00, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,57.80, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,48.10, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,16.50, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,58.00, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,61.40, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,17.30, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,38.00, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,58.00, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,60.50, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,37.70, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,32250, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,32170, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,32070, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,31720, km
IDE03474-IDE00304,Calculated volume-Fuel level,33.70, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,63, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,267, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,not_available,
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,not_available,
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,33.20, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,1.00, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,not_available,
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,not_available,
IDE03474-IDE00802,Calculated volume-Full volume,58.00, l
IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,34.20, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,1.00, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,not_available,
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,not_available,
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.00,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.00,
IDE03474-ENG102894,Calculated volume-averaged_volume,34.20, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,34.20, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,34.20, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,1.00,
IDE03474-ENG99553,Calculated volume-linking,0.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.16, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,35.10, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.00,
IDE03474-ENG99683,Calculated volume-version_of_application,12,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0008316,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03475-MAS12387,Control button in instrument cluster-Button for daily distance driven,not active,
IDE03477-IDE00500,GPS time-Hour,20, H
IDE03477-IDE00500,GPS time-Hour,19, H
IDE03477-IDE00501,GPS time-Minute,50, min
IDE03477-IDE00501,GPS time-Minute,19, min
IDE03477-IDE00502,GPS time-Year,2019, yr
IDE03477-IDE00503,GPS time-Month,11, mon
IDE03477-IDE00504,GPS time-Day,10, d
IDE03477-MAS00111,GPS time-Seconds,31, s
IDE03477-MAS00111,GPS time-Seconds,16, s
IDE03477-MAS03493,GPS time-last synchronization year,2019, yr
IDE03506,Distance: high resolution,01 EF ED 6B,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 AD,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0F,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0F,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 AD,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,6F F0 00 AD,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,2F F0 00 0F,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,4F F0 01 95,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,0F F0 3C 1F,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,8F F0 3C 1F,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,CF F0 01 95,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,6F F0 02 4B,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,2F F0 74 12,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04649-ENG128738,Activation for housing fan-PWM_FAN,0, %
IDE04649-ENG128737,Activation for housing fan-source_max_PWM_requested,none,
IDE04649-ENG98933,Activation for housing fan-Status,OFF,
IDE04649-ENG128733,Activation for housing fan-temperature_Boost,50, °C
IDE04649-ENG128734,Activation for housing fan-temperature_chipled,49, °C
IDE04649-ENG128736,Activation for housing fan-temperature_GPU,56, °C
IDE04649-ENG128735,Activation for housing fan-temperature_KI,50, °C
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,1095, d
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-IDE06026,Roller test bench mode: functional-Adaptation of brake pedal path sensor,not activated,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06924,Performance display,0,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE07578-MAS00138,Operating range consumption with electric drive-1,0.00,
IDE07578-MAS00139,Operating range consumption with electric drive-2,65534,
IDE07578-ENG04221,Operating range consumption with electric drive-ERW_Energieinhalt,0.00,
IDE07578-ENG114651,Operating range consumption with electric drive-s_erw_rw_batterie,65534, km
IDE07578-ENG114652,Operating range consumption with electric drive-s_erw_rw_batterie_anz,65534, km
IDE07578-ENG114648,Operating range consumption with electric drive-s_erw_rwds,0.00, A
IDE07578-ENG114640,Operating range consumption with electric drive-s_erw_rwds_high,10.00, A
IDE07578-ENG114644,Operating range consumption with electric drive-s_erw_rwds_low,10.00, A
IDE07578-ENG114637,Operating range consumption with electric drive-s_erw_rwdv_antrieb_high_unclass,2.50, kWh/100 km
IDE07578-ENG114641,Operating range consumption with electric drive-s_erw_rwdv_antrieb_low_unclass,25.00,
IDE07578-ENG114645,Operating range consumption with electric drive-s_erw_rwdv_antrieb_unclass,0.00,
IDE07578-ENG114638,Operating range consumption with electric drive-s_erw_rwdv_dcdc_high_unclass,0.20, kWh/100 km
IDE07578-ENG114642,Operating range consumption with electric drive-s_erw_rwdv_dcdc_low_unclass,0.20,
IDE07578-ENG114646,Operating range consumption with electric drive-s_erw_rwdv_dcdc_unclass,0.00,
IDE07578-ENG114639,Operating range consumption with electric drive-s_erw_rwdv_tme_high_unclass,0.50,
IDE07578-ENG114643,Operating range consumption with electric drive-s_erw_rwdv_tme_low_unclass,0.50,
IDE07578-ENG114647,Operating range consumption with electric drive-s_erw_rwdv_tme_unclass,0.00,
IDE07578-ENG114649,Operating range consumption with electric drive-s_erw_rwdv_unclass,0.00,
IDE07646-ENG114675,Consumption for road-specif. range with electric drive-s_erw_endsteigung,0.00, %
IDE07646-ENG114667,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_0,0.00, kWh/100 km
IDE07646-ENG114668,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_1,0.00, kWh/100 km
IDE07646-ENG114669,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_2,0.00, kWh/100 km
IDE07646-ENG114670,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_3,0.00, kWh/100 km
IDE07646-ENG114671,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_4,0.00, kWh/100 km
IDE07646-ENG114672,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_5,0.00, kWh/100 km
IDE07646-ENG114673,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_6,0.00, kWh/100 km
IDE07646-ENG114653,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_0,25.00, kWh/100 km
IDE07646-ENG114654,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_1,25.00, kWh/100 km
IDE07646-ENG114655,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_2,25.00, kWh/100 km
IDE07646-ENG114656,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_3,25.00, kWh/100 km
IDE07646-ENG114657,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_4,25.00, kWh/100 km
IDE07646-ENG114658,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_5,25.00, kWh/100 km
IDE07646-ENG114659,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_6,25.00, kWh/100 km
IDE07646-ENG04222,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_low_class,25.00, kWh/100 km
IDE07646-ENG114674,Consumption for road-specif. range with electric drive-s_erw_str_klasse,0,
IDE08343,Immobilizer Challenge,C6 E5 49 B4,
IDE08701-MAS07266,ESI: Status-Oil change: unit of dist. travelled,miles,
IDE08701-MAS07267,ESI: Status-Oil change: dist. travelled,8300,
IDE08701-MAS07268,ESI: Status-Oil change: stat. of dist. travelled,Service in,
IDE08701-MAS07269,ESI: Status-Oil change: stat. of time,Service in,
IDE08701-MAS07270,ESI: Status-Inspection: stat. of dist. travelled,Service in,
IDE08701-MAS07271,ESI: Status-Inspection: unit of dist. travelled,miles,
IDE08701-MAS07272,ESI: Status-Inspection: dist. travelled,9300,
IDE08701-MAS07273,ESI: Status-Inspection: time,517,
IDE08701-MAS07274,ESI: Status-Oil change warning,no warning,
IDE08701-MAS07277,ESI: Status-Inspections warning,no warning,
IDE08701-MAS07305,ESI: Status-Oil change: time,334,
IDE08701-MAS07308,ESI: Status-Inspection: status time,Service in,
IDE08701-MAS10768,ESI: Status-Daily mileage,80,
IDE08775-MAS01390,Active driver info.-Block 1,DF 00 A4 44,
IDE08775-MAS01391,Active driver info.-Block 2,A2 1F 00 00,
IDE08775-MAS01392,Active driver info.-Block 3,00 00 00 00,
IDE08775-MAS01393,Active driver info.-Block 4,00 00 00 00,
IDE08775-MAS01394,Active driver info.-Block 5,00 00 00 00,
IDE08775-MAS01395,Active driver info.-Block 6,00 00 00 00,
IDE08775-MAS01396,Active driver info.-Block 7,00 00 00 00,
IDE08775-MAS01397,Active driver info.-Block 8,00 00 00 00,
IDE08775-MAS01398,Active driver info.-Block 9,00 00 00 00,
IDE08775-MAS01399,Active driver info.-Block 10,00 00 00 00,
IDE08775-MAS01400,Active driver info.-Block 11,00 00 00 00,
IDE08775-MAS01401,Active driver info.-Block 12,00 00 00 00,
IDE08775-MAS01402,Active driver info.-Block 13,00 00 00 00,
IDE08775-MAS01403,Active driver info.-Block 14,00 00 00 00,
IDE08775-MAS01404,Active driver info.-Block 15,00 00 00 00,
IDE08775-MAS01405,Active driver info.-Block 16,00 00 00 00,
IDE08775-MAS01406,Active driver info.-Block 17,00 00 00 00,
IDE08775-MAS01407,Active driver info.-Block 18,00 00 00 00,
IDE08775-MAS01408,Active driver info.-Block 19,00 00 00 00,
IDE08775-MAS01409,Active driver info.-Block 20,00 00 00 00,
IDE08776-MAS01390,Key-relevant driver information-Block 1,A4 44 00 00,
IDE08776-MAS01391,Key-relevant driver information-Block 2,00 00 00 00,
IDE08776-MAS01392,Key-relevant driver information-Block 3,00 00 00 00,
IDE08776-MAS01393,Key-relevant driver information-Block 4,00 00 00 00,
IDE08776-MAS01394,Key-relevant driver information-Block 5,00 00 00 00,
IDE08776-MAS01395,Key-relevant driver information-Block 6,00 00 00 00,
IDE08776-MAS01396,Key-relevant driver information-Block 7,00 00 00 00,
IDE08776-MAS01397,Key-relevant driver information-Block 8,00 00 00 00,
IDE08776-MAS01398,Key-relevant driver information-Block 9,00 00 00 00,
IDE08776-MAS01399,Key-relevant driver information-Block 10,00 00 00 00,
IDE08777-MAS00106,History memory: driver info.-Year,2019,
IDE08777-MAS00107,History memory: driver info.-Month,11,
IDE08777-MAS00108,History memory: driver info.-Day,10,
IDE08777-MAS00109,History memory: driver info.-Hours,19,
IDE08777-MAS00110,History memory: driver info.-Minutes,50,
IDE08777-MAS00111,History memory: driver info.-Seconds,25,
IDE08777-MAS01390,History memory: driver info.-Block 1,A2 1F,
IDE10117-MAS11870,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 1,33.20, l
IDE10117-MAS11871,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 2,1.00, l
IDE10117-MAS11872,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 3,not_available,
IDE10117-MAS11873,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 4,not_available,
IDE10347-ENG118215,Trip distance challenge-Challenge,32 00 00 00 00 37 DE C9 8E 00 17 01 00 00 00 57 41 55 45 4E 41 46 34 37 4A 41 31 34 37 38 39 38 BC 13 44 04 B1 46 76 1F 00 00,
IDE10348-ENG98502,Trip distance data-Data,32 00 00 00 00 00 00 00 00 00 17 01 00 00 00 57 41 55 45 4E 41 46 34 37 4A 41 31 34 37 38 39 38 A4 7D EB 94 C4 DD BE 2C 00 14 00 03 00 F5 7E 00 F6 7E 00 00 00 00 00 00 00 00 00 00 00 00,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG126262-ENG114675,Consumption_for_distance_on_map-s_erw_endsteigung,0.00, %
ENG126262-ENG114674,Consumption_for_distance_on_map-s_erw_str_klasse,0,
ENG126262-ENG128739,Consumption_for_distance_on_map-s_vkmrw_rwdv_antrieb_low_class,7.20, l/100km
ENG126262-ENG126309,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_0,7.30, l/100km
ENG126262-ENG126310,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_1,9.80, l/100km
ENG126262-ENG126311,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_2,9.80, l/100km
ENG126262-ENG126312,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_3,9.80, l/100km
ENG126262-ENG126313,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_4,9.80, l/100km
ENG126262-ENG126314,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_5,9.80, l/100km
ENG126262-ENG126315,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_6,9.80, l/100km
ENG126262-ENG126302,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_0,7.30, l/100km
ENG126262-ENG126303,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_1,10.00, l/100km
ENG126262-ENG126304,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_2,10.00, l/100km
ENG126262-ENG126305,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_3,10.00, l/100km
ENG126262-ENG126306,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_4,10.00, l/100km
ENG126262-ENG126307,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_5,10.00, l/100km
ENG126262-ENG126308,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_6,10.00, l/100km
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,88, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,17, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,7, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,7, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,7, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,80, km
ENG107920-ENG98868,onboard_computer-Range,406, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,7.50, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,0.00, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,0.00, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,0.00, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,7.50, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,7.00, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,0.00, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,0.00, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,0.00, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,65534, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,65534, km
ENG107920-ENG119791,onboard_computer-range_display_value,406, km
ENG107920-ENG126299,onboard_computer-range_lpg,65534, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,65534, km
ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,151,
ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
ENG109340-ENG104056,tank_validation-s_vali_abs_active,not active,
ENG109340-ENG102652,tank_validation-s_vali_abs_display_0,not active,
ENG109340-ENG102994,tank_validation-s_vali_abs_distance/mileage,not active,
ENG109340-ENG101149,tank_validation-s_vali_abs_rough,not active,
ENG109340-ENG101740,tank_validation-s_vali_active,not active,
ENG109340-ENG101355,tank_validation-s_vali_consumption_deq,3276.80, l
ENG109340-ENG100596,tank_validation-s_vali_consumption_deq_abs,3276.80, l
ENG109340-ENG102770,tank_validation-s_vali_display_0,not active,
ENG109340-ENG99133,tank_validation-s_vali_needle_vol_ref,not active,
ENG109340-ENG99562,tank_validation-s_vali_rough,not active,
ENG109340-ENG100160,tank_validation-s_vali_status,2, l
ENG109340-ENG103691,tank_validation-s_vali_vol_delta_gef,3276.80, l
ENG109340-ENG100615,tank_validation-s_vali_vol_delta_roh,3277.00, l
ENG109340-ENG99506,tank_validation-s_vali_vol_g1_vg,3310.00, l
ENG109340-ENG103928,tank_validation-s_vali_vol_g2_vg,3277.80, l
ENG109340-ENG101476,tank_validation-s_vali_vol_g3_vg,3276.80, l
ENG109340-ENG101237,tank_validation-s_vali_vol_g4_vg,3276.80, l
ENG109340-ENG101103,tank_validation-s_vali_vol_ref_gew,3310.80, l
ENG109340-ENG100543,tank_validation-s_vali_vol_ref_vg,3316.10, l
ENG109340-ENG100079,tank_validation-s_vali_vol_total_vg,3311.00, l
Elapsed Time: 00:29
adpmap-17-8W5-920-890-D
;Sunday,10,November,2019,20:19:49:01617
IDE00001-Production mode,not active ,3
IDE00301-Distance,32501 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,US English ,1
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,20 H,1
IDE00501-Minute,19 min,1
IDE00502-Year,2019 yr,2
IDE00503-Month,11 mon,1
IDE00504-Day,10 d,1
IDE00510-ESI: distance driven from inspection,2700 km,3
IDE00511-ESI: time from inspection,31 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,14500 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,14500 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,5300 km,2
IDE00819-Day counter,618 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,16000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,0.00 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-1.00 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,0.00 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5
IDE03329-Driving profiled for range remaining,7.50 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,miles ,3
IDE03346-MAS01230-Units adjusted-Date,yy_mm_dd ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,°F ,3
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03348-Speed warning-,not active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,32032 km,3
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,17100 km,3
IDE03352-FIX: Time since last time-dependent inspection,213 d,2
IDE03372-Source for synchronization of time,GPS ,1
IDE03867-Deactivate seat belt warning,No ,1
IDE04169-Display correction of consumption and operating range: gas,100 %,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,1095 d,2
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,No display ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE07221-Cylinder shut-off,No display ,1
IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage,10.00 A,8
IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive,25 ,8
IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer,0.20 ,8
IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer,0.50 ,8
IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0,25.00 ,14
IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1,25.00 ,14
IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2,25.00 ,14
IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3,25.00 ,14
IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4,25.00 ,14
IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5,25.00 ,14
IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6,25.00 ,14
IDE08140-Driving profiled for range remaining CNG,0.00 kg/100 km,2
IDE08247-Driving profile for range remaining LPG,0.00 l/100km,2
IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
IDE10693-Initialize sensor for fuel level,No ,1
IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,7.30 l/100km,14
IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 l/100km,14
IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 l/100km,14
IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 l/100km,14
IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 l/100km,14
IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 l/100km,14
IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 l/100km,14
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE12050-Acoustic: drive position R,active ,1
MAS03555-Lap counter,No display ,1
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,21
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,21
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,21
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,21
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,21
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,21
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,21
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,500ms ,21
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,50ms ,21
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,50ms ,21
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,21
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,21
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,21
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,21
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,100ms ,21
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,21
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,21
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,21
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,21
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,21
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,21
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,21
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,21
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,21
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,21
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,21
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,21
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,21
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,21
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,21
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,21
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,21
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,21
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,21
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,21
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,500ms ,21
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,500ms ,21
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,21
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,100ms ,21
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,100ms ,21
ENG128731-MAS01129-designvariant_activation-Version 1,not active ,2
ENG128731-MAS01130-designvariant_activation-Version 2,not active ,2
ENG128731-MAS01131-designvariant_activation-Version 3,not active ,2
ENG128731-MAS03101-designvariant_activation-Version 4,not active ,2
ENG128731-MAS03102-designvariant_activation-Version 5,not active ,2
ENG128731-MAS03103-designvariant_activation-Version 6,not active ,2
ENG128731-MAS03104-designvariant_activation-Version 7,not active ,2
ENG128731-MAS03105-designvariant_activation-Version 8,not active ,2
ENG99320-Developers_menu,not active ,1
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00 ,12
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC ,12
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,50 ,12
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64 ,12
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,02 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,02 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64 ,12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00 ,12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64 ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,14 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,1E ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,32 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,46 ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,64 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,00 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,14 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,1E ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,32 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,46 ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,02 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,02 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,06 ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,0A ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,50 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00 ,20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32 ,20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64 ,20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4 ,20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD ,20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,50 ,12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s,16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h,16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min,16
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 °C,16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
ENG126283-parameter_hmi,41 43 56 03 05 FF 1E 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
ENG135292-phev_stat_intervall-,5.00 ,3
ENG135292-phev_stat_intervall-,100 m,3
ENG135292-phev_stat_intervall-,0 min,3
ENG119825-Picture_Upload_Download,not active ,1
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.50 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,1.40 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,active ,4
Elapsed Time: 00:26
blockmap-19-8W6-907-468-F
;SW:8W6-907-468-F   HW:8W6-907-468-E ---  CAN Gateway
;Component:Gateway       H43 0123, Coding:030100010000064029070000005900124C180007100000000175078E10000000
;EV_CGateCONTIAU491,003111,EV_CGateCONTIAU491_003_AU49.rod
;Sunday,10,November,2019,20:20:19:01617
;VCID: CDDD6A729CD7CF279C-8098
IDE00009,Date of manufacture,18 02 22,
IDE00010,Serial number,0287B774018222,
IDE00019,Voltage terminal 30,13.20, V
IDE00020-MAS00044,Terminal 15 status-Supply voltage: Terminal 15,13.20, V
IDE00020-MAS03680,Terminal 15 status-Terminal 15 status measured,On,
IDE00020-MAS05562,Terminal 15 status-Terminal 15 resulting,On,
IDE00020-MAS07720,Terminal 15 status-Terminal 15 via CAN,On,
IDE00020-MAS08946,Terminal 15 status-Terminal 15 via comparator,On,
IDE00056,History data 1,000*2019-01-24-15:13*00.2*01**,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00**,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00*00000**,
IDE00056,History data 1,000*2019-01-24-21:33*03.9*01*00165**,
IDE00056,History data 1,000*2019-01-24-12:33*01.0*01**,
IDE00056,History data 1,000*2019-01-23-20:19*05.6*01**,
IDE00056,History data 1,000*2019-01-24-14:19*00.1*01**,
IDE00056,History data 1,000*2019-01-24-16:52*01.7*01**,
IDE00057,History data 2,134*2019-03-08-19:24*0001.0*051*00101*0000*01**,
IDE00057,History data 2,172*2019-11-01-09:58*0001.1*051*00236*0000*01*00049**,
IDE00057,History data 2,134*2019-03-08-15:15*0001.0*052*00099*0000*01**,
IDE00057,History data 2,134*2019-03-07-18:25*0001.0*054*00114*0000*01**,
IDE00057,History data 2,066*2019-10-18-19:25*0001.0*047*00124*0000*01**,
IDE00057,History data 2,172*2019-11-01-07:35*0002.2*049*00223*0000*01**,
IDE00057,History data 2,184*2019-03-14-02:38*0002.0*055*00099*0000*01**,
IDE00057,History data 2,017*2018-12-25-02:51*0004.0*052*00237*0000*01**,
IDE00057,History data 2,166*2018-12-10-07:53*0003.0*054*00119*0000*01**,
IDE00057,History data 2,017*2018-12-25-06:53*0001.7*055*00267*0000*01**,
IDE00058,History data 3,027*2018-08-06-08:40*T*0*0*061*043*0000*0*00.0*00.0**,
IDE00058,History data 3,032*2018-08-22-08:49*T*0*0*090*069*0000*0*00.0*00.0**,
IDE00058,History data 3,030*2018-08-09-11:32*T*0*0*099*076*0000*0*00.0*00.0**,
IDE00058,History data 3,028*2018-08-07-11:45*T*0*0*089*067*0010*0*00.0*00.0**,
IDE00058,History data 3,031*2018-08-13-12:09*T*0*0*095*072*0010*0*00.0*00.0**,
IDE00058,History data 3,033*2018-08-22-13:06*T*0*0*085*065*0010*0*00.0*00.0**,
IDE00058,History data 3,029*2018-08-09-11:32*T*0*0*099*076*0000*0*00.0*00.0**,
IDE00059,History data 4,000*2000-01-01-00:00*00*000*00*000*0000000000*00000*00000*000.0*000.0*000.0**,
IDE00059,History data 4,009*2018-03-02-04:50*01*075*01*JCB*280225P0F4*10008*04247*000.0*000.0*000.0**,
IDE00060,History data 5,000*2000-01-01-00:00*0*000000*0000*00.0*000*00*-00.0*00000*00000*0000*00000000*000*00.0*00.0*0000.0**,
IDE00061,History data 6,008*2019-11-10-18:26*049*+26*+000.1*0000*00*00.01**,
IDE00061,History data 6,000*2019-11-09-17:02*053*+30*+001.1*0000*00*00.40**,
IDE00061,History data 6,002*2019-11-10-12:55*049*+23*+000.1*0000*00*00.01**,
IDE00061,History data 6,004*2019-11-10-17:31*049*+25*+001.1*0000*00*00.43**,
IDE00061,History data 6,003*2019-11-10-16:15*048*+25*+000.2*0000*00*00.01**,
IDE00061,History data 6,252*2019-11-08-23:06*046*+34*+000.9*0000*00*00.03**,
IDE00061,History data 6,005*2019-11-10-18:16*049*+26*+000.2*0000*00*00.11**,
IDE00061,History data 6,005*2019-11-10-17:57*049*+26*+000.4*0000*00*00.30**,
IDE00061,History data 6,254*2019-11-09-11:02*054*+29*+001.6*0032*02*00.83**,
IDE00061,History data 6,009*2019-11-10-18:28*049*+26*+000.0*0000*00*00.06**,
IDE00061,History data 6,252*2019-11-09-10:55*049*+29*+000.1*0079*01*00.11**,
IDE00061,History data 6,249*2019-11-08-22:47*047*+34*-000.1*0095*02*00.08**,
IDE00061,History data 6,006*2019-11-10-18:24*049*+26*+000.0*0000*00*00.03**,
IDE00061,History data 6,254*2019-11-09-12:10*054*+29*+001.2*0002*01*02.41**,
IDE00061,History data 6,001*2019-11-09-19:29*051*+29*+000.6*0000*00*00.31**,
IDE00062,History data 7,003*2019-11-10-16:16*048*-000.5*00.0*00.0*0001.2**,
IDE00062,History data 7,250*2019-11-08-22:54*046*-000.5*00.0*00.0*0000.1**,
IDE00062,History data 7,247*2019-11-08-19:39*046*-000.7*00.0*00.0*0002.3**,
IDE00062,History data 7,254*2019-11-09-11:53*052*-000.9*00.0*00.0*0000.2**,
IDE00062,History data 7,251*2019-11-08-23:05*046*-000.2*00.0*00.0*0000.0**,
IDE00062,History data 7,009*2019-11-10-18:32*050*-000.6*00.0*00.0*0001.2**,
IDE00062,History data 7,002*2019-11-10-12:57*049*-000.5*00.0*00.0*0003.1**,
IDE00062,History data 7,000*2019-11-09-17:27*051*-000.7*00.0*00.0*0001.9**,
IDE00062,History data 7,007*2019-11-10-18:26*049*-000.1*00.0*00.0*0000.0**,
IDE00062,History data 7,255*2019-11-09-14:36*053*-001.2*00.0*00.0*0002.3**,
IDE00062,History data 7,252*2019-11-08-23:09*052*-001.5*00.0*00.0*0010.4**,
IDE00062,History data 7,001*2019-11-09-19:49*049*-001.8*00.0*00.0*0016.6**,
IDE00062,History data 7,249*2019-11-08-22:52*047*-000.3*00.0*00.0*0000.0**,
IDE00062,History data 7,248*2019-11-08-22:46*046*-000.2*00.0*00.0*0000.0**,
IDE00062,History data 7,246*2019-11-08-19:30*045*-000.5*00.0*00.0*0000.0**,
IDE00063,History data 8,000*2018-08-06-08:45*1*+37.1*13.2*061*+29**,
IDE00063,History data 8,026*2018-03-01-22:44*1*+09.8*13.9*097*+22**,
IDE00063,History data 8,000*2018-08-06-09:17*1*+28.5*13.4*062*+30*12*00*00*05*00*00*000*000*00**,
IDE00063,History data 8,000*2018-03-02-00:05*1*+06.2*14.2*097*+23**,
IDE00063,History data 8,000*2018-08-06-09:12*1*+35.3*13.3*061*+29**,
IDE00063,History data 8,000*2018-03-01-23:59*1*+11.5*14.0*096*+22**,
IDE00064,History data 9,000*2019-07-17-07:51*086*089*075*051*02961*03.6*+29*09.5*02.9*00348*01770**,
IDE00064,History data 9,000*2019-01-13-05:22*085*093*053*033*01269*03.6*+21*09.2*03.0*00214*01077**,
IDE00064,History data 9,162*2019-08-16-23:26*087*090*078*054*03357*03.4*+34*09.6*03.0*00371*01886**,
IDE00064,History data 9,000*2019-05-16-18:39*090*091*070*050*02344*03.2*+31*09.6*03.0*00318*01616**,
IDE00064,History data 9,000*2019-06-16-08:11*086*090*084*059*02603*03.2*+28*09.8*03.0*00329*01684**,
IDE00064,History data 9,000*2018-12-13-11:20*082*091*077*050*00979*03.2*+26*09.9*02.8*00160*00800**,
IDE00064,History data 9,000*2019-02-12-22:32*092*094*073*055*01470*03.0*+27*09.7*02.9*00240*01201**,
IDE00064,History data 9,000*2019-04-15-17:20*087*092*068*046*02154*03.4*+29*09.7*03.0*00314*01595**,
IDE00064,History data 9,094*2019-09-16-13:35*082*086*075*052*03664*03.4*+38*09.4*02.9*00411*02068**,
IDE00064,History data 9,000*2000-01-01-00:00*000*000*000*000*00000*00.0*+00*02.0*00.0*00000*00000**,
IDE00064,History data 9,196*2019-03-15-15:50*092*093*074*055*01770*03.4*+26*09.6*02.9*00253*01282**,
IDE00064,History data 9,000*2019-10-17-11:56*084*088*074*049*03996*03.4*+30*09.6*03.0*00460*02335**,
IDE00065,History data 10,000*2000-01-01-00:00*00**,
IDE00065,History data 10,245*2019-10-02-20:22*2*079*051*+29*03*30*-28*10.8*6*00000*00027*00000**,
IDE00065,History data 10,243*2019-07-22-02:43*80*00000*00000*00000*00010*00000*00000*00000*00039**,
IDE00065,History data 10,000*2000-01-01-00:00*00*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00065,History data 10,243*2019-07-22-02:43*2*064*048*+38*03*30*-27*11.9*6**,
IDE00065,History data 10,116*2019-07-06-21:24*2*074*051*+30*03*30*-64*11.9*6**,
IDE00065,History data 10,230*2019-07-21-17:14*88**,
IDE00065,History data 10,070*2019-07-30-19:01*2*074*051*+38*03*30*-28*11.6*6**,
IDE00065,History data 10,213*2019-07-20-22:22*2*067*047*+41*03*30*-28*11.1*6**,
IDE00065,History data 10,233*2019-07-21-17:24*88**,
IDE00065,History data 10,233*2019-07-21-17:23*88**,
IDE00065,History data 10,243*2019-07-22-02:43*80**,
IDE00065,History data 10,220*2019-07-21-01:43*80**,
IDE00066,History data 11,009*2019-11-10-18:28*000*000*000*000*0000*004*00.1*00.1*077*049*077*049*00*00679*00789*01742*03407*00000**,
IDE00066,History data 11,004*2019-11-10-17:31*000*000*000*000*0000*026*00.2*01.3*076*048*076*049*00**,
IDE00066,History data 11,005*2019-11-10-18:16*000*000*000*000*0000*007*00.1*00.3*077*049*077*049*00**,
IDE00066,History data 11,006*2019-11-10-18:24*000*000*000*000*0000*002*00.1*00.1*077*049*077*049*00**,
IDE00066,History data 11,008*2019-11-10-18:26*000*000*000*000*0000*001*00.1*00.2*077*049*077*049*00**,
IDE00066,History data 11,005*2019-11-10-17:57*000*000*000*000*0000*018*00.1*00.5*076*049*077*049*00**,
IDE00067,History data 12,091*2019-10-21-15:13*0002*24*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,105*2019-09-18-10:12*0002*23*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,166*2019-10-31-10:53*0002*25*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,228*2019-08-30-08:16*0002*22*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,145*2019-08-07-23:47*0002*21*00*0000*00*00*0000*00*00**,
IDE00068,History data 13,254*2019-11-09-11:21*2*00.30*000*255*000*000*000*000*032**,
IDE00068,History data 13,254*2019-11-09-11:15*2*00.20*000*255*000*000*000*000*032**,
IDE00068,History data 13,253*2019-11-09-11:01*2*00.10*000*255*000*000*000*000*032**,
IDE00068,History data 13,255*2019-11-09-12:16*2*00.00*000*255*000*000*000*000*032**,
IDE00068,History data 13,249*2019-11-08-22:51*2*00.00*000*255*000*000*000*000*032**,
IDE00069,History data 14,000*2000-01-01-00:00*0*00.00*000*000*000*000*000*000*000**,
IDE00070,History data 15,000*2000-01-01-00:00*0*000*00.00*000*000*000**,
IDE00071,History data 16,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE00102,Control Module temperature,50, °C
IDE00322,Status of basic setting,was not yet started,
IDE00667,Microphone status,Electrical OK,
IDE00668,Microphone current consumption,6.10, mA
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button,Not available,
IDE00725,Manufacturer's test stand number,0032,
IDE00726,Subassembly and series number,0240,
IDE00767-ENG05080,No. of unscheduled ECU resets-KL30_Reset_Counter,6,
IDE00767-ENG05081,No. of unscheduled ECU resets-Last_Main_Controller_Reset_Reason,00 04,
IDE00767-ENG05078,No. of unscheduled ECU resets-Last_WD_Reset_Reason,00,
IDE00767-ENG05082,No. of unscheduled ECU resets-Main_Controller_Reset_Counter,1,
IDE00767-ENG05079,No. of unscheduled ECU resets-Wd_Reset_Counter,0,
IDE00767-ENG33384,No. of unscheduled ECU resets-Z0_Reset_Counter,0,
IDE01215,Terminal 58d dimmer,23.03, %
IDE01285,Counter of component protection malfunctions,00 00,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,-81709794,
IDE01712-MAS01780,GPS Position-Width,26245484,
IDE01712-MAS02230,GPS Position-Height,-10, m
IDE01713-MAS01632,Status GPS reception-Status,Not available,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,0,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,0,
IDE01715,Status terminal S,On,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,0, mA
IDE01803,History data 17,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE01804,History data 18,008*2019-11-10-18:26*1*001*00.01*000400*999*999*999**,
IDE01804,History data 18,005*2019-11-10-17:57*1*018*00.30*000400*999*999*999**,
IDE01804,History data 18,009*2019-11-10-18:28*1*004*00.06*000400*999*999*999**,
IDE01804,History data 18,007*2019-11-10-18:24*1*002*00.03*000400*999*999*999**,
IDE01804,History data 18,006*2019-11-10-18:16*1*007*00.11*000400*999*999*999**,
IDE01805,History data 19,000*2000-01-01-00:00*0000*0000.0*0000.0*0000.0*0000*00000000*000*000*000**,
IDE01805,History data 19,008*2018-03-02-00:57*0013*0001.9*0000.6*0000.7*0180*0103003D*000*000*002**,
IDE01805,History data 19,028*2018-03-01-23:18*0012*0031.5*0000.3*0030.3*0080*0103003D*000*000*001**,
IDE01806,History data 20,000*2000-01-01-00:00*0000*000*000*+0000000*+0000000**,
IDE01806,History data 20,034*2018-08-22-14:50*3938*057*073*-55D4A80*-ABA9500**,
IDE01807,History data 21,01318*05865*00190*00301**,
IDE01807,History data 21,01212*00298*00183**,
IDE01807,History data 21,00000*00000*00000*00000*00000**,
IDE01807,History data 21,00121*00006*00001**,
IDE01807,History data 21,032501**,
IDE01807,History data 21,02566*00028*00004*00003**,
IDE01807,History data 21,00034*00301*02233*00030*00005**,
IDE01807,History data 21,00015*00009*00009*00215**,
IDE01807,History data 21,00701*00354*00265*00186*00176*00129*00247*00155*00111*00241*00000**,
IDE01807,History data 21,01264*00725*00509**,
IDE01807,History data 21,00000*00000*00000*00000**,
IDE01807,History data 21,00707*00750*00325*00716**,
IDE01807,History data 21,00000*00000*00000**,
IDE01807,History data 21,,
IDE01808,History data 22,004*2019-11-10-17:38*2*0*003*000*075*075*0*00732*00289**,
IDE01808,History data 22,211*2019-11-05-07:52*2*0*004*000*072*072*0**,
IDE01808,History data 22,227*2019-11-06-22:48*2*0*009*000*075*075*0**,
IDE01808,History data 22,220*2019-11-05-13:44*2*0*003*000*071*070*0**,
IDE01808,History data 22,235*2019-11-08-06:48*2*0*003*000*071*071*0**,
IDE01809,History data 23,000*2000-01-01-00:00*0*00000*00000**,
IDE01810,History data 24,000*2000-01-01-00:00*0*0000*0000*0000*00000*00000*00000**,
IDE01811,History data 25,001*2000-00-00-00:00*000.1*001*000*000**,
IDE01811,History data 25,000*2000-01-01-00:00*000.0*000*000*001*00000*000.0*000*000*000**,
IDE01811,History data 25,000*2000-00-00-01:01*000.0*000*000*000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000**,
IDE01812,History data 26,009*2018-03-02-04:50*0040*00000*00000*00000*00000*00000*00000*00001*00000*00000*00000*00000*00000**,
IDE01816,History data 30,000*2000-00-00-00:00*0*0*0*0*0*000.00*000.00*-40**,
IDE01817,History data 31,,
IDE01817,History data 31,Nur für BEV                                             ,
IDE01817,History data 31,                                             ,
IDE01818,History data 32,000*2000-00-00-00:00*0*000*000*00.0*00.0*000*000*00.0*00.0*00000**,
IDE01819,History data 33,000*2000-00-00-00:00*0*000*000*000*000*00000*00000**,
IDE01820,History data 34,000*2000-00-00-00:00*0*0*000*000.0*00.0*00.0*000.0*00.0**,
IDE01821,History data 35,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01822,History data 36,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01823,History data 37,*0*0*0*0**000*2000-01-01-00:00*0*0*0*0*0,
IDE01823,History data 37,0*2000-01-01-00:00*0*0*0*0*0*0**,
IDE01823,History data 37,*0**000*2000-01-01-00:00*0*0*0*0*0*0**00,
IDE01823,History data 37,000*2000-01-01-00:00*0*0*0*0*0*0**000*20,
IDE01823,History data 37,01-00:00*0*0*0*0*0*0**000*2000-01-01-00:,
IDE01823,History data 37,00-01-01-00:00*0*0*0*0*0*0**000*2000-01-,
IDE01823,History data 37,00*0*0*0*0*0*0**000*2000-01-01-00:00*0*0,
IDE01823,History data 37,,
IDE01824,History data 38,000*2000-01-01-00:00*0*+000*000*0**,
IDE01825,History data 39,000*2019-11-10-17:29*000*001*000**,
IDE01825,History data 39,,
IDE01825,History data 39,000*2019-11-10-12:55*000*001*000**,
IDE01825,History data 39,000*2019-11-10-16:14*000*001*000**,
IDE01825,History data 39,000*2019-11-10-07:34*000*001*000**,
IDE01825,History data 39,000*2019-11-10-11:39*000*001*000**,
IDE01825,History data 39,000*2019-11-10-14:44*000*001*000**,
IDE01825,History data 39,000*2019-11-10-19:49*000*001*000**,
IDE01825,History data 39,000*2019-11-10-09:30*000*001*000**,
IDE01826,History data 40,000*2000-01-01-00:00*0*0*0*0*0*000.00*000.00*-50**,
IDE01827,Generator specified voltage value,13.5, V
IDE01828,Generator DF Signal,41.950, %
IDE01829,Generator exciter current,1.65, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Denso,
IDE01831-MAS06310,Generator variant-Generator identifier,110A - 150A MOSFET,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,1,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01833-MAS06105,Battery variant-Rated battery capacity,75, Ah
IDE01833-MAS06106,Battery variant-Battery technology,Fleece,
IDE01833-MAS06107,Battery variant-Battery manufacturer,JCI,
IDE01834,Battery voltage,13.303, V
IDE01836,Battery current,0.835, A
IDE01837,Temperature of battery sensor,29, °C
IDE01838,Battery temperature,28, °C
IDE01839,Battery charge condition,77, %
IDE01841,Battery internal resistance,3.8, mOhm
IDE01842,Usable battery charge,51, Ah
IDE01843,Battery voltage at rest,12.5, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shutdown level,Deactivation stage 0,
IDE01847-MAS01577,Auxiliary heater activation restriction request-Parking heater,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Previous journey energy summary,0.80, Ah
IDE01849,Previous journey duration,0.50, H
IDE01850,Total energy summary,10009.10, Ah
IDE01851,Total energy throughput,4248.1, Ah
IDE01852,Static current measurement: result,13, mA
IDE01853,Static current measurement: status,Cancel,
IDE01854-MAS09891,Energy reclamation request-recuperation active,active,
IDE01854-MAS09892,Energy reclamation request-Charge contingent for feedback,2880, As
IDE01855,Generator current,40.7, A
IDE01864-MAS03179,Status of current bus communication-Local data bus 2,active: local wakeup event,
IDE01864-MAS03180,Status of current bus communication-Local data bus,active: local wakeup event,
IDE01864-MAS05972,Status of current bus communication-Local data bus 3,not installed,
IDE01864-MAS10445,Status of current bus communication-Data bus CAN 1,active: local wakeup event,
IDE01864-MAS10446,Status of current bus communication-Data bus CAN 2,not installed,
IDE01864-MAS10447,Status of current bus communication-Data bus CAN 3,active: local wakeup event,
IDE01864-MAS10448,Status of current bus communication-Data bus CAN 4,active: local wakeup event,
IDE01864-MAS10449,Status of current bus communication-Data bus CAN 5,active: local wakeup event,
IDE01864-MAS10450,Status of current bus communication-Data bus CAN 6,active: local wakeup event,
IDE01864-MAS11107,Status of current bus communication-Data bus CAN 7,not installed,
IDE01864-MAS11108,Status of current bus communication-FlexRay star 3,not installed,
IDE01864-MAS11244,Status of current bus communication-FlexRay star 1,active: local wakeup event,
IDE01864-MAS11245,Status of current bus communication-FlexRay star 2,not installed,
IDE01948,Battery internal resistance not normed,3.6, mOhm
IDE01971,Lowest recorded control module temperature,33, °C
IDE01972,Highest recorded control module temperature,50, °C
IDE01992-IDE14867,Installation list: current installations-Subgateway as firewall control module,Not available,
IDE01992-SFT00001,Installation list: current installations-Engine Control Module 1,Available,
IDE01992-SFT00002,Installation list: current installations-Transmission Control Module,Available,
IDE01992-SFT00006,Installation list: current installations-Seat Adjustment Passenger Side,Not available,
IDE01992-SFT00007,Installation list: current installations-Display Control Unit,Not available,
IDE01992-SFT00008,Installation list: current installations-Air Conditioning,Available,
IDE01992-SFT00009,Installation list: current installations-Central Electrics,Available,
IDE01992-SFT00012,Installation list: current installations-Rear Axle Steering 2,Not available,
IDE01992-SFT00017,Installation list: current installations-Engine Control Module 2,Not available,
IDE01992-SFT00019,Installation list: current installations-Adaptive Cruise Control,Not available,
IDE01992-SFT00022,Installation list: current installations-Steering Column Electronics,Available,
IDE01992-SFT00023,Installation list: current installations-Dash Board,Available,
IDE01992-SFT00024,Installation list: current installations-Auxiliary Parking Heater,Not available,
IDE01992-SFT00025,Installation list: current installations-Gateway,Available,
IDE01992-SFT00027,Installation list: current installations-Active Steering,Not available,
IDE01992-SFT00032,Installation list: current installations-High Beam Assistance,Not available,
IDE01992-SFT00033,Installation list: current installations-Battery Energy Control Module 2,Not available,
IDE01992-SFT00034,Installation list: current installations-All Wheel Control,Not available,
IDE01992-SFT00035,Installation list: current installations-Brake Boost,Not available,
IDE01992-SFT00038,Installation list: current installations-Electronic Roof Control,Not available,
IDE01992-SFT00039,Installation list: current installations-Display Control Unit Rear,Not available,
IDE01992-SFT00040,Installation list: current installations-Climate Control Unit Rear,Not available,
IDE01992-SFT00042,Installation list: current installations-Control Unit Wireless Charging,Not available,
IDE01992-SFT00043,Installation list: current installations-Steering Column Locking,Not available,
IDE01992-SFT00048,Installation list: current installations-Special Function 2,Not available,
IDE01992-SFT00050,Installation list: current installations-Lock Electronics,Not available,
IDE01992-SFT00054,Installation list: current installations-Seat Adjustment Driver Side,Available,
IDE01992-SFT00061,Installation list: current installations-Special Function,Not available,
IDE01992-SFT00066,Installation list: current installations-Door Electronics Driver Side,Available,
IDE01992-SFT00068,Installation list: current installations-Steering Assistance,Available,
IDE01992-SFT00070,Installation list: current installations-Central Module Comfort System,Available,
IDE01992-SFT00072,Installation list: current installations-Seat Adjustment Rear Driver Side,Not available,
IDE01992-SFT00074,Installation list: current installations-Rear light,Not available,
IDE01992-SFT00077,Installation list: current installations-Löschkandidat_Datenübertragung Car2X,Not available,
IDE01992-SFT00080,Installation list: current installations-Seat Adjustment 3rd Row,Not available,
IDE01992-SFT00081,Installation list: current installations-Drive Motor Control Module,Not available,
IDE01992-SFT00082,Installation list: current installations-Door Electronics Passenger Side,Available,
IDE01992-SFT00090,Installation list: current installations-Longitudinal control,Not available,
IDE01992-SFT00091,Installation list: current installations-Seat Adjustment Rear Passenger Side,Not available,
IDE01992-SFT00095,Installation list: current installations-Information Control Unit 1,Available,
IDE01992-SFT00101,Installation list: current installations-Tire Pressure Monitoring 1,Not available,
IDE01992-SFT00105,Installation list: current installations-Trailer Function,Not available,
IDE01992-SFT00107,Installation list: current installations-Aerodynamics Control Unit,Not available,
IDE01992-SFT00108,Installation list: current installations-Camera System Rear View,Available,
IDE01992-SFT00109,Installation list: current installations-Deck Lid Control Unit,Not available,
IDE01992-SFT00116,Installation list: current installations-Chassis Control,Not available,
IDE01992-SFT00118,Installation list: current installations-Parking Assistance,Not available,
IDE01992-SFT00127,Installation list: current installations-Information Control Unit 2,Not available,
IDE01992-SFT00128,Installation list: current installations-Battery Regulation Auxiliary Accumulator 1,Not available,
IDE01992-SFT00129,Installation list: current installations-Gear Shift Control Module,Available,
IDE01992-SFT00130,Installation list: current installations-Head Up Display,Not available,
IDE01992-SFT00132,Installation list: current installations-Night Vision,Not available,
IDE01992-SFT00139,Installation list: current installations-Adaptive Cruise Control 2,Not available,
IDE01992-SFT00140,Installation list: current installations-Battery Energy Control Module,Not available,
IDE01992-SFT00166,Installation list: current installations-Microphone Control Unit,Not available,
IDE01992-SFT00169,Installation list: current installations-Actuator For Structure-borne Sound,Not available,
IDE01992-SFT00172,Installation list: current installations-Reductant Control Module,Not available,
IDE01992-SFT00183,Installation list: current installations-Access Startsystem Interface,Not available,
IDE01992-SFT00186,Installation list: current installations-Assembly Mounting,Not available,
IDE01992-SFT00192,Installation list: current installations-Actuator For Exterior Noise,Not available,
IDE01992-SFT00195,Installation list: current installations-Drive Motor Control Module 3,Not available,
IDE01992-SFT00196,Installation list: current installations-DC/DC Converter Control Module,Not available,
IDE01992-SFT00197,Installation list: current installations-Thermal management,Not available,
IDE01992-SFT00198,Installation list: current installations-Battery Charger Control Module,Not available,
IDE01992-SFT00203,Installation list: current installations-Rear Axle Steering,Not available,
IDE01992-SFT00205,Installation list: current installations-Laser Scanner,Not available,
IDE01992-SFT00206,Installation list: current installations-Drive Motor Control Module 2,Not available,
IDE01992-SFT00208,Installation list: current installations-Front Axle Lift System,Not available,
IDE01992-SFT00219,Installation list: current installations-Front Corner Radar 1,Not available,
IDE01992-SFT00220,Installation list: current installations-Front Corner Radar 2,Not available,
IDE01992-SFT00221,Installation list: current installations-Control Module 2 For Sunroof,Not available,
IDE01992-SFT33031,Installation list: current installations-Antenna Control Module,Not available,
IDE01992-SFT33232,Installation list: current installations-Central control for digital matrix light,Not available,
IDE01992-SFT09760,Installation list: current installations-Sun Roof,Available,
IDE01993-IDE14867,Control module reference number-Subgateway as firewall control module,00,
IDE01993-SFT00001,Control module reference number-Engine Control Module 1,76,
IDE01993-SFT00002,Control module reference number-Transmission Control Module,77,
IDE01993-SFT00003,Control module reference number-Brakes 1,13,
IDE01993-SFT00003,Control module reference number-Brakes 1,00,
IDE01993-SFT00006,Control module reference number-Seat Adjustment Passenger Side,4D,
IDE01993-SFT00007,Control module reference number-Display Control Unit,8E,
IDE01993-SFT00008,Control module reference number-Air Conditioning,46,
IDE01993-SFT00009,Control module reference number-Central Electrics,0E,
IDE01993-SFT00012,Control module reference number-Rear Axle Steering 2,00,
IDE01993-SFT00017,Control module reference number-Engine Control Module 2,78,
IDE01993-SFT00019,Control module reference number-Adaptive Cruise Control,57,
IDE01993-SFT00021,Control module reference number-Airbag,00,
IDE01993-SFT00021,Control module reference number-Airbag,15,
IDE01993-SFT00022,Control module reference number-Steering Column Electronics,0C,
IDE01993-SFT00023,Control module reference number-Dash Board,14,
IDE01993-SFT00024,Control module reference number-Auxiliary Parking Heater,6A,
IDE01993-SFT00025,Control module reference number-Gateway,10,
IDE01993-SFT00027,Control module reference number-Active Steering,16,
IDE01993-SFT00032,Control module reference number-High Beam Assistance,30,
IDE01993-SFT00033,Control module reference number-Battery Energy Control Module 2,9C,
IDE01993-SFT00034,Control module reference number-All Wheel Control,0F,
IDE01993-SFT00035,Control module reference number-Brake Boost,3B,
IDE01993-SFT00038,Control module reference number-Electronic Roof Control,2D,
IDE01993-SFT00039,Control module reference number-Display Control Unit Rear,93,
IDE01993-SFT00040,Control module reference number-Climate Control Unit Rear,1A,
IDE01993-SFT00042,Control module reference number-Control Unit Wireless Charging,8F,
IDE01993-SFT00043,Control module reference number-Steering Column Locking,31,
IDE01993-SFT00048,Control module reference number-Special Function 2,2B,
IDE01993-SFT00050,Control module reference number-Lock Electronics,1E,
IDE01993-SFT00054,Control module reference number-Seat Adjustment Driver Side,4C,
IDE01993-SFT00060,Control module reference number-Lane Change Assistant,4E,
IDE01993-SFT00060,Control module reference number-Lane Change Assistant,00,
IDE01993-SFT00061,Control module reference number-Special Function,2C,
IDE01993-SFT00066,Control module reference number-Door Electronics Driver Side,4A,
IDE01993-SFT00068,Control module reference number-Steering Assistance,12,
IDE01993-SFT00070,Control module reference number-Central Module Comfort System,8B,
IDE01993-SFT00072,Control module reference number-Seat Adjustment Rear Driver Side,87,
IDE01993-SFT00074,Control module reference number-Rear light,00,
IDE01993-SFT00077,Control module reference number-Löschkandidat_Datenübertragung Car2X,00,
IDE01993-SFT00080,Control module reference number-Seat Adjustment 3rd Row,95,
IDE01993-SFT00081,Control module reference number-Drive Motor Control Module,03,
IDE01993-SFT00081,Control module reference number-Drive Motor Control Module,7C,
IDE01993-SFT00082,Control module reference number-Door Electronics Passenger Side,4B,
IDE01993-SFT00090,Control module reference number-Longitudinal control,94,
IDE01993-SFT00091,Control module reference number-Seat Adjustment Rear Passenger Side,88,
IDE01993-SFT00095,Control module reference number-Information Control Unit 1,73,
IDE01993-SFT00101,Control module reference number-Tire Pressure Monitoring 1,0B,
IDE01993-SFT00105,Control module reference number-Trailer Function,47,
IDE01993-SFT00107,Control module reference number-Aerodynamics Control Unit,24,
IDE01993-SFT00108,Control module reference number-Camera System Rear View,69,
IDE01993-SFT00109,Control module reference number-Deck Lid Control Unit,23,
IDE01993-SFT00116,Control module reference number-Chassis Control,80,
IDE01993-SFT00118,Control module reference number-Parking Assistance,00,
IDE01993-SFT00127,Control module reference number-Information Control Unit 2,00,
IDE01993-SFT00128,Control module reference number-Battery Regulation Auxiliary Accumulator 1,AE,
IDE01993-SFT00129,Control module reference number-Gear Shift Control Module,53,
IDE01993-SFT00130,Control module reference number-Head Up Display,1B,
IDE01993-SFT00132,Control module reference number-Night Vision,27,
IDE01993-SFT00139,Control module reference number-Adaptive Cruise Control 2,56,
IDE01993-SFT00140,Control module reference number-Battery Energy Control Module,7B,
IDE01993-SFT00165,Control module reference number-Front Sensors Driver Assistance System,00,
IDE01993-SFT00165,Control module reference number-Front Sensors Driver Assistance System,4F,
IDE01993-SFT00166,Control module reference number-Microphone Control Unit,63,
IDE01993-SFT00169,Control module reference number-Actuator For Structure-borne Sound,1C,
IDE01993-SFT00172,Control module reference number-Reductant Control Module,2A,
IDE01993-SFT00183,Control module reference number-Access Startsystem Interface,00,
IDE01993-SFT00186,Control module reference number-Assembly Mounting,2E,
IDE01993-SFT00192,Control module reference number-Actuator For Exterior Noise,64,
IDE01993-SFT00195,Control module reference number-Drive Motor Control Module 3,00,
IDE01993-SFT00196,Control module reference number-DC/DC Converter Control Module,41,
IDE01993-SFT00197,Control module reference number-Thermal management,42,
IDE01993-SFT00198,Control module reference number-Battery Charger Control Module,44,
IDE01993-SFT00203,Control module reference number-Rear Axle Steering,60,
IDE01993-SFT00205,Control module reference number-Laser Scanner,00,
IDE01993-SFT00206,Control module reference number-Drive Motor Control Module 2,00,
IDE01993-SFT00207,Control module reference number-Control Unit Lane Change Assistant 2,00,
IDE01993-SFT00207,Control module reference number-Control Unit Lane Change Assistant 2,8A,
IDE01993-SFT00208,Control module reference number-Front Axle Lift System,00,
IDE01993-SFT00219,Control module reference number-Front Corner Radar 1,00,
IDE01993-SFT00220,Control module reference number-Front Corner Radar 2,00,
IDE01993-SFT00221,Control module reference number-Control Module 2 For Sunroof,A0,
IDE01993-SFT33031,Control module reference number-Antenna Control Module,00,
IDE01993-SFT33232,Control module reference number-Central control for digital matrix light,00,
IDE01993-SFT09760,Control module reference number-Sun Roof,84,
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,0, mA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,-113.00,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,Not available,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,Not available,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,Not available,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,Not available,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02384-IDE14867,Status of event memory-Subgateway as firewall control module,OK,
IDE02384-SFT00001,Status of event memory-Engine Control Module 1,OK,
IDE02384-SFT00002,Status of event memory-Transmission Control Module,OK,
IDE02384-SFT00003,Status of event memory-Brakes 1,OK,
IDE02384-SFT00006,Status of event memory-Seat Adjustment Passenger Side,OK,
IDE02384-SFT00007,Status of event memory-Display Control Unit,OK,
IDE02384-SFT00008,Status of event memory-Air Conditioning,OK,
IDE02384-SFT00009,Status of event memory-Central Electrics,OK,
IDE02384-SFT00012,Status of event memory-Rear Axle Steering 2,OK,
IDE02384-SFT00017,Status of event memory-Engine Control Module 2,OK,
IDE02384-SFT00019,Status of event memory-Adaptive Cruise Control,OK,
IDE02384-SFT00021,Status of event memory-Airbag,OK,
IDE02384-SFT00022,Status of event memory-Steering Column Electronics,OK,
IDE02384-SFT00023,Status of event memory-Dash Board,OK,
IDE02384-SFT00024,Status of event memory-Auxiliary Parking Heater,OK,
IDE02384-SFT00025,Status of event memory-Gateway,OK,
IDE02384-SFT00027,Status of event memory-Active Steering,OK,
IDE02384-SFT00032,Status of event memory-High Beam Assistance,OK,
IDE02384-SFT00033,Status of event memory-Battery Energy Control Module 2,OK,
IDE02384-SFT00034,Status of event memory-All Wheel Control,OK,
IDE02384-SFT00035,Status of event memory-Brake Boost,OK,
IDE02384-SFT00038,Status of event memory-Electronic Roof Control,OK,
IDE02384-SFT00039,Status of event memory-Display Control Unit Rear,OK,
IDE02384-SFT00040,Status of event memory-Climate Control Unit Rear,OK,
IDE02384-SFT00042,Status of event memory-Control Unit Wireless Charging,OK,
IDE02384-SFT00043,Status of event memory-Steering Column Locking,OK,
IDE02384-SFT00048,Status of event memory-Special Function 2,OK,
IDE02384-SFT00050,Status of event memory-Lock Electronics,OK,
IDE02384-SFT00054,Status of event memory-Seat Adjustment Driver Side,OK,
IDE02384-SFT00060,Status of event memory-Lane Change Assistant,OK,
IDE02384-SFT00061,Status of event memory-Special Function,OK,
IDE02384-SFT00066,Status of event memory-Door Electronics Driver Side,OK,
IDE02384-SFT00068,Status of event memory-Steering Assistance,OK,
IDE02384-SFT00070,Status of event memory-Central Module Comfort System,OK,
IDE02384-SFT00072,Status of event memory-Seat Adjustment Rear Driver Side,OK,
IDE02384-SFT00074,Status of event memory-Rear light,OK,
IDE02384-SFT00077,Status of event memory-Löschkandidat_Datenübertragung Car2X,OK,
IDE02384-SFT00080,Status of event memory-Seat Adjustment 3rd Row,OK,
IDE02384-SFT00081,Status of event memory-Drive Motor Control Module,OK,
IDE02384-SFT00082,Status of event memory-Door Electronics Passenger Side,OK,
IDE02384-SFT00090,Status of event memory-Longitudinal control,OK,
IDE02384-SFT00091,Status of event memory-Seat Adjustment Rear Passenger Side,OK,
IDE02384-SFT00095,Status of event memory-Information Control Unit 1,OK,
IDE02384-SFT00101,Status of event memory-Tire Pressure Monitoring 1,OK,
IDE02384-SFT00105,Status of event memory-Trailer Function,OK,
IDE02384-SFT00107,Status of event memory-Aerodynamics Control Unit,OK,
IDE02384-SFT00108,Status of event memory-Camera System Rear View,OK,
IDE02384-SFT00109,Status of event memory-Deck Lid Control Unit,OK,
IDE02384-SFT00116,Status of event memory-Chassis Control,OK,
IDE02384-SFT00118,Status of event memory-Parking Assistance,OK,
IDE02384-SFT00127,Status of event memory-Information Control Unit 2,OK,
IDE02384-SFT00128,Status of event memory-Battery Regulation Auxiliary Accumulator 1,OK,
IDE02384-SFT00129,Status of event memory-Gear Shift Control Module,OK,
IDE02384-SFT00130,Status of event memory-Head Up Display,OK,
IDE02384-SFT00132,Status of event memory-Night Vision,OK,
IDE02384-SFT00139,Status of event memory-Adaptive Cruise Control 2,OK,
IDE02384-SFT00140,Status of event memory-Battery Energy Control Module,OK,
IDE02384-SFT00165,Status of event memory-Front Sensors Driver Assistance System,OK,
IDE02384-SFT00166,Status of event memory-Microphone Control Unit,OK,
IDE02384-SFT00169,Status of event memory-Actuator For Structure-borne Sound,OK,
IDE02384-SFT00172,Status of event memory-Reductant Control Module,OK,
IDE02384-SFT00183,Status of event memory-Access Startsystem Interface,OK,
IDE02384-SFT00186,Status of event memory-Assembly Mounting,OK,
IDE02384-SFT00192,Status of event memory-Actuator For Exterior Noise,OK,
IDE02384-SFT00195,Status of event memory-Drive Motor Control Module 3,OK,
IDE02384-SFT00196,Status of event memory-DC/DC Converter Control Module,OK,
IDE02384-SFT00197,Status of event memory-Thermal management,OK,
IDE02384-SFT00198,Status of event memory-Battery Charger Control Module,OK,
IDE02384-SFT00203,Status of event memory-Rear Axle Steering,OK,
IDE02384-SFT00205,Status of event memory-Laser Scanner,OK,
IDE02384-SFT00206,Status of event memory-Drive Motor Control Module 2,OK,
IDE02384-SFT00207,Status of event memory-Control Unit Lane Change Assistant 2,OK,
IDE02384-SFT00208,Status of event memory-Front Axle Lift System,OK,
IDE02384-SFT00219,Status of event memory-Front Corner Radar 1,OK,
IDE02384-SFT00220,Status of event memory-Front Corner Radar 2,OK,
IDE02384-SFT00221,Status of event memory-Control Module 2 For Sunroof,OK,
IDE02384-SFT33031,Status of event memory-Antenna Control Module,OK,
IDE02384-SFT33232,Status of event memory-Central control for digital matrix light,OK,
IDE02384-SFT09760,Status of event memory-Sun Roof,OK,
IDE02578-IDE05118,Play protection status-Counter for function calls,0,
IDE02578-MAS02040,Play protection status-Play protection,not active,
IDE02744-MAS02311,Steering wheel heater-Steering wheel heating button,not activated,
IDE02744-MAS09775,Steering wheel heater-Steering wheel temp.,Initializing,
IDE03008-MAS02193,Stop process prevented-Outside air temperature,not active,
IDE03008-MAS04055,Stop process prevented-Usable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery charge condition too low,not active,
IDE03008-MAS04059,Stop process prevented-Battery temperature,not active,
IDE03008-MAS04060,Stop process prevented-Other reasons active,not active,
IDE03008-MAS04061,Stop process prevented-Idle speed increase active,not active,
IDE03008-MAS04062,Stop process prevented-Possible service life too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS09832,Stop process prevented-Intermittent operation,not active,
IDE03009-MAS01478,Start process requested-Insuff. voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04055,Start process requested-Usable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery charge condition too low,not active,
IDE03009-MAS04058,Start process requested-Service life expired,not active,
IDE03009-MAS04060,Start process requested-Other reasons active,not active,
IDE03009-MAS06003,Start process requested-Charging contingent,not active,
IDE03009-MAS06004,Start process requested-Special start requirements,not active,
IDE03010-MAS02193,Number of prevented stop processes-Outside air temperature,0,
IDE03010-MAS04055,Number of prevented stop processes-Usable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery charge condition too low,39,
IDE03010-MAS04059,Number of prevented stop processes-Battery temperature,0,
IDE03010-MAS04060,Number of prevented stop processes-Other reasons active,0,
IDE03010-MAS04061,Number of prevented stop processes-Idle speed increase active,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible service life too short,10,
IDE03010-MAS06001,Number of prevented stop processes-Energy management special veto,0,
IDE03010-MAS09832,Number of prevented stop processes-Intermittent operation,0,
IDE03011-MAS01478,Number of requested start processes-Insuff. voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04055,Number of requested start processes-Usable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery charge condition too low,0,
IDE03011-MAS04058,Number of requested start processes-Service life expired,0,
IDE03011-MAS04060,Number of requested start processes-Other reasons active,0,
IDE03011-MAS06003,Number of requested start processes-Charging contingent,0,
IDE03011-MAS06004,Number of requested start processes-Special start requirements,0,
IDE03150-IDE14867,Readiness for bus sleep mode-Subgateway as firewall control module,Sleep mode,
IDE03150-SFT00001,Readiness for bus sleep mode-Engine Control Module 1,active,
IDE03150-SFT00002,Readiness for bus sleep mode-Transmission Control Module,Sleep mode,
IDE03150-SFT00003,Readiness for bus sleep mode-Brakes 1,Sleep mode,
IDE03150-SFT00006,Readiness for bus sleep mode-Seat Adjustment Passenger Side,Sleep mode,
IDE03150-SFT00007,Readiness for bus sleep mode-Display Control Unit,Sleep mode,
IDE03150-SFT00008,Readiness for bus sleep mode-Air Conditioning,Sleep mode,
IDE03150-SFT00009,Readiness for bus sleep mode-Central Electrics,active,
IDE03150-SFT00012,Readiness for bus sleep mode-Rear Axle Steering 2,Sleep mode,
IDE03150-SFT00017,Readiness for bus sleep mode-Engine Control Module 2,Sleep mode,
IDE03150-SFT00019,Readiness for bus sleep mode-Adaptive Cruise Control,Sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,Sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,active,
IDE03150-SFT00022,Readiness for bus sleep mode-Steering Column Electronics,active,
IDE03150-SFT00023,Readiness for bus sleep mode-Dash Board,active,
IDE03150-SFT00024,Readiness for bus sleep mode-Auxiliary Parking Heater,Sleep mode,
IDE03150-SFT00025,Readiness for bus sleep mode-Gateway,active,
IDE03150-SFT00027,Readiness for bus sleep mode-Active Steering,Sleep mode,
IDE03150-SFT00032,Readiness for bus sleep mode-High Beam Assistance,Sleep mode,
IDE03150-SFT00033,Readiness for bus sleep mode-Battery Energy Control Module 2,Sleep mode,
IDE03150-SFT00034,Readiness for bus sleep mode-All Wheel Control,Sleep mode,
IDE03150-SFT00035,Readiness for bus sleep mode-Brake Boost,Sleep mode,
IDE03150-SFT00038,Readiness for bus sleep mode-Electronic Roof Control,Sleep mode,
IDE03150-SFT00039,Readiness for bus sleep mode-Display Control Unit Rear,Sleep mode,
IDE03150-SFT00040,Readiness for bus sleep mode-Climate Control Unit Rear,Sleep mode,
IDE03150-SFT00042,Readiness for bus sleep mode-Control Unit Wireless Charging,Sleep mode,
IDE03150-SFT00043,Readiness for bus sleep mode-Steering Column Locking,Sleep mode,
IDE03150-SFT00048,Readiness for bus sleep mode-Special Function 2,Sleep mode,
IDE03150-SFT00050,Readiness for bus sleep mode-Lock Electronics,Sleep mode,
IDE03150-SFT00054,Readiness for bus sleep mode-Seat Adjustment Driver Side,Sleep mode,
IDE03150-SFT00060,Readiness for bus sleep mode-Lane Change Assistant,Sleep mode,
IDE03150-SFT00061,Readiness for bus sleep mode-Special Function,Sleep mode,
IDE03150-SFT00066,Readiness for bus sleep mode-Door Electronics Driver Side,active,
IDE03150-SFT00068,Readiness for bus sleep mode-Steering Assistance,active,
IDE03150-SFT00070,Readiness for bus sleep mode-Central Module Comfort System,active,
IDE03150-SFT00072,Readiness for bus sleep mode-Seat Adjustment Rear Driver Side,Sleep mode,
IDE03150-SFT00074,Readiness for bus sleep mode-Rear light,Sleep mode,
IDE03150-SFT00077,Readiness for bus sleep mode-Löschkandidat_Datenübertragung Car2X,Sleep mode,
IDE03150-SFT00080,Readiness for bus sleep mode-Seat Adjustment 3rd Row,Sleep mode,
IDE03150-SFT00081,Readiness for bus sleep mode-Drive Motor Control Module,Sleep mode,
IDE03150-SFT00082,Readiness for bus sleep mode-Door Electronics Passenger Side,Sleep mode,
IDE03150-SFT00090,Readiness for bus sleep mode-Longitudinal control,Sleep mode,
IDE03150-SFT00091,Readiness for bus sleep mode-Seat Adjustment Rear Passenger Side,Sleep mode,
IDE03150-SFT00095,Readiness for bus sleep mode-Information Control Unit 1,active,
IDE03150-SFT00101,Readiness for bus sleep mode-Tire Pressure Monitoring 1,Sleep mode,
IDE03150-SFT00105,Readiness for bus sleep mode-Trailer Function,Sleep mode,
IDE03150-SFT00107,Readiness for bus sleep mode-Aerodynamics Control Unit,Sleep mode,
IDE03150-SFT00108,Readiness for bus sleep mode-Camera System Rear View,active,
IDE03150-SFT00109,Readiness for bus sleep mode-Deck Lid Control Unit,Sleep mode,
IDE03150-SFT00116,Readiness for bus sleep mode-Chassis Control,Sleep mode,
IDE03150-SFT00118,Readiness for bus sleep mode-Parking Assistance,Sleep mode,
IDE03150-SFT00127,Readiness for bus sleep mode-Information Control Unit 2,Sleep mode,
IDE03150-SFT00128,Readiness for bus sleep mode-Battery Regulation Auxiliary Accumulator 1,Sleep mode,
IDE03150-SFT00129,Readiness for bus sleep mode-Gear Shift Control Module,active,
IDE03150-SFT00130,Readiness for bus sleep mode-Head Up Display,Sleep mode,
IDE03150-SFT00132,Readiness for bus sleep mode-Night Vision,Sleep mode,
IDE03150-SFT00139,Readiness for bus sleep mode-Adaptive Cruise Control 2,Sleep mode,
IDE03150-SFT00140,Readiness for bus sleep mode-Battery Energy Control Module,Sleep mode,
IDE03150-SFT00165,Readiness for bus sleep mode-Front Sensors Driver Assistance System,Sleep mode,
IDE03150-SFT00166,Readiness for bus sleep mode-Microphone Control Unit,Sleep mode,
IDE03150-SFT00169,Readiness for bus sleep mode-Actuator For Structure-borne Sound,Sleep mode,
IDE03150-SFT00172,Readiness for bus sleep mode-Reductant Control Module,Sleep mode,
IDE03150-SFT00183,Readiness for bus sleep mode-Access Startsystem Interface,Sleep mode,
IDE03150-SFT00186,Readiness for bus sleep mode-Assembly Mounting,Sleep mode,
IDE03150-SFT00192,Readiness for bus sleep mode-Actuator For Exterior Noise,Sleep mode,
IDE03150-SFT00195,Readiness for bus sleep mode-Drive Motor Control Module 3,Sleep mode,
IDE03150-SFT00196,Readiness for bus sleep mode-DC/DC Converter Control Module,Sleep mode,
IDE03150-SFT00197,Readiness for bus sleep mode-Thermal management,Sleep mode,
IDE03150-SFT00198,Readiness for bus sleep mode-Battery Charger Control Module,Sleep mode,
IDE03150-SFT00203,Readiness for bus sleep mode-Rear Axle Steering,Sleep mode,
IDE03150-SFT00205,Readiness for bus sleep mode-Laser Scanner,Sleep mode,
IDE03150-SFT00206,Readiness for bus sleep mode-Drive Motor Control Module 2,Sleep mode,
IDE03150-SFT00207,Readiness for bus sleep mode-Control Unit Lane Change Assistant 2,Sleep mode,
IDE03150-SFT00207,Readiness for bus sleep mode-Control Unit Lane Change Assistant 2,active,
IDE03150-SFT00208,Readiness for bus sleep mode-Front Axle Lift System,Sleep mode,
IDE03150-SFT00219,Readiness for bus sleep mode-Front Corner Radar 1,Sleep mode,
IDE03150-SFT00220,Readiness for bus sleep mode-Front Corner Radar 2,Sleep mode,
IDE03150-SFT00221,Readiness for bus sleep mode-Control Module 2 For Sunroof,Sleep mode,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna Control Module,Sleep mode,
IDE03150-SFT33232,Readiness for bus sleep mode-Central control for digital matrix light,Sleep mode,
IDE03150-SFT09760,Readiness for bus sleep mode-Sun Roof,Sleep mode,
IDE03205,Manufacturer code,SME,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03477-MAS00106,GPS time-Year,Not available,
IDE03477-MAS00107,GPS time-Month,Not available,
IDE03477-MAS00108,GPS time-Day,Not available,
IDE03477-MAS00109,GPS time-Hours,Not available,
IDE03477-MAS00110,GPS time-Minutes,Not available,
IDE03477-MAS00111,GPS time-Seconds,Not available,
IDE03477-MAS01632,GPS time-Status,invalid,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery malfunction,no error,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,no error,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,no error,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,no error,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,no error,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,no error,
IDE04186,Battery terminal recognition,connected,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,A1 3C 3F 3E DB 3B C7 26 46 C8 A4 60 86 76 E2 B2 7C 49 E0 E1 7A 1D 94 D7 C5 3B C1 67 2D A4 14 CC CE 63 6F 13 57 0D FE 90 D7 72 D3 56 2B 8C 68 43 6E 73 E2 EE 50 F7 11 EE 51 46 49 F7 16 0E CB 5B 98 D2 66 93 17 79 C4 43 92 9A A9 A5 57 8A EC F1 CD FC 78 C7 97 B0 84 0E A8 B0 B0 FF 3C 28 8C 12 45 E1 7D 0E 3B 73 4E DD DF 49 90 9E 8E 8C 19 6A A7 F7 AC D9 2C 26 5D B5 E4 B2 68 17 B3 C3 76 73 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-IDE14867,Bus identification-Subgateway as firewall control module,Unknown,
IDE04343-SFT00001,Bus identification-Engine Control Module 1,Data bus Flexray A,
IDE04343-SFT00002,Bus identification-Transmission Control Module,Data bus Flexray A,
IDE04343-SFT00003,Bus identification-Brakes 1,Unknown,
IDE04343-SFT00003,Bus identification-Brakes 1,Data bus Flexray A,
IDE04343-SFT00006,Bus identification-Seat Adjustment Passenger Side,Comfort data bus,
IDE04343-SFT00007,Bus identification-Display Control Unit,Data bus Sensor/Hybrid,
IDE04343-SFT00008,Bus identification-Air Conditioning,Data bus Sensor/Hybrid,
IDE04343-SFT00009,Bus identification-Central Electrics,Comfort data bus,
IDE04343-SFT00012,Bus identification-Rear Axle Steering 2,Unknown,
IDE04343-SFT00017,Bus identification-Engine Control Module 2,Data bus Flexray A,
IDE04343-SFT00019,Bus identification-Adaptive Cruise Control,Data bus Flexray A,
IDE04343-SFT00021,Bus identification-Airbag,Unknown,
IDE04343-SFT00021,Bus identification-Airbag,Data bus Flexray A,
IDE04343-SFT00022,Bus identification-Steering Column Electronics,Data bus Flexray A,
IDE04343-SFT00023,Bus identification-Dash Board,Databus Infotainment,
IDE04343-SFT00024,Bus identification-Auxiliary Parking Heater,Databus extended,
IDE04343-SFT00025,Bus identification-Gateway,Busmaster,
IDE04343-SFT00027,Bus identification-Active Steering,Data bus Flexray A,
IDE04343-SFT00032,Bus identification-High Beam Assistance,Databus extended,
IDE04343-SFT00033,Bus identification-Battery Energy Control Module 2,Data bus Sensor/Hybrid,
IDE04343-SFT00034,Bus identification-All Wheel Control,Data bus Flexray A,
IDE04343-SFT00035,Bus identification-Brake Boost,Data bus Flexray A,
IDE04343-SFT00038,Bus identification-Electronic Roof Control,Comfort data bus,
IDE04343-SFT00039,Bus identification-Display Control Unit Rear,Data bus Sensor/Hybrid,
IDE04343-SFT00040,Bus identification-Climate Control Unit Rear,Data bus Sensor/Hybrid,
IDE04343-SFT00042,Bus identification-Control Unit Wireless Charging,Data bus Sensor/Hybrid,
IDE04343-SFT00043,Bus identification-Steering Column Locking,Comfort data bus,
IDE04343-SFT00048,Bus identification-Special Function 2,Comfort data bus,
IDE04343-SFT00050,Bus identification-Lock Electronics,Data bus Flexray A,
IDE04343-SFT00054,Bus identification-Seat Adjustment Driver Side,Comfort data bus,
IDE04343-SFT00060,Bus identification-Lane Change Assistant,Databus extended,
IDE04343-SFT00060,Bus identification-Lane Change Assistant,Unknown,
IDE04343-SFT00061,Bus identification-Special Function,Comfort data bus,
IDE04343-SFT00066,Bus identification-Door Electronics Driver Side,Comfort data bus,
IDE04343-SFT00068,Bus identification-Steering Assistance,Data bus Flexray A,
IDE04343-SFT00070,Bus identification-Central Module Comfort System,Comfort data bus,
IDE04343-SFT00072,Bus identification-Seat Adjustment Rear Driver Side,Comfort data bus,
IDE04343-SFT00074,Bus identification-Rear light,Unknown,
IDE04343-SFT00077,Bus identification-Löschkandidat_Datenübertragung Car2X,Unknown,
IDE04343-SFT00080,Bus identification-Seat Adjustment 3rd Row,Comfort data bus,
IDE04343-SFT00081,Bus identification-Drive Motor Control Module,Data bus Flexray A,
IDE04343-SFT00081,Bus identification-Drive Motor Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00082,Bus identification-Door Electronics Passenger Side,Comfort data bus,
IDE04343-SFT00090,Bus identification-Longitudinal control,Data bus Flexray A,
IDE04343-SFT00091,Bus identification-Seat Adjustment Rear Passenger Side,Comfort data bus,
IDE04343-SFT00095,Bus identification-Information Control Unit 1,Databus Infotainment,
IDE04343-SFT00101,Bus identification-Tire Pressure Monitoring 1,Databus extended,
IDE04343-SFT00105,Bus identification-Trailer Function,Comfort data bus,
IDE04343-SFT00107,Bus identification-Aerodynamics Control Unit,Comfort data bus,
IDE04343-SFT00108,Bus identification-Camera System Rear View,Databus extended,
IDE04343-SFT00109,Bus identification-Deck Lid Control Unit,Comfort data bus,
IDE04343-SFT00116,Bus identification-Chassis Control,Data bus Flexray A,
IDE04343-SFT00118,Bus identification-Parking Assistance,Unknown,
IDE04343-SFT00127,Bus identification-Information Control Unit 2,Unknown,
IDE04343-SFT00128,Bus identification-Battery Regulation Auxiliary Accumulator 1,Data bus Sensor/Hybrid,
IDE04343-SFT00129,Bus identification-Gear Shift Control Module,Databus Infotainment,
IDE04343-SFT00130,Bus identification-Head Up Display,Databus Infotainment,
IDE04343-SFT00132,Bus identification-Night Vision,Databus extended,
IDE04343-SFT00139,Bus identification-Adaptive Cruise Control 2,Data bus Flexray A,
IDE04343-SFT00140,Bus identification-Battery Energy Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00165,Bus identification-Front Sensors Driver Assistance System,Unknown,
IDE04343-SFT00165,Bus identification-Front Sensors Driver Assistance System,Data bus Flexray A,
IDE04343-SFT00166,Bus identification-Microphone Control Unit,Databus Infotainment,
IDE04343-SFT00169,Bus identification-Actuator For Structure-borne Sound,Databus extended,
IDE04343-SFT00172,Bus identification-Reductant Control Module,Databus extended,
IDE04343-SFT00183,Bus identification-Access Startsystem Interface,Unknown,
IDE04343-SFT00186,Bus identification-Assembly Mounting,Data bus Sensor/Hybrid,
IDE04343-SFT00192,Bus identification-Actuator For Exterior Noise,Databus extended,
IDE04343-SFT00195,Bus identification-Drive Motor Control Module 3,Unknown,
IDE04343-SFT00196,Bus identification-DC/DC Converter Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00197,Bus identification-Thermal management,Data bus Sensor/Hybrid,
IDE04343-SFT00198,Bus identification-Battery Charger Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00203,Bus identification-Rear Axle Steering,Data bus Flexray A,
IDE04343-SFT00205,Bus identification-Laser Scanner,Unknown,
IDE04343-SFT00206,Bus identification-Drive Motor Control Module 2,Unknown,
IDE04343-SFT00207,Bus identification-Control Unit Lane Change Assistant 2,Unknown,
IDE04343-SFT00207,Bus identification-Control Unit Lane Change Assistant 2,Databus extended,
IDE04343-SFT00208,Bus identification-Front Axle Lift System,Unknown,
IDE04343-SFT00219,Bus identification-Front Corner Radar 1,Unknown,
IDE04343-SFT00220,Bus identification-Front Corner Radar 2,Unknown,
IDE04343-SFT00221,Bus identification-Control Module 2 For Sunroof,Unknown,
IDE04343-SFT33031,Bus identification-Antenna Control Module,Unknown,
IDE04343-SFT33232,Bus identification-Central control for digital matrix light,Unknown,
IDE04343-SFT09760,Bus identification-Sun Roof,Comfort data bus,
IDE04605-IDE01712,Navigation: Corrected position-GPS Position,Not available,
IDE04605-MAS01779,Navigation: Corrected position-Length,2D 38 31 37 30 39 37 39 34 00 00 00 00 00,
IDE04605-MAS01780,Navigation: Corrected position-Width,32 36 32 34 35 34 38 34 00 00 00 00 00 00,
IDE04605-MAS04183,Navigation: Corrected position-Position error,0, m
IDE04750-MAS03876,SIM cards-active SIM card,internal,
IDE04750-MAS03877,SIM cards-SIM ID,148630001515359,
IDE04750-MAS03878,SIM cards-SIM IMSI,310170205372938,
IDE04750-MAS04226,SIM cards-Telephone number,,
IDE04750-MAS08401,SIM cards-SIM intern,Available,
IDE04750-MAS08402,SIM cards-SIM extern,Not available,
IDE04790,Call for help button,Not available,
IDE04806-MAS10929,Driving profile selection button-Button for load profile selection,not activated,
IDE04806-MAS10937,Driving profile selection button-Driving profile selection button 1,not activated,
IDE04806-MAS10938,Driving profile selection button-Driving profile selection button 2,not activated,
IDE04806-MAS10939,Driving profile selection button-Drive profile selection rotary switch,no function,
IDE05430,Telephone serial number,148630001515359,
IDE05583-IDE09851,Pause recommendation-Function active,Yes,
IDE05583-MAS03095,Pause recommendation-Function status,not installed,
IDE05583-MAS04622,Pause recommendation-Break recommend. message,No display,
IDE05583-MAS13273,Pause recommendation-deactivation status,not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,D9 56 E9 EC A2,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,no entry,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,Engine Control Module (ECM),
IDE06007-MAS00106,Driving profile history data 1-Year,2000, yr
IDE06007-MAS00107,Driving profile history data 1-Month,0, m
IDE06007-MAS00108,Driving profile history data 1-Day,0, d
IDE06007-MAS00109,Driving profile history data 1-Hours,0, H
IDE06007-MAS00110,Driving profile history data 1-Minutes,0, min
IDE06007-MAS00111,Driving profile history data 1-Seconds,0, s
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initializing,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,no entry,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,Start-stop,
IDE06008-MAS00106,Driving profile history data 2-Year,2000, yr
IDE06008-MAS00107,Driving profile history data 2-Month,0, m
IDE06008-MAS00108,Driving profile history data 2-Day,0, d
IDE06008-MAS00109,Driving profile history data 2-Hours,0, H
IDE06008-MAS00110,Driving profile history data 2-Minutes,0, min
IDE06008-MAS00111,Driving profile history data 2-Seconds,0, s
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initializing,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,no entry,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,no entry,
IDE06009-MAS00106,Driving profile history data 3-Year,2000, yr
IDE06009-MAS00107,Driving profile history data 3-Month,0, m
IDE06009-MAS00108,Driving profile history data 3-Day,0, d
IDE06009-MAS00109,Driving profile history data 3-Hours,0, H
IDE06009-MAS00110,Driving profile history data 3-Minutes,0, min
IDE06009-MAS00111,Driving profile history data 3-Seconds,0, s
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initializing,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,no entry,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,no entry,
IDE06010-MAS00106,Driving profile history data 4-Year,2000, yr
IDE06010-MAS00107,Driving profile history data 4-Month,0, m
IDE06010-MAS00108,Driving profile history data 4-Day,0, d
IDE06010-MAS00109,Driving profile history data 4-Hours,0, H
IDE06010-MAS00110,Driving profile history data 4-Minutes,0, min
IDE06010-MAS00111,Driving profile history data 4-Seconds,0, s
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initializing,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,Profile 2,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,Profile 1,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-ENG118695,Driving profile selection statistics-Profile_1,1930542892, min
IDE06165-ENG126249,Driving profile selection statistics-profile_10,0, min
IDE06165-ENG126250,Driving profile selection statistics-profile_11,0, min
IDE06165-ENG127921,Driving profile selection statistics-profile_12,0, min
IDE06165-ENG04216,Driving profile selection statistics-profile_13,0, min
IDE06165-ENG04217,Driving profile selection statistics-profile_14,0, min
IDE06165-ENG04218,Driving profile selection statistics-profile_15,0, min
IDE06165-ENG118696,Driving profile selection statistics-Profile_2,15534, min
IDE06165-ENG118697,Driving profile selection statistics-Profile_3,17864, min
IDE06165-ENG118698,Driving profile selection statistics-Profile_4,0, min
IDE06165-ENG118699,Driving profile selection statistics-Profile_5,0, min
IDE06165-ENG118700,Driving profile selection statistics-Profile_6,0, min
IDE06165-ENG118701,Driving profile selection statistics-Profile_7,3124, min
IDE06165-ENG118702,Driving profile selection statistics-Profile_8,0, min
IDE06165-ENG126248,Driving profile selection statistics-profile_9,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2000, yr
IDE06230-MAS00107,Break recommend.: last message-Month,1, m
IDE06230-MAS00108,Break recommend.: last message-Day,1, d
IDE06230-MAS00109,Break recommend.: last message-Hours,0, H
IDE06230-MAS00110,Break recommend.: last message-Minutes,0, min
IDE06230-MAS00111,Break recommend.: last message-Seconds,0, s
IDE06230-MAS03095,Break recommend.: last message-Function status,Initializing,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,no warning,
IDE06264-IDE09057,Deep discharge protection-HV battery charge state,ERROR,
IDE06264-MAS04721,Deep discharge protection-Minimum charge level,ERROR,
IDE06264-MAS13070,Deep discharge protection-High-voltage energy management shut-down stage,not active,
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,7,
IDE06307-MAS00108,Stop prevention history data-Day,22,
IDE06307-MAS00109,Stop prevention history data-Hours,2,
IDE06307-MAS00110,Stop prevention history data-Minutes,43,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Battery charge condition too low,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,1,
IDE06308-MAS00108,Start request history data-Day,1,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE06522,Temperature of phone unit,40, °C
IDE06577,Supplier Identification,Conti Temic microelectronic GmbH,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06805-MAS09523,Status of voltage freedom-Transformer for electrical drive,Initializing,
IDE06805-MAS09524,Status of voltage freedom-Hybrid Battery Management,Initializing,
IDE06805-MAS09525,Status of voltage freedom-Ctrl. mod. for contactless charging,Initializing,
IDE06805-MAS09526,Status of voltage freedom-High-voltage battery charger,Initializing,
IDE06805-MAS11874,Status of voltage freedom-Overall status,Initializing,
IDE06805-SFT00195,Status of voltage freedom-Drive Motor Control Module 3,Initializing,
IDE06805-SFT00206,Status of voltage freedom-Drive Motor Control Module 2,Initializing,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,not activated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,3,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,0,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,0,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07427-IDE04447,Status: driving profile selection for power steering-Function status,engaged,
IDE07427-IDE06260,Status: driving profile selection for power steering-ID number,0,
IDE07427-MAS01156,Status: driving profile selection for power steering-Communication status,OK,
IDE07427-MAS01447,Status: driving profile selection for power steering-Act.val.,2,
IDE07428-IDE04447,Status: driving profile selection for damping adjustment-Function status,not engaged,
IDE07428-IDE06260,Status: driving profile selection for damping adjustment-ID number,0,
IDE07428-MAS01156,Status: driving profile selection for damping adjustment-Communication status,OK,
IDE07428-MAS01447,Status: driving profile selection for damping adjustment-Act.val.,0,
IDE07429-IDE04447,Status: driving profile selection for A/C-Function status,engaged,
IDE07429-IDE06260,Status: driving profile selection for A/C-ID number,251,
IDE07429-MAS01156,Status: driving profile selection for A/C-Communication status,OK,
IDE07429-MAS01447,Status: driving profile selection for A/C-Act.val.,0,
IDE07430-IDE04447,Status: driving profile selection for adaptive cruise control-Function status,not engaged,
IDE07430-IDE06260,Status: driving profile selection for adaptive cruise control-ID number,249,
IDE07430-MAS01156,Status: driving profile selection for adaptive cruise control-Communication status,OK,
IDE07430-MAS01447,Status: driving profile selection for adaptive cruise control-Act.val.,0,
IDE07431-IDE04447,Status: driv prof.select.for corn.light & headlamp range ctrl-Function status,not engaged,
IDE07431-IDE06260,Status: driv prof.select.for corn.light & headlamp range ctrl-ID number,0,
IDE07431-MAS01156,Status: driv prof.select.for corn.light & headlamp range ctrl-Communication status,OK,
IDE07431-MAS01447,Status: driv prof.select.for corn.light & headlamp range ctrl-Act.val.,0,
IDE07432-IDE04447,Status: driving profile selection for structure-borne noise-Function status,not engaged,
IDE07432-IDE06260,Status: driving profile selection for structure-borne noise-ID number,0,
IDE07432-MAS01156,Status: driving profile selection for structure-borne noise-Communication status,OK,
IDE07432-MAS01447,Status: driving profile selection for structure-borne noise-Act.val.,0,
IDE07433-IDE04447,Status: driving profile selection for ambient lighting-Function status,engaged,
IDE07433-IDE06260,Status: driving profile selection for ambient lighting-ID number,35,
IDE07433-MAS01156,Status: driving profile selection for ambient lighting-Communication status,OK,
IDE07433-MAS01447,Status: driving profile selection for ambient lighting-Act.val.,0,
IDE07434-IDE04447,Status: driving profile selection for belt tensioner-Function status,engaged,
IDE07434-IDE06260,Status: driving profile selection for belt tensioner-ID number,0,
IDE07434-MAS01156,Status: driving profile selection for belt tensioner-Communication status,OK,
IDE07434-MAS01447,Status: driving profile selection for belt tensioner-Act.val.,2,
IDE07436-IDE04447,Status: driving profile selection for free-running hub-Function status,not engaged,
IDE07436-IDE06260,Status: driving profile selection for free-running hub-ID number,0,
IDE07436-MAS01156,Status: driving profile selection for free-running hub-Communication status,OK,
IDE07436-MAS01447,Status: driving profile selection for free-running hub-Act.val.,0,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stoppage time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,5, A
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.50, V
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognized,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognized,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,1.10, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,1.15, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,ERROR,
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,728, A
IDE07847-MAS00976,Start stop requests without reason-Counter,38417,
IDE07873-MAS06193,FPA enabled profiles-Profile 1,Comfort,
IDE07873-MAS06194,FPA enabled profiles-Profile 2,AUTO,
IDE07873-MAS06195,FPA enabled profiles-Profile 3,Dynamic,
IDE07873-MAS06196,FPA enabled profiles-Profile 4,Not Used,
IDE07873-MAS06197,FPA enabled profiles-Profile 5,Not Used,
IDE07873-MAS06198,FPA enabled profiles-Profile 6,Not Used,
IDE07873-MAS06199,FPA enabled profiles-Profile 7,INDIVIDUAL,
IDE07873-MAS06200,FPA enabled profiles-Profile 8,Not Used,
IDE07873-MAS08875,FPA enabled profiles-Profile 9,Not Used,
IDE07873-MAS08876,FPA enabled profiles-Profile 10,Not Used,
IDE07873-MAS08877,FPA enabled profiles-Profile 11,Not Used,
IDE07873-MAS08878,FPA enabled profiles-Profile 12,Not Used,
IDE07873-MAS08879,FPA enabled profiles-Profile 13,Not Used,
IDE07873-MAS08880,FPA enabled profiles-Profile 14,Not Used,
IDE07873-MAS08881,FPA enabled profiles-Profile 15,Not Used,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status GSG,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ELV,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,257,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08251-MAS01483,Configuration immobilizer-Softwareversion,00 00 00,
IDE08251-MAS02832,Configuration immobilizer-Malfunction status,00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,05,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,0E,
IDE08251-MAS06850,Configuration immobilizer-Supported power class 2,00,
IDE08251-MAS06851,Configuration immobilizer-Supported power class 3,00,
IDE08251-MAS06852,Configuration immobilizer-Supported power class 4,00,
IDE08251-MAS06853,Configuration immobilizer-Supported power class 5,00,
IDE08343,Immobilizer Challenge,85 A6 7F 2C,
IDE08355-IDE04447,Status: driving profile selection for external noise actuator-Function status,not engaged,
IDE08355-IDE06260,Status: driving profile selection for external noise actuator-ID number,0,
IDE08355-MAS01156,Status: driving profile selection for external noise actuator-Communication status,OK,
IDE08355-MAS01447,Status: driving profile selection for external noise actuator-Act.val.,0,
IDE08490,Activation of diagnosis via ethernet,not active,
IDE08530-MAS00106,Connection status online basic services-Year,2019, yr
IDE08530-MAS00107,Connection status online basic services-Month,11, m
IDE08530-MAS00108,Connection status online basic services-Day,10, d
IDE08530-MAS00109,Connection status online basic services-Hours,21, H
IDE08530-MAS00110,Connection status online basic services-Minutes,15, min
IDE08530-MAS00111,Connection status online basic services-Seconds,3, s
IDE08530-MAS07130,Connection status online basic services-Number of ID steps,14,
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,30,
IDE08531-MAS00106,Connection status online license services-Year,Not available,
IDE08531-MAS00107,Connection status online license services-Month,Not available,
IDE08531-MAS00108,Connection status online license services-Day,Not available,
IDE08531-MAS00109,Connection status online license services-Hours,Not available,
IDE08531-MAS00110,Connection status online license services-Minutes,Not available,
IDE08531-MAS07132,Connection status online license services-Code status,1792255,
IDE08531-MAS07133,Connection status online license services-No. of license serv.,14,
IDE08531-MAS07134,Connection status online license services-ID services,8704,
IDE08531-MAS07135,Connection status online license services-Activation status,Not available,
IDE08531-MAS07136,Connection status online license services-Exp. year,Not available,
IDE08531-MAS07137,Connection status online license services-Exp. month,Not available,
IDE08531-MAS07138,Connection status online license services-Exp. day,1, d
IDE08600-IDE04447,Status drive profile selec. for rear-wheel drive-Function status,not engaged,
IDE08600-IDE06260,Status drive profile selec. for rear-wheel drive-ID number,5,
IDE08600-MAS01156,Status drive profile selec. for rear-wheel drive-Communication status,OK,
IDE08600-MAS01447,Status drive profile selec. for rear-wheel drive-Act.val.,0,
IDE08601-IDE04447,Drive profile selection for actuator for exterior noise-Function status,engaged,
IDE08601-IDE06260,Drive profile selection for actuator for exterior noise-ID number,0,
IDE08601-MAS01156,Drive profile selection for actuator for exterior noise-Communication status,OK,
IDE08601-MAS01447,Drive profile selection for actuator for exterior noise-Act.val.,0,
IDE08602-IDE04447,Status drive profile selec. for active steering-Function status,not engaged,
IDE08602-IDE06260,Status drive profile selec. for active steering-ID number,2,
IDE08602-MAS01156,Status drive profile selec. for active steering-Communication status,OK,
IDE08602-MAS01447,Status drive profile selec. for active steering-Act.val.,0,
IDE08605-IDE04447,Status drive profile for level control system-Function status,not engaged,
IDE08605-IDE06260,Status drive profile for level control system-ID number,12,
IDE08605-MAS01156,Status drive profile for level control system-Communication status,OK,
IDE08605-MAS01447,Status drive profile for level control system-Act.val.,0,
IDE08611-IDE04447,Status drive profile for stabilizer-Function status,engaged,
IDE08611-IDE06260,Status drive profile for stabilizer-ID number,0,
IDE08611-MAS01156,Status drive profile for stabilizer-Communication status,OK,
IDE08611-MAS01447,Status drive profile for stabilizer-Act.val.,0,
IDE08614-IDE04447,Status drive profile for engine operating conditions-Function status,not engaged,
IDE08614-IDE06260,Status drive profile for engine operating conditions-ID number,0,
IDE08614-MAS01156,Status drive profile for engine operating conditions-Communication status,OK,
IDE08614-MAS01447,Status drive profile for engine operating conditions-Act.val.,0,
IDE08687-IDE04447,Status: driving profile select. for brake ctrl. sys.-Function status,not engaged,
IDE08687-IDE06260,Status: driving profile select. for brake ctrl. sys.-ID number,0,
IDE08687-MAS01156,Status: driving profile select. for brake ctrl. sys.-Communication status,OK,
IDE08687-MAS01447,Status: driving profile select. for brake ctrl. sys.-Act.val.,2,
IDE08796-IDE04447,Status: driving profile selec. for hill descent control-Function status,not engaged,
IDE08796-IDE06260,Status: driving profile selec. for hill descent control-ID number,0,
IDE08796-MAS01156,Status: driving profile selec. for hill descent control-Communication status,OK,
IDE08796-MAS01447,Status: driving profile selec. for hill descent control-Act.val.,0,
IDE08798-IDE04447,Status: drive profile for Matrix-Beam-Function status,engaged,
IDE08798-IDE06260,Status: drive profile for Matrix-Beam-ID number,0,
IDE08798-MAS01156,Status: drive profile for Matrix-Beam-Communication status,OK,
IDE08798-MAS01447,Status: drive profile for Matrix-Beam-Act.val.,0,
IDE08799-IDE04447,Status: driv. profile selec. for rear spoiler-Function status,not engaged,
IDE08799-IDE06260,Status: driv. profile selec. for rear spoiler-ID number,0,
IDE08799-MAS01156,Status: driv. profile selec. for rear spoiler-Communication status,OK,
IDE08799-MAS01447,Status: driv. profile selec. for rear spoiler-Act.val.,0,
IDE08804-IDE04447,Status: driv. profile selec. for ctr. differential-Function status,not engaged,
IDE08804-IDE06260,Status: driv. profile selec. for ctr. differential-ID number,0,
IDE08804-MAS01156,Status: driv. profile selec. for ctr. differential-Communication status,OK,
IDE08804-MAS01447,Status: driv. profile selec. for ctr. differential-Act.val.,0,
IDE08956-MAS08051,H-V power distro-Power quota: thermal management,6400, W
IDE08956-MAS08052,H-V power distro-Power quota: 12 V electrical system,1500, W
IDE08956-MAS08054,H-V power distro-Power quota: comfort loads,3000, W
IDE08956-MAS13094,H-V power distro-Power allocation by engine electronics,ERROR,
IDE08956-MAS13095,H-V power distro-Power allocation by high-voltage battery charger,ERROR,
IDE08956-MAS13096,H-V power distro-Power allocation by hybrid battery management,ERROR,
IDE08956-MAS13097,H-V power distro-Power drawn by voltage transformer for electric drive,ERROR,
IDE08956-MAS13098,H-V power distro-Power drawn by thermal management,ERROR,
IDE09074-MAS01078,Vehicle properties-Vehicle type,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,36700,
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),18.00,
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,7.00, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,23.00,
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,39.00, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,1000, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,800, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,6.00,
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,10.00, l/100km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,456, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,25, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,456, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,456, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,ERROR,
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,ERROR,
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,ERROR,
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,285, km
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,285, km
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,not installed,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,8.00, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,7.00, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,6.00, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,7.00, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,6.00, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,6.00, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,7.00, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,23.00,
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,23.00,
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,23.00,
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,23.00,
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,23.00,
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,23.00,
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,23.00,
IDE09080-MAS12005,Energy storage unit-Tank capacity with conventional fuel for range calculation,32.00, l
IDE09080-MAS12006,Energy storage unit-Energy content of HV battery for range calculation,0,
IDE09080-MAS12007,Energy storage unit-Tank capacity with CNG for range calculation,0.00, l
IDE09080-MAS12008,Energy storage unit-Tank capacity with LPG for range calculation,0.00, l
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,Electrical OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,0, mA
IDE09293-MAS04344,Status of antenna 2 for phone-Reception level antenna 2,-113.00,
IDE09467,MAC address,00 36 F8 3C C0 EB,
IDE09468-MAS01390,IPv4 address-Block 1,0,
IDE09468-MAS01391,IPv4 address-Block 2,0,
IDE09468-MAS01392,IPv4 address-Block 3,0,
IDE09468-MAS01393,IPv4 address-Block 4,0,
IDE09469-MAS01390,IPv6 address-Block 1,00 00,
IDE09469-MAS01391,IPv6 address-Block 2,00 00,
IDE09469-MAS01392,IPv6 address-Block 3,00 00,
IDE09469-MAS01393,IPv6 address-Block 4,00 00,
IDE09469-MAS01394,IPv6 address-Block 5,00 00,
IDE09469-MAS01395,IPv6 address-Block 6,00 00,
IDE09469-MAS01396,IPv6 address-Block 7,00 00,
IDE09469-MAS01397,IPv6 address-Block 8,00 00,
IDE09891-SFT00081,Voltage converter for electric drive: status of electric drive-Drive Motor Control Module,Initializing,
IDE09891-SFT00195,Voltage converter for electric drive: status of electric drive-Drive Motor Control Module 3,Initializing,
IDE09891-SFT00206,Voltage converter for electric drive: status of electric drive-Drive Motor Control Module 2,Initializing,
IDE09892-MAS02832,Hybrid battery management: status of electric drive-Malfunction status,Initializing,
IDE09892-MAS03001,Hybrid battery management: status of electric drive-Mode,Initializing,
IDE09893-MAS17071,High voltage battery charger: status of electric drive-High-voltage charging management: current mode,Initializing,
IDE09893-MAS17072,High voltage battery charger: status of electric drive-High-voltage charging management: error status,Initializing,
IDE09894-MAS13356,Thermal management: status of electric drive-Error status additional air heating,Initializing,
IDE09894-MAS13357,Thermal management: status of electric drive-Mode additional air heating,Initializing,
IDE09894-MAS13358,Thermal management: status of electric drive-Error status A/C compressor,Initializing,
IDE09894-MAS13359,Thermal management: status of electric drive-Mode A/C compressor,Initializing,
IDE09895-MAS13099,Engine electronics: status of electric drive-Error status electric drive,Initializing,
IDE09895-MAS13100,Engine electronics: status of electric drive-Electric drive mode,Initializing,
IDE09895-MAS13101,Engine electronics: status of electric drive-Error status of electric machine,Initializing,
IDE09895-MAS13102,Engine electronics: status of electric drive-Electric machine mode,255,
IDE09896-MAS02832,Ctrl. module for contactless charging: status of electric drive-Malfunction status,Initializing,
IDE09896-MAS03001,Ctrl. module for contactless charging: status of electric drive-Mode,Initializing,
IDE09897-MAS02246,Volt. converter for elec. drive: high-volt. activ. restrict.-Timeout,not active,
IDE09897-MAS09518,Volt. converter for elec. drive: high-volt. activ. restrict.-Safety line,not active,
IDE09897-MAS09519,Volt. converter for elec. drive: high-volt. activ. restrict.-Message error,not active,
IDE09897-MAS09542,Volt. converter for elec. drive: high-volt. activ. restrict.-Error status init. error,not active,
IDE09897-MAS09544,Volt. converter for elec. drive: high-volt. activ. restrict.-No component function,not active,
IDE09897-MAS09546,Volt. converter for elec. drive: high-volt. activ. restrict.-Voltage disconnect. init. error,not active,
IDE09897-MAS12345,Volt. converter for elec. drive: high-volt. activ. restrict.-Active discharge fault,not active,
IDE09898-MAS02246,Hybrid batt. management:  H-V activ. restriction-Timeout,not active,
IDE09898-MAS03123,Hybrid batt. management:  H-V activ. restriction-Reduced performance,not active,
IDE09898-MAS09513,Hybrid batt. management:  H-V activ. restriction-Insulation test stage 1 failed,not active,
IDE09898-MAS09514,Hybrid batt. management:  H-V activ. restriction-Insulation test stage 2 failed,not active,
IDE09898-MAS09518,Hybrid batt. management:  H-V activ. restriction-Safety line,not active,
IDE09898-MAS09519,Hybrid batt. management:  H-V activ. restriction-Message error,not active,
IDE09898-MAS09520,Hybrid batt. management:  H-V activ. restriction-Safety connector,not active,
IDE09898-MAS09541,Hybrid batt. management:  H-V activ. restriction-Act. mode init. error,not active,
IDE09898-MAS09542,Hybrid batt. management:  H-V activ. restriction-Error status init. error,not active,
IDE09898-MAS09543,Hybrid batt. management:  H-V activ. restriction-Operating mode error,not active,
IDE09898-MAS09544,Hybrid batt. management:  H-V activ. restriction-No component function,not active,
IDE09898-MAS09545,Hybrid batt. management:  H-V activ. restriction-Sequence error,not active,
IDE09898-MAS09546,Hybrid batt. management:  H-V activ. restriction-Voltage disconnect. init. error,not active,
IDE09898-MAS12351,Hybrid batt. management:  H-V activ. restriction-HV voltage measurement error,not active,
IDE09898-MAS13068,Hybrid batt. management:  H-V activ. restriction-HV voltage measurement initialization error,not active,
IDE09899-MAS02246,Eng. electronics: H-V activ. restriction-Timeout,not active,
IDE09899-MAS09519,Eng. electronics: H-V activ. restriction-Message error,not active,
IDE09899-MAS09541,Eng. electronics: H-V activ. restriction-Act. mode init. error,not active,
IDE09899-MAS09545,Eng. electronics: H-V activ. restriction-Sequence error,not active,
IDE09899-MAS09547,Eng. electronics: H-V activ. restriction-Error status drive motor: init. error,not active,
IDE09899-MAS09548,Eng. electronics: H-V activ. restriction-Error status drive: init. error,not active,
IDE09899-MAS09549,Eng. electronics: H-V activ. restriction-Drive condition: init. error,not active,
IDE09899-MAS09550,Eng. electronics: H-V activ. restriction-Safety line power electronics,not active,
IDE09899-MAS09551,Eng. electronics: H-V activ. restriction-Part. oper.,not active,
IDE09899-MAS09552,Eng. electronics: H-V activ. restriction-HV shut-down due to operating strategy,not active,
IDE09899-MAS09553,Eng. electronics: H-V activ. restriction-no component function drive motor,not active,
IDE09899-MAS09554,Eng. electronics: H-V activ. restriction-no component function drive,not active,
IDE09900-MAS02246,H-V batt. charger H-V activ. restriction-Timeout,not active,
IDE09900-MAS09519,H-V batt. charger H-V activ. restriction-Message error,not active,
IDE09900-MAS09546,H-V batt. charger H-V activ. restriction-Voltage disconnect. init. error,not active,
IDE09901-MAS02246,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Timeout,not active,
IDE09901-MAS09518,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Safety line,not active,
IDE09901-MAS09519,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Message error,not active,
IDE09901-MAS09541,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Act. mode init. error,not active,
IDE09901-MAS09542,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Error status init. error,not active,
IDE09901-MAS09543,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Operating mode error,not active,
IDE09901-MAS09544,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-No component function,not active,
IDE09901-MAS09546,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Voltage disconnect. init. error,not active,
IDE09901-MAS12351,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-HV voltage measurement error,not active,
IDE09901-MAS13068,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-HV voltage measurement initialization error,not active,
IDE09902-MAS02246,A/C compressor: H-V activ. restriction-Timeout,not active,
IDE09902-MAS09518,A/C compressor: H-V activ. restriction-Safety line,not active,
IDE09902-MAS09519,A/C compressor: H-V activ. restriction-Message error,not active,
IDE09902-MAS09541,A/C compressor: H-V activ. restriction-Act. mode init. error,not active,
IDE09902-MAS09542,A/C compressor: H-V activ. restriction-Error status init. error,not active,
IDE09902-MAS09544,A/C compressor: H-V activ. restriction-No component function,not active,
IDE09902-MAS09545,A/C compressor: H-V activ. restriction-Sequence error,not active,
IDE09902-MAS12351,A/C compressor: H-V activ. restriction-HV voltage measurement error,not active,
IDE09903-MAS02246,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Timeout,not active,
IDE09903-MAS09518,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Safety line,not active,
IDE09903-MAS09519,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Message error,not active,
IDE09903-MAS09541,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Act. mode init. error,not active,
IDE09903-MAS09542,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Error status init. error,not active,
IDE09903-MAS09544,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-No component function,not active,
IDE09903-MAS09545,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Sequence error,not active,
IDE09903-MAS12351,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-HV voltage measurement error,not active,
IDE09904-MAS00799,Airbag: H-V activ. restriction-Airbag control module,not active,
IDE09904-MAS02246,Airbag: H-V activ. restriction-Timeout,not active,
IDE09904-MAS09519,Airbag: H-V activ. restriction-Message error,not active,
IDE09904-MAS09521,Airbag: H-V activ. restriction-Light accident detected,not active,
IDE09904-MAS09522,Airbag: H-V activ. restriction-Severe accident detected,not active,
IDE09905-MAS00799,H-V activ. restriction-Airbag control module,not active,
IDE09905-MAS08044,H-V activ. restriction-Thermal management,not active,
IDE09905-MAS09516,H-V activ. restriction-Engine Electronics,not active,
IDE09905-MAS09523,H-V activ. restriction-Transformer for electrical drive,not active,
IDE09905-MAS09524,H-V activ. restriction-Hybrid Battery Management,not active,
IDE09905-MAS09525,H-V activ. restriction-Ctrl. mod. for contactless charging,not active,
IDE09905-MAS09526,H-V activ. restriction-High-voltage battery charger,not active,
IDE09905-MAS09555,H-V activ. restriction-HV activation prohibited due to accident,not active,
IDE09905-MAS09557,H-V activ. restriction-HV activation prohibited due to de-activation,not active,
IDE09905-MAS09558,H-V activ. restriction-HV activation prohibited due to blocking,not active,
IDE09905-MAS12352,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 1,not active,
IDE09905-MAS12353,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 2,not active,
IDE10084-MAS03950,Hybrid drive operating mode-Combustion engine: status,Engine running,
IDE10084-MAS09828,Hybrid drive operating mode-Status of drive readiness hybrid,not active,
IDE10084-MAS09829,Hybrid drive operating mode-Engine start in start-stop mode active,not active,
IDE10084-MAS09830,Hybrid drive operating mode-Engine stop in start-stop mode active,not active,
IDE10084-MAS09831,Hybrid drive operating mode-Engine running or driver readiness at engine stop,active,
IDE10341-SFT09757,Install. list of subsystems: act. install.-Alternator,Available,
IDE10341-SFT09777,Install. list of subsystems: act. install.-Multi Function Steering Wheel Control Module,Available,
IDE10341-SFT09783,Install. list of subsystems: act. install.-Battery Monitoring Control Module,Available,
IDE10341-SFT09833,Install. list of subsystems: act. install.-Power Converter DC AC,Not available,
IDE10341-SFT09960,Install. list of subsystems: act. install.-Starter Generator Control Module Sub,Not available,
IDE10341-SFT10046,Install. list of subsystems: act. install.-Control module for steering wheel touch recognition,Not available,
IDE10342-IDE02068,Standard - ambient data 1: status-Time stamp,Current,
IDE10342-MAS00711,Standard - ambient data 1: status-Odometer reading,Current,
IDE10365-MAS10445,Message mirroring: bus allocation-Data bus CAN 1,Comfort data bus,
IDE10365-MAS10446,Message mirroring: bus allocation-Data bus CAN 2,not installed,
IDE10365-MAS10447,Message mirroring: bus allocation-Data bus CAN 3,Data bus Sensor/Hybrid,
IDE10365-MAS10448,Message mirroring: bus allocation-Data bus CAN 4,Databus Infotainment,
IDE10365-MAS10449,Message mirroring: bus allocation-Data bus CAN 5,Databus extended,
IDE10365-MAS10450,Message mirroring: bus allocation-Data bus CAN 6,Data bus diagnostics,
IDE10365-MAS11107,Message mirroring: bus allocation-Data bus CAN 7,not installed,
IDE10505,History data 45,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE10506,History data 46,000*2000-01-01-00:00*0*000*+0000*00.00*000.00*00.00*00.00*00.00*00.00*0000.00*00000**,
IDE10510-MAS00106,History data 50-Year,2018,
IDE10510-MAS00107,History data 50-Month,3,
IDE10510-MAS00108,History data 50-Day,2,
IDE10510-MAS00109,History data 50-Hours,1, H
IDE10510-MAS00110,History data 50-Minutes,0, min
IDE10510-MAS01632,History data 50-Status,activated,
IDE10510-ENG05061,History data 50-Activation_Bus_Knock_Out,activated,
IDE10510-ENG05062,History data 50-Activation_Cluster_Sleep,activated,
IDE10510-ENG05063,History data 50-Activation_Cluster_Start,activated,
IDE10510-ENG05064,History data 50-Activation_FUNC_Monitoring,activated,
IDE10510-ENG05058,History data 50-Activation_Keeping_Awake,activated,
IDE10510-ENG05059,History data 50-Activation_Logical_Wakeup,activated,
IDE10510-ENG05060,History data 50-Activation_Physical_Wakeup,activated,
IDE10510-ENG05065,History data 50-Activation_Subbus_Monitoring,activated,
IDE10510-ENG06839,History data 50-Aktivitaetsstatus_Busaktivitaet,activated,
IDE10510-ENG118680,History data 50-Cycle_Counter,10,
IDE10510-ENG06840,History data 50-Status_Activation_Car_Wake_Up,activated,
IDE10510-ENG118681,History data 50-Time_Since_Clamp_15_Off,0.00, H
IDE10510-ENG05057,History data 50-Total_Cycle_Counter,2606,
IDE10511-MAS03174,History data 51-Comfort data bus,1.10, H
IDE10511-MAS03175,History data 51-Databus extended,0.00, H
IDE10511-MAS03177,History data 51-Databus Infotainment,1.30, H
IDE10511-MAS03179,History data 51-Local data bus 2,0.10, H
IDE10511-MAS03180,History data 51-Local data bus,0.00, H
IDE10511-MAS03181,History data 51-Flexray databus,0.00, H
IDE10511-MAS05686,History data 51-Data bus diagnostics,0.00, H
IDE10511-MAS05972,History data 51-Local data bus 3,0.00, H
IDE10511-MAS07380,History data 51-Data bus Sensor/Hybrid,0.00, H
IDE10511-MAS10036,History data 51-Data bus diagnosis 2,0.00, H
IDE10511-MAS12183,History data 51-Convenience data bus 2,0.00, H
IDE10511-MAS14086,History data 51-Instrument panel data bus,0.00, H
IDE10511-ENG118679,History data 51-Total_Bus_Active,2.20, H
IDE10512-MAS03174,History data 52-Comfort data bus,32173,
IDE10512-MAS03175,History data 52-Databus extended,1,
IDE10512-MAS03177,History data 52-Databus Infotainment,13,
IDE10512-MAS03179,History data 52-Local data bus 2,0,
IDE10512-MAS03180,History data 52-Local data bus,0,
IDE10512-MAS03181,History data 52-Flexray databus,20,
IDE10512-MAS05686,History data 52-Data bus diagnostics,0,
IDE10512-MAS05972,History data 52-Local data bus 3,0,
IDE10512-MAS07380,History data 52-Data bus Sensor/Hybrid,7,
IDE10512-MAS10036,History data 52-Data bus diagnosis 2,0,
IDE10512-MAS12183,History data 52-Convenience data bus 2,0,
IDE10512-MAS14086,History data 52-Instrument panel data bus,0,
IDE10513-MAS03174,History data 53-Comfort data bus,5484,
IDE10513-MAS03175,History data 53-Databus extended,0,
IDE10513-MAS03177,History data 53-Databus Infotainment,201,
IDE10513-MAS03179,History data 53-Local data bus 2,0,
IDE10513-MAS03180,History data 53-Local data bus,0,
IDE10513-MAS03181,History data 53-Flexray databus,19,
IDE10513-MAS05686,History data 53-Data bus diagnostics,0,
IDE10513-MAS05972,History data 53-Local data bus 3,0,
IDE10513-MAS07380,History data 53-Data bus Sensor/Hybrid,747,
IDE10513-MAS10036,History data 53-Data bus diagnosis 2,0,
IDE10513-MAS12183,History data 53-Convenience data bus 2,0,
IDE10513-MAS14086,History data 53-Instrument panel data bus,0,
IDE10514-MAS03174,History data 54-Comfort data bus,26594,
IDE10514-MAS03175,History data 54-Databus extended,0,
IDE10514-MAS03177,History data 54-Databus Infotainment,1465,
IDE10514-MAS03179,History data 54-Local data bus 2,0,
IDE10514-MAS03180,History data 54-Local data bus,0,
IDE10514-MAS03181,History data 54-Flexray databus,2524,
IDE10514-MAS05686,History data 54-Data bus diagnostics,0,
IDE10514-MAS05972,History data 54-Local data bus 3,0,
IDE10514-MAS07380,History data 54-Data bus Sensor/Hybrid,9,
IDE10514-MAS10036,History data 54-Data bus diagnosis 2,0,
IDE10514-MAS12183,History data 54-Convenience data bus 2,0,
IDE10514-MAS14086,History data 54-Instrument panel data bus,0,
IDE10515-MAS03174,History data 55-Comfort data bus,0,
IDE10515-MAS03175,History data 55-Databus extended,0,
IDE10515-MAS03177,History data 55-Databus Infotainment,5736,
IDE10515-MAS03179,History data 55-Local data bus 2,0,
IDE10515-MAS03180,History data 55-Local data bus,0,
IDE10515-MAS03181,History data 55-Flexray databus,12,
IDE10515-MAS05686,History data 55-Data bus diagnostics,0,
IDE10515-MAS05972,History data 55-Local data bus 3,0,
IDE10515-MAS07380,History data 55-Data bus Sensor/Hybrid,0,
IDE10515-MAS10036,History data 55-Data bus diagnosis 2,0,
IDE10515-MAS12183,History data 55-Convenience data bus 2,0,
IDE10515-MAS14086,History data 55-Instrument panel data bus,0,
IDE10516-ENG05046,History data 56-Cluster_1_Start_Error_Counter,41438,
IDE10516-ENG30616,History data 56-Cluster_10_Counter,0,
IDE10516-ENG30617,History data 56-Cluster_10_Sleep_Error_Counter,0,
IDE10516-ENG30618,History data 56-Cluster_10_Start_Error_Counter,0,
IDE10516-ENG05047,History data 56-Cluster_2_Sleep_Error_Counter,0,
IDE10516-ENG05048,History data 56-Cluster_3_Counter,22716,
IDE10516-ENG05050,History data 56-Cluster_3_Sleep_Error_Counter,0,
IDE10516-ENG05049,History data 56-Cluster_3_Start_Error_Counter,24701,
IDE10516-ENG05051,History data 56-Cluster_4_Counter,29721,
IDE10516-ENG05053,History data 56-Cluster_4_Sleep_Error_Counter,3374,
IDE10516-ENG05052,History data 56-Cluster_4_Start_Error_Counter,34007,
IDE10516-ENG05054,History data 56-Cluster_5_Counter,46103,
IDE10516-ENG05056,History data 56-Cluster_5_Sleep_Error_Counter,10219,
IDE10516-ENG05055,History data 56-Cluster_5_Start_Error_Counter,11183,
IDE10516-ENG30619,History data 56-Cluster_6_Counter,27855,
IDE10516-ENG30620,History data 56-Cluster_6_Sleep_Error_Counter,19965,
IDE10516-ENG30621,History data 56-Cluster_6_Start_Error_Counter,9596,
IDE10516-ENG30622,History data 56-Cluster_7_Counter,22722,
IDE10516-ENG30623,History data 56-Cluster_7_Sleep_Error_Counter,19965,
IDE10516-ENG30624,History data 56-Cluster_7_Start_Error_Counter,9596,
IDE10516-ENG30625,History data 56-Cluster_8_Counter,26390,
IDE10516-ENG30626,History data 56-Cluster_8_Sleep_Error_Counter,19965,
IDE10516-ENG30627,History data 56-Cluster_8_Start_Error_Counter,9596,
IDE10516-ENG30628,History data 56-Cluster_9_Counter,26282,
IDE10516-ENG30629,History data 56-Cluster_9_Sleep_Error_Counter,0,
IDE10516-ENG30630,History data 56-Cluster_9_Start_Error_Counter,0,
IDE10516-ENG05045,History data 56-Cluster_Sleep_1_Error_Counter,25,
IDE10516-ENG05043,History data 56-Cluster_Start_1_Counter,4041,
IDE10516-ENG05044,History data 56-Cluster_Start_1_Error_Counter,54081,
IDE10516-ENG06838,History data 56-Cluster_Start_2_Counter,37811,
IDE10517-MAS00106,History data 57-Year,2019, yr
IDE10517-MAS00107,History data 57-Month,11, m
IDE10517-MAS00108,History data 57-Day,10, d
IDE10517-MAS00109,History data 57-Hours,19, H
IDE10517-MAS00110,History data 57-Minutes,50, min
IDE10517-ENG20570,History data 57-Bus_1,Unknown (0),
IDE10517-ENG20572,History data 57-Bus_2,Unknown (0),
IDE10517-ENG20574,History data 57-Bus_3,Unknown (0),
IDE10517-ENG20576,History data 57-Bus_4,Unknown (0),
IDE10517-ENG20578,History data 57-Bus_5,Unknown (0),
IDE10517-ENG20571,History data 57-Bus_Active_Time_1,0.00, H
IDE10517-ENG20573,History data 57-Bus_Active_Time_2,0.00, H
IDE10517-ENG20575,History data 57-Bus_Active_Time_3,0.00, H
IDE10517-ENG20577,History data 57-Bus_Active_Time_4,0.00, H
IDE10517-ENG20579,History data 57-Bus_Active_Time_5,0.00, H
IDE10517-ENG118680,History data 57-Cycle_Counter,9,
IDE10517-ENG118681,History data 57-Time_Since_Clamp_15_Off,0.00, H
IDE10518-ENG28832,History data 58-Awake_Time_ECU_1,0.00, H
IDE10518-ENG28835,History data 58-Awake_Time_ECU_2,0.00, H
IDE10518-ENG28838,History data 58-Awake_Time_ECU_3,0.00, H
IDE10518-ENG28841,History data 58-Awake_Time_ECU_4,0.00, H
IDE10518-ENG28844,History data 58-Awake_Time_ECU_5,0.00, H
IDE10518-ENG28833,History data 58-Bus_ECU_1,0,
IDE10518-ENG28836,History data 58-Bus_ECU_2,0,
IDE10518-ENG28839,History data 58-Bus_ECU_3,0,
IDE10518-ENG28842,History data 58-Bus_ECU_4,0,
IDE10518-ENG28845,History data 58-Bus_ECU_5,0,
IDE10518-ENG28834,History data 58-Cluster_ECU_1,00 00 00,
IDE10518-ENG28837,History data 58-Cluster_ECU_2,00 00 00,
IDE10518-ENG28840,History data 58-Cluster_ECU_3,00 00 00,
IDE10518-ENG28843,History data 58-Cluster_ECU_4,00 00 00,
IDE10518-ENG28846,History data 58-Cluster_ECU_5,00 00 00,
IDE10518-ENG118680,History data 58-Cycle_Counter,9,
IDE10518-ENG106038,History data 58-ECU_1,0,
IDE10518-ENG106039,History data 58-ECU_2,0,
IDE10518-ENG28620,History data 58-ECU_3,0,
IDE10518-ENG106040,History data 58-ECU_4,0,
IDE10518-ENG106041,History data 58-ECU_5,0,
IDE10518-ENG28618,History data 58-Repeat_Counter_ECU_1,0,
IDE10518-ENG28619,History data 58-Repeat_Counter_ECU_2,0,
IDE10518-ENG28621,History data 58-Repeat_Counter_ECU_3,0,
IDE10518-ENG28622,History data 58-Repeat_Counter_ECU_4,0.00,
IDE10518-ENG28623,History data 58-Repeat_Counter_ECU_5,0,
IDE10519-ENG28833,History data 59-Bus_ECU_1,15,
IDE10519-ENG28836,History data 59-Bus_ECU_2,15,
IDE10519-ENG28839,History data 59-Bus_ECU_3,15,
IDE10519-ENG28842,History data 59-Bus_ECU_4,0,
IDE10519-ENG28845,History data 59-Bus_ECU_5,0,
IDE10519-ENG28834,History data 59-Cluster_ECU_1,00 00 00,
IDE10519-ENG28837,History data 59-Cluster_ECU_2,00 00 00,
IDE10519-ENG28840,History data 59-Cluster_ECU_3,00 00 00,
IDE10519-ENG28843,History data 59-Cluster_ECU_4,00 00 00,
IDE10519-ENG28846,History data 59-Cluster_ECU_5,00 00 00,
IDE10519-ENG118680,History data 59-Cycle_Counter,9,
IDE10519-ENG106038,History data 59-ECU_1,139,
IDE10519-ENG106039,History data 59-ECU_2,74,
IDE10519-ENG28620,History data 59-ECU_3,132,
IDE10519-ENG106040,History data 59-ECU_4,0,
IDE10519-ENG106041,History data 59-ECU_5,0,
IDE10519-ENG28847,History data 59-Logical_Wakeup_ECU_1,2,
IDE10519-ENG28848,History data 59-Logical_Wakeup_ECU_2,1,
IDE10519-ENG28849,History data 59-Logical_Wakeup_ECU_3,1,
IDE10519-ENG28850,History data 59-Logical_Wakeup_ECU_4,0,
IDE10519-ENG28851,History data 59-Logical_Wakeup_ECU_5,0,
IDE10520-ENG28833,History data 60-Bus_ECU_1,15,
IDE10520-ENG28836,History data 60-Bus_ECU_2,0,
IDE10520-ENG28839,History data 60-Bus_ECU_3,0,
IDE10520-ENG28842,History data 60-Bus_ECU_4,0,
IDE10520-ENG28845,History data 60-Bus_ECU_5,0,
IDE10520-ENG28834,History data 60-Cluster_ECU_1,00 00 2B,
IDE10520-ENG28837,History data 60-Cluster_ECU_2,00 00 00,
IDE10520-ENG28840,History data 60-Cluster_ECU_3,00 00 00,
IDE10520-ENG28843,History data 60-Cluster_ECU_4,00 00 00,
IDE10520-ENG28846,History data 60-Cluster_ECU_5,00 00 00,
IDE10520-ENG118680,History data 60-Cycle_Counter,9,
IDE10520-ENG106038,History data 60-ECU_1,139,
IDE10520-ENG106039,History data 60-ECU_2,0,
IDE10520-ENG28620,History data 60-ECU_3,0,
IDE10520-ENG106040,History data 60-ECU_4,0,
IDE10520-ENG106041,History data 60-ECU_5,0,
IDE10520-ENG28852,History data 60-Physical_Wakeup_ECU_1,1,
IDE10520-ENG28853,History data 60-Physical_Wakeup_ECU_2,0,
IDE10520-ENG28854,History data 60-Physical_Wakeup_ECU_3,0,
IDE10520-ENG28855,History data 60-Physical_Wakeup_ECU_4,0,
IDE10520-ENG28856,History data 60-Physical_Wakeup_ECU_5,0,
IDE10521-ENG28833,History data 61-Bus_ECU_1,18,
IDE10521-ENG28836,History data 61-Bus_ECU_2,0,
IDE10521-ENG28839,History data 61-Bus_ECU_3,0,
IDE10521-ENG28842,History data 61-Bus_ECU_4,0,
IDE10521-ENG28845,History data 61-Bus_ECU_5,0,
IDE10521-ENG28857,History data 61-Bus_Knock_Out_ECU_1,1,
IDE10521-ENG30432,History data 61-Bus_Knock_Out_ECU_2,0,
IDE10521-ENG28858,History data 61-Bus_Knock_Out_ECU_3,0,
IDE10521-ENG28859,History data 61-Bus_Knock_Out_ECU_4,0,
IDE10521-ENG28860,History data 61-Bus_Knock_Out_ECU_5,0,
IDE10521-ENG118680,History data 61-Cycle_Counter,9,
IDE10521-ENG106038,History data 61-ECU_1,20,
IDE10521-ENG106039,History data 61-ECU_2,0,
IDE10521-ENG28620,History data 61-ECU_3,0,
IDE10521-ENG106040,History data 61-ECU_4,0,
IDE10521-ENG106041,History data 61-ECU_5,0,
IDE10522-ENG28833,History data 62-Bus_ECU_1,15,
IDE10522-ENG28836,History data 62-Bus_ECU_2,18,
IDE10522-ENG28839,History data 62-Bus_ECU_3,15,
IDE10522-ENG28842,History data 62-Bus_ECU_4,15,
IDE10522-ENG28845,History data 62-Bus_ECU_5,15,
IDE10522-ENG28861,History data 62-Car_Wake_Up_Counter_ECU_1,2,
IDE10522-ENG28863,History data 62-Car_Wake_Up_Counter_ECU_2,1,
IDE10522-ENG28865,History data 62-Car_Wake_Up_Counter_ECU_3,1,
IDE10522-ENG28867,History data 62-Car_Wake_Up_Counter_ECU_4,1,
IDE10522-ENG28869,History data 62-Car_Wake_Up_Counter_ECU_5,1,
IDE10522-ENG28862,History data 62-Car_Wake_Up_Time_ECU_1,0.00, H
IDE10522-ENG28864,History data 62-Car_Wake_Up_Time_ECU_2,0.00, H
IDE10522-ENG28866,History data 62-Car_Wake_Up_Time_ECU_3,0.00, H
IDE10522-ENG28868,History data 62-Car_Wake_Up_Time_ECU_4,0.00, H
IDE10522-ENG28870,History data 62-Car_Wake_Up_Time_ECU_5,0.00, H
IDE10522-ENG118680,History data 62-Cycle_Counter,9,
IDE10522-ENG106038,History data 62-ECU_1,14,
IDE10522-ENG106039,History data 62-ECU_2,20,
IDE10522-ENG28620,History data 62-ECU_3,74,
IDE10522-ENG106040,History data 62-ECU_4,76,
IDE10522-ENG106041,History data 62-ECU_5,139,
IDE10523-ENG28833,History data 63-Bus_ECU_1,23,
IDE10523-ENG28836,History data 63-Bus_ECU_2,15,
IDE10523-ENG28839,History data 63-Bus_ECU_3,15,
IDE10523-ENG28842,History data 63-Bus_ECU_4,15,
IDE10523-ENG28845,History data 63-Bus_ECU_5,23,
IDE10523-ENG28871,History data 63-Cluster_Sleep_ECU_1,255,
IDE10523-ENG28872,History data 63-Cluster_Sleep_ECU_2,4,
IDE10523-ENG28873,History data 63-Cluster_Sleep_ECU_3,4,
IDE10523-ENG28874,History data 63-Cluster_Sleep_ECU_4,3,
IDE10523-ENG28875,History data 63-Cluster_Sleep_ECU_5,2,
IDE10523-ENG118680,History data 63-Cycle_Counter,9,
IDE10523-ENG106038,History data 63-ECU_1,21,
IDE10523-ENG106039,History data 63-ECU_2,14,
IDE10523-ENG28620,History data 63-ECU_3,139,
IDE10523-ENG106040,History data 63-ECU_4,74,
IDE10523-ENG106041,History data 63-ECU_5,12,
IDE10524-ENG28833,History data 64-Bus_ECU_1,15,
IDE10524-ENG28836,History data 64-Bus_ECU_2,15,
IDE10524-ENG28839,History data 64-Bus_ECU_3,3955,
IDE10524-ENG28842,History data 64-Bus_ECU_4,0,
IDE10524-ENG28845,History data 64-Bus_ECU_5,8,
IDE10524-ENG28876,History data 64-Cluster_1_Start,0,
IDE10524-ENG28877,History data 64-Cluster_2_Start,0,
IDE10524-ENG28878,History data 64-Cluster_3_Start,0,
IDE10524-ENG28879,History data 64-Cluster_4_Start,0,
IDE10524-ENG28880,History data 64-Cluster_5_Start,0,
IDE10524-ENG28881,History data 64-Cluster_Start_ECU_1,5,
IDE10524-ENG28882,History data 64-Cluster_Start_ECU_2,3,
IDE10524-ENG28883,History data 64-Cluster_Start_ECU_3,3,
IDE10524-ENG28884,History data 64-Cluster_Start_ECU_4,530,
IDE10524-ENG28885,History data 64-Cluster_Start_ECU_5,0,
IDE10524-ENG118680,History data 64-Cycle_Counter,9,
IDE10524-ENG106038,History data 64-ECU_1,132,
IDE10524-ENG106039,History data 64-ECU_2,75,
IDE10524-ENG28620,History data 64-ECU_3,76,
IDE10524-ENG106040,History data 64-ECU_4,0,
IDE10524-ENG106041,History data 64-ECU_5,0,
IDE10525-ENG28887,History data 65-Awake_Time_FUNC_1,0.00, H
IDE10525-ENG28890,History data 65-Awake_Time_FUNC_2,0.10, H
IDE10525-ENG28893,History data 65-Awake_Time_FUNC_3,0.10, H
IDE10525-ENG28896,History data 65-Awake_Time_FUNC_4,0.00, H
IDE10525-ENG28899,History data 65-Awake_Time_FUNC_5,0.00, H
IDE10525-ENG118680,History data 65-Cycle_Counter,9,
IDE10525-ENG28886,History data 65-FUNC_1,2,
IDE10525-ENG28889,History data 65-FUNC_2,17,
IDE10525-ENG28892,History data 65-FUNC_3,18,
IDE10525-ENG28895,History data 65-FUNC_4,14,
IDE10525-ENG28898,History data 65-FUNC_5,11,
IDE10525-ENG28888,History data 65-Physical_Wakeup_FUNC_1,255,
IDE10525-ENG28891,History data 65-Physical_Wakeup_FUNC_2,255,
IDE10525-ENG28894,History data 65-Physical_Wakeup_FUNC_3,255,
IDE10525-ENG28897,History data 65-Physical_Wakeup_FUNC_4,112,
IDE10525-ENG28900,History data 65-Physical_Wakeup_FUNC_5,78,
IDE10526-MAS00106,History data 66-Year,2000,
IDE10526-MAS00107,History data 66-Month,1,
IDE10526-MAS00108,History data 66-Day,1,
IDE10526-MAS00109,History data 66-Hours,0, H
IDE10526-MAS00110,History data 66-Minutes,0, min
IDE10526-ENG28832,History data 66-Awake_Time_ECU_1,0.00, H
IDE10526-ENG28835,History data 66-Awake_Time_ECU_2,0.00, H
IDE10526-ENG28838,History data 66-Awake_Time_ECU_3,0.00, H
IDE10526-ENG28841,History data 66-Awake_Time_ECU_4,0.00, H
IDE10526-ENG28844,History data 66-Awake_Time_ECU_5,0.00, H
IDE10526-ENG28833,History data 66-Bus_ECU_1,0,
IDE10526-ENG28836,History data 66-Bus_ECU_2,0,
IDE10526-ENG28839,History data 66-Bus_ECU_3,0,
IDE10526-ENG28842,History data 66-Bus_ECU_4,0,
IDE10526-ENG28845,History data 66-Bus_ECU_5,0,
IDE10526-ENG28834,History data 66-Cluster_ECU_1,00 00 00,
IDE10526-ENG28837,History data 66-Cluster_ECU_2,00 00 00,
IDE10526-ENG28840,History data 66-Cluster_ECU_3,00 00 00,
IDE10526-ENG28843,History data 66-Cluster_ECU_4,00 00 00,
IDE10526-ENG28846,History data 66-Cluster_ECU_5,00 00 00,
IDE10526-ENG118680,History data 66-Cycle_Counter,0,
IDE10526-ENG106038,History data 66-ECU_1,0,
IDE10526-ENG106039,History data 66-ECU_2,0,
IDE10526-ENG28620,History data 66-ECU_3,0,
IDE10526-ENG106040,History data 66-ECU_4,0,
IDE10526-ENG106041,History data 66-ECU_5,0,
IDE10526-ENG28618,History data 66-Repeat_Counter_ECU_1,0,
IDE10526-ENG28619,History data 66-Repeat_Counter_ECU_2,0,
IDE10526-ENG28621,History data 66-Repeat_Counter_ECU_3,0,
IDE10526-ENG28622,History data 66-Repeat_Counter_ECU_4,0,
IDE10526-ENG28623,History data 66-Repeat_Counter_ECU_5,0,
IDE10526-ENG118681,History data 66-Time_Since_Clamp_15_Off,0.00, H
IDE10527-MAS00106,History data 67-Year,2000,
IDE10527-MAS00107,History data 67-Month,1,
IDE10527-MAS00108,History data 67-Day,1,
IDE10527-MAS00109,History data 67-Hours,0, H
IDE10527-MAS00110,History data 67-Minutes,0, min
IDE10527-ENG28833,History data 67-Bus_ECU_1,0,
IDE10527-ENG28836,History data 67-Bus_ECU_2,0,
IDE10527-ENG28839,History data 67-Bus_ECU_3,0,
IDE10527-ENG28842,History data 67-Bus_ECU_4,0,
IDE10527-ENG28845,History data 67-Bus_ECU_5,0,
IDE10527-ENG28834,History data 67-Cluster_ECU_1,00 00 00,
IDE10527-ENG28837,History data 67-Cluster_ECU_2,00 00 00,
IDE10527-ENG28840,History data 67-Cluster_ECU_3,00 00 00,
IDE10527-ENG28843,History data 67-Cluster_ECU_4,00 00 00,
IDE10527-ENG28846,History data 67-Cluster_ECU_5,00 00 00,
IDE10527-ENG118680,History data 67-Cycle_Counter,0,
IDE10527-ENG106038,History data 67-ECU_1,0,
IDE10527-ENG106039,History data 67-ECU_2,0,
IDE10527-ENG28620,History data 67-ECU_3,0,
IDE10527-ENG106040,History data 67-ECU_4,0,
IDE10527-ENG106041,History data 67-ECU_5,0,
IDE10527-ENG28847,History data 67-Logical_Wakeup_ECU_1,0,
IDE10527-ENG28848,History data 67-Logical_Wakeup_ECU_2,0,
IDE10527-ENG28849,History data 67-Logical_Wakeup_ECU_3,0,
IDE10527-ENG28850,History data 67-Logical_Wakeup_ECU_4,0,
IDE10527-ENG28851,History data 67-Logical_Wakeup_ECU_5,0,
IDE10527-ENG118681,History data 67-Time_Since_Clamp_15_Off,0.00, H
IDE10528-MAS00106,History data 68-Year,2018,
IDE10528-MAS00107,History data 68-Month,9,
IDE10528-MAS00108,History data 68-Day,1,
IDE10528-MAS00109,History data 68-Hours,7, H
IDE10528-MAS00110,History data 68-Minutes,19, min
IDE10528-ENG28833,History data 68-Bus_ECU_1,15,
IDE10528-ENG28836,History data 68-Bus_ECU_2,16,
IDE10528-ENG28839,History data 68-Bus_ECU_3,0,
IDE10528-ENG28842,History data 68-Bus_ECU_4,0,
IDE10528-ENG28845,History data 68-Bus_ECU_5,0,
IDE10528-ENG28834,History data 68-Cluster_ECU_1,00 00 00,
IDE10528-ENG28837,History data 68-Cluster_ECU_2,00 00 00,
IDE10528-ENG28840,History data 68-Cluster_ECU_3,00 00 00,
IDE10528-ENG28843,History data 68-Cluster_ECU_4,00 00 00,
IDE10528-ENG28846,History data 68-Cluster_ECU_5,00 00 00,
IDE10528-ENG118680,History data 68-Cycle_Counter,42,
IDE10528-ENG106038,History data 68-ECU_1,139,
IDE10528-ENG106039,History data 68-ECU_2,255,
IDE10528-ENG28620,History data 68-ECU_3,0,
IDE10528-ENG106040,History data 68-ECU_4,0,
IDE10528-ENG106041,History data 68-ECU_5,0,
IDE10528-ENG28852,History data 68-Physical_Wakeup_ECU_1,255,
IDE10528-ENG28853,History data 68-Physical_Wakeup_ECU_2,20,
IDE10528-ENG28854,History data 68-Physical_Wakeup_ECU_3,0,
IDE10528-ENG28855,History data 68-Physical_Wakeup_ECU_4,0,
IDE10528-ENG28856,History data 68-Physical_Wakeup_ECU_5,0,
IDE10528-ENG118681,History data 68-Time_Since_Clamp_15_Off,1.30, H
IDE10529-MAS00106,History data 69-Year,2018,
IDE10529-MAS00107,History data 69-Month,9,
IDE10529-MAS00108,History data 69-Day,18,
IDE10529-MAS00109,History data 69-Hours,21, H
IDE10529-MAS00110,History data 69-Minutes,9, min
IDE10529-ENG28833,History data 69-Bus_ECU_1,18,
IDE10529-ENG28836,History data 69-Bus_ECU_2,0,
IDE10529-ENG28839,History data 69-Bus_ECU_3,0,
IDE10529-ENG28842,History data 69-Bus_ECU_4,0,
IDE10529-ENG28845,History data 69-Bus_ECU_5,0,
IDE10529-ENG28857,History data 69-Bus_Knock_Out_ECU_1,38,
IDE10529-ENG30432,History data 69-Bus_Knock_Out_ECU_2,0,
IDE10529-ENG28858,History data 69-Bus_Knock_Out_ECU_3,0,
IDE10529-ENG28859,History data 69-Bus_Knock_Out_ECU_4,0,
IDE10529-ENG28860,History data 69-Bus_Knock_Out_ECU_5,0,
IDE10529-ENG118680,History data 69-Cycle_Counter,54,
IDE10529-ENG106038,History data 69-ECU_1,20,
IDE10529-ENG106039,History data 69-ECU_2,0,
IDE10529-ENG28620,History data 69-ECU_3,0,
IDE10529-ENG106040,History data 69-ECU_4,0,
IDE10529-ENG106041,History data 69-ECU_5,0,
IDE10529-ENG118681,History data 69-Time_Since_Clamp_15_Off,0.00, H
IDE10530-MAS00106,History data 70-Year,2018,
IDE10530-MAS00107,History data 70-Month,9,
IDE10530-MAS00108,History data 70-Day,18,
IDE10530-MAS00109,History data 70-Hours,21, H
IDE10530-MAS00110,History data 70-Minutes,9, min
IDE10530-ENG28833,History data 70-Bus_ECU_1,15,
IDE10530-ENG28836,History data 70-Bus_ECU_2,0,
IDE10530-ENG28839,History data 70-Bus_ECU_3,0,
IDE10530-ENG28842,History data 70-Bus_ECU_4,0,
IDE10530-ENG28845,History data 70-Bus_ECU_5,0,
IDE10530-ENG28861,History data 70-Car_Wake_Up_Counter_ECU_1,35,
IDE10530-ENG28863,History data 70-Car_Wake_Up_Counter_ECU_2,0,
IDE10530-ENG28865,History data 70-Car_Wake_Up_Counter_ECU_3,0,
IDE10530-ENG28867,History data 70-Car_Wake_Up_Counter_ECU_4,0,
IDE10530-ENG28869,History data 70-Car_Wake_Up_Counter_ECU_5,0,
IDE10530-ENG28862,History data 70-Car_Wake_Up_Time_ECU_1,0.00, H
IDE10530-ENG28864,History data 70-Car_Wake_Up_Time_ECU_2,0.00, H
IDE10530-ENG28866,History data 70-Car_Wake_Up_Time_ECU_3,0.00, H
IDE10530-ENG28868,History data 70-Car_Wake_Up_Time_ECU_4,0.00, H
IDE10530-ENG28870,History data 70-Car_Wake_Up_Time_ECU_5,0.00, H
IDE10530-ENG118680,History data 70-Cycle_Counter,54,
IDE10530-ENG106038,History data 70-ECU_1,14,
IDE10530-ENG106039,History data 70-ECU_2,0,
IDE10530-ENG28620,History data 70-ECU_3,0,
IDE10530-ENG106040,History data 70-ECU_4,0,
IDE10530-ENG106041,History data 70-ECU_5,0,
IDE10530-ENG118681,History data 70-Time_Since_Clamp_15_Off,0.00, H
IDE10531-MAS00106,History data 71-Year,2019,
IDE10531-MAS00107,History data 71-Month,11,
IDE10531-MAS00108,History data 71-Day,10,
IDE10531-MAS00109,History data 71-Hours,19, H
IDE10531-MAS00110,History data 71-Minutes,50, min
IDE10531-ENG28833,History data 71-Bus_ECU_1,23,
IDE10531-ENG28836,History data 71-Bus_ECU_2,0,
IDE10531-ENG28839,History data 71-Bus_ECU_3,0,
IDE10531-ENG28842,History data 71-Bus_ECU_4,0,
IDE10531-ENG28845,History data 71-Bus_ECU_5,0,
IDE10531-ENG28871,History data 71-Cluster_Sleep_ECU_1,255,
IDE10531-ENG28872,History data 71-Cluster_Sleep_ECU_2,0,
IDE10531-ENG28873,History data 71-Cluster_Sleep_ECU_3,0,
IDE10531-ENG28874,History data 71-Cluster_Sleep_ECU_4,0,
IDE10531-ENG28875,History data 71-Cluster_Sleep_ECU_5,0,
IDE10531-ENG118680,History data 71-Cycle_Counter,9,
IDE10531-ENG106038,History data 71-ECU_1,21,
IDE10531-ENG106039,History data 71-ECU_2,0,
IDE10531-ENG28620,History data 71-ECU_3,0,
IDE10531-ENG106040,History data 71-ECU_4,0,
IDE10531-ENG106041,History data 71-ECU_5,0,
IDE10531-ENG118681,History data 71-Time_Since_Clamp_15_Off,0.00, H
IDE10532-MAS00106,History data 72-Year,2019,
IDE10532-MAS00107,History data 72-Month,10,
IDE10532-MAS00108,History data 72-Day,5,
IDE10532-MAS00109,History data 72-Hours,16, H
IDE10532-MAS00110,History data 72-Minutes,53, min
IDE10532-ENG28833,History data 72-Bus_ECU_1,15,
IDE10532-ENG28836,History data 72-Bus_ECU_2,15,
IDE10532-ENG28839,History data 72-Bus_ECU_3,0,
IDE10532-ENG28842,History data 72-Bus_ECU_4,0,
IDE10532-ENG28845,History data 72-Bus_ECU_5,0,
IDE10532-ENG28876,History data 72-Cluster_1_Start,0,
IDE10532-ENG28877,History data 72-Cluster_2_Start,0,
IDE10532-ENG28878,History data 72-Cluster_3_Start,0,
IDE10532-ENG28879,History data 72-Cluster_4_Start,0,
IDE10532-ENG28880,History data 72-Cluster_5_Start,0,
IDE10532-ENG28834,History data 72-Cluster_ECU_1,0,
IDE10532-ENG28837,History data 72-Cluster_ECU_2,0,
IDE10532-ENG28840,History data 72-Cluster_ECU_3,0,
IDE10532-ENG28843,History data 72-Cluster_ECU_4,0,
IDE10532-ENG28846,History data 72-Cluster_ECU_5,0,
IDE10532-ENG28881,History data 72-Cluster_Start_ECU_1,255,
IDE10532-ENG28882,History data 72-Cluster_Start_ECU_2,38,
IDE10532-ENG28883,History data 72-Cluster_Start_ECU_3,0,
IDE10532-ENG28884,History data 72-Cluster_Start_ECU_4,0,
IDE10532-ENG28885,History data 72-Cluster_Start_ECU_5,0,
IDE10532-ENG118680,History data 72-Cycle_Counter,14,
IDE10532-ENG106038,History data 72-ECU_1,132,
IDE10532-ENG106039,History data 72-ECU_2,76,
IDE10532-ENG28620,History data 72-ECU_3,0,
IDE10532-ENG106040,History data 72-ECU_4,0,
IDE10532-ENG106041,History data 72-ECU_5,0,
IDE10532-ENG118681,History data 72-Time_Since_Clamp_15_Off,0.00, H
IDE10533-MAS00106,History data 73-Year,2000,
IDE10533-MAS00107,History data 73-Month,1,
IDE10533-MAS00108,History data 73-Day,1,
IDE10533-MAS00109,History data 73-Hours,0, H
IDE10533-MAS00110,History data 73-Minutes,0, min
IDE10533-ENG28907,History data 73-Activetime_MIB,0.00, H
IDE10533-ENG28904,History data 73-Activetime_MOST,0.00, H
IDE10533-ENG28901,History data 73-Activetime_MU,0.00, H
IDE10533-ENG118680,History data 73-Cycle_Counter,0,
IDE10533-ENG28903,History data 73-State_MMI,3,
IDE10533-ENG28906,History data 73-State_MOST,1,
IDE10533-ENG118681,History data 73-Time_Since_Clamp_15_Off,0.00, H
IDE10533-ENG28905,History data 73-WakeUps_MOST,1,
IDE10533-ENG28902,History data 73-WakeUps_MU,1,
IDE10534-MAS00106,History data 74-Year,2019,
IDE10534-MAS00107,History data 74-Month,11,
IDE10534-MAS00108,History data 74-Day,10,
IDE10534-MAS00109,History data 74-Hours,19, H
IDE10534-MAS00110,History data 74-Minutes,50, min
IDE10534-ENG28887,History data 74-Awake_Time_FUNC_1,0.00, H
IDE10534-ENG28890,History data 74-Awake_Time_FUNC_2,0.10, H
IDE10534-ENG28893,History data 74-Awake_Time_FUNC_3,0.10, H
IDE10534-ENG28896,History data 74-Awake_Time_FUNC_4,0.00, H
IDE10534-ENG28899,History data 74-Awake_Time_FUNC_5,0.00, H
IDE10534-ENG118680,History data 74-Cycle_Counter,9,
IDE10534-ENG28886,History data 74-FUNC_1,2,
IDE10534-ENG28889,History data 74-FUNC_2,17,
IDE10534-ENG28892,History data 74-FUNC_3,18,
IDE10534-ENG28895,History data 74-FUNC_4,14,
IDE10534-ENG28898,History data 74-FUNC_5,11,
IDE10534-ENG28888,History data 74-Physical_Wakeup_FUNC_1,255,
IDE10534-ENG28891,History data 74-Physical_Wakeup_FUNC_2,255,
IDE10534-ENG28894,History data 74-Physical_Wakeup_FUNC_3,255,
IDE10534-ENG28897,History data 74-Physical_Wakeup_FUNC_4,112,
IDE10534-ENG28900,History data 74-Physical_Wakeup_FUNC_5,78,
IDE10534-ENG118681,History data 74-Time_Since_Clamp_15_Off,0.00, H
IDE10535-MAS03174,History data 75-Comfort data bus,0,
IDE10535-MAS03175,History data 75-Databus extended,0,
IDE10535-MAS03177,History data 75-Databus Infotainment,0,
IDE10535-MAS03179,History data 75-Local data bus 2,0,
IDE10535-MAS03180,History data 75-Local data bus,0,
IDE10535-MAS03181,History data 75-Flexray databus,0,
IDE10535-MAS05686,History data 75-Data bus diagnostics,0,
IDE10535-MAS05972,History data 75-Local data bus 3,0,
IDE10535-MAS07380,History data 75-Data bus Sensor/Hybrid,0,
IDE10535-MAS10036,History data 75-Data bus diagnosis 2,0,
IDE10535-MAS12183,History data 75-Convenience data bus 2,0,
IDE10535-MAS14086,History data 75-Instrument panel data bus,0,
IDE10623-IDE04447,Status drive profile for roll stabilization-Function status,engaged,
IDE10623-IDE06260,Status drive profile for roll stabilization-ID number,0,
IDE10623-MAS01156,Status drive profile for roll stabilization-Communication status,OK,
IDE10623-MAS01447,Status drive profile for roll stabilization-Act.val.,0,
IDE10624-IDE04447,Status: driving profile selection for sport differential-Function status,engaged,
IDE10624-IDE06260,Status: driving profile selection for sport differential-ID number,0,
IDE10624-MAS01156,Status: driving profile selection for sport differential-Communication status,OK,
IDE10624-MAS01447,Status: driving profile selection for sport differential-Act.val.,0,
IDE10625-IDE04447,Stat.driv.profile select.for warn.in case of. risk of collision-Function status,not engaged,
IDE10625-IDE06260,Stat.driv.profile select.for warn.in case of. risk of collision-ID number,0,
IDE10625-MAS01156,Stat.driv.profile select.for warn.in case of. risk of collision-Communication status,OK,
IDE10625-MAS01447,Stat.driv.profile select.for warn.in case of. risk of collision-Act.val.,0,
IDE10626-IDE04447,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-Function status,not engaged,
IDE10626-IDE06260,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-ID number,0,
IDE10626-MAS01156,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-Communication status,OK,
IDE10626-MAS01447,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-Act.val.,0,
IDE10627-IDE04447,Status driving profile selection for hybrid battery management-Function status,engaged,
IDE10627-IDE06260,Status driving profile selection for hybrid battery management-ID number,0,
IDE10627-MAS01156,Status driving profile selection for hybrid battery management-Communication status,OK,
IDE10627-MAS01447,Status driving profile selection for hybrid battery management-Act.val.,0,
IDE10628-IDE04447,Status: driving profile selection for emerg. brake assistance-Function status,engaged,
IDE10628-IDE06260,Status: driving profile selection for emerg. brake assistance-ID number,0,
IDE10628-MAS01156,Status: driving profile selection for emerg. brake assistance-Communication status,OK,
IDE10628-MAS01447,Status: driving profile selection for emerg. brake assistance-Act.val.,2,
IDE10629-IDE04447,Status: driving profile select. for rear axle differential lock-Function status,not engaged,
IDE10629-IDE06260,Status: driving profile select. for rear axle differential lock-ID number,0,
IDE10629-MAS01156,Status: driving profile select. for rear axle differential lock-Communication status,OK,
IDE10629-MAS01447,Status: driving profile select. for rear axle differential lock-Act.val.,0,
IDE10644-MAS06193,Driving profile selection: statistics distance driven-Profile 1,6985, km
IDE10644-MAS06194,Driving profile selection: statistics distance driven-Profile 2,4293924539, km
IDE10644-MAS06195,Driving profile selection: statistics distance driven-Profile 3,13998, km
IDE10644-MAS06196,Driving profile selection: statistics distance driven-Profile 4,0, km
IDE10644-MAS06197,Driving profile selection: statistics distance driven-Profile 5,0, km
IDE10644-MAS06198,Driving profile selection: statistics distance driven-Profile 6,0, km
IDE10644-MAS06199,Driving profile selection: statistics distance driven-Profile 7,1940, km
IDE10644-MAS06200,Driving profile selection: statistics distance driven-Profile 8,0, km
IDE10644-MAS08875,Driving profile selection: statistics distance driven-Profile 9,0, km
IDE10644-MAS08876,Driving profile selection: statistics distance driven-Profile 10,0, km
IDE10644-MAS08877,Driving profile selection: statistics distance driven-Profile 11,0, km
IDE10644-MAS08878,Driving profile selection: statistics distance driven-Profile 12,0, km
IDE10644-MAS08879,Driving profile selection: statistics distance driven-Profile 13,0, km
IDE10644-MAS08880,Driving profile selection: statistics distance driven-Profile 14,0, km
IDE10644-MAS08881,Driving profile selection: statistics distance driven-Profile 15,0, km
IDE10655-MAS00106,Pause recommendation: hist. data-Year,2019, yr
IDE10655-MAS00107,Pause recommendation: hist. data-Month,11, m
IDE10655-MAS00108,Pause recommendation: hist. data-Day,9, d
IDE10655-MAS00109,Pause recommendation: hist. data-Hours,19, H
IDE10655-MAS00110,Pause recommendation: hist. data-Minutes,49, min
IDE10655-MAS00111,Pause recommendation: hist. data-Seconds,25, s
IDE10655-MAS03401,Pause recommendation: hist. data-Parameter 1,0.40,
IDE10655-MAS03402,Pause recommendation: hist. data-Parameter 2,1.00,
IDE10655-MAS03403,Pause recommendation: hist. data-Parameter 3,4.07,
IDE10655-MAS03404,Pause recommendation: hist. data-Parameter 4,4.23,
IDE10655-MAS03405,Pause recommendation: hist. data-Parameter 5,0, %
IDE10655-MAS10985,Pause recommendation: hist. data-Overall drive duration,18, min
IDE10655-MAS10986,Pause recommendation: hist. data-Drive duration in active speed range,7, min
IDE10655-MAS10987,Pause recommendation: hist. data-Drive duration with warning readiness,3, min
IDE10655-MAS10988,Pause recommendation: hist. data-No. of warnings issued,00,
IDE10655-MAS14091,Pause recommendation: hist. data-Travel duration until first warning,0, min
IDE10656-MAS10989,Pause recommended: use-No. of drives with activated pause recommendation,02 2F,
IDE10656-MAS10990,Pause recommended: use-No. of drives with deactivated pause recommendation,01 B3,
IDE10669-MAS11003,Internal SIM card: identification-ICCID,89011702272053729387,
IDE10669-MAS11004,Internal SIM card: identification-UICCID,8949320000292358119F,
IDE10927-MAS11760,Total static current-current total quiescent current,0, mA
IDE10927-MAS11761,Total static current-Total time quiescent current exceeded,0.0, H
IDE10973,Generator voltage,13.5, V
IDE10974,12 V elec. system: error status,no error,
IDE11191-MAS12370,Open circuit detection: H-V lines-Wiring circuit 1,Mode not active,
IDE11191-MAS12371,Open circuit detection: H-V lines-Wiring circuit 2,Mode not active,
IDE11282-IDE00704,Battery for emergency call module-Charge level,99, %
IDE11282-MAS00362,Battery for emergency call module-Battery voltage,3341, mV
IDE11282-MAS02201,Battery for emergency call module-Temperature,38, °C
IDE11282-MAS02476,Battery for emergency call module-install,installed,
IDE11282-MAS08415,Battery for emergency call module-Battery condition,01,
IDE11282-MAS12544,Battery for emergency call module-Charge status,was not charged,
IDE11284-MAS00106,Sending status of online functions: history data-Year,2255, yr
IDE11284-MAS00107,Sending status of online functions: history data-Month,15, m
IDE11284-MAS00108,Sending status of online functions: history data-Day,31, d
IDE11284-MAS00109,Sending status of online functions: history data-Hours,31, H
IDE11284-MAS00110,Sending status of online functions: history data-Minutes,63, min
IDE11284-MAS00111,Sending status of online functions: history data-Seconds,63, s
IDE11284-MAS07134,Sending status of online functions: history data-ID services,ID_OTV,
IDE11284-MAS12545,Sending status of online functions: history data-Send attempt: status,not OK,
IDE11286-MAS01737,Crash signal: status-Diagnosis,not active,
IDE11286-MAS03849,Crash signal: status-Crash signal,not active,
IDE11286-MAS11203,Crash signal: status-Output DTM,not active,
IDE11295-MAS12548,Mobile radio network ident.-Country recognition of mobile radio network,36,
IDE11295-MAS12549,Mobile radio network ident.-Operator recognition of mobile radio network,9A,
IDE11378,Mobile radio network: registration status,registered,
IDE11485-MAS02832,HV voltage converter: status for electric drive-Malfunction status,Initializing,
IDE11485-MAS03001,HV voltage converter: status for electric drive-Mode,Initializing,
IDE11486-MAS02246,HV battery charge management: HV activation restriction-Timeout,not active,
IDE11486-MAS09518,HV battery charge management: HV activation restriction-Safety line,not active,
IDE11486-MAS09519,HV battery charge management: HV activation restriction-Message error,not active,
IDE11486-MAS09541,HV battery charge management: HV activation restriction-Act. mode init. error,not active,
IDE11486-MAS09542,HV battery charge management: HV activation restriction-Error status init. error,not active,
IDE11486-MAS09543,HV battery charge management: HV activation restriction-Operating mode error,not active,
IDE11486-MAS09544,HV battery charge management: HV activation restriction-No component function,not active,
IDE11486-MAS09545,HV battery charge management: HV activation restriction-Sequence error,not active,
IDE11486-MAS12351,HV battery charge management: HV activation restriction-HV voltage measurement error,not active,
IDE11486-MAS13068,HV battery charge management: HV activation restriction-HV voltage measurement initialization error,not active,
IDE11586-IDE04447,Status drive profile selection for integral steering-Function status,not engaged,
IDE11586-IDE06260,Status drive profile selection for integral steering-ID number,0,
IDE11586-MAS01156,Status drive profile selection for integral steering-Communication status,OK,
IDE11586-MAS01447,Status drive profile selection for integral steering-Act.val.,0,
IDE11661-IDE06930,Autonomous operation states-Voltage converter: status: Status,ERROR,
IDE11661-IDE08958,Autonomous operation states-H-V system: start request,active,
IDE11661-MAS07605,Autonomous operation states-Charge request,ERROR,
IDE11661-MAS08040,Autonomous operation states-Automatic recharging of starter battery,active,
IDE11661-MAS13088,Autonomous operation states-Preconditioning of the interior,ERROR,
IDE11661-MAS13089,Autonomous operation states-High-voltage vehicle electrical system: status,not active,
IDE11662-MAS13090,H-V power distribution-Energy allocation thermal management,12700, Wh
IDE11662-MAS13091,H-V power distribution-Energy allocation12-volt electrical system,102300, Wh
IDE11662-MAS13092,H-V power distribution-Energy content of the high-voltage battery,ERROR,
IDE11663,H-V energy management mode,Standby-mode,
IDE11664,Requirement to recharge the H-V battery charging management,not active,
IDE11671-MAS02246,H-V power transformers: prohibition on turning-on H-V-Timeout,not active,
IDE11671-MAS09518,H-V power transformers: prohibition on turning-on H-V-Safety line,not active,
IDE11671-MAS09519,H-V power transformers: prohibition on turning-on H-V-Message error,not active,
IDE11671-MAS09541,H-V power transformers: prohibition on turning-on H-V-Act. mode init. error,not active,
IDE11671-MAS09542,H-V power transformers: prohibition on turning-on H-V-Error status init. error,not active,
IDE11671-MAS09543,H-V power transformers: prohibition on turning-on H-V-Operating mode error,not active,
IDE11671-MAS09544,H-V power transformers: prohibition on turning-on H-V-No component function,not active,
IDE11671-MAS09545,H-V power transformers: prohibition on turning-on H-V-Sequence error,not active,
IDE11671-MAS12351,H-V power transformers: prohibition on turning-on H-V-HV voltage measurement error,not active,
IDE11671-MAS13068,H-V power transformers: prohibition on turning-on H-V-HV voltage measurement initialization error,not active,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11675-MAS02246,Roll stabilization: prohibition on turning-on 48V-Timeout,not active,
IDE11675-MAS09519,Roll stabilization: prohibition on turning-on 48V-Message error,not active,
IDE11675-MAS09541,Roll stabilization: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11675-MAS09542,Roll stabilization: prohibition on turning-on 48V-Error status init. error,not active,
IDE11675-MAS09543,Roll stabilization: prohibition on turning-on 48V-Operating mode error,not active,
IDE11675-MAS09544,Roll stabilization: prohibition on turning-on 48V-No component function,not active,
IDE11675-MAS09545,Roll stabilization: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11682-IDE04447,Status of driving profile selection for exhaust flaps-Function status,engaged,
IDE11682-IDE06260,Status of driving profile selection for exhaust flaps-ID number,0,
IDE11682-MAS01156,Status of driving profile selection for exhaust flaps-Communication status,OK,
IDE11682-MAS01447,Status of driving profile selection for exhaust flaps-Act.val.,0,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,Initializing,
IDE11683-MAS13708,Engine electronics: status of 48V network-Error status of electrical compressor,Initializing,
IDE11683-MAS13715,Engine electronics: status of 48V network-Electro compressor mode,Initializing,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,Initializing,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,Initializing,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,255,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initializing,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initializing,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initializing,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initializing,
IDE11686-MAS02832,Anti-roll stabilization: status for 48V power-Malfunction status,Initializing,
IDE11686-MAS03001,Anti-roll stabilization: status for 48V power-Mode,Initializing,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery Energy Control Module 2,not active,
IDE11911-SFT00196,48V activation restriction-DC/DC Converter Control Module,not active,
IDE11911-SFT09769,48V activation restriction-Control module for auxiliary air heater,not active,
IDE11911-SFT09997,48V activation restriction-Electrical Charger,not active,
IDE12084-MAS14046,Status of component protection slaves-Node address of the immobilizer master,00 8B,
IDE12084-MAS14047,Status of component protection slaves-Generation of the immobilizer master,Generation 2,
IDE12084-MAS14048,Status of component protection slaves-Authentication status of the immobilizer master,valid authentication,
IDE12084-MAS14053,Status of component protection slaves-Status of start authentication,switched on,
IDE12084-MAS14054,Status of component protection slaves-Start authentication can be deactivated,No,
IDE12084-MAS14055,Status of component protection slaves-Immobilizer master sends authentication request,Yes,
IDE12084-MAS14056,Status of component protection slaves-Status of the IKA key for immobilizer master,IKA key stored,
IDE12084-MAS14059,Status of component protection slaves-Node address of the component protection participant,00 6F,
IDE12084-MAS14060,Status of component protection slaves-Prioritized participant,No,
IDE12084-MAS14061,Status of component protection slaves-Authentication status of the component protection participant,valid authentication,
IDE12084-MAS14062,Status of component protection slaves-Participant extended start authentication,No,
IDE12084-MAS14063,Status of component protection slaves-Component protection participant sends authentication request,No,
IDE12084-MAS14064,Status of component protection slaves-Status of the IKA key for component protection participants,IKA key stored,
IDE12581-ENG28833,History data 76-Bus_ECU_1,0,
IDE12581-ENG28836,History data 76-Bus_ECU_2,0,
IDE12581-ENG28839,History data 76-Bus_ECU_3,0,
IDE12581-ENG28842,History data 76-Bus_ECU_4,0,
IDE12581-ENG28845,History data 76-Bus_ECU_5,0,
IDE12581-ENG118680,History data 76-Cycle_Counter,9,
IDE12581-ENG106038,History data 76-ECU_1,0,
IDE12581-ENG106039,History data 76-ECU_2,0,
IDE12581-ENG28620,History data 76-ECU_3,0,
IDE12581-ENG106040,History data 76-ECU_4,0,
IDE12581-ENG106041,History data 76-ECU_5,0,
IDE12581-ENG30992,History data 76-ECU_Knock_Out_ECU_1,0, min
IDE12581-ENG30993,History data 76-ECU_Knock_Out_ECU_2,0, min
IDE12581-ENG30994,History data 76-ECU_Knock_Out_ECU_3,0, min
IDE12581-ENG30995,History data 76-ECU_Knock_Out_ECU_4,0, min
IDE12581-ENG30996,History data 76-ECU_Knock_Out_ECU_5,0, min
IDE12581-ENG31201,History data 76-Fkt_Ausloesung_ECU_1,0,
IDE12581-ENG31202,History data 76-Fkt_Ausloesung_ECU_2,0,
IDE12581-ENG31203,History data 76-Fkt_Ausloesung_ECU_3,0,
IDE12581-ENG31204,History data 76-Fkt_Ausloesung_ECU_4,0,
IDE12581-ENG31205,History data 76-Fkt_Ausloesung_ECU_5,0,
IDE12581-ENG32787,History data 76-Sub_System_Aktiv_ECU_1,0,
IDE12581-ENG32788,History data 76-Sub_System_Aktiv_ECU_2,0,
IDE12581-ENG32789,History data 76-Sub_System_Aktiv_ECU_3,0,
IDE12581-ENG32790,History data 76-Sub_System_Aktiv_ECU_4,0,
IDE12581-ENG32791,History data 76-Sub_System_Aktiv_ECU_5,0,
IDE12581-ENG33300,History data 76-Veto_Aktiv_ECU_1,0,
IDE12581-ENG33301,History data 76-Veto_Aktiv_ECU_2,0,
IDE12581-ENG33302,History data 76-Veto_Aktiv_ECU_3,0,
IDE12581-ENG33303,History data 76-Veto_Aktiv_ECU_4,0,
IDE12581-ENG33304,History data 76-Veto_Aktiv_ECU_5,0,
IDE12583-MAS00106,History data 77-Year,2000, yr
IDE12583-MAS00107,History data 77-Month,1, m
IDE12583-MAS00108,History data 77-Day,1, d
IDE12583-MAS00109,History data 77-Hours,0, H
IDE12583-MAS00110,History data 77-Minutes,0, min
IDE12583-ENG28833,History data 77-Bus_ECU_1,0,
IDE12583-ENG28836,History data 77-Bus_ECU_2,0,
IDE12583-ENG28839,History data 77-Bus_ECU_3,0,
IDE12583-ENG28842,History data 77-Bus_ECU_4,0,
IDE12583-ENG28845,History data 77-Bus_ECU_5,0,
IDE12583-ENG118680,History data 77-Cycle_Counter,0,
IDE12583-ENG106038,History data 77-ECU_1,0,
IDE12583-ENG106039,History data 77-ECU_2,0,
IDE12583-ENG28620,History data 77-ECU_3,0,
IDE12583-ENG106040,History data 77-ECU_4,0,
IDE12583-ENG106041,History data 77-ECU_5,0,
IDE12583-ENG30992,History data 77-ECU_Knock_Out_ECU_1,0, min
IDE12583-ENG30993,History data 77-ECU_Knock_Out_ECU_2,0, min
IDE12583-ENG30994,History data 77-ECU_Knock_Out_ECU_3,0, min
IDE12583-ENG30995,History data 77-ECU_Knock_Out_ECU_4,0, min
IDE12583-ENG30996,History data 77-ECU_Knock_Out_ECU_5,0, min
IDE12583-ENG31201,History data 77-Fkt_Ausloesung_ECU_1,0,
IDE12583-ENG31202,History data 77-Fkt_Ausloesung_ECU_2,0,
IDE12583-ENG31203,History data 77-Fkt_Ausloesung_ECU_3,0,
IDE12583-ENG31204,History data 77-Fkt_Ausloesung_ECU_4,0,
IDE12583-ENG31205,History data 77-Fkt_Ausloesung_ECU_5,0,
IDE12583-ENG32787,History data 77-Sub_System_Aktiv_ECU_1,0,
IDE12583-ENG32788,History data 77-Sub_System_Aktiv_ECU_2,0,
IDE12583-ENG32789,History data 77-Sub_System_Aktiv_ECU_3,0,
IDE12583-ENG32790,History data 77-Sub_System_Aktiv_ECU_4,0,
IDE12583-ENG32791,History data 77-Sub_System_Aktiv_ECU_5,0,
IDE12583-ENG118681,History data 77-Time_Since_Clamp_15_Off,0.00, H
IDE12583-ENG33300,History data 77-Veto_Aktiv_ECU_1,0,
IDE12583-ENG33301,History data 77-Veto_Aktiv_ECU_2,0,
IDE12583-ENG33302,History data 77-Veto_Aktiv_ECU_3,0,
IDE12583-ENG33303,History data 77-Veto_Aktiv_ECU_4,0,
IDE12583-ENG33304,History data 77-Veto_Aktiv_ECU_5,0,
IDE13018-MAS02246,Electrical drive 2: high-voltage switch on prevention-Timeout,not active,
IDE13018-MAS09518,Electrical drive 2: high-voltage switch on prevention-Safety line,not active,
IDE13018-MAS09519,Electrical drive 2: high-voltage switch on prevention-Message error,not active,
IDE13018-MAS09542,Electrical drive 2: high-voltage switch on prevention-Error status init. error,not active,
IDE13018-MAS09544,Electrical drive 2: high-voltage switch on prevention-No component function,not active,
IDE13018-MAS09546,Electrical drive 2: high-voltage switch on prevention-Voltage disconnect. init. error,not active,
IDE13018-MAS12345,Electrical drive 2: high-voltage switch on prevention-Active discharge fault,not active,
IDE13019-MAS02246,Electrical drive 3: high-voltage switch on prevention-Timeout,not active,
IDE13019-MAS09518,Electrical drive 3: high-voltage switch on prevention-Safety line,not active,
IDE13019-MAS09519,Electrical drive 3: high-voltage switch on prevention-Message error,not active,
IDE13019-MAS09542,Electrical drive 3: high-voltage switch on prevention-Error status init. error,not active,
IDE13019-MAS09544,Electrical drive 3: high-voltage switch on prevention-No component function,not active,
IDE13019-MAS09546,Electrical drive 3: high-voltage switch on prevention-Voltage disconnect. init. error,not active,
IDE13019-MAS12345,Electrical drive 3: high-voltage switch on prevention-Active discharge fault,not active,
IDE13032,Emergency call module: start condition status,Not available,
IDE13033-MAS15531,Communication status of emergency call module: analysis-Components 1,Not available,
IDE13033-MAS15532,Communication status of emergency call module: analysis-Components 2,Not available,
IDE13033-MAS15533,Communication status of emergency call module: analysis-Components 3,Not available,
IDE13033-MAS15534,Communication status of emergency call module: analysis-Components 4,Available,
IDE13033-MAS15535,Communication status of emergency call module: analysis-Components 5,Available,
IDE13057-MAS15615,Lithium ions starter battery-Battery: fault status,no error,
IDE13057-MAS15620,Lithium ions starter battery-Battery cut-out element: fault status,no error,
IDE13140,History data 78,,
IDE13140,History data 78,*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0C000000*00000000*00000000*00000000*00**,
IDE13140,History data 78,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0C000000*00000000*00000000*00000000*00**,
IDE13140,History data 78,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00,
IDE13141,History data 79,1048574*2000-00-00-00:00:00**,
IDE13141,History data 79,,
IDE13142,History data 80,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0C000000*00000000*00000000*00000000*00**,
IDE13142,History data 80,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00,
IDE13142,History data 80,,
IDE13142,History data 80,*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0C000000*00000000*00000000*00000000*00**,
IDE13398-ENG39192,Driving profile history data 5-Battery_Charge,0, min
IDE13398-ENG39193,Driving profile history data 5-Battery_Hold,0, min
IDE13398-ENG39289,Driving profile history data 5-EV,0, min
IDE13398-ENG98636,Driving profile history data 5-Hybrid,0, min
IDE13402-MAS06193,Driving profile history data 6-Profile 1,0, km
IDE13402-MAS06194,Driving profile history data 6-Profile 2,0, km
IDE13402-MAS06195,Driving profile history data 6-Profile 3,0, km
IDE13402-MAS06196,Driving profile history data 6-Profile 4,0, km
IDE13573-IDE11095,Advanced StartStop display version-Rqmt. spec. version,,
IDE13573-MAS01483,Advanced StartStop display version-Softwareversion,,
IDE13673,Microphone 2 status,Not available,
IDE13674,Microphone 2 voltage consumption,0.00, mA
IDE13754-MAS03095,Diagnosis filter: status-Function status,Function is not active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755,Diagnosis filter: history data,,
IDE13848-MAS06568,Onboard network components: medium-voltage-Auxiliary Heater,not installed,
IDE13848-MAS10933,Onboard network components: medium-voltage-Roll stabilization,not installed,
IDE13848-MAS11243,Onboard network components: medium-voltage-Battery Management 48V,not installed,
IDE13848-MAS16949,Onboard network components: medium-voltage-Active setup verification,not installed,
IDE13848-MAS16953,Onboard network components: medium-voltage-Belt driven starter generator 48V,not installed,
IDE13848-MAS17010,Onboard network components: medium-voltage-48V Vehicle Electrical System Storage Capacitor,not installed,
IDE13848-SFT00196,Onboard network components: medium-voltage-DC/DC Converter Control Module,not installed,
IDE13848-SFT09997,Onboard network components: medium-voltage-Electrical Charger,not installed,
IDE13849-IDE12114,Onboard network diagnosis 48V 1-48V vehicle electrical system diagnosis,requested,
IDE13849-MAS01867,Onboard network diagnosis 48V 1-Measurement,OK,
IDE13849-MAS15721,Onboard network diagnosis 48V 1-Battery management 48V power supply battery,Initializing,
IDE13850-MAS01867,Onboard network diagnosis 48V 2-Measurement,OK,
IDE13850-MAS06864,Onboard network diagnosis 48V 2-Generator actual voltage,Initializing,
IDE13850-MAS15119,Onboard network diagnosis 48V 2-48V vehicle electrical system,not active,
IDE13850-MAS15722,Onboard network diagnosis 48V 2-Battery management 48V: actual voltage,Initializing,
IDE13850-MAS16957,Onboard network diagnosis 48V 2-Electrically driven compressor: current voltage,Initializing,
IDE13850-MAS16958,Onboard network diagnosis 48V 2-Voltage converter: current voltage,Initializing,
IDE13850-MAS16959,Onboard network diagnosis 48V 2-Roll stabilization front axis current voltage,Initializing,
IDE13850-MAS16960,Onboard network diagnosis 48V 2-Roll stabilization rear axis current voltage,Initializing,
IDE13850-MAS16961,Onboard network diagnosis 48V 2-Active setup verification front axle current voltage,Initializing,
IDE13850-MAS16962,Onboard network diagnosis 48V 2-Active setup verification rear axle current voltage,Initializing,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,0E,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,11,
MAS00464-MAS00108,Standard - ambient data 1-Day,10,
MAS00464-MAS00109,Standard - ambient data 1-Hours,20,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,25,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,47,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,114,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,32501,
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,not activated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,not activated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,3,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,Audi,
MAS00769-MAS01288,Multifunction steering wheel control module-Signal horn,not activated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Unknown (0),
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Unknown (0),
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,9,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,not activated,
MAS01758-IDE00500,Date/time-Hour,1, H
MAS01758-IDE00501,Date/time-Minute,25, min
MAS01758-IDE00502,Date/time-Year,2019, yr
MAS01758-IDE00503,Date/time-Month,11, m
MAS01758-IDE00504,Date/time-Day,11, d
MAS01758-MAS00111,Date/time-Seconds,47, s
MAS01758-MAS02238,Date/time-Current,Winter time,
MAS01758-MAS03617,Date/time-Time zone,0.00, H
MAS04394-IDE03580,Connection status-Country code for mobile network,310,
MAS04394-IDE07699,Connection status-Mobile network operator,410,
MAS04394-MAS03991,Connection status-Reception level antenna 1,18.91, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,Unknown (19),
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-MAS13670,Connection status-Mobile radio cell identification,59013,
MAS04394-ENG123308,Connection status-TCP_Connection_State,not active,
MAS06413,Audio signal output,Electrical OK,
MAS08178-IDE02493,Crash information-Automatic door unlocking,Not available,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08178-MAS08956,Crash information-Automatic emergency call activated:Fuel shut-off,Not available,
MAS08200,Emergency call speaker status,Electrical OK,
ENG06732-ENG06827,12V_zustart_prohibition-12V_start_system_error,00 04,
ENG06732-ENG06826,12V_zustart_prohibition-12V_zustart_prohibition_on_drive,00 58,
ENG06732-ENG06825,12V_zustart_prohibition-12V_zustart_prohibition_on_stop,00 00,
ENG08764-MAS01867,48V_overvoltage_check-Measurement,OK,
ENG08764-ENG09344,48V_overvoltage_check-Bms_48V_actual_voltage,Initializing,
ENG08764-ENG09345,48V_overvoltage_check-Bms_48V_Soc,Initializing,
ENG08769-MAS11874,48V_Zero_potential_status-Overall status,Initializing,
ENG04784,Break_Recommendation_Index,1.00,
ENG04785-ENG126257,Break_Recommendation_TTNR-TTNR_DS,0,
ENG04785-ENG126256,Break_Recommendation_TTNR-TTNR_SW,60042,
ENG06743,Challenge_KS,65 45 3D 03,
ENG06744-MAS06854,Checksumme_KS-Version,81,
ENG06744-MAS06855,Checksumme_KS-Test sum,E2 F8 DF 7C,
ENG08767-ENG09366,coldstart_requirement_engine-requirement_12V_start,active,
ENG08767-ENG09367,coldstart_requirement_engine-requirement_48V_start,not active,
ENG118785-ENG118741,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Error_Indication,0,
ENG118785-ENG118742,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Indication_State,0,
ENG118785-ENG118743,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State,0,
ENG118785-ENG118744,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State_Value,0,
ENG118784-ENG05030,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Active_Body_Control,not active,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG05036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Autonomous_Emergency_Breaking,not active,
ENG118784-ENG05035,Driv._Prof._Sel._Coord._Retry_State-Retry_State_battery_management,not active,
ENG118784-ENG118738,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Beam_Control,not active,
ENG118784-ENG05018,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG05023,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Centre_and_rear_axle_differential,not active,
ENG118784-ENG118735,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Climatronic,not active,
ENG118784-ENG05029,Driv._Prof._Sel._Coord._Retry_State-Retry_State_corner_assist,not active,
ENG118784-ENG05032,Driv._Prof._Sel._Coord._Retry_State-Retry_State_cruise_control,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG05024,Driv._Prof._Sel._Coord._Retry_State-Retry_State_e_quattro,not active,
ENG118784-ENG05031,Driv._Prof._Sel._Coord._Retry_State-Retry_State_E_Sound,not active,
ENG118784-ENG05038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Differential_Lock,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG05037,Driv._Prof._Sel._Coord._Retry_State-Retry_State_engine_operating_state,not active,
ENG118784-ENG05021,Driv._Prof._Sel._Coord._Retry_State-Retry_State_exhaust_gas_flaps,not active,
ENG118784-ENG05039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Forward_Collision_Warning_Objects,not active,
ENG118784-ENG05040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Forward_Collision_Warning_Pedestrian,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG05041,Driv._Prof._Sel._Coord._Retry_State-Retry_State_integral_steering,not active,
ENG118784-ENG05034,Driv._Prof._Sel._Coord._Retry_State-Retry_State_lift_control_unit,not active,
ENG118784-ENG05025,Driv._Prof._Sel._Coord._Retry_State-Retry_State_matrixbeam,not active,
ENG118784-ENG05022,Driv._Prof._Sel._Coord._Retry_State-Retry_State_middle_differential,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG05015,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Rear_Axle_Differential,not active,
ENG118784-ENG05027,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_axle_steering,not active,
ENG118784-ENG05017,Driv._Prof._Sel._Coord._Retry_State-Retry_State_ride-height_control_system,not active,
ENG118784-ENG118740,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Routing_Adaption,not active,
ENG118784-ENG05020,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sailing_suggestion,not active,
ENG118784-ENG05033,Driv._Prof._Sel._Coord._Retry_State-Retry_State_servo_tronic,not active,
ENG118784-ENG05019,Driv._Prof._Sel._Coord._Retry_State-Retry_State_sidepanel_seat,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG05026,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Spoiler_Control_Unit,not active,
ENG118784-ENG05028,Driv._Prof._Sel._Coord._Retry_State-Retry_State_stabilisation_control_unit,not active,
ENG118784-ENG118731,Driv._Prof._Sel._Coord._Retry_State-Retry_State_StartStop,not active,
ENG118784-ENG05016,Driv._Prof._Sel._Coord._Retry_State-Retry_State_steering_control_unit,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognized,
ENG118786-ENG05042,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile_BMA,not recognized,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,3,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG06742-MAS02832,eABC_48V_status-Malfunction status,Initializing,
ENG06742-MAS03001,eABC_48V_status-Mode,Initializing,
ENG118766,eASS_operation_status,active,
ENG06152-ENG112328,eCall Active Cell ID-CID,0D DA E6 85,
ENG06150,eCall_Current_Heading,118, °
ENG06149-MAS01779,eCall_Current_Position-Length,81, °
ENG06149-MAS01780,eCall_Current_Position-Width,26, °
ENG06151-ENG06150,eCall_Current_Position_Confidence-eCall_Current_Heading,100, m
ENG06154-MAS01779,eCall_Last_Valid_Position-Length,81, °
ENG06154-MAS01780,eCall_Last_Valid_Position-Width,26, °
ENG06153-ENG98842,eCall_Position_Confidence-Position,100, m
ENG04786-ENG05075,Ehr_segment_load-attribute_pool,0.00,
ENG04786-ENG05074,Ehr_segment_load-segment_pool,0.00,
ENG04786-ENG05076,Ehr_segment_load-speedlimit_pool,0.00,
ENG106121-ENG101157,EM_Battery_charge_discharge-BZE_Q_Elad,4248.1, Ah
ENG106121-ENG100159,EM_Battery_charge_discharge-BZE_Q_Lad,4336.3, Ah
ENG04782,EM_bdm_error_state,0,
ENG106123,EM_blAlternator On,On,
ENG26761,EM_Current_Control,active,
ENG118437,EM_IAlternatorReserve,98.3, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,650, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,85, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,81, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,Release,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,Release,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,Release,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,Release,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,Release,
ENG118780-ENG04973,EM_Recuperation_Precondition-battery_disconnected,Release,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,Release,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,Release,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,Release,
ENG118780-ENG30744,EM_Recuperation_Precondition-dc_source_activity,Release,
ENG118780-ENG30745,EM_Recuperation_Precondition-dc_source_diagnosis,Release,
ENG118780-ENG118444,EM_Recuperation_Precondition-generator_workload,Release,
ENG118780-ENG31832,EM_Recuperation_Precondition-hv_cutoff_level,Release,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,Release,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,Release,
ENG118780-ENG32123,EM_Recuperation_Precondition-mv_cutoff_level,Release,
ENG118780-ENG102605,EM_Recuperation_Precondition-outside_temperature,Release,
ENG118780-ENG104256,EM_Recuperation_Precondition-production_mode,Release,
ENG118780-ENG04974,EM_Recuperation_Precondition-trailer_dedection,Release,
ENG118780-ENG111086,EM_Recuperation_Precondition-Transport_Mode,Release,
ENG106169,EM_valHlkLevelRequirement,500, W
ENG106169,EM_valHlkLevelRequirement,Stage 1,
ENG06717,EM_vehicle_bus_state,01 03 00 3D,
ENG04777,EM_vehicle_state,02 14,
ENG04779-ENG04996,EM_voltage_control_state-EM_das_control_state,0,
ENG04779-ENG04995,EM_voltage_control_state-EM_gas_control_state,1,
ENG04779-ENG04997,EM_voltage_control_state-EM_ras_control_state,0,
ENG04779-ENG04998,EM_voltage_control_state-EM_Ureg_control_state,5,
ENG04776,EMZ_state,6,
ENG04775,engine_identifier,3,
ENG04780,freewheel_info,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,160101,
ENG118782-ENG05091,Gateway app. software identification-software_version_cGW,090025,
ENG118782-ENG05083,Gateway app. software identification-software_version_cha,250300,
ENG118782-ENG05090,Gateway app. software identification-software_version_eHorizont,130600,
ENG118782-ENG05085,Gateway app. software identification-software_version_HvEm,120800,
ENG118782-ENG05086,Gateway app. software identification-software_version_HvK,120800,
ENG118782-ENG05092,Gateway app. software identification-software_version_MvEM,120800,
ENG118782-ENG05093,Gateway app. software identification-software_version_MVK,120800,
ENG118782-ENG05084,Gateway app. software identification-software_version_NvEm,120800,
ENG118782-ENG05087,Gateway app. software identification-software_version_ObDc,080524,
ENG118782-ENG05088,Gateway app. software identification-software_version_PE,060610,
ENG118782-ENG05089,Gateway app. software identification-software_version_range,100105,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,110201,
ENG04773-ENG04886,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x03,00 00 00,
ENG04773-ENG31556,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x04,00 00 00,
ENG04773-ENG31557,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x05,00 00 00,
ENG04773-ENG31558,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x06,00 00 00,
ENG04773-ENG31559,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x07,00 00 00,
ENG04773-ENG31560,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x08,00 00 00,
ENG04773-ENG04887,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0A,00 00 00,
ENG04773-ENG04888,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0B,00 00 00,
ENG04773-ENG04889,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0C,00 00 00,
ENG04773-ENG04890,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0E,00 00 00,
ENG04773-ENG04891,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0F,00 00 00,
ENG04773-ENG04892,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x12,00 00 00,
ENG04773-ENG04893,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x13,00 00 00,
ENG04773-ENG04894,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x14,00 00 00,
ENG04773-ENG04895,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x15,00 00 00,
ENG04773-ENG04896,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x16,00 00 00,
ENG04773-ENG04897,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1A,00 00 00,
ENG04773-ENG04898,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1B,00 00 00,
ENG04773-ENG04899,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1C,00 00 00,
ENG04773-ENG04900,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1E,00 00 00,
ENG04773-ENG04901,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x23,10 00 00,
ENG04773-ENG04902,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x24,00 00 00,
ENG04773-ENG04903,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x27,04 00 00,
ENG04773-ENG04904,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2A,00 00 00,
ENG04773-ENG04905,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2B,00 00 00,
ENG04773-ENG04906,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2C,00 00 00,
ENG04773-ENG04907,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2D,00 00 00,
ENG04773-ENG04908,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2E,00 00 00,
ENG04773-ENG04909,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x30,00 00 00,
ENG04773-ENG04910,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x31,00 00 00,
ENG04773-ENG04911,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x32,00 00 00,
ENG04773-ENG04912,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x3B,00 00 00,
ENG04773-ENG04913,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x41,00 00 00,
ENG04773-ENG04914,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x42,00 00 00,
ENG04773-ENG31561,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x43,00 00 00,
ENG04773-ENG04915,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x44,00 01 00,
ENG04773-ENG04916,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x46,00 00 00,
ENG04773-ENG04917,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x47,02 00 00,
ENG04773-ENG116879,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x49,00 00 00,
ENG04773-ENG04918,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4A,00 00 00,
ENG04773-ENG04919,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4B,01 00 00,
ENG04773-ENG04920,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4C,08 00 00,
ENG04773-ENG04921,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4D,08 00 00,
ENG04773-ENG04922,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4E,00 00 00,
ENG04773-ENG04923,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4F,00 00 00,
ENG04773-ENG04924,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x53,00 00 00,
ENG04773-ENG04925,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x56,00 00 00,
ENG04773-ENG04926,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x57,00 00 00,
ENG04773-ENG31562,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x59,00 00 00,
ENG04773-ENG04927,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x5A,00 00 00,
ENG04773-ENG04928,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x60,00 00 00,
ENG04773-ENG31563,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x61,00 00 00,
ENG04773-ENG04929,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x63,00 00 00,
ENG04773-ENG04930,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x64,00 00 00,
ENG04773-ENG04931,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x69,00 00 00,
ENG04773-ENG04932,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x6A,00 00 00,
ENG04773-ENG04933,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x73,E0 00 00,
ENG04773-ENG04934,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x76,00 00 00,
ENG04773-ENG04935,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x77,00 00 00,
ENG04773-ENG04936,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x78,00 00 00,
ENG04773-ENG04937,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x7B,00 00 00,
ENG04773-ENG04938,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x7C,00 00 00,
ENG04773-ENG04939,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x80,00 00 00,
ENG04773-ENG04940,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x84,10 00 00,
ENG04773-ENG04941,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x87,08 00 00,
ENG04773-ENG04942,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x88,08 00 00,
ENG04773-ENG31564,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x89,00 00 00,
ENG04773-ENG04943,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8A,00 00 00,
ENG04773-ENG04944,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8B,00 00 00,
ENG04773-ENG04945,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8E,00 00 00,
ENG04773-ENG04946,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8F,00 00 00,
ENG04773-ENG04947,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x93,00 00 00,
ENG04773-ENG04948,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x94,00 00 00,
ENG04773-ENG04949,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x95,08 00 00,
ENG04773-ENG04950,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9B,00 00 00,
ENG04773-ENG04951,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9C,00 00 00,
ENG04773-ENG04952,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9D,00 00 00,
ENG04773-ENG04953,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9E,00 00 00,
ENG04773-ENG04954,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xA0,10 00 00,
ENG04773-ENG08116,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xAD,00 00 00,
ENG04773-ENG31565,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xAE,00 00 00,
ENG04773-ENG31566,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xB8,00 00 00,
ENG04773-ENG31567,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xBB,00 00 00,
ENG04773-ENG116981,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF3,00 00 00,
ENG04772-ENG04819,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x03,00,
ENG04772-ENG04833,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x1E,00,
ENG04772-ENG04843,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x32,00,
ENG04772-ENG04878,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x93,00,
ENG04772-ENG04879,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x94,00,
ENG04772-ENG04880,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x95,00,
ENG04772-ENG04881,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x9B,00,
ENG04772-ENG04882,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x9C,00,
ENG04772-ENG31568,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x04,00,
ENG04772-ENG31569,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x05,00,
ENG04772-ENG31570,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x06,00,
ENG04772-ENG31571,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x07,00,
ENG04772-ENG31572,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x08,00,
ENG04772-ENG04820,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0A,00,
ENG04772-ENG04821,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0B,00,
ENG04772-ENG04822,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0C,02,
ENG04772-ENG04823,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0E,02,
ENG04772-ENG04824,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0F,00,
ENG04772-ENG04825,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x12,02,
ENG04772-ENG04826,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x13,02,
ENG04772-ENG04827,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x14,02,
ENG04772-ENG04828,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x15,02,
ENG04772-ENG04829,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x16,00,
ENG04772-ENG04830,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1A,00,
ENG04772-ENG04831,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1B,00,
ENG04772-ENG04832,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1C,00,
ENG04772-ENG04834,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x23,00,
ENG04772-ENG06781,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x24,00,
ENG04772-ENG04835,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x27,00,
ENG04772-ENG04836,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2A,00,
ENG04772-ENG04837,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2B,00,
ENG04772-ENG04838,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2C,00,
ENG04772-ENG04839,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2D,00,
ENG04772-ENG04840,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2E,00,
ENG04772-ENG04841,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x30,00,
ENG04772-ENG04842,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x31,00,
ENG04772-ENG04844,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x3B,00,
ENG04772-ENG04845,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x41,00,
ENG04772-ENG04846,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x42,00,
ENG04772-ENG31573,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x43,00,
ENG04772-ENG04847,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x44,00,
ENG04772-ENG04848,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x46,02,
ENG04772-ENG04849,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x47,00,
ENG04772-ENG116935,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x49,00,
ENG04772-ENG04850,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4A,02,
ENG04772-ENG04851,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4B,02,
ENG04772-ENG04852,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4C,02,
ENG04772-ENG04853,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4D,00,
ENG04772-ENG04854,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4E,02,
ENG04772-ENG31574,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4F,00,
ENG04772-ENG04856,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x53,02,
ENG04772-ENG04857,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x56,00,
ENG04772-ENG04858,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x57,00,
ENG04772-ENG31575,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x59,00,
ENG04772-ENG04859,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x5A,00,
ENG04772-ENG04860,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x60,00,
ENG04772-ENG31576,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x61,00,
ENG04772-ENG06782,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x63,00,
ENG04772-ENG04861,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x64,00,
ENG04772-ENG04862,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x69,02,
ENG04772-ENG04863,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x6A,00,
ENG04772-ENG04864,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x73,02,
ENG04772-ENG04865,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x76,02,
ENG04772-ENG04866,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x77,02,
ENG04772-ENG04867,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x78,00,
ENG04772-ENG04868,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7B,00,
ENG04772-ENG04869,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7C,00,
ENG04772-ENG04870,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x80,00,
ENG04772-ENG04871,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x84,02,
ENG04772-ENG04872,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x87,00,
ENG04772-ENG04873,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x88,00,
ENG04772-ENG31577,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x89,00,
ENG04772-ENG04874,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8A,02,
ENG04772-ENG04875,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8B,02,
ENG04772-ENG04876,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8E,00,
ENG04772-ENG04877,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8F,00,
ENG04772-ENG04883,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9D,00,
ENG04772-ENG04884,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9E,00,
ENG04772-ENG04885,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xA0,00,
ENG04772-ENG08115,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xAD,00,
ENG04772-ENG31578,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xAE,00,
ENG04772-ENG31579,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB8,00,
ENG04772-ENG31580,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xBB,00,
ENG04772-ENG117001,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF3,00,
ENG117867-ENG06211,GPS_Count_Satellite_Phase_Lock_Counter-count_sattelite_phase_lock,0,
ENG123212-ENG123347,GPS_Dilution_of_precision-geometric_dilution_of_precision,00 00,
ENG123212-ENG123346,GPS_Dilution_of_precision-horizontal_dilution_of_precision,00 00,
ENG123212-ENG123296,GPS_Dilution_of_precision-Initiation,not initialized,
ENG123212-ENG123348,GPS_Dilution_of_precision-positional_dilution_of_precision,00 00,
ENG123212-ENG123345,GPS_Dilution_of_precision-time_dilution_of_precision,00 00,
ENG123212-ENG123344,GPS_Dilution_of_precision-vertical_dilution_of_precision,00 00,
ENG117868-ENG06212,GPS_Satellite_Code_Lock_Counter-count_sattelite_code_lock,0,
ENG06145-ENG06200,hvk_high_voltag_total_discharge_prevention-dcdc_target_mode,0,
ENG06145-ENG06199,hvk_high_voltag_total_discharge_prevention-hvk_total_discharge_prevention_state,0,
ENG06145-ENG06201,hvk_high_voltag_total_discharge_prevention-tme_ekk_target_mode,0,
ENG06145-ENG06202,hvk_high_voltag_total_discharge_prevention-tme_hvptc_target_mode,0,
ENG06144-ENG30377,hvk_high_voltage_zero_potential-awc_zero_potential,0,
ENG06144-ENG06195,hvk_high_voltage_zero_potential-bms_failure_state,7,
ENG06144-ENG06192,hvk_high_voltage_zero_potential-bms_zero_potential,0,
ENG06144-ENG06194,hvk_high_voltage_zero_potential-em1_zero_potential,0,
ENG06144-ENG39295,hvk_high_voltage_zero_potential-Flexray_status,1,
ENG06144-ENG39330,hvk_high_voltage_zero_potential-HCAN_status,1,
ENG06144-ENG06198,hvk_high_voltage_zero_potential-hvk_total_zero_potential,0,
ENG06144-ENG06196,hvk_high_voltage_zero_potential-hvlm_connector_plug_state,0,
ENG06144-ENG06193,hvk_high_voltage_zero_potential-lad_zero_potential,0,
ENG123205,Incoming_call_line_state,Idle,
ENG26975-ENG30888,MFLe_LIN-DI_Emblem,OFF,
ENG26975-ENG46163,MFLe_LIN-DI_KL_50xs,58,
ENG26975-ENG46164,MFLe_LIN-DI_KL_58xt,58,
ENG26975-ENG30921,MFLe_LIN-Dimmung_01_gueltig,invalid,
ENG26975-ENG31890,MFLe_LIN-Klemme_15_MFL,On,
ENG26975-ENG31892,MFLe_LIN-KLR_Modusanforderung,Normal_mode,
ENG26975-ENG31980,MFLe_LIN-LR_HZG_Freigabe,no_restriction,
ENG26975-ENG31981,MFLe_LIN-LR_HZG_on_off,OFF,
ENG26975-ENG32052,MFLe_LIN-MFLe_Anzeige_LaunchControl,display_off,
ENG26975-ENG32053,MFLe_LIN-MFLe_Anzeige_MAP,OFF,
ENG26975-ENG32054,MFLe_LIN-MFLe_Anzeige_Sport,display_off,
ENG26975-ENG32055,MFLe_LIN-MFLe_Anzeige_Sport_Plus,display_off,
ENG26975-ENG32056,MFLe_LIN-MFLe_Tastencode_alt_neu,apply_keycode_new,
ENG26975-ENG32226,MFLe_LIN-P_Mode_MFL,OFF,
ENG06740,MVEM_dc_current_Mv,204.0, A
ENG06739,MVEM_dc_power_desired,0, W
ENG06734,MVEM_DC_voltage_desired,63.50, V
ENG06741,MVEM_dc_voltage_Mv,63.25, V
ENG06736-ENG09198,MVEM_Derating_voltage-Derating_group_A,63.50, V
ENG06736-ENG09199,MVEM_Derating_voltage-Derating_group_B,63.50, V
ENG06736-ENG09200,MVEM_Derating_voltage-Derating_group_C,63.50, V
ENG06736-ENG09337,MVEM_Derating_voltage-Derating_Umax_feedback,63.5, V
ENG06738,MVEM_EMG_level_of_capacity,100.000, %
ENG06737,MVEM_Emg_voltage_desired,63.50, V
ENG06733,MVEM_Mv_current,-11, A
ENG08763-ENG09342,MVEM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG08763-ENG09343,MVEM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG08762-ENG09338,MVEM_release-12V_coldstart_release,No enabling,
ENG08762-ENG09339,MVEM_release-12V_warmstart_release,No enabling,
ENG08762-ENG09340,MVEM_release-48V_coldstart_release,No enabling,
ENG08762-ENG09341,MVEM_release-start_stopp_support_release,No enabling,
ENG06735,MVEM_RSG_maximal_current,508, A
ENG08761-ENG09336,MVEM_RSG_maximal_voltage-RSG_maximal_voltage,63.50, V
ENG06718-ENG06799,NVEM_12Vrsg_input_parameter-rsg_cutoff_ rotation_speed,3000, /min
ENG06718-ENG06798,NVEM_12Vrsg_input_parameter-rsg_exciter current_limit,16.0, A
ENG06718-ENG06800,NVEM_12Vrsg_input_parameter-rsg_load_response_time,3, s
ENG06718-ENG06801,NVEM_12Vrsg_input_parameter-rsg_target_mode,0,
ENG06718-ENG06797,NVEM_12Vrsg_input_parameter-rsg_voltage_desired,10.6, V
ENG04778-ENG55511,NVEM_Hlr_release-Release_FlHz_hl,No enabling,
ENG04778-ENG55512,NVEM_Hlr_release-Release_FlHz_hr,No enabling,
ENG04778-ENG55513,NVEM_Hlr_release-Release_FlHz_rest_seat,No enabling,
ENG04778-ENG55514,NVEM_Hlr_release-Release_FlHz_vl,No enabling,
ENG04778-ENG55515,NVEM_Hlr_release-Release_FlHz_vr,No enabling,
ENG04778-ENG04987,NVEM_Hlr_release-Release_FSH,OFF,
ENG04778-ENG04986,NVEM_Hlr_release-Release_HSH,No enabling,
ENG04778-ENG04989,NVEM_Hlr_release-Release_KRH_vl,No enabling,
ENG04778-ENG04988,NVEM_Hlr_release-Release_KRH_vr,No enabling,
ENG04778-ENG04990,NVEM_Hlr_release-Release_LRH,No enabling,
ENG04778-ENG04991,NVEM_Hlr_release-Release_PTC,No enabling,
ENG04778-ENG04992,NVEM_Hlr_release-Release_PTC_linear,0, W
ENG04778-ENG04975,NVEM_Hlr_release-Release_SIH_Fond,Release,
ENG04778-ENG04979,NVEM_Hlr_release-Release_SIH_hl,No enabling,
ENG04778-ENG04978,NVEM_Hlr_release-Release_SIH_hr,No enabling,
ENG04778-ENG04977,NVEM_Hlr_release-Release_SIH_vl,No enabling,
ENG04778-ENG04976,NVEM_Hlr_release-Release_SIH_vr,No enabling,
ENG04778-ENG04983,NVEM_Hlr_release-Release_SIL_hl,No enabling,
ENG04778-ENG04982,NVEM_Hlr_release-Release_SIL_hr,No enabling,
ENG04778-ENG04981,NVEM_Hlr_release-Release_SIL_vl,No enabling,
ENG04778-ENG04980,NVEM_Hlr_release-Release_SIL_vr,No enabling,
ENG04778-ENG04985,NVEM_Hlr_release-Release_Sp_heatin_codriver,No enabling,
ENG04778-ENG04984,NVEM_Hlr_release-Release_Sp_heatin_driver,No enabling,
ENG04778-ENG32447,NVEM_Hlr_release-Release_TCH,No enabling,
ENG06726,NVEM_Hv_DcDc_voltage_desired_nv,10.6, V
ENG04783,NVEM_hybrid_info,3,
ENG06730,NVEM_Mv_DcDc_voltage_desired_nv,10.6, V
ENG04774-ENG06796,NVEM_Voltage_Request-Voltage_Request_BCM,not active,
ENG04774-ENG04969,NVEM_Voltage_Request-Voltage_Request_ClimatControl,not active,
ENG04774-ENG04968,NVEM_Voltage_Request-Voltage_Request_engine,Stage 1,
ENG04774-ENG04966,NVEM_Voltage_Request-Voltage_Request_EPS,not active,
ENG04774-ENG04967,NVEM_Voltage_Request-Voltage_Request_ESP,not active,
ENG04774-ENG04970,NVEM_Voltage_Request-Voltage_Request_GearControl,not active,
ENG04774-ENG04971,NVEM_Voltage_Request-Voltage_Request_Reduction_Alternator_Load,not active,
ENG04788-ENG98667,operation_hours-Kilometers,904,
ENG123204,Outgoing_call_line_state,line_free,
ENG08771-ENG09431,Stack_Size_Max-Stack_Size_Max_ISR,10, %
ENG08771-ENG09408,Stack_Size_Max-Stack_Size_Max_Task_01,0, %
ENG08771-ENG09409,Stack_Size_Max-Stack_Size_Max_Task_02,25, %
ENG08771-ENG09410,Stack_Size_Max-Stack_Size_Max_Task_03,0, %
ENG08771-ENG09411,Stack_Size_Max-Stack_Size_Max_Task_04,0, %
ENG08771-ENG09412,Stack_Size_Max-Stack_Size_Max_Task_05,0, %
ENG08771-ENG09413,Stack_Size_Max-Stack_Size_Max_Task_06,16, %
ENG08771-ENG09414,Stack_Size_Max-Stack_Size_Max_Task_07,0, %
ENG08771-ENG09415,Stack_Size_Max-Stack_Size_Max_Task_08,53, %
ENG08771-ENG09416,Stack_Size_Max-Stack_Size_Max_Task_09,16, %
ENG08771-ENG09417,Stack_Size_Max-Stack_Size_Max_Task_10,31, %
ENG08771-ENG09418,Stack_Size_Max-Stack_Size_Max_Task_11,31, %
ENG08771-ENG09419,Stack_Size_Max-Stack_Size_Max_Task_12,57, %
ENG08771-ENG09420,Stack_Size_Max-Stack_Size_Max_Task_13,50, %
ENG08771-ENG09421,Stack_Size_Max-Stack_Size_Max_Task_14,0, %
ENG08771-ENG09422,Stack_Size_Max-Stack_Size_Max_Task_15,0, %
ENG08771-ENG09423,Stack_Size_Max-Stack_Size_Max_Task_16,0, %
ENG08771-ENG09424,Stack_Size_Max-Stack_Size_Max_Task_17,0, %
ENG08771-ENG09425,Stack_Size_Max-Stack_Size_Max_Task_18,0, %
ENG08771-ENG09426,Stack_Size_Max-Stack_Size_Max_Task_19,0, %
ENG08771-ENG09427,Stack_Size_Max-Stack_Size_Max_Task_20,0, %
ENG08771-ENG09428,Stack_Size_Max-Stack_Size_Max_Task_21,0, %
ENG08771-ENG09429,Stack_Size_Max-Stack_Size_Max_Task_22,0, %
ENG08771-ENG09430,Stack_Size_Max-Stack_Size_Max_Task_23,15, %
ENG04781,StartStop_info,0,
ENG08770-ENG09376,State_Dataset_AuxFunktions-Datensatz_0,not_valid,
ENG08770-ENG09377,State_Dataset_AuxFunktions-Datensatz_1,valid,
ENG08770-ENG09392,State_Dataset_AuxFunktions-Datensatz_10,not_valid,
ENG08770-ENG09393,State_Dataset_AuxFunktions-Datensatz_11,not_valid,
ENG08770-ENG09394,State_Dataset_AuxFunktions-Datensatz_12,not_valid,
ENG08770-ENG09395,State_Dataset_AuxFunktions-Datensatz_13,not_valid,
ENG08770-ENG09396,State_Dataset_AuxFunktions-Datensatz_14,not_valid,
ENG08770-ENG09397,State_Dataset_AuxFunktions-Datensatz_15,not_valid,
ENG08770-ENG09398,State_Dataset_AuxFunktions-Datensatz_16,not_valid,
ENG08770-ENG09399,State_Dataset_AuxFunktions-Datensatz_17,not_valid,
ENG08770-ENG09400,State_Dataset_AuxFunktions-Datensatz_18,not_valid,
ENG08770-ENG09401,State_Dataset_AuxFunktions-Datensatz_19,not_valid,
ENG08770-ENG09402,State_Dataset_AuxFunktions-Datensatz_1A,valid,
ENG08770-ENG09403,State_Dataset_AuxFunktions-Datensatz_1B,valid,
ENG08770-ENG09404,State_Dataset_AuxFunktions-Datensatz_1C,valid,
ENG08770-ENG09405,State_Dataset_AuxFunktions-Datensatz_1D,valid,
ENG08770-ENG09406,State_Dataset_AuxFunktions-Datensatz_1E,valid,
ENG08770-ENG09407,State_Dataset_AuxFunktions-Datensatz_1F,valid,
ENG08770-ENG09378,State_Dataset_AuxFunktions-Datensatz_2,not_valid,
ENG08770-ENG09379,State_Dataset_AuxFunktions-Datensatz_3,not_valid,
ENG08770-ENG09380,State_Dataset_AuxFunktions-Datensatz_4,not_valid,
ENG08770-ENG09381,State_Dataset_AuxFunktions-Datensatz_5,not_valid,
ENG08770-ENG09382,State_Dataset_AuxFunktions-Datensatz_6,not_valid,
ENG08770-ENG09383,State_Dataset_AuxFunktions-Datensatz_7,not_valid,
ENG08770-ENG09384,State_Dataset_AuxFunktions-Datensatz_8,not_valid,
ENG08770-ENG09385,State_Dataset_AuxFunktions-Datensatz_9,not_valid,
ENG08770-ENG09386,State_Dataset_AuxFunktions-Datensatz_A,not_valid,
ENG08770-ENG09387,State_Dataset_AuxFunktions-Datensatz_B,not_valid,
ENG08770-ENG09388,State_Dataset_AuxFunktions-Datensatz_C,not_valid,
ENG08770-ENG09389,State_Dataset_AuxFunktions-Datensatz_D,not_valid,
ENG08770-ENG09390,State_Dataset_AuxFunktions-Datensatz_E,not_valid,
ENG08770-ENG09391,State_Dataset_AuxFunktions-Datensatz_F,not_valid,
ENG06146-MAS00106,Status_to_a_agree_a_appointment_online-Year,2000,
ENG06146-MAS00107,Status_to_a_agree_a_appointment_online-Month,0,
ENG06146-MAS00108,Status_to_a_agree_a_appointment_online-Day,0,
ENG06146-MAS00109,Status_to_a_agree_a_appointment_online-Hours,0,
ENG06146-MAS00110,Status_to_a_agree_a_appointment_online-Minutes,0,
ENG06146-MAS00111,Status_to_a_agree_a_appointment_online-Seconds,0,
ENG06146-ENG28929,Status_to_a_agree_a_appointment_online-Status_OTV_remind_Flag,no_Set,
ENG06146-ENG28928,Status_to_a_agree_a_appointment_online-Status_OTV_Trigger,no_Set,
ENG08634-ENG120595,Transportmode_Status-Transport_Protection,not activated,
ENG08634-ENG98982,Transportmode_Status-Transportmode,not activated,
ENG04789-ENG05094,Voltage_Comfort_CAN-Voltage_CAN_High,1.30, V
ENG04789-ENG05095,Voltage_Comfort_CAN-Voltage_CAN_Low,1.16, V
ENG04792-ENG05094,Voltage_Extended_CAN-Voltage_CAN_High,1.30, V
ENG04792-ENG05095,Voltage_Extended_CAN-Voltage_CAN_Low,1.20, V
ENG04790-ENG05094,Voltage_Hybrid_CAN-Voltage_CAN_High,1.28, V
ENG04790-ENG05095,Voltage_Hybrid_CAN-Voltage_CAN_Low,1.14, V
ENG04791-ENG05094,Voltage_Infotainment_CAN-Voltage_CAN_High,1.36, V
ENG04791-ENG05095,Voltage_Infotainment_CAN-Voltage_CAN_Low,1.14, V
Elapsed Time: 07:34
adpmap-19-8W6-907-468-F
;SW:8W6-907-468-F   HW:8W6-907-468-E ---  CAN Gateway
;Component:Gateway       H43 0123, Coding:030100010000064029070000005900124C180007100000000175078E10000000
;EV_CGateCONTIAU491,003111,EV_CGateCONTIAU491_003_AU49.rod
;Sunday,10,November,2019,20:27:53:01617
;VCID: CDDD6A729CD7CF279C-8098
IDE00001-IDE00332-Production mode-Buttons for multi-function steering wheel,Deactivating ,3
IDE00001-IDE10279-Production mode-Onboard data collector,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS11109-Production mode-Wireless network connection,Deactivating ,3
IDE00002-Transport mode,not activated ,1
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE01211-Static current measuring mode,not activated ,1
IDE01996-IDE14867-Installation list: specified installations-Subgateway as firewall control module,Not coded ,32
IDE01996-MAS00796-Installation list: specified installations-Engine Control Module (ECM),coded ,32
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00007-Installation list: specified installations-Display Control Unit,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00012-Installation list: specified installations-Rear Axle Steering 2,Not coded ,32
IDE01996-SFT00017-Installation list: specified installations-Engine Control Module 2,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,coded ,32
IDE01996-SFT00027-Installation list: specified installations-Active Steering,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00039-Installation list: specified installations-Display Control Unit Rear,Not coded ,32
IDE01996-SFT00040-Installation list: specified installations-Climate Control Unit Rear,Not coded ,32
IDE01996-SFT00042-Installation list: specified installations-Control Unit Wireless Charging,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded ,32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,coded ,32
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00070-Installation list: specified installations-Central Module Comfort System,coded ,32
IDE01996-SFT00072-Installation list: specified installations-Seat Adjustment Rear Driver Side,Not coded ,32
IDE01996-SFT00074-Installation list: specified installations-Rear light,Not coded ,32
IDE01996-SFT00077-Installation list: specified installations-Löschkandidat_Datenübertragung Car2X,Not coded ,32
IDE01996-SFT00080-Installation list: specified installations-Seat Adjustment 3rd Row,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00090-Installation list: specified installations-Longitudinal control,Not coded ,32
IDE01996-SFT00091-Installation list: specified installations-Seat Adjustment Rear Passenger Side,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
IDE01996-SFT00107-Installation list: specified installations-Aerodynamics Control Unit,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00113-Installation list: specified installations-Battery Charger,Not coded ,32
IDE01996-SFT00116-Installation list: specified installations-Chassis Control,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded ,32
IDE01996-SFT00127-Installation list: specified installations-Information Control Unit 2,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00129-Installation list: specified installations-Gear Shift Control Module,coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00132-Installation list: specified installations-Night Vision,Not coded ,32
IDE01996-SFT00139-Installation list: specified installations-Adaptive Cruise Control 2,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00172-Installation list: specified installations-Reductant Control Module,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded ,32
IDE01996-SFT00186-Installation list: specified installations-Assembly Mounting,Not coded ,32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
IDE01996-SFT00195-Installation list: specified installations-Drive Motor Control Module 3,Not coded ,32
IDE01996-SFT00196-Installation list: specified installations-DC/DC Converter Control Module,Not coded ,32
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
IDE01996-SFT00203-Installation list: specified installations-Rear Axle Steering,Not coded ,32
IDE01996-SFT00205-Installation list: specified installations-Laser Scanner,Not coded ,32
IDE01996-SFT00206-Installation list: specified installations-Drive Motor Control Module 2,Not coded ,32
IDE01996-SFT00208-Installation list: specified installations-Front Axle Lift System,Not coded ,32
IDE01996-SFT00219-Installation list: specified installations-Front Corner Radar 1,Not coded ,32
IDE01996-SFT00220-Installation list: specified installations-Front Corner Radar 2,Not coded ,32
IDE01996-SFT00221-Installation list: specified installations-Control Module 2 For Sunroof,Not coded ,32
IDE01996-SFT33031-Installation list: specified installations-Antenna Control Module,Not coded ,32
IDE01996-SFT33232-Installation list: specified installations-Central control for digital matrix light,Not coded ,32
IDE01996-SFT271904-Installation list: specified installations-Sun Roof,coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,75 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,280225P0F4 ,15
IDE03903-Production process data 1,00 00 00 A2 AA AA ,6
IDE04159-Deactivation of start-stop function,regular operation ,1
IDE06748-Pause recommendation,activated ,1
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,10.20 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,40.10 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,100 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,10 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,990 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,24 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,23.10 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,23.10 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,23.10 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,23.10 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,23.10 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,23.10 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),24.10 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,10.30 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,23.30 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,23.10 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,6.10 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,10.20 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,10.20 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,10.20 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,10.20 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,10.20 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,10.20 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,10.20 l/100km,48
IDE10351-MAS05767-Message mirroring-port,00 00 ,21
IDE10351-MAS09111-Message mirroring-IP address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,21
IDE10351-MAS10445-Message mirroring-Data bus CAN 1,not active ,21
IDE10351-MAS10446-Message mirroring-Data bus CAN 2,not active ,21
IDE10351-MAS10447-Message mirroring-Data bus CAN 3,not active ,21
IDE10351-MAS10448-Message mirroring-Data bus CAN 4,not active ,21
IDE10351-MAS10449-Message mirroring-Data bus CAN 5,not active ,21
IDE10351-MAS10450-Message mirroring-Data bus CAN 6,not active ,21
IDE10351-MAS10451-Message mirroring-Data bus Flexray A,not active ,21
IDE10351-MAS10452-Message mirroring-Data bus LIN 1,not active ,21
IDE10351-MAS10453-Message mirroring-Data bus LIN 2,not active ,21
IDE10351-MAS10454-Message mirroring-Data bus LIN 3,not active ,21
IDE10351-MAS10460-Message mirroring-Target bus,not active ,21
IDE10351-MAS11107-Message mirroring-Data bus CAN 7,not active ,21
IDE10351-MAS13143-Message mirroring-FlexRay B data bus,not active ,21
IDE10351-MAS17841-Message mirroring-Data bus CAN 8,not active ,21
IDE11209-MAS12388-Vehicle condition report: settings-Send report after terminal 15 off wait time,3C ,5
IDE11209-MAS12389-Vehicle condition report: settings-After terminal 15 off: also wait for bus inactivity,OFF ,5
IDE11209-MAS12390-Vehicle condition report: settings-Send report after terminal 15 on wait time,3C ,5
IDE11209-MAS12391-Vehicle condition report: settings-Send report after bus inactivity wait time,05 ,5
IDE11209-MAS12392-Vehicle condition report: settings-Send report upon reaching BEM shutdown level,OFF ,5
IDE11688-IDE08958-Autonomous operation request-H-V system: start request,regular operation ,3
IDE11688-MAS08040-Autonomous operation request-Automatic recharging of starter battery,regular operation ,3
IDE11688-MAS13088-Autonomous operation request-Preconditioning of the interior,regular operation ,3
IDE13338-Basic functions connect,Deactivating ,4
IDE13756-Diagnosis filter: activation,not active ,1
IDE13757-MAS16868-Diagnosis filter: kilometer thresholds-Kilometer threshold: production,200 km,2
IDE13757-MAS16869-Diagnosis filter: kilometer thresholds-Kilometer threshold: customer service,20 km,2
ENG137256-Adaption_high_voltage_zero_potential,regular operation ,1
ENG137852-Backup_Power_Threshold,0 %,1
ENG153689-Counter_for_inconsistent_conditions,20 ,2
ENG153814-download_eem,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,256
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,13
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120 ,13
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,13
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,13
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,13
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,13
ENG118777-ENG136172-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Number_of_Keys,1 ,13
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,13
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,500 ms,13
ENG118777-ENG136168-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_1,800 ms,13
ENG118777-ENG136169-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_2,1000 ms,13
ENG118777-ENG136170-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_3,0 ms,13
ENG118777-ENG136171-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_4,0 ms,13
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,6000 ms,13
ENG118775-energy_management_deactiv_stage,regular operation ,1
ENG137255-HVK_Warning,regular operation ,1
ENG118451-ENG118685-Switch_on_ban_independent_car_heater-Set_point_target_time,80 min,2
ENG118451-ENG118684-Switch_on_ban_independent_car_heater-Switch_on_ban_activation,regular operation ,2
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,2
ENG118774-ENG136195-WakeUpMonitor_Activation-Activation_Bus_Activity,activated ,2
ENG118774-ENG136134-WakeUpMonitor_Activation-Activation_Cluster_Sleep,activated ,2
ENG118774-ENG136135-WakeUpMonitor_Activation-Activation_Cluster_Start,activated ,2
ENG118774-ENG136197-WakeUpMonitor_Activation-Activation_CWUP,activated ,2
ENG118774-ENG136130-WakeUpMonitor_Activation-Activation_Keeping_Awake,activated ,2
ENG118774-ENG136196-WakeUpMonitor_Activation-Activation_Knock_Out,activated ,2
ENG118774-ENG136131-WakeUpMonitor_Activation-Activation_Logical_Wakeup,activated ,2
ENG118774-ENG136198-WakeUpMonitor_Activation-Activation_NFU,activated ,2
ENG118774-ENG136132-WakeUpMonitor_Activation-Activation_Physical_Wakeup,activated ,2
ENG118774-ENG136199-WakeUpMonitor_Activation-Activation_SBU,activated ,2
ENG118773-ENG136190-WakeUpMonitor_Configuration-Max_Num_Cluster_Sleep,20 counts,13
ENG118773-ENG136191-WakeUpMonitor_Configuration-Max_Num_Cluster_Start,20 counts,13
ENG118773-ENG136192-WakeUpMonitor_Configuration-Max_Num_CWUP,30 counts,13
ENG118773-ENG136189-WakeUpMonitor_Configuration-Max_Num_Knock_Out,3 counts,13
ENG118773-ENG136187-WakeUpMonitor_Configuration-Max_Num_Logical_Wakeup,40 counts,13
ENG118773-ENG136193-WakeUpMonitor_Configuration-Max_Num_NF,20 min,13
ENG118773-ENG136188-WakeUpMonitor_Configuration-Max_Num_Physical_Wakeup,10 counts,13
ENG118773-ENG136194-WakeUpMonitor_Configuration-Max_Num_Sb,20 min,13
ENG118773-ENG136186-WakeUpMonitor_Configuration-Max_Time_Keeping_Awake,20 min,13
ENG118773-ENG109064-WakeUpMonitor_Configuration-Start_Delay,0 s,13
ENG118773-ENG136185-WakeUpMonitor_Configuration-Wake_Delay,20 min,13
Elapsed Time: 00:27
DrPeter
16.4905° S, 151.7375° W
Maps
Address [01]
blockmap-01-8W0-906-259-J
;SW:8W0-906-259-J   HW:06L-907-425-C ---  Engine
;Component:2.0l R4 TFSI  H15 0002, Coding:0A2500322326010E34280000000000000000000000000000
;EV_ECM20TFS0208W0906259J,001003,EV_ECM20TFS020_AU49.rod
;Sunday,10,November,2019,20:28:26:01617
;VCID: C8D35B6673B52A0FAF-809C
Group,Description,Actual
IDE00018,Voltage terminal 15,12.930, V
IDE00019,Voltage terminal 30,12.988, V
IDE00021,Engine speed,799, /min
IDE00025,Coolant temperature,108, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,603, s
IDE00083,Throttle valve position (absolute),11.4, %
IDE00084,Absolute load value,22, %
IDE00085,Normed load value,14.1, %
IDE00086,Accelerator position,15, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00102,Control Module temperature,89.0, °C
IDE00148,Median injection timing,1.0, ms
IDE00149,Ignition angle of current cylinder: actual value,3.00, °
IDE00150,Pressure in brake booster,1.150, bar
IDE00151,Oil fill level,88, mm
IDE00155,Timing angle retardation cylinder 1,0.00, °
IDE00156,Timing angle retardation cylinder 2,0.00, °
IDE00157,Timing angle retardation cylinder 3,0.00, °
IDE00158,Timing angle retardation cylinder 4,0.00, °
IDE00167,Exhaust temperature 1 bank 1,419.6, °C
IDE00172,A/C compressor torque,-8.69, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,4.5, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,4.5, °
IDE00178,Camshaft adjustment intake bank 1: specified value,5.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,4.9, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-0.7, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-3.7, °
IDE00186,Fuel low pressure: actual value,11.003, bar
IDE00187,Coolant temperature at engine start,75.0, °C
IDE00188,Fuel high pressure: actual value,55.5, bar
IDE00189,Activation of fuel pump electronics,28.17, %
IDE00190,Charge air pressure specified value,0.813, bar
IDE00191,Charge air pressure: actual value,1.019, bar
IDE00192,Coolant temperature at radiator outlet: actual value,44.7, °C
IDE00193,Coolant temperature at engine outlet: specified value,108.0, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,63.7, °C
IDE00196,Engine oil temperature,93.0, °C
IDE00199,Mean engine air mass,12, kg/h
IDE00200,Median vehicle speed,0.00, km/h
IDE00201,High fuel pressure: specified value,55.7, bar
IDE00202,Low fuel pressure: specified value,5.945, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00304,Fuel level,34, l
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00348,Intake air temperature,57, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,12, kg/h
IDE00355,Cruise Control System (CCS): status,main switch off,
IDE00357,Fuel temperature,96.0, °C
IDE00358,Limitation: torque,228.2, Nm
IDE00371,Fuel consumption,1.15, l/h
IDE00375,Generator: load signal,0.03, %
IDE00380,Coolant fan 1: activation,46.48, %
IDE00381,Coolant fan 2: activation,10.16, %
IDE00392,Accelerator pedal: sensor voltage 1,0.751, V
IDE00393,Accelerator pedal: sensor voltage 2,0.376, V
IDE00396,Charge Pressure Actuator: acknowledgment,3.555, V
IDE00400,Intake manifold Runner Control (IMRC): activation,100.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,100.00, %
IDE00404,Throttle valve: activation,17.73, %
IDE00405,Crankshaft speed (RPM),801, /min
IDE00406,Camshaft speed (RPM),0, /min
IDE00407,Rail pressure regulation: status,Regulated operation via quantity control valve,
IDE00408,Engine mount 1,active,
IDE00409,Engine mount 2,active,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,00,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 acknowledgment,01,
IDE00417,Starter control: shut-off conditions 1,00 01,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,9, mg/stroke
IDE00474,Ambient air pressure,102, kPa abs
IDE00476,Fuel Metering Valve,12.95, %
IDE00477,Torque request: sum of auxiliary aggregate,18.4, Nm
IDE00478,Engine-drag torque,14.7, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,93.0, °C
IDE00496,Activation of oil pressure switch valve,Low pressure,
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside air temperature,27, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.006 Lambda / -0.012 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.780, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.003, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,56.9, %
IDE00589,Fuel pressure,5470, kPa rel
IDE00592,Oxygen sensor control status,Closed loop,  / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,3.5, Degrees
IDE00594,Absolute intake pressure,33, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,4.7, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,0,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00727,Test steps still to be performed,0,
IDE00787,Cause for cancellation,0,
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE00968,Compressor speed,0, /min
IDE01076-MAS00109,Time since ignition off-Hours,1, H
IDE01076-MAS00110,Time since ignition off-Minutes,18, min
IDE01076-MAS00111,Time since ignition off-Seconds,52, s
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01266,Coolant shut-off valve,Open,
IDE01369,Intake manifold runner control (IMRC): offset closed,0.004, V
IDE01377,Throttle valve adapter: actual value,2.0, °
IDE01378,High fuel pressure: control deviation,0, bar
IDE01385,Wear index,0.00000026,
IDE01405-MAS05513,Status of starter activation-Bit 0,OK,
IDE01405-MAS05514,Status of starter activation-Bit 1,Before starter activation,
IDE01405-MAS05515,Status of starter activation-Bit 2,After starter activation,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.789, V
IDE01649,Throttle valve position 1,0.596, V
IDE01650,Throttle valve position 2,11, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,pressed,
IDE01672,Starter control: automatic start,not possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mech. test of starter not complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation not complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line not completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal not complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch complete,
IDE01677,Result of O2 sensor test ready bank 1 after cat. conv.,Test not started,
IDE01683-MAS05304,Valve stroke switch of AVS from small to large-Cylinder 1,switched,
IDE01683-MAS05305,Valve stroke switch of AVS from small to large-Cylinder 2,switched,
IDE01683-MAS05306,Valve stroke switch of AVS from small to large-Cylinder 3,switched,
IDE01683-MAS05307,Valve stroke switch of AVS from small to large-Cylinder 4,switched,
IDE01683-MAS05308,Valve stroke switch of AVS from small to large-Cylinder 5,switched,
IDE01683-MAS05309,Valve stroke switch of AVS from small to large-Cylinder 6,switched,
IDE01683-MAS05310,Valve stroke switch of AVS from small to large-Cylinder 7,switched,
IDE01683-MAS05311,Valve stroke switch of AVS from small to large-Cylinder 8,switched,
IDE01684-MAS05304,Valve stroke switch of AVS from large to small-Cylinder 1,switched,
IDE01684-MAS05305,Valve stroke switch of AVS from large to small-Cylinder 2,switched,
IDE01684-MAS05306,Valve stroke switch of AVS from large to small-Cylinder 3,switched,
IDE01684-MAS05307,Valve stroke switch of AVS from large to small-Cylinder 4,switched,
IDE01684-MAS05308,Valve stroke switch of AVS from large to small-Cylinder 5,switched,
IDE01684-MAS05309,Valve stroke switch of AVS from large to small-Cylinder 6,switched,
IDE01684-MAS05310,Valve stroke switch of AVS from large to small-Cylinder 7,switched,
IDE01684-MAS05311,Valve stroke switch of AVS from large to small-Cylinder 8,switched,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,active,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 OK,
IDE01873,Test of catalytic converter: measured value,0.000,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,-0.5, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4.126, V
IDE01884,Camshaft adjustment intake bank 1: activation,47.10, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,0.00, %
IDE01895,Charge pressure control: less than min. threshold adaptation,2.54, %
IDE01901,Lost torque adaptation: idle,1.1, Nm
IDE01905,Average of ignition timing angle delay adjustment,17.62, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,3.00, °
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1,
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,32501, km
IDE01923,Control module distance driven,32408, km
IDE01924,Load shift flaps: actual value,closed,
IDE01925,Load shift flaps: specified value,closed,
IDE01926,Adaptation of load shift flaps,Cancel: prerequisites have not been met,
IDE01928,Close cam shaft angle at quantity control valve,32.6, °
IDE01929,Open cam shaft angle at quantity control valve,4.0, °
IDE01931,High pressure pump injection volume control deviation,3, mg/stroke
IDE01932,High pressure pump injection volume,12, mg/stroke
IDE01975,Numb.of misfir.: cylinder 1,0,
IDE01976,Numb.of misfir.: cylinder 2,0,
IDE01977,Numb.of misfir.: cylinder 3,0,
IDE01978,Numb.of misfir.: cylinder 4,0,
IDE01986,Contact for tank leak test,Open,
IDE02116,Exhaust gas temperature before catalytic converter,398.4, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02229,Exh.gas temp.sen 1,1110.0, °C
IDE02756,Number of manual engine starts,2321,
IDE02757,Number of automatic engine starts,2341,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,1744,
IDE03010-MAS01627,Number of prevented stop processes-Steering,2730,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,1,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,154,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,16,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,4150,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,871,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,18,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,13,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,139,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,14,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,-179.96, °
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.502, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.501, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.908, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.087, V
IDE03267,Intake air temperature: unconditioned voltage,1.025, V
IDE03276,Charge air pressure sensor: unconditioned voltage,1.646, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.765, V
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03361,Driver request torque,33.2, Nm
IDE03362,Requested transmission torque,1024.0, Nm
IDE03375,Adaptation status for transmission neutral position sensor,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,2.544, V
IDE03582,Temperature sensor for engine temperature management,108.0, °C
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,not active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03692-MAS05513,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,Test of camshaft adjustment bank 2 outlet not complete,
IDE03692-MAS05514,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1,Test of camshaft adjustment bank 1 outlet complete,
IDE03692-MAS05515,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2,Test of camshaft adjustment bank 2 intake not complete,
IDE03692-MAS05516,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3,Test of camshaft adjustment bank 1 intake complete,
IDE03692-MAS05517,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4,Test of knock sensor 4 not complete,
IDE03692-MAS05518,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5,Test of knock sensor 3 not complete,
IDE03692-MAS05519,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6,Test of knock sensor 2 not complete,
IDE03692-MAS05520,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7,Test of knock sensor 1 complete,
IDE03693-MAS05513,Monitoring status of additional Onboard Diagnosis-Bit 0,Test of brake light switch not complete,
IDE03693-MAS05514,Monitoring status of additional Onboard Diagnosis-Bit 1,Test of clutch switch not complete,
IDE03693-MAS05515,Monitoring status of additional Onboard Diagnosis-Bit 2,Test of idle control not complete,
IDE03693-MAS05516,Monitoring status of additional Onboard Diagnosis-Bit 3,Test of coolant temperature sensor not complete,
IDE03693-MAS05517,Monitoring status of additional Onboard Diagnosis-Bit 4,Test of throttle valve potentiometer not complete,
IDE03693-MAS05518,Monitoring status of additional Onboard Diagnosis-Bit 5,Test of thermostat complete,
IDE03693-MAS05519,Monitoring status of additional Onboard Diagnosis-Bit 6,Test of charge pressure control complete,
IDE03693-MAS05520,Monitoring status of additional Onboard Diagnosis-Bit 7,Test of CCS switch complete,
IDE03693-MAS05521,Monitoring status of additional Onboard Diagnosis-Bit 8,Test of oxygen adaptation bank 1 complete,
IDE03711,Mass flow through throttle valve,9, kg/h
IDE03767,Engine status,Idling,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,56.44, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,1,
IDE03807,Oxygen sensor bank 1 sensor 2: status,1,
IDE03816,Exhaust flap bank 1,Open,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,333, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,41.02, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,305, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,37.11, %
IDE03832,Oxygen sensor bank 1 sensor 2: response time,0, ms
IDE03834,Oxygen sensor bank 1 sensor 2: response time filtered,0, ms
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,1.281, V
IDE03918,Engine reverse rotation recognition,not recognized,
IDE03919,Oxygen regulation operability and status,On,
IDE03920,Oxygen adaptation status,Condition not met,
IDE03921,Mixture adaptation factor at partial load,0.00, %
IDE03922,Mixture adaptation factor at idle speed,5.24, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,-0.00070,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Operating mode,
IDE03931,Charge pressure actuator: actual position,0.00, %
IDE03932,Charge pressure actuator: specified position,0.00, %
IDE03933,Charge pressure actuator: specified value,0.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3.516, V
IDE03935,Charge pressure actuator: adaptation for upper stop,0.570, V
IDE03949,Air mass: actual value (mg/stroke),128.67, mg/stroke
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.00, %
IDE03957,Throttle valve angle: specified value,2.0, °
IDE03963,Low fuel pressure adaptation value for EFP,0, mbar
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,99.61, %
IDE04002,Charge press. ctrl.,BP_A act:102, kPa
IDE04405,Mixture deviation in adapted partial load range 1,0.00, %
IDE04409,Intake manifold pressure: corrected,0.344, bar
IDE04410,Intake manifold pressure: target value,0.342, bar
IDE04412,Pressure before throttle valve: corrected,1.019, bar
IDE04415,Oxygen ctrl factor with precontrol correction,-0.32, %
IDE04629,AVS operating condition,Test is running,
IDE04630,AVS valve stroke position: current,AVS Stroke,
IDE04632-MAS05304,AVS error status of last switch-over standard stroke direction-Cylinder 1,OK,
IDE04632-MAS05305,AVS error status of last switch-over standard stroke direction-Cylinder 2,OK,
IDE04632-MAS05306,AVS error status of last switch-over standard stroke direction-Cylinder 3,OK,
IDE04632-MAS05307,AVS error status of last switch-over standard stroke direction-Cylinder 4,OK,
IDE04632-MAS05308,AVS error status of last switch-over standard stroke direction-Cylinder 5,OK,
IDE04632-MAS05309,AVS error status of last switch-over standard stroke direction-Cylinder 6,OK,
IDE04632-MAS05310,AVS error status of last switch-over standard stroke direction-Cylinder 7,OK,
IDE04632-MAS05311,AVS error status of last switch-over standard stroke direction-Cylinder 8,OK,
IDE04633-MAS05304,AVS error status of last switch-over AVS stroke direction-Cylinder 1,OK,
IDE04633-MAS05305,AVS error status of last switch-over AVS stroke direction-Cylinder 2,OK,
IDE04633-MAS05306,AVS error status of last switch-over AVS stroke direction-Cylinder 3,OK,
IDE04633-MAS05307,AVS error status of last switch-over AVS stroke direction-Cylinder 4,OK,
IDE04633-MAS05308,AVS error status of last switch-over AVS stroke direction-Cylinder 5,OK,
IDE04633-MAS05309,AVS error status of last switch-over AVS stroke direction-Cylinder 6,OK,
IDE04633-MAS05310,AVS error status of last switch-over AVS stroke direction-Cylinder 7,OK,
IDE04633-MAS05311,AVS error status of last switch-over AVS stroke direction-Cylinder 8,OK,
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04635,AVS switch-over meter: total,5384,
IDE04636,AVS overflow meter for all switch-overs,0,
IDE04637,Engine temperature management actuator,0.00, %
IDE04638,Transmission coolant valve,Open,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,1,
IDE04680,O2 sensor 1: bank 1: voltage raw value O2 signal,1.982, V
IDE04713,Active brake system status,Not operated,
IDE04814,Transmission oil cooler valve,Open,
IDE04937,Sensor for engine block temperature: raw value,-48.0, °C
IDE05140,Intake manifold pressure raw value,0.342, bar
IDE05259,Gear position sensor: raw value,0.00, %
IDE05260,Gear position sensor: current value,Intermediate position,
IDE05261,Gear position sensor: last valid value,Neutral,
IDE05262,Gear position sensor: gear position valid,invalid,
IDE05310,Charge air pressure control valve position: target value,0.00, %
IDE05311,Charge air pressure control valve position: actual value,0.00, %
IDE05312,Charge air pressure control valve uncond voltage sensor,3.5547, V
IDE05313,Charge air pressure control valve activation pulse duty factor,-14.80, %
IDE05314-ENG112584,Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0],00000000 ,
IDE05315,Charge air pressure control valve voltage: position closed,3.5156, V
IDE05316,Charge air pressure control valve voltage: position open,0.5701, V
IDE05317-ENG112583,Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0],00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,0.000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.375, bar
IDE05622-ENG125277,Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL,0,
IDE06006,Idle speed specified value,800, /min
IDE06192,Knock sensor: cylinder 2: voltage,0.544, V
IDE06193,Knock sensor: cylinder 3: voltage,0.380, V
IDE06194,Knock sensor: cylinder 4: voltage,0.656, V
IDE06195,Knock sensor: cylinder 1: voltage,0.575, V
IDE06296-ENG104200,Activation of oxygen control after main cat-Lambda probe 2: bank 1: status,00000001 ,
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,11,
IDE06307-MAS00108,Stop prevention history data-Day,10,
IDE06307-MAS00109,Stop prevention history data-Hours,16,
IDE06307-MAS00110,Stop prevention history data-Minutes,16,
IDE06307-MAS00111,Stop prevention history data-Seconds,23,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Driving situation,
IDE06307,Stop prevention history data,Steering,
IDE06307,Stop prevention history data,Steering angle,
IDE06308-MAS00106,Start request history data-Year,2019,
IDE06308-MAS00107,Start request history data-Month,8,
IDE06308-MAS00108,Start request history data-Day,30,
IDE06308-MAS00109,Start request history data-Hours,11,
IDE06308-MAS00110,Start request history data-Minutes,55,
IDE06308-MAS00111,Start request history data-Seconds,29,
IDE06308,Start request history data,not active,
IDE06308,Start request history data,Brake under pressure too low,
IDE06386,Oil level: static measurement,0, mm
IDE06387,Oil level: last valid dynamic value,0, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,0, mm
IDE06390,Oil level: minimum value,0, mm
IDE06391,Oil temperature sensor 2,93.0, °C
IDE06392,Oil temperature sensor 2: raw value,65.535, V
IDE06393,Oil level: dynamic average value,0, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,0.000, V
IDE06395,Fuel low pressure sensor: unconditioned voltage,4.995, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,0.658, V
IDE06397,Temperature sensor for engine temp. management: target value,107.3, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,0.659, V
IDE06399,Manifold absolute pressure sensor: unconditioned voltage,0.757, V
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06432,Oxygen sensor 1 bank 1 signal status,active,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,1.948, V
IDE06567,Start-stop function deactivation frequency counter,2951,
IDE06568,Stop prevention by driver frequency counter,11765,
IDE06569,Vehicle stopped frequency counter,25649,
IDE06573,Long-term adaptation of intake manifold injection,0.00, %
IDE06574,Long-term adaptation of intake manifold injection in idle,0.00, mg/stroke
IDE06610,Vehicle standstill with stop frequency counter,2290,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,Yes,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,Yes,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC,
IDE06707,CCS Switch,CCS operating unit,
IDE06709,ACC variants (coding),CCS,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06726,Timing deviation after chain replacement: intake bank 1,-1.00, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,-4.06, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,-0.94, °
IDE06736,Timing deviation: current value exhaust bank 1,-4.00, °
IDE07001,Piston-cooling jets: activation,On,
IDE07008,Tank leak: number no leak detected,0,
IDE07011,Tank leak: number communication errors to engine control,0,
IDE07014,Tank leak: number very small leaks detected,0,
IDE07019,Number of ignitions direct injection,0,
IDE07020,Number of ignitions intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,2.6214e+010, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07159-MAS00478,Control module switch-off: counter-Reserved,-1,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE07242,Heater support pump: spec. value,62.40, %
IDE07548,Engine temp. mangmt. actuator: specified value of angle,75.25, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,74.36, °
IDE07550,Engine temp. management actuator: raw value,1252,
IDE07551,Engine temp. management actuator: duty cycle activation,-4.67, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Adaptation successfully finished,
IDE07553,Engine temperature management actuator: after-run stop,3954,
IDE07554,Engine temperature management actuator: stop open,137,
IDE07564,Required torque adjustment by idling regulator,-0.3, Nm
IDE07571,Engine torque,18.6, Nm
IDE07572,High pressure regulation: adaptation value,0.72, mg
IDE07574,Long-term fuel trim bank 1 at idle,0.47, mg/stroke
IDE07575,Driver request torque,-0.3, Nm
IDE07576,Lost torque adaptation driving mode,0.0, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,1.0, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,not activated,
IDE07598-MAS00325,Cruise control switch actuation-Setting,not activated,
IDE07598-MAS00326,Cruise control switch actuation-Activation,not activated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,not activated,
IDE07598-MAS02310,Cruise control switch actuation-Decelerate,not activated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,not activated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,not activated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,not activated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,not activated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,not activated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07599-MAS01505,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off,No,
IDE07599-MAS03849,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal,No,
IDE07599-MAS04795,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off,Yes,
IDE07599-MAS05135,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected,No,
IDE07599-MAS05136,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control,No,
IDE07599-MAS05190,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated,Yes,
IDE07599-MAS05192,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking,No,
IDE07599-MAS05196,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error,No,
IDE07599-MAS05814,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error,No,
IDE07599-MAS05815,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error,No,
IDE07599-MAS05816,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error,No,
IDE07599-MAS05817,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation,No,
IDE07599-MAS05818,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible,No,
IDE07599-MAS05819,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking,No,
IDE07599-MAS05820,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error,No,
IDE07599-MAS05821,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak,No,
IDE07599-MAS05822,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available,No,
IDE07599-MAS05823,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization,No,
IDE07599-MAS05824,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation,No,
IDE07599-MAS05825,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault,No,
IDE07599-MAS05826,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault,No,
IDE07599-MAS05827,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met,No,
IDE07599-MAS05828,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature,No,
IDE07599-MAS05829,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault,No,
IDE07599-MAS05830,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component,No,
IDE07599-MAS05831,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component,No,
IDE07599-MAS05832,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error,No,
IDE07599-MAS05833,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error,No,
IDE07599-MAS05834,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault,No,
IDE07599-MAS05835,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault,No,
IDE07599-MAS05836,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error,No,
IDE07599-MAS05837,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error,No,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07669,Oxygen sensor 2 Bank 1 after cat operation readiness Status,active,
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,not activated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,not activated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,not activated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07945-MAS00334,Status of intermittent monitoring-Catalytic converter monitoring,not completed successfully,
IDE07945-MAS00335,Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature,completed successfully,
IDE07945-MAS00336,Status of intermittent monitoring-Monitoring of tank ventilation system,not completed successfully,
IDE07945-MAS00337,Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system,completed successfully,
IDE07945-MAS00338,Status of intermittent monitoring-Monitoring of A/C system refrigerant,completed successfully,
IDE07945-MAS00339,Status of intermittent monitoring-Monitoring of oxygen sensor,not completed successfully,
IDE07945-MAS00340,Status of intermittent monitoring-Monitoring of oxygen sensor heater,completed successfully,
IDE07945-MAS00341,Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR),not completed successfully,
IDE08071-ENG119931,Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1,0,
IDE08072-ENG119932,Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2,0,
IDE08073-ENG119933,Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3,0,
IDE08074-ENG119934,Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4,0,
IDE08075-ENG119935,Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5,0,
IDE08495,Activation radiator shutter result,0.00, %
IDE08805,EVAP valve diag. activation condition at minimal load,0.093, counts
IDE08806,EVAP valve diag. activation condition at maximum load,678, mbar
IDE10063-MAS00666,Engine oil level: current value-Warning,no warning,
IDE10063-MAS00900,Engine oil level: current value-Oil level,98.70, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,31921, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,31912, km
IDE10063-MAS09804,Engine oil level: current value-Test method 1,On,
IDE10063-MAS09805,Engine oil level: current value-Test method 2,On,
IDE10063-MAS09806,Engine oil level: current value-Test method 3,OFF,
IDE10063-MAS09807,Engine oil level: current value-Qualification,7,
IDE10064-MAS00666,Engine oil level: history 1-Warning,no warning,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,87.80, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,31180, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,31157, km
IDE10064-MAS09804,Engine oil level: history 1-Test method 1,On,
IDE10064-MAS09805,Engine oil level: history 1-Test method 2,On,
IDE10064-MAS09806,Engine oil level: history 1-Test method 3,OFF,
IDE10064-MAS09807,Engine oil level: history 1-Qualification,7,
IDE10065-MAS00666,Engine oil level: history 2-Warning,no warning,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,102.90, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,30434, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,30419, km
IDE10065-MAS09804,Engine oil level: history 2-Test method 1,On,
IDE10065-MAS09805,Engine oil level: history 2-Test method 2,On,
IDE10065-MAS09806,Engine oil level: history 2-Test method 3,OFF,
IDE10065-MAS09807,Engine oil level: history 2-Qualification,7,
IDE10066-MAS00666,Engine oil level: history 3-Warning,no warning,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,96.60, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,29693, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,29689, km
IDE10066-MAS09804,Engine oil level: history 3-Test method 1,On,
IDE10066-MAS09805,Engine oil level: history 3-Test method 2,On,
IDE10066-MAS09806,Engine oil level: history 3-Test method 3,OFF,
IDE10066-MAS09807,Engine oil level: history 3-Qualification,7,
IDE10067-MAS00666,Engine oil level: history 4-Warning,no warning,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,101.30, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,28946, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,28944, km
IDE10067-MAS09804,Engine oil level: history 4-Test method 1,On,
IDE10067-MAS09805,Engine oil level: history 4-Test method 2,On,
IDE10067-MAS09806,Engine oil level: history 4-Test method 3,OFF,
IDE10067-MAS09807,Engine oil level: history 4-Qualification,7,
IDE10068-MAS00666,Engine oil level: history 5-Warning,no warning,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,106.10, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,28203, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,28199, km
IDE10068-MAS09804,Engine oil level: history 5-Test method 1,On,
IDE10068-MAS09805,Engine oil level: history 5-Test method 2,On,
IDE10068-MAS09806,Engine oil level: history 5-Test method 3,OFF,
IDE10068-MAS09807,Engine oil level: history 5-Qualification,7,
IDE10069-MAS00666,Engine oil level: history 6-Warning,no warning,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,107.00, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,27465, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,27446, km
IDE10069-MAS09804,Engine oil level: history 6-Test method 1,On,
IDE10069-MAS09805,Engine oil level: history 6-Test method 2,On,
IDE10069-MAS09806,Engine oil level: history 6-Test method 3,OFF,
IDE10069-MAS09807,Engine oil level: history 6-Qualification,7,
IDE10070-MAS00666,Engine oil level: history 7-Warning,no warning,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,116.00, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,26714, km
IDE10070-MAS09804,Engine oil level: history 7-Test method 1,On,
IDE10070-MAS09805,Engine oil level: history 7-Test method 2,On,
IDE10070-MAS09806,Engine oil level: history 7-Test method 3,OFF,
IDE10070-MAS09807,Engine oil level: history 7-Qualification,7,
IDE10071-MAS00666,Engine oil level: history 8-Warning,no warning,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,116.40, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,25972, km
IDE10071-MAS09804,Engine oil level: history 8-Test method 1,On,
IDE10071-MAS09805,Engine oil level: history 8-Test method 2,On,
IDE10071-MAS09806,Engine oil level: history 8-Test method 3,OFF,
IDE10071-MAS09807,Engine oil level: history 8-Qualification,7,
IDE10072-MAS00666,Engine oil level: history 9-Warning,no warning,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,112.50, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,25244, km
IDE10072-MAS09804,Engine oil level: history 9-Test method 1,On,
IDE10072-MAS09805,Engine oil level: history 9-Test method 2,On,
IDE10072-MAS09806,Engine oil level: history 9-Test method 3,OFF,
IDE10072-MAS09807,Engine oil level: history 9-Qualification,7,
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.616, V
IDE10380,Knock sensor average voltage bank 1,0.488, V
IDE10551-MAS05304,Pre-ignition counter for oxygen shift-Cylinder 1,0,
IDE10551-MAS05305,Pre-ignition counter for oxygen shift-Cylinder 2,0,
IDE10551-MAS05306,Pre-ignition counter for oxygen shift-Cylinder 3,0,
IDE10551-MAS05307,Pre-ignition counter for oxygen shift-Cylinder 4,1,
IDE10551-MAS05308,Pre-ignition counter for oxygen shift-Cylinder 5,0,
IDE10551-MAS05309,Pre-ignition counter for oxygen shift-Cylinder 6,0,
IDE10551-MAS05310,Pre-ignition counter for oxygen shift-Cylinder 7,0,
IDE10551-MAS05311,Pre-ignition counter for oxygen shift-Cylinder 8,0,
IDE10552-MAS05304,Pre-ignition counter for torque reduction-Cylinder 1,0,
IDE10552-MAS05305,Pre-ignition counter for torque reduction-Cylinder 2,0,
IDE10552-MAS05306,Pre-ignition counter for torque reduction-Cylinder 3,0,
IDE10552-MAS05307,Pre-ignition counter for torque reduction-Cylinder 4,0,
IDE10552-MAS05308,Pre-ignition counter for torque reduction-Cylinder 5,0,
IDE10552-MAS05309,Pre-ignition counter for torque reduction-Cylinder 6,0,
IDE10552-MAS05310,Pre-ignition counter for torque reduction-Cylinder 7,0,
IDE10552-MAS05311,Pre-ignition counter for torque reduction-Cylinder 8,0,
IDE10553-MAS05304,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1,0,
IDE10553-MAS05305,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2,0,
IDE10553-MAS05306,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3,0,
IDE10553-MAS05307,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4,0,
IDE10553-MAS05308,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5,0,
IDE10553-MAS05309,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6,0,
IDE10553-MAS05310,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7,0,
IDE10553-MAS05311,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8,0,
IDE10554-MAS05304,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1,0,
IDE10554-MAS05305,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2,0,
IDE10554-MAS05306,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3,0,
IDE10554-MAS05307,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4,0,
IDE10554-MAS05308,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5,0,
IDE10554-MAS05309,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6,0,
IDE10554-MAS05310,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7,0,
IDE10554-MAS05311,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8,0,
IDE10580,Engine oil level: test method 1,86.50, %
IDE10581,Engine oil level: test method 2,90.50, %
IDE10582,Engine oil level: test method 3,95.80, %
IDE10634,Clutch protection function: slip speed of the clutch,0, /min
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10848,Accelerator position,0.00, %
IDE10922,Pump current of tank leakage diag.: corrected & filtered,0.000, mA
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10994,Poor start counter at start-stop,0,
IDE11065,Accel. pedal pos. sensor 1,614,
IDE11066,Accel. pedal pos. sensor 2,307,
IDE11115,Start/stop driver request: counter restart by starter,65,
IDE11116,Start/stop driver request: counter internal-motor restart,17,
IDE11267,Oil level: max. value: relative,108.50, %
IDE11268,Oil level: min. value: relative,74.90, %
IDE11302-MAS05513,Engine oil level: test method 1:qualification-Bit 0,1,
IDE11302,Engine oil level: test method 1:qualification,NO VALUE AVAILABLE,
IDE11303-MAS05513,Engine oil level: test method 3:qualification-Bit 0,1,
IDE11303,Engine oil level: test method 3:qualification,NO VALUE AVAILABLE,
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometers,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometers,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometers,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometers,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometers,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometers,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometers,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometers,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometers,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometers,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11598,Tank deaeration valve diagnosis: unweighted input value,0.000, counts
IDE11599,Tank deaeration valve diagnosis: weighted output value,0.000, counts
IDE11600,Tank tightness: ambient temperature,-48.00, °C
IDE11919,Lock time for cooling down of secondary air pump,0, s
IDE12137,Tank fill level diagnostic reference value,41.0, l
IDE12138,Fuel consumption per driving cycle,71.43, l/100km
ENG102981,AC compressor: speed increase,00000001 ,
ENG103860,AC request: speed increase,00000000 ,
ENG103042,Accelerator pedal sender: learned end stop,4.126, V
ENG101488,ACF: load,0.02344,
ENG103474,Activation of oil pressure switching valve,00000001 ,
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,9.53, kg/h
ENG104264,Alternator load,650, W
ENG103910,Ambient temperature,25.50, °C
ENG112539,AR_THR_AD_ADD_MMV,-0.0376, cm²
ENG98377,As,none,
ENG103165,Battery voltage,13.0, V
ENG07601,Bypasstool_a2l_name,SCBS4131_C_OEM A2L,
ENG07600,Bypasstool_manipulation_bit,not active,
ENG128780,CAM_DIF_VCP[EX_1],-0.070, °
ENG128781,CAM_DIF_VCP[IN_1],-0.133, °
ENG102002,CAM_OFS_IVVT_IN[1],0.000, °
ENG112540,CAM_PHA_ENG[GES_EX][CBK_1],4.336, °
ENG112541,CAM_PHA_ENG[GES_IN][CBK_1],4.836, °
ENG101169,CAM_PHA_OFS_MAF[IN][1],0.000, °
ENG112542,CAM_SP_IND_VCP[EX_1],4.500, °
ENG112543,CAM_SP_IND_VCP[IN_1],5.000, °
ENG112544,CAM_VCP[EX_1],4.375, °
ENG112545,CAM_VCP[IN_1],4.977, °
ENG103849,Cat. ageing: bank 1: actual,0.000,
ENG101785,Cat. temperature: bank 1,419.4125, °C
ENG102214,CPU_LOAD,56.3, %
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ[0],0,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ[1],0,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ[2],1,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ[3],0,
ENG101127,CTR_CDN_OBD_RBM,876,
ENG114826,CTR_EDGE_CAM_EX[1],99,
ENG114827,CTR_EDGE_CAM_IN[1],104,
ENG100536,CTR_IGK_CYC_RBM,2481,
ENG125193,CTR_LAMB_SP_PI_REQ[0],0,
ENG125194,CTR_LAMB_SP_PI_REQ[1],0,
ENG125195,CTR_LAMB_SP_PI_REQ[2],1,
ENG125196,CTR_LAMB_SP_PI_REQ[3],0,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE[0],0,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE[1],0,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE[2],0,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE[3],0,
ENG112558,CTR_MIS_TOT_NVMY_SAE,13116,
ENG125197,CTR_REQ_IV_OFF_PI_FAST[0],0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST[1],0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST[2],0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST[3],0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW[0],0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW[1],0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW[2],0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW[3],0,
ENG128782,CTR_REQ_IV_OFF_PI_SLOW_TMP[0],0,
ENG128783,CTR_REQ_IV_OFF_PI_SLOW_TMP[1],0,
ENG128784,CTR_REQ_IV_OFF_PI_SLOW_TMP[2],0,
ENG128785,CTR_REQ_IV_OFF_PI_SLOW_TMP[3],0,
ENG100764,CTR_SUM_SRV_INTL,0.0,
ENG125205,CTR_TQI_POW_MAX_PI_REQ[0],0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ[1],0,
ENG125207,CTR_TQI_POW_MAX_PI_REQ[2],0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ[3],0,
ENG119929,CTR_VLD_CAT_GAP_AFL[1],0,
ENG119930,CTR_VLD_CAT_GAP_AFR[1],0,
ENG99428,CTR_VLFT_1_SWI_NOT[0],0,
ENG103626,CTR_VLFT_1_SWI_NOT[1],0,
ENG100809,CTR_VLFT_1_SWI_NOT[2],0,
ENG99336,CTR_VLFT_1_SWI_NOT[3],0,
ENG103025,CTR_VLFT_STND_SWI_NOT[0],0,
ENG100017,CTR_VLFT_STND_SWI_NOT[1],0,
ENG100438,CTR_VLFT_STND_SWI_NOT[2],0,
ENG100736,CTR_VLFT_STND_SWI_NOT[3],0,
ENG112559,CTR_VVL_LIH_ACT,0,
ENG101271,CTR_VVL_LIH_DEAC,0,
ENG100551,CTR_VVL_SWI_DC,0,
ENG99561,CTR_VVL_SWI_H,0,
ENG101173,CTR_VVL_SWI_L,5384,
ENG99084,Cycle flags: (completed cycles): cat: lambda probe heater,9,
ENG100943,Cycle flags: (completed cycles): lambda probes: EGR,0,
ENG99495,Cycle flags: (completed tests): lambda adaption:,8,
ENG103597,Cycle flags:(completed cycles):lambda probes:sec.air sys.,56,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG102657,DIAG_INST[0],NO_ERROR,
ENG99120,DIAG_INST[1],NO_ERROR,
ENG103260,DIAG_INST[2],NO_ERROR,
ENG99710,DIAG_INST[3],NO_ERROR,
ENG102667,DIAG_INST[4],NO_ERROR,
ENG102739,DIAG_INST[5],NO_ERROR,
ENG100162,DIAG_INST[6],NO_ERROR,
ENG99103,DIAG_INST[7],NO_ERROR,
ENG99261,DIAG_INST[8],NO_ERROR,
ENG103622,DIAG_INST[9],NO_ERROR,
ENG112560,DIST_ACT_MIL_SAE,0, km
ENG112561,DIST_DTC_CLR_SAE,0, km
ENG103766,DIST_ENG_RUN_IN,32410704.9, m
ENG100531,DIST_ST,3.24078e+007, m
ENG100131,ECU_STATE,SYN_ENG_IGK_ON,
ENG103712,EFPPWM_MIN_AD,0.000, %
ENG104044,Engine load,14.843750, %
ENG102494,Engine speed: actual,768, /min
ENG102783,Engine: operating status,IS,
ENG103667,ENVD_0_MON,0,
ENG100777,ENVD_0_MON_3,0,
ENG126934,ENVD_0_MON_3_VD,0,
ENG99424,ENVD_1_MON,0,
ENG100344,ENVD_1_MON_3,0,
ENG126935,ENVD_1_MON_3_VD,0,
ENG99790,ENVD_2_MON,0,
ENG100541,ENVD_2_MON_3,0,
ENG126936,ENVD_2_MON_3_VD,0,
ENG99455,ENVD_3_MON,0,
ENG101268,ENVD_3_MON_3,0,
ENG126937,ENVD_3_MON_3_VD,0,
ENG01743,ENVD_4_MON,0,
ENG01744,ENVD_5_MON,0,
ENG01745,ENVD_6_MON,0,
ENG99752,Error flags: (completed cycles): cat: lambda probe heater,0,
ENG101275,Error flags: (completed cycles): lambda probes: EGR,0,
ENG104132,Error flags: (completed cycles): lambda probes:sec.air sys.,0,
ENG101942,ESI (extended service intervals) oil warning threshold,0.00, mm
ENG112562,FAC_AR_THR_AD,0.000, %
ENG104194,FAC_H_RNG_LAM_AD[1],0.000, %
ENG104151,FAC_L_RNG_LAM_AD[1],0.000, %
ENG100298,FAC_LAM_CP,-0.607, %
ENG100108,FAC_LAM_LIM[1],-0.685, %
ENG99722,FAC_LAM_TCO_A[1],0.000, %
ENG103521,FAC_LAM_TCO_B[1],0.000, %
ENG103641,FAC_LAM_TCO_C[1],0.000, %
ENG101578,FAC_LAM_TCO_D[1],0.000, %
ENG100685,FAC_LAM_TCO_E[1],0.000, %
ENG103307,FAC_MAF_MAX,0.04614,
ENG99791,FAC_SLOP_IV[1],0.00000,
ENG102306,FAC_TPS_1_SAE,11.718750, %
ENG102292,FAC_TPS_1_SAE,11.718750, %
ENG99630,Fan control relay: fan run-on,4194304,
ENG101437,Fan request from air conditioner,46.5, %
ENG124827,FIBEX_Integration_Step,V08.10.00,
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG128786,FTL_SAE,56.86274603, %
ENG104248,Fuel consumption signal,12284, µl
ENG101667,Fuel pump: adaption value,0.000, %
ENG100969,Fuel pump: fuel pressure: I-controller,0.000, %
ENG100250,Fuel regulating valve: duty cycle,13.380, %
ENG101692,Fuel supply system: high-pressure regulator,-90.5604, hPa
ENG114828,FUP_EFP_MES,11000.8, hPa
ENG103553,FUP_EFP_ST_H,0, hPa
ENG101056,FUP_EFP_ST_L,0, hPa
ENG99950,FUP_EFP_STOP_H,0, hPa
ENG100784,FUP_EFP_STOP_L,0, hPa
ENG102108,FUP_H,55641.0, hPa
ENG112563,FUP_H_SAE,5480.0, kPa
ENG103368,Gearbox -CAN bus messages,110455,
ENG99170,Height correction,1020.30, hPa
ENG103575,High-pressure system: regulator,-0.17, mg
ENG103879,High-pressure system: regulator: mobile part,2.23, mg
ENG102603,High-pressure system: status,MFP_CTL,
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,10.0, Nm
ENG101946,Idling stabilisation: operating status,00000000 ,
ENG100345,IGA_ADJ_KNK[0],0.000, °
ENG103593,IGA_ADJ_KNK[1],0.000, °
ENG103360,IGA_ADJ_KNK[2],0.000, °
ENG99404,IGA_ADJ_KNK[3],0.000, °
ENG100425,IGA_IGC[0],4.125, °
ENG101655,IGA_IGC[1],4.500, °
ENG100410,IGA_IGC[2],3.750, °
ENG100407,IGA_IGC[3],3.750, °
ENG112564,IGA_IGC_SAE,3.5, °
ENG101741,Intake air temperature,57.00, °C
ENG125209,KNKS_ERR_REL[0],0.0586, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ[1],0.00000,
ENG99601,LAMB_DELTA_I_LAM_ADJ[1],-0.00079,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD[1],0.00000,
ENG99674,Lambda controller: bank 1 (averaged value),-0.439, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000001 ,
ENG101336,Lambda probe 2: bank 1: status,00000001 ,
ENG99661,Lambda probe ageing: bank 1: dynamic factor,0.0000,
ENG101869,Lambda probe ageing: bank 1: probe 1: short trip result,320.8500, °C
ENG100478,Lambda probe correction: duty cycle offset: bank 1,-0.00195,
ENG103776,Lambda probe heater: bank 1: probe 2: short trip result,00000000 ,
ENG102380,Lambda probe heater: resistance: bank 1: probe 2,331, Ohm
ENG99353,Lambda probe voltage: bank 1: probe 1 (broadband probe),1.978, V
ENG102763,Lambda probes actual: bank1,1.0029,
ENG104114,Lambda probes specified: bank1,1.0020,
ENG06592,LF_COSI_CTL_ERR_A,0,
ENG06593,LF_COSI_CTL_ERR_B,0,
ENG112566,LF_DPS_CYC_ERR_RAW_BSW[1],16384,
ENG112567,LF_DPS_CYC_ERR_RAW_BSW[2],16384,
ENG112568,LF_DPS_CYC_ERR_VLD_BSW[1],65535,
ENG112569,LF_DPS_CYC_ERR_VLD_BSW[2],65535,
ENG112570,LF_DPS_INI_ERR_RAW_BSW[1],0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW[2],0,
ENG112572,LF_IV_ERR_RAW_BSW[0],0,
ENG112573,LF_IV_ERR_RAW_BSW[1],0,
ENG112574,LF_IV_ERR_RAW_BSW[2],0,
ENG112575,LF_IV_ERR_RAW_BSW[3],0,
ENG112576,LF_IV_ERR_VLD_BSW[0],8191,
ENG112577,LF_IV_ERR_VLD_BSW[1],8191,
ENG112578,LF_IV_ERR_VLD_BSW[2],8191,
ENG112579,LF_IV_ERR_VLD_BSW[3],8191,
ENG07602,LF_MVB_BUS_INTC_DIAG,256,
ENG07603,LF_MVB_PDU_INTC_DIAG_1,0,
ENG07604,LF_MVB_PDU_INTC_DIAG_10,0,
ENG07605,LF_MVB_PDU_INTC_DIAG_13,31743,
ENG07606,LF_MVB_PDU_INTC_DIAG_14,0,
ENG07607,LF_MVB_PDU_INTC_DIAG_15,39184,
ENG07608,LF_MVB_PDU_INTC_DIAG_16,0,
ENG07609,LF_MVB_PDU_INTC_DIAG_17,512,
ENG07610,LF_MVB_PDU_INTC_DIAG_18,35,
ENG07611,LF_MVB_PDU_INTC_DIAG_2,49152,
ENG07612,LF_MVB_PDU_INTC_DIAG_3,3,
ENG07613,LF_MVB_PDU_INTC_DIAG_4,12288,
ENG07614,LF_MVB_PDU_INTC_DIAG_5,0,
ENG07615,LF_MVB_PDU_INTC_DIAG_6,61472,
ENG07616,LF_MVB_PDU_INTC_DIAG_7,36864,
ENG07617,LF_MVB_PDU_INTC_DIAG_8,7,
ENG07618,LF_MVB_PDU_INTC_DIAG_9,64896,
ENG101645,LF_VVL_DIAG_SWI_NOT,0,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2019,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,11,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,4,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,14,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,39,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,5,
ENG127734,Life_cycle_data_start_requirement_development,not active,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2019,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,11,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,9,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,12,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,16,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,5,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2019,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,11,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,5,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,13,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,8,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,1,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Kessy,
ENG122701,LMVDes_st_Mod_Out_VW,154,
ENG122702,LMVDes_v_Max_Man_Lim_VW,511.992, km/h
ENG122703,LMVLim_v_Auth_Max_Out_VW,202.0000, km/h
ENG100402,LOIL_SUM_SRV_INTL,-0.06, mm
ENG99162,LV_ACC_RED_CMD,00000000 ,
ENG102235,LV_ATB_ACT_1,00000000 ,
ENG102541,LV_ATB_ACT_2,00000000 ,
ENG114829,LV_BPA_LIH_REQ[0],0,
ENG99095,LV_CAN_HOOD_SWI,00000000 ,
ENG128787,LV_CMD_RCL_OPEN,00000000 ,
ENG07619,LV_ECRAS_FB_DIAG_POS_RESP[1],00000000 ,
ENG103049,LV_EFPPWM_AD_STOP,00000001 ,
ENG101712,LV_ENG_RUN_IN,00000000 ,
ENG100267,LV_ENG_RUN_IN_EXT_ADJ,00000000 ,
ENG103319,LV_ERR_VLFT_1_SWI[1],00000000 ,
ENG103549,LV_ERR_VLFT_1_SWI[2],00000000 ,
ENG103191,LV_ERR_VLFT_1_SWI[3],00000000 ,
ENG101989,LV_ERR_VLFT_1_SWI[4],00000000 ,
ENG102313,LV_ERR_VLFT_STND_SWI[1],00000000 ,
ENG103044,LV_ERR_VLFT_STND_SWI[2],00000000 ,
ENG103443,LV_ERR_VLFT_STND_SWI[3],00000000 ,
ENG100487,LV_ERR_VLFT_STND_SWI[4],00000000 ,
ENG112471,LV_IGK,00000001 ,
ENG103773,LV_INH_STR_RLY,00000000 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,00000000 ,
ENG103908,LV_LOIL_L_WARN_TMP,00000000 ,
ENG103716,LV_POIL_SWI_H,00000000 ,
ENG100912,LV_POIL_SWI_L,00000001 ,
ENG112586,LV_PWR_RLY[0],00000001 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,0,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112587,LV_VCP_AD_END,00000001 ,
ENG99288,MAF_DIF_CAM_OFS_AD_SQ_TOT,0.000, kg²/h²
ENG112588,MAP_MES_SAE,34, kPa
ENG103501,MASS_SA_REL[0],1.000,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG103346,MFF_ADD_LAM_AD[1],0.47, mg/stroke
ENG126493,MFF_MPL_ADD_LAM_AD[1][1],0.47, mg/stroke
ENG101360,Misfire detection active,00000000 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG128796,N_SP_IS_CLC,800, /min
ENG103004,N_TCHA,7446.29, /min
ENG112590,N_TOOTH,796, /min
ENG107737-ENG112538,NC_NR_DIAG_RBM-NC Value,149,
ENG126111,NL_PRE[0],0.21378, V
ENG126112,NL_PRE[1],0.25612, V
ENG126113,NL_PRE[2],0.20737, V
ENG126114,NL_PRE[3],0.16632, V
ENG128789,NR_CYC_AD_DC_BAL_HOM[RNG_H],0,
ENG128790,NR_CYC_AD_DC_BAL_HOM[RNG_IS],0,
ENG128791,NR_CYC_AD_DC_BAL_HOM[RNG_L],0,
ENG128792,NR_CYC_AD_DIAG_BAL_HOM[0],0,
ENG128793,NR_CYC_AD_DIAG_BAL_HOM[1],0,
ENG128794,NR_CYC_AD_DIAG_BAL_HOM[2],0,
ENG128795,NR_CYC_AD_DIAG_BAL_HOM[3],0,
ENG112589,NR_CYL_FIRST_VVL_SWI,0,
ENG99776,NR_CYL_VVL_H_ACK,0,
ENG119936,O2L_MAX_CAT_GAP_AFL_MV[1],0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV[1],0.00000, g
ENG99157,PRS_SA_DIF,0.00, hPa
ENG02464,PRS_UP_THR_MES,1019.06, hPa
ENG112591,PSN_EDGE_REL_AD_CAM_EX[1][1],-2.8750, °
ENG112592,PSN_EDGE_REL_AD_CAM_IN[1][1],0.3750, °
ENG114830,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1],-2.8750, °
ENG114831,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2],-4.3750, °
ENG114832,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1],0.3750, °
ENG114833,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2],-0.9375, °
ENG128797,PV,0.00, %
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP[EX_1],90.002, %
ENG112594,PWM_ACT_VCP[IN_1],90.002, %
ENG101350,PWM_ETC,-18.457, %
ENG112595,PWM_HLD_VCP[EX_1],56.970, %
ENG112596,PWM_HLD_VCP[IN_1],47.192, %
ENG112597,PWM_PAS_VCP[EX_1],11.017, %
ENG112598,PWM_PAS_VCP[IN_1],11.017, %
ENG101201,Radiator fan 1: run-on: status,600W,
ENG102359,Radiator fan 2: run-on: status,400W,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV[1],0.0000000,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV[1],0.0000000,
ENG102377,Ready and error flags,165,
ENG112599,RVC_AV,74.42, °
ENG112601,RVC_SP,75.25, °
ENG112600,RVCPWM,-6.165, %
ENG103248,SEG_AD_MMV_ER[0],0.0000, ‰
ENG101135,SEG_AD_MMV_ER[1],0.5479, ‰
ENG99078,SEG_AD_MMV_ER[2],-0.0915, ‰
ENG103257,SEG_AD_MMV_ER[3],0.6559, ‰
ENG102511,SEG_AD_MMV_ER_H[0],0.0000, ‰
ENG103258,SEG_AD_MMV_ER_H[1],0.5646, ‰
ENG99291,SEG_AD_MMV_ER_H[2],-0.0801, ‰
ENG99954,SEG_AD_MMV_ER_H[3],0.7043, ‰
ENG100568,SEG_AD_MMV_ER_L[0],0.0000, ‰
ENG100601,SEG_AD_MMV_ER_L[1],0.5479, ‰
ENG102668,SEG_AD_MMV_ER_L[2],-0.0915, ‰
ENG101232,SEG_AD_MMV_ER_L[3],0.6559, ‰
ENG101561,SEG_AD_MMV_ER_MID[0],0.0000, ‰
ENG102964,SEG_AD_MMV_ER_MID[1],0.4196, ‰
ENG100890,SEG_AD_MMV_ER_MID[2],-0.0005, ‰
ENG99793,SEG_AD_MMV_ER_MID[3],0.6018, ‰
ENG103381,Shut-off time,14.80, s
ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,10, %
ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,19, %
ENG102971,Start adaption: temperature adaption factor 1,1.000000,
ENG102489,Start adaption: temperature adaption factor 2,1.000000,
ENG100723,Start adaption: temperature adaption factor 3,1.000000,
ENG100919,Starter control: interlock switch,00000000 ,
ENG100800,Starter: start relay 1,00000000 ,
ENG99979,Starter: start relay 2,00000000 ,
ENG102033,STATE_BPA[0],OPM,
ENG102127,STATE_COMC_NVLD,Wait,
ENG112602,STATE_CRK_STST,CRK_STST_ACQ_SHO_LEVEL,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,18415680,
ENG112603,STATE_EOL_VVL,DEAC,
ENG112605,STATE_LS_SAE[1],CL,
ENG104238,STATE_NVLD,Wait,
ENG112606,STATE_PWM_VCP[EX_1],HLD,
ENG112607,STATE_PWM_VCP[IN_1],HLD,
ENG101078,STATE_READY_OBD_1,39,
ENG100369,STATE_READY_OBD_3,0,
ENG100342,STATE_REQ_NVLD,NO_REQ,
ENG109090,STATE_SW_MVB,SCBS4110 CBS0050,
ENG128798,STATE_T_ES_RD,1,
ENG128799,STATE_T_ES_VLD_RD,1,
ENG112608,STATE_VCP,enable,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG103723,STATE_VVL_MNG,VVL_L,
ENG112609,T_ACT_MIL_SAE,0, min
ENG112494,T_AST_SAE,679, s
ENG104148,T_COOL_LOIL,489.2, ms
ENG112613,T_DTC_CLR_SAE,11, min
ENG102790,T_EFP_MEM_H,0.00, s
ENG102123,T_EFP_MEM_L,0.00, s
ENG109299,T_ES,78, min
ENG112616,T_ES_DC,78, min
ENG99463,T_ES_H,4733, s
ENG128802,T_IGK,655.35, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG08783,T_PWL_ECU_ATIC,459.2, s
ENG112636,T_SWI_VVL_ACR,72.7, ms
ENG101325,T_TEMP_SIG_LOIL,62.9, ms
ENG99126,T_VS_TOL_LOCK,0, min
ENG125440,TAA,26.000, °C
ENG102048,Tank breather valve: duty cycle,0.000000, %
ENG101339,Tank breather valve: short trip result,0.0000, kg/h
ENG100439,Tank level,00000000 ,
ENG112610,TCO_1_FIRST_ST,75, °C
ENG112611,TCO_1_ST,75, °C
ENG112612,TCO_1_SYS,108, °C
ENG103434,TCO_A_LAM_AD_WUP[1],-15.00, °C
ENG100381,TCO_B_LAM_AD_WUP[1],-5.25, °C
ENG101581,TCO_C_LAM_AD_WUP[1],5.25, °C
ENG100354,TCO_D_LAM_AD_WUP[1],18.00, °C
ENG101973,TCO_E_LAM_AD_WUP[1],30.00, °C
ENG128800,TCO_MDL[STUCK_L_COOL_MON],42.492, °C
ENG124460,TCO_MDL[TH],60.391, °C
ENG100390,TCO_MIN_INTER_LAM_AD_WUP[1],108.00, °C
ENG100853,TCO_MIN_LAM_AD_WUP[1],50.25, °C
ENG102279,TCS/ESP: specified torque,1023.96875, Nm
ENG99857,TCS: status,00000000 ,
ENG110436,TEG_DYN_LS_DOWN[1],386.2875, °C
ENG110437,TEG_DYN_LS_UP[1],398.4750, °C
ENG101941,TEMP_CAT_STAT_MDL[1],418.7875, °C
ENG112614,TEMP_CAT_UP_1_SAE,419.1, °C
ENG114837,TFPA,110, °C
ENG114838,TFU_HPP,45.75, °C
ENG99608,Throttle valve adjuster: adaption status,ST_CHK_END,
ENG101411,Throttle valve angle,2.035, °
ENG102845,Throttle valve deviation,-3.775, %
ENG126115,TI_1_MES_MPI[0],0.000, ms
ENG126116,TI_1_MES_MPI[1],0.000, ms
ENG126117,TI_1_MES_MPI[2],0.000, ms
ENG126118,TI_1_MES_MPI[3],0.000, ms
ENG126119,TI_MES_4[PLS_1][0],1.000, ms
ENG126120,TI_MES_4[PLS_1][1],0.988, ms
ENG126121,TI_MES_4[PLS_1][2],1.000, ms
ENG126122,TI_MES_4[PLS_1][3],1.012, ms
ENG126123,TI_MES_4[PLS_2][0],0.000, ms
ENG126124,TI_MES_4[PLS_2][1],0.000, ms
ENG126125,TI_MES_4[PLS_2][2],0.000, ms
ENG126126,TI_MES_4[PLS_2][3],0.000, ms
ENG126127,TI_MES_4[PLS_3][0],0.000, ms
ENG126128,TI_MES_4[PLS_3][1],0.000, ms
ENG126129,TI_MES_4[PLS_3][2],0.000, ms
ENG126130,TI_MES_4[PLS_3][3],0.000, ms
ENG128801,TIA_CHA_DOWN_MV,72.000, °C
ENG125276,TIG_MES_SAE[IM],58, °C
ENG103351,Time since engine start,2382.6, s
ENG112634,TLTS_MES[TCE],108.695, °C
ENG112635,TMAG_VCP,93, °C
ENG110444,TPS_AD_CDN_MIS,4,
ENG114839,TPS_ETC,2.035, °
ENG99274,TPS_SP,2.013, °
ENG103021,TQ_CONV,0.00000, Nm
ENG128804,TQI_ADD_ACT,36.03125, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG128805,TQI_N_TCHA_MAX,1023.96875, Nm
ENG102329,TTIP_MES_LS_UP[1],785.0000, °C
ENG100355,V_FUP_EFP_MV,4.995, V
ENG100739,V_PVS_1_BAS,0.7510, V
ENG114840,V_PVS_KD,0.000, V
ENG99514,VBOOST,64.5, V
ENG103201,VCV_CLOSE_RNG,22.1, °
ENG102311,Vehicle speed: filtered,0.000, km/h
ENG122704,VLCAvl_st_Pt_VW,4,
ENG122705,VLCReq_st_Dem_VW,0,
ENG112639,VLS_DOWN_SAE[1],0.785, V
ENG128806,VOL_FLOW_CHA_UP_RED_MV,0.002228, m³/s
ENG101929,VP_TPS_1,0.5957, V
ENG102985,VP_TPS_2,4.3994, V
ENG100421,VP_TPS_AD_EL_BOL_1,0.5025, V
ENG103444,VP_TPS_AD_EL_BOL_2,4.5006, V
ENG101674,VP_TPS_AD_LIH_1,0.9082, V
ENG99507,VP_TPS_AD_LIH_2,4.0869, V
Elapsed Time: 01:24
adpmap-01-8W0-906-259-J
;SW:8W0-906-259-J   HW:06L-907-425-C ---  Engine
;Component:2.0l R4 TFSI  H15 0002, Coding:0A2500322326010E34280000000000000000000000000000
;EV_ECM20TFS0208W0906259J,001003,EV_ECM20TFS020_AU49.rod
;Sunday,10,November,2019,20:29:51:01617
;VCID: C8D35B6673B52A0FAF-809C
IDE01945-Engine run-in oil pressure,not active ,1
IDE02332-Deactivate production mode,00 00 00 ,3
IDE04158-Activation of start-stop function,active ,1
IDE04617-Protective function,Enabled ,1
IDE06726-Timing deviation after chain replacement: intake bank 1,-1.00 °,2
IDE06728-Timing deviation after chain replacement: exhaust bank 1,-4.06 °,2
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 °,2
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 °,2
IDE06734-Timing deviation: current value intake bank 1,-0.94 °,2
IDE06736-Timing deviation: current value exhaust bank 1,-4.00 °,2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,4 ,1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,5 ,1
IDE06742-Chain elongation: initial values valid: intake bank 1,active ,1
IDE06744-Chain elongation: initial values valid: exhaust bank 1,active ,1
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE10261-MAS10172-Operating mode selec.-DI operation,not activated ,4
IDE10261-MAS10174-Operating mode selec.-CNG operation,not activated ,4
IDE10261-Operating mode selec.-,not activated ,4
Elapsed Time: 00:04
Address [02]
blockmap-02-8W2-927-155-BA
;SW:8W2-927-155-BA   HW:0CJ-927-156 ---  Auto Trans
;Component:0CL 20TFSINAR H05 0001, Coding:000001
;EV_TCMDL382021,002027,EV_TCMDL382021_AU49.rod
;Sunday,10,November,2019,20:29:58:01617
;VCID: 81458642100FDB4728-80D4
Group,Description,Actual
IDE00019,Voltage terminal 30,13.300, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine speed,804, /min
IDE00022,Transmission input speed,805.00, /min
IDE00023,Transmission output speed,0.00, /min
IDE00024-ENG98502,Transmission fluid temperature-Data,52, °C
IDE00025,Coolant temperature,108, °C
IDE00026,Vehicle speed from transmission,0.00, km/h
IDE00027-MAS00179,Status of brake signals-Brake Light Switch,not activated,
IDE00027-MAS00180,Status of brake signals-Brake pressure switch,not activated,
IDE00027-MAS00181,Status of brake signals-Validity of brake pressure information,plausible,
IDE00027-MAS00182,Status of brake signals-Validity of brake pedal information,plausible,
IDE00027-ENG119971,Status of brake signals-MO_Fahrer_bremst,not activated,
IDE00027-ENG06674,Status of brake signals-MO_Konsistenz_Bremsped,plausible,
IDE00028,Road resistance index,0, %
IDE00031,Torque transmitting function,0.0,
IDE00075,Vehicle speed,0, km/h
IDE00085,Normed load value,14.1, %
IDE00086,Accelerator position,15, %
IDE00087-MAS00115,Tiptronic status-Tiptronic gate,not active,
IDE00087-MAS00116,Tiptronic status-Tiptronic +,not active,
IDE00087-MAS00117,Tiptronic status-Tiptronic -,not active,
IDE00087-MAS00118,Tiptronic status-Tiptronic steering wheel +,not active,
IDE00087-MAS00119,Tiptronic status-Tiptronic steering wheel -,not active,
IDE00089-ENG98502,Driving position-Data,P,
IDE00090-ENG100894,selected gear-Ist Gang,1,
IDE00091,Status of starter lock,On,
IDE00094,Kick-down status,not active,
IDE00095,Status of selector lever lock,not active,
IDE00096,Selector lever position,Error E5,
IDE00098,Transmission position,P,
IDE00100-ENG98502,Engine torque-Data,0, Nm
IDE00102,Control Module temperature,54, °C
IDE00109-ENG98502,Selector lever maximum pulse width High-Data,0.000, ms
IDE00110-ENG98502,Selector lever minimum pulse width High-Data,26.214, ms
IDE00111-ENG98502,Selector lever maximum pulse width Low-Data,0.000, ms
IDE00112-ENG98502,Selector lever minimum pulse width Low-Data,26.214, ms
IDE00138,Total driving time,569.25, H
IDE00139,Economical driving time portion,85.6, %
IDE00140,Sport driving time portion,14.0, %
IDE00141,Manual driving time portion,0.0, %
IDE00445,Unlearning counter according OBD,255,
IDE00450-ENG100352,Operating Instructions-Requested Action for Routine,--no display--,
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00853-ENG98502,Clutch 1 lower adaptation point-Data,2.750, bar
IDE00854-ENG98502,Clutch 1 upper adaptation point-Data,12.834, bar
IDE00855-ENG98502,Clutch 2 lower adaptation point-Data,3.227, bar
IDE00856-ENG98502,Clutch 2 upper adaptation point-Data,12.736, bar
IDE00857-ENG98502,Target gear of shift during upshift-Data,1,
IDE00858-ENG98502,Condition of upshift-Data,Selecting,
IDE00861-ENG98502,Target gear of shift during downshift-Data,1,
IDE00866-ENG98502,Specified torque clutch 1-Data,-500.00, Nm
IDE00867-ENG98502,Specified torque clutch 2-Data,-500.00, Nm
IDE00878-ENG98502,Clutch status-Data,Neutral,
IDE02861-ENG98502,Mechatronic identification-Data,0CK325026AA0CK325031APE5C08K0568180220,
IDE02862-ENG98502,Production data transmission-Data,006TBRC020746K180220,
IDE03008-MAS03911,Stop process prevented-Oil temperature too low,not active,
IDE03008-MAS03912,Stop process prevented-Transmission fluid temperature too high,not active,
IDE03008-MAS03915,Stop process prevented-Gear 1 or 2 not selected,not active,
IDE03008-MAS16496,Stop process prevented-Current draw of transmission control module is too high,not active,
IDE03010-MAS03911,Number of prevented stop processes-Oil temperature too low,0,
IDE03010-MAS03912,Number of prevented stop processes-Transmission fluid temperature too high,0,
IDE03010-MAS03915,Number of prevented stop processes-Gear 1 or 2 not selected,0,
IDE03010-MAS16496,Number of prevented stop processes-Current draw of transmission control module is too high,0,
IDE03011-MAS03916,Number of requested start processes-Gear selector position,0,
IDE03011-MAS16496,Number of requested start processes-Current draw of transmission control module is too high,0,
IDE03127-IDE03008,Prevented stop processes (ring memory)-Stop process prevented,Unknown (255),
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03128-IDE03009,Requested start processes (ring memory)-Start process requested,Unknown (255),
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE04288-ENG101799,Adaptation status of the engagement point of clutch 1-Param to DOP,Engagement point broken in,
IDE04289-ENG101799,Adaptation status of the engagement point of clutch 2-Param to DOP,Engagement point broken in,
IDE04347-IDE00019,Expanded environmental conditions-Voltage terminal 30,12.6, V
IDE04347-IDE00021,Expanded environmental conditions-Engine speed,0.00, /min
IDE04347-IDE00023,Expanded environmental conditions-Transmission output speed,0, /min
IDE04347-IDE00024,Expanded environmental conditions-Transmission fluid temperature,34, °C
IDE04347-IDE00026,Expanded environmental conditions-Vehicle speed from transmission,0.0, km/h
IDE04347-IDE00089,Expanded environmental conditions-Driving position,P,
IDE04347-IDE00090,Expanded environmental conditions-selected gear,N,
IDE04347-IDE00100,Expanded environmental conditions-Engine torque,67.00, Nm
IDE04347-IDE00102,Expanded environmental conditions-Control Module temperature,42, °C
IDE04347-IDE00853,Expanded environmental conditions-Clutch 1 lower adaptation point,2.7, bar
IDE04347-IDE00854,Expanded environmental conditions-Clutch 1 upper adaptation point,12.8, bar
IDE04347-IDE00855,Expanded environmental conditions-Clutch 2 lower adaptation point,3.6, bar
IDE04347-IDE00856,Expanded environmental conditions-Clutch 2 upper adaptation point,12.8, bar
IDE04347-IDE00857,Expanded environmental conditions-Target gear of shift during upshift,N,
IDE04347-IDE00858,Expanded environmental conditions-Condition of upshift,Selecting,
IDE04347-IDE00861,Expanded environmental conditions-Target gear of shift during downshift,N,
IDE04347-IDE00866,Expanded environmental conditions-Specified torque clutch 1,-500.00, Nm
IDE04347-IDE00867,Expanded environmental conditions-Specified torque clutch 2,-500.00, Nm
IDE04347-IDE00868,Expanded environmental conditions-Current of gear Solen.val. 1-3,0.0, mA
IDE04347-IDE00869,Expanded environmental conditions-Current of gear Solen.val. 2-R,0.0, mA
IDE04347-IDE00870,Expanded environmental conditions-Current of gear Solen.val. 4-6,0.0, mA
IDE04347-IDE00872,Expanded environmental conditions-Current of main pressure valve,0.0, mA
IDE04347-IDE00873,Expanded environmental conditions-Current of cooling oil valve,746.6, mA
IDE04347-IDE00874,Expanded environmental conditions-Current of partial transmission valve 1,0.7, mA
IDE04347-IDE00875,Expanded environmental conditions-Current of partial transmission valve 2,0.0, mA
IDE04347-IDE00876,Expanded environmental conditions-Clutch pressure: clutch 1,0.0, bar
IDE04347-IDE00877,Expanded environmental conditions-Clutch pressure: clutch 2,0.0, bar
IDE04347-IDE00878,Expanded environmental conditions-Clutch status,New,
IDE04347-IDE05990,Expanded environmental conditions-Pressure of clutch 2: specified value,0.0, bar
IDE04347-IDE05991,Expanded environmental conditions-Pressure of clutch 1: specified value,0.0, bar
IDE04347-IDE09396,Expanded environmental conditions-Aux. hydraulic pump 1: actual RPM,0, /min
IDE04347-IDE09397,Expanded environmental conditions-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE04347-IDE09399,Expanded environmental conditions-Electrical pump 2 for trans. oil: nominal speed,22, °C
IDE04347-IDE09400,Expanded environmental conditions-Oil pressure reservoir: status,undefined,
IDE04347-IDE10177,Expanded environmental conditions-Transmission input speed sensor 1,0, /min
IDE04347-IDE10178,Expanded environmental conditions-Transmission input speed sensor 2,0, /min
IDE04347-MAS00106,Expanded environmental conditions-Year,2018,
IDE04347-MAS00107,Expanded environmental conditions-Month,3,
IDE04347-MAS00108,Expanded environmental conditions-Day,2,
IDE04347-MAS00109,Expanded environmental conditions-Hours,0,
IDE04347-MAS00110,Expanded environmental conditions-Minutes,44,
IDE04347-MAS00111,Expanded environmental conditions-Seconds,34,
IDE04347-MAS00156,Expanded environmental conditions-Driving direction,unbestimmt,
IDE04347-ENG129958,Expanded environmental conditions-Accumulator_pressure_valve_actual_current,0.0, mA
IDE04347-ENG129957,Expanded environmental conditions-Accumulator_pressure_valve_commanded_current,0.0, mA
IDE04347-ENG129751,Expanded environmental conditions-Automatic_transmission_fluid_pressure_accumulator_pressure,0.0, bar
IDE04347-ENG129686,Expanded environmental conditions-Automatic_transmission_fluid_pump_adaption_state,Init,
IDE04347-ENG130017,Expanded environmental conditions-Automatic_transmission_fluid_pump_current_adapted,0.0, A
IDE04347-ENG129731,Expanded environmental conditions-Automatic_transmission_fluid_pump_phase_current,0, A
IDE04347-ENG130016,Expanded environmental conditions-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE04347-ENG130015,Expanded environmental conditions-Automatic_transmission_fluid_pump_shunt_current,0.00, A
IDE04347-ENG129701,Expanded environmental conditions-Automatic_transmission_fluid_source_of_commanded_speed,SBW,
IDE04347-ENG118442,Expanded environmental conditions-Clutch_0_actual_torque_hyb,0.00, Nm
IDE04347-ENG118288,Expanded environmental conditions-Clutch_0_adaption_kisspoint,0.0, bar
IDE04347-ENG118374,Expanded environmental conditions-Clutch_0_adaption_PKp1,0.0, bar
IDE04347-ENG118416,Expanded environmental conditions-Clutch_0_adaption_PKp2,0.0, bar
IDE04347-ENG129961,Expanded environmental conditions-Clutch_0_commanded_pressure,0.0, bar
IDE04347-ENG118399,Expanded environmental conditions-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE04347-ENG118318,Expanded environmental conditions-Clutch_0_steel_leaves_temperatur,0, °C
IDE04347-ENG129954,Expanded environmental conditions-Clutch_0_valve_actual_current,0.0, mA
IDE04347-ENG129953,Expanded environmental conditions-Clutch_0_valve_commanded_current,0.0, mA
IDE04347-ENG129969,Expanded environmental conditions-Clutch_1_cooling_oil_requirement_actual_value,0.0, l/min
IDE04347-ENG129968,Expanded environmental conditions-Clutch_1_cooling_oil_requirement_commanded_value,0.0, l/min
IDE04347-ENG129972,Expanded environmental conditions-Clutch_1_steel_leaves_temperatur,34, °C
IDE04347-ENG129955,Expanded environmental conditions-Clutch_1_valve_commanded_current,0.0, mA
IDE04347-ENG129971,Expanded environmental conditions-Clutch_2_cooling_oil_requirement_actual_value,0.0, l/min
IDE04347-ENG129970,Expanded environmental conditions-Clutch_2_cooling_oil_requirement_commanded_value,0.0, l/min
IDE04347-ENG129973,Expanded environmental conditions-Clutch_2_steel_leaves_temperatur,34, °C
IDE04347-ENG129956,Expanded environmental conditions-Clutch_2_valve_commanded_current,0.0, mA
IDE04347-ENG129966,Expanded environmental conditions-Clutch_actuation_substate,0,
IDE04347-ENG129965,Expanded environmental conditions-Clutch_adaption_kisspoint_state,OFF,
IDE04347-ENG118401,Expanded environmental conditions-Combustion_engine_speed_hyb,0, /min
IDE04347-ENG129952,Expanded environmental conditions-Cooling_pressure_valve_commanded_current,766.7, mA
IDE04347-ENG99228,Expanded environmental conditions-Diagnostic Fault Check Code,00 57 48,
IDE04347-ENG129997,Expanded environmental conditions-Drive_position_sensor_value_neg,50.0, %
IDE04347-ENG129996,Expanded environmental conditions-Drive_position_sensor_value_pos,49.5, %
IDE04347-ENG130005,Expanded environmental conditions-Driving_strategy_ABS_state,OFF,
IDE04347-ENG130013,Expanded environmental conditions-Driving_strategy_accelerator_pedal_position_modified,0.0, %
IDE04347-ENG130014,Expanded environmental conditions-Driving_strategy_angle_of_inclination,0.0, %
IDE04347-ENG130010,Expanded environmental conditions-Driving_strategy_ASR_state,OFF,
IDE04347-ENG130006,Expanded environmental conditions-Driving_strategy_brake_state,OFF,
IDE04347-ENG118434,Expanded environmental conditions-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE04347-ENG130004,Expanded environmental conditions-Driving_strategy_down_shift_actuation_state,Selecting,
IDE04347-ENG130007,Expanded environmental conditions-Driving_strategy_EDS_state,OFF,
IDE04347-ENG118236,Expanded environmental conditions-Driving_strategy_electrical_drive,Init,
IDE04347-ENG130008,Expanded environmental conditions-Driving_strategy_ESP_state,OFF,
IDE04347-ENG130002,Expanded environmental conditions-Driving_strategy_gear_commanded,1,
IDE04347-ENG130003,Expanded environmental conditions-Driving_strategy_gear_preset,R,
IDE04347-ENG130009,Expanded environmental conditions-Driving_strategy_GRA_state,OFF,
IDE04347-ENG130012,Expanded environmental conditions-Driving_strategy_vehicle_coordinator_main_state,Stg Treiber,
IDE04347-ENG118348,Expanded environmental conditions-Electric_engine_torque_hyb,0.00, Nm
IDE04347-ENG118213,Expanded environmental conditions-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE04347-ENG118214,Expanded environmental conditions-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE04347-ENG118400,Expanded environmental conditions-Electrical_pump_3_for_transmission_current,0.0, A
IDE04347-ENG114478,Expanded environmental conditions-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE04347-ENG110459,Expanded environmental conditions-Engine_idle_speed_commanded_value,950, /min
IDE04347-ENG129959,Expanded environmental conditions-Engine_intervention_state,0,
IDE04347-ENG130000,Expanded environmental conditions-Engine_torque_dominant,1600.00, Nm
IDE04347-ENG129946,Expanded environmental conditions-Gear_selector_1_3_valve_commanded_current,0.0, mA
IDE04347-ENG129988,Expanded environmental conditions-Gear_selector_13_adapted_synchron_position_neg,-2.8, mm
IDE04347-ENG129989,Expanded environmental conditions-Gear_selector_13_adapted_synchron_position_pos,1.8, mm
IDE04347-ENG129984,Expanded environmental conditions-Gear_selector_13_measured_distance,9.1, mm
IDE04347-ENG129980,Expanded environmental conditions-Gear_selector_13_state,Init (Pos),
IDE04347-ENG129950,Expanded environmental conditions-Gear_selector_2_R_valve_commanded_current,0.0, mA
IDE04347-ENG129994,Expanded environmental conditions-Gear_selector_2R_adapted_synchron_position_neg,-2.1, mm
IDE04347-ENG129995,Expanded environmental conditions-Gear_selector_2R_adapted_synchron_position_pos,1.7, mm
IDE04347-ENG129987,Expanded environmental conditions-Gear_selector_2R_measured_distance,0.0, mm
IDE04347-ENG129983,Expanded environmental conditions-Gear_selector_2R_state,Init (Pos),
IDE04347-ENG129949,Expanded environmental conditions-Gear_selector_4_6_valve_commanded_current,0.0, mA
IDE04347-ENG129992,Expanded environmental conditions-Gear_selector_46_adapted_synchron_position_neg,-2.3, mm
IDE04347-ENG129993,Expanded environmental conditions-Gear_selector_46_adapted_synchron_position_pos,2.0, mm
IDE04347-ENG129986,Expanded environmental conditions-Gear_selector_46_measured_distance,-0.1, mm
IDE04347-ENG129982,Expanded environmental conditions-Gear_selector_46_state,Init (Pos),
IDE04347-ENG129948,Expanded environmental conditions-Gear_selector_5_7_valve_actual_current,0.0, mA
IDE04347-ENG129947,Expanded environmental conditions-Gear_selector_5_7_valve_commanded_current,0.0, mA
IDE04347-ENG129990,Expanded environmental conditions-Gear_selector_57_adapted_synchron_position_neg,-2.4, mm
IDE04347-ENG129991,Expanded environmental conditions-Gear_selector_57_adapted_synchron_position_pos,2.0, mm
IDE04347-ENG129985,Expanded environmental conditions-Gear_selector_57_measured_distance,-0.3, mm
IDE04347-ENG129981,Expanded environmental conditions-Gear_selector_57_state,Init (Pos),
IDE04347-ENG130011,Expanded environmental conditions-KL15_state,On,
IDE04347-ENG103792,Expanded environmental conditions-km-Mileage,2, km
IDE04347-ENG129951,Expanded environmental conditions-Main_pressure_valve_commanded_current,0.0, mA
IDE04347-ENG129755,Expanded environmental conditions-Manual_transmission_fluid_pump_actual_speed,0, /min
IDE04347-ENG129756,Expanded environmental conditions-Manual_transmission_fluid_pump_commanded_speed,0, /min
IDE04347-ENG27077,Expanded environmental conditions-Pressure_sensor_change_state,nicht vertauscht,
IDE04347-ENG129999,Expanded environmental conditions-Selector_lever_holding_magnet_state,1,
IDE04347-ENG99809,Expanded environmental conditions-System time in after-run mode,0, s
IDE04347-ENG99203,Expanded environmental conditions-System time in normal mode,29, s
IDE04347-ENG129976,Expanded environmental conditions-Transmission_control_module_LM71_temperature,35, °C
IDE04347-ENG129721,Expanded environmental conditions-Voltage_supply_1_for_sensors,5.0, V
IDE04347-ENG129722,Expanded environmental conditions-Voltage_supply_2_for_sensors,5.0, V
IDE04347-ENG129977,Expanded environmental conditions-Voltage_supply_3_for_sensors,5.0, V
IDE04347-ENG129978,Expanded environmental conditions-Voltage_supply_commanded_value,0.0, V
IDE04347-ENG129979,Expanded environmental conditions-Voltage_supply_speed_sensor,9.1, V
IDE05566-ENG100476,Counter for operation with increased engine oil temp-TEMP_INTERVAL_01_HOURS,637, H
IDE05566-ENG102684,Counter for operation with increased engine oil temp-TEMP_INTERVAL_01_MINUTES,54, min
IDE05566-ENG104078,Counter for operation with increased engine oil temp-TEMP_INTERVAL_01_SECONDS,9, s
IDE05566-ENG99589,Counter for operation with increased engine oil temp-TEMP_INTERVAL_02_HOURS,0, H
IDE05566-ENG103797,Counter for operation with increased engine oil temp-TEMP_INTERVAL_02_MINUTES,0, min
IDE05566-ENG103883,Counter for operation with increased engine oil temp-TEMP_INTERVAL_02_SECONDS,0, s
IDE05566-ENG103406,Counter for operation with increased engine oil temp-TEMP_INTERVAL_03_HOURS,0, H
IDE05566-ENG100661,Counter for operation with increased engine oil temp-TEMP_INTERVAL_03_MINUTES,0, min
IDE05566-ENG102183,Counter for operation with increased engine oil temp-TEMP_INTERVAL_03_SECONDS,0, s
IDE05566-ENG99316,Counter for operation with increased engine oil temp-TEMP_INTERVAL_04_HOURS,0, H
IDE05566-ENG99998,Counter for operation with increased engine oil temp-TEMP_INTERVAL_04_MINUTES,0, min
IDE05566-ENG100721,Counter for operation with increased engine oil temp-TEMP_INTERVAL_04_SECONDS,0, s
IDE05566-ENG100915,Counter for operation with increased engine oil temp-TEMP_INTERVAL_05_HOURS,0, H
IDE05566-ENG102533,Counter for operation with increased engine oil temp-TEMP_INTERVAL_05_MINUTES,0, min
IDE05566-ENG102011,Counter for operation with increased engine oil temp-TEMP_INTERVAL_05_SECONDS,0, s
IDE05815-MAS02985,Sail function-Value,289,
IDE05815-MAS07649,Sail function-Gas pedal depress.,No,
IDE05815-MAS07650,Sail function-Brake pedal depress.,No,
IDE05815-MAS12738,Sail function-Accel. pedal activated too quickly,No,
IDE05815-MAS12739,Sail function-Trailer hitched,No,
IDE05815-MAS12740,Sail function-Incline/decline excessive,No,
IDE05815-MAS12741,Sail function-Vehicle speed outside permitted range,Yes,
IDE05815-MAS12742,Sail function-Transmission adaption active,No,
IDE05815-MAS12743,Sail function-Transmission temp. outside permissible range,No,
IDE05815-MAS12744,Sail function-Exterior temperature outside permissible range,No,
IDE05815-MAS12745,Sail function-Event memory entry active,No,
IDE05815-MAS12746,Sail function-Coding of control module for automatic transmission incorrect,No,
IDE05815-MAS12747,Sail function-Engine drag torque control: ABS or ESC control active,No,
IDE05815-MAS12748,Sail function-Button for ASR and ESP activated,No,
IDE05815-MAS12749,Sail function-Activation prevented by engine control module,No,
IDE05815-MAS12750,Sail function-Activation prevented by battery energy management,No,
IDE05815-MAS12752,Sail function-Activation prevented by Climatronic control module,No,
IDE05815-MAS12753,Sail function-Activation prevented by ACC,No,
IDE05815-MAS12754,Sail function-Driving style insufficiently defined,No,
IDE05815-MAS12755,Sail function-Corner driving detected,Yes,
IDE05815-MAS12756,Sail function-Engine temperature too low/warm-up not finished,No,
IDE05815-MAS12757,Sail function-Deactivation by driver,No,
IDE05815-MAS12758,Sail function-Position of selector lever or drive program incorrect,Yes,
IDE06241,Uneven road surface recognition: total driving portion,0.00, %
IDE06242,Distance since last activation: uneven road surface recognition,16777215, km
IDE06243,Longest active distance with uneven road surface recognition,0, km
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,not active,
IDE06658,Pressure control valve 2: act. current,1.4, mA
IDE06659,Pressure control valve 3: act. current,3.3, mA
IDE06660,Pressure control valve 3: spec. current,0.0, mA
IDE06661,Pressure control valve 2: spec. current,0.0, mA
IDE06662,Pressure control valve 4: spec. current,513.3, mA
IDE06663,Pressure control valve 4: act. current,-55.3, mA
IDE06668,Pressure control valve 1: act. current,0.0, mA
IDE06669,Pressure control valve 1: spec. current,0.0, mA
IDE07677,Counter Auto-P,80,
IDE07678,Counter N-hold. phase,15,
IDE07679,Counter engine off in P,1776,
IDE07680,Counter insertion processes P,2694,
IDE08133-ENG98502,Basic setting: cause for cancellation-Data,Basic setting not active,
IDE09372-ENG98933,Oil pressure reservoir: status of emptying-Status,not active,
IDE09373-ENG98502,Oil pressure reservoir: pressure-Data,20.9, bar
IDE09396,Aux. hydraulic pump 1: actual RPM,619, /min
IDE09397-ENG98502,Aux. hydraulic pump 1: spec. RPM-Data,610, /min
IDE09398,Electrical pump 2 for trans. oil: actual speed,2999, /min
IDE09399,Electrical pump 2 for trans. oil: nominal speed,3000, /min
IDE09400-ENG98502,Oil pressure reservoir: status-Data,was not charged,
IDE09640-MAS09266,Adapted pressure values for clutch 1: raising-Basic value 1,0.000, bar
IDE09640-MAS09267,Adapted pressure values for clutch 1: raising-Basic value 2,0.000, bar
IDE09640-MAS09268,Adapted pressure values for clutch 1: raising-Basic value 3,0.000, bar
IDE09640-MAS09269,Adapted pressure values for clutch 1: raising-Basic value 4,0.000, bar
IDE09640-MAS09270,Adapted pressure values for clutch 1: raising-Basic value 5,0.000, bar
IDE09640-MAS09271,Adapted pressure values for clutch 1: raising-Basic value 6,0.000, bar
IDE09640-MAS09272,Adapted pressure values for clutch 1: raising-Basic value 7,0.000, bar
IDE09640-MAS09273,Adapted pressure values for clutch 1: raising-Basic value 8,0.000, bar
IDE09640-MAS09274,Adapted pressure values for clutch 1: raising-Basic value 9,0.000, bar
IDE09640-MAS09275,Adapted pressure values for clutch 1: raising-Basic value 10,0.000, bar
IDE09640-MAS09276,Adapted pressure values for clutch 1: raising-Basic value 11,0.000, bar
IDE09640-MAS09277,Adapted pressure values for clutch 1: raising-Basic value 12,0.000, bar
IDE09640-MAS09278,Adapted pressure values for clutch 1: raising-Basic value 13,0.000, bar
IDE09640-MAS09279,Adapted pressure values for clutch 1: raising-Basic value 14,0.000, bar
IDE09640-MAS09280,Adapted pressure values for clutch 1: raising-Basic value 15,0.000, bar
IDE09640-MAS09281,Adapted pressure values for clutch 1: raising-Basic value 16,0.000, bar
IDE09640-MAS09309,Adapted pressure values for clutch 1: raising-Basic value 17,0.000, bar
IDE09641-MAS09266,Adapted pressure values for clutch 1: falling-Basic value 1,0.000, bar
IDE09641-MAS09267,Adapted pressure values for clutch 1: falling-Basic value 2,0.000, bar
IDE09641-MAS09268,Adapted pressure values for clutch 1: falling-Basic value 3,0.000, bar
IDE09641-MAS09269,Adapted pressure values for clutch 1: falling-Basic value 4,0.000, bar
IDE09641-MAS09270,Adapted pressure values for clutch 1: falling-Basic value 5,0.000, bar
IDE09641-MAS09271,Adapted pressure values for clutch 1: falling-Basic value 6,0.000, bar
IDE09641-MAS09272,Adapted pressure values for clutch 1: falling-Basic value 7,0.000, bar
IDE09641-MAS09273,Adapted pressure values for clutch 1: falling-Basic value 8,0.000, bar
IDE09641-MAS09274,Adapted pressure values for clutch 1: falling-Basic value 9,0.000, bar
IDE09641-MAS09275,Adapted pressure values for clutch 1: falling-Basic value 10,0.000, bar
IDE09641-MAS09276,Adapted pressure values for clutch 1: falling-Basic value 11,0.000, bar
IDE09641-MAS09277,Adapted pressure values for clutch 1: falling-Basic value 12,0.000, bar
IDE09641-MAS09278,Adapted pressure values for clutch 1: falling-Basic value 13,0.000, bar
IDE09641-MAS09279,Adapted pressure values for clutch 1: falling-Basic value 14,0.000, bar
IDE09641-MAS09280,Adapted pressure values for clutch 1: falling-Basic value 15,0.000, bar
IDE09641-MAS09281,Adapted pressure values for clutch 1: falling-Basic value 16,0.000, bar
IDE09641-MAS09309,Adapted pressure values for clutch 1: falling-Basic value 17,0.000, bar
IDE09642-MAS09266,Adapted pressure values for clutch 2: raising-Basic value 1,0.000, bar
IDE09642-MAS09267,Adapted pressure values for clutch 2: raising-Basic value 2,0.000, bar
IDE09642-MAS09268,Adapted pressure values for clutch 2: raising-Basic value 3,0.000, bar
IDE09642-MAS09269,Adapted pressure values for clutch 2: raising-Basic value 4,0.000, bar
IDE09642-MAS09270,Adapted pressure values for clutch 2: raising-Basic value 5,0.000, bar
IDE09642-MAS09271,Adapted pressure values for clutch 2: raising-Basic value 6,0.000, bar
IDE09642-MAS09272,Adapted pressure values for clutch 2: raising-Basic value 7,0.000, bar
IDE09642-MAS09273,Adapted pressure values for clutch 2: raising-Basic value 8,0.000, bar
IDE09642-MAS09274,Adapted pressure values for clutch 2: raising-Basic value 9,0.000, bar
IDE09642-MAS09275,Adapted pressure values for clutch 2: raising-Basic value 10,0.000, bar
IDE09642-MAS09276,Adapted pressure values for clutch 2: raising-Basic value 11,0.000, bar
IDE09642-MAS09277,Adapted pressure values for clutch 2: raising-Basic value 12,0.000, bar
IDE09642-MAS09278,Adapted pressure values for clutch 2: raising-Basic value 13,0.000, bar
IDE09642-MAS09279,Adapted pressure values for clutch 2: raising-Basic value 14,0.000, bar
IDE09642-MAS09280,Adapted pressure values for clutch 2: raising-Basic value 15,0.000, bar
IDE09642-MAS09281,Adapted pressure values for clutch 2: raising-Basic value 16,0.000, bar
IDE09642-MAS09309,Adapted pressure values for clutch 2: raising-Basic value 17,0.000, bar
IDE09643-MAS09266,Adapted pressure values for clutch 2: falling-Basic value 1,0.000, bar
IDE09643-MAS09267,Adapted pressure values for clutch 2: falling-Basic value 2,0.000, bar
IDE09643-MAS09268,Adapted pressure values for clutch 2: falling-Basic value 3,0.000, bar
IDE09643-MAS09269,Adapted pressure values for clutch 2: falling-Basic value 4,0.000, bar
IDE09643-MAS09270,Adapted pressure values for clutch 2: falling-Basic value 5,0.000, bar
IDE09643-MAS09271,Adapted pressure values for clutch 2: falling-Basic value 6,0.000, bar
IDE09643-MAS09272,Adapted pressure values for clutch 2: falling-Basic value 7,0.000, bar
IDE09643-MAS09273,Adapted pressure values for clutch 2: falling-Basic value 8,0.000, bar
IDE09643-MAS09274,Adapted pressure values for clutch 2: falling-Basic value 9,0.000, bar
IDE09643-MAS09275,Adapted pressure values for clutch 2: falling-Basic value 10,0.000, bar
IDE09643-MAS09276,Adapted pressure values for clutch 2: falling-Basic value 11,0.000, bar
IDE09643-MAS09277,Adapted pressure values for clutch 2: falling-Basic value 12,0.000, bar
IDE09643-MAS09278,Adapted pressure values for clutch 2: falling-Basic value 13,0.000, bar
IDE09643-MAS09279,Adapted pressure values for clutch 2: falling-Basic value 14,0.000, bar
IDE09643-MAS09280,Adapted pressure values for clutch 2: falling-Basic value 15,0.000, bar
IDE09643-MAS09281,Adapted pressure values for clutch 2: falling-Basic value 16,0.000, bar
IDE09643-MAS09309,Adapted pressure values for clutch 2: falling-Basic value 17,0.000, bar
IDE09644-MAS09266,Adapted press. values for gear select. valve: raising-Basic value 1,0.000, bar
IDE09644-MAS09267,Adapted press. values for gear select. valve: raising-Basic value 2,0.000, bar
IDE09644-MAS09268,Adapted press. values for gear select. valve: raising-Basic value 3,0.000, bar
IDE09644-MAS09269,Adapted press. values for gear select. valve: raising-Basic value 4,0.000, bar
IDE09644-MAS09270,Adapted press. values for gear select. valve: raising-Basic value 5,0.000, bar
IDE09644-MAS09271,Adapted press. values for gear select. valve: raising-Basic value 6,0.000, bar
IDE09644-MAS09272,Adapted press. values for gear select. valve: raising-Basic value 7,0.000, bar
IDE09644-MAS09273,Adapted press. values for gear select. valve: raising-Basic value 8,0.000, bar
IDE09644-MAS09274,Adapted press. values for gear select. valve: raising-Basic value 9,0.000, bar
IDE09644-MAS09275,Adapted press. values for gear select. valve: raising-Basic value 10,0.000, bar
IDE09644-MAS09276,Adapted press. values for gear select. valve: raising-Basic value 11,0.000, bar
IDE09644-MAS09277,Adapted press. values for gear select. valve: raising-Basic value 12,0.000, bar
IDE09644-MAS09278,Adapted press. values for gear select. valve: raising-Basic value 13,0.000, bar
IDE09644-MAS09279,Adapted press. values for gear select. valve: raising-Basic value 14,0.000, bar
IDE09644-MAS09280,Adapted press. values for gear select. valve: raising-Basic value 15,0.000, bar
IDE09644-MAS09281,Adapted press. values for gear select. valve: raising-Basic value 16,0.000, bar
IDE09644-MAS09309,Adapted press. values for gear select. valve: raising-Basic value 17,0.000, bar
IDE09645-MAS09266,Adapted press. values for gear select. valve: falling-Basic value 1,0.000, bar
IDE09645-MAS09267,Adapted press. values for gear select. valve: falling-Basic value 2,0.000, bar
IDE09645-MAS09268,Adapted press. values for gear select. valve: falling-Basic value 3,0.000, bar
IDE09645-MAS09269,Adapted press. values for gear select. valve: falling-Basic value 4,0.000, bar
IDE09645-MAS09270,Adapted press. values for gear select. valve: falling-Basic value 5,0.000, bar
IDE09645-MAS09271,Adapted press. values for gear select. valve: falling-Basic value 6,0.000, bar
IDE09645-MAS09272,Adapted press. values for gear select. valve: falling-Basic value 7,0.000, bar
IDE09645-MAS09273,Adapted press. values for gear select. valve: falling-Basic value 8,0.000, bar
IDE09645-MAS09274,Adapted press. values for gear select. valve: falling-Basic value 9,0.000, bar
IDE09645-MAS09275,Adapted press. values for gear select. valve: falling-Basic value 10,0.000, bar
IDE09645-MAS09276,Adapted press. values for gear select. valve: falling-Basic value 11,0.000, bar
IDE09645-MAS09277,Adapted press. values for gear select. valve: falling-Basic value 12,0.000, bar
IDE09645-MAS09278,Adapted press. values for gear select. valve: falling-Basic value 13,0.000, bar
IDE09645-MAS09279,Adapted press. values for gear select. valve: falling-Basic value 14,0.000, bar
IDE09645-MAS09280,Adapted press. values for gear select. valve: falling-Basic value 15,0.000, bar
IDE09645-MAS09281,Adapted press. values for gear select. valve: falling-Basic value 16,0.000, bar
IDE09645-MAS09309,Adapted press. values for gear select. valve: falling-Basic value 17,0.000, bar
IDE10177,Transmission input speed sensor 1,0, /min
IDE10178,Transmission input speed sensor 2,0, /min
IDE10181-ENG98502,Rotor position sensor for auxil. hydraulic pump 1: offset sinus-Data,2777.6, mV
IDE10182-ENG98502,Rotor posit. sensor for auxil. hydraulic pump 1: offset cosine-Data,2776.1, mV
IDE10183-ENG98502,Rotor posit.sensor for auxil. hydraulic pump 1: amplitude sinus-Data,1087.1, mV
IDE10184-ENG98502,Rotor posit. sensor for auxil. hydraulic pump 1: amplitude cos.-Data,1082.2, mV
IDE10185-ENG98502,Rotor pos.sensor for auxil. hydraul.pump 1: max. upper shafts-Data,0.0, mV
IDE10186-ENG98502,Rotor posit.sens. for auxil. hydraulic pump 1: angle difference-Data,0.00, °
IDE10203-ENG98502,Audi drive select: drive program-Data,AUTO,
IDE10204-ENG98502,Transm. oil temp. MTD-Data,41, °C
IDE10209-ENG98502,Driving mode sensor 1: position-Data,P,
IDE10210-ENG98502,Driving mode sensor 2: position-Data,P,
IDE10213-ENG98502,Driving mode sensor: highest value for D-Data,37.00, %
IDE10394-ENG98502,Driving mode sensor: lowest value for D-Data,14.00, %
IDE10469-ENG98502,Clutch pressure: clutch 1-Data,0.0, bar
IDE10470-ENG98502,Clutch pressure: clutch 2-Data,0.0, bar
IDE10687-ENG98502,Electrical pump 2 for transmission: supply voltage terminal 30-Data,12.9, V
IDE10688-ENG98502,Electrical pump 2 for transmission: supply voltage terminal 15-Data,12.4, V
IDE10851-ENG98502,Selector lever position sensor: calibration status-Data,Init,
IDE10852-ENG98502,Selector lever position sensor: calibration step-Data,Checking prerequisites,
IDE10853-ENG98502,Transm. calibration: reason for abort-Data,OK,
IDE10854-ENG98502,Transm. calibration: calibration step-Data,Calibration off,
IDE11142-MAS12238,Configuration of valves-Solenoid valve 1,Gear selector positive gear 1 - negative gear 3,
IDE11142-MAS12239,Configuration of valves-Solenoid valve 2,Gear selector positive gear 2 - negative gear R,
IDE11142-MAS12240,Configuration of valves-Solenoid valve 3,Gear selector positive gear 5 - negative gear 7,
IDE11142-MAS12241,Configuration of valves-Solenoid valve 4,Gear selector positive gear 4 - negative gear 6,
IDE11142-MAS12242,Configuration of valves-Solenoid valve 5,Cooling oil valve,
IDE11142-MAS12243,Configuration of valves-Solenoid valve 6,Accum. press. valve,
IDE11142-MAS12244,Configuration of valves-Press.ctrl. valve 1,Clutch 1,
IDE11142-MAS12245,Configuration of valves-Press.ctrl. valve 2,Clutch 2,
IDE11142-MAS12246,Configuration of valves-Press.ctrl. valve 3,Main pressure valve,
IDE11142-MAS12247,Configuration of valves-Press.ctrl. valve 4,Clutch 0,
IDE11143,Sol. valve 1: act. current,0.6, mA
IDE11144,Sol. valve 1: spec. current,0.0, mA
IDE11145,Sol. valve 2: act. current,2.5, mA
IDE11146,Sol. valve 2: spec. current,0.0, mA
IDE11147,Sol. valve 3: act. current,1.9, mA
IDE11148,Sol. valve 3: spec. current,0.0, mA
IDE11149,Sol. valve 4: act. current,2.6, mA
IDE11150,Sol. valve 4: spec. current,0.0, mA
IDE11154-MAS12270,Sol. valve 1: engagement points of gear selector-Positive activation,831.0, mA
IDE11154-MAS12271,Sol. valve 1: engagement points of gear selector-Negative activation,649.0, mA
IDE11155-MAS12270,Sol. valve 2: engagement points of gear selector-Positive activation,827.0, mA
IDE11155-MAS12271,Sol. valve 2: engagement points of gear selector-Negative activation,653.0, mA
IDE11156-MAS12270,Sol. valve 3: engagement points of gear selector-Positive activation,844.0, mA
IDE11156-MAS12271,Sol. valve 3: engagement points of gear selector-Negative activation,669.0, mA
IDE11157-MAS12270,Sol. valve 4: engagement points of gear selector-Positive activation,834.0, mA
IDE11157-MAS12271,Sol. valve 4: engagement points of gear selector-Negative activation,642.0, mA
IDE11158-MAS12272,Configuration of distance sensors-Gear position distance sensor 1,Gear selector positive gear 1 - negative gear 3,
IDE11158-MAS12273,Configuration of distance sensors-Gear position distance sensor 2,Gear selector positive gear 2 - negative gear R,
IDE11158-MAS12274,Configuration of distance sensors-Gear position distance sensor 3,Gear selector positive gear 5 - negative gear 7,
IDE11158-MAS12275,Configuration of distance sensors-Gear position distance sensor 4,Gear selector positive gear 4 - negative gear 6,
IDE11159,Gear selector dist. sensor 1: position,9.1, mm
IDE11160,Gear selector dist. sensor 2: position,-9.4, mm
IDE11161,Gear selector dist. sensor 3: position,-0.1, mm
IDE11162,Gear selector dist. sensor 4: position,-0.2, mm
IDE11164-MAS12280,Gear 1: synchronization point-Adapted position,2.14, mm
IDE11164-MAS12281,Gear 1: synchronization point-Calibrated position,2.11, mm
IDE11165-MAS12280,Gear 2: synchronization point-Adapted position,2.06, mm
IDE11165-MAS12281,Gear 2: synchronization point-Calibrated position,2.80, mm
IDE11166-MAS12280,Gear 3: synchronization point-Adapted position,-2.36, mm
IDE11166-MAS12281,Gear 3: synchronization point-Calibrated position,-2.01, mm
IDE11167-MAS12280,Gear 4: synchronization point-Adapted position,2.08, mm
IDE11167-MAS12281,Gear 4: synchronization point-Calibrated position,1.98, mm
IDE11168-MAS12280,Gear 5: synchronization point-Adapted position,1.84, mm
IDE11168-MAS12281,Gear 5: synchronization point-Calibrated position,1.97, mm
IDE11169-MAS12280,Gear 6: synchronization point-Adapted position,-2.18, mm
IDE11169-MAS12281,Gear 6: synchronization point-Calibrated position,-2.33, mm
IDE11170-MAS12280,Gear 7: synchronization point-Adapted position,-2.41, mm
IDE11170-MAS12281,Gear 7: synchronization point-Calibrated position,-2.44, mm
IDE11171-MAS12280,Gear R: synchronization point-Adapted position,-1.72, mm
IDE11171-MAS12281,Gear R: synchronization point-Calibrated position,-2.11, mm
IDE11172,Gear 1: calibrated end position,9.13, mm
IDE11173,Gear 2: calibrated end position,9.26, mm
IDE11174,Gear 3: calibrated end position,-9.57, mm
IDE11175,Gear 4: calibrated end position,9.13, mm
IDE11176,Gear 5: calibrated end position,9.29, mm
IDE11177,Gear 6: calibrated end position,-9.57, mm
IDE11178,Gear 7: calibrated end position,-9.64, mm
IDE11179,Gear R: calibrated end position,-9.50, mm
IDE11180,Sol. valve 5: act. current,744.2, mA
IDE11181,Sol. valve 5: spec. current,742.8, mA
IDE11182,Sol. valve 6: act. current,0.0, mA
IDE11183,Sol. valve 6: spec. current,0.0, mA
IDE11187-MAS12281,Path sensor 2 for gear actuator: neutr.pos.calibr.and virt.-Calibrated position,-0.15, mm
IDE11187-MAS13292,Path sensor 2 for gear actuator: neutr.pos.calibr.and virt.-Virtual position,0.00, mm
IDE11287-MAS12281,Path sensor 1 for gear actuator: neutr.pos.calibr.and virt.-Calibrated position,-0.17, mm
IDE11287-MAS13292,Path sensor 1 for gear actuator: neutr.pos.calibr.and virt.-Virtual position,0.00, mm
IDE11296-MAS12281,Path sensor 3 for gear actuator: neutr.pos.calibr.and virt.-Calibrated position,-0.05, mm
IDE11296-MAS13292,Path sensor 3 for gear actuator: neutr.pos.calibr.and virt.-Virtual position,0.00, mm
IDE11374-MAS12281,Path sensor 4 for gear actuator: neutr.pos.calibr.and virt.-Calibrated position,-0.23, mm
IDE11374-MAS13292,Path sensor 4 for gear actuator: neutr.pos.calibr.and virt.-Virtual position,0.00, mm
IDE11394-MAS12281,Gear 1: end position calibrated and virtual-Calibrated position,9.13, mm
IDE11394-MAS13292,Gear 1: end position calibrated and virtual-Virtual position,0.00, mm
IDE11420-MAS12281,Gear 2: end position calibrated and virtual-Calibrated position,9.26, mm
IDE11420-MAS13292,Gear 2: end position calibrated and virtual-Virtual position,0.00, mm
IDE11450-MAS12281,Gear 3: end position calibrated and virtual-Calibrated position,-9.57, mm
IDE11450-MAS13292,Gear 3: end position calibrated and virtual-Virtual position,0.00, mm
IDE11505-MAS12281,Gear 4: end position calibrated and virtual-Calibrated position,9.13, mm
IDE11505-MAS13292,Gear 4: end position calibrated and virtual-Virtual position,0.00, mm
IDE11534-MAS12281,Gear 5: end position calibrated and virtual-Calibrated position,9.29, mm
IDE11534-MAS13292,Gear 5: end position calibrated and virtual-Virtual position,0.00, mm
IDE11535-MAS12281,Gear 6: end position calibrated and virtual-Calibrated position,-9.57, mm
IDE11535-MAS13292,Gear 6: end position calibrated and virtual-Virtual position,0.00, mm
IDE11536-MAS12281,Gear 7: end position calibrated and virtual-Calibrated position,-9.64, mm
IDE11536-MAS13292,Gear 7: end position calibrated and virtual-Virtual position,0.00, mm
IDE11572-MAS12281,Gear R: end position calibrated and virtual-Calibrated position,-9.50, mm
IDE11572-MAS13292,Gear R: end position calibrated and virtual-Virtual position,0.00, mm
IDE11718-MAS13293,Solen.val. 1: applic.point of the gear actuat. calibr.and virt.-Positive application point,831.0, mA
IDE11718-MAS13294,Solen.val. 1: applic.point of the gear actuat. calibr.and virt.-Negative application point,649.0, mA
IDE11718-MAS13295,Solen.val. 1: applic.point of the gear actuat. calibr.and virt.-Virtual positive application point,0.0, mA
IDE11718-MAS13296,Solen.val. 1: applic.point of the gear actuat. calibr.and virt.-Virtual negative application point,0.0, mA
IDE11768-MAS13293,Solen.val. 2: applic.point of the gear actuat. calibr.and virt.-Positive application point,827.0, mA
IDE11768-MAS13294,Solen.val. 2: applic.point of the gear actuat. calibr.and virt.-Negative application point,653.0, mA
IDE11768-MAS13295,Solen.val. 2: applic.point of the gear actuat. calibr.and virt.-Virtual positive application point,0.0, mA
IDE11768-MAS13296,Solen.val. 2: applic.point of the gear actuat. calibr.and virt.-Virtual negative application point,0.0, mA
IDE11772-MAS13293,Solen.val. 3: applic.point of the gear actuat. calibr.and virt.-Positive application point,844.0, mA
IDE11772-MAS13294,Solen.val. 3: applic.point of the gear actuat. calibr.and virt.-Negative application point,669.0, mA
IDE11772-MAS13295,Solen.val. 3: applic.point of the gear actuat. calibr.and virt.-Virtual positive application point,0.0, mA
IDE11772-MAS13296,Solen.val. 3: applic.point of the gear actuat. calibr.and virt.-Virtual negative application point,0.0, mA
IDE11787-MAS13293,Solen.val. 4: applic.point of the gear actuat. calibr.and virt.-Positive application point,834.0, mA
IDE11787-MAS13294,Solen.val. 4: applic.point of the gear actuat. calibr.and virt.-Negative application point,642.0, mA
IDE11787-MAS13295,Solen.val. 4: applic.point of the gear actuat. calibr.and virt.-Virtual positive application point,0.0, mA
IDE11787-MAS13296,Solen.val. 4: applic.point of the gear actuat. calibr.and virt.-Virtual negative application point,0.0, mA
IDE11806-MAS13316,Calibration of path sensors: status for all gear actuators-Measured data of the gear actuator basic measurement,valid,
IDE11806-MAS13317,Calibration of path sensors: status for all gear actuators-Virtual data of the gear actuator basic measurement,valid,
IDE11806-MAS13318,Calibration of path sensors: status for all gear actuators-Measured data of the application points,valid,
IDE11806-MAS13319,Calibration of path sensors: status for all gear actuators-Virtual data of the application points,invalid,
IDE11806-MAS13320,Calibration of path sensors: status for all gear actuators-Measured data of the synchronous positions,valid,
IDE11806-MAS13321,Calibration of path sensors: status for all gear actuators-Virtual data of the synchronous positions,invalid,
IDE11807-MAS13308,Calibration of path sensors: status for sub-gearbox 1-Measured data of the end positions of sub-gearbox 1,valid,
IDE11807-MAS13309,Calibration of path sensors: status for sub-gearbox 1-Virtual data of the end positions of sub-gearbox 1,invalid,
IDE11807-MAS13310,Calibration of path sensors: status for sub-gearbox 1-Measured data of the synchronous positions of sub-gearbox 1,valid,
IDE11807-MAS13311,Calibration of path sensors: status for sub-gearbox 1-Virtual data of the synchronous positions of sub-gearbox 1,invalid,
IDE11808-MAS13312,Calibration of path sensors: status for sub-gearbox 2-Measured data of the end positions of sub-gearbox 2,valid,
IDE11808-MAS13313,Calibration of path sensors: status for sub-gearbox 2-Virtual data of the end positions of sub-gearbox 2,invalid,
IDE11808-MAS13314,Calibration of path sensors: status for sub-gearbox 2-Measured data of the synchronous positions of sub-gearbox 2,valid,
IDE11808-MAS13315,Calibration of path sensors: status for sub-gearbox 2-Virtual data of the synchronous positions of sub-gearbox 2,invalid,
IDE11809-MAS13300,Calibration of path sensors: status for neutral position-Measured data of the neutral position of gear actuator 1/3,valid,
IDE11809-MAS13301,Calibration of path sensors: status for neutral position-Virtual data of the neutral position of gear actuator 1/3,invalid,
IDE11809-MAS13302,Calibration of path sensors: status for neutral position-Measured data of the neutral position of gear actuator 2/R,valid,
IDE11809-MAS13303,Calibration of path sensors: status for neutral position-Virtual data of the neutral position of gear actuator 2/R,invalid,
IDE11809-MAS13304,Calibration of path sensors: status for neutral position-Measured data of the neutral position of gear actuator 5/7,valid,
IDE11809-MAS13305,Calibration of path sensors: status for neutral position-Virtual data of the neutral position of gear actuator 5/7,invalid,
IDE11809-MAS13306,Calibration of path sensors: status for neutral position-Measured data of the neutral position of gear actuator 4/6,valid,
IDE11809-MAS13307,Calibration of path sensors: status for neutral position-Virtual data of the neutral position of gear actuator 4/6,invalid,
IDE11813-MAS12280,Gear 1: synchronization point calibrated: adapted: virtual-Adapted position,2.14, mm
IDE11813-MAS12281,Gear 1: synchronization point calibrated: adapted: virtual-Calibrated position,2.11, mm
IDE11813-MAS13292,Gear 1: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11814-MAS12280,Gear 2: synchronization point calibrated: adapted: virtual-Adapted position,2.06, mm
IDE11814-MAS12281,Gear 2: synchronization point calibrated: adapted: virtual-Calibrated position,2.80, mm
IDE11814-MAS13292,Gear 2: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11815-MAS12280,Gear 3: synchronization point calibrated: adapted: virtual-Adapted position,-2.36, mm
IDE11815-MAS12281,Gear 3: synchronization point calibrated: adapted: virtual-Calibrated position,-2.01, mm
IDE11815-MAS13292,Gear 3: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11816-MAS12280,Gear 4: synchronization point calibrated: adapted: virtual-Adapted position,2.08, mm
IDE11816-MAS12281,Gear 4: synchronization point calibrated: adapted: virtual-Calibrated position,1.98, mm
IDE11816-MAS13292,Gear 4: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11817-MAS12280,Gear 5: synchronization point calibrated: adapted: virtual-Adapted position,1.84, mm
IDE11817-MAS12281,Gear 5: synchronization point calibrated: adapted: virtual-Calibrated position,1.97, mm
IDE11817-MAS13292,Gear 5: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11818-MAS12280,Gear 6: synchronization point calibrated: adapted: virtual-Adapted position,-2.18, mm
IDE11818-MAS12281,Gear 6: synchronization point calibrated: adapted: virtual-Calibrated position,-2.33, mm
IDE11818-MAS13292,Gear 6: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11819-MAS12280,Gear 7: synchronization point calibrated: adapted: virtual-Adapted position,-2.41, mm
IDE11819-MAS12281,Gear 7: synchronization point calibrated: adapted: virtual-Calibrated position,-2.44, mm
IDE11819-MAS13292,Gear 7: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11820-MAS12280,Gear R: synchronization point calibrated: adapted: virtual-Adapted position,-1.72, mm
IDE11820-MAS12281,Gear R: synchronization point calibrated: adapted: virtual-Calibrated position,-2.11, mm
IDE11820-MAS13292,Gear R: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11821-MAS13297,Clutch 1 frict.point: ref.pres. calibr. and virtual-Calibrated pressure,0, mbar
IDE11821-MAS13298,Clutch 1 frict.point: ref.pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11822-MAS13297,Clutch 2 frict.point: ref.pres. calibr. and virtual-Calibrated pressure,0, mbar
IDE11822-MAS13298,Clutch 2 frict.point: ref.pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11823-MAS13297,Clutch 1 frict.point: actual pressure calibrated and virtual-Calibrated pressure,2560, mbar
IDE11823-MAS13298,Clutch 1 frict.point: actual pressure calibrated and virtual-Virtual pressure,0, mbar
IDE11824-MAS13297,Clutch 2 frict.point: actual pressure calibrated and virtual-Calibrated pressure,0, mbar
IDE11824-MAS13298,Clutch 2 frict.point: actual pressure calibrated and virtual-Virtual pressure,0, mbar
IDE11825-MAS13297,Clutch 1 frict.point: corrected ref.pres. calibr. and virtual-Calibrated pressure,2750, mbar
IDE11825-MAS13298,Clutch 1 frict.point: corrected ref.pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11826-MAS13297,Clutch 2 frict.point: corrected ref.pres. calibr. and virtual-Calibrated pressure,3227, mbar
IDE11826-MAS13298,Clutch 2 frict.point: corrected ref.pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11827-MAS13297,Clutch 1 frict.point: corrected act. pres. calibr. and virtual-Calibrated pressure,2679, mbar
IDE11827-MAS13298,Clutch 1 frict.point: corrected act. pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11828-MAS13297,Clutch 2 frict.point: corrected act. pres. calibr. and virtual-Calibrated pressure,3092, mbar
IDE11828-MAS13298,Clutch 2 frict.point: corrected act. pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11829,Adapt. of clutch frict.points: friction loss torque shaft 1,0.0, Nm
IDE11830,Adapt. of clutch frict.points: friction loss torque shaft 2,0.0, Nm
IDE11831,Adapt. of clutch frict.points: drag torque clutch 1,0.0, Nm
IDE11832,Adapt. of clutch frict.points: drag torque clutch 2,0.0, Nm
IDE12593-IDE11433,Hydraulic test: status of the clutch path-Status of magnet for park. lock.,OK,
IDE12593-MAS02985,Hydraulic test: status of the clutch path-Value,0,
IDE12593-MAS14780,Hydraulic test: status of the clutch path-Clutch 1 maximum pressure,OK,
IDE12593-MAS14781,Hydraulic test: status of the clutch path-Clutch 2 maximum pressure,OK,
IDE12593-MAS14782,Hydraulic test: status of the clutch path-Preload pressure: clutch 1,OK,
IDE12593-MAS14783,Hydraulic test: status of the clutch path-Preload pressure: clutch 2,OK,
IDE12593-MAS14784,Hydraulic test: status of the clutch path-Oil pressure reservoir: gas pressure spring characteristic curve,OK,
IDE12593-MAS14785,Hydraulic test: status of the clutch path-Clutch pressure increasing: clutch 1,OK,
IDE12593-MAS14786,Hydraulic test: status of the clutch path-Clutch pressure increasing: clutch 2,OK,
IDE12593-MAS14787,Hydraulic test: status of the clutch path-Retention leakage in the high-pressure area,OK,
IDE12593-MAS14788,Hydraulic test: status of the clutch path-Retention leakage in the area of clutch 1,OK,
IDE12593-MAS14789,Hydraulic test: status of the clutch path-Retention leakage in the area of clutch 2,OK,
IDE12593-MAS14790,Hydraulic test: status of the clutch path-Charge leakage in high pressure area,OK,
IDE12593-MAS14791,Hydraulic test: status of the clutch path-Charge leakage in the area of clutch 1,OK,
IDE12593-MAS14792,Hydraulic test: status of the clutch path-Charge leakage in the area of clutch 2,OK,
IDE12593-MAS14793,Hydraulic test: status of the clutch path-Pressure release by emptying oil pressure reservoir,OK,
IDE12593-MAS20157,Hydraulic test: status of the clutch path-Separating clutch: preload pressure,OK,
IDE12593-MAS20158,Hydraulic test: status of the clutch path-Separating clutch: coupling pressure increasing,OK,
IDE12593-MAS20159,Hydraulic test: status of the clutch path-Stop leakage near separating clutch,OK,
IDE12593-MAS20160,Hydraulic test: status of the clutch path-Charge leakage near separating clutch,OK,
IDE12594-MAS02985,Hydraulic test: status of the gear positioner path-Value,0,
IDE12594-MAS14795,Hydraulic test: status of the gear positioner path-Pressure leakage in gear R,OK,
IDE12594-MAS14796,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 1,OK,
IDE12594-MAS14797,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 2,OK,
IDE12594-MAS14798,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 3,OK,
IDE12594-MAS14799,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 4,OK,
IDE12594-MAS14800,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 5,OK,
IDE12594-MAS14801,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 6,OK,
IDE12594-MAS14802,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 7,OK,
IDE12595-MAS02985,Hydraulic test: status of the reservoir volume-Value,0,
IDE12595-MAS14803,Hydraulic test: status of the reservoir volume-Extraction volume,OK,
IDE12596-MAS02985,Hydraulic test: load valve status for store-Value,0,
IDE12596-MAS14804,Hydraulic test: load valve status for store-switches too infrequently,OK,
IDE12596-MAS14805,Hydraulic test: load valve status for store-switches too often,OK,
IDE12596-MAS14806,Hydraulic test: load valve status for store-switches too soon,OK,
IDE12596-MAS14807,Hydraulic test: load valve status for store-Switches too late,OK,
IDE12596-MAS14808,Hydraulic test: load valve status for store-does not switch at all,OK,
IDE12596-MAS14809,Hydraulic test: load valve status for store-switches implausibly during volume extraction,OK,
IDE12597-MAS02985,Hydraulic test: status of solenoid valve 6-Value,0,
IDE12597-MAS14810,Hydraulic test: status of solenoid valve 6-Sticks in pressure absent condition,OK,
IDE12597-MAS14811,Hydraulic test: status of solenoid valve 6-Sticks in pressure maintaining condition,OK,
IDE12598-MAS02985,Hydraulic test status of the ATF pump-Value,0,
IDE12598-MAS14812,Hydraulic test status of the ATF pump-Power output,OK,
IDE13197-IDE00024,Hydraulic test: reason for cancellation-Transmission fluid temperature,OK,
IDE13197-IDE11433,Hydraulic test: reason for cancellation-Status of magnet for park. lock.,OK,
IDE13197-MAS00362,Hydraulic test: reason for cancellation-Battery voltage,OK,
IDE13197-MAS00370,Hydraulic test: reason for cancellation-Vehicle speed,OK,
IDE13197-MAS00371,Hydraulic test: reason for cancellation-Engine speed,OK,
IDE13197-MAS01730,Hydraulic test: reason for cancellation-Pressure reduction,OK,
IDE13197-MAS03259,Hydraulic test: reason for cancellation-Pressure reservoir test,OK,
IDE13197-MAS05190,Hydraulic test: reason for cancellation-Parking brake or hand brake actuated,OK,
IDE13197-MAS05441,Hydraulic test: reason for cancellation-Selector lever in position P,OK,
IDE13197-MAS11577,Hydraulic test: reason for cancellation-Adaptation mode,OK,
IDE13197-MAS11730,Hydraulic test: reason for cancellation-Gear selector: Place in Neutral,OK,
IDE13197-MAS13382,Hydraulic test: reason for cancellation-Internal system status,OK,
IDE13197-MAS14719,Hydraulic test: reason for cancellation-Maximum time elapsed,OK,
IDE13197-MAS14794,Hydraulic test: reason for cancellation-ATF speed difference,OK,
IDE13197-MAS15617,Hydraulic test: reason for cancellation-Internal sensor malfunction,OK,
IDE13197-MAS15841,Hydraulic test: reason for cancellation-Flow deflection valve,OK,
IDE13197-MAS16121,Hydraulic test: reason for cancellation-Temperature difference between ATF and MTF,OK,
IDE13197-MAS16151,Hydraulic test: reason for cancellation-Valves flow release,OK,
IDE13197-MAS16153,Hydraulic test: reason for cancellation-Mobility of gear positioner,OK,
IDE13197-MAS16157,Hydraulic test: reason for cancellation-Parking lock function,OK,
IDE13327-IDE08627,Status internal sensors-Hydraulic pressure sensor 1,not OK,
IDE13327-MAS12272,Status internal sensors-Gear position distance sensor 1,not OK,
IDE13327-MAS12273,Status internal sensors-Gear position distance sensor 2,not OK,
IDE13327-MAS12274,Status internal sensors-Gear position distance sensor 3,not OK,
IDE13327-MAS12275,Status internal sensors-Gear position distance sensor 4,not OK,
IDE13327-MAS16154,Status internal sensors-Hydraulic pressure sensor 2,not OK,
IDE13327-MAS16155,Status internal sensors-Transmission fluid aux. hydraulic pump rotor position sensor,not OK,
IDE13327-MAS16156,Status internal sensors-Transmission fluid temperature sensor,not OK,
IDE13327-MAS16160,Status internal sensors-Drive position sensor,not OK,
IDE13327-MAS16161,Status internal sensors-Drive position sensor 2,not OK,
IDE13330-MAS12238,Valve flow deviation-Solenoid valve 1,OK,
IDE13330-MAS12239,Valve flow deviation-Solenoid valve 2,OK,
IDE13330-MAS12240,Valve flow deviation-Solenoid valve 3,OK,
IDE13330-MAS12241,Valve flow deviation-Solenoid valve 4,OK,
IDE13330-MAS12242,Valve flow deviation-Solenoid valve 5,OK,
IDE13330-MAS12243,Valve flow deviation-Solenoid valve 6,OK,
IDE13330-MAS12244,Valve flow deviation-Press.ctrl. valve 1,OK,
IDE13330-MAS12245,Valve flow deviation-Press.ctrl. valve 2,OK,
IDE13330-MAS12246,Valve flow deviation-Press.ctrl. valve 3,OK,
IDE13330-MAS12247,Valve flow deviation-Press.ctrl. valve 4,OK,
IDE13333,Solenoid valve 6: result of the hydraulic functional test,no error,
IDE80001-IDE00019,Analysis 1-Voltage terminal 30,12.6, V
IDE80001-IDE00021,Analysis 1-Engine speed,0.00, /min
IDE80001-IDE00023,Analysis 1-Transmission output speed,0, /min
IDE80001-IDE00026,Analysis 1-Vehicle speed from transmission,0.0, km/h
IDE80001-IDE00089,Analysis 1-Driving position,P,
IDE80001-IDE00100,Analysis 1-Engine torque,67.00, Nm
IDE80001-IDE00856,Analysis 1-Clutch 2 upper adaptation point,New,
IDE80001-IDE00866,Analysis 1-Specified torque clutch 1,-500.00, Nm
IDE80001-IDE00867,Analysis 1-Specified torque clutch 2,-500.00, Nm
IDE80001-IDE05990,Analysis 1-Pressure of clutch 2: specified value,0.0, bar
IDE80001-IDE05991,Analysis 1-Pressure of clutch 1: specified value,0.0, bar
IDE80001-IDE06658,Analysis 1-Pressure control valve 2: act. current,0.0, mA
IDE80001-IDE06659,Analysis 1-Pressure control valve 3: act. current,0.0, mA
IDE80001-IDE06660,Analysis 1-Pressure control valve 3: spec. current,0.0, mA
IDE80001-IDE06661,Analysis 1-Pressure control valve 2: spec. current,0.0, mA
IDE80001-IDE06662,Analysis 1-Pressure control valve 4: spec. current,0.0, mA
IDE80001-IDE06663,Analysis 1-Pressure control valve 4: act. current,-55.0, mA
IDE80001-IDE06668,Analysis 1-Pressure control valve 1: act. current,0.8, mA
IDE80001-IDE06669,Analysis 1-Pressure control valve 1: spec. current,0.0, mA
IDE80001-IDE09396,Analysis 1-Aux. hydraulic pump 1: actual RPM,0, /min
IDE80001-IDE09397,Analysis 1-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE80001-IDE10177,Analysis 1-Transmission input speed sensor 1,0, /min
IDE80001-IDE10178,Analysis 1-Transmission input speed sensor 2,0, /min
IDE80001-IDE10469,Analysis 1-Clutch pressure: clutch 1,0.0, bar
IDE80001-IDE10470,Analysis 1-Clutch pressure: clutch 2,0.0, bar
IDE80001-IDE11143,Analysis 1-Sol. valve 1: act. current,0.0, mA
IDE80001-IDE11144,Analysis 1-Sol. valve 1: spec. current,0.0, mA
IDE80001-IDE11145,Analysis 1-Sol. valve 2: act. current,0.0, mA
IDE80001-IDE11146,Analysis 1-Sol. valve 2: spec. current,0.0, mA
IDE80001-IDE11147,Analysis 1-Sol. valve 3: act. current,0.0, mA
IDE80001-IDE11148,Analysis 1-Sol. valve 3: spec. current,0.0, mA
IDE80001-IDE11149,Analysis 1-Sol. valve 4: act. current,0.0, mA
IDE80001-IDE11150,Analysis 1-Sol. valve 4: spec. current,0.0, mA
IDE80001-IDE11159,Analysis 1-Gear selector dist. sensor 1: position,9.1, mm
IDE80001-IDE11160,Analysis 1-Gear selector dist. sensor 2: position,0.0, mm
IDE80001-IDE11161,Analysis 1-Gear selector dist. sensor 3: position,-0.3, mm
IDE80001-IDE11162,Analysis 1-Gear selector dist. sensor 4: position,-0.1, mm
IDE80001-IDE11180,Analysis 1-Sol. valve 5: act. current,745.9, mA
IDE80001-IDE11181,Analysis 1-Sol. valve 5: spec. current,744.6, mA
IDE80001-IDE11182,Analysis 1-Sol. valve 6: act. current,0.0, mA
IDE80001-IDE11183,Analysis 1-Sol. valve 6: spec. current,0.0, mA
IDE80001-ENG129731,Analysis 1-Automatic_transmission_fluid_pump_phase_current,0, A
IDE80001-ENG130016,Analysis 1-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE80001-ENG130015,Analysis 1-Automatic_transmission_fluid_pump_shunt_current,655.33, A
IDE80001-ENG129701,Analysis 1-Automatic_transmission_fluid_source_of_commanded_speed,SBW,
IDE80001-ENG118442,Analysis 1-Clutch_0_actual_torque_hyb,0.00, Nm
IDE80001-ENG129961,Analysis 1-Clutch_0_commanded_pressure,0.0, bar
IDE80001-ENG118399,Analysis 1-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE80001-ENG129966,Analysis 1-Clutch_actuation_substate,0,
IDE80001-ENG118401,Analysis 1-Combustion_engine_speed_hyb,0, /min
IDE80001-ENG130018,Analysis 1-Data State,Data available,
IDE80001-ENG129997,Analysis 1-Drive_position_sensor_value_neg,50.0, %
IDE80001-ENG129996,Analysis 1-Drive_position_sensor_value_pos,49.5, %
IDE80001-ENG130013,Analysis 1-Driving_strategy_accelerator_pedal_position_modified,0, %
IDE80001-ENG118434,Analysis 1-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE80001-ENG130012,Analysis 1-Driving_strategy_vehicle_coordinator_main_state,Stg Treiber,
IDE80001-ENG118348,Analysis 1-Electric_engine_torque_hyb,0.00, Nm
IDE80001-ENG118213,Analysis 1-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE80001-ENG118214,Analysis 1-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE80001-ENG118400,Analysis 1-Electrical_pump_3_for_transmission_current,0.0, A
IDE80001-ENG114478,Analysis 1-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE80001-ENG129980,Analysis 1-Gear_selector_13_state,Init (Pos),
IDE80001-ENG129983,Analysis 1-Gear_selector_2R_state,Init (Pos),
IDE80001-ENG129982,Analysis 1-Gear_selector_46_state,Init (Pos),
IDE80001-ENG129981,Analysis 1-Gear_selector_57_state,Init (Pos),
IDE80001-ENG130011,Analysis 1-KL15_state,On,
IDE80001-ENG05954,Analysis 1-Time_difference_before_storage_of_diagnostic_entry,190, ms
IDE80001-ENG129721,Analysis 1-Voltage_supply_1_for_sensors,5.0, V
IDE80001-ENG129722,Analysis 1-Voltage_supply_2_for_sensors,5.0, V
IDE80001-ENG129977,Analysis 1-Voltage_supply_3_for_sensors,5.0, V
IDE80001-ENG129978,Analysis 1-Voltage_supply_commanded_value,0.0, V
IDE80001-ENG129979,Analysis 1-Voltage_supply_speed_sensor,9.1, V
IDE80002-IDE00019,Analysis 2-Voltage terminal 30,12.6, V
IDE80002-IDE00021,Analysis 2-Engine speed,0.00, /min
IDE80002-IDE00023,Analysis 2-Transmission output speed,0, /min
IDE80002-IDE00026,Analysis 2-Vehicle speed from transmission,0.0, km/h
IDE80002-IDE00089,Analysis 2-Driving position,P,
IDE80002-IDE00100,Analysis 2-Engine torque,67.00, Nm
IDE80002-IDE00856,Analysis 2-Clutch 2 upper adaptation point,New,
IDE80002-IDE00866,Analysis 2-Specified torque clutch 1,-500.00, Nm
IDE80002-IDE00867,Analysis 2-Specified torque clutch 2,-500.00, Nm
IDE80002-IDE05990,Analysis 2-Pressure of clutch 2: specified value,0.0, bar
IDE80002-IDE05991,Analysis 2-Pressure of clutch 1: specified value,0.0, bar
IDE80002-IDE06658,Analysis 2-Pressure control valve 2: act. current,0.0, mA
IDE80002-IDE06659,Analysis 2-Pressure control valve 3: act. current,0.0, mA
IDE80002-IDE06660,Analysis 2-Pressure control valve 3: spec. current,0.0, mA
IDE80002-IDE06661,Analysis 2-Pressure control valve 2: spec. current,0.0, mA
IDE80002-IDE06662,Analysis 2-Pressure control valve 4: spec. current,0.0, mA
IDE80002-IDE06663,Analysis 2-Pressure control valve 4: act. current,-55.2, mA
IDE80002-IDE06668,Analysis 2-Pressure control valve 1: act. current,0.6, mA
IDE80002-IDE06669,Analysis 2-Pressure control valve 1: spec. current,0.0, mA
IDE80002-IDE09396,Analysis 2-Aux. hydraulic pump 1: actual RPM,7, /min
IDE80002-IDE09397,Analysis 2-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE80002-IDE10177,Analysis 2-Transmission input speed sensor 1,0, /min
IDE80002-IDE10178,Analysis 2-Transmission input speed sensor 2,0, /min
IDE80002-IDE10469,Analysis 2-Clutch pressure: clutch 1,0.0, bar
IDE80002-IDE10470,Analysis 2-Clutch pressure: clutch 2,0.0, bar
IDE80002-IDE11143,Analysis 2-Sol. valve 1: act. current,0.0, mA
IDE80002-IDE11144,Analysis 2-Sol. valve 1: spec. current,0.0, mA
IDE80002-IDE11145,Analysis 2-Sol. valve 2: act. current,0.0, mA
IDE80002-IDE11146,Analysis 2-Sol. valve 2: spec. current,0.0, mA
IDE80002-IDE11147,Analysis 2-Sol. valve 3: act. current,0.0, mA
IDE80002-IDE11148,Analysis 2-Sol. valve 3: spec. current,0.0, mA
IDE80002-IDE11149,Analysis 2-Sol. valve 4: act. current,0.0, mA
IDE80002-IDE11150,Analysis 2-Sol. valve 4: spec. current,0.0, mA
IDE80002-IDE11159,Analysis 2-Gear selector dist. sensor 1: position,9.1, mm
IDE80002-IDE11160,Analysis 2-Gear selector dist. sensor 2: position,0.0, mm
IDE80002-IDE11161,Analysis 2-Gear selector dist. sensor 3: position,-0.3, mm
IDE80002-IDE11162,Analysis 2-Gear selector dist. sensor 4: position,-0.1, mm
IDE80002-IDE11180,Analysis 2-Sol. valve 5: act. current,745.8, mA
IDE80002-IDE11181,Analysis 2-Sol. valve 5: spec. current,744.6, mA
IDE80002-IDE11182,Analysis 2-Sol. valve 6: act. current,0.0, mA
IDE80002-IDE11183,Analysis 2-Sol. valve 6: spec. current,0.0, mA
IDE80002-ENG129731,Analysis 2-Automatic_transmission_fluid_pump_phase_current,0, A
IDE80002-ENG130016,Analysis 2-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE80002-ENG130015,Analysis 2-Automatic_transmission_fluid_pump_shunt_current,655.33, A
IDE80002-ENG129701,Analysis 2-Automatic_transmission_fluid_source_of_commanded_speed,SBW,
IDE80002-ENG118442,Analysis 2-Clutch_0_actual_torque_hyb,0.00, Nm
IDE80002-ENG129961,Analysis 2-Clutch_0_commanded_pressure,0.0, bar
IDE80002-ENG118399,Analysis 2-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE80002-ENG129966,Analysis 2-Clutch_actuation_substate,0,
IDE80002-ENG118401,Analysis 2-Combustion_engine_speed_hyb,0, /min
IDE80002-ENG130018,Analysis 2-Data State,Data available,
IDE80002-ENG129997,Analysis 2-Drive_position_sensor_value_neg,49.5, %
IDE80002-ENG129996,Analysis 2-Drive_position_sensor_value_pos,49.5, %
IDE80002-ENG130013,Analysis 2-Driving_strategy_accelerator_pedal_position_modified,0, %
IDE80002-ENG118434,Analysis 2-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE80002-ENG130012,Analysis 2-Driving_strategy_vehicle_coordinator_main_state,Stg Treiber,
IDE80002-ENG118348,Analysis 2-Electric_engine_torque_hyb,0.00, Nm
IDE80002-ENG118213,Analysis 2-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE80002-ENG118214,Analysis 2-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE80002-ENG118400,Analysis 2-Electrical_pump_3_for_transmission_current,0.0, A
IDE80002-ENG114478,Analysis 2-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE80002-ENG129980,Analysis 2-Gear_selector_13_state,Init (Pos),
IDE80002-ENG129983,Analysis 2-Gear_selector_2R_state,Init (Pos),
IDE80002-ENG129982,Analysis 2-Gear_selector_46_state,Init (Pos),
IDE80002-ENG129981,Analysis 2-Gear_selector_57_state,Init (Pos),
IDE80002-ENG130011,Analysis 2-KL15_state,On,
IDE80002-ENG05954,Analysis 2-Time_difference_before_storage_of_diagnostic_entry,150, ms
IDE80002-ENG129721,Analysis 2-Voltage_supply_1_for_sensors,5.0, V
IDE80002-ENG129722,Analysis 2-Voltage_supply_2_for_sensors,5.0, V
IDE80002-ENG129977,Analysis 2-Voltage_supply_3_for_sensors,5.0, V
IDE80002-ENG129978,Analysis 2-Voltage_supply_commanded_value,0.0, V
IDE80002-ENG129979,Analysis 2-Voltage_supply_speed_sensor,9.2, V
IDE80003-IDE00019,Analysis 3-Voltage terminal 30,12.6, V
IDE80003-IDE00021,Analysis 3-Engine speed,0.00, /min
IDE80003-IDE00023,Analysis 3-Transmission output speed,0, /min
IDE80003-IDE00026,Analysis 3-Vehicle speed from transmission,0.0, km/h
IDE80003-IDE00089,Analysis 3-Driving position,P,
IDE80003-IDE00100,Analysis 3-Engine torque,67.00, Nm
IDE80003-IDE00856,Analysis 3-Clutch 2 upper adaptation point,New,
IDE80003-IDE00866,Analysis 3-Specified torque clutch 1,-500.00, Nm
IDE80003-IDE00867,Analysis 3-Specified torque clutch 2,-500.00, Nm
IDE80003-IDE05990,Analysis 3-Pressure of clutch 2: specified value,0.0, bar
IDE80003-IDE05991,Analysis 3-Pressure of clutch 1: specified value,0.0, bar
IDE80003-IDE06658,Analysis 3-Pressure control valve 2: act. current,0.0, mA
IDE80003-IDE06659,Analysis 3-Pressure control valve 3: act. current,0.0, mA
IDE80003-IDE06660,Analysis 3-Pressure control valve 3: spec. current,0.0, mA
IDE80003-IDE06661,Analysis 3-Pressure control valve 2: spec. current,0.0, mA
IDE80003-IDE06662,Analysis 3-Pressure control valve 4: spec. current,0.0, mA
IDE80003-IDE06663,Analysis 3-Pressure control valve 4: act. current,-54.7, mA
IDE80003-IDE06668,Analysis 3-Pressure control valve 1: act. current,0.6, mA
IDE80003-IDE06669,Analysis 3-Pressure control valve 1: spec. current,0.0, mA
IDE80003-IDE09396,Analysis 3-Aux. hydraulic pump 1: actual RPM,0, /min
IDE80003-IDE09397,Analysis 3-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE80003-IDE10177,Analysis 3-Transmission input speed sensor 1,0, /min
IDE80003-IDE10178,Analysis 3-Transmission input speed sensor 2,0, /min
IDE80003-IDE10469,Analysis 3-Clutch pressure: clutch 1,0.0, bar
IDE80003-IDE10470,Analysis 3-Clutch pressure: clutch 2,0.0, bar
IDE80003-IDE11143,Analysis 3-Sol. valve 1: act. current,0.0, mA
IDE80003-IDE11144,Analysis 3-Sol. valve 1: spec. current,0.0, mA
IDE80003-IDE11145,Analysis 3-Sol. valve 2: act. current,0.0, mA
IDE80003-IDE11146,Analysis 3-Sol. valve 2: spec. current,0.0, mA
IDE80003-IDE11147,Analysis 3-Sol. valve 3: act. current,0.0, mA
IDE80003-IDE11148,Analysis 3-Sol. valve 3: spec. current,0.0, mA
IDE80003-IDE11149,Analysis 3-Sol. valve 4: act. current,0.0, mA
IDE80003-IDE11150,Analysis 3-Sol. valve 4: spec. current,0.0, mA
IDE80003-IDE11159,Analysis 3-Gear selector dist. sensor 1: position,9.1, mm
IDE80003-IDE11160,Analysis 3-Gear selector dist. sensor 2: position,0.0, mm
IDE80003-IDE11161,Analysis 3-Gear selector dist. sensor 3: position,-0.3, mm
IDE80003-IDE11162,Analysis 3-Gear selector dist. sensor 4: position,-0.1, mm
IDE80003-IDE11180,Analysis 3-Sol. valve 5: act. current,746.0, mA
IDE80003-IDE11181,Analysis 3-Sol. valve 5: spec. current,744.6, mA
IDE80003-IDE11182,Analysis 3-Sol. valve 6: act. current,0.0, mA
IDE80003-IDE11183,Analysis 3-Sol. valve 6: spec. current,0.0, mA
IDE80003-ENG129731,Analysis 3-Automatic_transmission_fluid_pump_phase_current,0, A
IDE80003-ENG130016,Analysis 3-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE80003-ENG130015,Analysis 3-Automatic_transmission_fluid_pump_shunt_current,655.35, A
IDE80003-ENG129701,Analysis 3-Automatic_transmission_fluid_source_of_commanded_speed,SBW,
IDE80003-ENG118442,Analysis 3-Clutch_0_actual_torque_hyb,0.00, Nm
IDE80003-ENG129961,Analysis 3-Clutch_0_commanded_pressure,0.0, bar
IDE80003-ENG118399,Analysis 3-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE80003-ENG129966,Analysis 3-Clutch_actuation_substate,0,
IDE80003-ENG118401,Analysis 3-Combustion_engine_speed_hyb,0, /min
IDE80003-ENG130018,Analysis 3-Data State,Data available,
IDE80003-ENG129997,Analysis 3-Drive_position_sensor_value_neg,50.0, %
IDE80003-ENG129996,Analysis 3-Drive_position_sensor_value_pos,49.5, %
IDE80003-ENG130013,Analysis 3-Driving_strategy_accelerator_pedal_position_modified,0, %
IDE80003-ENG118434,Analysis 3-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE80003-ENG130012,Analysis 3-Driving_strategy_vehicle_coordinator_main_state,Stg Treiber,
IDE80003-ENG118348,Analysis 3-Electric_engine_torque_hyb,0.00, Nm
IDE80003-ENG118213,Analysis 3-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE80003-ENG118214,Analysis 3-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE80003-ENG118400,Analysis 3-Electrical_pump_3_for_transmission_current,0.0, A
IDE80003-ENG114478,Analysis 3-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE80003-ENG129980,Analysis 3-Gear_selector_13_state,Init (Pos),
IDE80003-ENG129983,Analysis 3-Gear_selector_2R_state,Init (Pos),
IDE80003-ENG129982,Analysis 3-Gear_selector_46_state,Init (Pos),
IDE80003-ENG129981,Analysis 3-Gear_selector_57_state,Init (Pos),
IDE80003-ENG130011,Analysis 3-KL15_state,On,
IDE80003-ENG05954,Analysis 3-Time_difference_before_storage_of_diagnostic_entry,110, ms
IDE80003-ENG129721,Analysis 3-Voltage_supply_1_for_sensors,5.0, V
IDE80003-ENG129722,Analysis 3-Voltage_supply_2_for_sensors,5.0, V
IDE80003-ENG129977,Analysis 3-Voltage_supply_3_for_sensors,5.0, V
IDE80003-ENG129978,Analysis 3-Voltage_supply_commanded_value,0.0, V
IDE80003-ENG129979,Analysis 3-Voltage_supply_speed_sensor,9.2, V
IDE80004-IDE00019,Analysis 4-Voltage terminal 30,12.6, V
IDE80004-IDE00021,Analysis 4-Engine speed,0.00, /min
IDE80004-IDE00023,Analysis 4-Transmission output speed,0, /min
IDE80004-IDE00026,Analysis 4-Vehicle speed from transmission,0.0, km/h
IDE80004-IDE00089,Analysis 4-Driving position,P,
IDE80004-IDE00100,Analysis 4-Engine torque,67.00, Nm
IDE80004-IDE00856,Analysis 4-Clutch 2 upper adaptation point,New,
IDE80004-IDE00866,Analysis 4-Specified torque clutch 1,-500.00, Nm
IDE80004-IDE00867,Analysis 4-Specified torque clutch 2,-500.00, Nm
IDE80004-IDE05990,Analysis 4-Pressure of clutch 2: specified value,0.0, bar
IDE80004-IDE05991,Analysis 4-Pressure of clutch 1: specified value,0.0, bar
IDE80004-IDE06658,Analysis 4-Pressure control valve 2: act. current,0.0, mA
IDE80004-IDE06659,Analysis 4-Pressure control valve 3: act. current,0.0, mA
IDE80004-IDE06660,Analysis 4-Pressure control valve 3: spec. current,0.0, mA
IDE80004-IDE06661,Analysis 4-Pressure control valve 2: spec. current,0.0, mA
IDE80004-IDE06662,Analysis 4-Pressure control valve 4: spec. current,0.0, mA
IDE80004-IDE06663,Analysis 4-Pressure control valve 4: act. current,-54.8, mA
IDE80004-IDE06668,Analysis 4-Pressure control valve 1: act. current,0.5, mA
IDE80004-IDE06669,Analysis 4-Pressure control valve 1: spec. current,0.0, mA
IDE80004-IDE09396,Analysis 4-Aux. hydraulic pump 1: actual RPM,0, /min
IDE80004-IDE09397,Analysis 4-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE80004-IDE10177,Analysis 4-Transmission input speed sensor 1,0, /min
IDE80004-IDE10178,Analysis 4-Transmission input speed sensor 2,0, /min
IDE80004-IDE10469,Analysis 4-Clutch pressure: clutch 1,0.0, bar
IDE80004-IDE10470,Analysis 4-Clutch pressure: clutch 2,0.0, bar
IDE80004-IDE11143,Analysis 4-Sol. valve 1: act. current,0.0, mA
IDE80004-IDE11144,Analysis 4-Sol. valve 1: spec. current,0.0, mA
IDE80004-IDE11145,Analysis 4-Sol. valve 2: act. current,0.0, mA
IDE80004-IDE11146,Analysis 4-Sol. valve 2: spec. current,0.0, mA
IDE80004-IDE11147,Analysis 4-Sol. valve 3: act. current,0.0, mA
IDE80004-IDE11148,Analysis 4-Sol. valve 3: spec. current,0.0, mA
IDE80004-IDE11149,Analysis 4-Sol. valve 4: act. current,0.0, mA
IDE80004-IDE11150,Analysis 4-Sol. valve 4: spec. current,0.0, mA
IDE80004-IDE11159,Analysis 4-Gear selector dist. sensor 1: position,9.1, mm
IDE80004-IDE11160,Analysis 4-Gear selector dist. sensor 2: position,0.0, mm
IDE80004-IDE11161,Analysis 4-Gear selector dist. sensor 3: position,-0.3, mm
IDE80004-IDE11162,Analysis 4-Gear selector dist. sensor 4: position,-0.1, mm
IDE80004-IDE11180,Analysis 4-Sol. valve 5: act. current,746.0, mA
IDE80004-IDE11181,Analysis 4-Sol. valve 5: spec. current,744.6, mA
IDE80004-IDE11182,Analysis 4-Sol. valve 6: act. current,0.0, mA
IDE80004-IDE11183,Analysis 4-Sol. valve 6: spec. current,0.0, mA
IDE80004-ENG129731,Analysis 4-Automatic_transmission_fluid_pump_phase_current,0, A
IDE80004-ENG130016,Analysis 4-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE80004-ENG130015,Analysis 4-Automatic_transmission_fluid_pump_shunt_current,655.35, A
IDE80004-ENG129701,Analysis 4-Automatic_transmission_fluid_source_of_commanded_speed,SBW,
IDE80004-ENG118442,Analysis 4-Clutch_0_actual_torque_hyb,0.00, Nm
IDE80004-ENG129961,Analysis 4-Clutch_0_commanded_pressure,0.0, bar
IDE80004-ENG118399,Analysis 4-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE80004-ENG129966,Analysis 4-Clutch_actuation_substate,0,
IDE80004-ENG118401,Analysis 4-Combustion_engine_speed_hyb,0, /min
IDE80004-ENG130018,Analysis 4-Data State,Data available,
IDE80004-ENG129997,Analysis 4-Drive_position_sensor_value_neg,49.5, %
IDE80004-ENG129996,Analysis 4-Drive_position_sensor_value_pos,49.5, %
IDE80004-ENG130013,Analysis 4-Driving_strategy_accelerator_pedal_position_modified,0, %
IDE80004-ENG118434,Analysis 4-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE80004-ENG130012,Analysis 4-Driving_strategy_vehicle_coordinator_main_state,Stg Treiber,
IDE80004-ENG118348,Analysis 4-Electric_engine_torque_hyb,0.00, Nm
IDE80004-ENG118213,Analysis 4-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE80004-ENG118214,Analysis 4-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE80004-ENG118400,Analysis 4-Electrical_pump_3_for_transmission_current,0.0, A
IDE80004-ENG114478,Analysis 4-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE80004-ENG129980,Analysis 4-Gear_selector_13_state,Init (Pos),
IDE80004-ENG129983,Analysis 4-Gear_selector_2R_state,Init (Pos),
IDE80004-ENG129982,Analysis 4-Gear_selector_46_state,Init (Pos),
IDE80004-ENG129981,Analysis 4-Gear_selector_57_state,Init (Pos),
IDE80004-ENG130011,Analysis 4-KL15_state,On,
IDE80004-ENG05954,Analysis 4-Time_difference_before_storage_of_diagnostic_entry,70, ms
IDE80004-ENG129721,Analysis 4-Voltage_supply_1_for_sensors,5.0, V
IDE80004-ENG129722,Analysis 4-Voltage_supply_2_for_sensors,5.0, V
IDE80004-ENG129977,Analysis 4-Voltage_supply_3_for_sensors,5.0, V
IDE80004-ENG129978,Analysis 4-Voltage_supply_commanded_value,0.0, V
IDE80004-ENG129979,Analysis 4-Voltage_supply_speed_sensor,9.2, V
IDE80005-IDE00019,Analysis 5-Voltage terminal 30,12.6, V
IDE80005-IDE00021,Analysis 5-Engine speed,0.00, /min
IDE80005-IDE00023,Analysis 5-Transmission output speed,0, /min
IDE80005-IDE00026,Analysis 5-Vehicle speed from transmission,0.0, km/h
IDE80005-IDE00089,Analysis 5-Driving position,P,
IDE80005-IDE00100,Analysis 5-Engine torque,67.00, Nm
IDE80005-IDE00856,Analysis 5-Clutch 2 upper adaptation point,New,
IDE80005-IDE00866,Analysis 5-Specified torque clutch 1,-500.00, Nm
IDE80005-IDE00867,Analysis 5-Specified torque clutch 2,-500.00, Nm
IDE80005-IDE05990,Analysis 5-Pressure of clutch 2: specified value,0.0, bar
IDE80005-IDE05991,Analysis 5-Pressure of clutch 1: specified value,0.0, bar
IDE80005-IDE06658,Analysis 5-Pressure control valve 2: act. current,0.0, mA
IDE80005-IDE06659,Analysis 5-Pressure control valve 3: act. current,0.0, mA
IDE80005-IDE06660,Analysis 5-Pressure control valve 3: spec. current,0.0, mA
IDE80005-IDE06661,Analysis 5-Pressure control valve 2: spec. current,0.0, mA
IDE80005-IDE06662,Analysis 5-Pressure control valve 4: spec. current,0.0, mA
IDE80005-IDE06663,Analysis 5-Pressure control valve 4: act. current,-54.9, mA
IDE80005-IDE06668,Analysis 5-Pressure control valve 1: act. current,0.6, mA
IDE80005-IDE06669,Analysis 5-Pressure control valve 1: spec. current,0.0, mA
IDE80005-IDE09396,Analysis 5-Aux. hydraulic pump 1: actual RPM,0, /min
IDE80005-IDE09397,Analysis 5-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE80005-IDE10177,Analysis 5-Transmission input speed sensor 1,0, /min
IDE80005-IDE10178,Analysis 5-Transmission input speed sensor 2,0, /min
IDE80005-IDE10469,Analysis 5-Clutch pressure: clutch 1,0.0, bar
IDE80005-IDE10470,Analysis 5-Clutch pressure: clutch 2,0.0, bar
IDE80005-IDE11143,Analysis 5-Sol. valve 1: act. current,0.0, mA
IDE80005-IDE11144,Analysis 5-Sol. valve 1: spec. current,0.0, mA
IDE80005-IDE11145,Analysis 5-Sol. valve 2: act. current,0.0, mA
IDE80005-IDE11146,Analysis 5-Sol. valve 2: spec. current,0.0, mA
IDE80005-IDE11147,Analysis 5-Sol. valve 3: act. current,0.0, mA
IDE80005-IDE11148,Analysis 5-Sol. valve 3: spec. current,0.0, mA
IDE80005-IDE11149,Analysis 5-Sol. valve 4: act. current,0.0, mA
IDE80005-IDE11150,Analysis 5-Sol. valve 4: spec. current,0.0, mA
IDE80005-IDE11159,Analysis 5-Gear selector dist. sensor 1: position,9.1, mm
IDE80005-IDE11160,Analysis 5-Gear selector dist. sensor 2: position,0.0, mm
IDE80005-IDE11161,Analysis 5-Gear selector dist. sensor 3: position,-0.3, mm
IDE80005-IDE11162,Analysis 5-Gear selector dist. sensor 4: position,-0.1, mm
IDE80005-IDE11180,Analysis 5-Sol. valve 5: act. current,746.3, mA
IDE80005-IDE11181,Analysis 5-Sol. valve 5: spec. current,744.6, mA
IDE80005-IDE11182,Analysis 5-Sol. valve 6: act. current,0.0, mA
IDE80005-IDE11183,Analysis 5-Sol. valve 6: spec. current,0.0, mA
IDE80005-ENG129731,Analysis 5-Automatic_transmission_fluid_pump_phase_current,0, A
IDE80005-ENG130016,Analysis 5-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE80005-ENG130015,Analysis 5-Automatic_transmission_fluid_pump_shunt_current,655.33, A
IDE80005-ENG129701,Analysis 5-Automatic_transmission_fluid_source_of_commanded_speed,SBW,
IDE80005-ENG118442,Analysis 5-Clutch_0_actual_torque_hyb,0.00, Nm
IDE80005-ENG129961,Analysis 5-Clutch_0_commanded_pressure,0.0, bar
IDE80005-ENG118399,Analysis 5-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE80005-ENG129966,Analysis 5-Clutch_actuation_substate,0,
IDE80005-ENG118401,Analysis 5-Combustion_engine_speed_hyb,0, /min
IDE80005-ENG130018,Analysis 5-Data State,Data available,
IDE80005-ENG129997,Analysis 5-Drive_position_sensor_value_neg,50.0, %
IDE80005-ENG129996,Analysis 5-Drive_position_sensor_value_pos,49.5, %
IDE80005-ENG130013,Analysis 5-Driving_strategy_accelerator_pedal_position_modified,0, %
IDE80005-ENG118434,Analysis 5-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE80005-ENG130012,Analysis 5-Driving_strategy_vehicle_coordinator_main_state,Stg Treiber,
IDE80005-ENG118348,Analysis 5-Electric_engine_torque_hyb,0.00, Nm
IDE80005-ENG118213,Analysis 5-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE80005-ENG118214,Analysis 5-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE80005-ENG118400,Analysis 5-Electrical_pump_3_for_transmission_current,0.0, A
IDE80005-ENG114478,Analysis 5-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE80005-ENG129980,Analysis 5-Gear_selector_13_state,Init (Pos),
IDE80005-ENG129983,Analysis 5-Gear_selector_2R_state,Init (Pos),
IDE80005-ENG129982,Analysis 5-Gear_selector_46_state,Init (Pos),
IDE80005-ENG129981,Analysis 5-Gear_selector_57_state,Init (Pos),
IDE80005-ENG130011,Analysis 5-KL15_state,On,
IDE80005-ENG05954,Analysis 5-Time_difference_before_storage_of_diagnostic_entry,30, ms
IDE80005-ENG129721,Analysis 5-Voltage_supply_1_for_sensors,5.0, V
IDE80005-ENG129722,Analysis 5-Voltage_supply_2_for_sensors,5.0, V
IDE80005-ENG129977,Analysis 5-Voltage_supply_3_for_sensors,5.0, V
IDE80005-ENG129978,Analysis 5-Voltage_supply_commanded_value,0.0, V
IDE80005-ENG129979,Analysis 5-Voltage_supply_speed_sensor,9.2, V
IDE80006,Analysis 6,A8 48 38 0E FC 1D C5 73 FA A3 C9 DD 98 71 BC 6D 64 E4 E0 CD 88 63 BB 6F FB 25 81 CF B0 57 8A A2 11 0F C2 22 77 B4 79 A5 37 6B 87 52 7F B0 7B A4 B7 2B A7 42 C2 19 D8 A7 36 EB C7 72 6F B8 7F A6 B6 AB E7 62 17 84 61 A9 94 CD A3 92 1F 80 63 A8 B1 28 26 82 07 8C 65 AB 30 E8 46 B2 AA 2D C2 AA B0 A8 66 A2 37 94 69 AD 33 69 86 D2 3F 90 6B AC 16 8C 03 C2 27 9C 6D AF 32 E9 C6 F2 2F 98 6F AE B2 A9 E6 E2 72 41 F4 B1 3D 6E 05 13 DF E0 53 B0 BD 2E 25 03 C7 EC 55 B3 EA 6D FC 50,
MAS00156-ENG98502,Driving direction-Data,not recognized,
ENG00803,A004_Notfahren_NAnHS,0, /min
ENG00804-ENG98502,A014_NAnHS-Data,0, /min
ENG00805-ENG98502,A015_NAnHSKD-Data,10000, /min
ENG00806-ENG98502,A016_NAnHSKF-Data,0, /min
ENG00807-ENG98502,A017_NAnHSMin-Data,0, /min
ENG00808-ENG98502,A018_NAnRS-Data,0, /min
ENG00809-ENG98502,A019_NAnRSKF-Data,0, /min
ENG00810-ENG98502,A020_NAnRSMin-Data,0, /min
ENG00811-ENG98502,A022_NAnSchalt-Data,0, /min
ENG00812-ENG98502,A023_Bergab_NAnRSMin-Data,0, /min
ENG00813-ENG98502,A024_Bergab_NAnHSMin-Data,0, /min
ENG105000,A028_Svc_NMotLLSoll,800, /min
ENG38833-ENG98502,Ak0a_EepromData_PK0_Ist_PKP1-Data,6.500, bar
ENG38834-ENG98502,Ak0a_EepromData_PK0_Soll_PKP1-Data,6.500, bar
ENG38835-ENG98502,Ak0a_PSoll_PKP1_Roh-Data,6.500, bar
ENG38836-ENG98502,Ak0k_EepromData_PK0_Ist_PKP0-Data,4.100, bar
ENG38837-ENG98502,Ak0k_EepromData_PK0_Soll_PKP0-Data,4.200, bar
ENG38838-ENG98502,Ak0k_PSoll_PKP0_Norm-Data,4.200, bar
ENG08715-ENG98502,Ambient_air_pressure_during_adaption-Data,1.012, bar
ENG08716-ENG98502,Ambient_air_pressure_value-Data,1.012, bar
ENG129684-ENG130027,Atf_angle_sensor_error_code_of_adaption-Atf adaption Error Code,no error,
ENG129683-ENG98502,Atf_angle_sensor_state_of_adaption-Data,(0) Kal nicht aktiv,
ENG05873-ENG115659,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-y0,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG99777,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y1,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG115668,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-y10,6C B0 97 7D 57 32 20 7F 0C B9 9D 80 50 14 07 01 00 00 00 00,
ENG05873-ENG05915,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y11,72 B2 99 7D 57 32 20 7F 14 B8 9D 7E 4E 14 09 01 00 00 00 00,
ENG05873-ENG05916,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y12,7D B6 9D 7D 57 33 22 7F 17 B8 A0 7D 4B 15 0A 01 00 00 00 00,
ENG05873-ENG05917,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y13,86 BC A3 7D 57 35 23 0A C2 BE A3 7E 4D 1B 0F 01 00 00 00 00,
ENG05873-ENG05918,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y14,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG05919,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y15,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG05920,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y16,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG05921,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y17,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG05922,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y18,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG05923,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y19,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG100480,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y2,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG100773,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y3,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG100631,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y4,2E FA AF 7D 57 32 1F 80 FF FF F3 AB 7B 31 14 01 00 00 00 00,
ENG05873-ENG102174,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y5,3A AB 92 7D 57 32 1F 01 FF C3 A8 91 63 27 10 01 00 00 00 00,
ENG05873-ENG113993,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y6,43 B9 A0 7D 57 32 1F 14 FF C3 AA 87 5A 1A 0A 01 00 00 00 00,
ENG05873-ENG115665,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-y7,4A AA 91 7D 57 32 1F 7E 2B C3 A8 90 61 1D 0B 01 00 00 00 00,
ENG05873-ENG115666,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-y8,55 AD 94 7D 57 32 1F 7F 1C BF A3 88 58 1B 0B 01 00 00 00 00,
ENG05873-ENG115667,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-y9,5E AC 93 7D 57 32 1F 7F 0B B8 9D 84 56 16 09 01 00 00 00 00,
ENG129686-ENG98502,Automatic_transmission_fluid_pump_adaption_state-Data,Init,
ENG129691,Automatic_transmission_fluid_pump_atic_current_limitation,32896,
ENG129695,Automatic_transmission_fluid_pump_atic_device_state,56814,
ENG129720,Automatic_transmission_fluid_pump_atic_diagnose_aux_state,0,
ENG129689,Automatic_transmission_fluid_pump_atic_diagnose_state,0,
ENG129690,Automatic_transmission_fluid_pump_atic_hardware_state,61456,
ENG129719,Automatic_transmission_fluid_pump_atic_offstate_diagnose,0,
ENG129692,Automatic_transmission_fluid_pump_atic_onstate_diagnose,0,
ENG08700,Automatic_transmission_fluid_pump_commanded_phase_current,3, A
ENG08701-ENG98502,Automatic_transmission_fluid_pump_commanded_voltage-Data,2.5, V
ENG08714-ENG98502,Automatic_transmission_fluid_pump_commutation_angle-Data,2.5, °
ENG129699-ENG98502,Automatic_transmission_fluid_pump_cos_voltage_value-Data,3.216, V
ENG08697,Automatic_transmission_fluid_pump_current_limitation_counter,0,
ENG129687-ENG130032,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Abbruchtimer,No,
ENG129687-ENG130029,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Akustikzustand,No,
ENG129687-ENG130039,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Drehzahlabweichung,No,
ENG129687-ENG99021,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Insuff. voltage,No,
ENG129687-ENG130030,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Kuehlung,No,
ENG129687-ENG129443,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Maxdrehzahl,No,
ENG129687-ENG130035,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Maxstrom,No,
ENG129687-ENG09326,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Minstrom,No,
ENG129687-ENG130038,Automatic_transmission_fluid_pump_error_code_of_current_adaption-MittenTempBereich,No,
ENG129687-ENG130033,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Monotonie,No,
ENG129687-ENG09327,Automatic_transmission_fluid_pump_error_code_of_current_adaption-SollwertQuelle,No,
ENG129687-ENG130034,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Stromabweichung,No,
ENG129687-ENG130028,Automatic_transmission_fluid_pump_error_code_of_current_adaption-TBereich,No,
ENG129687-ENG130036,Automatic_transmission_fluid_pump_error_code_of_current_adaption-TMin,No,
ENG129687-ENG130037,Automatic_transmission_fluid_pump_error_code_of_current_adaption-UIntegral,No,
ENG129687-ENG130031,Automatic_transmission_fluid_pump_error_code_of_current_adaption-V_Motor_Start,No,
ENG08713,Automatic_transmission_fluid_pump_limited_phase_current,60, A
ENG129688-ENG98502,Automatic_transmission_fluid_pump_max_permissible_voltage-Data,13.308, V
ENG08698-ENG98502,Automatic_transmission_fluid_pump_modulation_commanded_speed-Data,610, /min
ENG129731,Automatic_transmission_fluid_pump_phase_current,3, A
ENG08699-ENG98502,Automatic_transmission_fluid_pump_scaling_factor-Data,0.19,
ENG129698-ENG98502,Automatic_transmission_fluid_pump_sin_voltage_value-Data,1.430, V
ENG129696-ENG98502,Automatic_transmission_fluid_pump_unit_circle_diagnose_value-Data,-100, %
ENG129697-ENG98502,Automatic_transmission_fluid_pump_unit_circle_sensor_value-Data,1.003,
ENG129701,Automatic_transmission_fluid_source_of_commanded_speed,Test,
ENG05872-ENG05929,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_adaption,181, min
ENG05872-ENG05931,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_ATF_filtering,13420, min
ENG05872-ENG05926,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_cooling,11113, min
ENG05872-ENG05928,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_cooling_request,0, min
ENG05872-ENG05933,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_none,2001, min
ENG05872-ENG05924,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_others,18, min
ENG05872-ENG05932,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_partial_accumulator,56, min
ENG05872-ENG05930,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_pressure accumulator_special_forced_speed,871, min
ENG05872-ENG05925,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_pressure_accumulator,7452, min
ENG05872-ENG05927,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_test,12715, min
ENG05872-ENG05934,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_WDE_control,8, min
ENG101413,Calibration Identification,8W2155BA00011   ,
ENG99697,Calibration Verification Number,F6 6A 77 DF,
ENG129678-ENG129945,CAN_messages_reception_state-State Dashboard received,received,
ENG129678-ENG101987,CAN_messages_reception_state-State ECM received,received,
ENG129678-ENG102056,CAN_messages_reception_state-State ESP received,received,
ENG129678-ENG103751,CAN_messages_reception_state-State Gateway received,received,
ENG129678-ENG104211,CAN_messages_reception_state-State Parking Brake received,received,
ENG129678-ENG101883,CAN_messages_reception_state-State Steering Angle received,received,
ENG129678-ENG102283,CAN_messages_reception_state-State Steering Assist received,received,
ENG08723-ENG98502,Clutch_1_absolute_pressure_value-Data,1.1, bar
ENG129681-ENG98502,Clutch_1_actual_pressure_raw_value-Data,1.1, bar
ENG08721,Clutch_1_adaption_temperature_range,3,
ENG08703-ENG98502,Clutch_1_filtered_absolute_pressure_during_adaption-Data,0.134, bar
ENG08695-ENG98502,Clutch_1_pressure_offset_adapted_value-Data,0.133, bar
ENG08717,Clutch_1_pressure_signal_quality,valid,
ENG08724-ENG98502,Clutch_2_absolute_pressure_value-Data,1.1, bar
ENG129682-ENG98502,Clutch_2_actual_pressure_raw_value-Data,1.1, bar
ENG08722,Clutch_2_adaption_temperature_range,3,
ENG08704-ENG98502,Clutch_2_filtered_absolute_pressure_during_adaption-Data,0.078, bar
ENG08696-ENG98502,Clutch_2_pressure_offset_adapted_adaption-Data,0.074, bar
ENG08718,Clutch_2_pressure_signal_quality,valid,
ENG129743-ENG98502,Clutch_temperature_calculated-Data,52, °C
ENG103018-ENG57629,Current Test Routine-Routine ID,Unknown (0),
ENG105740-ENG98502,D004_Svu_UChs2-Data,13.4, V
ENG105741-ENG98502,D005_Svu_UChs3-Data,13.3, V
ENG105742-ENG98502,D009_Svu_UChs1-Data,13.3, V
ENG05909,Drive_limiter_cause_safety_controller,0,
ENG05905,Drive_limiter_cause_signal_plausi,keine Fehler,
ENG05911,Drive_limiter_sopc_warning_level,0,
ENG26670-ENG30927,Drive_position_sensor_1_cause_of_failure-Drive_position_sensor_1_short_circuit_error_active,No,
ENG26670-ENG30928,Drive_position_sensor_1_cause_of_failure-Drive_position_sensor_1_src_error_active,No,
ENG26670-ENG30929,Drive_position_sensor_1_cause_of_failure-Drive_position_sensor_1_timing_error_active,No,
ENG26670-ENG98891,Drive_position_sensor_1_cause_of_failure-Reserved,-1,
ENG26671,Drive_position_sensor_1_high_level,322800,
ENG26672,Drive_position_sensor_1_interrupt,1257524,
ENG26673,Drive_position_sensor_1_low_level,1620325,
ENG26674,Drive_position_sensor_1_sensor_state,3,
ENG26675-ENG98502,Drive_position_sensor_1_signal_quality-Data,gueltig,
ENG57616-ENG98502,Drive_position_sensor_1_value-Data,83.5, %
ENG26676-ENG30930,Drive_position_sensor_2_cause_of_failure-Drive_position_sensor_2_short_circuit_error_active,No,
ENG26676-ENG30931,Drive_position_sensor_2_cause_of_failure-Drive_position_sensor_2_src_error_active,No,
ENG26676-ENG30932,Drive_position_sensor_2_cause_of_failure-Drive_position_sensor_2_timing_error_active,No,
ENG26676-ENG98891,Drive_position_sensor_2_cause_of_failure-Reserved,-1,
ENG26677,Drive_position_sensor_2_high_level,1637475,
ENG26678,Drive_position_sensor_2_interrupt,1266024,
ENG26679,Drive_position_sensor_2_low_level,291550,
ENG26680,Drive_position_sensor_2_sensor_state,3,
ENG26681-ENG98502,Drive_position_sensor_2_signal_quality-Data,gueltig,
ENG57617-ENG98502,Drive_position_sensor_2_value-Data,85.0, %
ENG06619-ENG102678,Drive_position_sensor_calculated_positions-Kalibrier Position D,0.00, %
ENG06619-ENG100378,Drive_position_sensor_calculated_positions-Kalibrier Position N,0.00, %
ENG06619-ENG103389,Drive_position_sensor_calculated_positions-Kalibrier Position P,0.00, %
ENG06619-ENG103160,Drive_position_sensor_calculated_positions-Kalibrier Position R,0.00, %
ENG06628-ENG98502,Drive_position_sensor_calibrated_range_D_minimum-Data,10.00, %
ENG06627-ENG98502,Drive_position_sensor_calibrated_range_ND-Data,33.00, %
ENG06624-ENG98502,Drive_position_sensor_calibrated_range_P_maximum-Data,90.00, %
ENG06625-ENG98502,Drive_position_sensor_calibrated_range_PR-Data,67.00, %
ENG06626-ENG98502,Drive_position_sensor_calibrated_range_RN-Data,47.00, %
ENG06618,Drive_position_sensor_calibration_saved_state,170,
ENG105999-ENG98502,E003_Akk_PKupAkt_PKp0[K1]-Data,2.679, bar
ENG106000-ENG98502,E004_Akk_PKupAkt_PKp0[K2]-Data,3.092, bar
ENG106006-ENG98502,E012_Akm_kl[K1].PKp0-Data,2.004, bar
ENG106007-ENG98502,E013_Akm_kl[k2].PKp0-Data,2.457, bar
ENG106008-ENG98502,E016_AkkEeprom.PKp0[K1]-Data,2.750, bar
ENG106009-ENG98502,E017_AkkEeprom.PKp0[K2]-Data,3.227, bar
ENG106010-ENG98502,E018_Akm_Eeprom.PKp1[K1]-Data,12.834, bar
ENG106011-ENG98502,E019_Akm_Eeprom.PKp1[K2]-Data,12.736, bar
ENG106014-ENG98502,E024_Akk_EEProm_Pakt.Pkupakt[K1]-Data,2.679, bar
ENG106015-ENG98502,E025_Akk_EEProm_Pakt.Pkupakt[K2]-Data,3.092, bar
ENG125929,ECU_R,04 80 01 09 14 20 9F F1 34 08 00 10 D0 01 4C FC 41 36 78 20,
ENG125930,ECU_ST,00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG100152,ECUNAME,-,
ENG100152-ENG28381,ECUNAME-Acronym,TCM-TransmisCtrl,
ENG100152,ECUNAME,TransmisCtrl,
ENG26777,ESP_Wheel_circumference,1990,
ENG103533-ENG98502,F004_Mmr_MMotEingriffDomina-Data,1600.00, Nm
ENG00839-ENG98502,F006_MLastHS-Data,53, Nm
ENG00840-ENG98502,F007_MLastRS-Data,7, Nm
ENG106462-ENG98502,F008_UmwMAbtrieb-Data,0, Nm
ENG105256,Front left wheel speed,0.0, km/h
ENG105255,Front right wheel speed,0.0, km/h
ENG106736-ENG104204,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_1,-15, °C
ENG106736-ENG101895,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_2,5, °C
ENG106736-ENG100724,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_3,25, °C
ENG106736-ENG103268,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_4,45, °C
ENG106736-ENG102350,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_5,65, °C
ENG106736-ENG103362,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_6,85, °C
ENG106736-ENG99474,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_7,105, °C
ENG106736-ENG101681,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_8,125, °C
ENG08705-ENG98502,Gear_1_synchron_speed-Data,0, /min
ENG08706-ENG98502,Gear_2_synchron_speed-Data,0, /min
ENG08707-ENG98502,Gear_3_synchron_speed-Data,0, /min
ENG08708-ENG98502,Gear_4_synchron_speed-Data,0, /min
ENG08709-ENG98502,Gear_5_synchron_speed-Data,0, /min
ENG08710-ENG98502,Gear_6_synchron_speed-Data,0, /min
ENG08711-ENG98502,Gear_7_synchron_speed-Data,0, /min
ENG08712-ENG98502,Gear_R_synchron_speed-Data,0, /min
ENG06638,Gear_selector_1_commanded_distance,9.1, mm
ENG06632,Gear_selector_1_flag_position_control_active,OFF,
ENG06636-ENG98502,Gear_selector_1_offset_to_nominal_position-Data,0.06, mm
ENG06620,Gear_selector_1_state,Abschaltung Bereit,
ENG06629,Gear_selector_2_commanded_distance,-9.4, mm
ENG06633,Gear_selector_2_flag_position_control_active,OFF,
ENG06637-ENG98502,Gear_selector_2_offset_to_nominal_position-Data,-0.12, mm
ENG06621,Gear_selector_2_state,Abschaltung Bereit,
ENG06630,Gear_selector_3_commanded_distance,-0.1, mm
ENG06634,Gear_selector_3_flag_position_control_active,OFF,
ENG06640-ENG98502,Gear_selector_3_offset_to_nominal_position-Data,0.07, mm
ENG06623,Gear_selector_3_state,Abschaltung Bereit,
ENG06631,Gear_selector_4_commanded_distance,-0.2, mm
ENG06635,Gear_selector_4_flag_position_control_active,OFF,
ENG06639-ENG98502,Gear_selector_4_offset_to_nominal_position-Data,-0.05, mm
ENG06622,Gear_selector_4_state,Abschaltung Bereit,
ENG05869,Gear_selector_basic_calibration_type,drehend,
ENG05870,Gear_selector_basic_calibration_validity,valid,
ENG08702-ENG09320,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_EPA_gueltig,valid,
ENG08702-ENG09321,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_SyncPos_ermittelt,gemessen,
ENG08702-ENG09322,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_TG1_Endl_gueltig,valid,
ENG08702-ENG09323,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_TG1_Sync_gueltig,valid,
ENG08702-ENG09324,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_TG2_Endl_gueltig,valid,
ENG08702-ENG09325,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_TG2_Sync_gueltig,valid,
ENG08702-ENG09319,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.DatenGRDgueltig,valid,
ENG08702-ENG98891,Gear_selector_calibration_state-Reserved,NOT-DEFINED,
ENG05871-ENG115659,Gear_selector_synchronization_adaption_start_pressure_correction_factor-y0,66 54 77 66,
ENG05871-ENG99777,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y1,68 53 4F 68,
ENG05871-ENG100480,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y2,5C 43 53 5C,
ENG05871-ENG100773,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y3,5E 4E 44 5E,
ENG05871-ENG100631,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y4,5B 59 51 5B,
ENG05871-ENG102174,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y5,70 70 8C 70,
ENG05871-ENG113993,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y6,64 64 64 64,
ENG05871-ENG115665,Gear_selector_synchronization_adaption_start_pressure_correction_factor-y7,64 64 64 64,
ENG06646,Gear_shift_module_P_taste_state,1,
ENG06644,Gear_shift_module_position_roh,4,
ENG06645,Gear_shift_module_position_roh_invers,11,
ENG06655,Gear_shift_module_reset_counter_since_erasing_DTC_memory,0,
ENG06653-ENG06673,Gear_shift_module_reset_state-Reset_status,No Error (other values does not exist),
ENG06654,Gear_shift_module_switch_off_counter_over_length_of_life,0,
ENG06656,Gear_shift_module_switch_off_counter_since_erasing_DTC_memory,0,
ENG06643,Gear_shift_module_variante,4,
ENG00878-ENG100894,H003_GangMax-Ist Gang,7,
ENG00879-ENG100894,H004_GangIst-Ist Gang,1,
ENG00880-ENG100894,H007_GangSoll-Ist Gang,1,
ENG00881-ENG100894,H008_GangVorwahl-Ist Gang,R,
ENG00882-ENG100894,H009_Notfahren_GangMax-Ist Gang,N,
ENG00883-ENG100894,H010_Notfahren_GangMin-Ist Gang,N,
ENG00884-ENG100894,H011_Notfahren_GangMaxGetrSchutz-Ist Gang,N,
ENG102399,Immobilizer_ambient_data,00 00 00 00 00 00,
ENG26900-ENG104089,Intelligent_park_assist_state-Drive readiness,No,
ENG26900-ENG31586,Intelligent_park_assist_state-GE_Status_GE_IPA,Not available,
ENG26900-ENG31605,Intelligent_park_assist_state-GSG_verfuegbar,No,
ENG26900-ENG31873,Intelligent_park_assist_state-IPA_01_E2E_unplausibel,No,
ENG26900-ENG31874,Intelligent_park_assist_state-IPA_01_Timeout,No,
ENG26900-ENG31875,Intelligent_park_assist_state-IPA_01_Wert_unplausibel,No,
ENG26900-ENG31876,Intelligent_park_assist_state-IPA_Fahrstufenwunsch,Initializing,
ENG26900-ENG31877,Intelligent_park_assist_state-IPA_relevanter_Fehler,No,
ENG26900-ENG31878,Intelligent_park_assist_state-IPA_Status_IPA_GE,Initializing,
ENG26900-ENG31932,Intelligent_park_assist_state-Letztes_P_einlegen_erfolgreich,No,
ENG26900-ENG32233,Intelligent_park_assist_state-P_Taste_betaetigt,not activated,
ENG26900-ENG32235,Intelligent_park_assist_state-Paddle_betaetigt,not activated,
ENG26900-ENG33260,Intelligent_park_assist_state-v_kleiner_Schwelle_Fahrstufenwechsel,No,
ENG26900-ENG33261,Intelligent_park_assist_state-v_kleiner_Schwelle_PiloPa_v_max,No,
ENG26900-ENG33262,Intelligent_park_assist_state-v_kleiner_Schwelle_Stillstand,No,
ENG26900-ENG33263,Intelligent_park_assist_state-v_Signal_Ersatzwert,No,
ENG26900-ENG33264,Intelligent_park_assist_state-v_Signal_intern_gebildet,No,
ENG26900-ENG33322,Intelligent_park_assist_state-Vorhalt 1,00000000 ,
ENG26900-ENG33323,Intelligent_park_assist_state-Vorhalt 2,00000000 ,
ENG26900-ENG33324,Intelligent_park_assist_state-Vorhalt 3,00000000 ,
ENG26900-ENG33325,Intelligent_park_assist_state-Vorhalt 4,00000000 ,
ENG26900-ENG33326,Intelligent_park_assist_state-Vorhalt 5,00000000 ,
ENG26900-ENG33327,Intelligent_park_assist_state-Vorhalt 6,00000000 ,
ENG26900-ENG33352,Intelligent_park_assist_state-WH_betaetigt,not activated,
ENG26900-ENG33392,Intelligent_park_assist_state-Zuendung,OFF,
ENG107135-ENG98502,J009_Akk_PKp0_def_ko[K1]-Data,3.000, bar
ENG107136-ENG98502,J010_Akk_PKp0_def_ko[K2]-Data,3.000, bar
ENG107137-ENG98502,J011_AkmPKp0Def_Msr_ko[K1]-Data,3.000, bar
ENG107138-ENG98502,J012_AkmPKp0Def_Msr_ko[K2]-Data,3.000, bar
ENG00895-ENG98502,K004_Schaltart-Data,Eco,
ENG00896-ENG98502,K009_FastOff_FlagAktiv-Data,No,
ENG00897-ENG98502,K010_FastOff_NAnHSMin-Data,0, /min
ENG00898-ENG98502,K011_TSK_NAnHSMin-Data,0, /min
ENG00899-ENG98502,K012_TSK_NAnRSMin-Data,0, /min
ENG00900-ENG98502,K013_Kurve_FlagAktiv-Data,No,
ENG00901-ENG98502,K014_Kurve_NAnHSMin-Data,0, /min
ENG00902-ENG98502,K015_Kurve_NAnRSMin-Data,0, /min
ENG00903-ENG98502,K016_SVF_FlagAktiv-Data,No,
ENG00904-ENG98502,K017_SVF_NAnHSMin-Data,0, /min
ENG00905-ENG98502,K018_SVF_NAnRSMin-Data,0, /min
ENG00906-ENG98502,K019_Vorwahl_ZustSchaltung-Data,Noch keine Prognose,
ENG00907-ENG102522,K020_StatusSchaltung-K022_Anzahl_HS,0,
ENG00907-ENG101683,K020_StatusSchaltung-K023_Anzahl_RS,0,
ENG00907-ENG101143,K020_StatusSchaltung-K024_Anzahl_bevorzuegteRS,0,
ENG00907-ENG101162,K020_StatusSchaltung-K025_Anzahl_AnfahrRS,0,
ENG107331-ENG99166,L001_Engine Coding Information-Z054_Engine_Code,69,
ENG107331-ENG103915,L001_Engine Coding Information-Z055_Transmission_Code,DL382_Allrad,
ENG107331-ENG101704,L001_Engine Coding Information-Z056_Emission_Type,no EOBD: no OBD (US),
ENG107332-ENG104007,L002_FehFehlerspeicher.0.s.FID[Fehler_0]-Error Code,Unknown (640),
ENG107333-ENG104007,L003_FehFehlerspeicher.1.s.FID[Fehler_1]-Error Code,Unknown (640),
ENG107334-ENG104007,L004_FehFehlerspeicher.2.s.FID[Fehler_2]-Error Code,Unknown (640),
ENG107335-ENG104007,L005_FehFehlerspeicher.3.s.FID[Fehler_3]-Error Code,Unknown (640),
ENG107336-ENG104007,L006_FehFehlerspeicher.4.s.FID[Fehler_4]-Error Code,Unknown (640),
ENG107337-ENG104007,L007_FehFehlerspeicher.5.s.FID[Fehler_5]-Error Code,Unknown (640),
ENG107338-ENG104007,L008_FehFehlerspeicher.6.s.FID[Fehler_6]-Error Code,Unknown (640),
ENG107339-ENG104007,L009_FehFehlerspeicher.7.s.FID[Fehler_7]-Error Code,Unknown (640),
ENG107340-ENG104007,L010_FehFehlerspeicher.8.s.FID[Fehler_8]-Error Code,Unknown (640),
ENG107341-ENG104007,L011_FehFehlerspeicher.9.s.FID[Fehler_9]-Error Code,Unknown (640),
ENG107342-ENG104007,L012_FehFehlerspeicher.10.s.FID[Fehler_10]-Error Code,Unknown (640),
ENG107343-ENG104007,L013_FehFehlerspeicher.11.s.FID[Fehler_11]-Error Code,Unknown (640),
ENG102017-ENG98502,M011_KrsZustand-Data,Selecting,
ENG100485,M012_KscZustandTSchutz,0,
ENG104077-ENG98502,M016_Svc_ABSAktiv-Data,OFF,
ENG101606-ENG98502,M017_Svc_Bremse-Data,OFF,
ENG99346-ENG98502,M018_Svc_EDSAktiv-Data,OFF,
ENG101980-ENG98502,M019_Svc_ESPAktiv-Data,OFF,
ENG107505-ENG98502,M020_Fzk_ZustHaupt-Data,Neutral,
ENG100481-ENG98502,M021_Svc_ZustKlima-Data,On,
ENG99617-ENG100068,M022_Svc_ZustStatusGRA-GRA Status,nicht verbaut / kein ACC zulässig,
ENG00916-ENG98502,M023_Zustand-Data,P,
ENG100148,M024_Svu_ZustKl15,Terminal 15 on,
ENG00917-ENG98502,M025_SFZ_FlagAktiv-Data,Undetected,
ENG107508-ENG98502,M026_Umw_NAbRichtung-Data,forwards,
ENG107510-ENG98502,M028_Akk_FlagPKp0_allg.Freigabe-Data,OFF,
ENG107511-ENG98502,M030_Vwh_FlagWh_TipInfo_FehlerStatus-Data,Error E5: Tiptronic Info wrong timing,
ENG107516-ENG103355,M035_Grd_FlagBed_VwhKal-Elektrisch Parkbremse Aus,No,
ENG107516-ENG101955,M035_Grd_FlagBed_VwhKal-Fehler Vorhanden,No,
ENG107516-ENG100526,M035_Grd_FlagBed_VwhKal-Klemme15 ist Aus,No,
ENG107516-ENG104233,M035_Grd_FlagBed_VwhKal-Motor ist nicht Aus,Yes,
ENG107516-ENG102761,M035_Grd_FlagBed_VwhKal-Temperatur Außerhalb Toleranz,No,
ENG107517-ENG98502,M036_SCM_Single_Bit_Error_Status-Data,Undetected,
ENG107524-ENG104213,M045_Grd_AbbruchCode-Abbruch Grunde,(0) GRD_KEIN_FEHLER,
ENG129679-ENG98502,M046_Grd_AnzeigeZustand-Data,(0) GRD_ZUST_HAUPT_AUS,
ENG107530,M052_Grd_Zust_Haupt,OFF,
ENG107531-ENG98502,M053_Akk_FehlerPkp0_Zust-Data,(0) Aus,
ENG107534-ENG98502,M056_Umw_SFZ_FlagErkannt-Data,No,
ENG107539-ENG98502,M061_Grd_ZustAbnahme_allg.alle-Data,Keine Routine laeuft,
ENG107540-ENG98502,M066_AopNeustart_ZustAdapt-Data,Unknown (7),
ENG107561-ENG100894,M088_GwsDat.Zustand[W1]-Ist Gang,1,
ENG107562-ENG100894,M089_GwsDat.Zustand[W2]-Ist Gang,R,
ENG129729,Manual_transmission_fluid_error_code,0,
ENG129727,Manual_transmission_fluid_pump_actual_current,1081, mA
ENG129749,Manual_transmission_fluid_pump_CALID,0CK281L 0576MTF ,
ENG129750,Manual_transmission_fluid_pump_CVN,00 00 28 4C,
ENG06648,Manual_transmission_fluid_pump_lin_communication_error_state,Test not completed,
ENG06650,Manual_transmission_fluid_pump_recieved_lin_frame_1_timeout_counter,0,
ENG06651,Manual_transmission_fluid_pump_recieved_lin_frame_2_timeout_counter,0,
ENG06652,Manual_transmission_fluid_pump_recieved_lin_frame_3_timeout_counter,0,
ENG06649,Manual_transmission_fluid_pump_sent_lin_frame_timeout_counter,0,
ENG06647,Manual_transmission_fluid_pump_state,EMC_MTF_BETRIEB,
ENG129730-ENG98502,Manual_transmission_fluid_pump_temperature-Data,42, °C
ENG129728-ENG98502,Manual_transmission_fluid_temperature_PCB-Data,200, °C
ENG06641,Multifunction_steering_wheel_tiptronic_left_error,0,
ENG06642,Multifunction_steering_wheel_tiptronic_right_error,0,
ENG125928,Occurrence_counter_over_length_of_life,255,
ENG107905-ENG130040,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 1,0.000, bar
ENG107905-ENG130041,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 2,0.180, bar
ENG107905-ENG130042,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 3,0.135, bar
ENG107905-ENG130043,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 4,0.135, bar
ENG107905-ENG130044,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 5,0.129, bar
ENG107905-ENG130045,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 6,0.140, bar
ENG107905-ENG130046,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 7,0.148, bar
ENG107905-ENG130047,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 8,0.000, bar
ENG107905-ENG130048,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 1,0.000, bar
ENG107905-ENG130049,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 2,0.097, bar
ENG107905-ENG130050,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 3,0.066, bar
ENG107905-ENG130051,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 4,0.072, bar
ENG107905-ENG130052,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 5,0.078, bar
ENG107905-ENG130053,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 6,0.091, bar
ENG107905-ENG130054,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 7,0.142, bar
ENG107905-ENG130055,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 8,0.000, bar
ENG08732-ENG98502,Parking_lock_calibrated_position_in_P-Data,84.10, %
ENG08733-ENG98502,Parking_lock_calibrated_position_not_in_P-Data,51.10, %
ENG06657-ENG06675,Parking_lock_counter_holding_verification-Counter_from_N_to_P,0,
ENG06657-ENG06677,Parking_lock_counter_holding_verification-Counter_from_P_to_N,0,
ENG06657-ENG06676,Parking_lock_counter_holding_verification-Counter_in_P,0,
ENG08728-ENG118270,Parking_lock_error_state-PbW_Fehler_01_PHM_Eingelegt,no error,
ENG08728-ENG118311,Parking_lock_error_state-PbW_Fehler_02_PHM_Ausgelegt,no error,
ENG08728-ENG09312,Parking_lock_error_state-PbW_Fehler_03_Mechanik_Einlegen,no error,
ENG08728-ENG09313,Parking_lock_error_state-PbW_Fehler_04_Mechanik_EinlegenL,no error,
ENG08728-ENG09314,Parking_lock_error_state-PbW_Fehler_05_Mechanik_Auslegen,no error,
ENG08728-ENG118295,Parking_lock_error_state-PbW_Fehler_06_PHM_Unplausibel,no error,
ENG08728-ENG118370,Parking_lock_error_state-PbW_Fehler_07_PHM_Rueckmeldung,no error,
ENG08728-ENG09317,Parking_lock_error_state-PbW_Fehler_08_SW_Unplausibel,no error,
ENG08728-ENG09318,Parking_lock_error_state-PbW_Fehler_09_SW_Unplausibel,no error,
ENG08728-ENG118352,Parking_lock_error_state-PbW_Fehler_10_PHM_Init,used,
ENG08728-ENG118396,Parking_lock_error_state-PbW_Fehler_11_PHM_Fehler,no error,
ENG08728-ENG98891,Parking_lock_error_state-Reserved,-1,
ENG08720,Parking_lock_function_state_E0,Eingelegt halten,
ENG08725,Parking_lock_function_state_E1,P_HALTEN,
ENG08726,Parking_lock_function_state_E2,Wait,
ENG08730,Parking_lock_hold_magnet_actual_position,Hold,
ENG08729,Parking_lock_hold_magnet_commanded_position,Hold,
ENG08719,Parking_lock_position_state,Parksperre_eingelegt,
ENG08727,Parking_lock_state_for_lock_function,PBW_L_INIT,
ENG129732,Pressure_sensor_1_buffer_error_count,0,
ENG129725,Pressure_sensor_1_error_code,0,
ENG129736,Pressure_sensor_1_fastchannel_crc_check_error_count,0,
ENG129723,Pressure_sensor_1_fastchannel_message_number,9236,
ENG129706,Pressure_sensor_1_received_values_correct_counter,18,
ENG129708,Pressure_sensor_1_serial_number,05 7E 01 40 00 00 00 00,
ENG129704-ENG98502,Pressure_sensor_1_temperature-Data,53, °C
ENG129734,Pressure_sensor_1_timestamp_error_count,0,
ENG129733,Pressure_sensor_2_buffer_error_count,0,
ENG129726,Pressure_sensor_2_error_code,0,
ENG129737,Pressure_sensor_2_fastchannel_crc_check_error_count,0,
ENG129724,Pressure_sensor_2_fastchannel_message_number,30373,
ENG129707,Pressure_sensor_2_received_values_correct_counter,16,
ENG129709,Pressure_sensor_2_serial_number,04 91 01 40 00 00 00 00,
ENG129705-ENG98502,Pressure_sensor_2_temperature-Data,53, °C
ENG129735,Pressure_sensor_2_timestamp_error_count,0,
ENG27077,Pressure_sensor_change_state,nicht vertauscht,
ENG129685-ENG98502,Pressure_sensor_offset_adaption_state-Data,Adaption gelaufen,
ENG108362-ENG102813,Q001_OBD Cycle And MIL State-Driving Cycle,active,
ENG108362-ENG98734,Q001_OBD Cycle And MIL State-mil,not active,
ENG108362-ENG99968,Q001_OBD Cycle And MIL State-WarmUp Cycle,not active,
ENG105258,Rear left wheel speed,0.0, km/h
ENG105257,Rear right wheel speed,0.0, km/h
ENG05895,Safety_interface_automatic_transmission_output_speed_gradient,0, 1/min/s
ENG05876,Safety_interface_automatic_transmission_shift_position,P,
ENG05906-ENG98502,Safety_interface_brake_signal_state-Data,not activated,
ENG05878-ENG05941,Safety_interface_calculated_selected_gear_nsync-Shaft_1,1,
ENG05878-ENG05942,Safety_interface_calculated_selected_gear_nsync-Shaft_2,R,
ENG05910-ENG98432,Safety_interface_can_signal_state-brakes,invalid,
ENG05910-ENG98432,Safety_interface_can_signal_state-brakes,Current,
ENG05910-ENG05935,Safety_interface_can_signal_state-NAn,Current,
ENG05910-ENG05935,Safety_interface_can_signal_state-NAn,invalid,
ENG05910-ENG05940,Safety_interface_can_signal_state-VFzg,invalid,
ENG05910-ENG05940,Safety_interface_can_signal_state-VFzg,Current,
ENG05910-ENG05936,Safety_interface_can_signal_state-VRad (front left),invalid,
ENG05910-ENG05936,Safety_interface_can_signal_state-VRad (front left),Current,
ENG05910-ENG05937,Safety_interface_can_signal_state-VRad (front right),Current,
ENG05910-ENG05937,Safety_interface_can_signal_state-VRad (front right),invalid,
ENG05910-ENG05938,Safety_interface_can_signal_state-VRad (rear left),invalid,
ENG05910-ENG05938,Safety_interface_can_signal_state-VRad (rear left),Current,
ENG05910-ENG05939,Safety_interface_can_signal_state-VRad (rear right),Current,
ENG05910-ENG05939,Safety_interface_can_signal_state-VRad (rear right),invalid,
ENG05890-ENG98502,Safety_interface_clutch_1_actual_pressure-Data,2.0, bar
ENG05891-ENG98502,Safety_interface_clutch_2_actual_pressure-Data,2.0, bar
ENG05875-ENG118109,Safety_interface_drive_position_sensor_signal_state-Sensor_1,valid,
ENG05875-ENG118110,Safety_interface_drive_position_sensor_signal_state-Sensor_2,valid,
ENG05883,Safety_interface_engine_speed,0, /min
ENG05896,Safety_interface_engine_speed_gradient,0, 1/min/s
ENG27107,Safety_interface_expected_wheel_circumference,2000,
ENG05904,Safety_interface_filtered_automatic_transmission_output_speed_negative_gradien,0, /min
ENG05899-ENG98502,Safety_interface_gear_selector_1_measured_distance-Data,9.13, mm
ENG05902-ENG98502,Safety_interface_gear_selector_2_measured_distance-Data,-9.39, mm
ENG05901-ENG98502,Safety_interface_gear_selector_3_measured_distance-Data,-0.10, mm
ENG05900-ENG98502,Safety_interface_gear_selector_4_measured_distance-Data,-0.15, mm
ENG05877-ENG05944,Safety_interface_gear_selector_signal_state-Gear_selector_1,valid,
ENG05877-ENG05945,Safety_interface_gear_selector_signal_state-Gear_selector_2,valid,
ENG05877-ENG05946,Safety_interface_gear_selector_signal_state-Gear_selector_3,valid,
ENG05877-ENG05947,Safety_interface_gear_selector_signal_state-Gear_selector_4,valid,
ENG05879-ENG05944,Safety_interface_gear_selector_speed_slowly_state-Gear_selector_1,No,
ENG05879-ENG05945,Safety_interface_gear_selector_speed_slowly_state-Gear_selector_2,No,
ENG05879-ENG05946,Safety_interface_gear_selector_speed_slowly_state-Gear_selector_3,No,
ENG05879-ENG05947,Safety_interface_gear_selector_speed_slowly_state-Gear_selector_4,No,
ENG05880-ENG02681,Safety_interface_gear_state-Gear_1,Eingespurt,
ENG05880-ENG02682,Safety_interface_gear_state-Gear_2,Neutral,
ENG05880-ENG02683,Safety_interface_gear_state-Gear_3,Neutral,
ENG05880-ENG02684,Safety_interface_gear_state-Gear_4,Neutral,
ENG05880-ENG02685,Safety_interface_gear_state-Gear_5,Neutral,
ENG05880-ENG02686,Safety_interface_gear_state-Gear_6,Neutral,
ENG05880-ENG02687,Safety_interface_gear_state-Gear_7,Neutral,
ENG05880-ENG05943,Safety_interface_gear_state-Gear_R,Eingespurt,
ENG05903-ENG98502,Safety_interface_gradient_filtered_vehicle_speed-Data,0.0, km/h
ENG08754-ENG09328,Safety_interface_holding_magnet_state-Holding Magnet State,ERROR,
ENG08755-ENG98502,Safety_interface_input_speed_sensor_1-Data,0, /min
ENG08756-ENG98502,Safety_interface_input_speed_sensor_2-Data,0, /min
ENG08753-ENG09329,Safety_interface_parking_brake_state-Parking Brake State,ERROR,
ENG08752-ENG09330,Safety_interface_parking_lock_state-Parking Lock State,selected,
ENG27108,Safety_interface_Pos_Info_status,1,
ENG27109,Safety_interface_Pos_Info_value,0,
ENG05897,Safety_interface_pressure_regulating_valve_1_actual_current,0.0, mA
ENG05888,Safety_interface_pressure_regulating_valve_1_allowed_current,1636.7, mA
ENG05898,Safety_interface_pressure_regulating_valve_2_actual_current,0.0, mA
ENG05889,Safety_interface_pressure_regulating_valve_2_allowed_current,1798.8, mA
ENG05907-ENG129639,Safety_interface_pressure_signal_state-Clutch_1,valid,
ENG05907-ENG129640,Safety_interface_pressure_signal_state-Clutch_2,valid,
ENG129742,Safety_interface_safety_controller_eeprom_prog_block_state,no error,
ENG05908-ENG05948,Safety_interface_safety_goal_error_state-Safety_goal_3_1,no error,
ENG05908-ENG05949,Safety_interface_safety_goal_error_state-Safety_goal_6,no error,
ENG05908-ENG05950,Safety_interface_safety_goal_error_state-Safety_goal_7_8,00,
ENG05884-ENG98502,Safety_interface_sensor_signal_gear_selector_1-Data,86, %
ENG05885-ENG98502,Safety_interface_sensor_signal_gear_selector_2-Data,13, %
ENG05887-ENG98502,Safety_interface_sensor_signal_gear_selector_3-Data,50, %
ENG05886-ENG98502,Safety_interface_sensor_signal_gear_selector_4-Data,49, %
ENG27110,Safety_interface_SG78_max_allowed_output_speed_gradient,64908,
ENG08757,Safety_interface_solenoid_valve_6_actual_current,0.0, mA
ENG08758,Safety_interface_solenoid_valve_6_current_before_SZ,0.0, mA
ENG08759-ENG98353,Safety_interface_solenoid_valve_6_source_unjustified_current-Adaption,No,
ENG08759-ENG09333,Safety_interface_solenoid_valve_6_source_unjustified_current-Fahr-SW,No,
ENG08759-ENG09335,Safety_interface_solenoid_valve_6_source_unjustified_current-Fehlerreaktion,No,
ENG08759-ENG09331,Safety_interface_solenoid_valve_6_source_unjustified_current-Pruefstand,No,
ENG08759-ENG09334,Safety_interface_solenoid_valve_6_source_unjustified_current-Tests,No,
ENG08759-ENG09332,Safety_interface_solenoid_valve_6_source_unjustified_current-Ventilanregung,No,
ENG05881-ENG98502,Safety_interface_vehicle_speed-Data,0.0, km/h
ENG05882-ENG98502,Safety_interface_vehicle_speed_from_wheel-Data,0.0, km/h
ENG05874-ENG05951,Safety_interface_voltage_state-Voltage_supply_1,valid,
ENG05874-ENG05952,Safety_interface_voltage_state-Voltage_supply_2,valid,
ENG05874-ENG05953,Safety_interface_voltage_state-Voltage_supply_3,valid,
ENG05874-ENG129979,Safety_interface_voltage_state-Voltage_supply_speed_sensor,valid,
ENG05892-ENG98502,Safety_interface_voltage_supply_1_for_sensors-Data,5.002, V
ENG05893-ENG98502,Safety_interface_voltage_supply_2_for_sensors-Data,5.009, V
ENG05894-ENG98502,Safety_interface_voltage_supply_3_for_sensors-Data,5.013, V
ENG122768,Scm_extended_fault_code,0,
ENG122761-ENG98502,Scm_fault_code-Data,SCM_E_NONE,
ENG38977,Scm_Fault_Code_Extend_Active,0,
ENG122765,Scm_faults_since_power_up,10 00 00 00,
ENG122766-ENG98502,Scm_persistent_safe_state-Data,SCM_NON_PERSISTENT,
ENG129741-ENG130070,SCM_PosInfo_ErrorFlag-PWM Pos Info Error Flag,stuck at ok,
ENG129740-ENG130069,SCM_PosInfo_InitFlag-PWM Pos Info Init Flag,true,
ENG129739-ENG130065,SCM_PWM_ErrorFlag-PWM GS13 Error Flag,stuck at ok,
ENG129739-ENG130066,SCM_PWM_ErrorFlag-PWM GS2R Error Flag,stuck at ok,
ENG129739-ENG130067,SCM_PWM_ErrorFlag-PWM GS46 Error Flag,stuck at ok,
ENG129739-ENG130068,SCM_PWM_ErrorFlag-PWM GS57 Error Flag,stuck at ok,
ENG129738-ENG130059,SCM_PWM_InitFlag-PWM GS13 Initflag,true,
ENG129738-ENG130060,SCM_PWM_InitFlag-PWM GS2R Initflag,true,
ENG129738-ENG130061,SCM_PWM_InitFlag-PWM GS46 Initflag,true,
ENG129738-ENG130062,SCM_PWM_InitFlag-PWM GS57 Initflag,true,
ENG129738-ENG130063,SCM_PWM_InitFlag-PWM MPIO Initflag,true,
ENG129738-ENG130064,SCM_PWM_InitFlag-PWM MTF PUMP Initflag,false,
ENG129738-ENG130057,SCM_PWM_InitFlag-PWM WHS1 Initflag,true,
ENG129738-ENG130058,SCM_PWM_InitFlag-PWM WHS2 Initflag,true,
ENG122763-ENG98502,Scm_reset_class-Data,SCM_RESET_TSBC,
ENG38980,Scm_Reset_Prrogram_Counter,00 00 00 00,
ENG122767-ENG98502,Scm_state-Data,SCM_STATE_NORMAL,
ENG38987,Scm_Task_Error_Nr,0,
ENG129717,Scm_trap_info,0,
ENG122762,Scm_warm_reset_cnt,1,
ENG122764,Scm_weight_rst_cnt,0,
ENG08731,Solenoid_valve_6_commanded_current_from_parking_lock_modul,0.0, mA
ENG129694-ENG98502,Sopc_Error_State_MC-Data,SOPC_ERR_OK,
ENG129716-ENG98502,Sopc_Nrst5_Active-Data,NRST5 nicht aktiv,
ENG129711,Sopc_SDS4_Dev1_Error,00000000 ,
ENG129712,Sopc_SDS4_Dev2_Error,00000000 ,
ENG129713,Sopc_SDS4_Dev3_Error,00000000 ,
ENG129703,Sopc_State_Diag,00001111 ,
ENG129693-ENG130019,Sopc_State_Diag_Sequence-Test_Step_1,00000000 ,
ENG129693-ENG130020,Sopc_State_Diag_Sequence-Test_Step_2,00001111 ,
ENG129693-ENG130021,Sopc_State_Diag_Sequence-Test_Step_3,00000000 ,
ENG129693-ENG130022,Sopc_State_Diag_Sequence-Test_Step_4,00001111 ,
ENG129693-ENG130023,Sopc_State_Diag_Sequence-Test_Step_5,00000000 ,
ENG129693-ENG130024,Sopc_State_Diag_Sequence-Test_Step_6,00001111 ,
ENG129693-ENG130025,Sopc_State_Diag_Sequence-Test_Step_7,00000000 ,
ENG129693-ENG130026,Sopc_State_Diag_Sequence-Test_Step_8,00001111 ,
ENG129702,Sopc_Test_Step,8,
ENG129714,Sopc_Tsbc_Diag1,00000000 00000000 00000000 00000111 ,
ENG129715,Sopc_Tsbc_Diag2,00000000 00000000 00000000 00000000 ,
ENG129710,Sopc_U_Kl30,1408,
ENG107872-ENG101695,System Supplier Boot Software Identification (BB)-System Supplier Boot Identification,0407      ,
ENG107872-ENG101202,System Supplier Boot Software Identification (BB)-System Supplier Calibration Data Identification,B9 2,0lT 185kW NAR quattro,
ENG107872-ENG101224,System Supplier Boot Software Identification (BB)-System Supplier HW Version,9  ,
ENG107872-ENG103214,System Supplier Boot Software Identification (BB)-System Supplier HW Version 2,Series,
ENG107872-ENG99311,System Supplier Boot Software Identification (BB)-System Supplier Software Identification,R8E2                                              ,
ENG00991-ENG98502,T002_FpModi-Data,0.0, %
ENG109306-ENG98502,T003_Svc_Fp-Data,0.0, %
ENG105260,Transfer speed by dash panel insert,0.00, km/h
ENG105259,Transfer speed from ESP,0.00, km/h
ENG129718,Tsbc_Report_diag_source_reg_value,00 04 00 28,
ENG129700-ENG98502,Voltage_sensor_sv1-Data,4.999, V
ENG129721-ENG98502,Voltage_supply_1_for_sensors-Data,5.0, V
ENG129722-ENG98502,Voltage_supply_2_for_sensors-Data,5.0, V
ENG129977-ENG98502,Voltage_supply_3_for_sensors-Data,5.0, V
ENG110036-ENG98502,W002_Vwh_FlagWh_PLCD1_FehlerStatus-Data,Signal OK,
ENG110038-ENG98502,W004_Vwh_FlagWh_PLCD2_FehlerStatus-Data,Signal OK,
ENG05868,XCP_communication_state,not active,
ENG110309-ENG98502,Z003_Umw_TSK_ASollMin-Data,-0.050, m/s²
ENG110311-ENG98502,Z005_Umw_TSK_AMaxGang[Gang1]-Data,1.731, m/s²
ENG01034-ENG98502,Z008_Freischau_FlagAktiv-Data,not active,
ENG110314-ENG98502,Z009_Umw_TSK_AMaxGang[Gang2]-Data,1.138, m/s²
ENG01035-ENG98502,Z010_Bergab_FlagAktiv-Data,not active,
ENG110316-ENG98502,Z011_Umw_TSK_AMaxGang[Gang3]-Data,0.737, m/s²
ENG110317-ENG98502,Z012_Umw_TSK_AMaxGang[Gang4]-Data,0.462, m/s²
ENG01036-ENG98502,Z013_RDLock_FlagAktiv-Data,No Detection,
ENG110319-ENG98502,Z014_Umw_TSK_AMaxGang[Gang5]-Data,0.272, m/s²
ENG110321-ENG98502,Z016_Umw_TSK_AMaxGang[Gang6]-Data,0.134, m/s²
ENG110322-ENG98502,Z017_Umw_TSK_AMaxGang[Gang7]-Data,0.062, m/s²
ENG110323-ENG98502,Z018_Umw_TSK_ASollMax-Data,0.150, m/s²
ENG110324-ENG98502,Z021_UmwKurvenRadius-Data,10000, m
ENG110325-ENG98502,Z024_UmwAnhaenger_vorhanden-Data,No,
ENG110327,Z027_UmwMadAnzahl,0,
ENG110329-ENG98502,Z030_UmwMasseLast-Data,0, kg
ENG110330,Z031_Umw_MAbtrieb_Zustand,invalid,
ENG01037-ENG98502,Z039_ZwangsSchaltung-Data,No,
ENG01038-ENG98502,Z042_TipSignalMinusAktiv-Data,not active,
ENG01039-ENG98502,Z043_TipSignalPlusAktiv-Data,not active,
ENG01040-ENG98502,Z044_TipbeiKD-Data,No,
ENG110337-ENG98502,Z045_UmwRadradius-Data,316, mm
ENG110338-ENG98502,Z046_UmwStrasseErkannt-Data,Unknown (255),
ENG101517-ENG98502,Z047_Umw_PrzNeig-Data,0.0, %
ENG110339-ENG98502,Z048_Ftp_PrzFtp-Data,0, %
ENG110340-ENG98502,Z052_Akk_FehlerPkp0_Welle-Data,(0) Welle1,
ENG110342-ENG98502,Z057_NsyUebGang[1]-Data,13.605,
ENG110343-ENG98502,Z058_NsyUebGang[2]-Data,9.349,
ENG110344-ENG98502,Z059_NsyUebGang[3]-Data,6.476,
ENG110345-ENG98502,Z060_NsyUebGang[4]-Data,4.512,
ENG110346-ENG98502,Z061_NsyUebGang[5]-Data,3.150,
ENG110347-ENG98502,Z062_NsyUebGang[6]-Data,2.164,
ENG110348-ENG98502,Z063_NsyUebGang[7]-Data,1.643,
ENG110349-ENG98502,Z064_NsyUebGang[N]-Data,1.000,
ENG110350-ENG98502,Z065_NsyUebGang[R]-Data,11.739,
ENG110352-ENG98502,Z067_Vwh_TWh_AbbruchZeit-Data,10000, ms
ENG110353-ENG98502,Z069_Akk_Tadap_PKp0[K1]-Data,0, ms
ENG110354-ENG98502,Z070_Akk_Tadap_PKp0[K2]-Data,0, ms
ENG01041-ENG98502,Z100_Notfahren_FlagAktiv-Data,not active,
Elapsed Time: 01:28
adpmap-02-8W2-927-155-BA
;SW:8W2-927-155-BA   HW:0CJ-927-156 ---  Auto Trans
;Component:0CL 20TFSINAR H05 0001, Coding:000001
;EV_TCMDL382021,002027,EV_TCMDL382021_AU49.rod
;Sunday,10,November,2019,20:31:27:01617
;VCID: 81458642100FDB4728-80D4
IDE01761-Distance data,active ,1
IDE02861-Mechatronic identification,0CK325026AA0CK325031APE5C08K0568180220 ,38
IDE02862-Production data transmission,006TBRC020746K180220 ,20
IDE04111-Single gear display,Default ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE05306-Write/reset automatic start counter,1 ,2
IDE09374-Oil pressure reservoir emptying,OFF ,1
ENG106098-ENG99811-Activation points_GS13-Einsatzpunkte_GS_neg,649.0 mA,4
ENG106098-ENG101455-Activation points_GS13-Einsatzpunkte_GS_pos,831.0 mA,4
ENG106099-ENG99811-Activation points_GS2R-Einsatzpunkte_GS_neg,653.0 mA,4
ENG106099-ENG101455-Activation points_GS2R-Einsatzpunkte_GS_pos,827.0 mA,4
ENG106100-ENG99811-Activation points_GS46-Einsatzpunkte_GS_neg,642.0 mA,4
ENG106100-ENG101455-Activation points_GS46-Einsatzpunkte_GS_pos,834.0 mA,4
ENG169905-Ak0a_EepromData_PK0_Ist_PKP1,6.500 bar,2
ENG169906-Ak0a_EepromData_PK0_Soll_PKP1,6.500 bar,2
ENG169908-Ak0k_EepromData_PK0_Ist_PKP0,4.100 bar,2
ENG169909-Ak0k_EepromData_PK0_Soll_PKP0,4.200 bar,2
ENG129676-ENG98345-ATF_motor_speed_requirement-Activation,keine Vorgabe ,3
ENG129676-ENG129929-ATF_motor_speed_requirement-Motor Speed Requirement,0 /min,3
ENG129673-ENG98353-ATFMotor_Winkelsensor_Adaption-Adaption,not active ,2
ENG129673-ENG98502-ATFMotor_Winkelsensor_Adaption-Data,0 ,2
ENG129677-Dither_amplitude_management,not active ,1
ENG105999-E003_Akk_PKupAkt_PKp0[K1],2.679 bar,2
ENG106000-E004_Akk_PKupAkt_PKp0[K2],3.092 bar,2
ENG99685-E010_Akk_kl[K1].PKp0,2.750 bar,2
ENG103532-E011_Akk_kl[K2].PKp0,3.227 bar,2
ENG125931-ECU_W,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,188
ENG139903-ENG99811-Einsatzpunkte_GS57-Einsatzpunkte_GS_neg,669.0 mA,4
ENG139903-ENG101455-Einsatzpunkte_GS57-Einsatzpunkte_GS_pos,844.0 mA,4
ENG129674-ENG129930-Externe_Wertevorgabe_aktivieren-Externe Wertevorgabe aktivieren,not active ,2
ENG129674-ENG129931-Externe_Wertevorgabe_aktivieren-Vorgabe TATF,Einlesen interner Tatf aktiv ,2
ENG106748-ENG104158-Gangvorgabe_Eingangswelle-Eingangswelle,Welle 1 ,2
ENG106748-ENG98913-Gangvorgabe_Eingangswelle-Sollgang,keine Vorgabe ,2
ENG129675-ENG98569-Getriebe_adaption-Function,0 ,6
ENG129675-ENG129932-Getriebe_adaption-Kalibrierungsart,0 ,6
ENG129675-ENG98840-Getriebe_adaption-Parameter 3,0.0 ,6
ENG106779-ENG100014-Getriebe_spezifische_Uebersetzungen-Daten_Erkennungs_Version,Version 1 ,17
ENG106779-ENG129933-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 1,13.610 ,17
ENG106779-ENG129934-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 2,9.353 ,17
ENG106779-ENG129935-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 3,6.478 ,17
ENG106779-ENG129936-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 4,4.514 ,17
ENG106779-ENG129937-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 5,3.151 ,17
ENG106779-ENG129938-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 6,2.169 ,17
ENG106779-ENG129939-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 7,1.647 ,17
ENG106779-ENG129940-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang R,11.742 ,17
ENG107510-M028_Akk_FlagPKp0_allg.Freigabe,OFF ,1
ENG109348-TCM_VMS,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 ,16
ENG153985-ENG154944-VKU_Ablage_Mittelposition-ATF_Motordrehzahl,3000 /min,9
ENG153985-ENG154945-VKU_Ablage_Mittelposition-ATF_Temperatur,59 °C,9
ENG153985-ENG155134-VKU_Ablage_Mittelposition-Herkunft,UDS-Vorgabe ,9
ENG153985-ENG155352-VKU_Ablage_Mittelposition-Mittelposition_fallend,746 mA,9
ENG153985-ENG155353-VKU_Ablage_Mittelposition-Mittelposition_steigend,772 mA,9
ENG153985-ENG155997-VKU_Ablage_Mittelposition-VSL_Position,charge ,9
ENG109987-Vorgabe_Reset,No Reset ,1
ENG109988-ENG98569-Vorgabe_Solldruck-Function,VKP1 ,4
ENG109988-ENG103310-Vorgabe_Solldruck-Solldruck,0.000 bar,4
ENG109988-ENG130056-Vorgabe_Solldruck-Vorgabeart,keine Vorgabe ,4
ENG109989-ENG98914-Vorgabe_Ventilstrom-Specified value,0.0 mA,4
ENG109989-ENG102564-Vorgabe_Ventilstrom-Ventil,VKP1 ,4
ENG109989-ENG100360-Vorgabe_Ventilstrom-Vorgabetyp,keine Vorgabe ,4
ENG110352-Z067_Vwh_TWh_AbbruchZeit,10000 ms,2
Elapsed Time: 00:13
Address [03]
blockmap-03-8W0-907-379-K
;SW:8W0-907-379-K   HW:8W0-907-379-J ---  ABS Brakes
;Component:ESP9 Plus     H10 0766, Coding:18AA409928A60A9D11A6489A00855292E4259A180214508812004A4927A459
;EV_ESP9BOSCHCMP,002013,EV_ESP9BOSCHCMP_002.rod
;Sunday,10,November,2019,20:31:43:01617
;VCID: CDDD6A729CD7CF279C-8098
Group,Description,Actual
IDE00019,Voltage terminal 30,13.516, V
IDE00020-MAS06489,Terminal 15 status-Terminal 15 signal,On,
IDE00020-MAS06490,Terminal 15 status-Terminal 15 load,On,
IDE00021,Engine speed,798, /min
IDE00025,Coolant temperature,108, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00078,Time since engine start,798, s
IDE00085,Normed load value,14.1, %
IDE00086,Accelerator position,15, %
IDE00097,OBD - requirements for which this vehicle is designed,None,
IDE00100,Engine torque,-1, Nm
IDE00150-MAS00102,Pressure in brake booster-valid,-982.13, mbar
IDE00322,Status of basic setting,Basic setting not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00326,Steering wheel angle,-316.74, °
IDE00445-MAS01759,Unlearning counter according OBD-OBD unlearning counter,FF,
IDE00556,Outside air temperature,27, °C
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00611,Malfunction that has caused the ambient data to be stored,P0000,
IDE00920,Front left wheel speed,0.00, km/h
IDE00921,Front right wheel speed,0.00, km/h
IDE00922,Left rear wheel speed,0.00, km/h
IDE00923,Right rear wheel speed,0.00, km/h
IDE01285,Counter of component protection malfunctions,00 00,
IDE01985-MAS06854,FAZIT identification test sum-Version,81,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,D8 FF EE E7,
IDE02211-MAS03714,Brake pressure-Left front wheel,not installed,
IDE02211-MAS03716,Brake pressure-Left rear wheel,not installed,
IDE02211-MAS09170,Brake pressure-Brake pressure sensor 1,-0.000, bar
IDE02239,Rotation rate sensor 1,0.00, rad/s
IDE02241,Lateral acceleration sensor 1,-0.19, m/s²
IDE02243,Rotation rate sensor 2,0.00, rad/s
IDE02245,Lateral acceleration sensor 2,0.00, m/s²
IDE02305,ESP brake application information,not activated,
IDE02308,ESP button status,not activated,
IDE02309,Valve relay status,passive,
IDE02310,Status of return pump,passive,
IDE02311-MAS12079,Left front wheel speed sensor installation position-Signal amplitude,0,
IDE02311-MAS12080,Left front wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02311-MAS12081,Left front wheel speed sensor installation position-Current air gap: status,OK,
IDE02311-MAS12082,Left front wheel speed sensor installation position-Average air gap: status,OK,
IDE02312-MAS12079,Right front wheel speed sensor installation position-Signal amplitude,0,
IDE02312-MAS12080,Right front wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02312-MAS12081,Right front wheel speed sensor installation position-Current air gap: status,OK,
IDE02312-MAS12082,Right front wheel speed sensor installation position-Average air gap: status,OK,
IDE02313-MAS12079,Left rear wheel speed sensor installation position-Signal amplitude,0,
IDE02313-MAS12080,Left rear wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02313-MAS12081,Left rear wheel speed sensor installation position-Current air gap: status,OK,
IDE02313-MAS12082,Left rear wheel speed sensor installation position-Average air gap: status,OK,
IDE02314-MAS12079,Right rear wheel speed sensor installation position-Signal amplitude,0,
IDE02314-MAS12080,Right rear wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02314-MAS12081,Right rear wheel speed sensor installation position-Current air gap: status,OK,
IDE02314-MAS12082,Right rear wheel speed sensor installation position-Average air gap: status,OK,
IDE02315,Direction of rotation front left wheel speed sensor,invalid,
IDE02316,Direction of rotation front right wheel speed sensor,invalid,
IDE02317,Direction of rotation rear left wheel speed sensor,invalid,
IDE02318,Direction of rotation rear right wheel speed sensor,invalid,
IDE02319-MAS02149,Hill start assistant signals-Hillside power take-off torque high wheel limit crawl torque,passive,
IDE02319-MAS02150,Hill start assistant signals-Engine torque high hillside power take-off torque,passive,
IDE02319-MAS02151,Hill start assistant signals-Q bit: incline angle EPB,passive,
IDE02319-MAS02153,Hill start assistant signals-Q bit EPB clutch pedal travel,active,
IDE02319-MAS02154,Hill start assistant signals-Q bit EPB switch position,passive,
IDE02319-MAS02155,Hill start assistant signals-EPB error status,passive,
IDE02486,Data logger triggering,not active,
IDE02538,Longitudinal acceleration sensor,0.00, m/s²
IDE02611-MAS02964,Incline angle of parking brake-Angle value,0.00, %
IDE02611-MAS09580,Incline angle of parking brake-Sensor status,valid value,
IDE02612-MAS01849,Parking brake tensioning force attained-Left,14100, N
IDE02612-MAS01850,Parking brake tensioning force attained-Right,14100, N
IDE02613,Status of parking brake button,Not operated,
IDE02626,Coding dynamic steering in ESP,Not coded,
IDE02656-MAS00128,System condition of parking brake-Distance Regulation,not coded/not installed,
IDE02656-MAS01090,System condition of parking brake-Transmission,automatic,
IDE02656-MAS02575,System condition of parking brake-Start of operations,performed,
IDE02656-MAS02665,System condition of parking brake-Automatic closing at button malfunction,active,
IDE02656-MAS02666,System condition of parking brake-Seat belt buckle scan,active,
IDE02656-MAS02669,System condition of parking brake-Automatic closing with engine off (key),not active,
IDE02656-MAS02670,System condition of parking brake-Gradual release of brake,not active,
IDE02656-MAS02672,System condition of parking brake-Start-stop,active,
IDE02656-MAS12067,System condition of parking brake-After automatic closing of the parking brake,Extended driver presence recognition,
IDE02656-MAS12068,System condition of parking brake-After manual closing of the parking brake,Driver side door contact and belt switch,
IDE02659-MAS01849,Parking brake status-Left,closed,
IDE02659-MAS01850,Parking brake status-Right,closed,
IDE03008-MAS04511,Stop process prevented-Skidding vehicle detected,not active,
IDE03008-MAS04512,Stop process prevented-Hard deceleration to standstill,not active,
IDE03008-MAS04513,Stop process prevented-Brake control module pump operation,not active,
IDE03008-MAS04514,Stop process prevented-Button for hill descent assist operated,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03008-MAS04516,Stop process prevented-ASR and ESP button operated,not active,
IDE03008-MAS04594,Stop process prevented-Road surface incline too high,not active,
IDE03010-MAS04511,Number of prevented stop processes-Skidding vehicle detected,0,
IDE03010-MAS04512,Number of prevented stop processes-Hard deceleration to standstill,1,
IDE03010-MAS04513,Number of prevented stop processes-Brake control module pump operation,0,
IDE03010-MAS04514,Number of prevented stop processes-Button for hill descent assist operated,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS04516,Number of prevented stop processes-ASR and ESP button operated,3,
IDE03010-MAS04594,Number of prevented stop processes-Road surface incline too high,14,
IDE03011-MAS04511,Number of requested start processes-Skidding vehicle detected,0,
IDE03011-MAS04514,Number of requested start processes-Button for hill descent assist operated,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03011-MAS04516,Number of requested start processes-ASR and ESP button operated,3,
IDE03315-MAS01000,Warnings-Warning text,4,
IDE03315-MAS01911,Warnings-Tone sensor,OFF,
IDE03315-MAS02590,Warnings-Red warning light,OFF,
IDE03315-MAS02591,Warnings-Yellow warning light,On,
IDE03315-MAS02592,Warnings-Red operating lamp,OFF,
IDE03315-MAS02593,Warnings-Green operating lamp,OFF,
IDE03315-MAS02594,Warnings-Indicator light in switch,OFF,
IDE03316-MAS02595,Deceleration: setpoint-Deceleration,0.00, m/s²
IDE03317,Transmission range gear recognition switch,Neutral,
IDE03491,Hydraulic pump run-on time,0, ms
IDE03493-MAS11867,Driver door status-Driver door status: qualification,no error,
IDE03493,Driver door status,closed,
IDE03680-MAS12015,Supply voltages-Terminal 30 for electronics,13.10, V
IDE03680-MAS12064,Supply voltages-Return pump,13.18, V
IDE03680-MAS12065,Supply voltages-ABS valves,13.18, V
IDE04253,Sys status of tire press monitoring display,5F 20,
IDE04451-IDE02763,Tire press monitoring display indictor lamp-System malfunction lamp: status,passive,
IDE04451-IDE02765,Tire press monitoring display indictor lamp-Pressure warning lamp: status,passive,
IDE04604-MAS02472,Accelerator pedal travel-Qualification bit,OFF,
IDE04604,Accelerator pedal travel,0.00, %
IDE05712,AUTO HOLD,Initialization/not installed,
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,10,
IDE06307-MAS00108,Stop prevention history data-Day,22,
IDE06307-MAS00109,Stop prevention history data-Hours,18,
IDE06307-MAS00110,Stop prevention history data-Minutes,36,
IDE06307-MAS00111,Stop prevention history data-Seconds,31,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Hard deceleration to standstill,
IDE06308-MAS00106,Start request history data-Year,2019,
IDE06308-MAS00107,Start request history data-Month,1,
IDE06308-MAS00108,Start request history data-Day,29,
IDE06308-MAS00109,Start request history data-Hours,18,
IDE06308-MAS00110,Start request history data-Minutes,39,
IDE06308-MAS00111,Start request history data-Seconds,52,
IDE06308,Start request history data,not active,
IDE06308,Start request history data,ASR and ESP button operated,
IDE06425-MAS02832,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06752,Hill descent control button,Initialization/not installed,
IDE06921-MAS02472,Calculated vehicle speed-Qualification bit,OFF,
IDE06921,Calculated vehicle speed,0.00, km/h
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,09,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,Not Used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE07905-MAS11308,Brake light switch status-"Driver braking" information from brake electronics,not activated,
IDE07905-MAS11309,Brake light switch status-"Driver braking" information from brake booster,not activated,
IDE07905-MAS11310,Brake light switch status-"Driver braking" information from brake electronics: qualif.,valid,
IDE07905-MAS11311,Brake light switch status-"Driver braking" information from brake booster: qualif.,valid,
IDE08343,Immobilizer Challenge,FA 5F BB CB,
IDE08623,OBD configuration,NO OBD,
IDE09285,Reason for tire monitoring warning,No warning display on,
IDE09286,Software version of tire monitoring display,R1409j,
IDE09287,Param. set version tire press monitoring display,BN1G,
IDE09288,Param. set tire press monitor display: checksum,E8 42 2D 94 E6 C4 A4 75,
IDE09289,Tire press monitor.display: diagnosis status,00 00 00 00,
IDE09580-MAS09177,RPM sensor: air gap-Left front: med. value,00,
IDE09580-MAS09178,RPM sensor: air gap-Left front: minimum,00,
IDE09580-MAS09179,RPM sensor: air gap-Left front: maximum,00,
IDE09580-MAS09180,RPM sensor: air gap-Right front: med. value,00,
IDE09580-MAS09181,RPM sensor: air gap-Right front: minimum,00,
IDE09580-MAS09182,RPM sensor: air gap-Right front: maximum,00,
IDE09580-MAS09183,RPM sensor: air gap-Left rear: med. value,00,
IDE09580-MAS09184,RPM sensor: air gap-Left rear: minimum,00,
IDE09580-MAS09185,RPM sensor: air gap-Left rear: maximum,00,
IDE09580-MAS09186,RPM sensor: air gap-Right rear: med. value,00,
IDE09580-MAS09187,RPM sensor: air gap-Right rear: minimum,00,
IDE09580-MAS09188,RPM sensor: air gap-Right rear: maximum,00,
IDE09581-MAS01853,RPM sensor: configuration-Left front,Sensor with rotation direction detection,
IDE09581-MAS01854,RPM sensor: configuration-Right front,Sensor with rotation direction detection,
IDE09581-MAS01855,RPM sensor: configuration-Left rear,Sensor with rotation direction detection,
IDE09581-MAS01856,RPM sensor: configuration-Right rear,Sensor with rotation direction detection,
IDE09581-MAS12016,RPM sensor: configuration-Front axle: number of terminals,48,
IDE09581-MAS12017,RPM sensor: configuration-Rear axle: number of terminals,48,
IDE10034-MAS01853,RPM sensor: overall wiring fault-Left front,0.00, %
IDE10034-MAS01854,RPM sensor: overall wiring fault-Right front,0.00, %
IDE10034-MAS01855,RPM sensor: overall wiring fault-Left rear,0.00, %
IDE10034-MAS01856,RPM sensor: overall wiring fault-Right rear,0.00, %
IDE10034-MAS09178,RPM sensor: overall wiring fault-Left front: minimum,0.00, %
IDE10034-MAS09179,RPM sensor: overall wiring fault-Left front: maximum,0.00, %
IDE10034-MAS09181,RPM sensor: overall wiring fault-Right front: minimum,0.00, %
IDE10034-MAS09182,RPM sensor: overall wiring fault-Right front: maximum,0.00, %
IDE10034-MAS09184,RPM sensor: overall wiring fault-Left rear: minimum,0.00, %
IDE10034-MAS09185,RPM sensor: overall wiring fault-Left rear: maximum,0.00, %
IDE10034-MAS09187,RPM sensor: overall wiring fault-Right rear: minimum,0.00, %
IDE10034-MAS09188,RPM sensor: overall wiring fault-Right rear: maximum,0.00, %
IDE10035-MAS09177,RPM sensor: single separation fault-Left front: med. value,0.00, µs
IDE10035-MAS09178,RPM sensor: single separation fault-Left front: minimum,0.00, %
IDE10035-MAS09179,RPM sensor: single separation fault-Left front: maximum,0.00, %
IDE10035-MAS09180,RPM sensor: single separation fault-Right front: med. value,0.00, µs
IDE10035-MAS09181,RPM sensor: single separation fault-Right front: minimum,0.00, %
IDE10035-MAS09182,RPM sensor: single separation fault-Right front: maximum,0.00, %
IDE10035-MAS09183,RPM sensor: single separation fault-Left rear: med. value,0.00, µs
IDE10035-MAS09184,RPM sensor: single separation fault-Left rear: minimum,0.00, %
IDE10035-MAS09185,RPM sensor: single separation fault-Left rear: maximum,0.00, %
IDE10035-MAS09186,RPM sensor: single separation fault-Right rear: med. value,0.00, µs
IDE10035-MAS09187,RPM sensor: single separation fault-Right rear: minimum,0.00, %
IDE10035-MAS09188,RPM sensor: single separation fault-Right rear: maximum,0.00, %
IDE10348,Trip distance data,32 00 00 00 00 00 00 00 00 00 03 00 00 00 00 57 41 55 45 4E 41 46 34 37 4A 41 31 34 37 38 39 38 8C 5D C3 0A 1C 14 23 6E 00 06 00 02 00 F2 7E 00,
IDE10372-MAS00102,Brake booster vacuum sensor 2-valid,Not coded,
IDE10667-MAS01447,Driving program for brake electronics-Act.val.,2,
IDE10667-MAS01448,Driving program for brake electronics-Specified value,0,
IDE10667-MAS05631,Driving program for brake electronics-System status,Available,
IDE10787-MAS00106,Tire press. monitoring sys.: last warning-Year,2019, yr
IDE10787-MAS00107,Tire press. monitoring sys.: last warning-Month,11, mon
IDE10787-MAS00108,Tire press. monitoring sys.: last warning-Day,4, d
IDE10787-MAS00109,Tire press. monitoring sys.: last warning-Hours,13, H
IDE10787-MAS00110,Tire press. monitoring sys.: last warning-Minutes,11, min
IDE10787-MAS00711,Tire press. monitoring sys.: last warning-Odometer reading,32039, km
IDE10787-MAS02832,Tire press. monitoring sys.: last warning-Malfunction status,07 0B 00 00,
IDE10788-MAS00106,Tire press. monitoring sys.: second last warning-Year,2019, yr
IDE10788-MAS00107,Tire press. monitoring sys.: second last warning-Month,4, mon
IDE10788-MAS00108,Tire press. monitoring sys.: second last warning-Day,18, d
IDE10788-MAS00109,Tire press. monitoring sys.: second last warning-Hours,8, H
IDE10788-MAS00110,Tire press. monitoring sys.: second last warning-Minutes,4, min
IDE10788-MAS00711,Tire press. monitoring sys.: second last warning-Odometer reading,15399, km
IDE10788-MAS02832,Tire press. monitoring sys.: second last warning-Malfunction status,06 04 00 00,
IDE10789-MAS00106,Tire press. monitoring sys.: third last warning-Year,2019, yr
IDE10789-MAS00107,Tire press. monitoring sys.: third last warning-Month,1, mon
IDE10789-MAS00108,Tire press. monitoring sys.: third last warning-Day,25, d
IDE10789-MAS00109,Tire press. monitoring sys.: third last warning-Hours,8, H
IDE10789-MAS00110,Tire press. monitoring sys.: third last warning-Minutes,12, min
IDE10789-MAS00711,Tire press. monitoring sys.: third last warning-Odometer reading,8280, km
IDE10789-MAS02832,Tire press. monitoring sys.: third last warning-Malfunction status,06 78 00 00,
IDE10790-MAS00106,Tire press. monitoring sys.: fourth last warning-Year,2018, yr
IDE10790-MAS00107,Tire press. monitoring sys.: fourth last warning-Month,3, mon
IDE10790-MAS00108,Tire press. monitoring sys.: fourth last warning-Day,1, d
IDE10790-MAS00109,Tire press. monitoring sys.: fourth last warning-Hours,21, H
IDE10790-MAS00110,Tire press. monitoring sys.: fourth last warning-Minutes,36, min
IDE10790-MAS00711,Tire press. monitoring sys.: fourth last warning-Odometer reading,0, km
IDE10790-MAS02832,Tire press. monitoring sys.: fourth last warning-Malfunction status,03 06 00 00,
IDE10791-MAS00106,Tire press. monitoring sys.: fifth last warning-Year,2018, yr
IDE10791-MAS00107,Tire press. monitoring sys.: fifth last warning-Month,3, mon
IDE10791-MAS00108,Tire press. monitoring sys.: fifth last warning-Day,1, d
IDE10791-MAS00109,Tire press. monitoring sys.: fifth last warning-Hours,21, H
IDE10791-MAS00110,Tire press. monitoring sys.: fifth last warning-Minutes,18, min
IDE10791-MAS00711,Tire press. monitoring sys.: fifth last warning-Odometer reading,0, km
IDE10791-MAS02832,Tire press. monitoring sys.: fifth last warning-Malfunction status,03 06 00 00,
IDE10792-MAS00106,Tire press. monitoring sys.: last calibration-Year,2019, yr
IDE10792-MAS00107,Tire press. monitoring sys.: last calibration-Month,11, mon
IDE10792-MAS00108,Tire press. monitoring sys.: last calibration-Day,4, d
IDE10792-MAS00109,Tire press. monitoring sys.: last calibration-Hours,14, H
IDE10792-MAS00110,Tire press. monitoring sys.: last calibration-Minutes,4, min
IDE10792-MAS00711,Tire press. monitoring sys.: last calibration-Odometer reading,32061, km
IDE10792-MAS02201,Tire press. monitoring sys.: last calibration-Temperature,30, °C
IDE10793-MAS00106,Tire press. monitoring sys.: second last calibration-Year,2019, yr
IDE10793-MAS00107,Tire press. monitoring sys.: second last calibration-Month,9, mon
IDE10793-MAS00108,Tire press. monitoring sys.: second last calibration-Day,3, d
IDE10793-MAS00109,Tire press. monitoring sys.: second last calibration-Hours,14, H
IDE10793-MAS00110,Tire press. monitoring sys.: second last calibration-Minutes,9, min
IDE10793-MAS00711,Tire press. monitoring sys.: second last calibration-Odometer reading,25751, km
IDE10793-MAS02201,Tire press. monitoring sys.: second last calibration-Temperature,27, °C
IDE10794-MAS00106,Tire press. monitoring sys.: third last calibration-Year,2019, yr
IDE10794-MAS00107,Tire press. monitoring sys.: third last calibration-Month,4, mon
IDE10794-MAS00108,Tire press. monitoring sys.: third last calibration-Day,18, d
IDE10794-MAS00109,Tire press. monitoring sys.: third last calibration-Hours,8, H
IDE10794-MAS00110,Tire press. monitoring sys.: third last calibration-Minutes,53, min
IDE10794-MAS00711,Tire press. monitoring sys.: third last calibration-Odometer reading,15433, km
IDE10794-MAS02201,Tire press. monitoring sys.: third last calibration-Temperature,27, °C
IDE10795-MAS00106,Tire press. monitoring sys.: fourth last calibration-Year,2019, yr
IDE10795-MAS00107,Tire press. monitoring sys.: fourth last calibration-Month,1, mon
IDE10795-MAS00108,Tire press. monitoring sys.: fourth last calibration-Day,25, d
IDE10795-MAS00109,Tire press. monitoring sys.: fourth last calibration-Hours,10, H
IDE10795-MAS00110,Tire press. monitoring sys.: fourth last calibration-Minutes,31, min
IDE10795-MAS00711,Tire press. monitoring sys.: fourth last calibration-Odometer reading,8311, km
IDE10795-MAS02201,Tire press. monitoring sys.: fourth last calibration-Temperature,18, °C
IDE10796-MAS00106,Tire press. monitoring sys.: fifth last calibration-Year,2018, yr
IDE10796-MAS00107,Tire press. monitoring sys.: fifth last calibration-Month,8, mon
IDE10796-MAS00108,Tire press. monitoring sys.: fifth last calibration-Day,22, d
IDE10796-MAS00109,Tire press. monitoring sys.: fifth last calibration-Hours,15, H
IDE10796-MAS00110,Tire press. monitoring sys.: fifth last calibration-Minutes,20, min
IDE10796-MAS00711,Tire press. monitoring sys.: fifth last calibration-Odometer reading,15, km
IDE10796-MAS02201,Tire press. monitoring sys.: fifth last calibration-Temperature,30, °C
IDE11037,Brake light switch: qualification,active,
IDE11039,Tire pr.monit.sys.: counter for fast press. loss: le. frt,255,
IDE11040,Tire pr.monit.sys.: counter for fast pres.loss: ri. frt.,255,
IDE11041,Tire pr.monit.sys.:counter for fast press. loss: le. rr.,255,
IDE11042,Tire pr.monit.sys.: counter for fast press. loss: ri. rr.,255,
IDE11043,Tire pr.monit.sys.: counter for slow press. loss: le. frt,254,
IDE11044,Tire pr.monit.sys.: counter for slow press. loss: ri. frt.,254,
IDE11045,Tire pr.monit.sys.: counter for slow press. loss: le. rr.,255,
IDE11046,Tire pr.monit.sys.: counter for slow press. loss: ri. rr.,255,
IDE11053-MAS00179,Brake light switch: signal from engine ctrl. mod.-Brake Light Switch,Brake not actuated,
IDE11053-MAS12083,Brake light switch: signal from engine ctrl. mod.-"Driver braking" signal,not activated,
IDE11053-MAS12084,Brake light switch: signal from engine ctrl. mod.-"Driver braking" signal: qualification,valid,
IDE11053-MAS12085,Brake light switch: signal from engine ctrl. mod.-Brake pedal information: plausibility,plausible,
IDE80100,Analysis 100,0F 00 45 53 50 39 41 75 64 69 4D 4C 42 65 76 6F 01 00 55 AA 00 00 00 00 00 00 46 4C 4D 39 01 B9 B8 9E 01 F2 30 0A 00 01 66 D6 00 00 95 96 00 00 19 41 00 00 01 52 00 00 18 98 00 00 00 00 00 30 FC 9D 00 00 03 8C 00 84 8E E5 00 47 62 00 00 50 29 5A 00 01 3A BF 00 00 00 57 00 00 00 00 00 00 00 00 00 00 01 77 00 00 00 00 00 00 00 00 00 00 B5 E2 00 00 00 00 00 00 00 00 4A 4C 41 52 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 09 DF 00 00 00 00 00 04 9D F9 00 88 C8 37 00 23 F8 E3 00 1C A2 DB 00 18 DC 74 00 2E F2 B6 00 41 CA 01 00 49 22 5C 00 17 B2 C5 00 01 48 46 00 00 00 1E 00 00 00 24 00 00 01 56 00 00 1C 2A 00 00 9C 71 00 04 1B 2A 00 10 E5 AE 00 3B F0 31 01 1B 46 FA 00 37 56 8C 00 11 74 9E 00 03 52 87 00 00 87 0E 00 00 1C EA 00 00 04 DD 01 A8 F4 F6 00 0B E3 39 00 03 BC 93 00 01 1C B1 00 00 07 1A 00 00 00 11 00 00 02 AE 00 00 04 7A 00 00 02 13 00 00 00 D1 00 00 00 22 00 00 00 95 00 00 00 00 00 00 00 00 52 4F 54 48 00 00 00 00 00 02 28 B6 00 00 00 00 00 00 09 81 00 00 00 00 00 00 03 23 00 00 00 00 00 00 05 F8 00 00 00 00 00 00 00 33 00 00 00 E0 56 30 01 00 10 3F 00 00 00 00 00 0E 00 03 00 11 00 0A 01 F0 03 C2 00 0F 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6C 00 00 00 01 00 00 00 00 00 00 00 00 00 24 00 C2 00 02 00 3A 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 08 00 00 00 00 00 00 00 00 00 00 00 1B 00 00 00 00 00 00 00 00 00 00 00 00 00 65 00 00 00 00 02 72 00 00 44 44 00 04 00 13 00 14 00 03 03 76 01 5B 01 57 01 3B 00 FF 00 79 00 17 00 02 00 53 00 48 00 00 00 00 00 00 00 00 00 00 00 0D 00 8C 04 F3 02 A9 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B AB 02 98 00 00 00 00 00 03 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 23 00 01 00 00 02 2C 00 33 00 10 00 02 00 01 00 00 01 A1 04 01 00 5C 00 02 00 00 00 00 00 13 00 00 00 00 00 00 00 00 0A 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 44 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 3A 79 00 00 00 00 19 97 00 00 00 00 25 CF 00 00 00 00 0A 5A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 01 00 00 00 44 00 00 00 00 00 00 00 00 00 00 44 00 00 D8 00 01 63 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 A8 00 28 21 43 A7 43 06 05 B7 00 00 81 00 00 4C 00 00 1A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0E 00 00 00 00 00 00 00 03 17 00 00 00 00 00 00 00 00 85 44 00 08 A4 00 00 00 00 00 00 00 17 72 00 2A B9 00 19 F8 00 0B EB 08 29 02 8D 00 41 00 00 00 00 00 01 00 0A 00 23 01 97 00 06 F5 00 63 16 00 08 1E 01 53 00 19 00 03 00 00 00 00 00 00 00 1C 00 0D 00 0E 00 06 00 0E 00 11 00 17 00 20 00 00 33 00 00 71 00 00 95 01 BA DC 00 00 00 00 00 00 00 00 2A 00 41 8B 00 20 A5 00 00 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 05 00 9E F6 00 38 1C 00 14 F5 00 08 54 00 07 81 04 67 D6 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 00 00 00 00 7D 00 00 00 4F 04 00 00 62 04 80 48 00 8E 00 29 00 00 00 00 05 77 12 CD 0A BF 04 18 02 7B 01 89 00 D6 00 71 00 EA 00 31 00 00 00 00 00 1F 01 8E 01 F5 01 0F 00 D8 00 7B 00 58 00 40 64 11 00 00 00 00 01 00 0E 00 0F 48 00 8E 00 29 00 00 00 00 05 77 12 CD 0A BF 04 18 02 7B 01 89 00 D6 00 71 00 EA 00 31 00 00 00 00 00 1F 01 8E 01 F5 01 0F 00 D8 00 7B 00 58 00 40 64 11 00 00 00 00 01 00 0E 00 0F 00 0B 00 04 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 49 00 24 00 00 00 00 00 00 00 13 00 0C 00 00 00 00 00 00 00 01 00 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 02 00 00 07 00 00 06 00 00 0E 00 00 02 00 00 0A 00 00 12 00 00 39 00 00 BB 00 01 3B 00 01 A5 00 00 16 00 00 50 00 00 94 00 02 A1 00 06 71 00 0B 19 00 0B BA 00 00 93 00 01 1A 00 02 9D 00 09 CB 00 12 B9 00 22 71 00 22 EC 00 01 87 00 02 C0 00 04 2E 00 0A F4 00 10 AC 00 22 75 00 20 D2 00 00 96 00 22 1B 00 21 7F 00 0D A0 00 06 61 00 0B 6E 00 0E AB 00 00 1B 53 00 00 00 00 00 27 02 15 02 B2 00 33 00 00 00 00 00 00 00 05 00 2C 00 23 00 00 00 00 00 00 00 00 00 05 00 32 00 21 00 00 00 00 00 00 00 00 00 07 00 23 00 1D 00 00 00 00 00 00 00 00 00 02 00 0B 00 09 00 02 00 00 00 00 00 00 00 02 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 04 87 0C 1E 02 72 00 0A 00 00 00 00 00 17 01 6E 01 5E 00 14 00 00 00 00 00 00 00 01 00 00 28 00 01 A0 00 01 C8 00 00 1B 00 00 00 00 00 00 00 00 00 00 00 2A 00 02 27 00 01 EE 00 00 2A 00 00 00 00 00 00 00 00 02 00 00 17 00 00 C3 00 00 F4 00 00 24 00 00 01 00 00 00 00 00 00 00 00 0E 00 00 2E 00 00 2A 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 0E 01 73 08 D1 05 AE 00 BE 00 00 00 00 00 06 01 26 02 ED 00 93 00 09 00 00 00 00 00 00 00 00 11 00 02 09 00 04 75 00 00 A6 00 00 03 00 00 00 00 00 00 00 00 1D 00 03 39 00 06 0E 00 00 E5 00 00 08 00 00 00 00 00 00 00 00 1D 00 01 C1 00 03 FF 00 01 49 00 00 0F 00 00 00 00 00 00 00 00 17 00 00 BC 00 01 E3 00 00 A4 00 00 06 00 00 00 00 00 00 00 00 00 00 00 05 00 00 0D 00 00 0A 00 00 00 00 00 00 00 00 03 00 91 05 1C 09 9B 03 C5 00 00 00 00 00 02 00 48 02 93 01 DF 00 45 00 00 00 00 00 00 00 00 09 00 00 D0 00 04 B1 00 02 98 00 00 40 00 00 00 00 00 00 00 00 07 00 01 34 00 06 F1 00 02 D3 00 00 29 00 00 00 00 00 00 00 00 0B 00 01 05 00 06 9F 00 04 1F 00 00 6F 00 00 00 00 00 00 00 00 09 00 00 AE 00 04 3D 00 03 34 00 00 5F 00 00 00 00 00 00 00 00 00 00 00 05 00 00 22 00 00 1C 00 00 00 00 00 00 00 00 00 00 16 01 C3 07 AE 0C D7 00 00 00 00 00 00 00 0C 01 5A 02 D2 01 38 00 00 00 00 00 00 00 00 00 00 00 26 00 02 5F 00 04 5B 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 45 00 04 4E 00 04 EB 00 00 9C 00 00 00 00 00 00 00 00 00 00 00 49 00 04 8B 00 07 67 00 01 4B 00 00 00 00 00 00 00 00 00 00 00 35 00 03 52 00 05 F3 00 01 67 00 00 00 00 00 00 00 00 00 00 00 01 00 00 16 00 00 2C 00 00 02 00 00 00 00 00 00 00 05 00 6B 03 DD 12 96 00 00 00 00 00 00 00 02 00 53 01 D7 02 40 00 00 00 00 00 00 00 00 00 00 00 05 00 00 A9 00 03 9D 00 01 FD 00 00 00 00 00 00 00 00 00 00 00 07 00 01 3D 00 04 B9 00 01 00 00 00 00 7D 00 00 00 29 03 00 00 62 04 80 00 00 00 00 00 00 00 00 00 0B 00 C9 0E 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 17 00 02 24 00 08 B7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2D 00 03 C4 00 05 83 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0B 00 C9 0E 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 17 00 02 24 00 08 B7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2D 00 03 C4 00 05 83 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3C 00 04 FC 00 08 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 03 23 00 07 9F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 27 00 00 21 50 39 36 34 34 32 00 09 D3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS06948-ENG56075,Brake bleeding and replacement check hydraulic connections-Measurement_Value_Basic_Setting,Ready to start,
ENG04544,Accelerator_pedal_position_requested_by_driver_or_cruise_control,0.00, %
ENG04547-ENG04671,Apply Counter left_right-Left_Brake_Full_Clamping_Force,593,
ENG04547-ENG04672,Apply Counter left_right-Left_Brake_Reduced_Clamping_Force,0,
ENG04547-ENG04669,Apply Counter left_right-Right_Brake_Full_Clamping_Force,593,
ENG04547-ENG04670,Apply Counter left_right-Right_Brake_Reduced_Clamping_Force,0,
ENG04525-ENG101167,BB_Num_and_SW_Version-Base version,7606,
ENG04525-ENG101969,BB_Num_and_SW_Version-BB-No.,96442,
ENG04525-ENG98430,BB_Num_and_SW_Version-Branch 1,0200,
ENG04525-ENG98431,BB_Num_and_SW_Version-Branch 2,0000,
ENG07087-ENG04744,Bootloader_Bosch_Signature_Status-Bosch_Signature,Yes,
ENG04560-IDE04450,Brake_pressure_at_BLS_change-Brake pressure sensor 1,36.245, bar
ENG04532,BTM_Driving_with_pushed_brakes,0, s
ENG04533-MAS00106,BTM_Last_occurence_of_driving_with_pushed_brakes-Year,2000, yr
ENG04533-MAS00107,BTM_Last_occurence_of_driving_with_pushed_brakes-Month,0, mon
ENG04533-MAS00108,BTM_Last_occurence_of_driving_with_pushed_brakes-Day,0, d
ENG04530-MAS00106,BTM_Last_occurence_of_maximum_temp_FL-Year,2019, yr
ENG04530-MAS00107,BTM_Last_occurence_of_maximum_temp_FL-Month,7, mon
ENG04530-MAS00108,BTM_Last_occurence_of_maximum_temp_FL-Day,20, d
ENG04528-MAS00106,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Year,2000, yr
ENG04528-MAS00107,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Month,0, mon
ENG04528-MAS00108,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Day,0, d
ENG04534-MAS00106,BTM_Last_reset_of_driving_with pushed_brakes-Year,2000, yr
ENG04534-MAS00107,BTM_Last_reset_of_driving_with pushed_brakes-Month,0, mon
ENG04534-MAS00108,BTM_Last_reset_of_driving_with pushed_brakes-Day,0, d
ENG04531-MAS00106,BTM_Last_reset_of_maximum_temp_FL-Year,2000, yr
ENG04531-MAS00107,BTM_Last_reset_of_maximum_temp_FL-Month,0, mon
ENG04531-MAS00108,BTM_Last_reset_of_maximum_temp_FL-Day,0, d
ENG04529-MAS00106,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Year,2000, yr
ENG04529-MAS00107,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Month,0, mon
ENG04529-MAS00108,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Day,0, d
ENG04545,BTM_Maximum_temp_of_temperature_brake_FL,358.00, °C
ENG04527,BTM_Time_of_temperature_FL_greater_than_temp_limit,0, s
ENG101413,Calibration Identification,8W0379K 0766---,
ENG99697,Calibration Verification Number,01 18 E6 1C,
ENG04552-ENG04693,Driver_Presence_Status-Input_Signal_A_Belt_Error,no error,
ENG04552-ENG04692,Driver_Presence_Status-Input_Signal_A_Belt_Status,not selected,
ENG04552-ENG04695,Driver_Presence_Status-Input_Signal_B_Door_Error,no error,
ENG04552-ENG04694,Driver_Presence_Status-Input_Signal_B_Door_Status,closed,
ENG04562-MAS02141,DSDL_VIN_Check_Status-Monitoring VIN,active,
ENG04562-ENG04743,DSDL_VIN_Check_Status-VIN_Check_Status,not performed,
ENG100152-ENG104003,ECUNAME-ECU,BSC,
ENG100152,ECUNAME,-BrakeSystem,
ENG04543,EDS_active_flag,passive,
ENG04539-MAS00109,Engine_off_time-Hours,1, H
ENG04539-MAS00110,Engine_off_time-Minutes,17, min
ENG04542,Engine_torque_loss,2, Nm
ENG04540,Engine_torque_with_external_intervention,509, Nm
ENG04548-ENG04677,ESC_EPBi_Dataset_Daten-ESC_DS_Compatibility_Version,0000,
ENG04548-ENG04675,ESC_EPBi_Dataset_Daten-ESC_EPBi_DS_Checksums,A0 2D 4F 89,
ENG04548-ENG04673,ESC_EPBi_Dataset_Daten-ESC_EPBi_DS_LogAdr,71 03,
ENG04548-ENG04674,ESC_EPBi_Dataset_Daten-ESC_EPBi_DS_Version,----,
ENG04548-ENG04676,ESC_EPBi_Dataset_Daten-ESC_SW_Compatibility_Version,0000,
ENG04548-ENG04679,ESC_EPBi_Dataset_Daten-PBC_DS_Checksums,F2 5A,
ENG04548-ENG32276,ESC_EPBi_Dataset_Daten-PBC_DS_Compatibility_Version,00 1C,
ENG04548-ENG04678,ESC_EPBi_Dataset_Daten-PBC_DS_Version,0002,
ENG04549-ENG04682,ESC_EPBi_Dataset_Satus-ESC_Dataset_Status_Compatibility,valid,
ENG04549-ENG04681,ESC_EPBi_Dataset_Satus-ESC_Dataset_Status_CS,Correct result,
ENG04549-ENG04684,ESC_EPBi_Dataset_Satus-PBC_Dataset_Status_Compatibility,valid,
ENG04549-ENG04683,ESC_EPBi_Dataset_Satus-PBC_Dataset_Status_CS,Correct result,
ENG07646,ESC_Function_mode,1,
ENG07088-ENG07109,ESP_Charisma_interface_signals-CHA_Ziel_FahrPr_ESP,0,
ENG07088-ENG07110,ESP_Charisma_interface_signals-ESP_Charisma_FahrPr,2,
ENG07088-ENG07111,ESP_Charisma_interface_signals-ESP_Charisma_Status,Init,
ENG04523,ESP_Sensor_unit_2_lateral_acceleration_confidence_factor,5,
ENG04521,ESP_Sensor_unit_2_turn_rate_confidence_factor,5,
ENG04522,ESP_Sensor_unit_lateral_acceleration_confidence_factor,0,
ENG04524,ESP_Sensor_unit_longitudinal_acceleration_confidence_factor,0,
ENG04520,ESP_Sensor_unit_turn_rate_confidence_factor,0,
ENG04536,FIBEX_Version,0811_00,
ENG04537,Lateral_acceleration_sensor_2_minus_lateral_acceleration_sensor_1,0.19200, m/s²
ENG111914-ENG04664,NoPata-BME Last5ICs,00000000 ,
ENG111914-ENG04660,NoPata-BME ThisIC,00000000 ,
ENG111914-ENG111902,NoPata-EPB Last5ICs,00000000 ,
ENG111914-ENG111895,NoPata-EPB ThisIC,00000000 ,
ENG111914-ENG111900,NoPata-Handtaschenlogik Last5ICs,00000000 ,
ENG111914-ENG111893,NoPata-Handtaschenlogik ThisIC,00000000 ,
ENG111914-ENG111904,NoPata-LUFE Last5ICs,00000000 ,
ENG111914-ENG111897,NoPata-LUFE ThisIC,00000000 ,
ENG111914-ENG111905,NoPata-QSP Last5ICs,00000000 ,
ENG111914-ENG111898,NoPata-QSP ThisIC,00000000 ,
ENG111914-ENG04663,NoPata-SCM Last5ICs,00000000 ,
ENG111914-ENG04659,NoPata-SCM ThisIC,00000000 ,
ENG111914-ENG111906,NoPata-Spoiler Last5ICs,00000000 ,
ENG111914-ENG111899,NoPata-Spoiler ThisIC,00000000 ,
ENG111914-ENG04662,NoPata-Systemdegradation Last5ICs,00000000 ,
ENG111914-ENG04658,NoPata-Systemdegradation ThisIC,00000000 ,
ENG111914-ENG04665,NoPata-TSK Last5ICs,00000000 ,
ENG111914-ENG04661,NoPata-TSK ThisIC,00000000 ,
ENG04553,PBC_SW_Version,085_00,
ENG04526-ENG99585,Steering_angle_sensor_data-LWI_QBit_Steering_wheel_angle,active,
ENG04526-ENG100735,Steering_angle_sensor_data-LWI_QBit_sub_data,active,
ENG04526-ENG99156,Steering_angle_sensor_data-LWI_sensor_status,OK,
ENG04526-ENG04627,Steering_angle_sensor_data-LWI_sub_data_SSI,valid,
ENG07092-ENG07114,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Day,31,
ENG07092-ENG07115,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Hour,31, H
ENG07092-ENG07118,Time_Mileage_RollerBenchMode_907_Deactivation-RBM KM,1048575, km
ENG07092-ENG07116,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Minute,63, min
ENG07092-ENG07113,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Month,15, mon
ENG07092-ENG07117,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Second,63, s
ENG07092-ENG07112,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Year,2127, yr
ENG04561-ENG04713,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Day,31,
ENG04561-ENG04714,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Hour,31, H
ENG04561-ENG04717,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 KM,1048575, km
ENG04561-ENG04715,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Minute,63, min
ENG04561-ENG04712,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Month,15, mon
ENG04561-ENG04716,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Second,63, s
ENG04561-ENG04718,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Status,active,
ENG04561-ENG04711,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Year,2127, yr
ENG04561-ENG04721,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Day,31,
ENG04561-ENG04722,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Hour,31, H
ENG04561-ENG04725,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 KM,1048575, km
ENG04561-ENG04723,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Minute,63, min
ENG04561-ENG04720,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Month,15, mon
ENG04561-ENG04724,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Second,63, s
ENG04561-ENG04726,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Status,active,
ENG04561-ENG04719,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Year,2127, yr
ENG04561-ENG04729,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Day,31,
ENG04561-ENG04730,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Hour,31, H
ENG04561-ENG04733,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 KM,1048575, km
ENG04561-ENG04731,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Minute,63, min
ENG04561-ENG04728,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Month,15, mon
ENG04561-ENG04732,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Second,63, s
ENG04561-ENG04734,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Status,active,
ENG04561-ENG04727,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Year,2127, yr
ENG04561-ENG04737,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Day,31,
ENG04561-ENG04738,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Hour,31, H
ENG04561-ENG04741,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 KM,1048575, km
ENG04561-ENG04739,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Minute,63, min
ENG04561-ENG04736,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Month,15, mon
ENG04561-ENG04740,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Second,63, s
ENG04561-ENG04742,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Status,active,
ENG04561-ENG04735,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Year,2127, yr
ENG110108-ENG103252,WAU Info KL15-FlexRay Transceiver PIN,passive,
ENG110108-ENG102268,WAU Info KL15-Klemme 15 PIN,active,
ENG04535,YAW_rate_sensor_2_minus_yawrate_sensor_1,0.00000, rad/s
Elapsed Time: 00:34
adpmap-03-8W0-907-379-K
;Sunday,10,November,2019,20:32:18:01617
IDE00001-IDE01211-Production mode-Static current measuring mode,Deactivating ,3
IDE00001-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
IDE00001-MAS16682-Production mode-Production mode after-run monitoring,Deactivating ,3
IDE00820-ENG135838-Activating and deactivating all development messages-EWB_DEV_EPB_01,not activated ,3
IDE00820-ENG135837-Activating and deactivating all development messages-EWB_DEV_ESP_01,not activated ,3
IDE00820-ENG135839-Activating and deactivating all development messages-EWB_DEV_RKA_01,not activated ,3
IDE00820-ENG135834-Activating and deactivating all development messages-EWB_S100,not activated ,3
IDE00820-ENG135835-Activating and deactivating all development messages-EWB_S101,not activated ,3
IDE00820-ENG135836-Activating and deactivating all development messages-EWB_S102,not activated ,3
IDE00820-ENG102355-Activating and deactivating all development messages-Internal System Error Number,00 00 ,3
IDE02630-MAS09081-ESP coasting operation-Axis for vehicle speed measurement,Front axle activated ,1
IDE02630-MAS09082-ESP coasting operation-Roller operation ESP: status,not active ,1
IDE02631-Brake disc wiper,normal ,1
IDE08134-Automatic parking brake,not activated ,1
IDE08220-Vehicle production mode-,Deactivating ,4
IDE08801-Tire press. monitor. sys: position display,Default ,1
IDE09290-Tire press monitor.display: warning sensitivity,0 ,1
IDE09537-Driver warn. during hill descent,active ,1
IDE09539-Tripping threshold for start-up assist.,normal ,1
IDE09540-ENG101644-Install. position of wheel speed sens.-Wheel FL,regularly ,1
IDE09540-ENG102524-Install. position of wheel speed sens.-Wheel FR,regularly ,1
IDE09540-ENG99883-Install. position of wheel speed sens.-Wheel RL,regularly ,1
IDE09540-ENG99053-Install. position of wheel speed sens.-wheel rr,regularly ,1
IDE09541-Brake direction holding function,On ,1
IDE10866-Hold management in production mode,Deactivating ,1
IDE10867-MAS11564-Hold management in transport mode-Local activation,Deactivating ,1
IDE10867-MAS13351-Hold management in transport mode-Automatically take over transport mode,Activate ,1
IDE11038-Automatic closing if error in button for parking brake,activated ,1
IDE11628-Analysis data: status,activated ,1
ENG135668-auto_hold_seatbelt_evaluation,Activate ,1
ENG135671-ENG135644-Dimmung_EPB_TaLa-Pos1_KL_58xd,1 ,6
ENG135671-ENG135645-Dimmung_EPB_TaLa-Pos2_KL_58xd,1 ,6
ENG135671-ENG135646-Dimmung_EPB_TaLa-Pos3_KL_58xd,10 ,6
ENG135671-ENG135647-Dimmung_EPB_TaLa-Pos4_KL_58xd,25 ,6
ENG135671-ENG135648-Dimmung_EPB_TaLa-Pos5_KL_58xd,60 ,6
ENG135671-ENG135649-Dimmung_EPB_TaLa-Pos6_KL_58xd,100 ,6
ENG135665-Driving_Steering_Recommendation,active ,1
ENG135670-DSDL_EOLCheck,not active ,1
ENG106318-ESP_ASR,ESC_Vollsystem ,1
ENG135666-Fading_Assistant_FBS_HFC_HPS,active ,1
ENG135672-Glaettung_PWM_Dimmung,not active ,1
ENG135673-Nominal_Voltage_dimming,13.00 V,1
ENG135669-Powertrain_Protection,not active ,1
ENG167431-Reset_ESC_Maximal_System_Runtime,valid value stored ,1
ENG135662-Reset_RKA_Maximal_System_Runtime,valid value stored ,1
ENG135660-RKA_Datalog_Mode,datalog off ,1
ENG135661-RKA_Simulation_Mode,00 00 ,2
ENG135663-RKA_Stop-Start,use real Kl.15 ,1
ENG100419-text_warning,active ,1
ENG100453-VIN_monitoring,active ,1
Elapsed Time: 00:13
Address [08]
blockmap-08-8W0-820-043-T
;SW:8W0-820-043-T   HW:8W0-820-043-T ---  Auto HVAC
;Component:Klima Zone 3  H60 0210, Coding:140805095544000D10000100880000000000000000000000000000000000
;EV_AirCondiBHTCAU491,001013,EV_AirCondiBHTCAU491.rod
;Sunday,10,November,2019,20:32:33:01617
;VCID: C4CB4F564F9D0E6F43-8090
IDE00019,Voltage terminal 30,13.13, V
IDE00021,Engine speed,797, /min
IDE00025,Coolant temperature,111.00, °C
IDE00198,Refrigerant pressure,12.00, bar
IDE00322,Status of basic setting,was not yet started,
IDE00767,No. of unscheduled ECU resets,3,
IDE00965,Compressor shut-off requirement,Compressor active: no shut-off condition is present,
IDE00966,Compressor current: actual value,0.48, A
IDE00967,Compressor current: specified value,0.49, A
IDE00970,Coolant fan activation: actual value,46.00, %
IDE00971,Coolant fan activation: specified value,46.40, %
IDE00972,Idle speed increase,not active,
IDE00973,Outside air temperature,26.50, °C
IDE00974,Outside air temperature internally calculated,26.50, °C
IDE00976,Left front vent temperature,26.30, °C
IDE00977,Right front vent temperature,22.30, °C
IDE00979,Left footwell vent temperature,26.70, °C
IDE00980,Right footwell vent temperature,22.50, °C
IDE00982,Temperature after evaporator,4.00, °C
IDE00983,Interior temperature,23.10, °C
IDE00984,Sun intensity left,0, W/m²
IDE00985,Sun intensity right,0, W/m²
IDE01063,Status of recirculation air,Fresh air,
IDE01065,Rear vent temperature,9.00, °C
IDE01066,Convertible top status,closed,
IDE01076,Time since ignition off,0, min
IDE01217-MAS01448,Left heated seat stage-Specified value,0,
IDE01218-MAS01448,Right heated seat stage-Specified value,0,
IDE01227,Blower current,1.75, A
IDE01232,Supply voltage for external components,5.03, V
IDE01287,Counter of compressor switch-offs,0,
IDE01309,Recirculation air flap motor: actual value,10000,
IDE01311,Left side vent flap motor: actual value,10423,
IDE01312,Right side vent flap motor: actual value,10000,
IDE01319,Rear temperature flap motor: actual value,10000,
IDE01328-IDE09056,Recirculation air flap motor: diagnostic-Last operating state,Blocking,
IDE01328-MAS01458,Recirculation air flap motor: diagnostic-Operating condition,No routine started,
IDE01330-IDE09056,Left side vent flap motor: diagnostic-Last operating state,Move flap motor,
IDE01330-MAS01458,Left side vent flap motor: diagnostic-Operating condition,No routine started,
IDE01331-IDE09056,Right side vent flap motor: diagnostic-Last operating state,Blocking,
IDE01331-MAS01458,Right side vent flap motor: diagnostic-Operating condition,No routine started,
IDE01338-IDE09056,Rear temperature flap motor: diagnosis-Last operating state,Blocking,
IDE01338-MAS01458,Rear temperature flap motor: diagnosis-Operating condition,No routine started,
IDE01352,Temperature unit,°F,
IDE01419,Compressor shut-off condition: last,Malfunction on fresh air blower,
IDE01420,Compressor shut-off requirement: penultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01421,Compressor shut-off requirement: antepenultimate,Malfunction on fresh air blower,
IDE01425,Defrost flap motor: actual value,10000,
IDE01426,Left temperature flap motor: actual value,10539,
IDE01427,Right temperature flap motor: actual value,10440,
IDE01428-IDE09056,Defrost flap motor: diagnostic-Last operating state,Blocking,
IDE01428-MAS01458,Defrost flap motor: diagnostic-Operating condition,No routine started,
IDE01429-IDE09056,Left temperature flap motor: diagnostic-Last operating state,Move flap motor,
IDE01429-MAS01458,Left temperature flap motor: diagnostic-Operating condition,No routine started,
IDE01430-IDE09056,Right temperature flap motor: diagnostic-Last operating state,Move flap motor,
IDE01430-MAS01458,Right temperature flap motor: diagnostic-Operating condition,No routine started,
IDE01433,Air quality status,Clean air,
IDE01442-IDE10964,Pressing a button-Button for instrument panel vents,not activated,
IDE01442-MAS01533,Pressing a button-Defrost,not activated,
IDE01442-MAS01534,Pressing a button-Recirculating air,not activated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,not activated,
IDE01442-MAS01536,Pressing a button-Left pressure knob,not activated,
IDE01442-MAS01537,Pressing a button-Right pressure knob,not activated,
IDE01442-MAS01538,Pressing a button-Left air distribution,not activated,
IDE01442-MAS01539,Pressing a button-Right air distribution,not activated,
IDE01442-MAS01545,Pressing a button-AUTO left,not activated,
IDE01442-MAS01546,Pressing a button-AUTO right,not activated,
IDE01442-MAS01547,Pressing a button-Air quantity left,not activated,
IDE01442-MAS01548,Pressing a button-Air quantity right,not activated,
IDE01442-MAS01550,Pressing a button-AC,not activated,
IDE01442-MAS01554,Pressing a button-Left heated seat,not activated,
IDE01442-MAS01555,Pressing a button-Left seat ventilation,not activated,
IDE01442-MAS01556,Pressing a button-Right heated seat,not activated,
IDE01442-MAS01557,Pressing a button-Right seat ventilation,not activated,
IDE01442-MAS01560,Pressing a button-OFF,not activated,
IDE01442-MAS02015,Pressing a button-AUTO,not activated,
IDE01442-MAS02191,Pressing a button-Air quantity,not activated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,not activated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,not activated,
IDE01442-MAS03832,Pressing a button-Air distribution up,not activated,
IDE01442-MAS04621,Pressing a button-Left cabin heater,not activated,
IDE01442-MAS04648,Pressing a button-Right cabin heater,not activated,
IDE01442-MAS07066,Pressing a button-AC max/eco,not activated,
IDE01442-MAS07154,Pressing a button-Input mode,not activated,
IDE01442-MAS07155,Pressing a button-A/C mode,not activated,
IDE01455,Key number,2,
IDE01622,Fresh air blower: speed,1660, /min
IDE01689,Left rear footwell vent temperature,25.50, °C
IDE01985-MAS06855,FAZIT identification test sum-Test sum,A2 8C FA F6,
IDE02492,Start-stop function: coding information,Start-stop function in control module active,
IDE02834,Fresh air flap motor: actual value,11227,
IDE02835-IDE09056,Fresh air flap motor: diagnostic-Last operating state,Blocking,
IDE02835-MAS01458,Fresh air flap motor: diagnostic-Operating condition,No routine started,
IDE03008-IDE80251,Stop process prevented-Head area heater,not active,
IDE03008-MAS00385,Stop process prevented-Basic setting active,not active,
IDE03008-MAS01517,Stop process prevented-Defrost active,not active,
IDE03008-MAS01957,Stop process prevented-Outside air temperature,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to setting,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS03902,Stop process prevented-Stop release for A/C comfort adaptation,not active,
IDE03008-MAS04353,Stop process prevented-Fogging hazard (humidity sensor),not active,
IDE03008-MAS04354,Stop process prevented-Interior comfort humidity too high (humidity sensor),not active,
IDE03008-MAS05047,Stop process prevented-Maximum cooling and heating set,not active,
IDE03010-IDE80251,Number of prevented stop processes-Head area heater,0,
IDE03010-MAS00385,Number of prevented stop processes-Basic setting active,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,66,
IDE03010-MAS01957,Number of prevented stop processes-Outside air temperature,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to setting,3943,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,4329,
IDE03010-MAS03902,Number of prevented stop processes-Stop release for A/C comfort adaptation,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),11,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),758,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,2818,
IDE03011-IDE80251,Number of requested start processes-Head area heater,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,1,
IDE03011-MAS01957,Number of requested start processes-Outside air temperature,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to setting,3,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,169,
IDE03011-MAS03902,Number of requested start processes-Stop release for A/C comfort adaptation,0,
IDE03011-MAS03903,Number of requested start processes-Dew point gradient,9,
IDE03011-MAS03904,Number of requested start processes-maximum stop duration reached,44,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),1,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),166,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,7,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,2557, s
IDE04312-MAS00084,System run time-Terminal 15 on,2558, s
IDE05725,Terminal 58xs dimmer,58, %
IDE05726,Terminal 58xd dimmer,58,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,supported,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,supported,
IDE05738-ENG06682,Subssystem diagnosis classes-DC2/DC2F_sysystems,supported,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Not supported,
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,33.00, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,numerical value: no text,
IDE06091-ENG07792,Humidity sensor: internal-dew_point_Textual,numerical value: no text,
IDE06091-ENG29452,Humidity sensor: internal-relative_humidity_Textual,numerical value: no text,
IDE06163-MAS04628,External humidity sensor-Air temperature,35.30, °C
IDE06163-MAS04630,External humidity sensor-Relative humidity,33.00, %
IDE06163-MAS04647,External humidity sensor-Dew point,18.50, °C
IDE06163-ENG29450,External humidity sensor-Air temperature_Textual,numerical value: no text,
IDE06163-ENG07792,External humidity sensor-dew_point_Textual,numerical value: no text,
IDE06163-ENG29452,External humidity sensor-relative_humidity_Textual,numerical value: no text,
IDE06201,Blower reduction,No switch-off: no reduction,
IDE06234-IDE01270,Auxiliary heater: in stages-Enabling for auxiliary heater operation,No enabling,
IDE06234-MAS01447,Auxiliary heater: in stages-Act.val.,6,
IDE06234-MAS01448,Auxiliary heater: in stages-Specified value,0,
IDE06307-MAS00107,Stop prevention history data-Month,11,
IDE06307-MAS00108,Stop prevention history data-Day,9,
IDE06307-MAS00109,Stop prevention history data-Hours,12,
IDE06307-MAS00110,Stop prevention history data-Minutes,16,
IDE06307-MAS00111,Stop prevention history data-Seconds,5,
IDE06307,Stop prevention history data,Interior temperature difference to setting,
IDE06308-MAS00107,Start request history data-Month,11,
IDE06308-MAS00108,Start request history data-Day,4,
IDE06308-MAS00109,Start request history data-Hours,14,
IDE06308-MAS00111,Start request history data-Seconds,6,
IDE06308,Start request history data,Interior vent difference to setting,
IDE06807,Fresh-air door motor / specified value,11227,
IDE06808,Fresh-air door motor / dynamics,1227,
IDE06809,Left temp. door motor / specified value,10524,
IDE06810,Left temp. door motor / dynamics,1424,
IDE06811,Right temp. door motor: specified value,10440,
IDE06812,Right temp. door motor: dynamics,1421,
IDE06813,Defroster door motor: specified value,10000,
IDE06814,Defroster door motor: dynamics,1532,
IDE06815,Recirc. air flap motor: spec.value,10000,
IDE06816,Recirc. air flap motor: dynamics,1625,
IDE06817,Rear temp. door motor: specified value,10000,
IDE06818,Rear temp. door motor: dynamics,1577,
IDE07133,Fresh air blower motor: temperature,34, °C
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,08,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07499,Left side vent flap motor: spec.value,10423,
IDE07500,Left side vent flap motor: dynamics,4070,
IDE07501,Right side vent flap motor: spec. value,10000,
IDE07502,Right side vent flap motor: dynamics,4060,
IDE07950-IDE04095,Historical data of motors-Engine running time,510, s
IDE07950-IDE09056,Historical data of motors-Last operating state,Blocking,
IDE07950-MAS00084,Historical data of motors-Terminal 15 on,510, s
IDE07950-MAS00106,Historical data of motors-Year,2019,
IDE07950-MAS00107,Historical data of motors-Month,5,
IDE07950-MAS00108,Historical data of motors-Day,4,
IDE07950-MAS00109,Historical data of motors-Hours,10,
IDE07950-MAS00110,Historical data of motors-Minutes,6,
IDE07950-MAS00111,Historical data of motors-Seconds,36,
IDE07950-MAS01458,Historical data of motors-Operating condition,Blocking handling,
IDE07950,Historical data of motors,14.20, V
IDE07950,Historical data of motors,36,
IDE07965,Rear air distribution flap motor: actual value,14930,
IDE07966,Rear air distr.flap mot.:spec.val,14930,
IDE07967,Rear air distribution flap motor: dynamic,6305,
IDE08343,Immobilizer Challenge,36 14 2A D5,
IDE08372,Fresh air blower: target speed,1660, /min
IDE08774-MAS01453,Fresh air blower: error status-Blocking detection,not active,
IDE08774-MAS01478,Fresh air blower: error status-Insuff. voltage,not active,
IDE08774-MAS01479,Fresh air blower: error status-Excess voltage,not active,
IDE08774-MAS01480,Fresh air blower: error status-Excess temp.,not active,
IDE08774-MAS01575,Fresh air blower: error status-Internal malfunction,not active,
IDE08774-MAS01807,Fresh air blower: error status-Short circuit,not active,
IDE08774-MAS07627,Fresh air blower: error status-Over current string,not active,
IDE08774-MAS07628,Fresh air blower: error status-Over current phase,not active,
IDE08774-MAS07629,Fresh air blower: error status-Error current offset,not active,
IDE08774-MAS07630,Fresh air blower: error status-error temperature sensor,not active,
IDE08774-MAS07631,Fresh air blower: error status-Error bridge driver,not active,
IDE08774-MAS07632,Fresh air blower: error status-Excess temp. bridge driver,not active,
IDE09584-MAS07663,Assembly position of users at local data bus 1: 3 zones front-Pos. 1 from master,Rear temperature door motor,
IDE09584-MAS07664,Assembly position of users at local data bus 1: 3 zones front-Pos. 2 from master,Left temperature flap positioning motor,
IDE09584-MAS07665,Assembly position of users at local data bus 1: 3 zones front-Pos. 3 from master,Left side vent motor,
IDE09584-MAS07666,Assembly position of users at local data bus 1: 3 zones front-Pos. 4 from master,Defroster flap motor,
IDE09584-MAS07667,Assembly position of users at local data bus 1: 3 zones front-Pos. 5 from master,Right side vent motor,
IDE09584-MAS07668,Assembly position of users at local data bus 1: 3 zones front-Pos. 6 from master,Right temperature flap positioning motor,
IDE09584-MAS07669,Assembly position of users at local data bus 1: 3 zones front-Pos. 7 from master,Rear air distribution door motor,
IDE09584-MAS07670,Assembly position of users at local data bus 1: 3 zones front-Pos. 8 from master,Fresh air door motor,
IDE09584-MAS07671,Assembly position of users at local data bus 1: 3 zones front-Pos. 9 from master,Recirculation flap motor,
IDE09584-MAS07672,Assembly position of users at local data bus 1: 3 zones front-Pos. 10 from master,not installed,
IDE09584-MAS07673,Assembly position of users at local data bus 1: 3 zones front-Pos. 11 from master,not installed,
IDE09584-MAS07674,Assembly position of users at local data bus 1: 3 zones front-Pos. 12 from master,not installed,
IDE09584-MAS07675,Assembly position of users at local data bus 1: 3 zones front-Pos. 13 from master,not installed,
IDE09584-MAS07676,Assembly position of users at local data bus 1: 3 zones front-Pos. 14 from master,not installed,
IDE09584-MAS07677,Assembly position of users at local data bus 1: 3 zones front-Pos. 15 from master,not installed,
IDE10418-IDE09056,Rear air distribution flap motor: diagnosis-Last operating state,End impact,
IDE10418-MAS01458,Rear air distribution flap motor: diagnosis-Operating condition,No routine started,
IDE10960,Ctrl. motor for instr.cluster vents: actual value,10000,
IDE10961,Ctrl. motor for instr.cluster vents: spec. value,10000,
IDE10962,Ctrl. motor for instr.cluster vents: dynamics,1168,
IDE10963-IDE09056,Ctrl. motor for instr.cluster vents: diagnosis-Last operating state,Blocking,
IDE10963-MAS01458,Ctrl. motor for instr.cluster vents: diagnosis-Operating condition,No routine started,
IDE10967-MAS07663,Assembly position of users at local data bus 2: 2 zones front-Pos. 1 from master,Ctrl. motor for instrument panel vents,
IDE10967-MAS07664,Assembly position of users at local data bus 2: 2 zones front-Pos. 2 from master,not installed,
IDE10967-MAS07665,Assembly position of users at local data bus 2: 2 zones front-Pos. 3 from master,not installed,
IDE10967-MAS07666,Assembly position of users at local data bus 2: 2 zones front-Pos. 4 from master,not installed,
IDE10967-MAS07667,Assembly position of users at local data bus 2: 2 zones front-Pos. 5 from master,not installed,
IDE10967-MAS07668,Assembly position of users at local data bus 2: 2 zones front-Pos. 6 from master,not installed,
IDE10967-MAS07669,Assembly position of users at local data bus 2: 2 zones front-Pos. 7 from master,not installed,
IDE10967-MAS07670,Assembly position of users at local data bus 2: 2 zones front-Pos. 8 from master,not installed,
IDE10967-MAS07671,Assembly position of users at local data bus 2: 2 zones front-Pos. 9 from master,not installed,
IDE10967-MAS07672,Assembly position of users at local data bus 2: 2 zones front-Pos. 10 from master,not installed,
IDE10967-MAS07673,Assembly position of users at local data bus 2: 2 zones front-Pos. 11 from master,not installed,
IDE10967-MAS07674,Assembly position of users at local data bus 2: 2 zones front-Pos. 12 from master,not installed,
IDE10967-MAS07675,Assembly position of users at local data bus 2: 2 zones front-Pos. 13 from master,not installed,
IDE10967-MAS07676,Assembly position of users at local data bus 2: 2 zones front-Pos. 14 from master,not installed,
IDE10967-MAS07677,Assembly position of users at local data bus 2: 2 zones front-Pos. 15 from master,not installed,
IDE80001-ENG110385,Analysis 1-Channel,0,
IDE80001-ENG02514,Analysis 1-Comma,not active,
IDE80001-ENG99000,Analysis 1-Value,1310,
Elapsed Time: 00:19
adpmap-08-8W0-820-043-T
;Sunday,10,November,2019,20:32:52:01617
IDE00001-Production mode,not active ,3
IDE01476-Store recirculation air setting for terminal 15 off,According to country version ,1
IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01485-Shut-off temperature for solar sunroof,5 °C,1
IDE01488-Retrofitting of parking heater without CAN,not installed ,1
IDE01491-Temperature offset: summer operation,Default ,1
IDE01492-Temperature offset: winter operation,Default ,1
IDE01493-Air quality sensor sensitivity,Medium ,1
IDE01495-After-run time of auxiliary heater with A/C off,120 s,1
IDE01500-Window condensation reduction at high humidity,Matching coding ,1
IDE01501-Leakage air to footwell,automatic ,1
IDE01503-Runtime for compressor run-in basic setting,60 s,1
IDE01506-Tolerance range for flap end stops,0 ,1
IDE01536-Post-heating of parking heater,10 min,1
IDE02380-MMI display time for controls at rear,10 s,1
IDE03252-Window condensation parameter for start-stop function,5 ,1
IDE03253-A/C comfort parameter for start-stop function,5 ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE05569-Compressor control in efficiency mode,Eco mode ,1
IDE06546-Interior target temperature for production routines,22 °C,1
IDE06547-Air distribution for production routines,Air distribution upper body vents and footwell ,1
IDE06593-Recirculation air for production routines,Recirculating air ,1
IDE06769-Blower regulator for production routines,7 ,1
IDE08209-Speed of motors,Default ,1
IDE08373-Offset of fresh air blower speed,Default ,1
IDE10914-Seat occupancy-depending A/C,none ,1
IDE13688-Parameter dew point vaporizer for sailing performance,5 ,1
IDE13691-Water loading for sailing performance parameter,5 ,1
ENG131964-ENG133589-EntwID_activation-CapSense,not activated ,2
ENG131964-ENG133591-EntwID_activation-Clima-OBD,not activated ,2
ENG131964-ENG133588-EntwID_activation-Climate,not activated ,2
ENG131964-ENG98556-EntwID_activation-Display,not activated ,2
ENG131964-ENG133587-EntwID_activation-Flaps,not activated ,2
ENG131964-ENG133398-EntwID_activation-LIN1,not activated ,2
ENG131964-ENG133399-EntwID_activation-LIN2,not activated ,2
ENG131964-ENG133590-EntwID_activation-Massflow,not activated ,2
ENG131964-ENG116788-EntwID_activation-Potentiometer,not activated ,2
ENG131964-ENG98962-EntwID_activation-system,not activated ,2
ENG133583-OBD_activation,not activated ,1
ENG128343-OBD_channel,0 ,2
Elapsed Time: 00:08
Address [09]
blockmap-09-8W0-907-063-CG
;SW:8W0-907-063-CG   HW:8W0-907-063-BG ---  Cent. Elect.
;Component:BCM1 MLBevo   H13 0267, Coding:07500363E0081CCD0515871518AC98BB110B3D08000000000000000020001A010A690122025705
;EV_BCM1BOSCHAU736,018006,EV_BCM1BOSCHAU736_018_AU49.rod
;Sunday,10,November,2019,20:33:03:01617
;VCID: 8247894E1509C05F31-80D6
Group,Description,Actual
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.00, km/h
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00957,Resulting distance of front sensors,infinite,
IDE00958,Resulting distance of rear sensors,infinite,
IDE00974,Outside air temperature internally calculated,25.50, °C
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123,Distance of left rear park assist sensor,infinite,
IDE01124,Distance of left rear center park assist sensors,infinite,
IDE01125,Distance of right rear center park assist sensors,infinite,
IDE01126,Distance of right rear park assist sensor,infinite,
IDE01127,Distance sensor for left front park assist,infinite,
IDE01128,Distance sensor for left front center park assist,infinite,
IDE01129,Distance sensor for right front center park assist,infinite,
IDE01130,Distance of right front park assist sensors,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,0.00, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,0.00, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,0.00, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,0.00, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,0.00, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,0.00, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,0.00, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,0.00, ms
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Speaker volume for rear park assist,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 6,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Speaker volume for front park assist,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 4,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164-MAS06614,Park assist button-Version,Local data bus: operating unit 1,
IDE01164-MAS07693,Park assist button-Button Status,Not operated,
IDE01164-MAS07694,Park assist button-Button status on CAN,Not operated,
IDE01164-MAS07699,Park assist button-Status indicator light on CAN,OFF,
IDE01164-MAS08062,Park assist button-Indicator light activation,OFF,
IDE01166,Supply voltage for park assist sensor,12.40, V
IDE01171-IDE01167,Convertible factory setting offset for volume level 1-Convertible offset for volume level 1,not installed,
IDE01172-IDE01168,Factory setting for increment for convertible volume levels-Increment for convertible volume levels,not installed,
IDE01173,Audio reduction factory setting,Yes,
IDE01174,Factory setting: visual display for park assist,OPS display,
IDE01236-MAS01580,Coolant recirculation pump-Activation,not coded/not installed,
IDE01236-MAS01634,Coolant recirculation pump-Supply voltage,not coded/not installed,
IDE01236-MAS06707,Coolant recirculation pump-Operating mode,not coded/not installed,
IDE01236-MAS07836,Coolant recirculation pump-Eng. delay. cool. shutdown,not coded/not installed,
IDE01236-MAS07837,Coolant recirculation pump-Last reason for local activity,not coded/not installed,
IDE01236-MAS07839,Coolant recirculation pump-Status feedback,not coded/not installed,
IDE01236-MAS12621,Coolant recirculation pump-Current draw (effective value),not coded/not installed,
IDE01266-MAS01580,Coolant shut-off valve-Activation,OFF,
IDE01266-MAS07806,Coolant shut-off valve-Spec. cond.,Open,
IDE01266-MAS12621,Coolant shut-off valve-Current draw (effective value),0, mA
IDE01268-MAS01464,Windshield wiper-Emergency running mode,not active,
IDE01268-MAS01632,Windshield wiper-Status,not active,
IDE01268-MAS02832,Windshield wiper-Malfunction status,not faulty,
IDE01268-MAS03006,Windshield wiper-Overload,not active,
IDE01268-MAS03638,Windshield wiper-Wipe speed,No wiping,
IDE01268-MAS06732,Windshield wiper-Status local activity,not active,
IDE01268-MAS06897,Windshield wiper-Wipe cycle counter,520,
IDE01268-MAS07055,Windshield wiper-Response error,not active,
IDE01268-MAS07998,Windshield wiper-park position,active,
IDE01268-MAS09379,Windshield wiper-Service position,not active,
IDE01268-MAS09595,Windshield wiper-Production mode,not active,
IDE01268-MAS09596,Windshield wiper-Debug Data,Not available,
IDE01268-MAS09597,Windshield wiper-Turn posn.,not active,
IDE01268-MAS09626,Windshield wiper-Status error validity,valid,
IDE01268-MAS09627,Windshield wiper-Error status: wiper 2,not faulty,
IDE01268-MAS09628,Windshield wiper-Overload: wiper 2,not active,
IDE01268-MAS09629,Windshield wiper-Status error validity: wiper 2,valid,
IDE01285,Counter of component protection malfunctions,00 00,
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,not activated,
IDE01411-MAS01426,Personalization 1 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01411-MAS01428,Personalization 1 for park assist-Speaker volume for front park assist,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,not active,
IDE01411-MAS12596,Personalization 1 for park assist-Park brake assistant,not activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01412-MAS01428,Personalization 2 for park assist-Speaker volume for front park assist,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,active,
IDE01412-MAS12596,Personalization 2 for park assist-Park brake assistant,not activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01413-MAS01428,Personalization 3 for park assist-Speaker volume for front park assist,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12596,Personalization 3 for park assist-Park brake assistant,not activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01414-MAS01428,Personalization 4 for park assist-Speaker volume for front park assist,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12596,Personalization 4 for park assist-Park brake assistant,not activated,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,OFF,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,OFF,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,not coded/not installed,
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,23.20, °C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,8.85, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not coded/not installed,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,OFF,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,not coded/not installed,
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,23.00, °C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,8.94, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded/not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,-0.01, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded/not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded/not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded/not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),not coded/not installed,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),not coded/not installed,
IDE01588,Driving direction,forwards,
IDE01632,System condition of park assist,not active,
IDE01633,Cause of park assist switching off,No shut-off requirement,
IDE01946,ESP intervention,OFF,
IDE01965-MAS06614,Parallel parking assistance button-Version,not coded/not installed,
IDE01965-MAS07693,Parallel parking assistance button-Button Status,not coded/not installed,
IDE01965-MAS07694,Parallel parking assistance button-Button status on CAN,Initialization/not installed,
IDE01965-MAS07699,Parallel parking assistance button-Status indicator light on CAN,OFF,
IDE01965-MAS08062,Parallel parking assistance button-Indicator light activation,not coded/not installed,
IDE01985-MAS06854,FAZIT identification test sum-Version,81,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,C9 FA 7C 33,
IDE01992-SFT00009,Installation list: current installations-Central Electrics,can be reached,
IDE01992-SFT00041,Installation list: current installations-Light Control Left,can be reached,
IDE01992-SFT00057,Installation list: current installations-Light Control Right,can be reached,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,can be reached,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,can be reached,
IDE01993-SFT00009,Control module reference number-Central Electrics,Central Electrics,
IDE01993-SFT00041,Control module reference number-Light Control Left,Light Control Left,
IDE01993-SFT00057,Control module reference number-Light Control Right,Light Control Right,
IDE01993-SFT00214,Control module reference number-Light Control Left 2,Light Control Left 2,
IDE01993-SFT00215,Control module reference number-Light Control Right 2,Light Control Right 2,
IDE01995-SFT00009,Control module protocol information-Central Electrics,ISO-TP,
IDE01995-SFT00041,Control module protocol information-Light Control Left,ISO-TP,
IDE01995-SFT00057,Control module protocol information-Light Control Right,ISO-TP,
IDE01995-SFT00214,Control module protocol information-Light Control Left 2,ISO-TP,
IDE01995-SFT00215,Control module protocol information-Light Control Right 2,ISO-TP,
IDE02384-SFT00009,Status of event memory-Central Electrics,OK,
IDE02384-SFT00041,Status of event memory-Light Control Left,OK,
IDE02384-SFT00057,Status of event memory-Light Control Right,OK,
IDE02384-SFT00214,Status of event memory-Light Control Left 2,OK,
IDE02384-SFT00215,Status of event memory-Light Control Right 2,OK,
IDE02455-MAS06911,Light function "Coming/Leaving Home"-Status Coming Home,not active,
IDE02455-MAS06912,Light function "Coming/Leaving Home"-Status Leaving Home,not active,
IDE02486,Data logger triggering,not active,
IDE02711-MAS09598,Rear Window Wiper-Request on CAN,OFF,
IDE02711-MAS09599,Rear Window Wiper-Error status via CAN,No error: no wiper activation,
IDE03008-IDE03726,Stop process prevented-Parallel Parking Assistance,passive,
IDE03008-MAS00825,Stop process prevented-Parking Aid Control Module,passive,
IDE03010-IDE03726,Number of prevented stop processes-Parallel Parking Assistance,0,
IDE03010-MAS00825,Number of prevented stop processes-Parking Aid Control Module,0,
IDE03011-IDE03726,Number of requested start processes-Parallel Parking Assistance,0,
IDE03011-MAS08785,Number of requested start processes-Parking aid,0,
IDE03111-MAS06885,Interior light-Terminal 30 for interior illumination,90, %
IDE03111-MAS06886,Interior light-Interior light delay (dimmer),0, %
IDE03111-MAS06986,Interior light-Footwell illumination rear,13, %
IDE03111-MAS06987,Interior light-Footwell illumination front,13, %
IDE03111-MAS09295,Interior light-ambient light.chan. 1,100, %
IDE03111-MAS09297,Interior light-Ambient illumination power supply,not coded/not installed,
IDE03111-MAS12622,Interior light-Terminal 30 for interior lighting: current draw (effect. value),5, mA
IDE03111-MAS12623,Interior light-Foot well illumination: rear: current draw (effective value),20, mA
IDE03111-MAS12624,Interior light-Foot well illumination: front: current draw (effective value),19, mA
IDE03111-MAS12625,Interior light-Ambient illumination channel 1: current draw (effective value),81, mA
IDE03111-MAS12626,Interior light-Supply for ambient illumination: current draw (effective value),not coded/not installed,
IDE03111-MAS12627,Interior light-Trunk illumination: front: current draw (effective value),not coded/not installed,
IDE03150-SFT00009,Readiness for bus sleep mode-Central Electrics,active,
IDE03150-SFT00041,Readiness for bus sleep mode-Light Control Left,Sleep mode,
IDE03150-SFT00057,Readiness for bus sleep mode-Light Control Right,Sleep mode,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03197-IDE08190,Rain/Light Recognition Sensor-Request exterior illumination,On,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,0, lx
IDE03197-MAS03637,Rain/Light Recognition Sensor-Rain quantity,0, %
IDE03197-MAS04806,Rain/Light Recognition Sensor-Splash,not active,
IDE03197-MAS06899,Rain/Light Recognition Sensor-Request glass close,not active,
IDE03197-MAS06900,Rain/Light Recognition Sensor-Status glass,closed,
IDE03197-MAS06998,Rain/Light Recognition Sensor-Request exterior illumination: inverse,OFF,
IDE03197-MAS06999,Rain/Light Recognition Sensor-Bright/dark information,Dark,
IDE03197-MAS07055,Rain/Light Recognition Sensor-Response error,not active,
IDE03197-MAS09630,Rain/Light Recognition Sensor-Qualification status of exterior lighting requirement,valid,
IDE03197-MAS09631,Rain/Light Recognition Sensor-Highway light requirement,OFF,
IDE03197-MAS09632,Rain/Light Recognition Sensor-Rain light requirement,OFF,
IDE03197-MAS09633,Rain/Light Recognition Sensor-Wiper speed requirement,No wiping,
IDE03197-MAS09634,Rain/Light Recognition Sensor-Adaptation error,not active,
IDE03197-MAS09635,Rain/Light Recognition Sensor-Error status rain sensors,not faulty,
IDE03197-MAS09636,Rain/Light Recognition Sensor-Error status light sensors,not faulty,
IDE03197-MAS10232,Rain/Light Recognition Sensor-Brightness ahead,0, lx
IDE03197-MAS10233,Rain/Light Recognition Sensor-Brightness ahead: boost,up to 6428 Lux,
IDE03602,Left front level control system sensor,Measured value not available,
IDE03604,Left rear level control system sensor,50.00, %
IDE03620,Front jounce travel,Measured value not available,
IDE03621,Rear jounce travel,-14, mm
IDE03622,Left headlight beam adjusting motor: status,no error,
IDE03623,Right headlight beam adjusting motor: status,no error,
IDE03628,Adjusting motor for variable left front lighting: status,Measured value not available,
IDE03629,Adjusting motor for variable right front lighting: status,Measured value not available,
IDE03630,Left headlight beam adjusting motor: specified value,-19.00, mm
IDE03631,Right headlight beam adjusting motor: specified value,-19.00, mm
IDE03632,Left-/right hand driving switch-over,Measured value not available,
IDE03638-IDE03717,static AFS light-Dim static left AFS light,0.00, %
IDE03638-IDE03718,static AFS light-Dim static right AFS light,0.00, %
IDE03662-MAS06614,ASR/ESP button-Version,Local data bus: operating unit 1,
IDE03662-MAS07693,ASR/ESP button-Button Status,Not operated,
IDE03662-MAS07694,ASR/ESP button-Button status on CAN,Not operated,
IDE03662-MAS07699,ASR/ESP button-Status indicator light on CAN,OFF,
IDE03662-MAS08062,ASR/ESP button-Indicator light activation,OFF,
IDE03663-MAS06614,-AUTO HOLD- Button-Version,not coded/not installed,
IDE03663-MAS07693,-AUTO HOLD- Button-Button Status,not coded/not installed,
IDE03663-MAS07694,-AUTO HOLD- Button-Button status on CAN,Initialization/not installed,
IDE03663-MAS07699,-AUTO HOLD- Button-Status indicator light on CAN,OFF,
IDE03663-MAS08062,-AUTO HOLD- Button-Indicator light activation,not coded/not installed,
IDE03669,Light distribution status,Measured value not available,
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,OFF,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded/not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded/not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded/not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded/not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,not coded/not installed,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,not coded/not installed,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded/not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,not coded/not installed,
IDE03680-MAS00043,Supply voltages-Supply voltage: Terminal 30,13.20, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,13.21, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,13.25, V
IDE03680-MAS06490,Supply voltages-Terminal 15 load,13.19, V
IDE03680-MAS06838,Supply voltages-Supply voltage: terminal 30 left,13.19, V
IDE03680-MAS06839,Supply voltages-Supply voltage terminal 30 right,13.16, V
IDE03680-MAS06840,Supply voltages-Supply voltage Terminal 30 - 4,13.22, V
IDE03680-MAS06841,Supply voltages-Supply voltage Terminal 30 - 5,13.21, V
IDE03680-MAS06842,Supply voltages-Supply voltage Terminal 30 - 6,13.13, V
IDE03727,Variable left front lighting specified position,Measured value not available,
IDE03728,Variable right front lighting specified position,Measured value not available,
IDE03784,Temporary function limitation due to environmental influences,No,
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),53.20, %
IDE04343-SFT00009,Bus identification-Central Electrics,Busmaster,
IDE04343-SFT00041,Bus identification-Light Control Left,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Light Control Right,AFS/From light data bus,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04806-MAS06614,Driving profile selection button-Version,Local data bus: operating unit 1,
IDE04806-MAS07693,Driving profile selection button-Button Status,Not operated,
IDE04806-MAS07694,Driving profile selection button-Button status on CAN,Not operated,
IDE04923-MAS08125,Turn signal control-Left front turn signal bulb: status,OFF,
IDE04923-MAS08127,Turn signal control-Right front turn signal bulb: status,OFF,
IDE04923-MAS08131,Turn signal control-Left turn signal lights: clock,OFF,
IDE04923-MAS08132,Turn signal control-Right turn signal lights: clock,OFF,
IDE05042-MAS06614,Emergency flasher button-Version,Discreet wire,
IDE05042-MAS07693,Emergency flasher button-Button Status,Not operated,
IDE05042-MAS07694,Emergency flasher button-Button status on CAN,Not operated,
IDE05042-MAS08062,Emergency flasher button-Indicator light activation,OFF,
IDE05071-MAS06614,Lane change assistance button-Version,not coded/not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not coded/not installed,
IDE05071-MAS07694,Lane change assistance button-Button status on CAN,Initialization/not installed,
IDE05071-MAS08062,Lane change assistance button-Indicator light activation,not coded/not installed,
IDE05534-MAS01580,Headlamp washer system-Activation,not coded/not installed,
IDE05534-MAS12621,Headlamp washer system-Current draw (effective value),not coded/not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,21.80, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,21.50, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,67, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,4.80, °C
IDE06091-MAS07055,Humidity sensor: internal-Response error,not active,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,not active,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06644-MAS06993,Vehicle positioning system-Request signal horn,not coded/not installed,
IDE06644-MAS09570,Vehicle positioning system-Parking light request,not coded/not installed,
IDE06644-MAS09571,Vehicle positioning system-Low beam request,not coded/not installed,
IDE06752-MAS06614,Hill descent control button-Version,Local data bus: operating unit 1,
IDE06752-MAS07693,Hill descent control button-Button Status,not installed,
IDE06752-MAS07694,Hill descent control button-Button status on CAN,Initialization/not installed,
IDE06752-MAS07699,Hill descent control button-Status indicator light on CAN,OFF,
IDE06752-MAS08062,Hill descent control button-Indicator light activation,OFF,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07991-MAS01580,A/C clutch-Activation,not coded/not installed,
IDE07991-MAS07919,A/C clutch-Min current consumption: spec value,not coded/not installed,
IDE07991-MAS12621,A/C clutch-Current draw (effective value),not coded/not installed,
IDE07991-MAS12776,A/C clutch-Spec.val. min.cur. draw prior to rec.op.circ./short circ. to B+,not coded/not installed,
IDE07991-MAS12778,A/C clutch-Act.val. min.curr. draw prior to recogn open circ/sh circ to B+,not coded/not installed,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS02832,Left cabin heater-Malfunction status,not coded/not installed,
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08125-MAS07055,Left cabin heater-Response error,not coded/not installed,
IDE08125-MAS09644,Left cabin heater-Vent temperature,not coded/not installed,
IDE08125-MAS12677,Left cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS02832,Right cabin heater-Malfunction status,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS07055,Right cabin heater-Response error,not coded/not installed,
IDE08126-MAS09644,Right cabin heater-Vent temperature,not coded/not installed,
IDE08126-MAS12677,Right cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08196-IDE01351,Terminal control-Terminal 75 status,On,
IDE08196-MAS06982,Terminal control-Terminal 15 status signal,On,
IDE08196-MAS07720,Terminal control-Terminal 15 via CAN,On,
IDE08196-MAS08123,Terminal control-Term 75: qualification,OFF,
IDE08343,Immobilizer Challenge,38 02 20 8A,
IDE08364-MAS01447,Left seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE08364-MAS01448,Left seat backrest fan 1: activation-Specified value,not coded/not installed,
IDE08365-MAS01447,Left seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08365-MAS01448,Left seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Specified value,not coded/not installed,
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08368-MAS01447,Right seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE08368-MAS01448,Right seat backrest fan 1: activation-Specified value,not coded/not installed,
IDE08369-MAS01447,Right seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08369-MAS01448,Right seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08370-MAS01447,Right seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE08370-MAS01448,Right seat cushion fan 1: activation-Specified value,not coded/not installed,
IDE08371-MAS01447,Right seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08376-MAS01580,Right daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08376-MAS01737,Right daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08376-MAS12621,Right daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08377-MAS01580,Left daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08377-MAS01737,Left daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08377-MAS12621,Left daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08378-MAS01580,Right front turn signal bulb-Activation,not coded/not installed,
IDE08378-MAS01737,Right front turn signal bulb-Diagnosis,not coded/not installed,
IDE08378-MAS12621,Right front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08379-MAS01580,Left front turn signal bulb-Activation,not coded/not installed,
IDE08379-MAS01737,Left front turn signal bulb-Diagnosis,not coded/not installed,
IDE08379-MAS12621,Left front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08380-MAS01580,Right side marker lamp bulb-Activation,not coded/not installed,
IDE08380-MAS01737,Right side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08380-MAS12621,Right side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08381-MAS01580,Left side marker lamp bulb-Activation,not coded/not installed,
IDE08381-MAS01737,Left side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08381-MAS12621,Left side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08382-MAS01580,Right front side marker lamp bulb-Activation,not coded/not installed,
IDE08382-MAS01737,Right front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08382-MAS12621,Right front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08383-MAS01580,Left front side marker lamp bulb-Activation,not coded/not installed,
IDE08383-MAS01737,Left front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08383-MAS12621,Left front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08384-MAS01580,Right daytime running lamp bulb-Activation,not coded/not installed,
IDE08384-MAS01737,Right daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08384-MAS12621,Right daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08385-MAS01580,Left daytime running lamp bulb-Activation,not coded/not installed,
IDE08385-MAS01737,Left daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08385-MAS12621,Left daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08386-MAS01580,Right low beam headlamp bulb-Activation,0.00, %
IDE08386-MAS01737,Right low beam headlamp bulb-Diagnosis,no error,
IDE08386-MAS12621,Right low beam headlamp bulb-Current draw (effective value),0, mA
IDE08387-MAS01580,Left low beam headlamp bulb-Activation,0.00, %
IDE08387-MAS01737,Left low beam headlamp bulb-Diagnosis,no error,
IDE08387-MAS12621,Left low beam headlamp bulb-Current draw (effective value),0, mA
IDE08388-MAS01580,Right high beam headlamp bulb-Activation,not coded/not installed,
IDE08388-MAS01737,Right high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08388-MAS12621,Right high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08389-MAS01580,Left high beam headlamp bulb-Activation,not coded/not installed,
IDE08389-MAS01737,Left high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08389-MAS12621,Left high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08390-MAS01580,Right fog light bulb-Activation,not coded/not installed,
IDE08390-MAS01737,Right fog light bulb-Diagnosis,not coded/not installed,
IDE08390-MAS12621,Right fog light bulb-Current draw (effective value),not coded/not installed,
IDE08391-MAS01580,Left fog light bulb-Activation,not coded/not installed,
IDE08391-MAS01737,Left fog light bulb-Diagnosis,not coded/not installed,
IDE08391-MAS12621,Left fog light bulb-Current draw (effective value),not coded/not installed,
IDE08392-MAS01580,Right LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08392-MAS01737,Right LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08392-MAS12621,Right LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08393-MAS01580,Left LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08393-MAS01737,Left LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08393-MAS12621,Left LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08394-MAS01580,Right LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08394-MAS01737,Right LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08394-MAS12621,Right LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08395-MAS01580,Left LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08395-MAS01737,Left LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08395-MAS12621,Left LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08396-MAS01580,Headlights right: supply-Activation,100, %
IDE08396-MAS01737,Headlights right: supply-Diagnosis,no error,
IDE08396-MAS12621,Headlights right: supply-Current draw (effective value),79, mA
IDE08397-MAS01580,Headlights left: supply-Activation,100, %
IDE08397-MAS01737,Headlights left: supply-Diagnosis,no error,
IDE08397-MAS12621,Headlights left: supply-Current draw (effective value),79, mA
IDE08402-IDE05742,Light switch-Light switch position,Parking light,
IDE08402-IDE07956,Light switch-redundant signal line,Medium,
IDE08402-MAS03866,Light switch-Head-up display button,Not operated,
IDE08402-MAS03868,Light switch-Position of eye box,0,
IDE08402-MAS06887,Light switch-Light switch position on CAN,Parking light,
IDE08402-MAS06888,Light switch-Fog light button,Not operated,
IDE08402-MAS06889,Light switch-Rear fog light button,Not operated,
IDE08402-MAS06890,Light switch-Night vision system button,Not operated,
IDE08402-MAS06891,Light switch-Control for Eyebox position,no operation,
IDE08404-IDE01351,Local data bus 1: information-Terminal 75 status,On,
IDE08404-MAS00370,Local data bus 1: information-Vehicle speed,0.00, km/h
IDE08404-MAS03679,Local data bus 1: information-Terminal 15 status,On,
IDE08404-MAS06495,Local data bus 1: information-Engine hood contact switch,closed,
IDE08405-MAS05030,Outside air temperature sensor-Resistance,0.97, kOhm
IDE08405-MAS08858,Outside air temperature sensor-Outside air temperature on CAN,26.00, °C
IDE08408-MAS12845,Hood contact-Switch 1,closed,
IDE08408-MAS12846,Hood contact-Switch 2,closed,
IDE08434-MAS01580,Right turn signal light bulb-Activation,not coded/not installed,
IDE08434-MAS01737,Right turn signal light bulb-Diagnosis,not coded/not installed,
IDE08434-MAS12621,Right turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08435-MAS01580,Left turn signal light bulb-Activation,not coded/not installed,
IDE08435-MAS01737,Left turn signal light bulb-Diagnosis,not coded/not installed,
IDE08435-MAS12621,Left turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08441-MAS06992,Control module for steering col electronics: requirements-Request wiping,Intermittent operation,
IDE08441-MAS06993,Control module for steering col electronics: requirements-Request signal horn,OFF,
IDE08441-MAS09575,Control module for steering col electronics: requirements-High beam request,OFF,
IDE08441-MAS09576,Control module for steering col electronics: requirements-Wash request,OFF,
IDE08441-MAS09577,Control module for steering col electronics: requirements-Rear interval wash request,OFF,
IDE08441-MAS09586,Control module for steering col electronics: requirements-Headlight flasher request,OFF,
IDE08441-MAS09587,Control module for steering col electronics: requirements-Headlight washer request,OFF,
IDE08441-MAS09600,Control module for steering col electronics: requirements-Request to flashing left,not active,
IDE08441-MAS09601,Control module for steering col electronics: requirements-Request to flashing right,not active,
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0, mA
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0, mA
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,not coded/not installed,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,not coded/not installed,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,not coded/not installed,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,not coded/not installed,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE08502-MAS01580,A/C compressor regulator valve-Activation,53, %
IDE08502-MAS09777,A/C compressor regulator valve-Specified current,487, mA
IDE08502-MAS09780,A/C compressor regulator valve-Supply Highside,On,
IDE08502-MAS12632,A/C compressor regulator valve-Current draw (mean value),484, mA
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,Measured value not available,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,Measured value not available,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,Measured value not available,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,Measured value not available,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,Measured value not available,
IDE08543-MAS00370,Garage door opener: last programming-Vehicle speed,below threshold,
IDE08543-MAS01240,Garage door opener: last programming-Programming status,0F,
IDE08543-MAS02246,Garage door opener: last programming-Timeout,Not reached,
IDE08543-MAS02949,Garage door opener: last programming-Frequency,05 84 B2,
IDE08543-MAS03159,Garage door opener: last programming-Manufacturer,FF,
IDE08543-MAS04184,Garage door opener: last programming-Cancellation by user,Yes,
IDE08543-MAS06670,Garage door opener: last programming-Channel,Channel 2,
IDE08543-MAS09308,Garage door opener: last programming-Error status and modulation,10010000 ,
IDE08543-MAS10442,Garage door opener: last programming-Programming antenna,External antenna,
IDE08544-MAS00370,Garage door opener: second-to-last progr.-Vehicle speed,below threshold,
IDE08544-MAS01240,Garage door opener: second-to-last progr.-Programming status,00,
IDE08544-MAS02246,Garage door opener: second-to-last progr.-Timeout,Not reached,
IDE08544-MAS02949,Garage door opener: second-to-last progr.-Frequency,Programming not performed,
IDE08544-MAS03159,Garage door opener: second-to-last progr.-Manufacturer,00,
IDE08544-MAS04184,Garage door opener: second-to-last progr.-Cancellation by user,No,
IDE08544-MAS06670,Garage door opener: second-to-last progr.-Channel,Programming not performed,
IDE08544-MAS09308,Garage door opener: second-to-last progr.-Error status and modulation,01000000 ,
IDE08544-MAS10442,Garage door opener: second-to-last progr.-Programming antenna,External antenna,
IDE08545-MAS00370,Garage door opener: third-to-last progr.-Vehicle speed,below threshold,
IDE08545-MAS01240,Garage door opener: third-to-last progr.-Programming status,00,
IDE08545-MAS02246,Garage door opener: third-to-last progr.-Timeout,Not reached,
IDE08545-MAS02949,Garage door opener: third-to-last progr.-Frequency,Programming not performed,
IDE08545-MAS03159,Garage door opener: third-to-last progr.-Manufacturer,00,
IDE08545-MAS04184,Garage door opener: third-to-last progr.-Cancellation by user,No,
IDE08545-MAS06670,Garage door opener: third-to-last progr.-Channel,Programming not performed,
IDE08545-MAS09308,Garage door opener: third-to-last progr.-Error status and modulation,00000000 ,
IDE08545-MAS10442,Garage door opener: third-to-last progr.-Programming antenna,External antenna,
IDE08622,Garage door opener: supply voltage,13.33, V
IDE08795-MAS06614,Button for rear window shade-Version,not coded/not installed,
IDE08795-MAS07693,Button for rear window shade-Button Status,not coded/not installed,
IDE08795-MAS07694,Button for rear window shade-Button status on CAN,Initialization/not installed,
IDE08948-MAS01632,Electrically Adjustable Steering Column-Status,not coded/not installed,
IDE08948-MAS06732,Electrically Adjustable Steering Column-Status local activity,not coded/not installed,
IDE08948-MAS09493,Electrically Adjustable Steering Column-Position: vertical,not coded/not installed,
IDE08948-MAS09494,Electrically Adjustable Steering Column-Position: axial,not coded/not installed,
IDE08948-MAS09495,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation up,not coded/not installed,
IDE08948-MAS09496,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation down,not coded/not installed,
IDE08948-MAS09497,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation out,not coded/not installed,
IDE08948-MAS09498,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation in,not coded/not installed,
IDE08948-MAS09501,Electrically Adjustable Steering Column-Entry assistance button,not coded/not installed,
IDE08948-MAS12678,Electrically Adjustable Steering Column-Motor for vertical adjustment: current draw (effective value),not coded/not installed,
IDE08948-MAS12679,Electrically Adjustable Steering Column-Motor for axial adjustment: current draw (effective value),not coded/not installed,
IDE08953,Garage door opener: country code,North America,
IDE08957-MAS01632,Supply for power outlets-Status,On,
IDE08957-MAS04445,Supply for power outlets-Relay output voltage,13.25, V
IDE08957-MAS07309,Supply for power outlets-Maximum current draw,2.80, A
IDE08957-MAS08025,Supply for power outlets-Output to input voltage ratio with relay switched off,44.50, %
IDE08957-MAS12621,Supply for power outlets-Current draw (effective value),14, mA
IDE08960-MAS08026,Status: control heads for driving and comfort functions-Control head for driving and comfort functions,ready for operation,
IDE08960-MAS08027,Status: control heads for driving and comfort functions-Control head 2 for driving and comfort functions,not coded/not installed,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,not installed,
IDE08962-IDE08357,Installation info: seat ventilation-Left seat backrest fan 2,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,not installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,not installed,
IDE08962-IDE08361,Installation info: seat ventilation-Right seat backrest fan 2,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,not installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE08978-MAS01580,Windshield washer pump-Activation,OFF,
IDE08978-MAS09022,Windshield washer pump-PWM value,0, %
IDE08978-MAS12621,Windshield washer pump-Current draw (effective value),0, mA
IDE08979-MAS06614,Valet parking lock button-Version,Discreet wire,
IDE08979-MAS07693,Valet parking lock button-Button Status,Not operated,
IDE08979-MAS07694,Valet parking lock button-Button status on CAN,Not operated,
IDE08979-MAS08062,Valet parking lock button-Indicator light activation,OFF,
IDE08980-MAS06614,Button for rear spoiler adjustment-Version,not coded/not installed,
IDE08980-MAS07693,Button for rear spoiler adjustment-Button Status,not coded/not installed,
IDE08980-MAS07694,Button for rear spoiler adjustment-Button status on CAN,Initialization/not installed,
IDE08980-MAS07699,Button for rear spoiler adjustment-Status indicator light on CAN,OFF,
IDE08980-MAS08062,Button for rear spoiler adjustment-Indicator light activation,not coded/not installed,
IDE08981-MAS06614,Front display open/close button-Version,Local data bus: operating unit 1,
IDE08981-MAS07693,Front display open/close button-Button Status,Not operated,
IDE08981-MAS07694,Front display open/close button-Button status on CAN,Not operated,
IDE08982-MAS06614,Button for start/stop operation/electrical driving-Version,Local data bus: operating unit 1,
IDE08982-MAS07693,Button for start/stop operation/electrical driving-Button Status,Not operated,
IDE08982-MAS07694,Button for start/stop operation/electrical driving-Button status on CAN,Not operated,
IDE08982-MAS08062,Button for start/stop operation/electrical driving-Indicator light activation,OFF,
IDE08983-MAS06614,Driving profile selection button 2-Version,Local data bus: operating unit 1,
IDE08983-MAS07693,Driving profile selection button 2-Button Status,Not operated,
IDE08983-MAS07694,Driving profile selection button 2-Button status on CAN,Not operated,
IDE08998-MAS06901,Driver info-Washer fluid level,OK,
IDE08998-MAS08063,Driver info-Coolant level from sensor for low coolant display,OK,
IDE08998-MAS08064,Driver info-Coolant level from sensor 2 for low coolant display,OK,
IDE08998-MAS08065,Driver info-Brake fluid level,OK,
IDE08998-MAS08122,Driver info-Brake lining,OK,
IDE08999-MAS08124,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: request,OFF,
IDE08999-MAS08125,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: status,OFF,
IDE08999-MAS08126,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: request,OFF,
IDE08999-MAS08127,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: status,OFF,
IDE08999-MAS08128,Control modules for light activation: turn sig ctrl-Left flashing function,not active,
IDE08999-MAS08129,Control modules for light activation: turn sig ctrl-Right flashing function,not active,
IDE08999-MAS08133,Control modules for light activation: turn sig ctrl-Flashing mode,normal,
IDE09000-MAS01580,Control module for light activation: left: supply-Activation,100, %
IDE09000-MAS01737,Control module for light activation: left: supply-Diagnosis,no error,
IDE09000-MAS12621,Control module for light activation: left: supply-Current draw (effective value),326, mA
IDE09001-MAS01580,Control module for light activation: right: supply-Activation,100, %
IDE09001-MAS01737,Control module for light activation: right: supply-Diagnosis,no error,
IDE09001-MAS12621,Control module for light activation: right: supply-Current draw (effective value),205, mA
IDE09234-MAS01580,Subfloor lighting-Activation,not coded/not installed,
IDE09234-MAS12621,Subfloor lighting-Current draw (effective value),not coded/not installed,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,Not operated,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,Not operated,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,Not operated,
IDE09887-MAS01580,Right daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09887-MAS01737,Right daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09887-MAS12621,Right daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09888-MAS01580,Left daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09888-MAS01737,Left daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09888-MAS12621,Left daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09920-MAS06614,Special Purpose Vehicle Control Module-Version,not coded/not installed,
IDE09920-MAS06992,Special Purpose Vehicle Control Module-Request wiping,not coded/not installed,
IDE09920-MAS06993,Special Purpose Vehicle Control Module-Request signal horn,not coded/not installed,
IDE09920-MAS09569,Special Purpose Vehicle Control Module-Remote control status,not coded/not installed,
IDE09920-MAS09570,Special Purpose Vehicle Control Module-Parking light request,not coded/not installed,
IDE09920-MAS09571,Special Purpose Vehicle Control Module-Low beam request,not coded/not installed,
IDE09920-MAS09572,Special Purpose Vehicle Control Module-Intermittent high beam request,not coded/not installed,
IDE09920-MAS09573,Special Purpose Vehicle Control Module-Footwell illumination request,not coded/not installed,
IDE09920-MAS09574,Special Purpose Vehicle Control Module-Interior illumination request,not coded/not installed,
IDE09920-MAS09575,Special Purpose Vehicle Control Module-High beam request,not coded/not installed,
IDE09920-MAS09576,Special Purpose Vehicle Control Module-Wash request,not coded/not installed,
IDE09920-MAS09577,Special Purpose Vehicle Control Module-Rear interval wash request,not coded/not installed,
IDE09920-MAS09586,Special Purpose Vehicle Control Module-Headlight flasher request,not coded/not installed,
IDE09920-MAS09588,Special Purpose Vehicle Control Module-Emerg. sig. flasher request,not coded/not installed,
IDE09920-MAS09589,Special Purpose Vehicle Control Module-Daytime running light deactivation req.,not coded/not installed,
IDE09920-MAS09590,Special Purpose Vehicle Control Module-Suppression of interior illumination request,not coded/not installed,
IDE09921-MAS01632,Automatic high beam assist control module-Status,not coded/not installed,
IDE09921-MAS02832,Automatic high beam assist control module-Malfunction status,not coded/not installed,
IDE09921-MAS09580,Automatic high beam assist control module-Sensor status,not coded/not installed,
IDE09921-MAS09581,Automatic high beam assist control module-PWM specs.,not coded/not installed,
IDE09921-MAS09582,Automatic high beam assist control module-Status on combi,not coded/not installed,
IDE09921-MAS09583,Automatic high beam assist control module-error status on combi,not coded/not installed,
IDE09921-MAS09584,Automatic high beam assist control module-Sensor status on combi,not coded/not installed,
IDE09921-MAS09585,Automatic high beam assist control module-Turn up headlights request,not coded/not installed,
IDE09922-MAS01448,Static headlight range adjustment-Specified value,not coded/not installed,
IDE09922-MAS09527,Static headlight range adjustment-Activation voltage: act. value,not coded/not installed,
IDE09922-MAS10074,Static headlight range adjustment-Supply voltage: actual value,not coded/not installed,
IDE09922-MAS10075,Static headlight range adjustment-Activation voltage/supply voltage ratio,not coded/not installed,
IDE09922-MAS12621,Static headlight range adjustment-Current draw (effective value),not coded/not installed,
IDE09933,Multifunction steerg. wheel: request signal horn,OFF,
IDE09934-MAS09591,Shift lever / selector lever position-Signal transm. ctrl. mod.,Selector lever in position P,
IDE09934-MAS09592,Shift lever / selector lever position-Signal engine ctrl. mod.,Unknown (9),
IDE09936-MAS01580,Right daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09936-MAS01737,Right daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09936-MAS12621,Right daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09937-MAS01580,Left daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09937-MAS01737,Left daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09937-MAS12621,Left daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09938-MAS01580,Right front turn signal bulb 2-Activation,not coded/not installed,
IDE09938-MAS01737,Right front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09938-MAS12621,Right front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09939-MAS01580,Left front turn signal bulb 2-Activation,not coded/not installed,
IDE09939-MAS01737,Left front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09939-MAS12621,Left front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09940-MAS01580,Right side marker bulb 2-Activation,not coded/not installed,
IDE09940-MAS01737,Right side marker bulb 2-Diagnosis,not coded/not installed,
IDE09940-MAS12621,Right side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09941-MAS01580,Left side marker bulb 2-Activation,not coded/not installed,
IDE09941-MAS01737,Left side marker bulb 2-Diagnosis,not coded/not installed,
IDE09941-MAS12621,Left side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09955-MAS07693,Dimming interior rearview mirror-Button Status,Not operated,
IDE09955-MAS09651,Dimming interior rearview mirror-Error status sensor front,not faulty,
IDE09955-MAS09652,Dimming interior rearview mirror-Error status sensor rear,not faulty,
IDE09955-MAS10386,Dimming interior rearview mirror-Dim. value spec.: exterior mirror,0.00, V
IDE09958-MAS01580,Right low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09958-MAS01737,Right low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09958-MAS12621,Right low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE09959-MAS01580,Left low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09959-MAS01737,Left low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09959-MAS12621,Left low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE10085-MAS09757,Switch and display illumination-Terminal 58xs on CAN,58, %
IDE10085-MAS09815,Switch and display illumination-Terminal 58xd on CAN,58,
IDE10085-MAS09816,Switch and display illumination-Phototransistor wert,2,
IDE10085-MAS09817,Switch and display illumination-Terminal 58xs,58.00, %
IDE10085-MAS09819,Switch and display illumination-T. 58xs: Diagnosis,no error,
IDE10085-MAS09820,Switch and display illumination-Terminal 58xt,58.00, %
IDE10085-MAS09822,Switch and display illumination-T. 58xt: Diagnosis,no error,
IDE10085-MAS09823,Switch and display illumination-Driver's request (light switch),54, %
IDE10085-MAS09824,Switch and display illumination-Driver's request (Kombi),0, %
IDE10085-MAS09825,Switch and display illumination-Driver's request (MMI),0, %
IDE10085-MAS09826,Switch and display illumination-Driver's request on CAN,54, %
IDE10085-MAS09827,Switch and display illumination-Terminal 58xt on CAN,58, %
IDE10085-MAS12628,Switch and display illumination-Terminal 58xs: current draw (effective value),37, mA
IDE10085-MAS12629,Switch and display illumination-Terminal 58xt: current draw (effective value),33, mA
IDE10219-MAS01580,High/low tone horn-Activation,OFF,
IDE10219-MAS12621,High/low tone horn-Current draw (effective value),0, mA
IDE10260-MAS01448,Static headlight range adjustment: spec./counter-Specified value,not coded/not installed,
IDE10260-MAS10076,Static headlight range adjustment: spec./counter-Step index,not coded/not installed,
IDE10260-MAS11358,Static headlight range adjustment: spec./counter-Number of adjustments left motor,0,
IDE10260-MAS11359,Static headlight range adjustment: spec./counter-Number of adjustments right motor,0,
IDE10327-MAS01632,Cupholder with heating and cooling element-Status,not coded/not installed,
IDE10327-MAS01968,Cupholder with heating and cooling element-Fan,not coded/not installed,
IDE10327-MAS02819,Cupholder with heating and cooling element-CURRENT temperature,not coded/not installed,
IDE10327-MAS02832,Cupholder with heating and cooling element-Malfunction status,not coded/not installed,
IDE10327-MAS10303,Cupholder with heating and cooling element-Heating function indicator lamp,not coded/not installed,
IDE10327-MAS10304,Cupholder with heating and cooling element-Cooling function indicator lamp,not coded/not installed,
IDE10327-MAS10305,Cupholder with heating and cooling element-Light for residual heat display,not coded/not installed,
IDE10327-MAS10333,Cupholder with heating and cooling element-Heat function button,not coded/not installed,
IDE10327-MAS10334,Cupholder with heating and cooling element-Cooling function button,not coded/not installed,
IDE10327-MAS10336,Cupholder with heating and cooling element-Peltier element,not coded/not installed,
IDE10327-MAS10337,Cupholder with heating and cooling element-Peltier element: PWM value,not coded/not installed,
IDE10338,Ctrl. motor for left headlight range adjust.: act. value,-20.00, mm
IDE10339,Ctrl. motor for right headlight range adjust.: act. value,-20.00, mm
IDE10340-IDE00104,Roof electronics control module-DTC,0,
IDE10340-MAS01634,Roof electronics control module-Supply voltage,13.20, V
IDE10340-MAS02832,Roof electronics control module-Malfunction status,not faulty,
IDE10340-MAS05946,Roof electronics control module-Actual temp.,37, °C
IDE10340-MAS09113,Roof electronics control module-Maximum temperature,87, °C
IDE10343-MAS01795,Roof electronics control module: dim. value-Front interior light,0, %
IDE10343-MAS10432,Roof electronics control module: dim. value-Uplight: front,0, %
IDE10343-MAS10433,Roof electronics control module: dim. value-Search rings,0, %
IDE10343-MAS10434,Roof electronics control module: dim. value-indicator lights,6, %
IDE10344-MAS10485,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: dim. value,0, %
IDE10344-MAS10486,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: diagnosis,no error,
IDE10344-MAS10487,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: dim. value,0, %
IDE10344-MAS10488,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: diagnosis,no error,
IDE10344-MAS10489,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: dim. value,0, %
IDE10344-MAS10490,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: diagnosis,no error,
IDE10344-MAS10491,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: dim. value,0, %
IDE10344-MAS10492,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: diagnosis,no error,
IDE10344-MAS10493,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10494,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: diagnosis,no error,
IDE10344-MAS10495,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10496,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: diagnosis,no error,
IDE10344-MAS10497,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: dim. value,0, %
IDE10344-MAS10498,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: diagnosis,Unknown (0),
IDE10345-MAS10416,Roof electronics control module: button-Front interior light button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10418,Roof electronics control module: button-Front button for rear reading light,Not operated,
IDE10345-MAS10419,Roof electronics control module: button-Front reading lamp button: left,Not operated,
IDE10345-MAS10420,Roof electronics control module: button-Front reading lamp button: right,Not operated,
IDE10345-MAS10421,Roof electronics control module: button-Left rear reading lamp switch,Not operated,
IDE10345-MAS10422,Roof electronics control module: button-Right rear reading lamp button,Not operated,
IDE10345-MAS10423,Roof electronics control module: button-Left reading light button: 3rd seat row,Not operated,
IDE10345-MAS10424,Roof electronics control module: button-Right reading light button: 3rd seat row,Not operated,
IDE10345-MAS10425,Roof electronics control module: button-Emergency call button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10346-MAS10427,Roof electronics control module: indicator lights-Indicator lamp for interior light: front,OFF,
IDE10346-MAS10428,Roof electronics control module: indicator lights-Indicator light for door contact switching,OFF,
IDE10346-MAS10429,Roof electronics control module: indicator lights-Indicator lamp for front reading light,OFF,
IDE10346-MAS10430,Roof electronics control module: indicator lights-Indicator light for emerg. call,On,
IDE10346-MAS10431,Roof electronics control module: indicator lights-Indicator light for roadside assist.,OFF,
IDE10360-MAS01442,A/C compressor speed sensor-Compressor speed,not coded/not installed,
IDE10360-MAS10225,A/C compressor speed sensor-Signal level,not coded/not installed,
IDE10360-MAS10455,A/C compressor speed sensor-Deviation of compressor speed from specified RPM,not coded/not installed,
IDE10361-MAS06905,Driver information sensor-Washer fluid level sensor,3.16, kOhm
IDE10361-MAS06906,Driver information sensor-Sensor for inadequate coolant level display,1.41, kOhm
IDE10361-MAS07003,Driver information sensor-Sensor 2 for inadequate coolant level display,not coded/not installed,
IDE10482-MAS01632,Release for external systems-Status,not coded/not installed,
IDE10482-MAS07929,Release for external systems-Power quota setting by energy management,not coded/not installed,
IDE10482-MAS10746,Release for external systems-Installation info.: external system,no system,
IDE10645,Status of optical display park assist,OFF,
IDE10808-MAS06614,Directional stabilization assistance button-Version,not coded/not installed,
IDE10808-MAS07693,Directional stabilization assistance button-Button Status,not coded/not installed,
IDE10808-MAS07694,Directional stabilization assistance button-Button status on CAN,Initialization/not installed,
IDE10808-MAS08062,Directional stabilization assistance button-Indicator light activation,OFF,
IDE10810-MAS06614,Button for side view camera-Version,not coded/not installed,
IDE10810-MAS07693,Button for side view camera-Button Status,not coded/not installed,
IDE10810-MAS07694,Button for side view camera-Button status on CAN,Initialization/not installed,
IDE11273-MAS10360,Control unit 2 for driv.and convenience funct.: special funct.-Lift button for vehicle leveling,not coded/not installed,
IDE11273-MAS10361,Control unit 2 for driv.and convenience funct.: special funct.-Lower button for vehicle leveling,not coded/not installed,
IDE11273-MAS12379,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: actual mode,not coded/not installed,
IDE11273-MAS12380,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: mode setting,not coded/not installed,
IDE11273-MAS12499,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for load level,not coded/not installed,
IDE11273-MAS12500,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for low level,not coded/not installed,
IDE11273-MAS12501,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for high level,not coded/not installed,
IDE11273-MAS12502,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for special off-road level,not coded/not installed,
IDE11274-MAS08932,Operating controls for sunroof/tilt roof and roof blind-Sunroof shade button,not coded/not installed,
IDE11274-MAS12383,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof,not coded/not installed,
IDE11274-MAS12515,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof: rear,not coded/not installed,
IDE11274-MAS12516,Operating controls for sunroof/tilt roof and roof blind-Button sunroof shade button: rear,not coded/not installed,
IDE11301-MAS12561,Number of events: headlight theft monitoring-Theft: left headlight suspected due to cold monitoring,0,
IDE11301-MAS12562,Number of events: headlight theft monitoring-Theft: right headlight suspected due to cold monitoring,0,
IDE11301-MAS12563,Number of events: headlight theft monitoring-Theft: left headlight confirmed due to heat monitoring,0,
IDE11301-MAS12564,Number of events: headlight theft monitoring-Theft: right headlight confirmed due to heat monitoring,0,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,0, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,0, W/m²
IDE11979,Parking distance control secure condition: cause,00 00,
IDE12156,Parking aid: system status master module,00000000 00000000 00000000 11111111 ,
IDE12318-MAS01580,Left signature light bulb: supply-Activation,not coded/not installed,
IDE12318-MAS01737,Left signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12318-MAS12621,Left signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12319-MAS01580,Right signature light bulb: supply-Activation,not coded/not installed,
IDE12319-MAS01737,Right signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12319-MAS12621,Right signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12342-MAS06614,Button engine sound generation-Version,not coded/not installed,
IDE12342-MAS07693,Button engine sound generation-Button Status,not coded/not installed,
IDE12342-MAS07694,Button engine sound generation-Button status on CAN,Initialization/not installed,
IDE12342-MAS07699,Button engine sound generation-Status indicator light on CAN,ERROR,
IDE12342-MAS08062,Button engine sound generation-Indicator light activation,not coded/not installed,
IDE12826-MAS07693,Engine noise selection button-Button Status,not coded/not installed,
IDE12826-MAS07694,Engine noise selection button-Button status on CAN,Not operated,
IDE12882-MAS06614,Rear window shade button 2-Version,not coded/not installed,
IDE12882-MAS07693,Rear window shade button 2-Button Status,not coded/not installed,
IDE12882-MAS07694,Rear window shade button 2-Button status on CAN,Initialization/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06997,Head area heater-Outside temperature: filtered,Temp. sensor not installed,
IDE80251-MAS09637,Head area heater-Head area heater left: release,not coded/not installed,
IDE80251-MAS09638,Head area heater-Head area heater right: release,not coded/not installed,
IDE80251-MAS09639,Head area heater-Head area heater left: output DTM,not coded/not installed,
IDE80251-MAS09640,Head area heater-Head area heater right: output DTM,not coded/not installed,
IDE80251-MAS09641,Head area heater-Interior temperature,Temp. sensor not installed,
IDE80251-MAS09642,Head area heater-Adaptation vent temperature,not coded/not installed,
IDE80251-MAS09643,Head area heater-Adaptation fan speed,not coded/not installed,
IDE80251-MAS09646,Head area heater-Occupation status not available,not coded/not installed,
IDE80251-MAS09778,Head area heater-Convert. top open and locked,not coded/not installed,
IDE80251-MAS09779,Head area heater-Convert. top closed and locked,not coded/not installed,
ENG08010-ENG101382,actual_abort_reason_APS_PLA-System_state,00 00,
ENG08009-ENG101382,APS_PLA_error_message-System_state,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF,
ENG02609,average_Voltage_terminals,13.10, V
ENG26644-ENG30703,Data_Definitions-Data_Definition_BAP_Climate_Master,,
ENG26644-ENG30704,Data_Definitions-Data_Definition_BAP_Climate_Zone_1_2,,
ENG26644-ENG30705,Data_Definitions-Data_Definition_BAP_Climate_Zone_3_4,,
ENG26644-ENG30706,Data_Definitions-Data_Definition_BAP_Clock,,
ENG26644-ENG30707,Data_Definitions-Data_Definition_BAP_ExteriorLight,,
ENG26644-ENG30708,Data_Definitions-Data_Definition_BAP_InteriorLight,,
ENG26644-ENG30709,Data_Definitions-Data_Definition_BAP_Parkheater,,
ENG26644-ENG30710,Data_Definitions-Data_Definition_BAP_PDC,,
ENG26644-ENG30711,Data_Definitions-Data_Definition_BAP_SeatPneumatic,,
ENG26644-ENG30712,Data_Definitions-Data_Definition_BAP_TrailorAssist,,
ENG26644-ENG30713,Data_Definitions-Data_Definition_BAP_Wiper,,
ENG26644-ENG30714,Data_Definitions-Data_Definition_CAN_Frontlight,ÿÿÿÿÿÿ,
ENG26644-ENG30715,Data_Definitions-Data_Definition_CAN_Komfort,ÿÿÿÿÿÿ,
ENG26644-ENG30716,Data_Definitions-Data_Definition_LIN_1,ÿÿÿÿÿÿ,
ENG26644-ENG30717,Data_Definitions-Data_Definition_LIN_10,,
ENG26644-ENG30718,Data_Definitions-Data_Definition_LIN_11,,
ENG26644-ENG30719,Data_Definitions-Data_Definition_LIN_12,,
ENG26644-ENG30720,Data_Definitions-Data_Definition_LIN_2,ÿÿ,
ENG26644-ENG30721,Data_Definitions-Data_Definition_LIN_3,,
ENG26644-ENG30722,Data_Definitions-Data_Definition_LIN_4,,
ENG26644-ENG30723,Data_Definitions-Data_Definition_LIN_5,,
ENG26644-ENG30724,Data_Definitions-Data_Definition_LIN_6,,
ENG26644-ENG30725,Data_Definitions-Data_Definition_LIN_7,,
ENG26644-ENG30726,Data_Definitions-Data_Definition_LIN_8,,
ENG26644-ENG30727,Data_Definitions-Data_Definition_LIN_9,,
ENG02611-ENG02852,EVLS-block_counter_axial_in,not coded/not installed,
ENG02611-ENG02851,EVLS-block_counter_axial_out,not coded/not installed,
ENG02611-ENG02850,EVLS-block_counter_vertically_down,not coded/not installed,
ENG02611-ENG02849,EVLS-block_counter_vertically_up,not coded/not installed,
ENG02611-ENG02847,EVLS-drivers_door_open,not coded/not installed,
ENG02611-ENG02856,EVLS-Electrically_adjustable_steering_column_BCM1_down,not coded/not installed,
ENG02611-ENG02858,EVLS-Electrically_adjustable_steering_column_BCM1_in,not coded/not installed,
ENG02611-ENG02857,EVLS-Electrically_adjustable_steering_column_BCM1_out,not coded/not installed,
ENG02611-ENG02855,EVLS-Electrically_adjustable_steering_column_BCM1_up,not coded/not installed,
ENG02611-ENG02845,EVLS-Electrically_adjustable_steering_column_error,not coded/not installed,
ENG02611-ENG02853,EVLS-Electrically_adjustable_steering_column_response_error,not coded/not installed,
ENG02611-ENG02848,EVLS-Electrically_adjustable_steering_column_state,not coded/not installed,
ENG02611-ENG02844,EVLS-Electrically_adjustable_steering_column_state_HV,not coded/not installed,
ENG02611-ENG02843,EVLS-Electrically_adjustable_steering_column_state_LV,not coded/not installed,
ENG02611-ENG02842,EVLS-FS_MMB_global_stop_mode,not coded/not installed,
ENG02611-ENG02838,EVLS-FS_MMB_storage_mode,not coded/not installed,
ENG02611-ENG02841,EVLS-FS_MMB_store_mode,not coded/not installed,
ENG02611-ENG02840,EVLS-FS_MMB_tap_mode,not coded/not installed,
ENG02611-ENG02839,EVLS-FS_MMB_tip_mode,not coded/not installed,
ENG02611-ENG02846,EVLS-LSV_EE_switch,not coded/not installed,
ENG02611-ENG02854,EVLS-motor_start_stopp_restart,not coded/not installed,
ENG101323,Headlight leveling control state,static,
ENG02610,interior_temperature,23.00, °C
ENG107366,Left headlight leveling motor position,64.00, %
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,active,
ENG116804-ENG121664,Light sensor parameter-night_mode,not active,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,not active,
ENG116804-ENG121666,Light sensor parameter-rain_mode,not active,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,189,
ENG116804-ENG03606,Light sensor parameter-rb_E2_Sensor_Error_1_g,0,
ENG116804-ENG03607,Light sensor parameter-rb_E2_Sensor_Error_2_g,0,
ENG116804-ENG03608,Light sensor parameter-rb_E2_Sensor_Error_3_g,0,
ENG116804-ENG03609,Light sensor parameter-rb_E2_Sensor_Error_4_g,0,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,189,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,63,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,95,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG03603,Light sensor parameter-rb_LIN_CHECKSUM_ERROR_COUNTER_g,0,
ENG116804-ENG03605,Light sensor parameter-rb_LIN_FRAME_ERROR_COUNTER_g,0,
ENG116804-ENG03604,Light sensor parameter-rb_LIN_OVER_T_FRAME_MAX_COUNTER_g,0,
ENG116804-ENG03602,Light sensor parameter-rb_LIN_OVER_T_HEADER_MAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,131,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,0, bit
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,126,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,0, bit
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,0, bit
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,not active,
ENG02672-ENG121648,Rain_sensor_parameters-rb_CloseTypeStandby_g,0,
ENG02672-ENG121657,Rain_sensor_parameters-rb_Errorflags_g,0,
ENG02672-ENG121651,Rain_sensor_parameters-rb_HumTemp_ErrorCode_g,0,
ENG02672-ENG121653,Rain_sensor_parameters-rb_NoCommunicationCounter,0,
ENG02672-ENG121641,Rain_sensor_parameters-rb_PotiStageFromBox_g,5,
ENG02672-ENG121642,Rain_sensor_parameters-rb_PWM_Voltage_g,128,
ENG02672-ENG121652,Rain_sensor_parameters-rb_StaticNoCommunicationCounter,0,
ENG02672-ENG121654,Rain_sensor_parameters-rb_SupplyVoltage_mg,166,
ENG02672-ENG03611,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Max_g,141,
ENG02672-ENG03610,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Min_g,139,
ENG02672-ENG121640,Rain_sensor_parameters-rub_Empf_Faktor,23,
ENG02672-ENG121639,Rain_sensor_parameters-rub_Int_Speicher,0,
ENG02672-ENG121645,Rain_sensor_parameters-rub_LengthCounter,78,
ENG02672-ENG121643,Rain_sensor_parameters-rub_Nachwisch_Count,0,
ENG02672-ENG121638,Rain_sensor_parameters-rub_Ovr_Speicher,0,
ENG02672-ENG121646,Rain_sensor_parameters-rub_PulseCounter,1,
ENG02672-ENG121647,Rain_sensor_parameters-rub_SignalIntegral_g,0,
ENG02672-ENG121644,Rain_sensor_parameters-ruw_StX_Speicher,0,
ENG02672-ENG121650,Rain_sensor_parameters-rw_HumiTicks_g,20504,
ENG02672-ENG121649,Rain_sensor_parameters-rw_TempTicks_g,614,
ENG108469,Right headlight leveling motor position,64.00, %
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,3,
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0,
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,5,
ENG03700-ENG109174,sw_version_integration_afs-SW_VERSION,I266,
ENG03701-ENG109174,sw_version_integration_aps-SW_VERSION,3031,
ENG03702-ENG109174,sw_version_integration_wpca-SW_VERSION,0511,
ENG02665-ENG03561,UPIT-Counter_UPIT_shortcut_ground_front,0,
ENG02665-ENG03562,UPIT-Counter_UPIT_shortcut_ground_rear,0,
ENG02665-ENG03560,UPIT-UPIT_system_state,00000000 00000000 ,
ENG02665-ENG03559,UPIT-UPIT_version,00000000 00100011 ,
Elapsed Time: 01:33
adpmap-09-8W0-907-063-CG
;SW:8W0-907-063-CG   HW:8W0-907-063-BG ---  Cent. Elect.
;Component:BCM1 MLBevo   H13 0267, Coding:07500363E0081CCD0515871518AC98BB110B3D08000000000000000020001A010A690122025705
;EV_BCM1BOSCHAU736,018006,EV_BCM1BOSCHAU736_018_AU49.rod
;Sunday,10,November,2019,20:34:37:01617
;VCID: 8247894E1509C05F31-80D6
IDE00001-MAS10842-Production mode-Deactivate exterior lighting,not active ,3
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10844-Production mode-Deactivate rear windshield wiper,not active ,3
IDE00001-MAS10847-Production mode-Deactivate windshield wipers,not active ,3
IDE00001-MAS10848-Production mode-Deactivate left-/right hand driving switch-over,not active ,3
IDE00001-MAS10849-Production mode-Switch parking assist to mute,not active ,3
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS10871-Production mode-Deactivate AC compressor,not active ,3
IDE00001-MAS13264-Production mode-Activate headlamp cleaning system directly,not active ,3
IDE01165-Park assist activation tone,On ,1
IDE01169-Audio reduction request,On ,1
IDE01170-Visual display for park assist,OPS display ,1
IDE01550-Service position,147.20 ,2
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,installed ,1
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,installed ,1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,installed ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,installed ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,installed ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE03642-Presentation mode,not active ,1
IDE03679-Adaptive light functions,active ,1
IDE03782-Switch-off speed for parking assist,5 ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE07356-Position during interval mode,21.00 ,2
IDE10296-upper turn position,163.30 ,2
IDE10297-lower turn position,24.51 ,2
IDE10298-Alternating park position 1,15.80 ,2
IDE10299-Alternating park position 2,19.10 ,2
IDE10307-Presentation mode of multicolor ambient and contour lighting,not active ,1
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1,0 °C,3
IDE10321-MAS01365-Seat heater: micro adjust.-Stage 2,0 °C,3
IDE10321-MAS01366-Seat heater: micro adjust.-Stage 3,0 °C,3
IDE10322-MAS01364-Seat ventilation: micro adjust.-Stage 1,0 %,3
IDE10322-MAS01365-Seat ventilation: micro adjust.-Stage 2,0 %,3
IDE10322-MAS01366-Seat ventilation: micro adjust.-Stage 3,0 %,3
IDE10330-Roof electronics ctrl module: delay time: change of dim value,0 ms,2
IDE10331-MAS02201-Roof electronics control module: temperature-related dim.-Temperature,70 °C,2
IDE10331-MAS10404-Roof electronics control module: temperature-related dim.-max. brightness,0 %,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,not active ,1
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,not active ,1
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,not active ,1
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,not active ,1
IDE10729-Runtime measurement,on task level ,1
IDE11055-Headlight cleaning system: activation time in production mode,2.56e+006 ms,2
IDE11954-Automatic activation of parking distance control,active ,1
IDE12224-MAS14154-Rear parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12224-MAS14155-Rear parking aid warning buzzer with open convertible top-Increment between the volume levels,4 ,2
IDE12225-MAS14154-Front parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12225-MAS14155-Front parking aid warning buzzer with open convertible top-Increment between the volume levels,4 ,2
MAS01426-Speaker volume for rear park assist,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 6 ,1
MAS01428-Speaker volume for front park assist,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 4 ,1
MAS12129-Customer-oriented off-road trip,not activated ,1
MAS12843-Maneuvering brake function,activated ,1
ENG116833-Fehlermaske,00 00 ,2
ENG133836-Fehlermaske 2,00 00 00 00 ,4
ENG117283-Frontwaschfunktion,10 ,2
ENG133832-sLWR_counter_left,0 ,4
ENG133833-sLWR_counter_right,0 ,4
Elapsed Time: 00:57
Address [15]
blockmap-15-8W0-959-655-G
;SW:8W0-959-655-G   HW:8W0-959-655-G ---  Airbags
;Component:Airbag10.44   H05 0107, Coding:BFCCF0C000800000A0000033D24C00000000
;EV_AirbaAU10BPAAU736,006016,EV_AirbaAU10BPAAU736_006_AU49.rod
;Sunday,10,November,2019,20:35:37:01617
;VCID: CDDD6A729CD7CF279C-8098
Group,Description,Actual
IDE00323,Security Access: Number of invalid keys,0,
IDE00821,Safety belt switch 2nd row driver side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Safety belt switch 2nd row center,not installed,
IDE00824,Driver side 3rd row seat belt switch,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00826,Center 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,3.1, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01099,Driver side airbag igniter 2 ohm value,too High,
IDE01100,Passenger side airbag igniter ohm value,2.1, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.1, Ohm
IDE01102,Driver's side airbag igniter ohm value,2.3, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.3, Ohm
IDE01104,driver side rear airbag igniter ohm value,too High,
IDE01105,Ft. pass.side rear airbag igniter ohm value,too High,
IDE01106,Driver side head curtain airbag igniter ohm value,2.2, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.3, Ohm
IDE01108,Driver side knee airbag igniter ohm value,2.1, Ohm
IDE01109,Frt.pass. side knee airbag igniter ohm value,2.2, Ohm
IDE01110,Driver side belt tensioner igniter ohm value,2.1, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.2, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,too High,
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,too High,
IDE01114,Driver side belt force limiter igniter ohm value,2.2, Ohm
IDE01115,side belt force limiter igniter ohm value,2.1, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,2.3, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.3, Ohm
IDE01118,Rear center belt tensioner igniter ohm value,too High,
IDE01119,Battery open circuit igniter ohm value,2.3, Ohm
IDE01193,Driver belt tensioner ohm value,396.0, Ohm
IDE01194,Frt.pass. belt tensioner ohm value,400.0, Ohm
IDE01195,Front passenger side seat occupancy detection: Ohm value,too High,
IDE01197,Key switch contact 1 ohm value,too High,
IDE01198,Key switch contact 2 ohm value,too High,
IDE01200,Driver seat position sensor current value,5.6, mA
IDE01201,Frt.pass. seat position sensor current value,5.6, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,no measured value present,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,no measured value present,
IDE01207,Safety belt switch center 2nd row ohm value,no measured value present,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01210,Safety belt switch center 3rd row ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01285,Counter of component protection malfunctions,0,
IDE01357,Pedestrian protection trigger: driver side,not installed,
IDE01358,Pedestrian protection trigger: frt.pass. side,not installed,
IDE01555,Number of frontal crashes,0,
IDE01556,Number of side crashes driver side,0,
IDE01557,Number of side crashes frt.pass. side,0,
IDE01558,Number of rear crashes,0,
IDE01559,Number of rollover crashes,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,too High,
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,too High,
IDE02246,Number of activations of pedestrian protection,0,
IDE02486,Data logger triggering,not active,
IDE02852,Igniter for battery interrupt: high voltage battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,too High,
IDE03730,Igniter for driver side air bag release valve: ohm value,3.0, Ohm
IDE03731,Igniter for frt.pass. side air bag release valve: ohm value,2.2, Ohm
IDE03800,Driver airbag release valve igniter,correct,
IDE03801,Frt.pass. airbag release valve igniter,correct,
IDE03870,Seat occupied recognition malfunction status,00,
IDE03870,Seat occupied recognition malfunction status,0,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05726-MAS09976,Terminal 58xd dimmer-Dim. value indicator lamp for airbag 'off': frt. pass. side,0.0, %
IDE05726-MAS09977,Terminal 58xd dimmer-Dim. value indicator lamp for airbag 'on': frt. pass. side,0.0, %
IDE05726-MAS09978,Terminal 58xd dimmer-Dim. value indicator lamp for airbag 'text': frt. pass. side,0.0, %
IDE06034,Rollover protection trigger: driver side,cannot be measured currently,
IDE06035,Rollover protection trigger: frt.pass. side,cannot be measured currently,
IDE06036,Rollover protection trigger: driver side ohm value,no measured value present,
IDE06038,Rollover protection trigger: frt.pass. side ohm value,no measured value present,
IDE06110,Right belt tensioner supply voltage,correct,
IDE06118,Right belt tensioner current consumption,0.0, A
IDE06119,Left belt tensioner tensioning cycles charac. curve 1,2,
IDE06120,Left belt tensioner tensioning cycles charac. curve 2,0,
IDE06121,Left belt tensioner tensioning cycles charac. curve 3,0,
IDE06122,Left belt tensioner tensioning cycles charac. curve 4,0,
IDE06123,Right belt tensioner tensioning cycles charac. curve 1,0,
IDE06124,Right belt tensioner tensioning cycles charac. curve 2,0,
IDE06125,Right belt tensioner tensioning cycles charac. curve 3,0,
IDE06126,Right belt tensioner tensioning cycles charac. curve 4,0,
IDE06128,Left belt tensioner temperature,32.0, °C
IDE06129,Right belt tensioner temperature,32.0, °C
IDE06130,Left belt tensioner supply voltage,correct,
IDE06131,Left belt tensioner current consumption,0.0, A
IDE06525,Left belt tensioner error status,0,
IDE06525,Left belt tensioner error status,00,
IDE06525,Left belt tensioner error status,40,
IDE06526,Right belt tensioner error status,0,
IDE06526,Right belt tensioner error status,40,
IDE06526,Right belt tensioner error status,00,
IDE06959,Seat occupant detection: diagnosis signal,36.0, %
IDE06960,Seat occupant detection: msmt. signal,0.5, %
IDE06961,Seat occupant detection: ref. signal,0.5, %
IDE07190,Igniter for battery open circuit 2nd battery,not installed,
IDE07191,2nd Battery open circuit igniter ohm value,too High,
IDE08436,Driver side seat belt tensioner igniter 3,not installed,
IDE08437,Frt.pass. side seat belt tensioner igniter 3,not installed,
IDE08438,Driver side seat belt tensioner igniter 3rd row ohm value,too High,
IDE08439,Frt.pass. side seat belt tensioner igniter 3rd row ohm value,too High,
IDE10187,Supply voltage [V],13.0, V
IDE10188,Left belt tensioner supply voltage [V],13.1, V
IDE10189,Right belt tensioner supply voltage [V],13.2, V
IDE80001,Analysis 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80002,Analysis 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80003,Analysis 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80004,Analysis 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80005,Analysis 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80006,Analysis 6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00001,Driver airbag igniter,correct,
MAS00002,Driver airbag igniter 2,not installed,
MAS00003,Passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,not installed,
MAS00008,Passenger side rear thorax airbag igniter,not installed,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,correct,
MAS00012,Front passenger knee airbag igniter,correct,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,not installed,
MAS00016,Front passenger side seat belt tensioner igniter 2,not installed,
MAS00017,Driver side belt force limiter igniter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear safety belt tension igniter,correct,
MAS00021,Center rear seat belt tensioner igniter,not installed,
MAS00022,Igniter for battery interrupt,correct,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00031,Airbag deactivation status,OFF,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS00231,Seat occupant detection: front passenger side,not installed,
MAS01634,Supply voltage,correct,
Elapsed Time: 00:22
adpmap-15-8W0-959-655-G
;Sunday,10,November,2019,20:36:00:01617
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE06314-Calibration data: pre-crash,01 40 7D FF FE FB 73 6F 00 07 00 00 68 5B 00 D0 1F 18 ,18
IDE06527-IDE06311-Adaptation pre-crash-Seat belt tensioner: left,activated ,4
IDE06527-IDE06312-Adaptation pre-crash-Seat belt tensioner: right,activated ,4
IDE06527-IDE07271-Adaptation pre-crash-Belt tensioner 2nd row: right,not defined ,4
IDE06527-IDE07274-Adaptation pre-crash-Belt tensioner 2nd row: left,not defined ,4
IDE06527-IDE12159-Adaptation pre-crash-Control module for belt feed: second second row left,not defined ,4
IDE06527-IDE12160-Adaptation pre-crash-Control module for belt feed: second second row right,not defined ,4
IDE06527-MAS00478-Adaptation pre-crash-Reserved,2 ,4
IDE06528-Programming: left belt tensioner,80 00 0D 00 30 0E 00 FF 28 29 2A 2B 2C FF FF FF 0D 0E 00 FF 30 31 32 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0D 0E 00 FF 48 49 4A FF FF FF FF FF 00 02 1E 01 01 00 FF FF 00 0A 16 01 01 10 FF FF 00 14 10 01 01 10 FF FF 0D AC 1A 09 00 00 FF FF 00 0A 00 81 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 1E 14 01 00 10 FF FF 0D AC 14 09 00 10 FF FF 00 0A 00 81 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 05 E2 84 00 00 FF FF 00 14 E2 04 00 00 FF FF 00 05 00 84 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,384
IDE06529-Programming: right belt tensioner,80 00 0D 00 30 0E 00 FF 28 29 2A 2B 2C FF FF FF 0D 0E 00 FF 30 31 32 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0D 0E 00 FF 48 49 4A FF FF FF FF FF 00 02 1E 01 01 00 FF FF 00 0A 16 01 01 10 FF FF 00 14 10 01 01 10 FF FF 0D AC 1A 09 00 00 FF FF 00 0A 00 81 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 1E 14 01 00 10 FF FF 0D AC 14 09 00 10 FF FF 00 0A 00 81 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 05 E2 84 00 00 FF FF 00 14 E2 04 00 00 FF FF 00 05 00 84 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,384
IDE09601-IDE03311-Adaptation PreCrash functions-Emergency brake display,not defined ,16
IDE09601-IDE03633-Adaptation PreCrash functions-Close sunroof,activated ,16
IDE09601-IDE03634-Adaptation PreCrash functions-Close windows,activated ,16
IDE09601-IDE09602-Adaptation PreCrash functions-Locale hazard warning,not defined ,16
IDE09601-IDE09603-Adaptation PreCrash functions-RECAS,not defined ,16
IDE09601-IDE09604-Adaptation PreCrash functions-Seat adjustment - backrest,activated ,16
IDE09601-IDE09605-Adaptation PreCrash functions-Seat adjust. - side bolster,activated ,16
IDE09601-IDE09606-Adaptation PreCrash functions-Seat adjustment - headrests,activated ,16
IDE09601-IDE09607-Adaptation PreCrash functions-PreCrash Front,activated ,16
IDE09601-IDE09608-Adaptation PreCrash functions-Seat belt slack reduction: left,not defined ,16
IDE09601-IDE09609-Adaptation PreCrash functions-Seat belt slack reduction: right,not defined ,16
IDE09601-IDE09610-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row left,not defined ,16
IDE09601-IDE09611-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row right,not defined ,16
IDE09601-IDE09612-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row ctr.,not defined ,16
IDE09601-IDE09613-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row left,not defined ,16
IDE09601-IDE09614-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row right,not defined ,16
IDE09601-IDE09615-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row ctr.,not defined ,16
IDE09601-IDE09616-Adaptation PreCrash functions-Reversible belt tensioning left,activated ,16
IDE09601-IDE09617-Adaptation PreCrash functions-Reversible belt tensioning right,activated ,16
IDE09601-IDE09618-Adaptation PreCrash functions-Reversible belt tensioning: act. code of seat belt tightenert,not defined ,16
IDE09601-IDE09619-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row right,not defined ,16
IDE09601-IDE09620-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row ctr.,not defined ,16
IDE09601-IDE09621-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row left,not defined ,16
IDE09601-IDE09622-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row right,not defined ,16
IDE09601-IDE09623-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row ctr.,not defined ,16
IDE09601-MAS00478-Adaptation PreCrash functions-Reserved,2 ,16
IDE09601-MAS03834-Adaptation PreCrash functions-Emergency signal flashing,activated ,16
IDE09601-MAS09950-Adaptation PreCrash functions-LED bar activation,not defined ,16
IDE09601-MAS15067-Adaptation PreCrash functions-Belt parking: first Row,not defined ,16
IDE09601-MAS15068-Adaptation PreCrash functions-Belt parking: second Row,not defined ,16
IDE09601-MAS15069-Adaptation PreCrash functions-Measurement value recording,not defined ,16
IDE09601-MAS15070-Adaptation PreCrash functions-BAP resistance PreSense system,not defined ,16
IDE09601-MAS15071-Adaptation PreCrash functions-BAP resistance PreSense warning,not defined ,16
IDE09601-MAS15072-Adaptation PreCrash functions-BAP resistance: distance warning,not defined ,16
IDE09601-MAS15073-Adaptation PreCrash functions-BAP resistance: turning assistance,not defined ,16
IDE09601-MAS15074-Adaptation PreCrash functions-BAP resistance proactive passenger cover,not defined ,16
MAS00975-IDE00947-Airbag adaptations-driver side rear curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Frt.passenger side rear curtain airbag igniter,not defined ,8
MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined ,8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,not defined ,8
MAS00975-IDE07192-Airbag adaptations-Igniter for window airbag,not defined ,8
MAS00975-IDE08436-Airbag adaptations-Driver side seat belt tensioner igniter 3,not defined ,8
MAS00975-IDE08437-Airbag adaptations-Frt.pass. side seat belt tensioner igniter 3,not defined ,8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated ,8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated ,8
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,activated ,8
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated ,8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,activated ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,activated ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,activated ,8
MAS00975-MAS00023-Airbag adaptations-Driver side active head restraint igniter,not defined ,8
MAS00975-MAS00024-Airbag adaptations-Igniter for active head restraint on frt. passenger side,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized ,8
MAS00975-MAS00231-Airbag adaptations-Seat occupant detection: front passenger side,activated ,8
MAS00975-MAS00478-Airbag adaptations-Reserved,2 ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,not defined ,8
Elapsed Time: 00:13
Address [16]
blockmap-16-4M0-907-129-GB
;SW:4M0-907-129-GB   HW:4M0-907-129-GB ---  Steering wheel
;Component:Lenks.Modul   H11 0009, Coding:
;EV_SMLSKLOAU736,006008,EV_SMLSKLOAU736_006.rod
;Sunday,10,November,2019,20:36:15:01617
;VCID: F6AFE59E49C1ECFF0D-80A2
IDE00030,Status of actuator test,not active,
IDE00322,Status of basic setting,was not yet started,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No malfunction detected,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not installed,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,Engaged ON,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,CCS Switch,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
IDE00356-MAS04523,Cruise Control System (CCS): switch position-Accelerate tip level 2,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,8 positions,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS10720,Cruise Control System (CCS): switch position-Speed limiter,not installed,
IDE02068-MAS00106,Time stamp-Year,2018, yr
IDE02068-MAS00107,Time stamp-Month,3, m
IDE02068-MAS00108,Time stamp-Day,1, d
IDE02068-MAS00109,Time stamp-Hours,21, H
IDE02068-MAS00110,Time stamp-Minutes,40, min
IDE02068-MAS00111,Time stamp-Seconds,24, s
IDE02068-MAS00711,Time stamp-Odometer reading,0, km
IDE02068-MAS02543,Time stamp-VIN determined during calibration,57 41 55 45 4E 41 46 34 37 4A 41 31 34 37 38 39 38,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,not activated,
IDE02693-IDE08189,Turn signals and parking lights-Malfunction status flasher,No malfunction detected,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Intermittent operation,
IDE02695-IDE11269,Front wiping: front washing-Front windshield wiper error status,No malfunction detected,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 4,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,not activated,
IDE02743-IDE05742,High Beam-Light switch position,not activated,
IDE03680-IDE00019,Supply voltages-Voltage terminal 30,13150.78, mV
IDE03680-IDE00618,Supply voltages-Voltage supply 5V,4978.13, mV
IDE03680-MAS00125,Supply voltages-Cruise control system,0.00, mV
IDE05725-IDE01763,Terminal 58xs dimmer-Dimming,58, %
IDE05725-MAS03873,Terminal 58xs dimmer-Duty cycle,50, %
IDE08696-IDE02219,Steerg. wheel angle sens.-Steering wheel angle: sign,Negative,
IDE08696-MAS00037,Steerg. wheel angle sens.-Calibration status,calibrated,
IDE08696-MAS00370,Steerg. wheel angle sens.-Vehicle speed,in permissible range,
IDE08696-MAS02125,Steerg. wheel angle sens.-Steering wheel angle speed,0, °/s
IDE08696-MAS02126,Steerg. wheel angle sens.-Steering angle sensor: status,initialized,
IDE08696-MAS02128,Steerg. wheel angle sens.-Q bit: steering wheel angle,valid,
IDE08696-MAS02357,Steerg. wheel angle sens.-Vehicle identification,detected,
IDE08696-MAS02358,Steerg. wheel angle sens.-Calibration angle,outside permissible range,
IDE08696-MAS02406,Steerg. wheel angle sens.-Steering wheel angle: internal value,316.2, °
IDE08696-MAS02453,Steerg. wheel angle sens.-Steering wheel angle offset,0.3, °
IDE08696-MAS02832,Steerg. wheel angle sens.-Malfunction status,no error,
IDE08696-MAS02983,Steerg. wheel angle sens.-Steering wheel angle,316.5, °
IDE08696-MAS04474,Steerg. wheel angle sens.-Left front wheel speed,0.00, km/h
IDE08696-MAS04475,Steerg. wheel angle sens.-Right front wheel speed,0.00, km/h
IDE08696-MAS04476,Steerg. wheel angle sens.-Left rear wheel speed,0.00, km/h
IDE08696-MAS04477,Steerg. wheel angle sens.-Right rear wheel speed,0.00, km/h
IDE08696-MAS07727,Steerg. wheel angle sens.-Steering wheel angle: prefix internal value,Negative,
IDE08696-MAS07728,Steerg. wheel angle sens.-Steering wheel angle offset: prefix,Positive,
IDE08696-MAS07729,Steerg. wheel angle sens.-Steering wheel speed: prefix,Positive,
IDE09381-IDE02219,Steering angle sensor calibration status-Steering wheel angle: sign,Negative,
IDE09381-MAS00037,Steering angle sensor calibration status-Calibration status,calibrated,
IDE09381-MAS00370,Steering angle sensor calibration status-Vehicle speed,in permissible range,
IDE09381-MAS02126,Steering angle sensor calibration status-Steering angle sensor: status,initialized,
IDE09381-MAS02357,Steering angle sensor calibration status-Vehicle identification,detected,
IDE09381-MAS02358,Steering angle sensor calibration status-Calibration angle,outside permissible range,
IDE09381-MAS02406,Steering angle sensor calibration status-Steering wheel angle: internal value,316.2, °
IDE09381-MAS02832,Steering angle sensor calibration status-Malfunction status,no error,
IDE09381-MAS02983,Steering angle sensor calibration status-Steering wheel angle,316.5, °
IDE09381-MAS04121,Steering angle sensor calibration status-Voltage,in permissible range,
IDE09381-MAS07727,Steering angle sensor calibration status-Steering wheel angle: prefix internal value,Negative,
IDE09381-MAS08808,Steering angle sensor calibration status-Maximal allowed offset angle,0.0, °
IDE09381-MAS08809,Steering angle sensor calibration status-Maximal allowed offset angle: sign,Positive,
IDE09381-MAS08810,Steering angle sensor calibration status-Minimum allowed offset angle,0.0, °
IDE09381-MAS08811,Steering angle sensor calibration status-Minimum allowed offset angle: sign,Positive,
Elapsed Time: 00:05
adpmap-16-4M0-907-129-GB
;Sunday,10,November,2019,20:36:21:01617
IDE00820-IDE80001-Activating and deactivating all development messages-Analysis 1,OFF ,1
IDE00820-IDE80002-Activating and deactivating all development messages-Analysis 2,OFF ,1
IDE00820-IDE80003-Activating and deactivating all development messages-Analysis 3,OFF ,1
IDE00820-IDE80004-Activating and deactivating all development messages-Analysis 4,OFF ,1
IDE00820-IDE80005-Activating and deactivating all development messages-Analysis 5,OFF ,1
Elapsed Time: 00:01
drp
DrPeter
16.4905° S, 151.7375° W
More maps...
Address [29]
adpmap-29-4M0-907-397-AC
;SW:4M0-907-397-AC   HW:4M0-907-397-C ---  Left Light
;Component:LCM_MLBevoH05 0024, Coding:
;EV_LCMLeftHELLAAU736,001012,EV_LCMLeftHELLAAU736_VW48.rod
;Sunday,10,November,2019,20:36:32:01617
;VCID: F8B3EBA643D59A8F1F-80AC
IDE01550-Service position,not active ,1
Elapsed Time: 00:01
blockmap-29-4M0-907-397-AC
;Sunday,10,November,2019,20:36:24:01617
IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,0,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE00773,Terminal 15 status via CAN,On,
IDE03680-MAS01468,Supply voltages-Terminal 15,Not available,
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,12.90, V
IDE06876-MAS01482,Signature light bulb-Hardwareversion,Not available,
IDE06876-MAS01483,Signature light bulb-Softwareversion,Not available,
IDE06876-MAS12381,Signature light bulb-Software subversion,0F,
IDE06876-ENG14244,Signature light bulb-Software_sub_version_Textual,Not available,
IDE06926-IDE02068,History memory: reset counter-Time stamp,F0 4D 5F 4D 4C,
IDE06926-MAS09176,History memory: reset counter-Reset reason,Unknown (0),
IDE08742-MAS01155,Operating time-Control module,920.09, H
IDE08742-MAS03835,Operating time-Parking light,332.48, H
IDE08742-MAS09325,Operating time-Daytime running lights,459.06, H
IDE08742-MAS09330,Operating time-Cover for low beam headlight,0.00, H
IDE08742-MAS09332,Operating time-Turn signal,20.38, H
IDE08742-MAS09333,Operating time-Side-marker light,332.48, H
IDE08742-MAS09334,Operating time-Parking light,0.00, H
IDE09492-MAS01155,Temperatures-Control module,71.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,57.00, °C
IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,57.00, °C
IDE09768-MAS04121,LED channel 1-Voltage,19.00, V
IDE09768-MAS04136,LED channel 1-Current,360, mA
IDE09768-MAS09022,LED channel 1-PWM value,13.00, %
IDE09768-MAS09327,LED channel 1-LED brightness class,2,
IDE09768-MAS09328,LED channel 1-Primary function,Daytime running lights/parking light,
IDE09768-MAS09329,LED channel 1-Secondary function,no function,
IDE09769-MAS04121,LED channel 2-Voltage,0.00, V
IDE09769-MAS04136,LED channel 2-Current,0, mA
IDE09769-MAS09022,LED channel 2-PWM value,0.00, %
IDE09769-MAS09327,LED channel 2-LED brightness class,4,
IDE09769-MAS09328,LED channel 2-Primary function,Turn signal,
IDE09769-MAS09329,LED channel 2-Secondary function,no function,
IDE09770-MAS04136,High side channel 1-Current,620, mA
IDE09770-MAS09022,High side channel 1-PWM value,0.00, %
IDE09770-MAS09326,High side channel 1-Function,no function,
IDE09771-MAS04136,High side channel 2-Current,0, mA
IDE09771-MAS09022,High side channel 2-PWM value,0.00, %
IDE09771-MAS09326,High side channel 2-Function,no function,
IDE09772-MAS04136,High side channel 3-Current,90, mA
IDE09772-MAS09022,High side channel 3-PWM value,100.00, %
IDE09772-MAS09326,High side channel 3-Function,Side-marker light,
IDE09774-MAS03835,Number of activations-Parking light,1895,
IDE09774-MAS09325,Number of activations-Daytime running lights,8135,
IDE09774-MAS09330,Number of activations-Cover for low beam headlight,0,
IDE09774-MAS09332,Number of activations-Turn signal,217098,
IDE09774-MAS09333,Number of activations-Side-marker light,1895,
IDE09774-MAS09334,Number of activations-Parking light,0,
IDE09775-MAS09336,High temperature operating times for control unit-°C,0.25, H
IDE09775-MAS09337,High temperature operating times for control unit-between 105°C and 115°C,0.00, H
IDE09775-MAS09338,High temperature operating times for control unit-over 115°C,0.00, H
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,99.59, %
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,0.02, %
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-over 60%,0.00, %
IDE09828-MAS00890,Head lamp variant-via CAN,E0 0F,
IDE09828-MAS01155,Head lamp variant-Control module,E0 0F,
IDE09916-MAS09563,Data set names-Number of data set names,01,
IDE09916-MAS09564,Data set names-Data set ID,28928,
IDE09916-MAS09565,Data set names-Data set name,B9A4LEDSWSAE,
IDE10175,Capturing statistic data: status,active,
IDE10301-MAS01155,Number of excess temp. protection activations-Control module,0,
IDE10301-MAS03835,Number of excess temp. protection activations-Parking light,1,
IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lights,6,
IDE10301-MAS09332,Number of excess temp. protection activations-Turn signal,0,
IDE11123-MAS04136,High side channel 4-Current,0, mA
IDE11123-MAS09022,High side channel 4-PWM value,0.00, %
IDE11123-MAS09326,High side channel 4-Function,no function,
IDE11124-MAS12195,Headlight beam adjusting motor-Reference run status,performed,
IDE11124-MAS12196,Headlight beam adjusting motor-Fault position,not approached,
IDE11124-MAS12199,Headlight beam adjusting motor-Adjustment speed,normal,
IDE11124-MAS12206,Headlight beam adjusting motor-Motor position (percent of max. adjustment stroke),64.00, %
IDE11124-MAS12207,Headlight beam adjusting motor-Low beam inclination,-20.00, mm
IDE11125-MAS12195,Dynamic cornering light adjusting motor-Reference run status,not performed,
IDE11125-MAS12196,Dynamic cornering light adjusting motor-Fault position,not approached,
IDE11125-MAS12199,Dynamic cornering light adjusting motor-Adjustment speed,normal,
IDE11125-MAS12206,Dynamic cornering light adjusting motor-Motor position (percent of max. adjustment stroke),Unknown,
IDE11125-MAS12209,Dynamic cornering light adjusting motor-Swivel angle,Unknown,
IDE11276-MAS01482,Power output stage for headlamp aux. functions-Hardwareversion,Not available,
IDE11276-MAS01483,Power output stage for headlamp aux. functions-Softwareversion,Not available,
IDE11276-MAS12381,Power output stage for headlamp aux. functions-Software subversion,0F,
IDE11276-ENG14244,Power output stage for headlamp aux. functions-Software_sub_version_Textual,Not available,
IDE11347-MAS12195,Variable headlamp positioning motor-Reference run status,performed,
IDE11347-MAS12196,Variable headlamp positioning motor-Fault position,approached,
IDE11347-MAS12199,Variable headlamp positioning motor-Adjustment speed,reduced,
IDE11347-MAS12212,Variable headlamp positioning motor-Calibrated light index setting,Unknown,
Elapsed Time: 00:07
Address [36]
blockmap-36-4M4-959-760
;SW:4M4-959-760   HW:4M4-959-760 ---  Seat Mem. Drvr
;Component:MEM-FS        009 0042, Coding:005C1B000000B0010000010101010000000000000000000000000000000000
;EV_SCMDriveSideCONTIAU736,006009,EV_SCMDriveSideCONTIAU736_AU49.rod
;Sunday,10,November,2019,20:36:35:01617
;VCID: F9B5EEA278DF838760-80AC
IDE00019-MAS00043,Voltage terminal 30-Supply voltage: Terminal 30,13.20, V
IDE00102,Control Module temperature,48,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Backrest inclination adjustment-Block 1,33835,
IDE06510-MAS01391,Backrest inclination adjustment-Block 2,32252,
IDE06510-MAS02282,Backrest inclination adjustment-Position,32778,
IDE06510-MAS02955,Backrest inclination adjustment-Engine temperature,25, °C
IDE06510-MAS03129,Backrest inclination adjustment-Reset counter,250,
IDE06510-MAS04160,Backrest inclination adjustment-Load change,847,
IDE06510-MAS04337,Backrest inclination adjustment-Engine current,0, A
IDE06510-MAS05370,Backrest inclination adjustment-Direction of movement,not activated,
IDE06510-MAS05563,Backrest inclination adjustment-Norming,normed,
IDE06510-MAS05719,Backrest inclination adjustment-Maximum travel,1583,
IDE06510-MAS12838,Backrest inclination adjustment-Standardization flag,normed,
IDE06511-MAS01390,Seat height adjustment-Block 1,33337,
IDE06511-MAS01391,Seat height adjustment-Block 2,32757,
IDE06511-MAS02282,Seat height adjustment-Position,33286,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,31,
IDE06511-MAS04160,Seat height adjustment-Load change,1015,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,not activated,
IDE06511-MAS05563,Seat height adjustment-Norming,normed,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,580,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,normed,
IDE06512-MAS01390,Seat forward/back position adjustment-Block 1,32773,
IDE06512-MAS01391,Seat forward/back position adjustment-Block 2,32116,
IDE06512-MAS02282,Seat forward/back position adjustment-Position,32328,
IDE06512-MAS02955,Seat forward/back position adjustment-Engine temperature,25, °C
IDE06512-MAS03129,Seat forward/back position adjustment-Reset counter,73,
IDE06512-MAS04160,Seat forward/back position adjustment-Load change,1688,
IDE06512-MAS04337,Seat forward/back position adjustment-Engine current,0, A
IDE06512-MAS05370,Seat forward/back position adjustment-Direction of movement,not activated,
IDE06512-MAS05563,Seat forward/back position adjustment-Norming,normed,
IDE06512-MAS05719,Seat forward/back position adjustment-Maximum travel,657,
IDE06512-MAS12838,Seat forward/back position adjustment-Standardization flag,normed,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-save,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,33038,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32766,
IDE06683-MAS02282,Seat inclination adjustment-Position,32767,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,8,
IDE06683-MAS04160,Seat inclination adjustment-Load change,741,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,not activated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,normed,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,272,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,normed,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,0,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,0,
IDE06684-MAS02282,Lumbar support height adjustment-Position,0,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,not activated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,not normed,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,0,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,never normed,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,0,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,0,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,0,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,0,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,0,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,not activated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,not normed,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,0,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,never normed,
IDE06871-IDE06510,Seat adjustment control head-Backrest inclination adjustment,not activated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,not activated,
IDE06871-IDE06512,Seat adjustment control head-Seat forward/back position adjustment,not activated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,not activated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,not activated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,not activated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,not activated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,not activated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,not activated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,not activated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,not activated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Backrest inclination adjustment,33021,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,32930,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Seat forward/back position adjustment,32453,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,32776,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Backrest inclination adjustment,32798,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,32757,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Seat forward/back position adjustment,32773,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,32996,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Backrest inclination adjustment,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Seat forward/back position adjustment,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Backrest inclination adjustment,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Seat forward/back position adjustment,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Backrest inclination adjustment,0,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,0,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Seat forward/back position adjustment,0,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Backrest inclination adjustment,32778,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,33286,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Seat forward/back position adjustment,32328,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,32767,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Backrest inclination adjustment,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Seat forward/back position adjustment,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Backrest inclination adjustment,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Seat forward/back position adjustment,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,not activated,
IDE08989-MAS05563,Seat depth adjustment-Norming,not normed,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,not activated,
IDE08990-MAS05563,Backrest top adjustment-Norming,not normed,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,not activated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,not activated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,not activated,
IDE09081-MAS08293,Seat switch module-Rocker,not activated,
IDE09082,Massage button,not activated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,not activated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,not activated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,not activated,
IDE09085,Backrest limit switch,not activated,
IDE10995-IDE06510,Calibrating the motors: status-Backrest inclination adjustment,normed,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,normed,
IDE10995-IDE06512,Calibrating the motors: status-Seat forward/back position adjustment,normed,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,normed,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,not normed,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not normed,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not normed,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,not normed,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not normed,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Not adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Not adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,not activated,
IDE11024-MAS05563,Headrest height adjustment-Norming,not normed,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,0,
IDE11025-MAS01391,Headrest length adjustment-Block 2,0,
IDE11025-MAS02282,Headrest length adjustment-Position,0,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,0, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,0,
IDE11025-MAS04160,Headrest length adjustment-Load change,0,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,not activated,
IDE11025-MAS05563,Headrest length adjustment-Norming,not normed,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,0,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,never normed,
IDE11957-MAS01390,Display unit adjustment-Block 1,0,
IDE11957-MAS01391,Display unit adjustment-Block 2,0,
IDE11957-MAS02282,Display unit adjustment-Position,0,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,0, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,0,
IDE11957-MAS04160,Display unit adjustment-Load change,0,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,not activated,
IDE11957-MAS05563,Display unit adjustment-Norming,not normed,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,0,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,never normed,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,0,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,0,
IDE11969-MAS02282,Adjustment of foot rest-Position,0,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,0, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,0,
IDE11969-MAS04160,Adjustment of foot rest-Load change,0,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,not activated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,not normed,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,0,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,never normed,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,0,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,0,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,0,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,0, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,0,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,0,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,not activated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,not normed,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,0,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,never normed,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,not activated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,not activated,
MAS12838-IDE06510,Standardization flag-Backrest inclination adjustment,normed,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,normed,
MAS12838-IDE06512,Standardization flag-Seat forward/back position adjustment,normed,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,normed,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,never normed,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,never normed,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG08879-IDE06510,Account_1-Backrest inclination adjustment,0,
ENG08879-IDE06511,Account_1-Seat height adjustment,0,
ENG08879-IDE06512,Account_1-Seat forward/back position adjustment,0,
ENG08879-IDE06683,Account_1-Seat inclination adjustment,0,
ENG08879-IDE06684,Account_1-Lumbar support height adjustment,0,
ENG08879-IDE06685,Account_1-Lumbar support longitudinal position adjustment,0,
ENG08879-IDE08989,Account_1-Seat depth adjustment,0,
ENG08879-IDE08990,Account_1-Backrest top adjustment,0,
ENG08879-IDE08991,Account_1-Belt height adjustment,0,
ENG08879-IDE11024,Account_1-Headrest height adjustment,0,
ENG08880-IDE06510,Account_2-Backrest inclination adjustment,32778,
ENG08880-IDE06511,Account_2-Seat height adjustment,33286,
ENG08880-IDE06512,Account_2-Seat forward/back position adjustment,32328,
ENG08880-IDE06683,Account_2-Seat inclination adjustment,32767,
ENG08880-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG08880-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG08880-IDE08989,Account_2-Seat depth adjustment,0,
ENG08880-IDE08990,Account_2-Backrest top adjustment,0,
ENG08880-IDE08991,Account_2-Belt height adjustment,0,
ENG08880-IDE11024,Account_2-Headrest height adjustment,0,
ENG08881-IDE06510,Account_3-Backrest inclination adjustment,0,
ENG08881-IDE06511,Account_3-Seat height adjustment,0,
ENG08881-IDE06512,Account_3-Seat forward/back position adjustment,0,
ENG08881-IDE06683,Account_3-Seat inclination adjustment,0,
ENG08881-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG08881-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG08881-IDE08989,Account_3-Seat depth adjustment,0,
ENG08881-IDE08990,Account_3-Backrest top adjustment,0,
ENG08881-IDE08991,Account_3-Belt height adjustment,0,
ENG08881-IDE11024,Account_3-Headrest height adjustment,0,
ENG08882-IDE06510,Account_4-Backrest inclination adjustment,0,
ENG08882-IDE06511,Account_4-Seat height adjustment,0,
ENG08882-IDE06512,Account_4-Seat forward/back position adjustment,0,
ENG08882-IDE06683,Account_4-Seat inclination adjustment,0,
ENG08882-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG08882-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG08882-IDE08989,Account_4-Seat depth adjustment,0,
ENG08882-IDE08990,Account_4-Backrest top adjustment,0,
ENG08882-IDE08991,Account_4-Belt height adjustment,0,
ENG08882-IDE11024,Account_4-Headrest height adjustment,0,
ENG08883-IDE06510,Account_5-Backrest inclination adjustment,0,
ENG08883-IDE06511,Account_5-Seat height adjustment,0,
ENG08883-IDE06512,Account_5-Seat forward/back position adjustment,0,
ENG08883-IDE06683,Account_5-Seat inclination adjustment,0,
ENG08883-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG08883-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG08883-IDE08989,Account_5-Seat depth adjustment,0,
ENG08883-IDE08990,Account_5-Backrest top adjustment,0,
ENG08883-IDE08991,Account_5-Belt height adjustment,0,
ENG08883-IDE11024,Account_5-Headrest height adjustment,0,
ENG08884-IDE06510,Account_6-Backrest inclination adjustment,0,
ENG08884-IDE06511,Account_6-Seat height adjustment,0,
ENG08884-IDE06512,Account_6-Seat forward/back position adjustment,0,
ENG08884-IDE06683,Account_6-Seat inclination adjustment,0,
ENG08884-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG08884-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG08884-IDE08989,Account_6-Seat depth adjustment,0,
ENG08884-IDE08990,Account_6-Backrest top adjustment,0,
ENG08884-IDE08991,Account_6-Belt height adjustment,0,
ENG08884-IDE11024,Account_6-Headrest height adjustment,0,
ENG08885-IDE06510,Account_7-Backrest inclination adjustment,0,
ENG08885-IDE06511,Account_7-Seat height adjustment,0,
ENG08885-IDE06512,Account_7-Seat forward/back position adjustment,0,
ENG08885-IDE06683,Account_7-Seat inclination adjustment,0,
ENG08885-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG08885-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG08885-IDE08989,Account_7-Seat depth adjustment,0,
ENG08885-IDE08990,Account_7-Backrest top adjustment,0,
ENG08885-IDE08991,Account_7-Belt height adjustment,0,
ENG08885-IDE11024,Account_7-Headrest height adjustment,0,
ENG08878-IDE06510,BAP_Seat_Adjustment_Button_Status-Backrest inclination adjustment,not activated,
ENG08878-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,not activated,
ENG08878-IDE06512,BAP_Seat_Adjustment_Button_Status-Seat forward/back position adjustment,not activated,
ENG08878-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,not activated,
ENG08878-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,not activated,
ENG08878-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,not activated,
ENG08878-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,not activated,
ENG08878-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,not activated,
ENG08878-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,not activated,
ENG08878-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,not activated,
ENG08878-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,not activated,
ENG08878-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,not activated,
ENG08878-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,not activated,
ENG08878-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,not activated,
ENG08878-ENG09596,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,not activated,
ENG08878-ENG09597,BAP_Seat_Adjustment_Button_Status-footmat,not activated,
ENG08878-ENG09595,BAP_Seat_Adjustment_Button_Status-side_bolster,not activated,
ENG05253-ENG101098,crash_precrash-Crash,not active,
ENG05253-ENG00891,crash_precrash-Precrash,not active,
ENG05258-ENG05268,Entnormierursache-Axis_1,Normierroutine,
ENG05258-ENG05277,Entnormierursache-Axis_10,Achse decodiert,
ENG05258-ENG05269,Entnormierursache-Axis_2,Normierroutine,
ENG05258-ENG05270,Entnormierursache-Axis_3,Normierroutine,
ENG05258-ENG05271,Entnormierursache-Axis_4,Normierroutine,
ENG05258-ENG05272,Entnormierursache-Axis_5,Achse decodiert,
ENG05258-ENG05273,Entnormierursache-Axis_6,Achse decodiert,
ENG05258-ENG05274,Entnormierursache-Axis_7,Achse decodiert,
ENG05258-ENG05275,Entnormierursache-Axis_8,Achse decodiert,
ENG05258-ENG05276,Entnormierursache-Axis_9,Achse decodiert,
ENG116729-ENG117054,info_developer-ax_da,7E 48 7D 74 80 05 00 07 80 0A 7D FC 84 2B 00 07 82 06 7F F5 82 39 00 07 7F FF 7F FE 81 0E 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A,
ENG116729-ENG117006,info_developer-gl_lo,34 4D 34 39 35 39 37 36 30 20 20 00 00 00 00 00 30 30 34 32 00 00 00 00 31 38 32 39 00 00 00 00 53 43 58 58 58 51 37 42 41 53 49 53 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116875,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 02 00 00 03 00 03 04 04 00 00 00 00,
ENG116729-ENG117035,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116968,info_developer-so_deb,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG05278-ENG05354,key_memory_activated-mmi_key_memory_activated,active,
ENG26210-ENG30378,Maximum travel-Axis_1_current,657,
ENG26210-ENG30379,Maximum travel-Axis_1_last,0,
ENG26210-ENG30380,Maximum travel-Axis_10_current,65535,
ENG26210-ENG30381,Maximum travel-Axis_10_last,0,
ENG26210-ENG30382,Maximum travel-Axis_2_current,1583,
ENG26210-ENG30383,Maximum travel-Axis_2_last,0,
ENG26210-ENG30384,Maximum travel-Axis_3_current,580,
ENG26210-ENG30385,Maximum travel-Axis_3_last,0,
ENG26210-ENG30386,Maximum travel-Axis_4_current,272,
ENG26210-ENG30387,Maximum travel-Axis_4_last,0,
ENG26210-ENG30388,Maximum travel-Axis_5_current,65535,
ENG26210-ENG30389,Maximum travel-Axis_5_last,0,
ENG26210-ENG30390,Maximum travel-Axis_6_current,65535,
ENG26210-ENG30391,Maximum travel-Axis_6_last,0,
ENG26210-ENG30392,Maximum travel-Axis_7_current,65535,
ENG26210-ENG30393,Maximum travel-Axis_7_last,0,
ENG26210-ENG30394,Maximum travel-Axis_8_current,65535,
ENG26210-ENG30395,Maximum travel-Axis_8_last,0,
ENG26210-ENG30396,Maximum travel-Axis_9_current,65535,
ENG26210-ENG30397,Maximum travel-Axis_9_last,0,
ENG05251-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG05251-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG05251-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG05251-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG05251-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG05251-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG05251-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG05251-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG05252-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG05252-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,not active,
ENG05252-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,not active,
ENG05252-ENG09278,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG05252-ENG05263,Memory_ID_CAN_2-Hardware_onoff,active,
ENG05252-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG05252-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG05252-ENG116986,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG26976-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG26976-ENG116860,missing_pre_conditions-_reserviert,0,
ENG26976-ENG30399,missing_pre_conditions-backrest_locked,active,
ENG26976-ENG30400,missing_pre_conditions-backrest_unlocked,active,
ENG26976-ENG30434,missing_pre_conditions-button_pressed,not active,
ENG26976-ENG30644,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG26976-ENG32216,missing_pre_conditions-other_adjustment_already_active,not active,
ENG26976-ENG100589,missing_pre_conditions-Reserviert 2,0,
ENG26976-ENG32451,missing_pre_conditions-reset_problem,not active,
ENG26976-ENG32661,missing_pre_conditions-speed_above_5kmh,active,
ENG26976-ENG28397,missing_pre_conditions-Voltage_supply,not active,
ENG05256-ENG05265,pwm_generator-pwm_generator_group_1_overload,not active,
ENG05256-ENG05266,pwm_generator-pwm_generator_group_2_overload,not active,
ENG05254-ENG99389,Resets-Resetcounter,3,
ENG05257-ENG05267,sbc-sbc_overload,not active,
ENG05279-ENG05366,Seat_Actual_Positions-Current_Position_fsv,32768,
ENG05279-ENG05362,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG05279-ENG05369,Seat_Actual_Positions-Current_Position_kks,32768,
ENG05279-ENG05365,Seat_Actual_Positions-Current_Position_ksv_x,32768,
ENG05279-ENG05359,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG05279-ENG05364,Seat_Actual_Positions-Current_Position_ldh,32768,
ENG05279-ENG05363,Seat_Actual_Positions-Current_Position_ldw,32768,
ENG05279-ENG05361,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG05279-ENG05356,Seat_Actual_Positions-Current_Position_lnv,32778,
ENG05279-ENG05367,Seat_Actual_Positions-Current_Position_rse1,32768,
ENG05279-ENG05368,Seat_Actual_Positions-Current_Position_rse2,32768,
ENG05279-ENG05357,Seat_Actual_Positions-Current_Position_shv,33286,
ENG05279-ENG05355,Seat_Actual_Positions-Current_Position_slv,32328,
ENG05279-ENG05358,Seat_Actual_Positions-Current_Position_snv,32767,
ENG05279-ENG05360,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG05349,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG05350,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG05351,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG05352,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG05353,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,Key 2,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,Key 2,
ENG123053-ENG05345,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG05340,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG05346,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG05343,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG05348,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG05347,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG05344,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG05341,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG05342,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG05339,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG27116-IDE06510,Seat_Position_Memory_Remote_Control_5-Backrest inclination adjustment,0,
ENG27116-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG27116-IDE06512,Seat_Position_Memory_Remote_Control_5-Seat forward/back position adjustment,0,
ENG27116-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG27116-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG27116-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG27116-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG27116-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG27116-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG27116-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG27117-IDE06510,Seat_Position_Memory_Remote_Control_6-Backrest inclination adjustment,0,
ENG27117-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG27117-IDE06512,Seat_Position_Memory_Remote_Control_6-Seat forward/back position adjustment,0,
ENG27117-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG27117-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG27117-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG27117-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG27117-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG27117-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG27117-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG27118-IDE06510,Seat_Position_Memory_Remote_Control_7-Backrest inclination adjustment,0,
ENG27118-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG27118-IDE06512,Seat_Position_Memory_Remote_Control_7-Seat forward/back position adjustment,0,
ENG27118-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG27118-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG27118-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG27118-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG27118-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG27118-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG27118-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG05255-ENG116986,Source_Last_Reset-Low_Voltage,not active,
ENG05255-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,not active,
ENG05255-ENG123072,Source_Last_Reset-Power_On_Reset,active,
ENG05255-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG05255-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG05255-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:22
adpmap-36-4M4-959-760
;Sunday,10,November,2019,20:36:58:01617
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS18842-Production mode-Assembly mode,not active ,3
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE02854-Resetting standardization,all ,3
IDE03066-Reset counter for compressor for multicontour seat,Activate ,1
IDE06869-installation position,Memory seat driver side ,1
ENG123066-vehicle_velocity_monitoring,active ,1
Elapsed Time: 00:17
Address [39]
blockmap-39-4M0-907-397-AC
;SW:4M0-907-397-AC   HW:4M0-907-397-C ---  Right Light
;EV_LCMRightHELLAAU736,001012,EV_LCMLeftHELLAAU736_VW48.rod
;Sunday,10,November,2019,20:37:17:01617
Group,Description,Actual
IDE00323,Security Access: Number of invalid keys,0,
IDE08742-MAS01155,Operating time-Control module,917.94, H
IDE08742-MAS03835,Operating time-Parking light,331.91, H
IDE08742-MAS09325,Operating time-Daytime running lights,467.89, H
IDE08742-MAS09332,Operating time-Turn signal,13.82, H
IDE08742-MAS09333,Operating time-Side-marker light,331.90, H
IDE09492-MAS01155,Temperatures-Control module,53.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,39.00, °C
IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,39.00, °C
IDE09768-MAS04121,LED channel 1-Voltage,19.27, V
IDE09770-MAS04136,High side channel 1-Current,800, mA
IDE09772-MAS04136,High side channel 3-Current,100, mA
IDE09774-MAS03835,Number of activations-Parking light,1885,
IDE09774-MAS09325,Number of activations-Daytime running lights,7883,
IDE09774-MAS09332,Number of activations-Turn signal,156412,
IDE09774-MAS09333,Number of activations-Side-marker light,1885,
IDE09775-MAS09336,High temperature operating times for control unit-°C,0.03, H
IDE10301-MAS03835,Number of excess temp. protection activations-Parking light,0,
IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lights,3,
Elapsed Time: 00:03
adpmap-39-4M0-907-397-AC
;Sunday,10,November,2019,20:37:21:01617
Elapsed Time: 00:01
Address [3C]
blockmap-3C-4M0-907-566-D
;SW:4M0-907-566-D   HW:4M0-907-566 ---  Lane Change
;Component:MRR1Rear      H18 0410, Coding:0E8002
;EV_RearRadarS1BoschAU736,001022,EV_RearRadarS1BoschAU736.rod
;Sunday,10,November,2019,20:37:24:01617
;VCID: B62F259E0941ACFFCD-80E2
IDE00018,Voltage terminal 15,Measured value not available,
IDE00019,Voltage terminal 30,12.90, V
IDE00020,Terminal 15 status,On,
IDE00075,Vehicle speed,0.00, km/h
IDE00102,Control Module temperature,62, °C
IDE00322,Status of basic setting,not active,
IDE00925,Yaw rate,-127, °/s
IDE01352,Temperature unit,°C,
IDE01441,Back-up light,OFF,
IDE01763,Dimming,3,
IDE02049,Trailer detected,Unknown (255),
IDE02057,Dynamic calibration: status,active,
IDE02389,Ambient brightness,0, %
IDE02486,Data logger triggering,not active,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,253,
IDE03197-MAS02477,Rain/Light Recognition Sensor-Front brightness,0,
IDE03197-ENG09275,Rain/Light Recognition Sensor-Brightness_forwards_Textual,numerical value: no text,
IDE03504-MAS03692,Personalized settings-Key 1,0,
IDE03504-MAS03693,Personalized settings-Key 2,0,
IDE03504-MAS03694,Personalized settings-Key 3,0,
IDE03504-MAS03695,Personalized settings-Key 4,0,
IDE03505-MAS03692,Personalized settings dimming-Key 1,3,
IDE03505-MAS03693,Personalized settings dimming-Key 2,4,
IDE03505-MAS03694,Personalized settings dimming-Key 3,3,
IDE03505-MAS03695,Personalized settings dimming-Key 4,3,
IDE05068,Driver side warning light flashing cycle,Unknown (255),
IDE05069,Frt.pass. side warning light flashing cycle,Unknown (255),
IDE05070,Curve radius,65458, m
IDE05071,Lane change assistance button,not activated,
IDE05075,Status of driver side warning light,OFF,
IDE05076,Status of frt.pass. side warning light,OFF,
IDE05089,Dynamic calibration: distance traveled,0, km
IDE05090,Measured receiving power lane change assist. 1,1, %
IDE05091,Measured receiving power lane change assist. 2,58, %
IDE05092,Measured angle lane change assist. 1,-40.20, °
IDE05093,Measured angle lane change assist. 2,41.00, °
IDE05094,Static angle offset lane change assist. 1,0.16, °
IDE05095,Static angle offset lane change assist. 2,-1.19, °
IDE05393,Currently used key,Key 3,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE09232,Vehicle speed from radar measurement,0.00, km/h
IDE09387,Dynamic angle offset lane change assist.,1.50, °
IDE09388,Rear cross traffic assistant: warning levels,Stage 0,
IDE09780,System condition ctrl. mod.,Terminal 15 on,
IDE09781,Syst. condition lane change assistance,Available,
IDE09782,System condition rear cross traffic assistant,Available,
IDE09783,System condition pre sense rear,Available,
IDE09784,Functional status of lane change assist.,passive,
IDE09785,Function condition rear cross traffic assistant,OFF,
IDE09786,Function condition pre sense rear,passive,
IDE10587,Exit warning: function condition,active,
IDE10588,Exit warning: system condition,Available,
ENG112308,ECU_Serial_Number,32 36 2E 30 31 2E 31 38 37 37 31 32 41 34 38 39,
Elapsed Time: 00:05
adpmap-3C-4M0-907-566-D
;Sunday,10,November,2019,20:37:29:01617
IDE00001-MAS15623-Production mode-Deactivation of lane change assistance and exit warning,not active ,3
IDE00001-MAS15624-Production mode-Deactivation of Cross traffic assistant rear and pre sense rear,not active ,3
IDE00820-Activating and deactivating all development messages,not activated ,1
IDE05394-Brightness characteristic of warning display,normal ,1
Elapsed Time: 00:04
Address [42]
blockmap-42-4M0-959-793-H
;SW:4M0-959-793-H   HW:4M0-959-793-F ---  Door Elect, Driver
;Component:TSG FS        005 0129, Coding:005F1B205E001080000100B2
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_AU49.rod
;Sunday,10,November,2019,20:37:35:01617
;VCID: C3C94C4A4A9309577A-8096
IDE00030,Status of actuator test,not active,
IDE00310,Outside air temperature,26.50, °C
IDE00322,Status of basic setting,was not yet started,
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver side door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Driver side rear door control module,
IDE02262,synchronous mirror adjustment,not active,
IDE02267-IDE00773,Supply voltage for door control module: front: driver side-Terminal 15 status via CAN,active,
IDE02267-IDE01715,Supply voltage for door control module: front: driver side-Status terminal S,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,13.10, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE02668,Central window regulator switch,not installed,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,Sleep mode,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not activated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,not activated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,not activated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,not activated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,not activated,
IDE04220,Driver power window button,not activated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Busmaster,
IDE04411,Child Safety Lock Switch,not activated,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,48, %
IDE04539-MAS02229,Mirror memory-Y coordinate,49, %
IDE04539-MAS02476,Mirror memory-install,installed,
IDE04540,Mirror adjustment (X/Y-direction),Position center,
IDE04580,Dimming of inside door handle lighting,58, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,On,
IDE05071-MAS07693,Lane change assistance button-Button Status,not activated,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,not activated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not activated,
IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
IDE05725,Terminal 58xs dimmer,58, %
IDE05726,Terminal 58xd dimmer,2, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not activated,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02039,Front window regulator status: driver side-Force limitation,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,56.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Power window control standardized,Yes,
IDE06206-MAS03548,Front window regulator status: driver side-Motor current,0, A
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,not active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Idle condition,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not activated,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not activated,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not activated,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06933,Front window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE07222,Window regulator child lock: driver side,Not available,
IDE07405-IDE03114,Enable driver front window regulator relay-Comfort function,No,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07409-MAS01632,Excessive temper. disconnect: front window regulator: driv.side-Status,not active,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,35, °C
IDE07413,Comfort function for front window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08061,Child safety lock button 2,not installed,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE08697-MAS07303,Number of driving cycles without opening door-Actual number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,automatic day/night exterior mirror-Status,not active,
IDE10164-MAS03691,automatic day/night exterior mirror-Dimming,0, %
MAS01872,Rear lid remote release button,not activated,
MAS02099,Switch for inside door handle,not installed,
MAS02100,Switch for outside door handle,not installed,
MAS02101,Child safety,active,
MAS06010,Ambient light,100, %
Elapsed Time: 00:07
adpmap-42-4M0-959-793-H
;Sunday,10,November,2019,20:37:43:01617
IDE00001-MAS10864-Production mode-Reduce reverse threshold,Deactivating ,3
IDE00001-MAS10865-Production mode-Power windows operable with terminal 15 off,Deactivating ,3
IDE00001-MAS10866-Production mode-Reduce switch-on time of lighting,Deactivating ,3
IDE00001-MAS10867-Production mode-Deactivate speed control for power windows,Deactivating ,3
IDE00001-MAS10868-Production mode-Deactivate closing aid,Deactivating ,3
IDE00001-MAS10869-Production mode-Activate test mode for the fold-in mirror,Deactivating ,3
IDE00001-MAS10870-Production mode-Activate test mode for power windows,Deactivating ,3
IDE00001-MAS17286-Production mode-Deactivation of actuation of opening assistance motor: e-lock,Deactivating ,3
IDE00001-MAS17291-Production mode-Deactivation of CarWakeUp due to activation of seatbelt feeder,Deactivating ,3
ENG117297-Reversing_Threshold_Driver_Side_Front,90 %,1
Elapsed Time: 00:02
Address [44]
blockmap-44-8W0-909-144-H
;SW:8W0-909-144-H   HW:8W0-909-144-B ---  Steering Assist
;Component:EPS_MLBEVO_ZF H08 0410, Coding:09000380008000
;EV_EPSZFAU49X,003023,EV_EPSZFAU49X_003.rod
;Sunday,10,November,2019,20:37:48:01617
;VCID: C2C7494E5589005F71-8096
IDE00020,Terminal 15 status,active,
IDE00102,Control Module temperature,56, °C
IDE00102-IDE02202,Control Module temperature-End stage temperature,49, °C
IDE00321,Manufacture location index,0658,
IDE02068-MAS00106,Time stamp-Year,2019, yr
IDE02068-MAS00107,Time stamp-Month,11, m
IDE02068-MAS00108,Time stamp-Day,10, d
IDE02068-MAS00109,Time stamp-Hours,20, H
IDE02068-MAS00110,Time stamp-Minutes,37, min
IDE02068-MAS00111,Time stamp-Seconds,47, s
IDE02068-MAS00711,Time stamp-Odometer reading,32501, km
IDE02224-MAS02981,Active assisted steering angle-Overlay angle,0.00, °
IDE02224-MAS09580,Active assisted steering angle-Sensor status,invalid,
IDE03008-MAS05361,Stop process prevented-Manual steering torque too large,not active,
IDE03008-MAS05409,Stop process prevented-Calculated steering angle too large,active,
IDE03008-MAS14902,Stop process prevented-Limp home mode active,not active,
IDE03008-ENG09521,Stop process prevented-Start_Stop_Prohibition_Reason_4,not active,
IDE03008-ENG09522,Stop process prevented-Start_Stop_Prohibition_Reason_5,not active,
IDE03010-MAS05361,Number of prevented stop processes-Manual steering torque too large,1,
IDE03010-MAS05409,Number of prevented stop processes-Calculated steering angle too large,39,
IDE03010-MAS14902,Number of prevented stop processes-Limp home mode active,0,
IDE03010-ENG07080,Number of prevented stop processes-Frequency_Counter_Value_Prohibition_4,0,
IDE03010-ENG07081,Number of prevented stop processes-Frequency_Counter_Value_Prohibition_5,0,
IDE03011-ENG07082,Number of requested start processes-Frequency_Counter_Value_Restart_1,10,
IDE03011-ENG07083,Number of requested start processes-Frequency_Counter_Value_Restart_2,0,
IDE03011-ENG07084,Number of requested start processes-Frequency_Counter_Value_Restart_3,0,
IDE03011-ENG07085,Number of requested start processes-Frequency_Counter_Value_Restart_4,0,
IDE03011-ENG07086,Number of requested start processes-Frequency_Counter_Value_Restart_5,0,
IDE03680-MAS00043,Supply voltages-Supply voltage: Terminal 30,13.28, V
IDE03682-IDE04457,Sensor for motor position-Electric motor speed,7, /min
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
IDE03726-MAS05631,Parallel Parking Assistance-System status,not active,
IDE03734,Support power,100.00, %
IDE03734-MAS03095,Support power-Function status,activated,
IDE03735,Steering torque,-0.07, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE04186,Battery terminal recognition,connected,
IDE04561-MAS00371,Switch-on and shut-off conditions-Engine speed,795, /min
IDE04561-MAS08112,Switch-on and shut-off conditions-Drive readiness,not activated,
IDE04561-MAS10224,Switch-on and shut-off conditions-Calculated vehicle speed,0.00, km/h
IDE04561-MAS13443,Switch-on and shut-off conditions-Calculated vehicles speed: status,valid,
IDE04561-MAS13444,Switch-on and shut-off conditions-Engine speed status,valid,
IDE04805-MAS05629,Driving profile selection-Driving profile: specified value,automatic,
IDE04805-MAS05630,Driving profile selection-Driving profile: actual value,automatic,
IDE05155,Power steering current consumption,0.00, A
IDE05162-MAS01849,Software end stop-Left,69.30, mm
IDE05162-MAS01850,Software end stop-Right,-67.16, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05162-MAS11513,Software end stop-End stop left,Adapted during slow drive,
IDE05162-MAS11514,Software end stop-End stop right,Adapted during slow drive,
IDE05963-MAS09952,ASSY part number-Part Number,8W1423055AE,
IDE05963-MAS11961,ASSY part number-Serial number,00407519,
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,11,
IDE06307-MAS00108,Stop prevention history data-Day,3,
IDE06307-MAS00109,Stop prevention history data-Hours,21,
IDE06307-MAS00110,Stop prevention history data-Minutes,29,
IDE06307-MAS00111,Stop prevention history data-Seconds,53,
IDE06307,Stop prevention history data,Calculated steering angle too large,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2019,
IDE06308-MAS00107,Start request history data-Month,9,
IDE06308-MAS00108,Start request history data-Day,16,
IDE06308-MAS00109,Start request history data-Hours,9,
IDE06308-MAS00110,Start request history data-Minutes,1,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE06308,Start request history data,Start request,
IDE06657-MAS01567,Steering angle: calculated-Synchronization,rawinit,
IDE06657-MAS01632,Steering angle: calculated-Status,rawinit,
IDE06657-ENG06987,Steering angle: calculated-Steering_Angle_Calculated,-317.30, °
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE10902-MAS01493,Expanded ambient data 1-Engine running,Engine_not_running,
IDE10902-MAS01634,Expanded ambient data 1-Supply voltage,0.00, V
IDE10902-MAS02201,Expanded ambient data 1-Temperature,-70, °C
IDE10902-MAS05631,Expanded ambient data 1-System status,0,
IDE10902,Expanded ambient data 1,4C,
IDE10902-ENG117774,Expanded ambient data 1-driving_direction,1,
IDE10902-ENG120717,Expanded ambient data 1-KFA,32768,
IDE10902-ENG120716,Expanded ambient data 1-KFC,320,
IDE10902-ENG07008,Expanded ambient data 1-Ready_To_Drive_Bit,0,
IDE10902-ENG07009,Expanded ambient data 1-StartStop Info,0,
IDE10902-ENG06987,Expanded ambient data 1-Steering_Angle_Calculated,1011, °
IDE10902-ENG07006,Expanded ambient data 1-Steering_Angle_Calculated_Sign,0,
IDE10902-ENG110748,Expanded ambient data 1-Steering_torque,7.80, Nm
IDE10902-ENG07007,Expanded ambient data 1-Steering_Torque_Sign,0,
IDE10903-ENG31193,Expanded ambient data 2-Filtered_supply_voltage,0.00, V
IDE10903-ENG06121,Expanded ambient data 2-Switched_voltage_terminal_30_unfiltered,512.00, V
IDE10903-ENG06120,Expanded ambient data 2-Voltage_terminal_30_unfiltered,5.00, V
IDE10904-ENG07011,Expanded ambient data 3-Action_os_error_status,128,
IDE10904-ENG07012,Expanded ambient data 3-Called_from_os_error_status,0,
IDE10904-ENG07014,Expanded ambient data 3-Error_condition_os_error_status,254,
IDE10904-ENG120635,Expanded ambient data 3-OsMon_RestartReason,1,
IDE10904-ENG07010,Expanded ambient data 3-Result_os_error_status,64,
IDE10904-ENG07013,Expanded ambient data 3-Serviceld_os_error_status,76,
IDE10904-ENG07016,Expanded ambient data 3-Y_os_mon_akt_task_gdu8,98,
IDE10905-ENG07019,Expanded ambient data 4-I_cu_current_phase_u_irq_xds16,5.00, A
IDE10905-ENG07020,Expanded ambient data 4-Icu_current_phase_w_irq_xds16,-2340.57, A
IDE10905-ENG07018,Expanded ambient data 4-M_appll_limited_motor_torque_xds16,0.00, Nm
IDE10905-ENG07021,Expanded ambient data 4-M_appll_torsion_bar_torque_xds16,19.00, Nm
IDE10905-ENG07017,Expanded ambient data 4-N_applI_rotor_speed_filt_xds16,0.00, /min
IDE10905-ENG07022,Expanded ambient data 4-Wrs_curr_rotor_pos_irq_xdu16,5723.61, °
IDE10906-ENG31188,Expanded ambient data 5-feeIsNvShareCrcCheckFinished_gdb,0,
IDE10906-ENG31189,Expanded ambient data 5-feeNvShareCrcErrorDetected_gdb,0,
IDE10906-ENG07024,Expanded ambient data 5-Rom_ram_ecc_adr_1,5045858,
IDE10906-ENG07023,Expanded ambient data 5-Rom_ram_ecc_eipc,21004288,
IDE10906-ENG33383,Expanded ambient data 5-yeeFirstUnusedNVShareAddr_gdu32,0,
IDE10907-ENG07029,Expanded ambient data 6-Asc_ctrll_get_la_reg,76,
IDE10907-ENG07021,Expanded ambient data 6-M_appll_torsion_bar_torque_xds16,0.00, Nm
IDE10907-ENG07027,Expanded ambient data 6-Sst_mdsensor_state_xdu8,0,
IDE10907-ENG07031,Expanded ambient data 6-Sst_sensor_voltage_state_xdu8,98,
IDE10907-ENG07026,Expanded ambient data 6-Yee_torque_sensor_type_xdu8,4,
IDE10907-ENG07030,Expanded ambient data 6-Yio_dms_error_type_xau16,254,
IDE10907-ENG07025,Expanded ambient data 6-Yio_dms_sin_xas16,0.10, %
IDE10907-ENG07028,Expanded ambient data 6-Ystf_torque_rad_filtrd_xau16,3200.00,
IDE10908-ENG07032,Expanded ambient data 7-Ycp_error_ident_level1_xdu16,0,
IDE10908-ENG07036,Expanded ambient data 7-Ycp_lower_limit_level1_xds16,-414,
IDE10908-ENG07034,Expanded ambient data 7-Ycp_neg_value_level1_xds16,16512,
IDE10908-ENG07033,Expanded ambient data 7-Ycp_pos_value_level1_xds16,1,
IDE10908-ENG07035,Expanded ambient data 7-Ycp_upper_limit_level1_xds16,76,
IDE10909-ENG07041,Expanded ambient data 8-1_xau16[1]_yod_pwd,0.16, %
IDE10909-ENG07042,Expanded ambient data 8-2_xau16[2]_yod_pwd,128.91, %
IDE10909-ENG07040,Expanded ambient data 8-Xau16[0]_yod_pwd,4.96, %
IDE10909-ENG07037,Expanded ambient data 8-Yod_pwm_xau16[0],0.00, %
IDE10909-ENG07038,Expanded ambient data 8-Yod1_pwm_xau16[1],0.00, %
IDE10909-ENG07039,Expanded ambient data 8-Yod2_pwm_xau16[2],0.78, %
IDE10910-ENG31869,Expanded ambient data 9-ioCSIE0CmdQueuePointer 2,128,
IDE10910-ENG31870,Expanded ambient data 9-ioCSIE0TransferStatus,1,
IDE10910-ENG31871,Expanded ambient data 9-ioCSIEOCmdQueueSize 3,0,
IDE10910-ENG31872,Expanded ambient data 9-ioCSIEOFirstCmdNotSend 4,76,
IDE10910-ENG07048,Expanded ambient data 9-Zck_csie0_first_cmdn_sended_mdu16,65122,
IDE10910-ENG07044,Expanded ambient data 9-Zck_csie0_retry_counter_xdu8,64,
IDE10911-ENG07053,Expanded ambient data 10-1_uad_hall1_xdu16,0.00, V
IDE10911-ENG07054,Expanded ambient data 10-2_uad_hall2_xdu16,0.00, V
IDE10911-ENG07050,Expanded ambient data 10-Cos_uio_rp_cos_main_xdu16,0.00, V
IDE10911-ENG07052,Expanded ambient data 10-Cos2_uio_rp_cos2_main_xdu16,0.41, V
IDE10911-ENG07049,Expanded ambient data 10-Sin_uio_rp_sin_main_xdu16,0.00, V
IDE10911-ENG07051,Expanded ambient data 10-Sin2_uio_rp_sin2_main_xdu16,0.06, V
IDE10911-ENG07057,Expanded ambient data 10-Xrs_asic_sin_amp_xdu16,196,
IDE10936-ENG07059,Expanded ambient data 11-Asc_ctrll_get_requlo_finish,0,
IDE10936-ENG07060,Expanded ambient data 11-Asc_wdI_get_threshold,0,
IDE10936-ENG120682,Expanded ambient data 11-Internal State Error,0,
IDE10936-ENG07058,Expanded ambient data 11-Output_stage_Signal,0,
IDE10936-ENG07063,Expanded ambient data 11-Register_dia1,128,
IDE10936-ENG07064,Expanded ambient data 11-Register_dia2,0,
IDE10936-ENG07065,Expanded ambient data 11-Register_dia3,76,
IDE10936-ENG07066,Expanded ambient data 11-Register_dia4,254,
IDE10936-ENG07067,Expanded ambient data 11-Register_dia5,98,
IDE10936-ENG07062,Expanded ambient data 11-Register_ehr,64,
IDE10936-ENG07061,Expanded ambient data 11-Register_rdt,1,
IDE10937-ENG07068,Expanded ambient data 12-Cappll_dbc_temp_u_xds16,0, °C
IDE10937-ENG07069,Expanded ambient data 12-Cappll_dbc_temp_v_xds16,1, °C
IDE10937-ENG07070,Expanded ambient data 12-Cappll_dbc_temp_w_xds16,16512, °C
IDE10938-ENG07076,Expanded ambient data 13-lappll_rack_position_xds16,-12.94, mm
IDE10938-ENG07074,Expanded ambient data 13-Mappll_limited_motor_torque_xds16,8.00, Nm
IDE10938-ENG07073,Expanded ambient data 13-Mappll_torsion_bar_torque_xds16,0.31, Nm
IDE10938-ENG07075,Expanded ambient data 13-Nappll_rotor_speed_filt_xds16,1228, /min
IDE10938-ENG07072,Expanded ambient data 13-Ycp_conversion_factor_xds16,0,
IDE10938-ENG07071,Expanded ambient data 13-Ycp_error_ident_level2_xdu16,0,
IDE11867-IDE03525,Steering torque sensor: identification-Sensor identification number (sensor ID),00000000 00000000 ,
IDE11867-MAS00106,Steering torque sensor: identification-Year,2018, yr
IDE11867-MAS00107,Steering torque sensor: identification-Month,2, m
IDE11867-MAS00108,Steering torque sensor: identification-Day,6, d
IDE12638-ENG36803,Expanded ambient data 14-KFA_FAST_RESET,76,
IDE12638-ENG36804,Expanded ambient data 14-KFC_FAST_RESET,16512,
IDE12638-ENG06121,Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered,196.28, V
IDE12638-ENG06120,Expanded ambient data 14-Voltage_terminal_30_unfiltered,0.00, V
IDE12990-ENG36824,Expanded ambient data 15-MsgStateFifo_Byte0,00 00 31 12,
IDE12990-ENG36825,Expanded ambient data 15-MsgStateFifo_Byte1,40 80 00 4C,
IDE12990-ENG36826,Expanded ambient data 15-MsgStateFifo_Byte2,FE 62 70 80,
IDE12990-ENG36827,Expanded ambient data 15-MsgStateFifo_Byte3,00 4C E8 C5,
IDE12990-ENG36829,Expanded ambient data 15-NumOfMsgCntFaults,8A,
IDE12990-ENG36830,Expanded ambient data 15-NumOfMsgCrcFaults_2,00,
IDE12990-ENG36831,Expanded ambient data 15-NumOfMsgNoFaults_3,4C,
IDE12990-ENG36832,Expanded ambient data 15-NumOfMsgTimoFaults_1,80,
IDE12991-ENG36677,Expanded ambient data 16-(Null),FE,
IDE12991-ENG36679,Expanded ambient data 16-Access_Status,31,
IDE12991-ENG36688,Expanded ambient data 16-Background_Status,12,
IDE12991-ENG36692,Expanded ambient data 16-BlockIdBitCoded,40 80 00 4C,
IDE12991-ENG36807,Expanded ambient data 16-locStatus,62,
IDE12991-ENG36834,Expanded ambient data 16-Operation_Status,00 00,
MAS00815-MAS01632,Steering angle sensor-Status,valid,
MAS00815-MAS02983,Steering angle sensor-Steering wheel angle,-316.50, °
MAS00815-MAS02984,Steering angle sensor-Steering angle speed,0.50, °/s
MAS00815-MAS04924,Steering angle sensor-Initialization of steering angle,locked,
MAS00815-MAS09519,Steering angle sensor-Message error,Unknown (76),
MAS00815-MAS13281,Steering angle sensor-Steering angle: quality,valid,
ENG98964,System status,Driveup,
ENG06988,Warning_lamp_Status,OFF,
Elapsed Time: 00:07
adpmap-44-8W0-909-144-H
;Sunday,10,November,2019,20:37:55:01617
IDE00820-ENG110581-Activating and deactivating all development messages-PDU_DEV_01,not activated ,1
IDE00820-ENG110578-Activating and deactivating all development messages-S_100,not activated ,1
IDE00820-ENG110579-Activating and deactivating all development messages-S_101,not activated ,1
IDE00820-ENG110580-Activating and deactivating all development messages-S_102,not activated ,1
IDE00820-ENG99057-Activating and deactivating all development messages-XCP,not activated ,1
IDE04555-MAS13276-Activation of pwr steering asst without engine running-21% steering support,not activated ,5
IDE04555-MAS13277-Activation of pwr steering asst without engine running-41% steering support,not activated ,5
IDE04555-MAS13278-Activation of pwr steering asst without engine running-61% steering support,not activated ,5
IDE04555-MAS13279-Activation of pwr steering asst without engine running-81% steering support,not activated ,5
IDE04555-MAS13280-Activation of pwr steering asst without engine running-100% steering support,not activated ,5
ENG110746-V_limit_kL30_disconnect,18 km/h,2
Elapsed Time: 00:01
Address [46]
blockmap-46-8W0-907-064-EC
;SW:8W0-907-064-EC   HW:8W0-907-064-DC ---  Central Conv.
;Component:BCM2 MLBevo   025 0387, Coding:013400004FB00080650FA0002E01000233024000810026502F0400000B04803F001E0001000000
;EV_BCM2HellaAU736,014014,EV_BCM2HellaAU736_014_AU49.rod
;Sunday,10,November,2019,20:37:59:01617
;VCID: 81458642100FDB4728-80D4
IDE00027-MAS04423,Status of brake signals-Automatic braking signal via CAN,not active,
IDE00027-MAS04424,Status of brake signals-Driver brakes signal via CAN,not active,
IDE00027-MAS06469,Status of brake signals-Brake light signal,not active,
IDE00027-MAS06470,Status of brake signals-Brake light signal via CAN,not active,
IDE00027-MAS06471,Status of brake signals-Request emergency brake display,OFF,
IDE00027-MAS15241,Status of brake signals-Brake light signal from brake booster control module,Not available,
IDE00096-MAS00364,Selector lever position-Shift lever / selector lever position,Selector lever in position P,
IDE00096-MAS06480,Selector lever position-Transmission park selector switch,not coded/not installed,
IDE00306-MAS02227,Fuel Level Sensor 1-Quality,10,
IDE00306-MAS06614,Fuel Level Sensor 1-Version,Three-wire sensor,
IDE00306-MAS06615,Fuel Level Sensor 1-Soiling resistance,2,
IDE00306-MAS06621,Fuel Level Sensor 1-Raw value 1,00 FC,
IDE00306-MAS06622,Fuel Level Sensor 1-Raw value 2,02 51,
IDE00306-MAS06623,Fuel Level Sensor 1-Sensor including soiling resistance,65,
IDE00306-MAS06624,Fuel Level Sensor 1-Sensor without soiling resistance,63,
IDE00306-MAS06643,Fuel Level Sensor 1-Resistance 1: measurable value,66,
IDE00306-MAS06644,Fuel Level Sensor 1-Resistance 2: measurable value,282,
IDE00307-MAS02227,Fuel Level Sensor 2-Quality,10,
IDE00307-MAS06614,Fuel Level Sensor 2-Version,Three-wire sensor,
IDE00307-MAS06615,Fuel Level Sensor 2-Soiling resistance,3,
IDE00307-MAS06621,Fuel Level Sensor 2-Raw value 1,02 4E,
IDE00307-MAS06622,Fuel Level Sensor 2-Raw value 2,01 13,
IDE00307-MAS06623,Fuel Level Sensor 2-Sensor including soiling resistance,272,
IDE00307-MAS06624,Fuel Level Sensor 2-Sensor without soiling resistance,269,
IDE00307-MAS06643,Fuel Level Sensor 2-Resistance 1: measurable value,279,
IDE00307-MAS06644,Fuel Level Sensor 2-Resistance 2: measurable value,75,
IDE00308-MAS02227,Fuel Level Sensor 3-Quality,not coded/not installed,
IDE00308-MAS06614,Fuel Level Sensor 3-Version,not coded/not installed,
IDE00308-MAS06615,Fuel Level Sensor 3-Soiling resistance,not coded/not installed,
IDE00308-MAS06621,Fuel Level Sensor 3-Raw value 1,not coded/not installed,
IDE00308-MAS06622,Fuel Level Sensor 3-Raw value 2,not coded/not installed,
IDE00308-MAS06623,Fuel Level Sensor 3-Sensor including soiling resistance,not coded/not installed,
IDE00308-MAS06624,Fuel Level Sensor 3-Sensor without soiling resistance,not coded/not installed,
IDE00308-MAS06643,Fuel Level Sensor 3-Resistance 1: measurable value,not coded/not installed,
IDE00308-MAS06644,Fuel Level Sensor 3-Resistance 2: measurable value,not coded/not installed,
IDE00309-MAS02227,Fuel Level Sensor 4-Quality,not coded/not installed,
IDE00309-MAS06614,Fuel Level Sensor 4-Version,not coded/not installed,
IDE00309-MAS06615,Fuel Level Sensor 4-Soiling resistance,not coded/not installed,
IDE00309-MAS06621,Fuel Level Sensor 4-Raw value 1,not coded/not installed,
IDE00309-MAS06622,Fuel Level Sensor 4-Raw value 2,not coded/not installed,
IDE00309-MAS06623,Fuel Level Sensor 4-Sensor including soiling resistance,not coded/not installed,
IDE00309-MAS06624,Fuel Level Sensor 4-Sensor without soiling resistance,not coded/not installed,
IDE00309-MAS06643,Fuel Level Sensor 4-Resistance 1: measurable value,not coded/not installed,
IDE00309-MAS06644,Fuel Level Sensor 4-Resistance 2: measurable value,not coded/not installed,
IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,0,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE01285,Counter of component protection malfunctions,00 00,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01464-MAS01580,Rear window defogger-Activation,OFF,
IDE01464-MAS06528,Rear window defogger-Release status,No enabling,
IDE01464-MAS06996,Rear window defogger-Validity of filtered outside temperature,valid,
IDE01464-MAS06997,Rear window defogger-Outside temperature: filtered,25.5, °C
IDE01464-MAS09460,Rear window defogger-Release status: convert. top ctrl. mod.,not coded/not installed,
IDE01464-MAS13453,Rear window defogger-Load requirement of 12 V energy management,no request,
IDE01537-MAS01581,Windshield defogger-Power consumption,not coded/not installed,
IDE01537-MAS01737,Windshield defogger-Diagnosis,not coded/not installed,
IDE01537-MAS04737,Windshield defogger-Indicator lamp,not coded/not installed,
IDE01537-MAS05030,Windshield defogger-Resistance,not coded/not installed,
IDE01537-MAS05851,Windshield defogger-Current power consumption,not coded/not installed,
IDE01537-MAS06535,Windshield defogger-Resistance: lower limit value,not coded/not installed,
IDE01537-MAS06536,Windshield defogger-Resistance: upper limit value,not coded/not installed,
IDE01537-MAS06537,Windshield defogger-Power consumption: target value,not coded/not installed,
IDE01537-MAS06726,Windshield defogger-Hardware / software version,not coded/not installed,
IDE01537-MAS06732,Windshield defogger-Status local activity,not coded/not installed,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not activated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,not coded/not installed,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,not activated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,Open,
IDE02092-MAS09072,Tailgate condition-Locking mechanism button in the rear lid,not coded/not installed,
IDE02488-MAS01632,DWA Interior monitoring-Status,not active,
IDE02488-MAS04508,DWA Interior monitoring-Alarm detected,No,
IDE02711-MAS01580,Rear Window Wiper-Activation,not coded/not installed,
IDE02711-MAS07731,Rear Window Wiper-No. of wisher cycles,not coded/not installed,
IDE02711-MAS07732,Rear Window Wiper-Number of recognized blockings,not coded/not installed,
IDE02711-MAS07733,Rear Window Wiper-Requirements rear window wiper,not coded/not installed,
IDE02711-MAS07939,Rear Window Wiper-Rear window wiper motor diagnostic,not coded/not installed,
IDE02711-MAS07940,Rear Window Wiper-Contact switch for rear window wiper end shelf,not coded/not installed,
IDE02711-MAS07965,Rear Window Wiper-Contact switch for rear window wiper end shelf diagnostic,not coded/not installed,
IDE03008-MAS09566,Stop process prevented-Key not in vehicle,not active,
IDE03010-MAS09566,Number of prevented stop processes-Key not in vehicle,0,
IDE03527-MAS12075,CAN signals-Keyless entry and start authorization: driver info,0,
IDE03659-MAS03834,Roller test bench mode-Emergency signal flashing,not active,
IDE03659-MAS06320,Roller test bench mode-Status rolling mode,not active,
IDE03680-MAS00043,Supply voltages-Supply voltage: Terminal 30,13.424, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,13.452, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,13.452, V
IDE04254-MAS00215,Play protection for central locking-Tank flap,not active,
IDE04254-MAS00222,Play protection for central locking-Rear lid,not active,
IDE04254-MAS02444,Play protection for central locking-Central locking,not active,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE05822-MAS01632,DWA Vehicle inclination sensor-Status,not active,
IDE05822-MAS04508,DWA Vehicle inclination sensor-Alarm detected,No,
IDE05824-MAS04583,DWA Vehicle inclination sensor: angle-Reference angle: X-axis,-1.2, °
IDE05824-MAS04584,DWA Vehicle inclination sensor: angle-Reference angle: Y-axis,8.4, °
IDE05824-MAS04585,DWA Vehicle inclination sensor: angle-Reference angle: Z-axis,Implausible,
IDE05824-MAS04586,DWA Vehicle inclination sensor: angle-Angle difference: X-axis,0.0, °
IDE05824-MAS04587,DWA Vehicle inclination sensor: angle-Angle difference: Y-axis,0.0, °
IDE05824-MAS04588,DWA Vehicle inclination sensor: angle-Angle difference: Z-axis,Implausible,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Alarm horn for anti-theft warning system,not coded/not installed,
IDE05828-MAS00976,DWA History data for alarm triggering-Counter,55,
IDE05828-MAS02545,DWA History data for alarm triggering-Last,Activation by external system,
IDE05828-MAS02546,DWA History data for alarm triggering-Second to last,Activation by external system,
IDE05828-MAS02547,DWA History data for alarm triggering-Third to last,Activation by external system,
IDE05828-MAS02548,DWA History data for alarm triggering-Fourth to last,Activation by external system,
IDE05832,DWA Number of alarms triggered in anti-theft warn.system sensor,22,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Key not in vehicle,
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06324-MAS10861,Tank cap lock-Fuel tank cap unlocked via ECM,not coded/not installed,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06644-MAS00145,Vehicle positioning system-Starter lock,not coded/not installed,
IDE06644-MAS04968,Vehicle positioning system-Vehicle positioning alarm,not coded/not installed,
IDE06926-MAS00106,History memory: reset counter-Year,2000,
IDE06926-MAS00107,History memory: reset counter-Month,0,
IDE06926-MAS00108,History memory: reset counter-Day,0,
IDE06926-MAS00109,History memory: reset counter-Hours,0,
IDE06926-MAS00110,History memory: reset counter-Minutes,0,
IDE06926-MAS00111,History memory: reset counter-Seconds,0,
IDE06926,History memory: reset counter,Insuff. voltage,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,08,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,not coded/not installed,
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,50.08, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,not coded/not installed,
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,789.8, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,4.965, V
IDE07293-IDE00500,History data of panic alarm-Hour,1,
IDE07293-IDE00501,History data of panic alarm-Minute,58,
IDE07293-MAS00107,History data of panic alarm-Month,7,
IDE07293-MAS00108,History data of panic alarm-Day,22,
IDE07293-MAS04478,History data of panic alarm-Cause for alarm activation,Panic button,
IDE08162-MAS06256,TSG driver side: signals for central locking-Status door lock,unlocked,
IDE08162-MAS06266,TSG driver side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08162-MAS06431,TSG driver side: signals for central locking-Door contact switch,closed,
IDE08162-MAS06432,TSG driver side: signals for central locking-Button for interior lock,Not operated,
IDE08162-MAS06433,TSG driver side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08163-MAS06256,TSG frt.pass.side: signals for central locking-Status door lock,unlocked,
IDE08163-MAS06266,TSG frt.pass.side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08163-MAS06431,TSG frt.pass.side: signals for central locking-Door contact switch,closed,
IDE08163-MAS06432,TSG frt.pass.side: signals for central locking-Button for interior lock,Not operated,
IDE08163-MAS06433,TSG frt.pass.side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,unlocked,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,closed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Button for interior lock,Not operated,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,unlocked,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,closed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Button for interior lock,Not operated,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08176,History data doors,11100001 ,
IDE08177-MAS06456,Central locking-Autolock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,closed,
IDE08177-MAS09895,Central locking-Act. condition: Status central locking locked,active,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09899,Central locking-Act. condition: Status central locking individual door unlocked,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,unlocked,
IDE08177-MAS16237,Central locking-Outside door handles,Initializing,
IDE08178-MAS06437,Valet parking service-Valet parking lock button,Not operated,
IDE08178-MAS06438,Valet parking service-Valet parking indicator lamp,OFF,
IDE08180-IDE00500,History data central locking: last event-Hour,18,
IDE08180-IDE00501,History data central locking: last event-Minute,32,
IDE08180-MAS00106,History data central locking: last event-Year,not known,
IDE08180-MAS00107,History data central locking: last event-Month,11,
IDE08180-MAS00108,History data central locking: last event-Day,10,
IDE08180-MAS00111,History data central locking: last event-Seconds,30,
IDE08180-MAS01551,History data central locking: last event-Key number,2,
IDE08180-MAS06441,History data central locking: last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE08181-IDE00500,History data central locking: second-to-last event-Hour,16,
IDE08181-IDE00501,History data central locking: second-to-last event-Minute,16,
IDE08181-MAS00106,History data central locking: second-to-last event-Year,not known,
IDE08181-MAS00107,History data central locking: second-to-last event-Month,11,
IDE08181-MAS00108,History data central locking: second-to-last event-Day,10,
IDE08181-MAS00111,History data central locking: second-to-last event-Seconds,45,
IDE08181-MAS01551,History data central locking: second-to-last event-Key number,2,
IDE08181-MAS06441,History data central locking: second-to-last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE08182-IDE00500,History data central locking: third-to-last event-Hour,16,
IDE08182-IDE00501,History data central locking: third-to-last event-Minute,15,
IDE08182-MAS00106,History data central locking: third-to-last event-Year,not known,
IDE08182-MAS00107,History data central locking: third-to-last event-Month,11,
IDE08182-MAS00108,History data central locking: third-to-last event-Day,10,
IDE08182-MAS00111,History data central locking: third-to-last event-Seconds,30,
IDE08182-MAS01551,History data central locking: third-to-last event-Key number,2,
IDE08182-MAS06441,History data central locking: third-to-last event-Control-section / cause,no data present,
IDE08183-IDE00500,History data central locking: fourth-to-last event-Hour,12,
IDE08183-IDE00501,History data central locking: fourth-to-last event-Minute,57,
IDE08183-MAS00106,History data central locking: fourth-to-last event-Year,not known,
IDE08183-MAS00107,History data central locking: fourth-to-last event-Month,11,
IDE08183-MAS00108,History data central locking: fourth-to-last event-Day,10,
IDE08183-MAS00111,History data central locking: fourth-to-last event-Seconds,15,
IDE08183-MAS01551,History data central locking: fourth-to-last event-Key number,2,
IDE08183-MAS06441,History data central locking: fourth-to-last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE08184-IDE00500,History data central locking: fifth-to-last event-Hour,12,
IDE08184-IDE00501,History data central locking: fifth-to-last event-Minute,56,
IDE08184-MAS00106,History data central locking: fifth-to-last event-Year,not known,
IDE08184-MAS00107,History data central locking: fifth-to-last event-Month,11,
IDE08184-MAS00108,History data central locking: fifth-to-last event-Day,10,
IDE08184-MAS00111,History data central locking: fifth-to-last event-Seconds,15,
IDE08184-MAS01551,History data central locking: fifth-to-last event-Key number,2,
IDE08184-MAS06441,History data central locking: fifth-to-last event-Control-section / cause,no data present,
IDE08187-MAS02362,Request direction flashing-Flashing: right,not active,
IDE08187-MAS02363,Request direction flashing-Flashing: left,not active,
IDE08189-MAS04309,Malfunction status flasher-Turn signal front left,no error,
IDE08189-MAS04310,Malfunction status flasher-Turn signal front right,no error,
IDE08189-MAS04311,Malfunction status flasher-Left rear turn signal,no error,
IDE08189-MAS04312,Malfunction status flasher-Turn signal rear right,no error,
IDE08190-MAS01281,Request exterior illumination-Back-up light,OFF,
IDE08190-MAS03836,Request exterior illumination-Rear fog light,OFF,
IDE08190-MAS06466,Request exterior illumination-Parking light left,OFF,
IDE08190-MAS06467,Request exterior illumination-Parking light right,OFF,
IDE08190-MAS06468,Request exterior illumination-Tail light,On,
IDE08194-MAS06982,Signals vehicle electrical system control module-Terminal 15 status signal,On,
IDE08194-MAS07716,Signals vehicle electrical system control module-Last status: terminal 15,On,
IDE08195-MAS06483,Access/Start Authorization Button-Access/start authorization button: contact 1,Not operated,
IDE08195-MAS06484,Access/Start Authorization Button-Access/start authorization button: contact 2,Not operated,
IDE08195-MAS06485,Access/Start Authorization Button-Access/start authorization button: contact 3,Not operated,
IDE08195-MAS06486,Access/Start Authorization Button-Access/start authorization button: contact 4,Not operated,
IDE08196-IDE12848,Terminal control-Remote start relay or preconditioning,not active,
IDE08196-MAS06982,Terminal control-Terminal 15 status signal,active,
IDE08196-MAS07383,Terminal control-Terminal 15 on CAN,active,
IDE08196-MAS07386,Terminal control-Terminal 50 on CAN,not active,
IDE08196-MAS07715,Terminal control-Activation: terminal 15,active,
IDE08196-MAS07716,Terminal control-Last status: terminal 15,active,
IDE08196-MAS07719,Terminal control-Terminal 50 status,not active,
IDE08197-IDE02666,Alarm horn for anti-theft warning system-Convertible top status,not coded/not installed,
IDE08197-MAS06495,Alarm horn for anti-theft warning system-Engine hood contact switch,closed,
IDE08197-MAS06507,Alarm horn for anti-theft warning system-Trailer disconnected,not coded/not installed,
IDE08197-MAS07350,Alarm horn for anti-theft warning system-Left headlight,not coded/not installed,
IDE08197-MAS07351,Alarm horn for anti-theft warning system-Right headlight,not coded/not installed,
IDE08197-MAS11121,Alarm horn for anti-theft warning system-Glass breakage sensor or glove box,not coded/not installed,
IDE08199-IDE00500,History data anti-theft protection: last event-Hour,9,
IDE08199-IDE00501,History data anti-theft protection: last event-Minute,28,
IDE08199-MAS00106,History data anti-theft protection: last event-Year,2019,
IDE08199-MAS00107,History data anti-theft protection: last event-Month,10,
IDE08199-MAS00108,History data anti-theft protection: last event-Day,23,
IDE08199-MAS04478,History data anti-theft protection: last event-Cause for alarm activation,Door contact driver door,
IDE08200-IDE00500,History data anti-theft protection: second-to-last event-Hour,18,
IDE08200-IDE00501,History data anti-theft protection: second-to-last event-Minute,11,
IDE08200-MAS00106,History data anti-theft protection: second-to-last event-Year,2019,
IDE08200-MAS00107,History data anti-theft protection: second-to-last event-Month,7,
IDE08200-MAS00108,History data anti-theft protection: second-to-last event-Day,25,
IDE08200-MAS04478,History data anti-theft protection: second-to-last event-Cause for alarm activation,Door contact driver door,
IDE08201-IDE00500,History data anti-theft protection: third-to-last event-Hour,not known,
IDE08201-IDE00501,History data anti-theft protection: third-to-last event-Minute,not known,
IDE08201-MAS00106,History data anti-theft protection: third-to-last event-Year,not known,
IDE08201-MAS00107,History data anti-theft protection: third-to-last event-Month,not known,
IDE08201-MAS00108,History data anti-theft protection: third-to-last event-Day,not known,
IDE08201-MAS04478,History data anti-theft protection: third-to-last event-Cause for alarm activation,Alarm horn,
IDE08202-IDE00500,History data anti-theft protection: fourth-to-last event-Hour,14,
IDE08202-IDE00501,History data anti-theft protection: fourth-to-last event-Minute,18,
IDE08202-MAS00106,History data anti-theft protection: fourth-to-last event-Year,2019,
IDE08202-MAS00107,History data anti-theft protection: fourth-to-last event-Month,6,
IDE08202-MAS00108,History data anti-theft protection: fourth-to-last event-Day,18,
IDE08202-MAS04478,History data anti-theft protection: fourth-to-last event-Cause for alarm activation,Interior Monitoring,
IDE08203-MAS05851,Sunshade-Current power consumption,not coded/not installed,
IDE08203-MAS06258,Sunshade-Left child safety,not coded/not installed,
IDE08203-MAS06259,Sunshade-Right child safety,not coded/not installed,
IDE08203-MAS06513,Sunshade-Driver side rear window shade button,not coded/not installed,
IDE08203-MAS06514,Sunshade-assenger side rear window shade button,not coded/not installed,
IDE08203-MAS06515,Sunshade-Button for rear window shade,not coded/not installed,
IDE08203-MAS06516,Sunshade-Rear window shade status,not coded/not installed,
IDE08203-MAS06517,Sunshade-Rear spoiler counter,not coded/not installed,
IDE08204-MAS06520,Rear lid -closed- sensor-Rear lid -closed- sensor 1,not coded/not installed,
IDE08204-MAS06521,Rear lid -closed- sensor-Rear lid -closed- sensor 2,not coded/not installed,
IDE08204-MAS06522,Rear lid -closed- sensor-Rear lid: Status,not coded/not installed,
IDE08206-MAS06714,Local data bus: bus level malfunction-Local data bus: malfunction status,no error,
IDE08206-MAS06715,Local data bus: bus level malfunction-Local data bus 2: malfunction status,no error,
IDE08206-MAS06716,Local data bus: bus level malfunction-Local data bus 3: malfunction status,no error,
IDE08206-MAS06717,Local data bus: bus level malfunction-Local data bus 4: malfunction status,not coded/not installed,
IDE08206-MAS06718,Local data bus: bus level malfunction-Local data bus 5: malfunction status,not coded/not installed,
IDE08206-MAS06719,Local data bus: bus level malfunction-Local data bus 6: malfunction status,not coded/not installed,
IDE08206-MAS06720,Local data bus: bus level malfunction-Local data bus: malfunction counter,0,
IDE08206-MAS06721,Local data bus: bus level malfunction-Local data bus 2: malfunction counter,0,
IDE08206-MAS06722,Local data bus: bus level malfunction-Local data bus 3: malfunction counter,0,
IDE08206-MAS06723,Local data bus: bus level malfunction-Local data bus 4: malfunction counter,not coded/not installed,
IDE08206-MAS06724,Local data bus: bus level malfunction-Local data bus 5: malfunction counter,not coded/not installed,
IDE08206-MAS06725,Local data bus: bus level malfunction-Local data bus 6: malfunction counter,not coded/not installed,
IDE08208-MAS06528,Control module for rear lid opening-Release status,No enabling,
IDE08208-MAS06529,Control module for rear lid opening-Trailer recognition,no approach,
IDE08208-MAS06532,Control module for rear lid opening-Foot gestic recognition,No foot gestic,
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status GSG,F8,
IDE08235-MAS06805,Status of immobilizer participant-Status ELV,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,No,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,No,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,00000000 ,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,00000000 ,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,00000000 ,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,00000000 ,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,00000000 ,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,00000000 ,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,00000000 ,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,20 33 A6 98,
IDE08240,Transponder ID Key 2,20 34 F9 BE,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,02 38 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00,
IDE08251-MAS06850,Configuration immobilizer-Supported power class 2,00,
IDE08251-MAS06851,Configuration immobilizer-Supported power class 3,00,
IDE08251-MAS06852,Configuration immobilizer-Supported power class 4,00,
IDE08251-MAS06853,Configuration immobilizer-Supported power class 5,00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,4B FC 51 0A,
IDE08343,Immobilizer Challenge,87 24 39 32,
IDE08479,Signal type,no flashing function active,
IDE08631,Radio receiver field strength (RSSI),87,
IDE09133-MAS01580,Output 1 for exterior lighting-Activation,Output not used,
IDE09133-MAS05851,Output 1 for exterior lighting-Current power consumption,Output not used,
IDE09133-MAS08347,Output 1 for exterior lighting-Assigned event code,Output not used,
IDE09133-MAS08349,Output 1 for exterior lighting-Type of connected lamp,Output not used,
IDE09134-MAS01580,Output 2 for exterior lighting-Activation,0.0, %
IDE09134-MAS05851,Output 2 for exterior lighting-Current power consumption,0, mA
IDE09134-MAS08347,Output 2 for exterior lighting-Assigned event code,B12CB00,
IDE09134-MAS08349,Output 2 for exterior lighting-Type of connected lamp,LED,
IDE09135-MAS01580,Output 3 for exterior lighting-Activation,100.0, %
IDE09135-MAS05851,Output 3 for exterior lighting-Current power consumption,246, mA
IDE09135-MAS08347,Output 3 for exterior lighting-Assigned event code,B12BE00,
IDE09135-MAS08349,Output 3 for exterior lighting-Type of connected lamp,LED,
IDE09136-MAS01580,Output 4 for exterior lighting-Activation,100.0, %
IDE09136-MAS05851,Output 4 for exterior lighting-Current power consumption,99, mA
IDE09136-MAS08347,Output 4 for exterior lighting-Assigned event code,B12C000,
IDE09136-MAS08349,Output 4 for exterior lighting-Type of connected lamp,LED,
IDE09137-MAS01580,Output 5 for exterior lighting-Activation,0.0, %
IDE09137-MAS05851,Output 5 for exterior lighting-Current power consumption,0, mA
IDE09137-MAS08347,Output 5 for exterior lighting-Assigned event code,B133600,
IDE09137-MAS08349,Output 5 for exterior lighting-Type of connected lamp,LED,
IDE09138-MAS01580,Output 6 for exterior lighting-Activation,0.0, %
IDE09138-MAS05851,Output 6 for exterior lighting-Current power consumption,0, mA
IDE09138-MAS08347,Output 6 for exterior lighting-Assigned event code,B133400,
IDE09138-MAS08349,Output 6 for exterior lighting-Type of connected lamp,LED,
IDE09139-MAS01580,Output 7 for exterior lighting-Activation,100.0, %
IDE09139-MAS05851,Output 7 for exterior lighting-Current power consumption,119, mA
IDE09139-MAS08347,Output 7 for exterior lighting-Assigned event code,B12CA00,
IDE09139-MAS08349,Output 7 for exterior lighting-Type of connected lamp,LED,
IDE09140-MAS01580,Output 8 for exterior lighting-Activation,Output not used,
IDE09140-MAS05851,Output 8 for exterior lighting-Current power consumption,Output not used,
IDE09140-MAS08347,Output 8 for exterior lighting-Assigned event code,Output not used,
IDE09140-MAS08349,Output 8 for exterior lighting-Type of connected lamp,Output not used,
IDE09141-MAS01580,Output 9 for exterior lighting-Activation,0.0, %
IDE09141-MAS05851,Output 9 for exterior lighting-Current power consumption,0, mA
IDE09141-MAS08347,Output 9 for exterior lighting-Assigned event code,B12CC00,
IDE09141-MAS08349,Output 9 for exterior lighting-Type of connected lamp,LED,
IDE09142-MAS01580,Output 10 for exterior lighting-Activation,100.0, %
IDE09142-MAS05851,Output 10 for exterior lighting-Current power consumption,262, mA
IDE09142-MAS08347,Output 10 for exterior lighting-Assigned event code,B12BF00,
IDE09142-MAS08349,Output 10 for exterior lighting-Type of connected lamp,LED,
IDE09143-MAS01580,Output 11 for exterior lighting-Activation,0.0, %
IDE09143-MAS05851,Output 11 for exterior lighting-Current power consumption,0, mA
IDE09143-MAS08347,Output 11 for exterior lighting-Assigned event code,B133300,
IDE09143-MAS08349,Output 11 for exterior lighting-Type of connected lamp,LED,
IDE09144-MAS01580,Output 12 for exterior lighting-Activation,Output not used,
IDE09144-MAS05851,Output 12 for exterior lighting-Current power consumption,Output not used,
IDE09144-MAS08347,Output 12 for exterior lighting-Assigned event code,Output not used,
IDE09144-MAS08349,Output 12 for exterior lighting-Type of connected lamp,Output not used,
IDE09145-MAS01580,Output 13 for exterior lighting-Activation,0.0, %
IDE09145-MAS05851,Output 13 for exterior lighting-Current power consumption,0, mA
IDE09145-MAS08347,Output 13 for exterior lighting-Assigned event code,B121500,
IDE09145-MAS08349,Output 13 for exterior lighting-Type of connected lamp,LED,
IDE09146-MAS01580,Output 14 for exterior lighting-Activation,100.0, %
IDE09146-MAS05851,Output 14 for exterior lighting-Current power consumption,92, mA
IDE09146-MAS08347,Output 14 for exterior lighting-Assigned event code,B12C100,
IDE09146-MAS08349,Output 14 for exterior lighting-Type of connected lamp,LED,
IDE09147-MAS01580,Output 15 for exterior lighting-Activation,0.0, %
IDE09147-MAS05851,Output 15 for exterior lighting-Current power consumption,0, mA
IDE09147-MAS08347,Output 15 for exterior lighting-Assigned event code,B133500,
IDE09147-MAS08349,Output 15 for exterior lighting-Type of connected lamp,LED,
IDE09148-MAS01580,Output 16 for exterior lighting-Activation,Output not used,
IDE09148-MAS05851,Output 16 for exterior lighting-Current power consumption,Output not used,
IDE09148-MAS08347,Output 16 for exterior lighting-Assigned event code,Output not used,
IDE09148-MAS08349,Output 16 for exterior lighting-Type of connected lamp,Output not used,
IDE09149-MAS01580,Output 17 for exterior lighting-Activation,0.0, %
IDE09149-MAS05851,Output 17 for exterior lighting-Current power consumption,0, mA
IDE09149-MAS08347,Output 17 for exterior lighting-Assigned event code,B12C600,
IDE09149-MAS08349,Output 17 for exterior lighting-Type of connected lamp,LED,
IDE09150-MAS01580,Output 18 for exterior lighting-Activation,Output not used,
IDE09150-MAS05851,Output 18 for exterior lighting-Current power consumption,Output not used,
IDE09150-MAS08347,Output 18 for exterior lighting-Assigned event code,Output not used,
IDE09150-MAS08349,Output 18 for exterior lighting-Type of connected lamp,Output not used,
IDE09151-MAS01580,Output 19 for exterior lighting-Activation,Output not used,
IDE09151-MAS05851,Output 19 for exterior lighting-Current power consumption,Output not used,
IDE09151-MAS08347,Output 19 for exterior lighting-Assigned event code,Output not used,
IDE09151-MAS08349,Output 19 for exterior lighting-Type of connected lamp,Output not used,
IDE09153-MAS01580,Output 20 for exterior lighting-Activation,Output not used,
IDE09153-MAS05851,Output 20 for exterior lighting-Current power consumption,Output not used,
IDE09153-MAS08347,Output 20 for exterior lighting-Assigned event code,Output not used,
IDE09153-MAS08349,Output 20 for exterior lighting-Type of connected lamp,Output not used,
IDE09157-MAS01580,Output 21 for exterior lighting-Activation,Output not used,
IDE09157-MAS05851,Output 21 for exterior lighting-Current power consumption,Output not used,
IDE09157-MAS08347,Output 21 for exterior lighting-Assigned event code,Output not used,
IDE09157-MAS08349,Output 21 for exterior lighting-Type of connected lamp,Output not used,
IDE09218-MAS06793,Key information-Number of adapted keys,2,
IDE09218-MAS07008,Key information-Number of keys to be adapted,2,
IDE09218-MAS08428,Key information-Number of the active key,2,
IDE09220-MAS01551,Information of last change code error-Key number,255,
IDE09220-MAS08433,Information of last change code error-Last OK counter status control module,FF FF FF FF,
IDE09220-MAS08434,Information of last change code error-Last OK counter status control module: redundant,FF FF FF FF,
IDE09220-MAS08435,Information of last change code error-Last OK counter status key,FF FF FF FF,
IDE09220-MAS08436,Information of last change code error-Counter status control module at error event,FF FF FF FF,
IDE09220-MAS08437,Information of last change code error-Counter status control module at error event: redundant,FF FF FF FF,
IDE09220-MAS08438,Information of last change code error-Counter status key at error event,FF FF FF FF,
IDE09220-MAS08460,Information of last change code error-Time between last OK recognition and error event,6553.500, s
IDE09221-MAS03692,Change code counter status-Key 1,00 00 09 C2,
IDE09221-MAS03693,Change code counter status-Key 2,00 02 9A 79,
IDE09221-MAS03694,Change code counter status-Key 3,Not adapted,
IDE09221-MAS03695,Change code counter status-Key 4,Not adapted,
IDE09221-MAS03696,Change code counter status-Key 5,Not adapted,
IDE09221-MAS03697,Change code counter status-Key 6,Not adapted,
IDE09221-MAS03698,Change code counter status-Key 7,Not adapted,
IDE09221-MAS03699,Change code counter status-Key 8,Not adapted,
IDE09250-MAS08462,Key search in vehicle interior-Authenticated key in search area,00000000 ,
IDE09250-MAS08463,Key search in vehicle interior-Authenticated key,00000000 ,
IDE09250-MAS08464,Key search in vehicle interior-Recognized key,00000000 ,
IDE09252-MAS08462,Key search in trunk-Authenticated key in search area,00000000 ,
IDE09252-MAS08463,Key search in trunk-Authenticated key,00000000 ,
IDE09252-MAS08464,Key search in trunk-Recognized key,00000000 ,
IDE09253-MAS08462,Key search in left area-Authenticated key in search area,00000000 ,
IDE09253-MAS08463,Key search in left area-Authenticated key,00000000 ,
IDE09253-MAS08464,Key search in left area-Recognized key,00000000 ,
IDE09254-MAS08462,Key search in right area-Authenticated key in search area,00000000 ,
IDE09254-MAS08463,Key search in right area-Authenticated key,00000000 ,
IDE09254-MAS08464,Key search in right area-Recognized key,00000000 ,
IDE09255-MAS08462,Key search in rear area-Authenticated key in search area,00000000 ,
IDE09255-MAS08463,Key search in rear area-Authenticated key,00000000 ,
IDE09255-MAS08464,Key search in rear area-Recognized key,00000000 ,
IDE09401-IDE00500,History data central locking: sixth-to-last event-Hour,19,
IDE09401-IDE00501,History data central locking: sixth-to-last event-Minute,50,
IDE09401-MAS00106,History data central locking: sixth-to-last event-Year,not known,
IDE09401-MAS00107,History data central locking: sixth-to-last event-Month,11,
IDE09401-MAS00108,History data central locking: sixth-to-last event-Day,9,
IDE09401-MAS00111,History data central locking: sixth-to-last event-Seconds,15,
IDE09401-MAS01551,History data central locking: sixth-to-last event-Key number,2,
IDE09401-MAS06441,History data central locking: sixth-to-last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE09402-IDE00500,History data central locking: seventh-to-last event-Hour,19,
IDE09402-IDE00501,History data central locking: seventh-to-last event-Minute,50,
IDE09402-MAS00106,History data central locking: seventh-to-last event-Year,not known,
IDE09402-MAS00107,History data central locking: seventh-to-last event-Month,11,
IDE09402-MAS00108,History data central locking: seventh-to-last event-Day,9,
IDE09402-MAS00111,History data central locking: seventh-to-last event-Seconds,15,
IDE09402-MAS01551,History data central locking: seventh-to-last event-Key number,2,
IDE09402-MAS06441,History data central locking: seventh-to-last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE09403-IDE00500,History data central locking: eighth-to-last event-Hour,19,
IDE09403-IDE00501,History data central locking: eighth-to-last event-Minute,50,
IDE09403-MAS00106,History data central locking: eighth-to-last event-Year,not known,
IDE09403-MAS00107,History data central locking: eighth-to-last event-Month,11,
IDE09403-MAS00108,History data central locking: eighth-to-last event-Day,9,
IDE09403-MAS00111,History data central locking: eighth-to-last event-Seconds,0,
IDE09403-MAS01551,History data central locking: eighth-to-last event-Key number,2,
IDE09403-MAS06441,History data central locking: eighth-to-last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE09404-IDE00500,History data central locking: ninth-to-last event-Hour,19,
IDE09404-IDE00501,History data central locking: ninth-to-last event-Minute,31,
IDE09404-MAS00106,History data central locking: ninth-to-last event-Year,not known,
IDE09404-MAS00107,History data central locking: ninth-to-last event-Month,11,
IDE09404-MAS00108,History data central locking: ninth-to-last event-Day,9,
IDE09404-MAS00111,History data central locking: ninth-to-last event-Seconds,0,
IDE09404-MAS01551,History data central locking: ninth-to-last event-Key number,2,
IDE09404-MAS06441,History data central locking: ninth-to-last event-Control-section / cause,no data present,
IDE09405-IDE00500,History data central locking: tenth-to-last event-Hour,19,
IDE09405-IDE00501,History data central locking: tenth-to-last event-Minute,29,
IDE09405-MAS00106,History data central locking: tenth-to-last event-Year,not known,
IDE09405-MAS00107,History data central locking: tenth-to-last event-Month,11,
IDE09405-MAS00108,History data central locking: tenth-to-last event-Day,9,
IDE09405-MAS00111,History data central locking: tenth-to-last event-Seconds,30,
IDE09405-MAS01551,History data central locking: tenth-to-last event-Key number,2,
IDE09405-MAS06441,History data central locking: tenth-to-last event-Control-section / cause,Driver interior locking button,
IDE09406-IDE00500,History data central locking: eleventh-to-last event-Hour,17,
IDE09406-IDE00501,History data central locking: eleventh-to-last event-Minute,27,
IDE09406-MAS00106,History data central locking: eleventh-to-last event-Year,not known,
IDE09406-MAS00107,History data central locking: eleventh-to-last event-Month,11,
IDE09406-MAS00108,History data central locking: eleventh-to-last event-Day,9,
IDE09406-MAS00111,History data central locking: eleventh-to-last event-Seconds,30,
IDE09406-MAS01551,History data central locking: eleventh-to-last event-Key number,2,
IDE09406-MAS06441,History data central locking: eleventh-to-last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE09407-IDE00500,History data central locking: twelfth-to-last event-Hour,17,
IDE09407-IDE00501,History data central locking: twelfth-to-last event-Minute,9,
IDE09407-MAS00106,History data central locking: twelfth-to-last event-Year,not known,
IDE09407-MAS00107,History data central locking: twelfth-to-last event-Month,11,
IDE09407-MAS00108,History data central locking: twelfth-to-last event-Day,9,
IDE09407-MAS00111,History data central locking: twelfth-to-last event-Seconds,30,
IDE09407-MAS01551,History data central locking: twelfth-to-last event-Key number,2,
IDE09407-MAS06441,History data central locking: twelfth-to-last event-Control-section / cause,Autolock,
IDE09408-IDE00500,History data central locking: thirteenth-to-last event-Hour,17,
IDE09408-IDE00501,History data central locking: thirteenth-to-last event-Minute,9,
IDE09408-MAS00106,History data central locking: thirteenth-to-last event-Year,not known,
IDE09408-MAS00107,History data central locking: thirteenth-to-last event-Month,11,
IDE09408-MAS00108,History data central locking: thirteenth-to-last event-Day,9,
IDE09408-MAS00111,History data central locking: thirteenth-to-last event-Seconds,30,
IDE09408-MAS01551,History data central locking: thirteenth-to-last event-Key number,2,
IDE09408-MAS06441,History data central locking: thirteenth-to-last event-Control-section / cause,no data present,
IDE09409-IDE00500,History data central locking: fourteenth-to-last event-Hour,17,
IDE09409-IDE00501,History data central locking: fourteenth-to-last event-Minute,4,
IDE09409-MAS00106,History data central locking: fourteenth-to-last event-Year,not known,
IDE09409-MAS00107,History data central locking: fourteenth-to-last event-Month,11,
IDE09409-MAS00108,History data central locking: fourteenth-to-last event-Day,9,
IDE09409-MAS00111,History data central locking: fourteenth-to-last event-Seconds,45,
IDE09409-MAS01551,History data central locking: fourteenth-to-last event-Key number,2,
IDE09409-MAS06441,History data central locking: fourteenth-to-last event-Control-section / cause,Autolock,
IDE09410-IDE00500,History data central locking: fifteenth-to-last event-Hour,17,
IDE09410-IDE00501,History data central locking: fifteenth-to-last event-Minute,4,
IDE09410-MAS00106,History data central locking: fifteenth-to-last event-Year,not known,
IDE09410-MAS00107,History data central locking: fifteenth-to-last event-Month,11,
IDE09410-MAS00108,History data central locking: fifteenth-to-last event-Day,9,
IDE09410-MAS00111,History data central locking: fifteenth-to-last event-Seconds,45,
IDE09410-MAS01551,History data central locking: fifteenth-to-last event-Key number,2,
IDE09410-MAS06441,History data central locking: fifteenth-to-last event-Control-section / cause,no data present,
IDE09411-IDE00500,History data central locking: sixteenth-to-last event-Hour,14,
IDE09411-IDE00501,History data central locking: sixteenth-to-last event-Minute,49,
IDE09411-MAS00106,History data central locking: sixteenth-to-last event-Year,not known,
IDE09411-MAS00107,History data central locking: sixteenth-to-last event-Month,11,
IDE09411-MAS00108,History data central locking: sixteenth-to-last event-Day,9,
IDE09411-MAS00111,History data central locking: sixteenth-to-last event-Seconds,45,
IDE09411-MAS01551,History data central locking: sixteenth-to-last event-Key number,2,
IDE09411-MAS06441,History data central locking: sixteenth-to-last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE09412-IDE00500,History data central locking: seventeenth-to-last event-Hour,14,
IDE09412-IDE00501,History data central locking: seventeenth-to-last event-Minute,37,
IDE09412-MAS00106,History data central locking: seventeenth-to-last event-Year,not known,
IDE09412-MAS00107,History data central locking: seventeenth-to-last event-Month,11,
IDE09412-MAS00108,History data central locking: seventeenth-to-last event-Day,9,
IDE09412-MAS00111,History data central locking: seventeenth-to-last event-Seconds,30,
IDE09412-MAS01551,History data central locking: seventeenth-to-last event-Key number,2,
IDE09412-MAS06441,History data central locking: seventeenth-to-last event-Control-section / cause,Remote control,
IDE09413-IDE00500,History data central locking: eighteenth-to-last event-Hour,12,
IDE09413-IDE00501,History data central locking: eighteenth-to-last event-Minute,42,
IDE09413-MAS00106,History data central locking: eighteenth-to-last event-Year,not known,
IDE09413-MAS00107,History data central locking: eighteenth-to-last event-Month,11,
IDE09413-MAS00108,History data central locking: eighteenth-to-last event-Day,9,
IDE09413-MAS00111,History data central locking: eighteenth-to-last event-Seconds,0,
IDE09413-MAS01551,History data central locking: eighteenth-to-last event-Key number,2,
IDE09413-MAS06441,History data central locking: eighteenth-to-last event-Control-section / cause,Autolock,
IDE09414-IDE00500,History data central locking: nineteenth-to-last event-Hour,12,
IDE09414-IDE00501,History data central locking: nineteenth-to-last event-Minute,41,
IDE09414-MAS00106,History data central locking: nineteenth-to-last event-Year,not known,
IDE09414-MAS00107,History data central locking: nineteenth-to-last event-Month,11,
IDE09414-MAS00108,History data central locking: nineteenth-to-last event-Day,9,
IDE09414-MAS00111,History data central locking: nineteenth-to-last event-Seconds,30,
IDE09414-MAS01551,History data central locking: nineteenth-to-last event-Key number,2,
IDE09414-MAS06441,History data central locking: nineteenth-to-last event-Control-section / cause,no data present,
IDE09415-IDE00500,History data central locking: twentieth-to-last event-Hour,12,
IDE09415-IDE00501,History data central locking: twentieth-to-last event-Minute,11,
IDE09415-MAS00106,History data central locking: twentieth-to-last event-Year,not known,
IDE09415-MAS00107,History data central locking: twentieth-to-last event-Month,11,
IDE09415-MAS00108,History data central locking: twentieth-to-last event-Day,9,
IDE09415-MAS00111,History data central locking: twentieth-to-last event-Seconds,15,
IDE09415-MAS01551,History data central locking: twentieth-to-last event-Key number,2,
IDE09415-MAS06441,History data central locking: twentieth-to-last event-Control-section / cause,no data present,
IDE09416,Control line for dynamic turn signal,not active,
IDE09840-MAS09380,CU for tailgate opener: counter readings-proximity detected,00 30,
IDE09840-MAS09381,CU for tailgate opener: counter readings-Foot gestic detected,00 30,
IDE09840-MAS09382,CU for tailgate opener: counter readings-De-activation,1E 59,
IDE09840-MAS09383,CU for tailgate opener: counter readings-Play protection activation,00 00,
IDE09841-MAS09384,CU for tailgate opener: sensor status-Proximity detected: sensor 1,No,
IDE09841-MAS09385,CU for tailgate opener: sensor status-Proximity detected: sensor 2,No,
IDE09841-MAS09386,CU for tailgate opener: sensor status-Sensor module connected,No,
IDE09917-MAS03692,Last change code counter status-Key 1,00 00 09 C1,
IDE09917-MAS03693,Last change code counter status-Key 2,00 02 9A 55,
IDE09917-MAS03694,Last change code counter status-Key 3,Not adapted,
IDE09917-MAS03695,Last change code counter status-Key 4,Not adapted,
IDE09917-MAS03696,Last change code counter status-Key 5,Not adapted,
IDE09917-MAS03697,Last change code counter status-Key 6,Not adapted,
IDE09917-MAS03698,Last change code counter status-Key 7,Not adapted,
IDE09917-MAS03699,Last change code counter status-Key 8,Not adapted,
IDE10096-MAS01551,Radio remote control: last radio shot-Key number,2,
IDE10096-MAS06879,Radio remote control: last radio shot-Checksum,OK,
IDE10096-MAS08411,Radio remote control: last radio shot-Button for vehicle locking,operated,
IDE10096-MAS08412,Radio remote control: last radio shot-Button for vehicle unlocking,Not operated,
IDE10096-MAS08413,Radio remote control: last radio shot-Button for luggage compartment unlocking,Not operated,
IDE10096-MAS08414,Radio remote control: last radio shot-Panic button,Not operated,
IDE10096-MAS08415,Radio remote control: last radio shot-Battery condition,used,
IDE10096-MAS08419,Radio remote control: last radio shot-Key condition,OK,
IDE10096-MAS08421,Radio remote control: last radio shot-Transponder ID: Byte 1,F9,
IDE10096-MAS08422,Radio remote control: last radio shot-Cryptography,OK,
IDE10096-MAS08423,Radio remote control: last radio shot-Rolling code information,Detection area 1,
IDE10096-MAS08427,Radio remote control: last radio shot-Time since last radio shot,255, s
IDE10096-MAS13216,Radio remote control: last radio shot-Front windshield remote unlocking button,Not operated,
IDE10096-MAS13230,Radio remote control: last radio shot-Freely assignable button,Not operated,
IDE10097-IDE01442,Comfort closing convert. top/rear lid-Pressing a button,no key actuated,
IDE10097-MAS06528,Comfort closing convert. top/rear lid-Release status,not enabled,
IDE10097-MAS08432,Comfort closing convert. top/rear lid-Requirement,No,
IDE10097-MAS09907,Comfort closing convert. top/rear lid-Key search,not active,
IDE10097-MAS09908,Comfort closing convert. top/rear lid-Key within reach,No,
IDE10097-MAS09909,Comfort closing convert. top/rear lid-Number of key searches,0,
IDE10097-MAS09910,Comfort closing convert. top/rear lid-Number of key responses,0,
IDE10098-MAS09911,Zone and area information key 1 - 4-Key 1: Zone information,Not Present,
IDE10098-MAS09912,Zone and area information key 1 - 4-Key 1: Area information,Not Present,
IDE10098-MAS09913,Zone and area information key 1 - 4-Key 2: Zone information,Not Present,
IDE10098-MAS09914,Zone and area information key 1 - 4-Key 2: Area information,Not Present,
IDE10098-MAS09915,Zone and area information key 1 - 4-Key 3: Zone information,Not adapted,
IDE10098-MAS09916,Zone and area information key 1 - 4-Key 3: Area information,Not adapted,
IDE10098-MAS09917,Zone and area information key 1 - 4-Key 4: Zone information,Not adapted,
IDE10098-MAS09918,Zone and area information key 1 - 4-Key 4: Area information,Not adapted,
IDE10099-MAS09919,Zone and area information key 5 - 8-Key 5: Zone information,Not adapted,
IDE10099-MAS09920,Zone and area information key 5 - 8-Key 5: Area information,Not adapted,
IDE10099-MAS09921,Zone and area information key 5 - 8-Key 6: Zone information,Not adapted,
IDE10099-MAS09922,Zone and area information key 5 - 8-Key 6: Area information,Not adapted,
IDE10099-MAS09923,Zone and area information key 5 - 8-Key 7: Zone information,Not adapted,
IDE10099-MAS09924,Zone and area information key 5 - 8-Key 7: Area information,Not adapted,
IDE10099-MAS09925,Zone and area information key 5 - 8-Key 8: Zone information,Not adapted,
IDE10099-MAS09926,Zone and area information key 5 - 8-Key 8: Area information,Not adapted,
IDE10100-MAS09931,Individual activation of antennae for access and start system-Access/start system antenna 1 in vehicle interior,112,
IDE10100-MAS09932,Individual activation of antennae for access and start system-Access/start system antenna in luggage compartment,96,
IDE10100-MAS09933,Individual activation of antennae for access and start system-Left Access/Start Authorization Antenna,136,
IDE10100-MAS09934,Individual activation of antennae for access and start system-Right Access/Start Authorization Antenna,not coded/not installed,
IDE10100-MAS09935,Individual activation of antennae for access and start system-Access/start system antenna 2 in vehicle interior,not coded/not installed,
IDE10159-MAS09936,Outside door handle sens.: frt. left-Unlocking sensor: proximity detected,No,
IDE10159-MAS09937,Outside door handle sens.: frt. left-Locking sensor: proximity detected,No,
IDE10159-MAS09938,Outside door handle sens.: frt. left-Unlocking sensor: activation detected,No,
IDE10159-MAS09939,Outside door handle sens.: frt. left-Locking sensor: activation detected,No,
IDE10159-MAS09951,Outside door handle sens.: frt. left-Receiving wakeup signal,not coded/not installed,
IDE10160-MAS09936,Outside door handle sens.: frt. right-Unlocking sensor: proximity detected,No,
IDE10160-MAS09937,Outside door handle sens.: frt. right-Locking sensor: proximity detected,No,
IDE10160-MAS09938,Outside door handle sens.: frt. right-Unlocking sensor: activation detected,No,
IDE10160-MAS09939,Outside door handle sens.: frt. right-Locking sensor: activation detected,No,
IDE10160-MAS09951,Outside door handle sens.: frt. right-Receiving wakeup signal,not coded/not installed,
IDE10161-MAS09936,Outside door handle sens.: left rear-Unlocking sensor: proximity detected,No,
IDE10161-MAS09937,Outside door handle sens.: left rear-Locking sensor: proximity detected,No,
IDE10161-MAS09938,Outside door handle sens.: left rear-Unlocking sensor: activation detected,No,
IDE10161-MAS09939,Outside door handle sens.: left rear-Locking sensor: activation detected,No,
IDE10161-MAS09951,Outside door handle sens.: left rear-Receiving wakeup signal,not coded/not installed,
IDE10162-MAS09936,Outside door handle sens.: right rear-Unlocking sensor: proximity detected,No,
IDE10162-MAS09937,Outside door handle sens.: right rear-Locking sensor: proximity detected,No,
IDE10162-MAS09938,Outside door handle sens.: right rear-Unlocking sensor: activation detected,No,
IDE10162-MAS09939,Outside door handle sens.: right rear-Locking sensor: activation detected,No,
IDE10162-MAS09951,Outside door handle sens.: right rear-Receiving wakeup signal,not coded/not installed,
IDE10190-MAS02040,Left front outside door handle sens.: status-Play protection,not active,
IDE10190-MAS06517,Left front outside door handle sens.: status-Rear spoiler counter,0,
IDE10190-MAS08440,Left front outside door handle sens.: status-Activity,active,
IDE10191-MAS02040,Right front outside door handle sens.: status-Play protection,not active,
IDE10191-MAS06517,Right front outside door handle sens.: status-Rear spoiler counter,0,
IDE10191-MAS08440,Right front outside door handle sens.: status-Activity,active,
IDE10192-MAS02040,Left rear outside door handle sens.: status-Play protection,not active,
IDE10192-MAS06517,Left rear outside door handle sens.: status-Rear spoiler counter,0,
IDE10192-MAS08440,Left rear outside door handle sens.: status-Activity,active,
IDE10193-MAS02040,Right rear outside door handle sens.: status-Play protection,not active,
IDE10193-MAS06517,Right rear outside door handle sens.: status-Rear spoiler counter,0,
IDE10193-MAS08440,Right rear outside door handle sens.: status-Activity,active,
IDE10262-MAS08462,Key search in vehicle interior (scan)-Authenticated key in search area,00000000 ,
IDE10262-MAS08463,Key search in vehicle interior (scan)-Authenticated key,00000000 ,
IDE10262-MAS08464,Key search in vehicle interior (scan)-Recognized key,00000000 ,
IDE10263-MAS03692,Transponder IDs found during last key search-Key 1,FF FF FF FF,
IDE10263-MAS03693,Transponder IDs found during last key search-Key 2,FF FF FF FF,
IDE10263-MAS03694,Transponder IDs found during last key search-Key 3,FF FF FF FF,
IDE10263-MAS03695,Transponder IDs found during last key search-Key 4,FF FF FF FF,
IDE10263-MAS03696,Transponder IDs found during last key search-Key 5,FF FF FF FF,
IDE10263-MAS03697,Transponder IDs found during last key search-Key 6,FF FF FF FF,
IDE10263-MAS03698,Transponder IDs found during last key search-Key 7,FF FF FF FF,
IDE10263-MAS03699,Transponder IDs found during last key search-Key 8,FF FF FF FF,
IDE10263-MAS10077,Transponder IDs found during last key search-Number of repeated searches,00,
IDE10263-MAS10078,Transponder IDs found during last key search-Number of keys found,00,
IDE10284-MAS03692,Number of "Key battery dead" recognitions-Key 1,0,
IDE10284-MAS03693,Number of "Key battery dead" recognitions-Key 2,0,
IDE10284-MAS03694,Number of "Key battery dead" recognitions-Key 3,Not adapted,
IDE10284-MAS03695,Number of "Key battery dead" recognitions-Key 4,Not adapted,
IDE10284-MAS03696,Number of "Key battery dead" recognitions-Key 5,Not adapted,
IDE10284-MAS03697,Number of "Key battery dead" recognitions-Key 6,Not adapted,
IDE10284-MAS03698,Number of "Key battery dead" recognitions-Key 7,Not adapted,
IDE10284-MAS03699,Number of "Key battery dead" recognitions-Key 8,Not adapted,
IDE10285-MAS02447,Release of rear lid exterior button-Release,Enabled,
IDE10306-MAS10178,Rear window heater test: measures voltage differences-Pulse 1,0.000, V
IDE10306-MAS10179,Rear window heater test: measures voltage differences-Pulse 2,0.000, V
IDE10306-MAS10180,Rear window heater test: measures voltage differences-Pulse 3,0.000, V
IDE10306-MAS10181,Rear window heater test: measures voltage differences-Pulse 4,0.000, V
IDE10306-MAS10182,Rear window heater test: measures voltage differences-Pulse 5,0.000, V
IDE10306-MAS10183,Rear window heater test: measures voltage differences-Pulse 6,0.000, V
IDE10306-MAS10184,Rear window heater test: measures voltage differences-Pulse 7,0.000, V
IDE10306-MAS10185,Rear window heater test: measures voltage differences-Pulse 8,0.000, V
IDE10306-MAS10186,Rear window heater test: measures voltage differences-Pulse 9,0.000, V
IDE10306-MAS10187,Rear window heater test: measures voltage differences-Pulse 10,0.000, V
IDE10306-MAS10188,Rear window heater test: measures voltage differences-Pulse 11,0.000, V
IDE10306-MAS10189,Rear window heater test: measures voltage differences-Pulse 12,0.000, V
IDE10306-MAS10190,Rear window heater test: measures voltage differences-Pulse 13,0.000, V
IDE10306-MAS10191,Rear window heater test: measures voltage differences-Pulse 14,0.000, V
IDE10306-MAS10192,Rear window heater test: measures voltage differences-Pulse 15,0.000, V
IDE10306-MAS10193,Rear window heater test: measures voltage differences-Mean value,0.000, V
IDE10348,Trip distance data,31 00 00 00 00 00 00 00 00 00 46 14 00 00 01 57 41 55 45 4E 41 46 34 37 4A 41 31 34 37 38 39 38 FC B4 E0 24 AB 10 C9 41 00 C0 00 01 00 F2 7E 00 00 4E D3 3B 32 37 6F 00 00 4E D4 CE 49 EF 7E 00 00 4E D3 3B 2F 31 6F 00 00 4E D3 3C 5C 90 7E 00 D8 FB AD A7 E6 00 00 4E D2 DB BB 43 01 8E 7B 00 DE 7B 00 00 4E C4 D4 6F 02 8B 7B 00 DB 7B 00 00 4E C4 D4 67 01 A8 76 00 E1 77 00 00 4E 9C DE 24 02 A6 76 00 DE 77 00 00 4E 9C DE 1A 01 05 71 00 65 71 00 00 4E 85 50 E5 02 03 71 00 62 71 00 00 4E 85 50 D7 02 11 6E 00 61 6E 00 00 4E 78 FB 87 01 14 6E 00 64 6E 00 00 4E 78 FB 87 02 03 6A 00 31 6A 00 00 4E 64 AA 60 01 06 6A 00 33 6A 00 00 4E 64 AA 57 B5 06 3D 05 B4 3D 00 4C C3 63 09 B5 C7 2A 05 94 3D 00 4C C3 67 9D,
IDE10681,Blocked keys,00,
IDE10682-MAS00106,Historical data blocked keys-Year,2018,
IDE10682-MAS00107,Historical data blocked keys-Month,11,
IDE10682-MAS00108,Historical data blocked keys-Day,8,
IDE10682-MAS00109,Historical data blocked keys-Hours,22,
IDE10682-MAS00110,Historical data blocked keys-Minutes,28,
IDE10682-MAS00111,Historical data blocked keys-Seconds,50,
IDE10682-MAS01551,Historical data blocked keys-Key number,2,
IDE10682-MAS11095,Historical data blocked keys-cause:,0,
IDE10683-IDE00500,Historical data unsuccessful automatic cut-off terminal 15-Hour,6,
IDE10683-IDE00501,Historical data unsuccessful automatic cut-off terminal 15-Minute,54,
IDE10683-MAS00107,Historical data unsuccessful automatic cut-off terminal 15-Month,9,
IDE10683-MAS00108,Historical data unsuccessful automatic cut-off terminal 15-Day,16,
IDE10683-MAS08075,Historical data unsuccessful automatic cut-off terminal 15-Reason for shut-off attempt,Timeout,
IDE10683-MAS08080,Historical data unsuccessful automatic cut-off terminal 15-Failure reason,255,
IDE10683-MAS08081,Historical data unsuccessful automatic cut-off terminal 15-Reason for timer stop,01101111 ,
IDE10684-IDE00500,Historical data unsuccessful switch-on attempt term 15-Hour,22,
IDE10684-IDE00501,Historical data unsuccessful switch-on attempt term 15-Minute,43,
IDE10684-MAS00107,Historical data unsuccessful switch-on attempt term 15-Month,11,
IDE10684-MAS00108,Historical data unsuccessful switch-on attempt term 15-Day,6,
IDE10684-MAS08080,Historical data unsuccessful switch-on attempt term 15-Failure reason,0,
IDE10685-IDE00500,Historical data automatic cut-off terminal 15-Hour,22,
IDE10685-IDE00501,Historical data automatic cut-off terminal 15-Minute,52,
IDE10685-IDE04105,Historical data automatic cut-off terminal 15-Environmental conditions,00000000 00000000 ,
IDE10685-MAS00107,Historical data automatic cut-off terminal 15-Month,11,
IDE10685-MAS00108,Historical data automatic cut-off terminal 15-Day,8,
IDE10685-MAS08082,Historical data automatic cut-off terminal 15-Reason for shut-off,Exiting the vehicle,
IDE10685-MAS08087,Historical data automatic cut-off terminal 15-Shut-off due to locking of vehicle: control section,Remote control,
IDE10685-MAS08091,Historical data automatic cut-off terminal 15-State before shut-off,00001111 ,
IDE10686-IDE00500,Historical data switch-on source terminal 15-Hour,19,
IDE10686-IDE00501,Historical data switch-on source terminal 15-Minute,50,
IDE10686-MAS00107,Historical data switch-on source terminal 15-Month,11,
IDE10686-MAS00108,Historical data switch-on source terminal 15-Day,10,
IDE10686-MAS11095,Historical data switch-on source terminal 15-cause:,Actuation of button for access and start authorization,
IDE10696-IDE00500,Histor.data switch-off terminal 15 by means of actuat. button-Hour,18,
IDE10696-IDE00501,Histor.data switch-off terminal 15 by means of actuat. button-Minute,32,
IDE10696-IDE04105,Histor.data switch-off terminal 15 by means of actuat. button-Environmental conditions,00000000 00000000 ,
IDE10696-MAS00107,Histor.data switch-off terminal 15 by means of actuat. button-Month,11,
IDE10696-MAS00108,Histor.data switch-off terminal 15 by means of actuat. button-Day,10,
IDE10696-MAS08082,Histor.data switch-off terminal 15 by means of actuat. button-Reason for shut-off,Normal shut-off,
IDE10696-MAS08091,Histor.data switch-off terminal 15 by means of actuat. button-State before shut-off,01001111 ,
IDE10750,Anti-theft warn. interior monitoring: version of parameter set,20 C2,
IDE11484,Rear spoiler: position,not coded/not installed,
IDE11487-MAS12819,Trunk emergency release-Button for trunk emergency unlocking system,not coded/not installed,
IDE11487-MAS12820,Trunk emergency release-Luggage compartment emergency release button,not coded/not installed,
IDE11487-MAS12821,Trunk emergency release-Button for unlocking hood,not coded/not installed,
IDE11487-MAS12822,Trunk emergency release-Hood release motor,not coded/not installed,
IDE11487-MAS12823,Trunk emergency release-Enabling trunk emergency unlocking,not coded/not installed,
IDE11487-MAS12824,Trunk emergency release-Enabling trunk emerg. unlocking: reversed,Unknown (3),
IDE11487-MAS12825,Trunk emergency release-Error display in instrument panel cluster,not coded/not installed,
IDE11487-MAS17287,Trunk emergency release-Indicator lamp for luggage compartment emergency release,OFF,
IDE11778-MAS09936,Engine hood unlocking mechanism sensor-Unlocking sensor: proximity detected,not coded/not installed,
IDE11778-MAS09937,Engine hood unlocking mechanism sensor-Locking sensor: proximity detected,not coded/not installed,
IDE11778-MAS09938,Engine hood unlocking mechanism sensor-Unlocking sensor: activation detected,not coded/not installed,
IDE11778-MAS09939,Engine hood unlocking mechanism sensor-Locking sensor: activation detected,not coded/not installed,
IDE11778-MAS09951,Engine hood unlocking mechanism sensor-Receiving wakeup signal,not coded/not installed,
IDE11779-MAS02040,Engine hood unlocking mechanism sensor: status-Play protection,not coded/not installed,
IDE11779-MAS06517,Engine hood unlocking mechanism sensor: status-Rear spoiler counter,not coded/not installed,
IDE11779-MAS08440,Engine hood unlocking mechanism sensor: status-Activity,not coded/not installed,
IDE11780-MAS09936,Rear hood unlocking mechanism sensor-Unlocking sensor: proximity detected,not coded/not installed,
IDE11780-MAS09937,Rear hood unlocking mechanism sensor-Locking sensor: proximity detected,not coded/not installed,
IDE11780-MAS09938,Rear hood unlocking mechanism sensor-Unlocking sensor: activation detected,not coded/not installed,
IDE11780-MAS09939,Rear hood unlocking mechanism sensor-Locking sensor: activation detected,not coded/not installed,
IDE11780-MAS09951,Rear hood unlocking mechanism sensor-Receiving wakeup signal,not coded/not installed,
IDE11781-MAS02040,Rear hood unlocking mechanism sensor: status-Play protection,not coded/not installed,
IDE11781-MAS06517,Rear hood unlocking mechanism sensor: status-Rear spoiler counter,not coded/not installed,
IDE11781-MAS08440,Rear hood unlocking mechanism sensor: status-Activity,not coded/not installed,
IDE11917-MAS08462,Searching for key outside of vehicle-Authenticated key in search area,00000000 ,
IDE11917-MAS08463,Searching for key outside of vehicle-Authenticated key,00000000 ,
IDE11917-MAS08464,Searching for key outside of vehicle-Recognized key,00000000 ,
IDE11938-IDE02021,Piloted parking and vehicle stopping function-Comfort closing,not coded/not installed,
IDE11938-MAS00829,Piloted parking and vehicle stopping function-Access and start authorization,no request,
IDE11938-MAS02362,Piloted parking and vehicle stopping function-Flashing: right,not coded/not installed,
IDE11938-MAS02363,Piloted parking and vehicle stopping function-Flashing: left,not coded/not installed,
IDE11938-MAS02444,Piloted parking and vehicle stopping function-Central locking,not coded/not installed,
IDE11938-MAS09388,Piloted parking and vehicle stopping function-Engine running,no request,
IDE11938-MAS09907,Piloted parking and vehicle stopping function-Key search,no request,
IDE11938-MAS13254,Piloted parking and vehicle stopping function-Active parking function,not coded/not installed,
IDE11938-MAS13454,Piloted parking and vehicle stopping function-Comfort closing: convertible top,not coded/not installed,
IDE11938-MAS13462,Piloted parking and vehicle stopping function-Hazard lights of emergency assistant,not coded/not installed,
IDE11938-MAS13469,Piloted parking and vehicle stopping function-Vehicle stopping function,not coded/not installed,
IDE11938-MAS14248,Piloted parking and vehicle stopping function-Unlocking by vehicle halt function,not coded/not installed,
IDE11938-MAS14250,Piloted parking and vehicle stopping function-Radio key LED,no request,
IDE11938-MAS14251,Piloted parking and vehicle stopping function-Driver information,no request,
IDE11938-MAS14253,Piloted parking and vehicle stopping function-Confirmation flashing,not coded/not installed,
IDE11980-MAS01156,Windshield defroster relay-Communication status,not coded/not installed,
IDE11980-MAS01478,Windshield defroster relay-Insuff. voltage,not coded/not installed,
IDE11980-MAS01479,Windshield defroster relay-Excess voltage,not coded/not installed,
IDE11980-MAS01580,Windshield defroster relay-Activation,not coded/not installed,
IDE11980-MAS08432,Windshield defroster relay-Requirement,not coded/not installed,
IDE11980-MAS13674,Windshield defroster relay-Windshield defogger button,not coded/not installed,
IDE11980-MAS13675,Windshield defroster relay-Windshield defogger indicator lamp,not coded/not installed,
IDE11980-MAS13676,Windshield defroster relay-Power quota,not coded/not installed,
IDE11980-MAS13720,Windshield defroster relay-Error qualification,not coded/not installed,
IDE11980-MAS13724,Windshield defroster relay-Status of self-monitoring,not coded/not installed,
IDE11984-MAS10178,Result of checking relay for heated windshield-Pulse 1,0.000, V
IDE11984-MAS10179,Result of checking relay for heated windshield-Pulse 2,0.000, V
IDE11984-MAS10180,Result of checking relay for heated windshield-Pulse 3,0.000, V
IDE11984-MAS10181,Result of checking relay for heated windshield-Pulse 4,0.000, V
IDE11984-MAS10182,Result of checking relay for heated windshield-Pulse 5,0.000, V
IDE11984-MAS10183,Result of checking relay for heated windshield-Pulse 6,0.000, V
IDE11984-MAS10184,Result of checking relay for heated windshield-Pulse 7,0.000, V
IDE11984-MAS10185,Result of checking relay for heated windshield-Pulse 8,0.000, V
IDE11984-MAS10186,Result of checking relay for heated windshield-Pulse 9,0.000, V
IDE11984-MAS10187,Result of checking relay for heated windshield-Pulse 10,0.000, V
IDE11984-MAS10188,Result of checking relay for heated windshield-Pulse 11,0.000, V
IDE11984-MAS10189,Result of checking relay for heated windshield-Pulse 12,0.000, V
IDE11984-MAS10190,Result of checking relay for heated windshield-Pulse 13,0.000, V
IDE11984-MAS10191,Result of checking relay for heated windshield-Pulse 14,0.000, V
IDE11984-MAS10192,Result of checking relay for heated windshield-Pulse 15,0.000, V
IDE11984-MAS10193,Result of checking relay for heated windshield-Mean value,0.000, V
IDE11996-MAS13729,Sunshade 2-Button for rear sunshade in operat. and numb. for A/C sys:rear,not coded/not installed,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,Yes,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,00,
IDE12263,Virtual radio key: vehicle ID,88 B7 85 49 29 0D D5 AF 31 8A 3E 60 3E 79 C6 D9,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,A9 C7 24 1D,
IDE12304-IDE00500,Separation monitoring radio key to rear lid: history-Hour,not known,
IDE12304-IDE00501,Separation monitoring radio key to rear lid: history-Minute,not known,
IDE12304-MAS00111,Separation monitoring radio key to rear lid: history-Seconds,not known,
IDE12304-MAS14238,Separation monitoring radio key to rear lid: history-Key found in Zone 1,00001111 ,
IDE12304-MAS14239,Separation monitoring radio key to rear lid: history-Key found in Zone 2,00001111 ,
IDE12304-MAS14240,Separation monitoring radio key to rear lid: history-Key found in Zone 3,00001111 ,
IDE12304-MAS14241,Separation monitoring radio key to rear lid: history-Key found in Zone 4,00001111 ,
IDE12304-MAS15180,Separation monitoring radio key to rear lid: history-Part function carried out,00001111 ,
IDE12304-MAS15181,Separation monitoring radio key to rear lid: history-Cause of cancellation,00001111 ,
IDE12466-IDE00500,Unlocking central locking system history data-Hour,not known,
IDE12466-IDE00501,Unlocking central locking system history data-Minute,not known,
IDE12466-MAS00106,Unlocking central locking system history data-Year,not known,
IDE12466-MAS00107,Unlocking central locking system history data-Month,not known,
IDE12466-MAS00108,Unlocking central locking system history data-Day,not known,
IDE12466-MAS00111,Unlocking central locking system history data-Seconds,not known,
IDE12466-MAS01551,Unlocking central locking system history data-Key number,2,
IDE12466-MAS06441,Unlocking central locking system history data-Control-section / cause,Outside door handle sens.: frt. left,
IDE12549-IDE00500,History data NFC authentication-Hour,not known,
IDE12549-IDE00501,History data NFC authentication-Minute,not known,
IDE12549-MAS00106,History data NFC authentication-Year,not known,
IDE12549-MAS00107,History data NFC authentication-Month,not known,
IDE12549-MAS00108,History data NFC authentication-Day,not known,
IDE12549-MAS00111,History data NFC authentication-Seconds,not known,
IDE12549-MAS14763,History data NFC authentication-Authentication type,FF,
IDE12549-MAS14764,History data NFC authentication-Authentication event,FF,
IDE12549-MAS14765,History data NFC authentication-Key number of NFC device,255,
IDE12549-MAS14766,History data NFC authentication-Authentication location,15,
IDE12834-MAS07359,Relay for preconditioning-via discreet wire,not coded/not installed,
IDE12834-MAS07360,Relay for preconditioning-via data bus,not coded/not installed,
IDE12834-MAS15268,Relay for preconditioning-Requirement from Climatronic control module,not coded/not installed,
IDE13345-MAS16268,Current Secure Element-Secure Element,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13345-MAS16269,Current Secure Element-Secure Element is contained in ticket table,No,
IDE13345-MAS16270,Current Secure Element-Secure element is authenticated,No,
IDE13403-IDE08980,Rear spoiler control module: input signals-Button for rear spoiler adjustment,not coded/not installed,
IDE13403-IDE13404,Rear spoiler control module: input signals-Locking by keyless access authorization: driver door,not coded/not installed,
IDE13403-MAS00370,Rear spoiler control module: input signals-Vehicle speed,not coded/not installed,
IDE13403-MAS01443,Rear spoiler control module: input signals-Request by Engine Control Module,not coded/not installed,
IDE13403-MAS01468,Rear spoiler control module: input signals-Terminal 15,not coded/not installed,
IDE13403-MAS06253,Rear spoiler control module: input signals-Static current measuring mode,not coded/not installed,
IDE13403-MAS06429,Rear spoiler control module: input signals-Transport protection,not coded/not installed,
IDE13403-MAS16413,Rear spoiler control module: input signals-Unlock driver lock cylinder contact switch,not coded/not installed,
IDE13403-MAS16414,Rear spoiler control module: input signals-Lock driver lock cylinder contact switch,not coded/not installed,
IDE13405-IDE08980,Rear spoiler control module: output signals-Button for rear spoiler adjustment,not coded/not installed,
IDE13405-MAS01478,Rear spoiler control module: output signals-Insuff. voltage,not coded/not installed,
IDE13405-MAS01479,Rear spoiler control module: output signals-Excess voltage,not coded/not installed,
IDE13405-MAS02040,Rear spoiler control module: output signals-Play protection,not coded/not installed,
IDE13405-MAS02590,Rear spoiler control module: output signals-Red warning light,not coded/not installed,
IDE13405-MAS02591,Rear spoiler control module: output signals-Yellow warning light,not coded/not installed,
IDE13405-MAS04737,Rear spoiler control module: output signals-Indicator lamp,not coded/not installed,
IDE13405-MAS16466,Rear spoiler control module: output signals-Rear spoiler positioning button: status,not coded/not installed,
IDE13405-MAS16467,Rear spoiler control module: output signals-Stop position retracted,not coded/not installed,
IDE13405-MAS16470,Rear spoiler control module: output signals-Stop position extended,not coded/not installed,
IDE13405-MAS16471,Rear spoiler control module: output signals-Rear spoiler positioning: status,not coded/not installed,
IDE13405-MAS16472,Rear spoiler control module: output signals-Rear spoiler positioning motor: status,not coded/not installed,
IDE13405-MAS16473,Rear spoiler control module: output signals-Rear spoiler: malfunction status,not coded/not installed,
IDE13405-MAS16474,Rear spoiler control module: output signals-Manual operation blocked,not coded/not installed,
IDE13405-MAS16475,Rear spoiler control module: output signals-BAP signals,not coded/not installed,
IDE80001-MAS01483,Analysis 1-Softwareversion,N1220023000000342407000000240021,
IDE80001-MAS06973,Analysis 1-Target hardware version BCM2,    N1220023000000342407000000240021,
IDE80001-MAS06974,Analysis 1-HF building block: hardware version,0023000000342407000000240021,
IDE80001-MAS06975,Analysis 1-HF building block: firmware version,000000342407000000240021,
IDE80001-MAS06976,Analysis 1-LF building block: hardware version,00342407000000240021,
IDE80001-MAS06977,Analysis 1-LF building block: firmware version,2407000000240021,
IDE80001-MAS06978,Analysis 1-LF building block: version configuration data,000000240021,
IDE80001-MAS06979,Analysis 1-Version CDD_LF,00240021,
IDE80001-MAS06980,Analysis 1-Version CDD_RF,0021,
MAS00077-MAS02345,Immobilizer-Current condition,Adapted,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,0E,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-MAS10132,Immobilizer-Configuration Kessy coded,Yes,
MAS00077-MAS10133,Immobilizer-Configuration E vehicle,No,
MAS00077-MAS10134,Immobilizer-Configuration SHE,Yes,
MAS00077-MAS14181,Immobilizer-Configuration of virtual radio key ready,Yes,
ENG98397-ENG13709,Airbag-seat_belt_lock_driver_side,2,
ENG98397-ENG46648,Airbag-seat_occupied_driver_side,0,
ENG12918,antenna_freeze_frame,01010000 00000000 00000001 01001010 ,
ENG12884-ENG13852,Breaking_light_operating_mode-Intern_operating_mode,Driving_mode,
ENG12884-ENG13853,Breaking_light_operating_mode-Transition_operating_mode,04,
ENG12916,can_lin_communication_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12857-MAS06439,central_locking_crash_status-Crash status,not active,
ENG12857-MAS06440,central_locking_crash_status-Precrash status,not active,
ENG12860-MAS00314,clutch_pedal_status-Clutch Pedal Switch,not coded/not installed,
ENG12860-MAS00363,clutch_pedal_status-Clutch pedal position,Unknown (65280),
ENG12860-MAS06475,clutch_pedal_status-Clutch Pedal Switch for Engine Start,not coded/not installed,
ENG12886-IDE01442,Comfort_close_convertible_top_and_trunk_lid-Pressing a button,no key actuated,
ENG12886-ENG13854,Comfort_close_convertible_top_and_trunk_lid-Key_search,No,
ENG12886-ENG13855,Comfort_close_convertible_top_and_trunk_lid-Key_within_reach,No,
ENG12886-ENG13857,Comfort_close_convertible_top_and_trunk_lid-Number_of_key_responses,0,
ENG12886-ENG13856,Comfort_close_convertible_top_and_trunk_lid-Number_of_key_searches,0,
ENG12905-ENG14003,communication_state_fbs-latest_job_number,50,
ENG12905-ENG14002,communication_state_fbs-latest_job_request_confirmation,00,
ENG12905-ENG14001,communication_state_fbs-latest_job_request_job_number,50,
ENG12905-ENG14004,communication_state_fbs-latest_job_result,01,
ENG12905-ENG14007,communication_state_fbs-latest_key_info_authentication,12,
ENG12905-ENG14005,communication_state_fbs-latest_key_info_job_number,19,
ENG12905-ENG14006,communication_state_fbs-latest_key_info_key_line,0B,
ENG12905-ENG14008,communication_state_fbs-latest_key_info_position,03,
ENG12847-MAS04188,cutoff_levels-Transport mode,not active,
ENG12847-MAS06253,cutoff_levels-Static current measuring mode,not active,
ENG12847-MAS06428,cutoff_levels-Static current shutdown level,Deactivation stage 0,
ENG12847-MAS06429,cutoff_levels-Transport protection,not active,
ENG12904-ENG13995,debug_fbs-debug_1,00000000 00000000 00000000 00000000 ,
ENG12904-ENG13996,debug_fbs-debug_2,00000000 00000000 00000000 00000000 ,
ENG12904-ENG13997,debug_fbs-debug_3,11111111 11111111 11110100 10010010 ,
ENG12904-ENG13998,debug_fbs-debug_4,11111111 11111111 11111001 00100111 ,
ENG12904-ENG13999,debug_fbs-debug_5,11111111 11111111 11111111 11111111 ,
ENG12904-ENG14000,debug_fbs-debug_6,00000000 00000000 00000000 00000000 ,
ENG12917,defect_fusi_voltage_error_freeze_frame,00000000 00000000 00001100 00000000 ,
ENG12903-ENG98504,diagnose_01_message-Day,10,
ENG12903-ENG98653,diagnose_01_message-Hour,20,
ENG12903-ENG98667,diagnose_01_message-Kilometers,32501,
ENG12903-ENG98739,diagnose_01_message-Minute,38,
ENG12903-ENG98748,diagnose_01_message-Month,11,
ENG12903-ENG102365,diagnose_01_message-Second,54,
ENG12903-ENG99063,diagnose_01_message-Year,2019,
ENG12881-MAS11095,Diagnosis_data_sbc-cause:,1,
ENG12861-ENG13706,elv_01-elv_clamp_enabling,not coded/not installed,
ENG12861-ENG13707,elv_01-elv_interruption_request_clamp_enabling,not coded/not installed,
ENG12861-ENG13704,elv_01-elv_locked,not coded/not installed,
ENG12861-ENG13705,elv_01-elv_unlocked,not coded/not installed,
ENG12843-MAS00371,Engine_status-Engine speed,798.00, /min
ENG12843-MAS04447,Engine_status-Engine running status,Engine running,
ENG12843-MAS06149,Engine_status-Terminal 75,active,
ENG12843-MAS06150,Engine_status-Terminal 50,not active,
ENG12843-MAS06712,Engine_status-Status drive readiness hybrid,Not ready,
ENG12843-ENG13701,Engine_status-restart_lock,active,
ENG12843-ENG13702,Engine_status-start_from_msg,2,
ENG12843-ENG13700,Engine_status-start_stop_driver_command,Stopp_prohibition,
ENG12843-ENG13699,Engine_status-start_stop_engine_stop,not active,
ENG12843-ENG114851,Engine_status-Start_Stop_Restart,not active,
ENG12843-ENG121476,Engine_status-Start_Stop_status,system_active_not_enabled_by_start_stop_coordinator,
ENG122522-ENG99298,EPB_01-State,1,
ENG12890-ENG13891,Error_counter_keyless-lf_antenna_error,254,
ENG12890-ENG13893,Error_counter_keyless-Retries,0,
ENG12890-ENG13892,Error_counter_keyless-unsuccessfully_entry_exit_activities,72,
ENG12888-ENG13882,Error_counter_lf_hf_communication-Checksum_error_hf,99,
ENG12888-ENG13884,Error_counter_lf_hf_communication-cryptology_error,1,
ENG12888-ENG13883,Error_counter_lf_hf_communication-Data_error_hf,254,
ENG12919,exterior_handle_sensor_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12882-ENG13849,External_light_defect_reasons-Break_light,00000000 ,
ENG12882-ENG13851,External_light_defect_reasons-Other_reasons,00000000 00000000 ,
ENG12882-ENG13659,External_light_defect_reasons-Tail_light,00000000 ,
ENG12882-ENG13850,External_light_defect_reasons-Turn_signal_light,00000000 00000000 ,
ENG12920,fuel_sender_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12911-ENG14036,general_additional_freeze_frame-Ambient_temperature_not_filtered,27.0, °C
ENG12911-ENG14040,general_additional_freeze_frame-coprocessor_spi_status,00000001 ,
ENG12911-ENG14039,general_additional_freeze_frame-dataflash_status,00000000 ,
ENG12911-ENG02610,general_additional_freeze_frame-interior_temperature,23.5, °C
ENG12911-ENG13636,general_additional_freeze_frame-Operating_Status,00000001 00000000 ,
ENG12911-ENG104256,general_additional_freeze_frame-production_mode,not active,
ENG12911-ENG14038,general_additional_freeze_frame-reset_cause,00000000 ,
ENG12911-ENG108452,general_additional_freeze_frame-Reset_counter,0,
ENG12911-ENG13694,general_additional_freeze_frame-Stall_current_cutoff_level,Deactivation stage 0,
ENG12911-ENG13635,general_additional_freeze_frame-Stall_Current_Measuring_Mode,not active,
ENG12911-ENG14037,general_additional_freeze_frame-subnetwork_status,00000000 00000000 ,
ENG12911-ENG14035,general_additional_freeze_frame-terminal_control_intern_status,1B 02 5A 90 02 E0,
ENG12911-ENG111086,general_additional_freeze_frame-Transport_Mode,not active,
ENG12911-ENG99010,general_additional_freeze_frame-Vehicle speed,0.00, km/h
ENG12859,hazard_warning_switch,Not operated,
ENG12858,hdsg_opening_acknowledge,not coded/not installed,
ENG12910-ENG127696,HF_LF_Counters-Counter_1,0,
ENG12910-ENG14012,HF_LF_Counters-Counter_10,0,
ENG12910-ENG14013,HF_LF_Counters-Counter_11,0,
ENG12910-ENG14014,HF_LF_Counters-Counter_12,0,
ENG12910-ENG14015,HF_LF_Counters-Counter_13,0,
ENG12910-ENG14016,HF_LF_Counters-Counter_14,0,
ENG12910-ENG14017,HF_LF_Counters-Counter_15,0,
ENG12910-ENG14018,HF_LF_Counters-Counter_16,0,
ENG12910-ENG14019,HF_LF_Counters-Counter_17,0,
ENG12910-ENG14020,HF_LF_Counters-Counter_18,0,
ENG12910-ENG14021,HF_LF_Counters-Counter_19,3,
ENG12910-ENG127697,HF_LF_Counters-Counter_2,0,
ENG12910-ENG14022,HF_LF_Counters-Counter_20,1,
ENG12910-ENG14023,HF_LF_Counters-Counter_21,10,
ENG12910-ENG14024,HF_LF_Counters-Counter_22,6,
ENG12910-ENG14025,HF_LF_Counters-Counter_23,0,
ENG12910-ENG14026,HF_LF_Counters-Counter_24,0,
ENG12910-ENG14027,HF_LF_Counters-Counter_25,0,
ENG12910-ENG14028,HF_LF_Counters-Counter_26,0,
ENG12910-ENG14029,HF_LF_Counters-Counter_27,0,
ENG12910-ENG14030,HF_LF_Counters-Counter_28,0,
ENG12910-ENG14031,HF_LF_Counters-Counter_29,0,
ENG12910-ENG127700,HF_LF_Counters-Counter_3,0,
ENG12910-ENG14032,HF_LF_Counters-Counter_30,0,
ENG12910-ENG14033,HF_LF_Counters-Counter_31,0,
ENG12910-ENG14034,HF_LF_Counters-Counter_32,1,
ENG12910-ENG127699,HF_LF_Counters-Counter_4,0,
ENG12910-ENG127698,HF_LF_Counters-Counter_5,0,
ENG12910-ENG127701,HF_LF_Counters-Counter_6,0,
ENG12910-ENG14009,HF_LF_Counters-Counter_7,3,
ENG12910-ENG14010,HF_LF_Counters-Counter_8,0,
ENG12910-ENG14011,HF_LF_Counters-Counter_9,0,
ENG12883-ENG98842,ignition_switch_pag-Position,not coded/not installed,
ENG12921,Immobilizer_freeze_frame_1,00000000 00000000 00000000 00000000 ,
ENG12930,Immobilizer_freeze_frame_10,00000000 00000000 00000000 00000000 ,
ENG12931,Immobilizer_freeze_frame_11,00000000 00000000 00000000 00000000 ,
ENG12932,Immobilizer_freeze_frame_12,00000000 00000000 00000000 00000000 ,
ENG12933,Immobilizer_freeze_frame_13,00000000 00000000 00000000 00000000 ,
ENG12934,Immobilizer_freeze_frame_14,00000000 00000000 00000000 00000000 ,
ENG13201,Immobilizer_freeze_frame_15,00000000 00000000 00000000 00000000 ,
ENG12922,Immobilizer_freeze_frame_2,00000000 00000000 00000000 00000000 ,
ENG12923,Immobilizer_freeze_frame_3,00000000 00000000 00000000 00000000 ,
ENG12924,Immobilizer_freeze_frame_4,00000000 00000000 00000000 00000000 ,
ENG12925,Immobilizer_freeze_frame_5,00000000 00000000 00000000 00000000 ,
ENG12926,Immobilizer_freeze_frame_6,00000000 00000000 00000000 00000000 ,
ENG12927,Immobilizer_freeze_frame_7,00000000 00000000 00000000 00000000 ,
ENG12928,Immobilizer_freeze_frame_8,00000000 00000000 00000000 00000000 ,
ENG12929,Immobilizer_freeze_frame_9,00000000 00000000 00000000 00000000 ,
ENG13196-ENG14609,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte1,not coded/not installed,
ENG13196-ENG14610,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte2,not coded/not installed,
ENG13196-ENG14611,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte3,not coded/not installed,
ENG13196-ENG14612,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte4,not coded/not installed,
ENG13196-ENG14613,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte5,not coded/not installed,
ENG13196-ENG14614,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte6,not coded/not installed,
ENG13196-ENG14615,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte7,not coded/not installed,
ENG13196-ENG14616,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte8,not coded/not installed,
ENG13196-ENG14617,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte1,not coded/not installed,
ENG13196-ENG14618,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte2,not coded/not installed,
ENG13196-ENG14619,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte3,not coded/not installed,
ENG13196-ENG14620,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte4,not coded/not installed,
ENG13196-ENG14621,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte5,not coded/not installed,
ENG13196-ENG14622,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte6,not coded/not installed,
ENG13196-ENG14623,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte7,not coded/not installed,
ENG13196-ENG14624,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte8,not coded/not installed,
ENG13196-ENG14625,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte1,not coded/not installed,
ENG13196-ENG14626,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte2,not coded/not installed,
ENG13196-ENG14627,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte3,not coded/not installed,
ENG13196-ENG14628,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte4,not coded/not installed,
ENG13196-ENG14629,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte5,not coded/not installed,
ENG13196-ENG14630,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte6,not coded/not installed,
ENG13196-ENG14631,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte7,not coded/not installed,
ENG13196-ENG14632,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte8,not coded/not installed,
ENG13196-ENG14633,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte1,not coded/not installed,
ENG13196-ENG14634,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte2,not coded/not installed,
ENG13196-ENG14635,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte3,not coded/not installed,
ENG13196-ENG14636,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte4,not coded/not installed,
ENG13196-ENG14637,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte5,not coded/not installed,
ENG13196-ENG14638,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte6,not coded/not installed,
ENG13196-ENG14639,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte7,not coded/not installed,
ENG13196-ENG14640,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte8,not coded/not installed,
ENG13196-ENG14641,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte1,not coded/not installed,
ENG13196-ENG14642,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte2,not coded/not installed,
ENG13196-ENG14643,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte3,not coded/not installed,
ENG13196-ENG14644,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte4,not coded/not installed,
ENG13196-ENG14645,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte5,not coded/not installed,
ENG13196-ENG14646,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte6,not coded/not installed,
ENG13196-ENG14647,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte7,not coded/not installed,
ENG13196-ENG14648,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte8,not coded/not installed,
ENG12889-ENG13886,Intern_conditions_advanced_key-Active_advanced_key_priority,254,
ENG12889-ENG13885,Intern_conditions_advanced_key-Aktive_activity,5C,
ENG12889-ENG13889,Intern_conditions_advanced_key-IDG_line_Luki,1,
ENG12889-ENG13890,Intern_conditions_advanced_key-IDG_line_VLuki,0,
ENG12889-ENG13887,Intern_conditions_advanced_key-Next_advanced_key_Activity,5C,
ENG12889-ENG13888,Intern_conditions_advanced_key-Next_advanced_key_priority,254,
ENG26920-ENG30365,IRUE_NGS_deactivation_via_mmi-ASG_Aktivation_State,0,
ENG26920-ENG31533,IRUE_NGS_deactivation_via_mmi-FSG_Aktivation_State,0,
ENG12912,key_error_freeze_frame,10011000 11111111 11111111 11111111 ,
ENG12909-MAS00106,Life_cycle_data_failed_keyless_search-Year,2019,
ENG12909-MAS00107,Life_cycle_data_failed_keyless_search-Month,11,
ENG12909-MAS00108,Life_cycle_data_failed_keyless_search-Day,10,
ENG12909-MAS00109,Life_cycle_data_failed_keyless_search-Hours,20,
ENG12909-MAS00110,Life_cycle_data_failed_keyless_search-Minutes,18,
ENG12909-MAS00111,Life_cycle_data_failed_keyless_search-Seconds,30,
ENG12909-ENG28817,Life_cycle_data_failed_keyless_search-Error_description,00000000 ,
ENG12909-ENG13626,Life_cycle_data_failed_keyless_search-Trigger,136,
ENG12907-MAS00106,Life_cycle_data_keyless_entry_exit_search-Year,2019,
ENG12907-MAS00107,Life_cycle_data_keyless_entry_exit_search-Month,11,
ENG12907-MAS00108,Life_cycle_data_keyless_entry_exit_search-Day,10,
ENG12907-MAS00109,Life_cycle_data_keyless_entry_exit_search-Hours,18,
ENG12907-MAS00110,Life_cycle_data_keyless_entry_exit_search-Minutes,33,
ENG12907-MAS00111,Life_cycle_data_keyless_entry_exit_search-Seconds,5,
ENG12907-ENG28815,Life_cycle_data_keyless_entry_exit_search-Operating_point,00001111 ,
ENG12907-ENG28814,Life_cycle_data_keyless_entry_exit_search-Search_result,00001001 ,
ENG12908-MAS00106,Life_cycle_data_keyless_event_search-Year,2019,
ENG12908-MAS00107,Life_cycle_data_keyless_event_search-Month,11,
ENG12908-MAS00108,Life_cycle_data_keyless_event_search-Day,10,
ENG12908-MAS00109,Life_cycle_data_keyless_event_search-Hours,20,
ENG12908-MAS00110,Life_cycle_data_keyless_event_search-Minutes,18,
ENG12908-MAS00111,Life_cycle_data_keyless_event_search-Seconds,30,
ENG12908-MAS00370,Life_cycle_data_keyless_event_search-Vehicle speed,0, km/h
ENG12908-ENG28816,Life_cycle_data_keyless_event_search-Search_cycle,10100000 ,
ENG12908-ENG28814,Life_cycle_data_keyless_event_search-Search_result,00000000 ,
ENG12908-ENG13626,Life_cycle_data_keyless_event_search-Trigger,9,
ENG12906-MAS00106,Life_cycle_data_keyless_go_search-Year,2019,
ENG12906-MAS00107,Life_cycle_data_keyless_go_search-Month,11,
ENG12906-MAS00108,Life_cycle_data_keyless_go_search-Day,10,
ENG12906-MAS00109,Life_cycle_data_keyless_go_search-Hours,19,
ENG12906-MAS00110,Life_cycle_data_keyless_go_search-Minutes,50,
ENG12906-MAS00111,Life_cycle_data_keyless_go_search-Seconds,4,
ENG12906-ENG28814,Life_cycle_data_keyless_go_search-Search_result,00001001 ,
ENG12906-ENG13626,Life_cycle_data_keyless_go_search-Trigger,00010000 ,
ENG12877-MAS00106,Life_cycle_data_reset_reasons_coprocessor-Year,2000,
ENG12877-MAS00107,Life_cycle_data_reset_reasons_coprocessor-Month,0,
ENG12877-MAS00108,Life_cycle_data_reset_reasons_coprocessor-Day,0,
ENG12877-MAS00109,Life_cycle_data_reset_reasons_coprocessor-Hours,0,
ENG12877-MAS00110,Life_cycle_data_reset_reasons_coprocessor-Minutes,0,
ENG12877-MAS00111,Life_cycle_data_reset_reasons_coprocessor-Seconds,0,
ENG12877-MAS11095,Life_cycle_data_reset_reasons_coprocessor-cause:,0,
ENG12879-MAS00106,Life_cycle_data_reset_reasons_main_processor-Year,2000,
ENG12879-MAS00107,Life_cycle_data_reset_reasons_main_processor-Month,0,
ENG12879-MAS00108,Life_cycle_data_reset_reasons_main_processor-Day,0,
ENG12879-MAS00109,Life_cycle_data_reset_reasons_main_processor-Hours,0,
ENG12879-MAS00110,Life_cycle_data_reset_reasons_main_processor-Minutes,0,
ENG12879-MAS00111,Life_cycle_data_reset_reasons_main_processor-Seconds,0,
ENG12879-MAS11095,Life_cycle_data_reset_reasons_main_processor-cause:,0,
ENG12914,light_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG117002-ENG13752,MFG-mfg_signals_CAN,not coded/not installed,
ENG12863-ENG13712,NVEM-request_kl15_deactivation,0,
ENG12874-ENG13836,Outputs_for_exterior_lighting-Output_1,Output not used,
ENG12874-ENG120566,Outputs_for_exterior_lighting-Output_10,active,
ENG12874-ENG120567,Outputs_for_exterior_lighting-Output_11,not active,
ENG12874-ENG120568,Outputs_for_exterior_lighting-Output_12,Output not used,
ENG12874-ENG120561,Outputs_for_exterior_lighting-Output_13,not active,
ENG12874-ENG120562,Outputs_for_exterior_lighting-Output_14,active,
ENG12874-ENG120563,Outputs_for_exterior_lighting-Output_15,not active,
ENG12874-ENG120564,Outputs_for_exterior_lighting-Output_16,Output not used,
ENG12874-ENG120557,Outputs_for_exterior_lighting-Output_17,not active,
ENG12874-ENG120558,Outputs_for_exterior_lighting-Output_18,Output not used,
ENG12874-ENG120559,Outputs_for_exterior_lighting-Output_19,Output not used,
ENG12874-ENG13837,Outputs_for_exterior_lighting-Output_2,not active,
ENG12874-ENG120560,Outputs_for_exterior_lighting-Output_20,Output not used,
ENG12874-ENG120553,Outputs_for_exterior_lighting-Output_21,Output not used,
ENG12874-ENG13838,Outputs_for_exterior_lighting-Output_3,active,
ENG12874-ENG13839,Outputs_for_exterior_lighting-Output_4,active,
ENG12874-ENG13840,Outputs_for_exterior_lighting-Output_5,not active,
ENG12874-ENG13841,Outputs_for_exterior_lighting-Output_6,not active,
ENG12874-ENG13842,Outputs_for_exterior_lighting-Output_7,active,
ENG12874-ENG13843,Outputs_for_exterior_lighting-Output_8,Output not used,
ENG12874-ENG13844,Outputs_for_exterior_lighting-Output_9,not active,
ENG12869-ENG13749,park_heating_and_air_conditioning-auxiliary_ventilation_CAN,not active,
ENG12869-ENG02610,park_heating_and_air_conditioning-interior_temperature,23.5, °C
ENG12869-ENG13748,park_heating_and_air_conditioning-park_heating_CAN,not active,
ENG12869-ENG13750,park_heating_and_air_conditioning-solar_fan_CAN,not active,
ENG126653-IDE00500,Personalized_Account_Key_History-Hour,22,
ENG126653-IDE00501,Personalized_Account_Key_History-Minute,31,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,11,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,8,
ENG126653-MAS00111,Personalized_Account_Key_History-Seconds,58,
ENG126653-ENG29120,Personalized_Account_Key_History-Account_number,0,
ENG126653-ENG29858,Personalized_Account_Key_History-Device_number,2,
ENG12943-MAS03692,Personalized_key_setting-Key 1,0,
ENG12943-MAS03693,Personalized_key_setting-Key 2,0,
ENG12943-MAS03694,Personalized_key_setting-Key 3,0,
ENG12943-MAS03695,Personalized_key_setting-Key 4,0,
ENG12943-MAS03696,Personalized_key_setting-Key 5,0,
ENG12943-MAS03697,Personalized_key_setting-Key 6,0,
ENG12943-MAS03698,Personalized_key_setting-Key 7,0,
ENG12943-MAS03699,Personalized_key_setting-Key 8,0,
ENG126654-IDE00500,Personalized_Signals-Hour,not known,
ENG126654-IDE00501,Personalized_Signals-Minute,not known,
ENG126654-MAS00107,Personalized_Signals-Month,not known,
ENG126654-MAS00108,Personalized_Signals-Day,not known,
ENG126654-MAS00111,Personalized_Signals-Seconds,not known,
ENG126654-ENG29120,Personalized_Signals-Account_number,0,
ENG126654-ENG98351,Personalized_Signals-active,not active,
ENG126654-ENG29121,Personalized_Signals-Contol_mode,0,
ENG126654-ENG29122,Personalized_Signals-Control_parameter,0,
ENG126654-ENG29124,Personalized_Signals-Enabling_adjustment,Initializing,
ENG126654-ENG29123,Personalized_Signals-Position_of_actuation,Initializing,
ENG126654-ENG99298,Personalized_Signals-State,not active,
ENG13195-ENG14593,Personalized_smart_device_setting-Smart_device_1,0,
ENG13195-ENG14602,Personalized_smart_device_setting-Smart_device_10,15,
ENG13195-ENG14603,Personalized_smart_device_setting-Smart_device_11,15,
ENG13195-ENG14604,Personalized_smart_device_setting-Smart_device_12,15,
ENG13195-ENG14605,Personalized_smart_device_setting-Smart_device_13,15,
ENG13195-ENG14606,Personalized_smart_device_setting-Smart_device_14,15,
ENG13195-ENG14607,Personalized_smart_device_setting-Smart_device_15,15,
ENG13195-ENG14608,Personalized_smart_device_setting-Smart_device_16,15,
ENG13195-ENG14594,Personalized_smart_device_setting-Smart_device_2,0,
ENG13195-ENG14595,Personalized_smart_device_setting-Smart_device_3,0,
ENG13195-ENG14596,Personalized_smart_device_setting-Smart_device_4,0,
ENG13195-ENG14597,Personalized_smart_device_setting-Smart_device_5,0,
ENG13195-ENG14598,Personalized_smart_device_setting-Smart_device_6,0,
ENG13195-ENG14599,Personalized_smart_device_setting-Smart_device_7,15,
ENG13195-ENG14600,Personalized_smart_device_setting-Smart_device_8,15,
ENG13195-ENG14601,Personalized_smart_device_setting-Smart_device_9,15,
ENG121948-ENG121879,Rear_Lid_Opening_Sender_Cycle_Data-trace_1,01,
ENG121948-ENG121888,Rear_Lid_Opening_Sender_Cycle_Data-trace_10,01,
ENG121948-ENG121889,Rear_Lid_Opening_Sender_Cycle_Data-trace_11,70,
ENG121948-ENG121890,Rear_Lid_Opening_Sender_Cycle_Data-trace_12,70,
ENG121948-ENG121891,Rear_Lid_Opening_Sender_Cycle_Data-trace_13,70,
ENG121948-ENG121892,Rear_Lid_Opening_Sender_Cycle_Data-trace_14,01,
ENG121948-ENG121893,Rear_Lid_Opening_Sender_Cycle_Data-trace_15,70,
ENG121948-ENG121894,Rear_Lid_Opening_Sender_Cycle_Data-trace_16,70,
ENG121948-ENG121895,Rear_Lid_Opening_Sender_Cycle_Data-trace_17,70,
ENG121948-ENG121896,Rear_Lid_Opening_Sender_Cycle_Data-trace_18,70,
ENG121948-ENG121897,Rear_Lid_Opening_Sender_Cycle_Data-trace_19,01,
ENG121948-ENG121880,Rear_Lid_Opening_Sender_Cycle_Data-trace_2,10,
ENG121948-ENG121898,Rear_Lid_Opening_Sender_Cycle_Data-trace_20,70,
ENG121948-ENG121881,Rear_Lid_Opening_Sender_Cycle_Data-trace_3,01,
ENG121948-ENG121882,Rear_Lid_Opening_Sender_Cycle_Data-trace_4,10,
ENG121948-ENG121883,Rear_Lid_Opening_Sender_Cycle_Data-trace_5,70,
ENG121948-ENG121884,Rear_Lid_Opening_Sender_Cycle_Data-trace_6,10,
ENG121948-ENG121885,Rear_Lid_Opening_Sender_Cycle_Data-trace_7,01,
ENG121948-ENG121886,Rear_Lid_Opening_Sender_Cycle_Data-trace_8,10,
ENG121948-ENG121887,Rear_Lid_Opening_Sender_Cycle_Data-trace_9,01,
ENG121949,Rear_Lid_Opening_Sender_ROM-Parameter_Version,09 10,
ENG12878-ENG108452,Reset_counter_coprocessor-Reset_counter,0,
ENG12880-ENG108452,Reset_counter_main_processor-Reset_counter,0,
ENG12897-ENG13902,service_key_counter_datagroup-datagroup_1,853,
ENG12897-ENG13903,service_key_counter_datagroup-datagroup_2,737,
ENG12897-ENG13904,service_key_counter_datagroup-datagroup_3,449,
ENG12897-ENG13905,service_key_counter_datagroup-datagroup_4,1769,
ENG12899-ENG13914,service_key_intern_conditions-conditions,00000010 ,
ENG12899-ENG13916,service_key_intern_conditions-mq_states,00,
ENG12899-ENG13918,service_key_intern_conditions-obdc_changed_datagroup,00 00,
ENG12899-ENG13915,service_key_intern_conditions-obdc_interface_states,00000000 ,
ENG12899-ENG13917,service_key_intern_conditions-obdc_request_timeout_counter,30,
ENG12899-ENG13626,service_key_intern_conditions-Trigger,00000010 ,
ENG12901-ENG13983,service_key_key_store_counter-all_key_counter,5808,
ENG12901-ENG13894,service_key_key_store_counter-key1_counter,65,
ENG12901-ENG13895,service_key_key_store_counter-key2_counter,5741,
ENG12901-ENG13896,service_key_key_store_counter-key3_counter,Not adapted,
ENG12901-ENG13897,service_key_key_store_counter-key4_counter,Not adapted,
ENG12901-ENG13898,service_key_key_store_counter-key5_counter,Not adapted,
ENG12901-ENG13899,service_key_key_store_counter-key6_counter,Not adapted,
ENG12901-ENG13900,service_key_key_store_counter-key7_counter,Not adapted,
ENG12901-ENG13901,service_key_key_store_counter-key8_counter,Not adapted,
ENG12902-ENG13894,service_key_key_store_counter_per_day-key1_counter,6,
ENG12902-ENG13895,service_key_key_store_counter_per_day-key2_counter,20,
ENG12902-ENG13896,service_key_key_store_counter_per_day-key3_counter,Not adapted,
ENG12902-ENG13897,service_key_key_store_counter_per_day-key4_counter,Not adapted,
ENG12902-ENG13898,service_key_key_store_counter_per_day-key5_counter,Not adapted,
ENG12902-ENG13899,service_key_key_store_counter_per_day-key6_counter,Not adapted,
ENG12902-ENG13900,service_key_key_store_counter_per_day-key7_counter,Not adapted,
ENG12902-ENG13901,service_key_key_store_counter_per_day-key8_counter,Not adapted,
ENG12898-ENG13913,service_key_store_conditions-debounce_kilometer,15,
ENG12898-ENG13621,service_key_store_conditions-Distance,20,
ENG12898-ENG13911,service_key_store_conditions-hazard_warning_switch_delay_time,10,
ENG12898-ENG13908,service_key_store_conditions-retry_request_obdc,3,
ENG12898-ENG13906,service_key_store_conditions-service_key_coded,Yes,
ENG12898-ENG13907,service_key_store_conditions-timeout_request_obdc,30,
ENG12898-ENG13912,service_key_store_conditions-write_data_delay_time,40,
ENG12898-ENG13910,service_key_store_conditions-write_delay_speed,20,
ENG12898-ENG13909,service_key_store_conditions-write_delay_time,20,
ENG12900-ENG13920,service_key_store_time-key1_day,28,
ENG12900-ENG13919,service_key_store_time-key1_kilometer,18,
ENG12900-ENG13921,service_key_store_time-key1_month,8,
ENG12900-ENG13922,service_key_store_time-key1_year,2018,
ENG12900-ENG13924,service_key_store_time-key2_day,9,
ENG12900-ENG13923,service_key_store_time-key2_kilometer,32298,
ENG12900-ENG13925,service_key_store_time-key2_month,11,
ENG12900-ENG13926,service_key_store_time-key2_year,2019,
ENG12900-ENG13928,service_key_store_time-key3_day,Not adapted,
ENG12900-ENG13927,service_key_store_time-key3_kilometer,Not adapted,
ENG12900-ENG13929,service_key_store_time-key3_month,Not adapted,
ENG12900-ENG13930,service_key_store_time-key3_year,Not adapted,
ENG12900-ENG13932,service_key_store_time-key4_day,Not adapted,
ENG12900-ENG13931,service_key_store_time-key4_kilometer,Not adapted,
ENG12900-ENG13933,service_key_store_time-key4_month,Not adapted,
ENG12900-ENG13934,service_key_store_time-key4_year,Not adapted,
ENG12900-ENG13936,service_key_store_time-key5_day,Not adapted,
ENG12900-ENG13935,service_key_store_time-key5_kilometer,Not adapted,
ENG12900-ENG13937,service_key_store_time-key5_month,Not adapted,
ENG12900-ENG13938,service_key_store_time-key5_year,Not adapted,
ENG12900-ENG13940,service_key_store_time-key6_day,Not adapted,
ENG12900-ENG13939,service_key_store_time-key6_kilometer,Not adapted,
ENG12900-ENG13941,service_key_store_time-key6_month,Not adapted,
ENG12900-ENG13942,service_key_store_time-key6_year,Not adapted,
ENG12900-ENG13944,service_key_store_time-key7_day,Not adapted,
ENG12900-ENG13943,service_key_store_time-key7_kilometer,Not adapted,
ENG12900-ENG13945,service_key_store_time-key7_month,Not adapted,
ENG12900-ENG13946,service_key_store_time-key7_year,Not adapted,
ENG12900-ENG13948,service_key_store_time-key8_day,Not adapted,
ENG12900-ENG13947,service_key_store_time-key8_kilometer,Not adapted,
ENG12900-ENG13949,service_key_store_time-key8_month,Not adapted,
ENG12900-ENG13950,service_key_store_time-key8_year,Not adapted,
ENG12885,Software_version_fbs,M310805:SW_C2.6.N122_MLB_EVO_FBS,
ENG12856-MAS06262,sun_blind_power_limit_status-Roof blind 1,not coded/not installed,
ENG12856-MAS06263,sun_blind_power_limit_status-Roof Blind 2,not coded/not installed,
ENG12850-MAS06262,sun_blind_standardization_status-Roof blind 1,not coded/not installed,
ENG12850-MAS06263,sun_blind_standardization_status-Roof Blind 2,not coded/not installed,
ENG12853-MAS06262,sun_blind_thermal_protection_status-Roof blind 1,not coded/not installed,
ENG12853-MAS06263,sun_blind_thermal_protection_status-Roof Blind 2,not coded/not installed,
ENG12942-ENG14150,sun_roof_position-MD1_position,0, %
ENG12942-ENG14151,sun_roof_position-MD3_position,0, %
ENG12942-ENG14152,sun_roof_position-Sun_roof_2_position,not coded/not installed,
ENG12855-MAS06260,sun_roof_power_limit_status-Sunroof 1,not active,
ENG12855-MAS06261,sun_roof_power_limit_status-Sunroof 2,not coded/not installed,
ENG12870-ENG13754,sunroof_control_unit-sunroof_control_unit_signals_CAN,not coded/not installed,
ENG12849-MAS06260,sunroof_standardization_status-Sunroof 1,normed,
ENG12849-MAS06261,sunroof_standardization_status-Sunroof 2,not coded/not installed,
ENG12852-MAS06260,sunroof_thermal_protection_status-Sunroof 1,not active,
ENG12852-MAS06261,sunroof_thermal_protection_status-Sunroof 2,not coded/not installed,
ENG12875-ENG13846,sw_version_in_house_development-Software_version_central_locking,10 01 00 17,
ENG12875-ENG13845,sw_version_in_house_development-Software_version_clamp_control,0D 03 01 1C,
ENG12875-ENG13847,sw_version_in_house_development-Software_version_reserve_1,,
ENG12875-ENG13848,sw_version_in_house_development-Software_version_reserve_2,,
ENG12876,System_load,00,
ENG12862-ENG13711,systeminfo_01-diagnostics_active,not active,
ENG12913,terminal_control_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12864-ENG13717,terminal_control_intern_conditions-restart_information,no_restart_detected,
ENG12864-ENG13716,terminal_control_intern_conditions-start_stop_information,engine_Start_and_engine_speed_detected,
ENG12864-ENG13714,terminal_control_intern_conditions-terminal_control_status,state_S4,
ENG12864-ENG13715,terminal_control_intern_conditions-terminal_control_status_terminals,00000011 ,
ENG12867-ENG13743,terminal_control_intern_signals-customer_request,00000000 ,
ENG12867-ENG13738,terminal_control_intern_signals-diagnostic_routine_kl15,00000000 ,
ENG12867-ENG13740,terminal_control_intern_signals-elv,00000010 ,
ENG12867-ENG13736,terminal_control_intern_signals-engine_brake_gearshift,00000011 ,
ENG12867-ENG13745,terminal_control_intern_signals-kl15_counter,2604,
ENG12867-ENG13742,terminal_control_intern_signals-kl15_shut_off,00010101 ,
ENG12867-ENG13741,terminal_control_intern_signals-leave_concept,00000101 ,
ENG12867-ENG13739,terminal_control_intern_signals-p_mode,00000000 ,
ENG12867-ENG13737,terminal_control_intern_signals-sst,00000000 ,
ENG12867-ENG13744,terminal_control_intern_signals-start_trials,0,
ENG12865-ENG13719,terminal_control_klemmen_status_01-bz,2,
ENG12865-ENG13718,terminal_control_klemmen_status_01-crc,222,
ENG12865-ENG13723,terminal_control_klemmen_status_01-kst_driver_note_1,not active,
ENG12865-ENG13724,terminal_control_klemmen_status_01-kst_driver_note_2,not active,
ENG12865-ENG13725,terminal_control_klemmen_status_01-kst_driver_note_3,not active,
ENG12865-ENG13726,terminal_control_klemmen_status_01-kst_driver_note_4,not active,
ENG12865-ENG13727,terminal_control_klemmen_status_01-kst_driver_note_5,not active,
ENG12865-ENG13728,terminal_control_klemmen_status_01-kst_driver_note_6,not active,
ENG12865-ENG13721,terminal_control_klemmen_status_01-kst_warn_p1_zst_def,no error,
ENG12865-ENG13722,terminal_control_klemmen_status_01-kst_warn_p2_zst_def,no error,
ENG12865-ENG09864,terminal_control_klemmen_status_01-remote_start,not active,
ENG12865-ENG13627,terminal_control_klemmen_status_01-terminal_15,active,
ENG12865-ENG13629,terminal_control_klemmen_status_01-terminal_50,not active,
ENG12865-ENG13720,terminal_control_klemmen_status_01-terminal_infotainment,active,
ENG12865-ENG13628,terminal_control_klemmen_status_01-terminal_S,active,
ENG12865-ENG13637,terminal_control_klemmen_status_01-terminal_x,not active,
ENG12866-ENG13719,terminal_control_klemmen_steuerung_01-bz,1,
ENG12866-ENG13718,terminal_control_klemmen_steuerung_01-crc,232,
ENG12866-ENG13731,terminal_control_klemmen_steuerung_01-kst_anf_klemmenfreigabe_elv,not_requested,
ENG12866-ENG13735,terminal_control_klemmen_steuerung_01-kst_aut_abschaltung_zuendung,not active,
ENG12866-ENG13732,terminal_control_klemmen_steuerung_01-kst_elv_trigger_entriegelung,not_requested,
ENG12866-ENG13729,terminal_control_klemmen_steuerung_01-kst_txt_p_gang,OFF,
ENG12866-ENG13730,terminal_control_klemmen_steuerung_01-kst_txt_panikabschaltung,OFF,
ENG12866-ENG13734,terminal_control_klemmen_steuerung_01-kst_unterdr_zuendungsmeldung,not active,
ENG12866-ENG13733,terminal_control_klemmen_steuerung_01-kst_zat_betaetigt,Not operated,
ENG12868-ENG13746,terminal_control_task_state-clamp_state_1,10100111 ,
ENG12868-ENG13747,terminal_control_task_state-clamp_state_2,00000010 ,
ENG100973-MAS00370,Vehicle_speed-Vehicle speed,0.00, km/h
ENG100973-MAS05849,Vehicle_speed-Vehicle speed validity from bus,valid,
ENG12871-ENG13756,virtual_pedal_signals_LIN-vipe_01_byte1,00000000 00000000 ,
ENG12871-ENG13757,virtual_pedal_signals_LIN-vipe_01_byte2,00000000 00000000 ,
ENG12871-ENG13758,virtual_pedal_signals_LIN-vipe_01_byte3,00000000 00000000 ,
ENG12871-ENG13759,virtual_pedal_signals_LIN-vipe_01_byte4,0, %
ENG12871-ENG13760,virtual_pedal_signals_LIN-vipe_01_byte5,0,
ENG12871-ENG13761,virtual_pedal_signals_LIN-vipe_01_byte6,00000000 00000000 ,
ENG12871-ENG13762,virtual_pedal_signals_LIN-vipe_01_byte7,00000000 00000000 ,
ENG12871-ENG13763,virtual_pedal_signals_LIN-vipe_01_byte8,00000000 00000000 ,
ENG12871-ENG13764,virtual_pedal_signals_LIN-vips_01_byte1,00000000 00000000 ,
ENG12871-ENG13765,virtual_pedal_signals_LIN-vips_01_byte2,00000000 00000000 ,
ENG12871-ENG13766,virtual_pedal_signals_LIN-vips_01_byte3,00000000 00000000 ,
ENG12871-ENG13767,virtual_pedal_signals_LIN-vips_01_byte4,0,
ENG12871-ENG13768,virtual_pedal_signals_LIN-vips_01_byte5,00000000 00000000 ,
ENG12871-ENG13769,virtual_pedal_signals_LIN-vips_01_byte6,00000000 00000000 ,
ENG12871-ENG13770,virtual_pedal_signals_LIN-vips_01_byte7,00000000 00000000 ,
ENG12871-ENG13771,virtual_pedal_signals_LIN-vips_01_byte8,00000000 00000000 ,
ENG12887-ENG13880,wakepattern-Active_wakepattern,1E C0 BB 4F,
ENG12887-ENG13881,wakepattern-Next_wakepattern,FF FF FF FF,
ENG12891-ENG13894,wcs_counter-key1_counter,10,
ENG12891-ENG13895,wcs_counter-key2_counter,10,
ENG12891-ENG13896,wcs_counter-key3_counter,255,
ENG12891-ENG13897,wcs_counter-key4_counter,255,
ENG12891-ENG13898,wcs_counter-key5_counter,255,
ENG12891-ENG13899,wcs_counter-key6_counter,255,
ENG12891-ENG13900,wcs_counter-key7_counter,255,
ENG12891-ENG13901,wcs_counter-key8_counter,255,
ENG12854-MAS00218,window_lift_power_limit_status-Driver door,not active,
ENG12854-MAS00219,window_lift_power_limit_status-Front Passenger Door,not active,
ENG12854-MAS02555,window_lift_power_limit_status-Rear driver side,not active,
ENG12854-MAS02556,window_lift_power_limit_status-Rear passenger-side,not active,
ENG12848-MAS00218,window_lift_standardization_status-Driver door,normed,
ENG12848-MAS00219,window_lift_standardization_status-Front Passenger Door,normed,
ENG12848-MAS02555,window_lift_standardization_status-Rear driver side,normed,
ENG12848-MAS02556,window_lift_standardization_status-Rear passenger-side,normed,
ENG12851-MAS00218,window_lift_thermal_protection_status-Driver door,not active,
ENG12851-MAS00219,window_lift_thermal_protection_status-Front Passenger Door,not active,
ENG12851-MAS02555,window_lift_thermal_protection_status-Rear driver side,not active,
ENG12851-MAS02556,window_lift_thermal_protection_status-Rear passenger-side,not active,
ENG110126-MAS00218,Window_Lifter_Position-Driver door,56.0, %
ENG110126-MAS00219,Window_Lifter_Position-Front Passenger Door,0.0, %
ENG110126-MAS02555,Window_Lifter_Position-Rear driver side,0.0, %
ENG110126-MAS02556,Window_Lifter_Position-Rear passenger-side,0.0, %
ENG12915,zv_engine_lwr_rear_wiper_freeze_frame,11110001 00010111 00010011 10010000 ,
Elapsed Time: 01:40
;SW:8W0-907-064-EC   HW:8W0-907-064-DC ---  Central Conv.
;Component:BCM2 MLBevo   025 0387, Coding:013400004FB00080650FA0002E01000233024000810026502F0400000B04803F001E0001000000
;EV_BCM2HellaAU736,014014,EV_BCM2HellaAU736_014_AU49.rod
;Sunday,10,November,2019,20:39:40:01617
;VCID: 81458642100FDB4728-80D4
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10851-Production mode-Deactivate engine start,not active ,3
IDE00001-MAS10853-Production mode-Deactivate sensor-controlled rear lid opening,not active ,3
IDE00001-MAS10854-Production mode-Deactivate central locking: function lock,not active ,3
IDE00001-MAS10855-Production mode-Deactivate ignition switch-off when vehicle has been left,not active ,3
IDE00001-MAS12009-Production mode-Deactivate lighting,not active ,3
IDE00001-MAS12010-Production mode-Deactivate automatic unlocking,not active ,3
IDE00001-MAS17290-Production mode-Suppress further signal sources for “Terminal 15 on”,not active ,3
IDE00820-Activating and deactivating all development messages,00 ,1
IDE01464-MAS01167-Rear window defogger-Actuation time,600 s,2
IDE01464-MAS01186-Rear window defogger-Shut-off temperature,35.0 °C,2
IDE02488-DWA Interior monitoring,100 %,1
IDE04923-MAS08465-Turn signal control-Freeway flashing: flashing cycles,3 ,4
IDE04923-MAS08466-Turn signal control-Confirmation flashing unlocking central locking:flashing cycles,2 ,4
IDE04923-MAS08467-Turn signal control-Confirmation flashing locking central locking: flashing cycles,1 ,4
IDE04923-MAS10114-Turn signal control-Turn signal with relocking,On ,4
IDE04923-MAS10115-Turn signal control-Anti-theft blinkers by inter. door handle activ.,On ,4
IDE04923-MAS13291-Turn signal control-Motorway flashing cancel by counter tap,On ,4
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 DE D6 06 00 0F 1E 00 85 0E 39 F7 63 23 65 42 57 9B 25 44 3F 3A 69 58 85 2E 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 68 0F A3 42 87 9B 05 34 3A 3A 69 25 03 0A 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 9B 05 24 3F 3A 69 47 03 0A 09 A3 04 23 15 4A 16 0A 16 1F 89 0B 28 51 32 0C 61 31 5B 94 05 24 8F FD 57 45 02 14 05 A2 05 61 06 03 17 0C 11 1A 87 02 23 33 69 23 65 42 57 9B 25 24 0C FA 0A 35 85 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 20 C2 28 57 ,172
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE07279-Anti-theft warning system: monitoring diagnostics connection,On ,1
IDE07392-Terminal 15,Default ,1
IDE08221-MAS02444-Personalization settings key 1-Central locking,Individual door opening ,3
IDE08221-MAS06456-Personalization settings key 1-Autolock,On ,3
IDE08221-MAS06457-Personalization settings key 1-autounlock,On ,3
IDE08221-MAS06696-Personalization settings key 1-Comfort opening sunroof,OFF ,3
IDE08221-MAS06697-Personalization settings key 1-Acoustic acknowledge signal,On ,3
IDE08221-MAS06698-Personalization settings key 1-Freeway flashing,On ,3
IDE08221-MAS06740-Personalization settings key 1-Release button in rear lid handle locked,OFF ,3
IDE08221-MAS06756-Personalization settings key 1-Window shade automatic,OFF ,3
IDE08221-MAS06880-Personalization settings key 1-Mirror fold-in (Audi),OFF ,3
IDE08221-MAS10221-Personalization settings key 1-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08221-MAS10228-Personalization settings key 1-Comfort opening window: driver side,OFF ,3
IDE08221-MAS10229-Personalization settings key 1-Comfort opening window: frt. pass. side,OFF ,3
IDE08221-MAS10230-Personalization settings key 1-Comfort opening rear window: driver side,OFF ,3
IDE08221-MAS10231-Personalization settings key 1-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08222-MAS02444-Personalization settings key 2-Central locking,global opening ,3
IDE08222-MAS06456-Personalization settings key 2-Autolock,On ,3
IDE08222-MAS06457-Personalization settings key 2-autounlock,On ,3
IDE08222-MAS06696-Personalization settings key 2-Comfort opening sunroof,On ,3
IDE08222-MAS06697-Personalization settings key 2-Acoustic acknowledge signal,On ,3
IDE08222-MAS06698-Personalization settings key 2-Freeway flashing,On ,3
IDE08222-MAS06740-Personalization settings key 2-Release button in rear lid handle locked,OFF ,3
IDE08222-MAS06756-Personalization settings key 2-Window shade automatic,OFF ,3
IDE08222-MAS06880-Personalization settings key 2-Mirror fold-in (Audi),On ,3
IDE08222-MAS10221-Personalization settings key 2-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08222-MAS10228-Personalization settings key 2-Comfort opening window: driver side,On ,3
IDE08222-MAS10229-Personalization settings key 2-Comfort opening window: frt. pass. side,On ,3
IDE08222-MAS10230-Personalization settings key 2-Comfort opening rear window: driver side,On ,3
IDE08222-MAS10231-Personalization settings key 2-Comfort opening rear window: frt. pass. side,On ,3
IDE08223-MAS02444-Personalization settings key 3-Central locking,Individual door opening ,3
IDE08223-MAS06456-Personalization settings key 3-Autolock,On ,3
IDE08223-MAS06457-Personalization settings key 3-autounlock,On ,3
IDE08223-MAS06696-Personalization settings key 3-Comfort opening sunroof,OFF ,3
IDE08223-MAS06697-Personalization settings key 3-Acoustic acknowledge signal,On ,3
IDE08223-MAS06698-Personalization settings key 3-Freeway flashing,On ,3
IDE08223-MAS06740-Personalization settings key 3-Release button in rear lid handle locked,OFF ,3
IDE08223-MAS06756-Personalization settings key 3-Window shade automatic,OFF ,3
IDE08223-MAS06880-Personalization settings key 3-Mirror fold-in (Audi),OFF ,3
IDE08223-MAS10221-Personalization settings key 3-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08223-MAS10228-Personalization settings key 3-Comfort opening window: driver side,OFF ,3
IDE08223-MAS10229-Personalization settings key 3-Comfort opening window: frt. pass. side,OFF ,3
IDE08223-MAS10230-Personalization settings key 3-Comfort opening rear window: driver side,OFF ,3
IDE08223-MAS10231-Personalization settings key 3-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08224-MAS02444-Personalization settings key 4-Central locking,Individual door opening ,3
IDE08224-MAS06456-Personalization settings key 4-Autolock,On ,3
IDE08224-MAS06457-Personalization settings key 4-autounlock,On ,3
IDE08224-MAS06696-Personalization settings key 4-Comfort opening sunroof,OFF ,3
IDE08224-MAS06697-Personalization settings key 4-Acoustic acknowledge signal,On ,3
IDE08224-MAS06698-Personalization settings key 4-Freeway flashing,On ,3
IDE08224-MAS06740-Personalization settings key 4-Release button in rear lid handle locked,OFF ,3
IDE08224-MAS06756-Personalization settings key 4-Window shade automatic,OFF ,3
IDE08224-MAS06880-Personalization settings key 4-Mirror fold-in (Audi),OFF ,3
IDE08224-MAS10221-Personalization settings key 4-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08224-MAS10228-Personalization settings key 4-Comfort opening window: driver side,OFF ,3
IDE08224-MAS10229-Personalization settings key 4-Comfort opening window: frt. pass. side,OFF ,3
IDE08224-MAS10230-Personalization settings key 4-Comfort opening rear window: driver side,OFF ,3
IDE08224-MAS10231-Personalization settings key 4-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08225-MAS02444-Personalization settings vehicle-Central locking,Individual door opening ,3
IDE08225-MAS06456-Personalization settings vehicle-Autolock,On ,3
IDE08225-MAS06457-Personalization settings vehicle-autounlock,On ,3
IDE08225-MAS06696-Personalization settings vehicle-Comfort opening sunroof,OFF ,3
IDE08225-MAS06697-Personalization settings vehicle-Acoustic acknowledge signal,On ,3
IDE08225-MAS06698-Personalization settings vehicle-Freeway flashing,On ,3
IDE08225-MAS06740-Personalization settings vehicle-Release button in rear lid handle locked,OFF ,3
IDE08225-MAS06756-Personalization settings vehicle-Window shade automatic,OFF ,3
IDE08225-MAS06880-Personalization settings vehicle-Mirror fold-in (Audi),OFF ,3
IDE08225-MAS10221-Personalization settings vehicle-Rear lid unlocking through rear lid opening sensors,On ,3
IDE08225-MAS10228-Personalization settings vehicle-Comfort opening window: driver side,OFF ,3
IDE08225-MAS10229-Personalization settings vehicle-Comfort opening window: frt. pass. side,OFF ,3
IDE08225-MAS10230-Personalization settings vehicle-Comfort opening rear window: driver side,OFF ,3
IDE08225-MAS10231-Personalization settings vehicle-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08225-MAS16238-Personalization settings vehicle-Keyless access authorization,On ,3
IDE08226-Use of personalization settings,Key ,1
IDE08398-Delay time alarm triggering,0 s,1
IDE08399-Delay time crash unlocking,2.5 s,1
IDE08400-Betätigungszeit Öffnen der Heckklappe mit Funkfernbedienung,800 ms,1
IDE09735-CU tailgate opener: sensor 1: threshold value 1,15 ,1
IDE09736-CU tailgate opener: sensor 1: threshold value 2,15 ,1
IDE09737-CU tailgate opener: sensor 1: threshold value 3,15 ,1
IDE09738-CU tailgate opener: sensor 1: threshold value 4,15 ,1
IDE09739-CU tailgate opener: sensor 1: threshold value 5,15 ,1
IDE09740-CU tailgate opener: sensor 2: threshold value 1,02 ,1
IDE09741-CU tailgate opener: sensor 2: threshold value 2,1F ,1
IDE09742-CU tailgate opener: sensor 2: threshold value 3,02 ,1
IDE09743-CU tailgate opener: sensor 2: threshold value 4,1F ,1
IDE09744-CU tailgate opener: sensor 2: threshold value 5,40 ,1
IDE09745-CU tailgate opener: sensor 1: timer value 1,AA ,1
IDE09746-CU tailgate opener: sensor 1: timer value 2,00 ,1
IDE09747-CU tailgate opener: sensor 1: timer value 3,00 ,1
IDE09748-CU tailgate opener: sensor 1: timer value 4,E1 ,1
IDE09749-CU tailgate opener: sensor 1: timer value 5,00 ,1
IDE09750-CU tailgate opener: sensor 2: timer value 1,0B ,1
IDE09751-CU tailgate opener: sensor 2: timer value 2,AA ,1
IDE09752-CU tailgate opener: sensor 2: timer value 3,53 ,1
IDE09753-CU tailgate opener: sensor 2: timer value 4,CC ,1
IDE09754-CU tailgate opener: sensor 2: timer value 5,B5 ,1
IDE09755-CU tailgate opener: sensor 1: burst length,10 ,1
IDE09756-CU tailgate opener: sensor 1: active screening,10 ,1
IDE09757-CU tailgate opener: sensor 2: burst length,02 ,1
IDE09758-CU tailgate opener: sensor 2: active screening,1F ,1
IDE09759-CU for tailgate opener: reset all counters,E0 ,1
IDE09760-CU for tailgate opener: check sum,AA ,1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,02 ,1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,1F ,1
IDE09831-CU for tailgate opener: play protection increments,06 ,1
IDE09832-CU for tailgate opener: play protection decrements,19 ,1
IDE09833-CU for tailgate opener: play protection threshold active,FF ,1
IDE09834-CU for tailgate opener: play protection threshold inactive,05 ,1
IDE09835-CU for tailgate opener: play protection decrement interval,3C ,1
IDE09836-CU tailgate opener: sensor 1: control parameter,10 ,1
IDE09837-CU tailgate opener: sensor 2: control parameter,10 ,1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation,00 ,1
IDE09839-CU for tailgate opener: parameter set version,00 0A ,2
IDE10086-IDE02262-Personal settings of key 1: Part 2-synchronous mirror adjustment,OFF ,1
IDE10086-IDE03946-Personal settings of key 1: Part 2-Mirror dimming,OFF ,1
IDE10086-MAS05213-Personal settings of key 1: Part 2-Mirror heater,OFF ,1
IDE10086-MAS06870-Personal settings of key 1: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10086-MAS06881-Personal settings of key 1: Part 2-Mirror fold-in (VW),OFF ,1
IDE10087-IDE02262-Personal settings of key 2: Part 2-synchronous mirror adjustment,OFF ,1
IDE10087-IDE03946-Personal settings of key 2: Part 2-Mirror dimming,OFF ,1
IDE10087-MAS05213-Personal settings of key 2: Part 2-Mirror heater,OFF ,1
IDE10087-MAS06870-Personal settings of key 2: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10087-MAS06881-Personal settings of key 2: Part 2-Mirror fold-in (VW),OFF ,1
IDE10088-IDE02262-Personal settings of key 3: Part 2-synchronous mirror adjustment,OFF ,1
IDE10088-IDE03946-Personal settings of key 3: Part 2-Mirror dimming,OFF ,1
IDE10088-MAS05213-Personal settings of key 3: Part 2-Mirror heater,OFF ,1
IDE10088-MAS06870-Personal settings of key 3: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10088-MAS06881-Personal settings of key 3: Part 2-Mirror fold-in (VW),OFF ,1
IDE10089-IDE02262-Personal settings of key 4: Part 2-synchronous mirror adjustment,OFF ,1
IDE10089-IDE03946-Personal settings of key 4: Part 2-Mirror dimming,OFF ,1
IDE10089-MAS05213-Personal settings of key 4: Part 2-Mirror heater,OFF ,1
IDE10089-MAS06870-Personal settings of key 4: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10089-MAS06881-Personal settings of key 4: Part 2-Mirror fold-in (VW),OFF ,1
IDE10090-IDE02262-Personal settings of vehicle: Part 2-synchronous mirror adjustment,OFF ,1
IDE10090-IDE03946-Personal settings of vehicle: Part 2-Mirror dimming,OFF ,1
IDE10090-MAS05213-Personal settings of vehicle: Part 2-Mirror heater,OFF ,1
IDE10090-MAS06870-Personal settings of vehicle: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10090-MAS06881-Personal settings of vehicle: Part 2-Mirror fold-in (VW),OFF ,1
IDE10283-Key identification: transponder ID,FF FF FF FF ,4
IDE10318-Sunshade activation,cannot be activated ,1
IDE10347-Trip distance challenge,00 00 00 00 00 00 00 00 ,8
IDE10836-Enable code for vehicle positioning system,18477 ,2
IDE10858-Number of simultaneously adapting key,0 ,1
IDE10913-MAS10979-Setting the key data-Start page,00 00 ,3
IDE10913-MAS10980-Setting the key data-No. of pages,00 ,3
IDE10913-MAS11635-Setting the key data-Data security,encrypted ,3
IDE11476-Ignition lock: variant,Audi ,1
IDE11487-Trunk emergency release,OFF ,1
IDE11700-Parameter group 1,FF FF FF C0 00 00 00 00 00 00 0F 32 14 0A 05 80 0F 00 19 50 46 46 00 0A 02 14 3C 01 00 14 00 02 05 00 0A 14 B4 01 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E 39 ,255
IDE11701-Parameter group 2,FF FF FF FF F0 00 00 00 00 00 00 00 1E 01 1E 0A 00 0A 03 00 00 00 1E 0A 3C 3C 01 04 00 01 03 00 00 00 01 50 96 01 01 02 FF 00 FF 00 00 5A 14 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1A E6 ,255
IDE11702-Parameter group 3,FF FF FF E0 00 00 00 00 00 00 0A 0C 14 16 14 16 02 00 0A 14 16 14 1E 14 14 00 00 1E 0A FF FF FF 05 28 3C 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 A0 ,255
IDE11703-Parameter group 4,E0 00 00 00 00 00 00 00 00 00 FF FF 83 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 31 ,255
IDE11704-Parameter group 5,E0 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B3 CA ,255
IDE11705-Parameter group 6,FF FF C0 00 00 00 00 00 00 00 F5 96 02 0A 64 02 01 00 96 06 96 06 96 06 96 06 14 00 0F 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 44 ,255
IDE11706-Parameter group 7,FF FF FF FF FF F0 00 00 00 00 02 0A 32 3C 18 14 05 0A 1E 01 02 5A 14 14 0A 00 00 06 05 0F 14 00 5A 02 32 14 05 05 05 05 05 05 05 01 00 32 0A 05 1E 06 14 01 01 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 65 67 ,255
IDE11707-Parameter group 8,FF FF FF FE 00 00 00 00 00 00 01 00 00 1E 00 05 32 00 00 01 07 00 07 00 00 02 01 01 04 00 14 1E 0A 02 0A 02 1E 64 1E 0A 3C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 0B ,255
IDE11708-Parameter group 9,80 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 19 DF ,255
IDE11709-Parameter group 10,FF E0 00 00 00 00 00 00 00 00 00 0A 00 0A 00 1C 00 3C 00 32 0A 05 05 32 05 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 92 E4 ,255
IDE11798-Speed-dependent activation of the back window heater,activated ,1
IDE11935-MAS13456-Personalization-Automatic key assignment,activated ,1
IDE11935-MAS13457-Personalization-Status of personalization,activated ,1
IDE12303-MAS14243-Separation monitoring radio key to rear lid-Minimum opening angle of the rear lid for activation,3 %,6
IDE12303-MAS14244-Separation monitoring radio key to rear lid-Minimum opening angle of the rear lid to reverse,224 %,6
IDE12303-MAS14245-Separation monitoring radio key to rear lid-Lock vehicle after closing,OFF ,6
IDE12303-MAS14246-Separation monitoring radio key to rear lid-Monitoring time for rear lid restart,0 %,6
IDE12303-MAS14247-Separation monitoring radio key to rear lid-Monitoring time for rear lid closing,0 %,6
IDE12465-Rear lid opener control module: response in trailer mode,not activated ,2
IDE12481-MAS06700-Horn and flasher via smartphone app-Speed threshold,0 km/h,5
IDE12481-MAS14561-Horn and flasher via smartphone app-Division factor of horn frequency,0 ,5
IDE12481-MAS14562-Horn and flasher via smartphone app-Maximum execution duration,45 s,5
IDE12548-MAS14750-NFC communication: settings-Command category for single-sided NFC authentication,00 ,27
IDE12548-MAS14751-NFC communication: settings-Command for one-sided NFC authentication,10 ,27
IDE12548-MAS14752-NFC communication: settings-Parameter 1 for one-sided NFC authentication,00 ,27
IDE12548-MAS14753-NFC communication: settings-Parameter 2 for one-sided NFC authentication,00 ,27
IDE12548-MAS14754-NFC communication: settings-Command category for two-sided NFC authentication,00 ,27
IDE12548-MAS14755-NFC communication: settings-Command for two-sided NFC authentication,10 ,27
IDE12548-MAS14756-NFC communication: settings-Parameter 1 for two-sided NFC authentication,10 ,27
IDE12548-MAS14757-NFC communication: settings-Parameter 2 for two-sided NFC authentication,00 01 02 ,27
IDE12548-MAS14758-NFC communication: settings-Time point for NFC advance authentication,Last door closed ,27
IDE12548-MAS14761-NFC communication: settings-Block NFC device in the interior,not activated ,27
IDE12548-MAS14762-NFC communication: settings-NFC event search,activated ,27
IDE12548-MAS15378-NFC communication: settings-Command category to trigger an event,00 ,27
IDE12548-MAS15379-NFC communication: settings-Command to trigger an event,10 ,27
IDE12548-MAS15380-NFC communication: settings-Parameter 1 to trigger an event,20 ,27
IDE12548-MAS15381-NFC communication: settings-Parameter 2 to trigger an event,00 ,27
IDE12548-MAS15382-NFC communication: settings-Command category for vehicle data,00 ,27
IDE12548-MAS15383-NFC communication: settings-Command for vehicle data,10 ,27
IDE12548-MAS15384-NFC communication: settings-Parameter 1 for vehicle data,90 ,27
IDE12548-MAS15385-NFC communication: settings-Parameter 2 for vehicle data,01 ,27
IDE12548-MAS15386-NFC communication: settings-Command category for event data,00 ,27
IDE12548-MAS15387-NFC communication: settings-Command for event data,10 ,27
IDE12548-MAS15388-NFC communication: settings-Parameter 1 for event data,90 ,27
IDE12548-MAS15389-NFC communication: settings-Parameter 2 for event data,00 ,27
IDE12548-MAS16723-NFC communication: settings-Expected length of triggering event,00 ,27
IDE12548-MAS16724-NFC communication: settings-Expected length of vehicle data,00 ,27
IDE12548-MAS16725-NFC communication: settings-Expected length of event data,00 ,27
IDE12792-MAS02444-Personalization of user account 1-Central locking,Individual door opening ,3
IDE12792-MAS06456-Personalization of user account 1-Autolock,On ,3
IDE12792-MAS06457-Personalization of user account 1-autounlock,On ,3
IDE12792-MAS06696-Personalization of user account 1-Comfort opening sunroof,OFF ,3
IDE12792-MAS06697-Personalization of user account 1-Acoustic acknowledge signal,On ,3
IDE12792-MAS06698-Personalization of user account 1-Freeway flashing,On ,3
IDE12792-MAS06740-Personalization of user account 1-Release button in rear lid handle locked,OFF ,3
IDE12792-MAS06756-Personalization of user account 1-Window shade automatic,OFF ,3
IDE12792-MAS06880-Personalization of user account 1-Mirror fold-in (Audi),OFF ,3
IDE12792-MAS10221-Personalization of user account 1-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12792-MAS10228-Personalization of user account 1-Comfort opening window: driver side,OFF ,3
IDE12792-MAS10229-Personalization of user account 1-Comfort opening window: frt. pass. side,OFF ,3
IDE12792-MAS10230-Personalization of user account 1-Comfort opening rear window: driver side,OFF ,3
IDE12792-MAS10231-Personalization of user account 1-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12793-IDE02262-Personalization of user account 1: part 2-synchronous mirror adjustment,OFF ,1
IDE12793-IDE03946-Personalization of user account 1: part 2-Mirror dimming,OFF ,1
IDE12793-MAS05213-Personalization of user account 1: part 2-Mirror heater,OFF ,1
IDE12793-MAS06870-Personalization of user account 1: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12793-MAS06881-Personalization of user account 1: part 2-Mirror fold-in (VW),OFF ,1
IDE12794-MAS02444-Personalization of user account 2-Central locking,Individual door opening ,3
IDE12794-MAS06456-Personalization of user account 2-Autolock,On ,3
IDE12794-MAS06457-Personalization of user account 2-autounlock,On ,3
IDE12794-MAS06696-Personalization of user account 2-Comfort opening sunroof,OFF ,3
IDE12794-MAS06697-Personalization of user account 2-Acoustic acknowledge signal,On ,3
IDE12794-MAS06698-Personalization of user account 2-Freeway flashing,On ,3
IDE12794-MAS06740-Personalization of user account 2-Release button in rear lid handle locked,OFF ,3
IDE12794-MAS06756-Personalization of user account 2-Window shade automatic,OFF ,3
IDE12794-MAS06880-Personalization of user account 2-Mirror fold-in (Audi),OFF ,3
IDE12794-MAS10221-Personalization of user account 2-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12794-MAS10228-Personalization of user account 2-Comfort opening window: driver side,OFF ,3
IDE12794-MAS10229-Personalization of user account 2-Comfort opening window: frt. pass. side,OFF ,3
IDE12794-MAS10230-Personalization of user account 2-Comfort opening rear window: driver side,OFF ,3
IDE12794-MAS10231-Personalization of user account 2-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12795-IDE02262-Personalization of user account 2: part 2-synchronous mirror adjustment,OFF ,1
IDE12795-IDE03946-Personalization of user account 2: part 2-Mirror dimming,OFF ,1
IDE12795-MAS05213-Personalization of user account 2: part 2-Mirror heater,OFF ,1
IDE12795-MAS06870-Personalization of user account 2: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12795-MAS06881-Personalization of user account 2: part 2-Mirror fold-in (VW),OFF ,1
IDE12796-MAS02444-Personalization of user account 3-Central locking,Individual door opening ,3
IDE12796-MAS06456-Personalization of user account 3-Autolock,On ,3
IDE12796-MAS06457-Personalization of user account 3-autounlock,On ,3
IDE12796-MAS06696-Personalization of user account 3-Comfort opening sunroof,OFF ,3
IDE12796-MAS06697-Personalization of user account 3-Acoustic acknowledge signal,On ,3
IDE12796-MAS06698-Personalization of user account 3-Freeway flashing,On ,3
IDE12796-MAS06740-Personalization of user account 3-Release button in rear lid handle locked,OFF ,3
IDE12796-MAS06756-Personalization of user account 3-Window shade automatic,OFF ,3
IDE12796-MAS06880-Personalization of user account 3-Mirror fold-in (Audi),OFF ,3
IDE12796-MAS10221-Personalization of user account 3-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12796-MAS10228-Personalization of user account 3-Comfort opening window: driver side,OFF ,3
IDE12796-MAS10229-Personalization of user account 3-Comfort opening window: frt. pass. side,OFF ,3
IDE12796-MAS10230-Personalization of user account 3-Comfort opening rear window: driver side,OFF ,3
IDE12796-MAS10231-Personalization of user account 3-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12797-IDE02262-Personalization of user account 3: part 2-synchronous mirror adjustment,OFF ,1
IDE12797-IDE03946-Personalization of user account 3: part 2-Mirror dimming,OFF ,1
IDE12797-MAS05213-Personalization of user account 3: part 2-Mirror heater,OFF ,1
IDE12797-MAS06870-Personalization of user account 3: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12797-MAS06881-Personalization of user account 3: part 2-Mirror fold-in (VW),OFF ,1
IDE12798-MAS02444-Personalization of user account 4-Central locking,Individual door opening ,3
IDE12798-MAS06456-Personalization of user account 4-Autolock,On ,3
IDE12798-MAS06457-Personalization of user account 4-autounlock,On ,3
IDE12798-MAS06696-Personalization of user account 4-Comfort opening sunroof,OFF ,3
IDE12798-MAS06697-Personalization of user account 4-Acoustic acknowledge signal,On ,3
IDE12798-MAS06698-Personalization of user account 4-Freeway flashing,On ,3
IDE12798-MAS06740-Personalization of user account 4-Release button in rear lid handle locked,OFF ,3
IDE12798-MAS06756-Personalization of user account 4-Window shade automatic,OFF ,3
IDE12798-MAS06880-Personalization of user account 4-Mirror fold-in (Audi),OFF ,3
IDE12798-MAS10221-Personalization of user account 4-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12798-MAS10228-Personalization of user account 4-Comfort opening window: driver side,OFF ,3
IDE12798-MAS10229-Personalization of user account 4-Comfort opening window: frt. pass. side,OFF ,3
IDE12798-MAS10230-Personalization of user account 4-Comfort opening rear window: driver side,OFF ,3
IDE12798-MAS10231-Personalization of user account 4-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12799-IDE02262-Personalization of user account 4: part 2-synchronous mirror adjustment,OFF ,1
IDE12799-IDE03946-Personalization of user account 4: part 2-Mirror dimming,OFF ,1
IDE12799-MAS05213-Personalization of user account 4: part 2-Mirror heater,OFF ,1
IDE12799-MAS06870-Personalization of user account 4: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12799-MAS06881-Personalization of user account 4: part 2-Mirror fold-in (VW),OFF ,1
IDE12800-MAS02444-Personalization of user account 5-Central locking,Individual door opening ,3
IDE12800-MAS06456-Personalization of user account 5-Autolock,On ,3
IDE12800-MAS06457-Personalization of user account 5-autounlock,On ,3
IDE12800-MAS06696-Personalization of user account 5-Comfort opening sunroof,OFF ,3
IDE12800-MAS06697-Personalization of user account 5-Acoustic acknowledge signal,On ,3
IDE12800-MAS06698-Personalization of user account 5-Freeway flashing,On ,3
IDE12800-MAS06740-Personalization of user account 5-Release button in rear lid handle locked,OFF ,3
IDE12800-MAS06756-Personalization of user account 5-Window shade automatic,OFF ,3
IDE12800-MAS06880-Personalization of user account 5-Mirror fold-in (Audi),OFF ,3
IDE12800-MAS10221-Personalization of user account 5-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12800-MAS10228-Personalization of user account 5-Comfort opening window: driver side,OFF ,3
IDE12800-MAS10229-Personalization of user account 5-Comfort opening window: frt. pass. side,OFF ,3
IDE12800-MAS10230-Personalization of user account 5-Comfort opening rear window: driver side,OFF ,3
IDE12800-MAS10231-Personalization of user account 5-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12801-IDE02262-Personalization of user account 5: part 2-synchronous mirror adjustment,OFF ,1
IDE12801-IDE03946-Personalization of user account 5: part 2-Mirror dimming,OFF ,1
IDE12801-MAS05213-Personalization of user account 5: part 2-Mirror heater,OFF ,1
IDE12801-MAS06870-Personalization of user account 5: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12801-MAS06881-Personalization of user account 5: part 2-Mirror fold-in (VW),OFF ,1
IDE12802-MAS02444-Personalization of user account 6-Central locking,Individual door opening ,3
IDE12802-MAS06456-Personalization of user account 6-Autolock,On ,3
IDE12802-MAS06457-Personalization of user account 6-autounlock,On ,3
IDE12802-MAS06696-Personalization of user account 6-Comfort opening sunroof,OFF ,3
IDE12802-MAS06697-Personalization of user account 6-Acoustic acknowledge signal,On ,3
IDE12802-MAS06698-Personalization of user account 6-Freeway flashing,On ,3
IDE12802-MAS06740-Personalization of user account 6-Release button in rear lid handle locked,OFF ,3
IDE12802-MAS06756-Personalization of user account 6-Window shade automatic,OFF ,3
IDE12802-MAS06880-Personalization of user account 6-Mirror fold-in (Audi),OFF ,3
IDE12802-MAS10221-Personalization of user account 6-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12802-MAS10228-Personalization of user account 6-Comfort opening window: driver side,OFF ,3
IDE12802-MAS10229-Personalization of user account 6-Comfort opening window: frt. pass. side,OFF ,3
IDE12802-MAS10230-Personalization of user account 6-Comfort opening rear window: driver side,OFF ,3
IDE12802-MAS10231-Personalization of user account 6-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12803-IDE02262-Personalization of user account 6: part 2-synchronous mirror adjustment,OFF ,1
IDE12803-IDE03946-Personalization of user account 6: part 2-Mirror dimming,OFF ,1
IDE12803-MAS05213-Personalization of user account 6: part 2-Mirror heater,OFF ,1
IDE12803-MAS06870-Personalization of user account 6: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12803-MAS06881-Personalization of user account 6: part 2-Mirror fold-in (VW),OFF ,1
IDE12804-MAS02444-Personalization of user account 7-Central locking,Individual door opening ,3
IDE12804-MAS06456-Personalization of user account 7-Autolock,On ,3
IDE12804-MAS06457-Personalization of user account 7-autounlock,On ,3
IDE12804-MAS06696-Personalization of user account 7-Comfort opening sunroof,OFF ,3
IDE12804-MAS06697-Personalization of user account 7-Acoustic acknowledge signal,On ,3
IDE12804-MAS06698-Personalization of user account 7-Freeway flashing,On ,3
IDE12804-MAS06740-Personalization of user account 7-Release button in rear lid handle locked,OFF ,3
IDE12804-MAS06756-Personalization of user account 7-Window shade automatic,OFF ,3
IDE12804-MAS06880-Personalization of user account 7-Mirror fold-in (Audi),OFF ,3
IDE12804-MAS10221-Personalization of user account 7-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12804-MAS10228-Personalization of user account 7-Comfort opening window: driver side,OFF ,3
IDE12804-MAS10229-Personalization of user account 7-Comfort opening window: frt. pass. side,OFF ,3
IDE12804-MAS10230-Personalization of user account 7-Comfort opening rear window: driver side,OFF ,3
IDE12804-MAS10231-Personalization of user account 7-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12805-IDE02262-Personalization of user account 7: part 2-synchronous mirror adjustment,OFF ,1
IDE12805-IDE03946-Personalization of user account 7: part 2-Mirror dimming,OFF ,1
IDE12805-MAS05213-Personalization of user account 7: part 2-Mirror heater,OFF ,1
IDE12805-MAS06870-Personalization of user account 7: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12805-MAS06881-Personalization of user account 7: part 2-Mirror fold-in (VW),OFF ,1
IDE12808-Personalization of user account 1: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12809-Personalization of user account 2: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12810-Personalization of user account 3: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12811-Personalization of user account 4: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12812-Personalization of user account 5: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12813-Personalization of user account 6: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12814-Personalization of user account 7: name,47 61 73 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12815-MAS15187-User accounts for the NFC devices-User account of NFC device 1,0 ,8
IDE12815-MAS15188-User accounts for the NFC devices-User account of NFC device 2,0 ,8
IDE12815-MAS15189-User accounts for the NFC devices-User account of NFC device 3,0 ,8
IDE12815-MAS15190-User accounts for the NFC devices-User account of NFC device 4,0 ,8
IDE12815-MAS15191-User accounts for the NFC devices-User account of NFC device 5,0 ,8
IDE12815-MAS15192-User accounts for the NFC devices-User account of NFC device 6,0 ,8
IDE12815-MAS15193-User accounts for the NFC devices-User account of NFC device 7,0 ,8
IDE12815-MAS15194-User accounts for the NFC devices-User account of NFC device 8,0 ,8
IDE12815-MAS15195-User accounts for the NFC devices-User account of NFC device 9,0 ,8
IDE12815-MAS15196-User accounts for the NFC devices-User account of NFC device 10,0 ,8
IDE12815-MAS15197-User accounts for the NFC devices-User account of NFC device 11,0 ,8
IDE12815-MAS15198-User accounts for the NFC devices-User account of NFC device 12,0 ,8
IDE12815-MAS15199-User accounts for the NFC devices-User account of NFC device 13,0 ,8
IDE12815-MAS15200-User accounts for the NFC devices-User account of NFC device 14,0 ,8
IDE12815-MAS15201-User accounts for the NFC devices-User account of NFC device 15,0 ,8
IDE12815-MAS15202-User accounts for the NFC devices-User account of NFC device 16,0 ,8
IDE12938-MAS15390-NFC communication 2: settings-Command category for SELECT,00 ,22
IDE12938-MAS15391-NFC communication 2: settings-Command for SELECT,A4 ,22
IDE12938-MAS15392-NFC communication 2: settings-Parameter 1 for SELECT,04 ,22
IDE12938-MAS15393-NFC communication 2: settings-Parameter 2 for SELECT,00 ,22
IDE12938-MAS15394-NFC communication 2: settings-Utility data length for SELECT,10 ,22
IDE12938-MAS15395-NFC communication 2: settings-Application ID for SELECT,A0 00 00 07 02 00 00 00 00 00 00 00 01 00 00 01 ,22
IDE12938-MAS15396-NFC communication 2: settings-Expected length for SELECT,10 ,22
IDE13253-MAS16009-Convertible top convenience operation-Convenience closure with radio key,On ,2
IDE13253-MAS16010-Convertible top convenience operation-Convenience opening with lock cylinder,On ,2
IDE13253-MAS16011-Convertible top convenience operation-Convenience closing with exterior door handle touch sensor,On ,2
IDE13253-MAS16012-Convertible top convenience operation-Convenience opening with radio key,On ,2
IDE13253-MAS16013-Convertible top convenience operation-Convenient opening with lock cylinder,On ,2
IDE13254-MAS16014-Convenience opening: control points-Convenience opening of the window regulator with radio key,On ,2
IDE13254-MAS16015-Convenience opening: control points-Convenience opening of the window regulator with lock cylinder,On ,2
IDE13254-MAS16016-Convenience opening: control points-Convenience opening of the window regulator with window regulator button,On ,2
IDE13254-MAS16017-Convenience opening: control points-Convenience opening of the roof shade with the radio key,On ,2
IDE13254-MAS16018-Convenience opening: control points-Convenience opening of the roof shade with lock cylinder,On ,2
IDE13254-MAS16019-Convenience opening: control points-Convenience opening of the roof shade with window regulator button,On ,2
IDE13254-MAS16020-Convenience opening: control points-Comfort opening only for driver door,OFF ,2
IDE13254-MAS16029-Convenience opening: control points-Convenience opening of the sunroof with radio key,On ,2
IDE13254-MAS16030-Convenience opening: control points-Convenience opening of the sunroof with lock cylinder,On ,2
IDE13254-MAS16031-Convenience opening: control points-Convenience opening of the sun roof with window regulator button,On ,2
IDE13254-MAS16032-Convenience opening: control points-Convenience opening of rear sun roof with radio key,On ,2
IDE13254-MAS16033-Convenience opening: control points-Convenience opening of rear sun roof with lock cylinder,On ,2
IDE13254-MAS16034-Convenience opening: control points-Comfort opening of the rear sunroof with window regulator button,On ,2
IDE13255-MAS16021-Convenience closing: control points-Convenience closure of the window regulator with radio key,On ,2
IDE13255-MAS16022-Convenience closing: control points-Convenience closure of the window regulator with lock cylinder,On ,2
IDE13255-MAS16023-Convenience closing: control points-Convenience closure of the window regulator with window regulator button,On ,2
IDE13255-MAS16024-Convenience closing: control points-Convenience closure of window regulator with outside door handle sensor,On ,2
IDE13255-MAS16025-Convenience closing: control points-Convenience closing of the roof shade with the radio key,On ,2
IDE13255-MAS16026-Convenience closing: control points-Convenience closure of the roof shade with lock cylinder,On ,2
IDE13255-MAS16027-Convenience closing: control points-Convenience closure of the roof shade with window regulator button,On ,2
IDE13255-MAS16028-Convenience closing: control points-Convenience closure of roof shade with outside door handle,On ,2
IDE13255-MAS16035-Convenience closing: control points-Convenience closure of sun roof with radio key,On ,2
IDE13255-MAS16036-Convenience closing: control points-Convenience closing of the sunroof with lock cylinder,On ,2
IDE13255-MAS16037-Convenience closing: control points-Convenience closure of the sun roof with window regulator button,On ,2
IDE13255-MAS16038-Convenience closing: control points-Convenience closure of sunroof with outside door handle sensor,On ,2
IDE13255-MAS16039-Convenience closing: control points-Convenience closure of rear sun roof with radio key,On ,2
IDE13255-MAS16040-Convenience closing: control points-Convenience closure of rear sun roof with lock cylinder,On ,2
IDE13255-MAS16041-Convenience closing: control points-Convenience closure of the rear sun roof with window regulator button,On ,2
IDE13255-MAS16042-Convenience closing: control points-Convenience closure of rear sunroof with outside door handle sensor,On ,2
IDE14072-MAS17381-Central locking system actuation counter: configuration-Interface 1: counter 1,0 ,12
IDE14072-MAS17382-Central locking system actuation counter: configuration-Interface 2: counter 1,0 ,12
IDE14072-MAS17383-Central locking system actuation counter: configuration-Interface 3: counter 1,0 ,12
IDE14072-MAS17384-Central locking system actuation counter: configuration-Interface 1: counter 2,0 ,12
IDE14072-MAS17385-Central locking system actuation counter: configuration-Interface 2: counter 2,0 ,12
IDE14072-MAS17386-Central locking system actuation counter: configuration-Interface 3: counter 2,0 ,12
IDE14072-MAS17387-Central locking system actuation counter: configuration-Interface 1: counter 3,0 ,12
IDE14072-MAS17388-Central locking system actuation counter: configuration-Interface 2: counter 3,0 ,12
IDE14072-MAS17389-Central locking system actuation counter: configuration-Interface 3: counter 3,0 ,12
IDE14072-MAS17390-Central locking system actuation counter: configuration-Interface 1: counter 4,0 ,12
IDE14072-MAS17391-Central locking system actuation counter: configuration-Interface 2: counter 4,0 ,12
IDE14072-MAS17392-Central locking system actuation counter: configuration-Interface 3: counter 4,0 ,12
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,0 ,37
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,1 ,37
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,1 ,37
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,1 ,37
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,0 ,37
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,21 ,37
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,21 ,37
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,21 ,37
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,21 ,37
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,2 ,37
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,31 ,37
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,2 ,37
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,31 ,37
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,64 ,37
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,10 ,37
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,10 ,37
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,0 ,37
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,0 ,37
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,0 ,37
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,0 ,37
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,active ,37
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,not active ,37
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,not active ,37
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,Bottom ,37
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,Dynamic ,37
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,3 ,37
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,not active ,37
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,Dynamic ,37
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,10 ,37
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,6 ,37
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,active ,37
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,19 ,37
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,1 ,37
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,12 ,37
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,4 ,37
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,Do not reset ,37
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,16 ,37
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,16 ,37
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,16 ,37
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,16 ,37
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,2 ,37
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,31 ,37
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,2 ,37
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,31 ,37
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,224 ,37
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,10 ,37
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,10 ,37
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,0 ,37
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,0 ,37
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,0 ,37
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,0 ,37
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,6 ,37
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,25 ,37
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,255 ,37
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,5 ,37
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,60 ,37
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,181 ,37
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle type,0 ,37
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,not active ,37
ENG146368-ENG146489-central_locking_system-autolock_rear,On ,2
ENG146368-ENG146488-central_locking_system-beep_at_opening,OFF ,2
ENG146368-ENG146490-central_locking_system-global_unlocking_via_kessy_double_puls,OFF ,2
ENG146368-ENG146491-central_locking_system-unlocking_rear_via_vip_at_s_contact_active,OFF ,2
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG146414-ffb_kessy_active_for_piloted_parking,not activated ,1
ENG146373-headlamp_range_adjustment,OFF ,1
ENG146406-ENG146575-Heated_front_window_lin_relais-Off_delay,0.50 s,14
ENG146406-ENG146574-Heated_front_window_lin_relais-On_delay,0.50 s,14
ENG146406-ENG146571-Heated_front_window_lin_relais-Threshold_driver_side_off,150 W,14
ENG146406-ENG146570-Heated_front_window_lin_relais-Threshold_driver_side_on,300 W,14
ENG146406-ENG146573-Heated_front_window_lin_relais-Threshold_passenger_side_off,350 W,14
ENG146406-ENG146572-Heated_front_window_lin_relais-Threshold_passenger_side_on,500 W,14
ENG146406-ENG146576-Heated_front_window_lin_relais-Two_Relais_installed,1 ,14
ENG146400-ENG146554-Heated_rear_window_with_extension-Default_activation_time,10 min,16
ENG146400-ENG155020-Heated_rear_window_with_extension-Delay_time_deactivate_heated_rear_window,25.50 ,16
ENG146400-ENG146546-Heated_rear_window_with_extension-Interval_1,5 min,16
ENG146400-ENG146547-Heated_rear_window_with_extension-Interval_2,7 min,16
ENG146400-ENG146548-Heated_rear_window_with_extension-Interval_3,15 min,16
ENG146400-ENG146549-Heated_rear_window_with_extension-Interval_4,20 min,16
ENG146400-ENG146550-Heated_rear_window_with_extension-Renewal_interval_1,0 min,16
ENG146400-ENG146551-Heated_rear_window_with_extension-Renewal_interval_2,3 min,16
ENG146400-ENG146552-Heated_rear_window_with_extension-Renewal_interval_3,5 min,16
ENG146400-ENG146553-Heated_rear_window_with_extension-Renewal_interval_4,0 min,16
ENG146400-ENG146555-Heated_rear_window_with_extension-Speed_theshold,50 ,16
ENG146400-ENG145114-Heated_rear_window_with_extension-Temperature_1,132 ,16
ENG146400-ENG145115-Heated_rear_window_with_extension-Temperature_2,124 ,16
ENG146400-ENG146545-Heated_rear_window_with_extension-Temperature_3,116 ,16
ENG146374-hella_debug_switch,00 00 ,2
ENG146372-ENG146515-horn_settings-number_of_acoustic_acknowlagement_signals_zv_close,2 ,2
ENG146372-ENG146514-horn_settings-number_of_acoustic_acknowlagement_signals_zv_open,0 ,2
ENG153896-ENG146539-Mobile_Key-idle_time_state_S1,60 ,4
ENG153896-ENG155141-Mobile_Key-idle_time_state_S2,20 ,4
ENG153896-ENG155142-Mobile_Key-idle_time_vtan_state_S1,60 ,4
ENG153896-ENG155143-Mobile_Key-idle_time_vtan_state_S2,20 ,4
ENG146397-ENG146535-mq_ewi_activation-ewi_mode,On ,4
ENG146397-ENG146534-mq_ewi_activation-ewi_trace,On ,4
ENG146397-ENG146536-mq_ewi_activation-ewi_trace_messages,FF FF FF ,4
ENG146405-ENG146480-Personalisation_ew-Delay_Time,0.40 s,8
ENG146405-ENG146558-Personalisation_ew-FSG_Setup2_Bit1,0 ,8
ENG146405-ENG146559-Personalisation_ew-FSG_Setup2_Bit2,0 ,8
ENG146405-ENG146560-Personalisation_ew-FSG_Setup2_Bit3,1 ,8
ENG146405-ENG146561-Personalisation_ew-FSG_Setup2_Bit4,0 ,8
ENG146405-ENG146562-Personalisation_ew-FSG_Setup2_Bit5,0 ,8
ENG146405-ENG146563-Personalisation_ew-FSG_Setup2_Bit6,1 ,8
ENG146405-ENG146564-Personalisation_ew-FSG_Setup2_Bit7,1 ,8
ENG146405-ENG146569-Personalisation_ew-Minimum_display_duration,1 ,8
ENG146405-ENG146566-Personalisation_ew-Number_of_accounts,7 ,8
ENG146405-ENG146577-Personalisation_ew-Prioritization_device,0 ,8
ENG146405-ENG146567-Personalisation_ew-Time_slot_driver_door_opening,0.30 s,8
ENG146405-ENG146565-Personalisation_ew-Time_slot_key_identification,5 ,8
ENG146405-ENG146568-Personalisation_ew-Timeout_drive_active,60 ,8
ENG146375-ENG146520-pwm_levels_hl_1-pwm_high_1,255 ,3
ENG146375-ENG146521-pwm_levels_hl_1-pwm_high_2,255 ,3
ENG146375-ENG146519-pwm_levels_hl_1-pwm_low,255 ,3
ENG146384-ENG146520-pwm_levels_hl_10-pwm_high_1,255 ,3
ENG146384-ENG146521-pwm_levels_hl_10-pwm_high_2,255 ,3
ENG146384-ENG146519-pwm_levels_hl_10-pwm_low,200 ,3
ENG146385-ENG146520-pwm_levels_hl_11-pwm_high_1,200 ,3
ENG146385-ENG146521-pwm_levels_hl_11-pwm_high_2,255 ,3
ENG146385-ENG146519-pwm_levels_hl_11-pwm_low,255 ,3
ENG146386-ENG146520-pwm_levels_hl_12-pwm_high_1,255 ,3
ENG146386-ENG146521-pwm_levels_hl_12-pwm_high_2,255 ,3
ENG146386-ENG146519-pwm_levels_hl_12-pwm_low,255 ,3
ENG146387-ENG146520-pwm_levels_hl_13-pwm_high_1,200 ,3
ENG146387-ENG146521-pwm_levels_hl_13-pwm_high_2,255 ,3
ENG146387-ENG146519-pwm_levels_hl_13-pwm_low,255 ,3
ENG146388-ENG146520-pwm_levels_hl_14-pwm_high_1,255 ,3
ENG146388-ENG146521-pwm_levels_hl_14-pwm_high_2,255 ,3
ENG146388-ENG146519-pwm_levels_hl_14-pwm_low,200 ,3
ENG146389-ENG146520-pwm_levels_hl_15-pwm_high_1,200 ,3
ENG146389-ENG146521-pwm_levels_hl_15-pwm_high_2,255 ,3
ENG146389-ENG146519-pwm_levels_hl_15-pwm_low,255 ,3
ENG146390-ENG146520-pwm_levels_hl_16-pwm_high_1,255 ,3
ENG146390-ENG146521-pwm_levels_hl_16-pwm_high_2,255 ,3
ENG146390-ENG146519-pwm_levels_hl_16-pwm_low,255 ,3
ENG146391-ENG146520-pwm_levels_hl_17-pwm_high_1,200 ,3
ENG146391-ENG146521-pwm_levels_hl_17-pwm_high_2,255 ,3
ENG146391-ENG146519-pwm_levels_hl_17-pwm_low,255 ,3
ENG146392-ENG146520-pwm_levels_hl_18-pwm_high_1,255 ,3
ENG146392-ENG146521-pwm_levels_hl_18-pwm_high_2,255 ,3
ENG146392-ENG146519-pwm_levels_hl_18-pwm_low,255 ,3
ENG146393-ENG146520-pwm_levels_hl_19-pwm_high_1,255 ,3
ENG146393-ENG146521-pwm_levels_hl_19-pwm_high_2,255 ,3
ENG146393-ENG146519-pwm_levels_hl_19-pwm_low,255 ,3
ENG146376-ENG146520-pwm_levels_hl_2-pwm_high_1,200 ,3
ENG146376-ENG146521-pwm_levels_hl_2-pwm_high_2,255 ,3
ENG146376-ENG146519-pwm_levels_hl_2-pwm_low,255 ,3
ENG146394-ENG146520-pwm_levels_hl_20-pwm_high_1,255 ,3
ENG146394-ENG146521-pwm_levels_hl_20-pwm_high_2,255 ,3
ENG146394-ENG146519-pwm_levels_hl_20-pwm_low,255 ,3
ENG146395-ENG146520-pwm_levels_hl_21-pwm_high_1,255 ,3
ENG146395-ENG146521-pwm_levels_hl_21-pwm_high_2,255 ,3
ENG146395-ENG146519-pwm_levels_hl_21-pwm_low,255 ,3
ENG146377-ENG146520-pwm_levels_hl_3-pwm_high_1,255 ,3
ENG146377-ENG146521-pwm_levels_hl_3-pwm_high_2,255 ,3
ENG146377-ENG146519-pwm_levels_hl_3-pwm_low,200 ,3
ENG146378-ENG146520-pwm_levels_hl_4-pwm_high_1,255 ,3
ENG146378-ENG146521-pwm_levels_hl_4-pwm_high_2,255 ,3
ENG146378-ENG146519-pwm_levels_hl_4-pwm_low,200 ,3
ENG146379-ENG146520-pwm_levels_hl_5-pwm_high_1,200 ,3
ENG146379-ENG146521-pwm_levels_hl_5-pwm_high_2,255 ,3
ENG146379-ENG146519-pwm_levels_hl_5-pwm_low,255 ,3
ENG146380-ENG146520-pwm_levels_hl_6-pwm_high_1,200 ,3
ENG146380-ENG146521-pwm_levels_hl_6-pwm_high_2,255 ,3
ENG146380-ENG146519-pwm_levels_hl_6-pwm_low,255 ,3
ENG146381-ENG146520-pwm_levels_hl_7-pwm_high_1,200 ,3
ENG146381-ENG146521-pwm_levels_hl_7-pwm_high_2,255 ,3
ENG146381-ENG146519-pwm_levels_hl_7-pwm_low,255 ,3
ENG146382-ENG146520-pwm_levels_hl_8-pwm_high_1,255 ,3
ENG146382-ENG146521-pwm_levels_hl_8-pwm_high_2,255 ,3
ENG146382-ENG146519-pwm_levels_hl_8-pwm_low,255 ,3
ENG146383-ENG146520-pwm_levels_hl_9-pwm_high_1,200 ,3
ENG146383-ENG146521-pwm_levels_hl_9-pwm_high_2,255 ,3
ENG146383-ENG146519-pwm_levels_hl_9-pwm_low,255 ,3
ENG146399-ENG146543-remote_functions-idle_time_bap_remote_beep,500 ,8
ENG146399-ENG146544-remote_functions-idle_time_state_S0,1 ,8
ENG146399-ENG146539-remote_functions-idle_time_state_S1,60 ,8
ENG146399-ENG146540-remote_functions-idle_time_state_S3,2000 ,8
ENG146399-ENG146537-remote_functions-Rear_lid_handle_release_button_activation_time,15 ,8
ENG146399-ENG146538-remote_functions-Rear_lid_handle_release_button_active,active ,8
ENG146399-ENG146541-remote_functions-remote_beep_activation_time_high,100 ,8
ENG146399-ENG146542-remote_functions-remote_beep_activation_time_low,900 ,8
ENG146403-ENG114991-RF_adjustment-channel_1,50 ,3
ENG146403-ENG114992-RF_adjustment-channel_2,52 ,3
ENG146403-ENG114993-RF_adjustment-channel_3,50 ,3
ENG146402-ENG114991-RF_calibration-channel_1,FF FF FF ,9
ENG146402-ENG114992-RF_calibration-channel_2,FF FF FF ,9
ENG146402-ENG114993-RF_calibration-channel_3,FF FF FF ,9
ENG129054-ENG144985-SERVICE_KEY-debounce_kilometer,15 km,9
ENG129054-ENG144693-SERVICE_KEY-Distance,20 km,9
ENG129054-ENG144983-SERVICE_KEY-hazard_warning_switch_delay_time,10 s,9
ENG129054-ENG144980-SERVICE_KEY-retry_request_obdc,3 ,9
ENG129054-ENG144979-SERVICE_KEY-timeout_request_obdc,30 s,9
ENG129054-ENG146532-SERVICE_KEY-write_cycles_per_key_and_day,20 ,9
ENG129054-ENG144984-SERVICE_KEY-write_data_delay_time,40 s,9
ENG129054-ENG144982-SERVICE_KEY-write_delay_speed,20 km/h,9
ENG129054-ENG144981-SERVICE_KEY-write_delay_time,20 s,9
ENG146371-ENG146510-sounder_settings-beeptime,10_ms ,2
ENG146371-ENG146511-sounder_settings-beeptime_closing_central_locking,single_beep ,2
ENG146371-ENG146513-sounder_settings-beeptime_opening_central_locking,no_beep ,2
ENG146371-ENG146512-sounder_settings-sounder_sound,frequency_modulated ,2
ENG146364-ENG146516-Terminal_Control-deactivation_time_kl15,30 min,3
ENG146364-ENG146517-Terminal_Control-delay_time_leave_concept,200 ms,3
ENG146398-wiping_indicator,00010111  ,1
ENG146401-Write_key_content,17 00 01 0A 28 14 0F 14 FF 05 00 0A 32 FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,98
Elapsed Time: 01:21
Address [47]
blockmap-47-8W0-035-465
;SW:8W0-035-465   HW:8W0-035-465 ---  Sound System
;Component:MIB2_amp_P_B9 H11 0420, Coding:0194010800AFAAAFAA0000010000
;EV_AMPMst16C2Gen2ALPI,001012,EV_AMPMst16C2Gen2ALPI.rod
;Sunday,10,November,2019,20:41:04:01617
;VCID: F6AFE59E49C1ECFF0D-80A2
Group,Description,Actual
IDE00019,Voltage terminal 30,13.2, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,802.00, /min
IDE00075,Vehicle speed,0.00, km/h
IDE00323,Security Access: Number of invalid keys,0,
IDE00668-MAS03231,Microphone current consumption-Microphone 1,2.90, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,0, counts
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,On,
IDE01715,Status terminal S,On,
IDE01716,Terminal 50 status,OFF,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,No,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,Yes,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,47,
IDE03880-MAS03425,MOST address-Physical address,04 02,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,51, min
IDE04317-MAS00108,Total system run time-Day,34, d
IDE04317-MAS00109,Total system run time-Hours,9, H
IDE04317-MAS00110,Total system run time-Minutes,47, min
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,No,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,Yes,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04649-MAS01968,Activation for housing fan-Fan,OFF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,Mute,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,Mute,
IDE05704-MAS02646,Digital Transmission Content Protection (DTCP) key-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,2,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,60,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE06055,Invalid authentication (DTCP),5F,
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,76, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-2, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Current,62, °C
IDE09935-MAS01424,Temperature of inductor-max.value,92, °C
IDE09935-MAS01425,Temperature of inductor-min.value,-4, °C
IDE09935-MAS02238,Temperature of inductor-Current,66, °C
IDE10498,Noise level adjust. depending on static noise: status,0.0,
IDE10545-MAS01188,Speaker status-Left front bass speaker,Condition not met,
IDE10545-MAS01189,Speaker status-Left Front Midrange Speaker,Condition not met,
IDE10545-MAS01191,Speaker status-Right front bass speaker,Condition not met,
IDE10545-MAS01192,Speaker status-Right Front Midrange Speaker,Condition not met,
IDE10545-MAS01194,Speaker status-Left rear bass speaker,Condition not met,
IDE10545-MAS01196,Speaker status-Right rear bass speaker,Condition not met,
IDE10545-MAS01198,Speaker status-Center speaker,Condition not met,
IDE10545-MAS01199,Speaker status-Left effect speaker,Condition not met,
IDE10545-MAS01200,Speaker status-Right effect speaker,Condition not met,
IDE10545-MAS04506,Speaker status-Double subwoofer speaker 1,Condition not met,
IDE10545-MAS04507,Speaker status-Double subwoofer speaker 2,Condition not met,
IDE10545-MAS06561,Speaker status-Left front treble speaker 2,Condition not met,
IDE10545-MAS06562,Speaker status-Right front treble speaker 2,Condition not met,
IDE10545-MAS11754,Speaker status-Center speaker 2,Condition not met,
IDE10545-MAS11755,Speaker status-Left front midrange speaker 2,Condition not met,
IDE10545-MAS11756,Speaker status-Right front midrange speaker 2,Condition not met,
IDE10545-ENG126180,Speaker status-loudspeaker_channel_17,Measured value not available,
IDE10545-ENG126181,Speaker status-loudspeaker_channel_18,Measured value not available,
IDE10545-ENG126182,Speaker status-loudspeaker_channel_19,Measured value not available,
IDE10545-ENG126183,Speaker status-loudspeaker_channel_20,Measured value not available,
IDE10545-ENG126184,Speaker status-loudspeaker_channel_21,Measured value not available,
IDE10545-ENG126185,Speaker status-loudspeaker_channel_22,Measured value not available,
IDE10545-ENG126186,Speaker status-loudspeaker_channel_23,Measured value not available,
IDE10545-ENG126187,Speaker status-loudspeaker_channel_24,Measured value not available,
IDE10657-MAS01424,Temperature switching power supply-max.value,94, °C
IDE10657-MAS01425,Temperature switching power supply-min.value,-3, °C
IDE10657-MAS02238,Temperature switching power supply-Current,68, °C
IDE10659-MAS01424,Temperature switching power supply 2-max.value,75, °C
IDE10659-MAS01425,Temperature switching power supply 2-min.value,3, °C
IDE10659-MAS02238,Temperature switching power supply 2-Current,69, °C
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,11,
MAS00464-MAS00108,Standard - ambient data 1-Day,10,
MAS00464-MAS00109,Standard - ambient data 1-Hours,20,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,41,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,9,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,114,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,32501, km
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,1, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,1, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,19, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,11, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,10, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,19, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,50, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,4, s
Elapsed Time: 00:07
adpmap-47-8W0-035-465
;Sunday,10,November,2019,20:41:12:01617
IDE10493-MAS03001-Electrical test 2 of loudspeakers-Mode,automatic ,73
IDE10493-ENG117360-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,73
IDE10493-ENG117361-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,60 ,73
IDE10493-ENG117378-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,73
IDE10493-ENG117379-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,60 ,73
IDE10493-ENG117380-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,73
IDE10493-ENG117381-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,60 ,73
IDE10493-ENG117382-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,73
IDE10493-ENG117383-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,60 ,73
IDE10493-ENG117384-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,73
IDE10493-ENG117385-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,60 ,73
IDE10493-ENG117386-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,73
IDE10493-ENG117387-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,60 ,73
IDE10493-ENG117388-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,73
IDE10493-ENG117389-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,60 ,73
IDE10493-ENG117390-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,73
IDE10493-ENG117391-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,60 ,73
IDE10493-ENG126164-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,73
IDE10493-ENG126165-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,60 ,73
IDE10493-ENG126166-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,73
IDE10493-ENG126167-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,60 ,73
IDE10493-ENG126168-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,73
IDE10493-ENG126169-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,60 ,73
IDE10493-ENG117362-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,73
IDE10493-ENG117363-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,60 ,73
IDE10493-ENG126170-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,73
IDE10493-ENG126171-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,60 ,73
IDE10493-ENG126172-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,73
IDE10493-ENG126173-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,60 ,73
IDE10493-ENG126174-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,73
IDE10493-ENG126175-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,60 ,73
IDE10493-ENG126176-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,73
IDE10493-ENG126177-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,60 ,73
IDE10493-ENG126178-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,73
IDE10493-ENG126179-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,60 ,73
IDE10493-ENG117364-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,73
IDE10493-ENG117365-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,60 ,73
IDE10493-ENG117366-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,73
IDE10493-ENG117367-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,60 ,73
IDE10493-ENG117368-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,73
IDE10493-ENG117369-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,60 ,73
IDE10493-ENG117370-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,73
IDE10493-ENG117371-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,60 ,73
IDE10493-ENG117372-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,73
IDE10493-ENG117373-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,60 ,73
IDE10493-ENG117374-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,73
IDE10493-ENG117375-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,60 ,73
IDE10493-ENG117376-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,73
IDE10493-ENG117377-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,60 ,73
Elapsed Time: 00:02
Address [52]
blockmap-52-4M0-959-792-H
;SW:4M0-959-792-H   HW:4M0-959-792-F ---  Door Elect, Pass.
;Component:TSG BFS       005 0129, Coding:005F1B205E001080000100B0
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_AU49.rod
;Sunday,10,November,2019,20:41:16:01617
;VCID: C2C7494E5589005F71-8096
IDE00030,Status of actuator test,not active,
IDE00310,Outside air temperature,27.50, °C
IDE00322,Status of basic setting,was not yet started,
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Frt.pass. side door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear passenger side door control module,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,13.20, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,Sleep mode,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Busmaster,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,54, %
IDE04539-MAS02229,Mirror memory-Y coordinate,43, %
IDE04539-MAS02476,Mirror memory-install,installed,
IDE04540,Mirror adjustment (X/Y-direction),not installed,
IDE04580,Dimming of inside door handle lighting,58, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05725,Terminal 58xs dimmer,58, %
IDE05726,Terminal 58xd dimmer,2, %
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not activated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: released,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06872,Front passenger power window button,not activated,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,73.00, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,35, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10164-MAS01632,automatic day/night exterior mirror-Status,not active,
IDE10164-MAS03691,automatic day/night exterior mirror-Dimming,0, %
MAS02099,Switch for inside door handle,not installed,
MAS02100,Switch for outside door handle,not installed,
MAS06010,Ambient light,100, %
Elapsed Time: 00:06
adpmap-52-4M0-959-792-H
;Sunday,10,November,2019,20:41:23:01617
IDE00001-MAS10864-Production mode-Reduce reverse threshold,Deactivating ,3
IDE00001-MAS10865-Production mode-Power windows operable with terminal 15 off,Deactivating ,3
IDE00001-MAS10866-Production mode-Reduce switch-on time of lighting,Deactivating ,3
IDE00001-MAS10867-Production mode-Deactivate speed control for power windows,Deactivating ,3
IDE00001-MAS10868-Production mode-Deactivate closing aid,Deactivating ,3
IDE00001-MAS10869-Production mode-Activate test mode for the fold-in mirror,Deactivating ,3
IDE00001-MAS10870-Production mode-Activate test mode for power windows,Deactivating ,3
IDE00001-MAS17286-Production mode-Deactivation of actuation of opening assistance motor: e-lock,Deactivating ,3
IDE00001-MAS17291-Production mode-Deactivation of CarWakeUp due to activation of seatbelt feeder,Deactivating ,3
ENG117298-Reversing_Threshold_Passenger_Side_Front,90 %,1
Elapsed Time: 00:03
Address [5F]
blockmap-5F-8W5-035-880-B
;SW:8W5-035-880-B   HW:8W5-035-880 ---  Information Electr.
;Component:MU-P-LNS-US   034 1178, Coding:019401020000000053220002041A00102F0002E501700904FE
;EV_MUHig6C3Gen2HBAS,001115,EV_MUHig6C3Gen2HBAS_AU37.rod
;Sunday,10,November,2019,20:41:29:01617
;VCID: BE3F3DBE217164BF15-80EA
IDE00021,Engine speed,800.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,69, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,3, °C
IDE00655-MAS02238,Temperature of processor circuit board-Current,53, °C
IDE00668-MAS03231,Microphone current consumption-Microphone 1,5.60, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,5.00, mA
IDE00767,No. of unscheduled ECU resets,1, counts
IDE00916-IDE02127,Speaker status-Left front speaker,Measured value not available,
IDE00916-IDE02128,Speaker status-Right front speaker,Measured value not available,
IDE00916-IDE02129,Speaker status-Left rear speaker,Measured value not available,
IDE00916-IDE02130,Speaker status-Right rear speaker,Measured value not available,
IDE00916-MAS01198,Speaker status-Center speaker,Measured value not available,
IDE00916-MAS01201,Speaker status-Subwoofer speaker,Measured value not available,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
IDE01442-MAS06123,Pressing a button-Eject button,not activated,
IDE01712-MAS01779,GPS Position-Length,81 42'33.5"W,
IDE01712-MAS01780,GPS Position-Width,26 14'43.8"N,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,12,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,11,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,57, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,27, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,43, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,28, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,Electrical OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,255, mA
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,Not available,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,not installed,
IDE01992-ENG20557,Installation list: current installations-ECU present Bit 0 Main_Unit,installed,
IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,not installed,
IDE01992-ENG20556,Installation list: current installations-ECU present Bit 1 reserved,not installed,
IDE01992-ENG20933,Installation list: current installations-ECU present Bit 10 SmartControlCarrier2,not installed,
IDE01992-ENG20932,Installation list: current installations-ECU present Bit 11 WirelessCharger1,not installed,
IDE01992-ENG20931,Installation list: current installations-ECU present Bit 12 WirelessCharger2,not installed,
IDE01992-ENG20930,Installation list: current installations-ECU present Bit 13 Multimedia Operating Unit,not installed,
IDE01992-ENG20929,Installation list: current installations-ECU present Bit 14 Head-up Display,not installed,
IDE01992-ENG20950,Installation list: current installations-ECU present Bit 15,not installed,
IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,not installed,
IDE01992-ENG20555,Installation list: current installations-ECU present Bit 2 Sound_System,installed,
IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,not installed,
IDE01992-ENG20554,Installation list: current installations-ECU present Bit 3 TV_Tuner,not installed,
IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,not installed,
IDE01992-ENG20553,Installation list: current installations-ECU present Bit 4 DVD_Changer,not installed,
IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,not installed,
IDE01992-ENG20552,Installation list: current installations-ECU present Bit 5 RearSeatEntertainment,not installed,
IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,not installed,
IDE01992-ENG20919,Installation list: current installations-ECU present Bit 6 MOST Kombi-Display,installed,
IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,not installed,
IDE01992-ENG20918,Installation list: current installations-ECU present Bit 7 SmartDisplayCarrier1,not installed,
IDE01992-ENG20935,Installation list: current installations-ECU present Bit 8 SmartDisplayCarrier2,not installed,
IDE01992-ENG20934,Installation list: current installations-ECU present Bit 9 SmartControlCarrier1,not installed,
IDE01995-ENG16990,Control module protocol information-Ethernet,No,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,255, mA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,35.5, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,27,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,26,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,23,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,16,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,48, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,48, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,47, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,43, dBµV
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG20563,Status of event memory-ECU Dtc Bit 0 Main_Unit,OK,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG20562,Status of event memory-ECU Dtc Bit 1 reserved,OK,
IDE02384-ENG20924,Status of event memory-ECU Dtc Bit 10 SmartControlCarrier2,OK,
IDE02384-ENG20923,Status of event memory-ECU Dtc Bit 11 WirelessCharger1,OK,
IDE02384-ENG20922,Status of event memory-ECU Dtc Bit 12 WirelessCharger2,OK,
IDE02384-ENG20921,Status of event memory-ECU Dtc Bit 13 Multimedia Operating Unit,OK,
IDE02384-ENG20920,Status of event memory-ECU Dtc Bit 14 Head-up Display,OK,
IDE02384-ENG20949,Status of event memory-ECU Dtc Bit 15,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG20561,Status of event memory-ECU Dtc Bit 2 Sound_System,OK,
IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG20560,Status of event memory-ECU Dtc Bit 3 TV_Tuner,OK,
IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG20559,Status of event memory-ECU Dtc Bit 4 DVD_Changer,OK,
IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG20558,Status of event memory-ECU Dtc Bit 5 Rear_Seat_Entertainment,OK,
IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG20945,Status of event memory-ECU Dtc Bit 6 MOST Kombi-Display,OK,
IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
IDE02384-ENG20944,Status of event memory-ECU Dtc Bit 7 SmartDisplayCarrier1,OK,
IDE02384-ENG20926,Status of event memory-ECU Dtc Bit 8 SmartDisplayCarrier2,OK,
IDE02384-ENG20925,Status of event memory-ECU Dtc Bit 9 SmartControlCarrier1,OK,
IDE02452-IDE02451,Satellite radio tuner status-Satellite radio antenna status,Electrical OK,
IDE02452-IDE02453,Satellite radio tuner status-Channel selection for satellite radio,114,
IDE02452-MAS01765,Satellite radio tuner status-Audio Signal,Available,
IDE02452-MAS01808,Satellite radio tuner status-Antenna current,136, mA
IDE02452-MAS02573,Satellite radio tuner status-Reception quality,optimum_signal,
IDE02452-MAS13343,Satellite radio tuner status-Satellite radio tuner: pre-activation status,05,
IDE02452-MAS13344,Satellite radio tuner status-Satellite radio tuner: pre-activation value,05,
IDE02486,Data logger triggering,not active,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE02766,Malfunction status,FF FB,
IDE03150-ENG16256,Readiness for bus sleep mode-Sleep Bit 0,Sleep mode,
IDE03150-ENG20569,Readiness for bus sleep mode-Sleep Bit 0 Main_Unit,End busstat,
IDE03150-ENG45492,Readiness for bus sleep mode-Sleep Bit 1,Sleep mode,
IDE03150-ENG20568,Readiness for bus sleep mode-Sleep Bit 1 reserved,Sleep mode,
IDE03150-ENG20941,Readiness for bus sleep mode-Sleep Bit 10 SmartControlCarrier2,Sleep mode,
IDE03150-ENG20940,Readiness for bus sleep mode-Sleep Bit 11 WirelessCharger1,Sleep mode,
IDE03150-ENG20939,Readiness for bus sleep mode-Sleep Bit 12 WirelessCharger2,Sleep mode,
IDE03150-ENG20938,Readiness for bus sleep mode-Sleep Bit 13 Bedienteil vorne,Sleep mode,
IDE03150-ENG20937,Readiness for bus sleep mode-Sleep Bit 14 Head-up Display,Sleep mode,
IDE03150-ENG20936,Readiness for bus sleep mode-Sleep Bit 15,Sleep mode,
IDE03150-ENG45491,Readiness for bus sleep mode-Sleep Bit 2,Sleep mode,
IDE03150-ENG20567,Readiness for bus sleep mode-Sleep Bit 2 Sound_System,End busstat,
IDE03150-ENG45490,Readiness for bus sleep mode-Sleep Bit 3,Sleep mode,
IDE03150-ENG20566,Readiness for bus sleep mode-Sleep Bit 3 TV_Tuner,Sleep mode,
IDE03150-ENG45489,Readiness for bus sleep mode-Sleep Bit 4,Sleep mode,
IDE03150-ENG20565,Readiness for bus sleep mode-Sleep Bit 4 DVD_Changer,Sleep mode,
IDE03150-ENG45488,Readiness for bus sleep mode-Sleep Bit 5,Sleep mode,
IDE03150-ENG20564,Readiness for bus sleep mode-Sleep Bit 5 RearSeatEntertainment,Sleep mode,
IDE03150-ENG21675,Readiness for bus sleep mode-Sleep Bit 6,Sleep mode,
IDE03150-ENG20928,Readiness for bus sleep mode-Sleep Bit 6 MOST Kombi-Display,End busstat,
IDE03150-ENG16255,Readiness for bus sleep mode-Sleep Bit 7,Sleep mode,
IDE03150-ENG20927,Readiness for bus sleep mode-Sleep Bit 7 SmartDisplayCarrier1,Sleep mode,
IDE03150-ENG20943,Readiness for bus sleep mode-Sleep Bit 8 SmartDisplayCarrier2,Sleep mode,
IDE03150-ENG20942,Readiness for bus sleep mode-Sleep Bit 9 SmartControlCarrier1,Sleep mode,
IDE03477-MAS00106,GPS time-Year,2019,
IDE03477-MAS00107,GPS time-Month,11,
IDE03477-MAS00108,GPS time-Day,11,
IDE03477-MAS00109,GPS time-Hours,1,
IDE03477-MAS00110,GPS time-Minutes,41,
IDE03477-MAS00111,GPS time-Seconds,37,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,5F,
IDE03880-MAS03425,MOST address-Physical address,04 00,
IDE04317-MAS00108,Total system run time-Day,38, d
IDE04317-MAS00109,Total system run time-Hours,22, H
IDE04317-MAS00110,Total system run time-Minutes,11, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 06 09 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04334-MAS02643,Public key for SWaP function-Key,9A 49 9B 04 8B AE BF AC 83 3F DE 81 BA 80 30 93 05 B6 6F ED 54 59 C3 8F 60 F6 10 A9 AA 5A 19 10 05 17 05 8F EA 49 D3 75 E3 F9 E1 54 4E 17 EE C9 C3 C1 DD 7D 30 16 DE B1 55 45 FD 9E 18 00 51 22 D6 A1 33 10 95 C0 DD CF 43 A1 C2 FE C0 BC AA 1C FE 48 49 25 89 9E DD 71 B0 D4 08 CF 16 BF 10 E2 E1 BC 70 A3 52 F2 E6 54 0B 60 05 5A A7 52 EC 4A 83 65 F7 68 19 66 F4 D5 46 C7 38 B1 6B 5A 1F 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-ENG20542,Bus identification-Bus Identifier,Busmaster,
IDE04484,Regional codes,FE FF,
IDE04484,Regional codes,Not available,
IDE04484-MAS01632,Regional codes-Status,not active,
IDE04484-MAS03230,Regional codes-Optical drive,0,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04542-MAS03621,Status of active media source at output 2-Video codec,--------------------,
IDE04542-MAS03622,Status of active media source at output 2-Horizontal video resolution,65535,
IDE04542-MAS03623,Status of active media source at output 2-Vertical video resolution,65535,
IDE04542-MAS03778,Status of active media source at output 2-Active media source,Not available,
IDE04542-MAS03783,Status of active media source at output 2-Video Bitrate,65535, kbps
IDE04542-MAS03784,Status of active media source at output 2-Audio Bitrate,Not available,
IDE04542-MAS03785,Status of active media source at output 2-Digital rights management (DRM),Not available,
IDE04542-MAS03786,Status of active media source at output 2-Audio Codec,--------------------,
IDE04542-MAS03787,Status of active media source at output 2-Image format,--------------------,
IDE04542-MAS03788,Status of active media source at output 2-Horizontal image resolution,65535,
IDE04542-MAS03789,Status of active media source at output 2-Vertical image resolution,65535,
IDE04542-MAS03793,Status of active media source at output 2-Color depth,65535, bit
IDE04543-MAS00866,Authorization level for protection of minors-system origin,0,
IDE04543-MAS03778,Authorization level for protection of minors-Active media source,255,
IDE04544,Media type in optical drive,Not available,
IDE04545-IDE01588,Vehicle state-Driving direction,Measured value not available,
IDE04545-IDE01714,Vehicle state-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle state-Distance impulses,0,
IDE04545-IDE03684,Vehicle state-Vehicle stopped,Yes,
IDE04546-IDE00301,Navigation calibration-Distance,0.000, mm
IDE04546-MAS03647,Navigation calibration-Calibration condition,complete,
IDE04547,Traffic information,OFF,
IDE04605-MAS01779,Navigation: Corrected position-Length,081°42'35,3"W ,
IDE04605-MAS01780,Navigation: Corrected position-Width,026°14'43,7"N ,
IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,0.0, °/s
IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,20.08, m/s²
IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,20.08, m/s²
IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,20.08, m/s²
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04750-MAS03876,SIM cards-active SIM card,internal SIM-card,
IDE04750-MAS03877,SIM cards-SIM ID,890117022720843,
IDE04750-MAS03878,SIM cards-SIM IMSI,310170208432164,
IDE04750-MAS13882,SIM cards-SIM card in main unit: status,Not available,
IDE04750-MAS13883,SIM cards-SIM card in handset1 for telephone: status,Not available,
IDE04750-MAS13884,SIM cards-SIM card in handset 2 for telephone: status,Not available,
IDE04750-MAS13885,SIM cards-SIM card in mobile telephone: status,Not available,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth device address,2C DC AD 44 26 A2,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05277-MAS04210,Available changes in regional codes-Available changes DVD,4,
IDE05277-MAS04211,Available changes in regional codes-Available changes Blue-Ray,4,
IDE05277-MAS04285,Available changes in regional codes-Regional codes DVD,1,
IDE05277-MAS04286,Available changes in regional codes-Regional codes Blue-Ray,1,
IDE05430,Telephone serial number,354128064908032,
IDE05432-IDE07365,Mechanics of display unit 1 for multimedia system-Limit switch for display open,not activated,
IDE05432-IDE07366,Mechanics of display unit 1 for multimedia system-Limit switch for display close,not activated,
IDE05432-MAS01458,Mechanics of display unit 1 for multimedia system-Operating condition,not defined,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2127,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,15,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,0,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,31,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,63,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,63,
IDE05596-MAS00106,Last time GPS position outside map-Year,2019,
IDE05596-MAS00107,Last time GPS position outside map-Month,9,
IDE05596-MAS00108,Last time GPS position outside map-Day,30,
IDE05596-MAS00109,Last time GPS position outside map-Hours,18,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,36,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,4,
IDE05597-IDE03615,Bluetooth: Paired device 1-Version,Qˆ_¶¡XT1254------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,5C 51 88 5F B6 A1,
IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,Qˆ_¶¡XT1254------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),5C 51,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),5C 51,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,Qˆ_¶¡XT1254------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,XT1254
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,5C 51,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,5C 51,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,5C 51,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,5C 51,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,5C 51,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,5C 51,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,5C 51,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,5C 51,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,5C 51,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,5C 51,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,5C 51,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,5C 51,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,5C 51,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,5C 51,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,5C 51,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,5C 51,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,5C 51,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,00 00 00 00 00 00,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,--
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),00 00,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),00 00,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,--
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,--
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,00 00,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,00 00,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,00 00,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,00 00,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,00 00,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,00 00,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,00 00,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,00 00,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,00 00,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,00 00,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,00 00,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,00 00,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,00 00,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,00 00,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,00 00,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,00 00,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,00 00,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,--
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,00 00 00 00 00 00,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,--
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,0,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05726,Terminal 58xd dimmer,22.91, %
IDE05814,Individualization characteristic,1B 8D 3A 84 41,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06516-MAS01424,Temperature: optical drive-max.value,58, °C
IDE06516-MAS01425,Temperature: optical drive-min.value,2, °C
IDE06516-MAS02238,Temperature: optical drive-Current,42, °C
IDE06517-MAS01424,Temperature: audio amplifier-max.value,70, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,2, °C
IDE06517-MAS02238,Temperature: audio amplifier-Current,42, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,63, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-3, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Current,47, °C
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,73, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,9, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Current,50, °C
IDE06522-MAS01424,Temperature of phone unit-max.value,62, °C
IDE06522-MAS01425,Temperature of phone unit-min.value,8, °C
IDE06522-MAS02238,Temperature of phone unit-Current,38, °C
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07364,GPS receiver status,GPS data available,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE08530-MAS00106,Connection status online basic services-Year,2019.0, yr
IDE08530-MAS00107,Connection status online basic services-Month,11, mon
IDE08530-MAS00108,Connection status online basic services-Day,11, d
IDE08530-MAS00109,Connection status online basic services-Hours,0, H
IDE08530-MAS00110,Connection status online basic services-Minutes,52, min
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,200,
IDE08530-ENG20907,Connection status online basic services-Server_HTTP_Status_Code_Textual,not defined,
IDE08531-MAS00106,Connection status online license services-Year,2019.0, yr
IDE08531-MAS00107,Connection status online license services-Month,11, mon
IDE08531-MAS00108,Connection status online license services-Day,11, d
IDE08531-MAS00109,Connection status online license services-Hours,1, H
IDE08531-MAS00110,Connection status online license services-Minutes,18, min
IDE08531-MAS07132,Connection status online license services-Code status,8200,
IDE08531-MAS07134,Connection status online license services-ID services,86,
IDE08531-MAS07135,Connection status online license services-Activation status,Not available,
IDE08531-MAS07136,Connection status online license services-Exp. year,0, yr
IDE08531-MAS07137,Connection status online license services-Exp. month,0, mon
IDE08531-MAS07138,Connection status online license services-Exp. day,0, d
IDE08531-ENG20907,Connection status online license services-Server_HTTP_Status_Code_Textual,not defined,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,Electrical OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,255, mA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,35.5, %
IDE10200-MAS01482,Identification of volume control-Hardwareversion,H21,
IDE10200-MAS01483,Identification of volume control-Softwareversion,0108,
IDE10200-MAS09952,Identification of volume control-Part Number,8W1919616  ,
IDE10201-MAS01482,Identification of control unit for driving and comfort funct.-Hardwareversion,,
IDE10201-MAS01483,Identification of control unit for driving and comfort funct.-Softwareversion,,
IDE10201-MAS09952,Identification of control unit for driving and comfort funct.-Part Number,,
IDE10412,Media status in optical drive,Empty,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10600-MAS01159,Status of the navigation database-Version number,00 1A,
IDE10600-MAS01632,Status of the navigation database-Status,valid,
IDE10600-MAS10892,Status of the navigation database-Country Code,00 01,
IDE10600-MAS10893,Status of the navigation database-Region Code,F0,
IDE10669-MAS11003,Internal SIM card: identification-ICCID,89011702272084321642,
IDE10669-MAS11004,Internal SIM card: identification-UICCID,74000036533459140512176BBD931A--,
IDE10843-MAS01482,Function module: identification-Hardwareversion,11,
IDE10843-MAS04326,Function module: identification-Device name,AMP16bAPN                        ,
IDE10843-MAS11354,Function module: identification-Bootloader version,420,
IDE10843-MAS11355,Function module: identification-Application version,420,
IDE10843-MAS11356,Function module: identification-Module Name,AMP16bAPPL                       ,
IDE10857-MAS02476,Touchless loading of mobile phone: status-install,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-charge,No,
IDE10926-MAS00318,Function module: status-activated,Yes,
IDE10926-MAS00791,Function module: status-installed,Yes,
IDE10926-MAS11356,Function module: status-Module Name,Navigation,
IDE10926-MAS11749,Function module: status-Function and diagnosis readiness,Yes,
IDE11034-MAS01482,Satellite radio: module information-Hardwareversion,x01-00-01,
IDE11034-MAS11961,Satellite radio: module information-Serial number,9964LA4E,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 CE 00 39 39 36 34 4C 41 34 45 00 02 98 05 8A 38 64 68 F5 31 71 89 CD BF 18 05 86 7F 26 A1 0A FC B7 F2 75 12 03 41 00 66 03 41 00 07 00 66 00 07,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,x0b-24-00,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,x01-22-13,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,x03-04-02,
IDE11034-MAS11966,Satellite radio: module information-Database Version,C0a00-F0400,
IDE11504-ENG127677,Satellite radio tuner: pre-activated subscription-SDARS_preactivation_coding status,Yes,
IDE13417-MAS02646,Key (DTCP): MMX-Key type,License key (DTLA),
IDE13516-MAS01159,Device certificate (DTCP): MMX-Version number,0,
IDE13516-MAS01779,Device certificate (DTCP): MMX-Length,0,
IDE13516-MAS06742,Device certificate (DTCP): MMX-Certificate type,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,42,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,5,
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia display unit 1-System status,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,820, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,40, min
MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,13.2, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,80, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,39, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,9, %
MAS00837-MAS01632,Telephone Transceiver-Status,Not blocked,
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,1,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,105.9, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,27, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,29, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,0,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,1,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,48, dBµV
MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
MAS01991-IDE01001,Card reader-Application,--,
MAS01991-MAS01632,Card reader-Status,not connected,
MAS01991-MAS03159,Card reader-Manufacturer,FF,
MAS01991-MAS03375,Card reader-Major version,15,
MAS01991-MAS03376,Card reader-Minor version,15,
MAS01991-MAS03959,Card reader-Write-protection,Not available,
MAS01991-MAS04388,Card reader-Card type,-----,
MAS01991-MAS13476,Card reader-Manufacturing date: month,15, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, mon
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS03782-ENG117422,WLAN-IP_Address,010.173.189.001                        ,
MAS03782-ENG117423,WLAN-IP_Subnetmask,255.255.255.000                        ,
MAS03782-ENG117421,WLAN-MAC_Address,2C DC AD 44 26 A2,
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,0,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,SDAP,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,8,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,11,
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,3, min
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,17, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,29, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,52, s
ENG127486-ENG117422,mac_adress_wlan_tethering-IP_Address,---------------------------------------,
ENG127486-ENG117423,mac_adress_wlan_tethering-IP_Subnetmask,---------------------------------------,
ENG127486-ENG117421,mac_adress_wlan_tethering-MAC_Address,2C DC AD 44 26 A1,
ENG129160,MMX mNAND Flash Version,Product = mmx2qc
Branch = rel/CLU8
Up to CL = 10681477
FirstTierSupplier = HARMAN
Project = project_mmx2qc_audi_nar_g22.cfg
OEM = AU
Region = NAR
Variant = G22
Media-Stack = EVO
Framework = 5.49.12.SR3 MIB2MAIN I199 CI68 QC
JavaVM = j9_1.16+ObjectSwapper_1.02+XIPLoader_1.10+MCFObjectReader_1.01C+JavaCrypto_1.05+Socks5Support_1.00
DSI = 2_67.1
GraphicsServices = MIB2CLU8 199.1
Splashscreens = 62.0 MIB2MAIN
rdiserver = 118
SDIS_MU_ASI = 7.10.0.I7
MediaEngine = Cinemo_1.79.28
Navigation = CLU8_16291MIB2MAIN_QC_B17.07.3.80200
NavigationMapStyles:
			- NAR  = 10.0.2567
LocationAccessor = 0.9.15
Speech = 129.1650.1-MIB2QCMAIN
SpeechResources = 129.1706.1
sseProc = 1.4.3
trufflesSpeech = 1.6.9
HMI = HMI_AU_MIB2_HQC_NAR_G22_C8_173201
GCT = 2.8.2.1839
VoiceEncoderApp = v2.1.3121_FW5.49.12.SR3_TCC8REL01.10A_GPUsnapdragon
GoogleEarth = v2.1.3125_FW5.49.12.SR3_TCC8REL01.10A_v7_Bclu8_GPUsnapdragon
RenderDataProvider = 24
Streetview = v2.1.3121_FW5.49.12.SR3_TCC8REL01.10A_GPUsnapdragon
exFAT-Library = Tuxera_2016/02/0Ýb$oolVersionGUIAsia = 26352
TextToolVersionSDSAsia = 25972
OptoolVersionGUIAsia = 26352
OptionDrawerVersion = 8.50
devp-iso-mmx-mib2 = 2014/08/15_05-51-30_UTC
refresh_tool = 1.6 (2016/06/16-12:27:17-GMT)
putl = 1.0.0
uaputl = 2016/08/03-11:44:10-EDT
BlueSDK = 4.3.1 + AV 2.2.2u1
ALS6A-FW = 02.011 (App: 01.001.24)
ALS6A-BOLO = 84084
Bluetooth-Firmware = Id: w8787-Ax, RF878X, FP44, 14.44.35.p233
TelephoneDriver = 10.615.471
Radiodata = 2.8.0
GracenoteSDK = 3.05.4
OS = QNX 6.5.0
Toolchain = RL_QNX_OS_650SP1_QC_MMX2_C8REL01.13A
PDK = QC_CRM_BUILD_90113_1
ENG129161,MMX NOR Flash Version,Product = mmx2qc
Branch = rel/CLU8
Up to CL = 10681477
OEM = AU
Region = NAR
Variant = G22
Media-Stack = EVO
DSI = 2_67.1
rdiserver = 118
			- NAR  = 10.0.2567
sseProc = 1.4.3
GCT = 2.8.2.1839
exFAT-Library = Tuxera_2016/02/0Ýb"oolVersionGUIAsia = 26352
putl = 1.0.0
ALS6A-BOLO = 84084
Radiodata = 2.8.0
OS = QNX 6.5.0
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,118, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG122217-ENG122284,SDARS_service-audio_service,subscribed,
ENG122217-ENG122285,SDARS_service-traffic_service,not_subscribed,
ENG122217-ENG122286,SDARS_service-travel_link_service,not_subscribed,
ENG122216-MAS00106,SDARS_subscription_status-Year,2098,
ENG122216-MAS00107,SDARS_subscription_status-Month,1,
ENG122216-MAS00108,SDARS_subscription_status-Day,1,
ENG122216-MAS00109,SDARS_subscription_status-Hours,0,
ENG122216-MAS00110,SDARS_subscription_status-Minutes,0,
ENG122216-MAS00111,SDARS_subscription_status-Seconds,0,
ENG122216-ENG122279,SDARS_subscription_status-SDARS_subscription,subscribed,
ENG122216-ENG125804,SDARS_subscription_status-SDARS_suspend_alert,no_alert,
ENG122216-ENG122280,SDARS_subscription_status-SDARS_suspension,not_suspended,
ENG117855-ENG117392,System_Character_Recognition-touchpanel_information,,
Elapsed Time: 00:47
adpmap-5F-8W5-035-880-B
;Sunday,10,November,2019,20:42:17:01617
IDE00346-Summertime-automatic,automatic ,1
IDE00768-Country identification: country of sale,US ,2
IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00845-Wheel circ.,0 mm,2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,No ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,Yes ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit,No ,3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,No ,3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
IDE02121-CD eject button,Enabled ,1
IDE02122-Developer mode,not activated ,1
IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,32 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,85 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,85 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,85 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,85 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,85 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,85 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,85 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,17 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,17 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,32 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,85 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,85 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,85 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,85 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,85 ,49
IDE02502-Confirmation of installation change,31 68 ,2
IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,On ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,On ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,On ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present ,30
IDE03471-ENG127492-Vehicle configuration-LGI,On ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,On ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,On ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,On ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,On ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,Deactivated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_NAR ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,On ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,On ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE03580-Country code for mobile network,0 ,2
IDE03902-Automatic ring break diagnostic,No automatic start ,1
IDE04292-Roadside assistance mode,Corresponding setting in MMI ,1
IDE04294-Number attempted dialing attempts for roadside assistance,3 ,1
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,1 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,1 ,2
IDE04521-Sporadic ring break detection,Visual ,1
IDE04549-Telephone data services,On ,1
IDE04550-Bluetooth: Sniff mode,OFF ,1
IDE05111-Fee-based traffic information (TMC),65533 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE07399-ENG142045-Engine type-Engine_type_adaption_1,Value_from_BAP_protocol ,1
IDE07399-ENG142046-Engine type-Engine_type_adaption_2,Value_from_BAP_protocol ,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,On ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0 ,16
IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0 ,16
IDE10082-MAS09813-Telephone functions configuration-Entering Access Point Name,On ,1
IDE10082-MAS09814-Telephone functions configuration-Call Center Function,On ,1
IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi,Available ,1
IDE10082-MAS13847-Telephone functions configuration-Call center function on MIB: roadside assistance call,On ,1
IDE10082-MAS13848-Telephone functions configuration-Call center function on MIB: POI call,On ,1
IDE10082-MAS16726-Telephone functions configuration-Call center function on MIB: POI call regions,OFF ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,17 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,7 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
IDE10668-Internal SIM card: use,Always ,1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,20 dBµV,3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,50 dB,3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,0.1 s,3
IDE11105-Brand-specific display of connect application,de.audi.mmiconnect ,19
IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength,4294967295 ,330
IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle,65535 ,330
IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle,65535 ,330
IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos,32767 ,330
IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle,65535 ,330
IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos,32767 ,330
IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos,32767 ,330
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
IDE11503-Satellite radio tuner: pre-activated subscription,05 ,1
IDE11524-ENG249835-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57,not activated ,192
IDE11524-ENG249836-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57_msg_bus,Comfort data bus ,192
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
IDE11524-ENG249837-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C,not activated ,192
IDE11524-ENG249838-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C_msg_bus,Comfort data bus ,192
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,Comfort data bus ,192
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192
IDE11524-ENG248719-Vehicle function list BAP 2nd generation: expansion-ITM_0x65,not activated ,192
IDE11524-ENG248720-Vehicle function list BAP 2nd generation: expansion-ITM_0x65_msg_bus,Comfort data bus ,192
IDE11524-ENG249902-Vehicle function list BAP 2nd generation: expansion-lift_0x64,not activated ,192
IDE11524-ENG249903-Vehicle function list BAP 2nd generation: expansion-lift_0x64_msg_bus,Comfort data bus ,192
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,Comfort data bus ,192
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
IDE11638-Bluetooth Audio Codec,FF ,1
IDE12266-Follow on time for telephone,activated ,1
IDE12353-Configuration of traffic light online functions,On ,1
IDE12434-ENG249906-Vehicle menu operation: second generation: extension-menu_chassis_control,not activated ,60
IDE12434-ENG249907-Vehicle menu operation: second generation: extension-menu_chassis_control_after_disclaimer,not activated ,60
IDE12434-ENG249908-Vehicle menu operation: second generation: extension-menu_chassis_control_clamp_15_off,not activated ,60
IDE12434-ENG249909-Vehicle menu operation: second generation: extension-menu_chassis_control_over_threshold_high,not activated ,60
IDE12434-ENG249910-Vehicle menu operation: second generation: extension-menu_chassis_control_stillstand,not activated ,60
IDE12434-ENG152495-Vehicle menu operation: second generation: extension-menu_connection_manager,not activated ,60
IDE12434-ENG152499-Vehicle menu operation: second generation: extension-menu_connection_manager_after_disclaimer,not activated ,60
IDE12434-ENG152496-Vehicle menu operation: second generation: extension-menu_connection_manager_clamp_15_off,not activated ,60
IDE12434-ENG152497-Vehicle menu operation: second generation: extension-menu_connection_manager_over_threshold_high,not activated ,60
IDE12434-ENG152498-Vehicle menu operation: second generation: extension-menu_connection_manager_standstill,not activated ,60
IDE12434-ENG249911-Vehicle menu operation: second generation: extension-menu_convertible_top,not activated ,60
IDE12434-ENG249912-Vehicle menu operation: second generation: extension-menu_convertible_top_after_disclaimer,not activated ,60
IDE12434-ENG249913-Vehicle menu operation: second generation: extension-menu_convertible_top_clamp_15_off,not activated ,60
IDE12434-ENG249914-Vehicle menu operation: second generation: extension-menu_convertible_top_over_threshold_high,not activated ,60
IDE12434-ENG249915-Vehicle menu operation: second generation: extension-menu_convertible_top_stillstand,not activated ,60
IDE12434-ENG152548-Vehicle menu operation: second generation: extension-menu_daf_profile,not activated ,60
IDE12434-ENG152549-Vehicle menu operation: second generation: extension-menu_daf_profile_after_disclaimer,not activated ,60
IDE12434-ENG152550-Vehicle menu operation: second generation: extension-menu_daf_profile_clamp_15_off,not activated ,60
IDE12434-ENG152551-Vehicle menu operation: second generation: extension-menu_daf_profile_over_threshold_high,not activated ,60
IDE12434-ENG152552-Vehicle menu operation: second generation: extension-menu_daf_profile_stillstand,not activated ,60
IDE12434-ENG185793-Vehicle menu operation: second generation: extension-menu_engine_functions,not activated ,60
IDE12434-ENG185794-Vehicle menu operation: second generation: extension-menu_engine_functions_after_disclaimer,not activated ,60
IDE12434-ENG185795-Vehicle menu operation: second generation: extension-menu_engine_functions_clamp_15_off,not activated ,60
IDE12434-ENG185796-Vehicle menu operation: second generation: extension-menu_engine_functions_over_threshold_high,not activated ,60
IDE12434-ENG185797-Vehicle menu operation: second generation: extension-menu_engine_functions_stillstand,not activated ,60
IDE12434-ENG152515-Vehicle menu operation: second generation: extension-menu_fas_profile,not activated ,60
IDE12434-ENG152519-Vehicle menu operation: second generation: extension-menu_fas_profile_after_disclaimer,not activated ,60
IDE12434-ENG152516-Vehicle menu operation: second generation: extension-menu_fas_profile_clamp_15_off,not activated ,60
IDE12434-ENG152517-Vehicle menu operation: second generation: extension-menu_fas_profile_over_threshold_high,not activated ,60
IDE12434-ENG152518-Vehicle menu operation: second generation: extension-menu_fas_profile_standstill,not activated ,60
IDE12434-ENG185798-Vehicle menu operation: second generation: extension-menu_fod,not activated ,60
IDE12434-ENG185799-Vehicle menu operation: second generation: extension-menu_fod_after_disclaimer,not activated ,60
IDE12434-ENG185800-Vehicle menu operation: second generation: extension-menu_fod_clamp_15_off,not activated ,60
IDE12434-ENG185801-Vehicle menu operation: second generation: extension-menu_fod_over_threshold_high,not activated ,60
IDE12434-ENG185802-Vehicle menu operation: second generation: extension-menu_fod_stillstand,not activated ,60
IDE12434-ENG248744-Vehicle menu operation: second generation: extension-menu_ITM,not activated ,60
IDE12434-ENG248745-Vehicle menu operation: second generation: extension-menu_ITM_after_disclaimer,not activated ,60
IDE12434-ENG248746-Vehicle menu operation: second generation: extension-menu_ITM_clamp_15_off,not activated ,60
IDE12434-ENG248747-Vehicle menu operation: second generation: extension-menu_ITM_over_threshold_high,not activated ,60
IDE12434-ENG248748-Vehicle menu operation: second generation: extension-menu_ITM_stillstand,not activated ,60
IDE12434-ENG249916-Vehicle menu operation: second generation: extension-menu_lift,not activated ,60
IDE12434-ENG249917-Vehicle menu operation: second generation: extension-menu_lift_after_disclaimer,not activated ,60
IDE12434-ENG249918-Vehicle menu operation: second generation: extension-menu_lift_clamp_15_off,not activated ,60
IDE12434-ENG249919-Vehicle menu operation: second generation: extension-menu_lift_over_threshold_high,not activated ,60
IDE12434-ENG249920-Vehicle menu operation: second generation: extension-menu_lift_stillstand,not activated ,60
IDE12434-ENG184478-Vehicle menu operation: second generation: extension-menu_mascot,not activated ,60
IDE12434-ENG184479-Vehicle menu operation: second generation: extension-menu_mascot_after_disclaimer,not activated ,60
IDE12434-ENG184480-Vehicle menu operation: second generation: extension-menu_mascot_clamp_15_off,not activated ,60
IDE12434-ENG184481-Vehicle menu operation: second generation: extension-menu_mascot_over_threshold_high,not activated ,60
IDE12434-ENG184482-Vehicle menu operation: second generation: extension-menu_mascot_stillstand,not activated ,60
IDE12434-ENG152562-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile,not activated ,60
IDE12434-ENG152563-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_after_disclaimer,not activated ,60
IDE12434-ENG152564-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_clamp_15_off,not activated ,60
IDE12434-ENG152565-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_over_threshold_high,not activated ,60
IDE12434-ENG152566-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_stillstand,not activated ,60
IDE12434-ENG152505-Vehicle menu operation: second generation: extension-menu_statistic,not activated ,60
IDE12434-ENG152509-Vehicle menu operation: second generation: extension-menu_statistic_after_disclaimer,not activated ,60
IDE12434-ENG152506-Vehicle menu operation: second generation: extension-menu_statistic_clamp_15_off,not activated ,60
IDE12434-ENG152507-Vehicle menu operation: second generation: extension-menu_statistic_over_threshold_high,not activated ,60
IDE12434-ENG152508-Vehicle menu operation: second generation: extension-menu_statistic_standstill,not activated ,60
IDE12434-ENG152510-Vehicle menu operation: second generation: extension-menu_sunroof,not activated ,60
IDE12434-ENG152514-Vehicle menu operation: second generation: extension-menu_sunroof_after_disclaimer,not activated ,60
IDE12434-ENG152511-Vehicle menu operation: second generation: extension-menu_sunroof_clamp_15_off,not activated ,60
IDE12434-ENG152512-Vehicle menu operation: second generation: extension-menu_sunroof_over_threshold_high,not activated ,60
IDE12434-ENG152513-Vehicle menu operation: second generation: extension-menu_sunroof_standstill,not activated ,60
IDE12434-ENG185803-Vehicle menu operation: second generation: extension-menu_vas,not activated ,60
IDE12434-ENG185804-Vehicle menu operation: second generation: extension-menu_vas_after_disclaimer,not activated ,60
IDE12434-ENG185805-Vehicle menu operation: second generation: extension-menu_vas_clamp_15_off,not activated ,60
IDE12434-ENG185806-Vehicle menu operation: second generation: extension-menu_vas_over_threshold_high,not activated ,60
IDE12434-ENG185807-Vehicle menu operation: second generation: extension-menu_vas_stillstand,not activated ,60
IDE12434-ENG152500-Vehicle menu operation: second generation: extension-menu_wireless_charging,not activated ,60
IDE12434-ENG152504-Vehicle menu operation: second generation: extension-menu_wireless_charging_after_disclaimer,not activated ,60
IDE12434-ENG152501-Vehicle menu operation: second generation: extension-menu_wireless_charging_clamp_15_off,not activated ,60
IDE12434-ENG152502-Vehicle menu operation: second generation: extension-menu_wireless_charging_over_threshold_high,not activated ,60
IDE12434-ENG152503-Vehicle menu operation: second generation: extension-menu_wireless_charging_standstill,not activated ,60
MAS00951-Bluetooth,On ,1
MAS03690-Telephone,Data & language service active ,1
MAS03782-WLAN,On ,1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,On ,12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,150.00 ms,12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,On ,12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,150.00 ms,12
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15 ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Terminal 15 ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Terminal 15 ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Databus Infotainment ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,CAB_4 ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Databus Infotainment ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Terminal 15 ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Databus Infotainment ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15 ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Terminal 15 ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15 ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Terminal 15 ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15 ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Terminal 15 ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15 ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15 ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15 ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Terminal 15 ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Terminal 15 ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Terminal 15 ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On ,10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,RLE ,10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1 ,10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,LVDS_map_FPK ,10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,0 ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,On ,10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1 ,10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,LVDS_map_FPK ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,On ,10
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,20 ,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,5 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,13 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,33 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %,12
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,FF ,32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,FF ,32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,FF ,32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,FF ,32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,FF ,32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,FF ,32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,FF ,32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,FF ,32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,FF ,32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,FF ,32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,FF ,32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,FF ,32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,FF ,32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,FF ,32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,FF ,32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,FF ,32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,FF ,32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,FF ,32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,FF ,32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,FF ,32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,FF ,32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,FF ,32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,FF ,32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,FF ,32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,FF ,32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,FF ,32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,FF ,32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,FF ,32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,FF ,32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,FF ,32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,FF ,32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,FF ,32
ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,10 %,1
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 00:58
drp
DrPeter
16.4905° S, 151.7375° W
More and more Maps...
Address [6C]
blockmap-6C-4M0-980-556-A
;SW:4M0-980-556-A   HW:4M0-980-556-A ---  Back-up Cam.
;Component:RVC Compact   H12 0250, Coding:0294010102002001400040
;EV_CamSysRVRVCPANAMLBEv,005010,EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
;Sunday,10,November,2019,20:43:18:01617
;VCID: B3291C8A1A33B9D7EA-80E6
Group,Description,Actual
IDE00019,Voltage terminal 30,14.49, V
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.00, km/h
IDE00303-MAS00222,Status of doors/lids 1-Rear lid,closed,
IDE00303-MAS00223,Status of doors/lids 1-Hood,Measured value not available,
IDE00303-MAS01374,Status of doors/lids 1-Trailer,detected,
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00773,Terminal 15 status via CAN,On,
IDE00924-IDE08941,Steering angle-Rack position,47.320, mm
IDE00924-MAS02471,Steering angle-Sign,Negative,
IDE00924-MAS02983,Steering angle-Steering wheel angle,0.000, °
IDE00924,Steering angle,24.000, °
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,0.000, °
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Negative,
IDE01714,Status reverse gear,not selected,
IDE02486,Data logger triggering,not active,
IDE03619,System status,passive,
IDE06449-MAS05746,Calibration of camera system-Rearview camera calibration status,Calibration ended,
IDE06449-MAS05748,Calibration of camera system-Rearview camera calibration progress,100, %
IDE06449-MAS05750,Calibration of camera system-Rearview camera calibration repeat attempts,0,
IDE06449-MAS05753,Calibration of camera system-Cause of rearview camera calibration error,no error,
IDE06449-MAS05803,Calibration of camera system-Rearview camera calibration resumption,No resumption,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE07402,External activation,Not available,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,11,
MAS00464-MAS00108,Standard - ambient data 1-Day,10,
MAS00464-MAS00109,Standard - ambient data 1-Hours,20,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,43,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,18,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,114, counts
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,32501, km
ENG119197-ENG128717,camera_calibration_parameters-Cam0 Calibration binary threshold,00,
ENG119197-ENG119070,camera_calibration_parameters-Cam0 Calibration Result judgment,00 00 E0 40 00 00 E0 40 00 00 E0 40 00 00 20 41 00 00 20 41 00 00 A0 41 00 00 A0 40,
ENG119197-ENG119060,camera_calibration_parameters-Cam0 Changing default data - Ground to Camera Z,0, mm
ENG119197-ENG119061,camera_calibration_parameters-Cam0 Changing default data - Ground to wheel arch Z,1144274125, mm
ENG119197-ENG119068,camera_calibration_parameters-Cam0 division counts horizontal,1,
ENG119197-ENG119069,camera_calibration_parameters-Cam0 division counts vertical,0,
ENG119197-ENG119062,camera_calibration_parameters-Cam0 Fixed value input - Ground to Camera Z,0, mm
ENG119197-ENG119063,camera_calibration_parameters-Cam0 Fixed value input - Ground to wheel arch Z,0, mm
ENG119197-ENG119067,camera_calibration_parameters-Cam0 height of marker,1110992486, mm
ENG119197-ENG119064,camera_calibration_parameters-Cam0 Marker size Full-size or Half-size,half size,
ENG119197-ENG119058,camera_calibration_parameters-Cam0 Transversal position front axle,1036831949, mm
ENG119197-ENG119059,camera_calibration_parameters-Cam0 Transversal position rear axle,1045220557, mm
ENG119197-ENG119065,camera_calibration_parameters-Cam0 X direction of marker red ribbon,1166434304, mm
ENG119197-ENG119066,camera_calibration_parameters-Cam0 Y direction of marker,3184315597, mm
ENG119196-ENG119090,camera_calibration_tolerance-RV_Calibration_Result,1046562734, px
ENG119196-ENG119084,camera_calibration_tolerance-RV_Calibration_Tolerance_alpha,3210991370, °
ENG119196-ENG119085,camera_calibration_tolerance-RV_Calibration_Tolerance_beta,3215521219, °
ENG119196-ENG119086,camera_calibration_tolerance-RV_Calibration_Tolerance_gamma,3201763901, °
ENG119196-ENG119087,camera_calibration_tolerance-RV_Calibration_Tolerance_x,0, mm
ENG119196-ENG119088,camera_calibration_tolerance-RV_Calibration_Tolerance_y,0, mm
ENG119196-ENG119089,camera_calibration_tolerance-RV_Calibration_Tolerance_z,1098330752, mm
Elapsed Time: 00:02
adpmap-6C-4M0-980-556-A
;Sunday,10,November,2019,20:43:20:01617
IDE02709-Actuator: PWM signal,100 %,1
IDE03531-Wheel/tire description,1950 mm,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
MAS02209-Image contrast,50 %,1
MAS02851-Brightness,50 %,1
ENG119212-camera_off,35.00 km/h,2
ENG119211-camera_on,30.00 km/h,2
ENG119200-color,50 %,1
ENG119218-debounce_time_for_reverse_gear,0 ms,2
ENG119215-display_position,0 px,1
ENG119216-engine_restart_timer,0 ms,2
ENG119209-Frequency_Swinging_Logo,100 Hz,2
ENG119221-FSG_control_state,On ,1
ENG119220-ENG119101-grafic_element_setting-setting_1_color_value,FF FF ,128
ENG119220-ENG119099-grafic_element_setting-setting_1_HMI_mode,FF ,128
ENG119220-ENG119100-grafic_element_setting-setting_1_pallet_ID,255 ,128
ENG119220-ENG119128-grafic_element_setting-setting_10_color_value,FF FF ,128
ENG119220-ENG119126-grafic_element_setting-setting_10_HMI_mode,FF ,128
ENG119220-ENG119127-grafic_element_setting-setting_10_pallet_ID,255 ,128
ENG119220-ENG119131-grafic_element_setting-setting_11_color_value,FF FF ,128
ENG119220-ENG119129-grafic_element_setting-setting_11_HMI_mode,FF ,128
ENG119220-ENG119130-grafic_element_setting-setting_11_pallet_ID,255 ,128
ENG119220-ENG119134-grafic_element_setting-setting_12_color_value,FF FF ,128
ENG119220-ENG119132-grafic_element_setting-setting_12_HMI_mode,FF ,128
ENG119220-ENG119133-grafic_element_setting-setting_12_pallet_ID,255 ,128
ENG119220-ENG119137-grafic_element_setting-setting_13_color_value,FF FF ,128
ENG119220-ENG119135-grafic_element_setting-setting_13_HMI_mode,FF ,128
ENG119220-ENG119136-grafic_element_setting-setting_13_pallet_ID,255 ,128
ENG119220-ENG119140-grafic_element_setting-setting_14_color_value,FF FF ,128
ENG119220-ENG119138-grafic_element_setting-setting_14_HMI_mode,FF ,128
ENG119220-ENG119139-grafic_element_setting-setting_14_pallet_ID,255 ,128
ENG119220-ENG119143-grafic_element_setting-setting_15_color_value,FF FF ,128
ENG119220-ENG119141-grafic_element_setting-setting_15_HMI_mode,FF ,128
ENG119220-ENG119142-grafic_element_setting-setting_15_pallet_ID,255 ,128
ENG119220-ENG119146-grafic_element_setting-setting_16_color_value,FF FF ,128
ENG119220-ENG119144-grafic_element_setting-setting_16_HMI_mode,FF ,128
ENG119220-ENG119145-grafic_element_setting-setting_16_pallet_ID,255 ,128
ENG119220-ENG119149-grafic_element_setting-setting_17_color_value,FF FF ,128
ENG119220-ENG119147-grafic_element_setting-setting_17_HMI_mode,FF ,128
ENG119220-ENG119148-grafic_element_setting-setting_17_pallet_ID,255 ,128
ENG119220-ENG119152-grafic_element_setting-setting_18_color_value,FF FF ,128
ENG119220-ENG119150-grafic_element_setting-setting_18_HMI_mode,FF ,128
ENG119220-ENG119151-grafic_element_setting-setting_18_pallet_ID,255 ,128
ENG119220-ENG119155-grafic_element_setting-setting_19_color_value,FF FF ,128
ENG119220-ENG119153-grafic_element_setting-setting_19_HMI_mode,FF ,128
ENG119220-ENG119154-grafic_element_setting-setting_19_pallet_ID,255 ,128
ENG119220-ENG119104-grafic_element_setting-setting_2_color_value,FF FF ,128
ENG119220-ENG119102-grafic_element_setting-setting_2_HMI_mode,FF ,128
ENG119220-ENG119103-grafic_element_setting-setting_2_pallet_ID,255 ,128
ENG119220-ENG119158-grafic_element_setting-setting_20_color_value,FF FF ,128
ENG119220-ENG119156-grafic_element_setting-setting_20_HMI_mode,FF ,128
ENG119220-ENG119157-grafic_element_setting-setting_20_pallet_ID,255 ,128
ENG119220-ENG119161-grafic_element_setting-setting_21_color_value,FF FF ,128
ENG119220-ENG119159-grafic_element_setting-setting_21_HMI_mode,FF ,128
ENG119220-ENG119160-grafic_element_setting-setting_21_pallet_ID,255 ,128
ENG119220-ENG119164-grafic_element_setting-setting_22_color_value,FF FF ,128
ENG119220-ENG119162-grafic_element_setting-setting_22_HMI_mode,FF ,128
ENG119220-ENG119163-grafic_element_setting-setting_22_pallet_ID,255 ,128
ENG119220-ENG119167-grafic_element_setting-setting_23_color_value,FF FF ,128
ENG119220-ENG119165-grafic_element_setting-setting_23_HMI_mode,FF ,128
ENG119220-ENG119166-grafic_element_setting-setting_23_pallet_ID,255 ,128
ENG119220-ENG119170-grafic_element_setting-setting_24_color_value,FF FF ,128
ENG119220-ENG119168-grafic_element_setting-setting_24_HMI_mode,FF ,128
ENG119220-ENG119169-grafic_element_setting-setting_24_pallet_ID,255 ,128
ENG119220-ENG119173-grafic_element_setting-setting_25_color_value,FF FF ,128
ENG119220-ENG119171-grafic_element_setting-setting_25_HMI_mode,FF ,128
ENG119220-ENG119172-grafic_element_setting-setting_25_pallet_ID,255 ,128
ENG119220-ENG119176-grafic_element_setting-setting_26_color_value,FF FF ,128
ENG119220-ENG119174-grafic_element_setting-setting_26_HMI_mode,FF ,128
ENG119220-ENG119175-grafic_element_setting-setting_26_pallet_ID,255 ,128
ENG119220-ENG119179-grafic_element_setting-setting_27_color_value,FF FF ,128
ENG119220-ENG119177-grafic_element_setting-setting_27_HMI_mode,FF ,128
ENG119220-ENG119178-grafic_element_setting-setting_27_pallet_ID,255 ,128
ENG119220-ENG119182-grafic_element_setting-setting_28_color_value,FF FF ,128
ENG119220-ENG119180-grafic_element_setting-setting_28_HMI_mode,FF ,128
ENG119220-ENG119181-grafic_element_setting-setting_28_pallet_ID,255 ,128
ENG119220-ENG119185-grafic_element_setting-setting_29_color_value,FF FF ,128
ENG119220-ENG119183-grafic_element_setting-setting_29_HMI_mode,FF ,128
ENG119220-ENG119184-grafic_element_setting-setting_29_pallet_ID,255 ,128
ENG119220-ENG119107-grafic_element_setting-setting_3_color_value,FF FF ,128
ENG119220-ENG119105-grafic_element_setting-setting_3_HMI_mode,FF ,128
ENG119220-ENG119106-grafic_element_setting-setting_3_pallet_ID,255 ,128
ENG119220-ENG119188-grafic_element_setting-setting_30_color_value,FF FF ,128
ENG119220-ENG119186-grafic_element_setting-setting_30_HMI_mode,FF ,128
ENG119220-ENG119187-grafic_element_setting-setting_30_pallet_ID,255 ,128
ENG119220-ENG119191-grafic_element_setting-setting_31_color_value,FF FF ,128
ENG119220-ENG119189-grafic_element_setting-setting_31_HMI_mode,FF ,128
ENG119220-ENG119190-grafic_element_setting-setting_31_pallet_ID,255 ,128
ENG119220-ENG119194-grafic_element_setting-setting_32_color_value,FF FF ,128
ENG119220-ENG119192-grafic_element_setting-setting_32_HMI_mode,FF ,128
ENG119220-ENG119193-grafic_element_setting-setting_32_pallet_ID,255 ,128
ENG119220-ENG119110-grafic_element_setting-setting_4_color_value,FF FF ,128
ENG119220-ENG119108-grafic_element_setting-setting_4_HMI_mode,FF ,128
ENG119220-ENG119109-grafic_element_setting-setting_4_pallet_ID,255 ,128
ENG119220-ENG119113-grafic_element_setting-setting_5_color_value,FF FF ,128
ENG119220-ENG119111-grafic_element_setting-setting_5_HMI_mode,FF ,128
ENG119220-ENG119112-grafic_element_setting-setting_5_pallet_ID,255 ,128
ENG119220-ENG119116-grafic_element_setting-setting_6_color_value,FF FF ,128
ENG119220-ENG119114-grafic_element_setting-setting_6_HMI_mode,FF ,128
ENG119220-ENG119115-grafic_element_setting-setting_6_pallet_ID,255 ,128
ENG119220-ENG119119-grafic_element_setting-setting_7_color_value,FF FF ,128
ENG119220-ENG119117-grafic_element_setting-setting_7_HMI_mode,FF ,128
ENG119220-ENG119118-grafic_element_setting-setting_7_pallet_ID,255 ,128
ENG119220-ENG119122-grafic_element_setting-setting_8_color_value,FF FF ,128
ENG119220-ENG119120-grafic_element_setting-setting_8_HMI_mode,FF ,128
ENG119220-ENG119121-grafic_element_setting-setting_8_pallet_ID,255 ,128
ENG119220-ENG119125-grafic_element_setting-setting_9_color_value,FF FF ,128
ENG119220-ENG119123-grafic_element_setting-setting_9_HMI_mode,FF ,128
ENG119220-ENG119124-grafic_element_setting-setting_9_pallet_ID,255 ,128
ENG119201-image_delay_timer,0.0 s,1
ENG119219-Minimal_time_to_stay_in_bus_sleep_before_ECU_off,20000 ms,2
ENG119214-rv_dark_off,10.00 km/h,2
ENG119213-rv_dark_on,15.00 km/h,2
ENG119203-RV_Last_Mode,90° parking spot ,1
ENG102898-RV_Start_Mode,90° parking spot ,1
ENG119205-Time_to_open_Swinging_Logo,750 ms,2
Elapsed Time: 00:06
Address [81]
blockmap-81-8W1-713-041-G
;SW:8W1-713-041-G   HW:8W1-713-041-J ---  Gear Shift
;Component:GSM-LL        H09 0077, Coding:
;EV_GSMWaehlZFAU736,001017,EV_GSMWaehlZFAU736.rod
;Sunday,10,November,2019,20:43:29:01617
;VCID: B731289A0E4B55F7D6-80E2
IDE00019,Voltage terminal 30,14.4, V
IDE01215,Terminal 58d dimmer,10.0, %
IDE03393-MAS02985,Selector lever position-Value,04,
IDE03393-MAS03359,Selector lever position-Text,Basic setting X,
IDE07270,Magnet for select. lever lock.: current,0.0, A
IDE11401-MAS02985,Selec. range display: spec. val.-Value,08,
IDE11401-MAS03359,Selec. range display: spec. val.-Text,P,
IDE11402-MAS02985,Neutral halt position-Value,00,
IDE11402-MAS03359,Neutral halt position-Text,not active,
IDE11403-MAS00116,Selec. range display: spec. val.: volts.-Tiptronic +,4619, mV
IDE11403-MAS00117,Selec. range display: spec. val.: volts.-Tiptronic -,4619, mV
IDE11403-MAS00146,Selec. range display: spec. val.: volts.-P,1314, mV
IDE11403-MAS00148,Selec. range display: spec. val.: volts.-R,4228, mV
IDE11403-MAS00150,Selec. range display: spec. val.: volts.-N,4252, mV
IDE11403-MAS00152,Selec. range display: spec. val.: volts.-d,4604, mV
IDE11403-MAS12722,Selec. range display: spec. val.: volts.-Button for park. lock,845, mV
IDE11403-MAS12723,Selec. range display: spec. val.: volts.-Arrow symbol,4648, mV
IDE11404,Magnet for park. lock.: voltage,9.9, V
IDE11405,Magnet for select. lever lock.: act. current,0.6, A
IDE11406,Magnet for select. lever lock.: spec. current,0.6, A
IDE11407,Sensor for select. lever pos.: X-value,0.12, mm
IDE11408,Sensor for select. lever pos.: Y-value,0.09, mm
IDE11409,Button for select. lever unlock.: voltage,3.9, V
IDE11411-MAS06275,Button for park. lock-Switch 2 and 3: voltage value,3.9, V
IDE11411-MAS06276,Button for park. lock-Switch 2 and 3: state,no switch is operated,
IDE11411-MAS11178,Button for park. lock-Signal to the transmission: status,not activated,
IDE11411-MAS11179,Button for park. lock-Signal to the transmission: value,01,
IDE11411-MAS11180,Button for park. lock-Switch 1: state,not activated,
IDE11411-MAS11181,Button for park. lock-Switch 1: value,00,
IDE11412,Magnet for park. lock.: resistance,6.3, Ohm
IDE11413-MAS00116,Selec. range display: pulse duty cycle-Tiptronic +,0.6, %
IDE11413-MAS00117,Selec. range display: pulse duty cycle-Tiptronic -,0.6, %
IDE11413-MAS00146,Selec. range display: pulse duty cycle-P,5.0, %
IDE11413-MAS00148,Selec. range display: pulse duty cycle-R,0.4, %
IDE11413-MAS00150,Selec. range display: pulse duty cycle-N,0.4, %
IDE11413-MAS00152,Selec. range display: pulse duty cycle-d,1.0, %
IDE11413-MAS12722,Selec. range display: pulse duty cycle-Button for park. lock,9.8, %
IDE11413-MAS12723,Selec. range display: pulse duty cycle-Arrow symbol,1.1, %
IDE11414,Magnet for park. lock.: pulse duty cycle,27, %
IDE11415-MAS02985,Selector lever release button-Value,01,
IDE11415-MAS03359,Selector lever release button-Text,not activated,
IDE11433-MAS02985,Status of magnet for park. lock.-Value,02,
IDE11433-MAS03359,Status of magnet for park. lock.-Text,operated,
IDE11451,Magnet for selector lever lock.: pulse duty cycle,0, %
IDE11453-MAS02985,Magnet for selector lever lock.: status-Value,00,
IDE11453-MAS03359,Magnet for selector lever lock.: status-Text,not activated,
IDE11454-MAS02985,Motor for transv. selector lever lock.: status-Value,01,
IDE11454-MAS03359,Motor for transv. selector lever lock.: status-Text,operated,
ENG07136-ENG32277,Btn_OccurenceCounter_NotClosing-PBTN_MECHERROR,NoErrorActive,
ENG07136-ENG07251,Btn_OccurenceCounter_NotClosing-PBTN_MS_PSM1,0,
ENG07136-ENG07252,Btn_OccurenceCounter_NotClosing-PBTN_MS_PSM1_Flag,0,
ENG07136-ENG07253,Btn_OccurenceCounter_NotClosing-PBTN_MS_PSM2,0,
ENG07136-ENG07254,Btn_OccurenceCounter_NotClosing-PBTN_MS_PSM2_Flag,0,
ENG07136-ENG07245,Btn_OccurenceCounter_NotClosing-PBTN_PSM1,0,
ENG07136-ENG07246,Btn_OccurenceCounter_NotClosing-PBTN_PSM1_Flag,0,
ENG07136-ENG07257,Btn_OccurenceCounter_NotClosing-PBTN_PSM1_MS,0,
ENG07136-ENG07258,Btn_OccurenceCounter_NotClosing-PBTN_PSM1_MS_Flag,0,
ENG07136-ENG07255,Btn_OccurenceCounter_NotClosing-PBTN_PSM1_PSM2,0,
ENG07136-ENG07256,Btn_OccurenceCounter_NotClosing-PBTN_PSM1_PSM2_Flag,0,
ENG07136-ENG07247,Btn_OccurenceCounter_NotClosing-PBTN_PSM2,0,
ENG07136-ENG07248,Btn_OccurenceCounter_NotClosing-PBTN_PSM2_Flag,0,
ENG07136-ENG07261,Btn_OccurenceCounter_NotClosing-PBTN_PSM2_MS,0,
ENG07136-ENG07262,Btn_OccurenceCounter_NotClosing-PBTN_PSM2_MS_Flag,0,
ENG07136-ENG07259,Btn_OccurenceCounter_NotClosing-PBTN_PSM2_PSM1,0,
ENG07136-ENG07260,Btn_OccurenceCounter_NotClosing-PBTN_PSM2_PSM1_Flag,0,
ENG07136-ENG07249,Btn_OccurenceCounter_NotClosing-PBTN_SWITCH,0,
ENG07136-ENG07250,Btn_OccurenceCounter_NotClosing-PBTN_SWITCH_Flag,0,
ENG07136-ENG07241,Btn_OccurenceCounter_NotClosing-UBTN_PSM,0,
ENG07136-ENG07242,Btn_OccurenceCounter_NotClosing-UBTN_PSM_Flag,0,
ENG07136-ENG07243,Btn_OccurenceCounter_NotClosing-UBTN_SWITCH,0,
ENG07136-ENG07244,Btn_OccurenceCounter_NotClosing-UBTN_SWITCH_Flag,0,
ENG07139,ECC_1Bit_ErrorCounter,0,
ENG26767-ENG31008,EOL_dimming_curve-EOL_dimming_curve_CRC,65407,
ENG26767-ENG31009,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_1_X,0,
ENG26767-ENG31010,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_1_Y,115,
ENG26767-ENG31011,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_2_X,100,
ENG26767-ENG31012,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_2_Y,115,
ENG26767-ENG31013,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_3_X,9500,
ENG26767-ENG31014,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_3_Y,14700,
ENG26767-ENG31015,EOL_dimming_curve-EOL_dimming_curve_function_DS_1_X,0,
ENG26767-ENG31016,EOL_dimming_curve-EOL_dimming_curve_function_DS_1_Y,200,
ENG26767-ENG31017,EOL_dimming_curve-EOL_dimming_curve_function_DS_2_X,100,
ENG26767-ENG31018,EOL_dimming_curve-EOL_dimming_curve_function_DS_2_Y,200,
ENG26767-ENG31019,EOL_dimming_curve-EOL_dimming_curve_function_DS_3_X,9500,
ENG26767-ENG31020,EOL_dimming_curve-EOL_dimming_curve_function_DS_3_Y,25000,
ENG26767-ENG31021,EOL_dimming_curve-EOL_dimming_curve_function_M_1_X,0,
ENG26767-ENG31022,EOL_dimming_curve-EOL_dimming_curve_function_M_1_Y,115,
ENG26767-ENG31023,EOL_dimming_curve-EOL_dimming_curve_function_M_2_X,100,
ENG26767-ENG31024,EOL_dimming_curve-EOL_dimming_curve_function_M_2_Y,115,
ENG26767-ENG31025,EOL_dimming_curve-EOL_dimming_curve_function_M_3_X,9500,
ENG26767-ENG31026,EOL_dimming_curve-EOL_dimming_curve_function_M_3_Y,14700,
ENG26767-ENG31027,EOL_dimming_curve-EOL_dimming_curve_function_N_1_X,0,
ENG26767-ENG31028,EOL_dimming_curve-EOL_dimming_curve_function_N_1_Y,84,
ENG26767-ENG31029,EOL_dimming_curve-EOL_dimming_curve_function_N_2_X,100,
ENG26767-ENG31030,EOL_dimming_curve-EOL_dimming_curve_function_N_2_Y,84,
ENG26767-ENG31031,EOL_dimming_curve-EOL_dimming_curve_function_N_3_X,9500,
ENG26767-ENG31032,EOL_dimming_curve-EOL_dimming_curve_function_N_3_Y,11000,
ENG26767-ENG31033,EOL_dimming_curve-EOL_dimming_curve_function_P_1_X,0,
ENG26767-ENG31034,EOL_dimming_curve-EOL_dimming_curve_function_P_1_Y,160,
ENG26767-ENG31035,EOL_dimming_curve-EOL_dimming_curve_function_P_2_X,100,
ENG26767-ENG31036,EOL_dimming_curve-EOL_dimming_curve_function_P_2_Y,160,
ENG26767-ENG31037,EOL_dimming_curve-EOL_dimming_curve_function_P_3_X,9500,
ENG26767-ENG31038,EOL_dimming_curve-EOL_dimming_curve_function_P_3_Y,15400,
ENG26767-ENG31039,EOL_dimming_curve-EOL_dimming_curve_function_PButton_1_X,0,
ENG26767-ENG31040,EOL_dimming_curve-EOL_dimming_curve_function_PButton_1_Y,245,
ENG26767-ENG31041,EOL_dimming_curve-EOL_dimming_curve_function_PButton_2_X,100,
ENG26767-ENG31042,EOL_dimming_curve-EOL_dimming_curve_function_PButton_2_Y,245,
ENG26767-ENG31043,EOL_dimming_curve-EOL_dimming_curve_function_PButton_3_X,9500,
ENG26767-ENG31044,EOL_dimming_curve-EOL_dimming_curve_function_PButton_3_Y,30583,
ENG26767-ENG31045,EOL_dimming_curve-EOL_dimming_curve_function_R_1_X,0,
ENG26767-ENG31046,EOL_dimming_curve-EOL_dimming_curve_function_R_1_Y,84,
ENG26767-ENG31047,EOL_dimming_curve-EOL_dimming_curve_function_R_2_X,100,
ENG26767-ENG31048,EOL_dimming_curve-EOL_dimming_curve_function_R_2_Y,84,
ENG26767-ENG31049,EOL_dimming_curve-EOL_dimming_curve_function_R_3_X,9500,
ENG26767-ENG31050,EOL_dimming_curve-EOL_dimming_curve_function_R_3_Y,11000,
ENG26767-ENG31051,EOL_dimming_curve-EOL_dimming_curve_raw,00 00 00 64 25 1C 00 A0 00 A0 3C 28 00 00 00 64 25 1C 00 00 00 00 00 00 00 00 00 64 25 1C 00 54 00 54 2A F8 00 00 00 64 25 1C 00 00 00 01 00 F5 00 00 00 64 25 1C 00 54 00 54 2A F8 00 00 00 64 25 1C 00 00 00 01 00 F5 00 00 00 64 25 1C 00 C8 00 C8 61 A8 00 00 00 64 25 1C 00 00 00 01 02 17 00 00 00 64 25 1C 00 73 00 73 39 6C 00 00 00 64 25 1C 00 00 00 01 01 54 00 00 00 64 25 1C 00 73 00 73 39 6C 00 00 00 64 25 1C 00 00 00 01 02 4E 00 00 00 64 25 1C 00 F5 00 F5 77 77 00 00 00 64 25 1C 00 00 00 01 02 71 FF 7F 00 00,
ENG26767-ENG31052,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_1_X,0,
ENG26767-ENG31053,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_1_Y,0,
ENG26767-ENG31054,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_2_X,100,
ENG26767-ENG31055,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_2_Y,1,
ENG26767-ENG31056,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_3_X,9500,
ENG26767-ENG31057,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_3_Y,590,
ENG26767-ENG31058,EOL_dimming_curve-EOL_dimming_curve_search_DS_1_X,0,
ENG26767-ENG31059,EOL_dimming_curve-EOL_dimming_curve_search_DS_1_Y,0,
ENG26767-ENG31060,EOL_dimming_curve-EOL_dimming_curve_search_DS_2_X,100,
ENG26767-ENG31061,EOL_dimming_curve-EOL_dimming_curve_search_DS_2_Y,1,
ENG26767-ENG31062,EOL_dimming_curve-EOL_dimming_curve_search_DS_3_X,9500,
ENG26767-ENG31063,EOL_dimming_curve-EOL_dimming_curve_search_DS_3_Y,535,
ENG26767-ENG31064,EOL_dimming_curve-EOL_dimming_curve_search_M_1_X,0,
ENG26767-ENG31065,EOL_dimming_curve-EOL_dimming_curve_search_M_1_Y,0,
ENG26767-ENG31066,EOL_dimming_curve-EOL_dimming_curve_search_M_2_X,100,
ENG26767-ENG31067,EOL_dimming_curve-EOL_dimming_curve_search_M_2_Y,1,
ENG26767-ENG31068,EOL_dimming_curve-EOL_dimming_curve_search_M_3_X,9500,
ENG26767-ENG31069,EOL_dimming_curve-EOL_dimming_curve_search_M_3_Y,340,
ENG26767-ENG31070,EOL_dimming_curve-EOL_dimming_curve_search_N_1_X,0,
ENG26767-ENG31071,EOL_dimming_curve-EOL_dimming_curve_search_N_1_Y,0,
ENG26767-ENG31072,EOL_dimming_curve-EOL_dimming_curve_search_N_2_X,100,
ENG26767-ENG31073,EOL_dimming_curve-EOL_dimming_curve_search_N_2_Y,1,
ENG26767-ENG31074,EOL_dimming_curve-EOL_dimming_curve_search_N_3_X,9500,
ENG26767-ENG31075,EOL_dimming_curve-EOL_dimming_curve_search_N_3_Y,245,
ENG26767-ENG31076,EOL_dimming_curve-EOL_dimming_curve_search_P_1_X,0,
ENG26767-ENG31077,EOL_dimming_curve-EOL_dimming_curve_search_P_1_Y,0,
ENG26767-ENG31078,EOL_dimming_curve-EOL_dimming_curve_search_P_2_X,100,
ENG26767-ENG31079,EOL_dimming_curve-EOL_dimming_curve_search_P_2_Y,0,
ENG26767-ENG31080,EOL_dimming_curve-EOL_dimming_curve_search_P_3_X,9500,
ENG26767-ENG31081,EOL_dimming_curve-EOL_dimming_curve_search_P_3_Y,0,
ENG26767-ENG31082,EOL_dimming_curve-EOL_dimming_curve_search_PButton_1_X,0,
ENG26767-ENG31083,EOL_dimming_curve-EOL_dimming_curve_search_PButton_1_Y,0,
ENG26767-ENG31084,EOL_dimming_curve-EOL_dimming_curve_search_PButton_2_X,100,
ENG26767-ENG31085,EOL_dimming_curve-EOL_dimming_curve_search_PButton_2_Y,1,
ENG26767-ENG31086,EOL_dimming_curve-EOL_dimming_curve_search_PButton_3_X,9500,
ENG26767-ENG31087,EOL_dimming_curve-EOL_dimming_curve_search_PButton_3_Y,625,
ENG26767-ENG31088,EOL_dimming_curve-EOL_dimming_curve_search_R_1_X,0,
ENG26767-ENG31089,EOL_dimming_curve-EOL_dimming_curve_search_R_1_Y,0,
ENG26767-ENG31090,EOL_dimming_curve-EOL_dimming_curve_search_R_2_X,100,
ENG26767-ENG31091,EOL_dimming_curve-EOL_dimming_curve_search_R_2_Y,1,
ENG26767-ENG31092,EOL_dimming_curve-EOL_dimming_curve_search_R_3_X,9500,
ENG26767-ENG31093,EOL_dimming_curve-EOL_dimming_curve_search_R_3_Y,245,
ENG26767-ENG31094,EOL_dimming_curve-EOL_dimming_curve_Variant,AUDI MLBevo,
ENG26767-ENG31095,EOL_dimming_curve-EOL_dimming_curve_Version_Number,00,
ENG48497-ENG49840,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_CRC,61257,
ENG48497-ENG49841,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_X_1,0,
ENG48497-ENG49842,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_X_2,10,
ENG48497-ENG49843,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_X_3,100,
ENG48497-ENG49844,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_X_4,200,
ENG48497-ENG49845,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_X_5,253,
ENG48497-ENG49846,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_Y_1,2,
ENG48497-ENG49847,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_Y_2,2,
ENG48497-ENG49848,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_Y_3,17,
ENG48497-ENG49849,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_Y_4,50,
ENG48497-ENG49850,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_Y_5,95,
ENG48497-ENG49851,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_raw,00 0A 64 C8 FD 02 02 11 32 5F 00 01 32 5F 7D 00 01 32 5F 5F EF 49 01 00,
ENG48497-ENG49852,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_X_1,0,
ENG48497-ENG49853,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_X_2,1,
ENG48497-ENG49854,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_X_3,50,
ENG48497-ENG49855,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_X_4,95,
ENG48497-ENG49856,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_X_5,125,
ENG48497-ENG49857,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_Y_1,0,
ENG48497-ENG49858,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_Y_2,1,
ENG48497-ENG49859,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_Y_3,50,
ENG48497-ENG49860,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_Y_4,95,
ENG48497-ENG49861,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_Y_5,95,
ENG48497-ENG49862,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_Variant,AUDI MSS,
ENG48497-ENG49863,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_Version,00,
ENG07128,Gear_KL58xt_Signal,3A,
ENG07126,Gear_Park_Lock_Solenoid_Signal,lock,
ENG111659,Invalid_key_counter,00,
ENG07135-ENG07240,LED_Level_Intensity-function_level_intensity,10, %
ENG07135-ENG07239,LED_Level_Intensity-search_level_intensity,58, %
ENG07131,MLL_Motor_Pos1Sensor_State,01,
ENG07140-ENG07301,MLL_RetryCounter_PWM100-MLL_RetryCounter_PWM100_Kickback,0,
ENG07140-ENG07300,MLL_RetryCounter_PWM100-MLL_RetryCounter_PWM100_Opening,0,
ENG07137,Mll_TargetPwmDutyCycle,70, %
ENG08877-ENG09593,MW_WH_Warnung-Mll_Wh_Warning_Info,none,
ENG08877-ENG09594,MW_WH_Warnung-Moni_WhWarning,none,
ENG07125,NWDF_Active,On,
ENG08876-ENG07265,PLS_ErrorCounter-CurrentDeviationCounter_OncePerKL15,0,
ENG08876-ENG07264,PLS_ErrorCounter-CurrentDeviationCounter_ThisKL15,0,
ENG08876-ENG09591,PLS_ErrorCounter-LowVoltInOnCounter_ThisKL15,0,
ENG08876-ENG09592,PLS_ErrorCounter-LowVoltInOnCounterCounter_OncePerKL15,0,
ENG08876-ENG07271,PLS_ErrorCounter-OnlineDiagCounter_OncePerKL15,0,
ENG08876-ENG07270,PLS_ErrorCounter-OnlineDiagCounter_ThisKL15,0,
ENG08876-ENG09590,PLS_ErrorCounter-ResistanceInOnCounter_OncePerKL15,0,
ENG08876-ENG09589,PLS_ErrorCounter-ResistanceInOnCounter_ThisKL15,0,
ENG08876-ENG07268,PLS_ErrorCounter-UndervoltCurrentDeviationCounter_OncePerKL15,0,
ENG08876-ENG07267,PLS_ErrorCounter-UndervoltCurrentDeviationCounter_ThisKL15,0,
ENG07119-ENG36278,RuntimeDataStruct-Runtime_Data_bios_pls_deviationCounterPerKL15,0,
ENG07119-ENG36279,RuntimeDataStruct-Runtime_Data_bios_pls_InOnCounterPerKL15onlineDiag,0,
ENG07119-ENG36280,RuntimeDataStruct-Runtime_Data_bios_pls_InOnUndervoltCounterPerKL15,0,
ENG07119-ENG36281,RuntimeDataStruct-Runtime_Data_bios_pls_onlineDiagCounterPerKL15,0,
ENG07119-ENG36282,RuntimeDataStruct-Runtime_Data_bios_pls_undervoltDeviationCounterPerKL15,0,
ENG07119-ENG32508,RuntimeDataStruct-Runtime_Data_btn_counters,00 00 00 00 00 00 00 00 00 00 00 00,
ENG07119-ENG36283,RuntimeDataStruct-Runtime_Data_Bus_Knockout_counter,0,
ENG07119-ENG36284,RuntimeDataStruct-Runtime_Data_ECC_Dsi_Error_counter,0,
ENG07119-ENG36285,RuntimeDataStruct-Runtime_Data_ECC_Mci_Error_counter,0,
ENG07119-ENG36286,RuntimeDataStruct-Runtime_Data_ECC_One_Bit_Error_counter,0,
ENG07119-ENG36287,RuntimeDataStruct-Runtime_Data_ECU_Knockout_counter,0,
ENG07119-ENG36288,RuntimeDataStruct-Runtime_Data_Fee_Overrun_counter,0,
ENG07119-ENG36289,RuntimeDataStruct-Runtime_Data_handshake_reset_counter,0,
ENG07119-ENG36290,RuntimeDataStruct-Runtime_Data_mll_Full_Pwm_kickback_counter,0,
ENG07119-ENG36291,RuntimeDataStruct-Runtime_Data_mll_Full_Pwm_opening_counter,0,
ENG07119-ENG32509,RuntimeDataStruct-Runtime_Data_Reserved,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07119-ENG32510,RuntimeDataStruct-Runtime_Data_Std_FreezeFrame_Data,F5 7E 00 00 13 20 0B 30 12 0A,
ENG07119-ENG36292,RuntimeDataStruct-Runtime_Data_unlearn_counter,114,
ENG07127,Selector_Counter_Handshake_Resets,0,
ENG108912,Selector_lever_position_inverse,Basic setting X,
ENG07121,Selector_Lever_Position_Inverse_Undebounced,Basic setting X,
ENG07120,Selector_Lever_Position_Undebounced,Basic setting X,
ENG07124,Selector_Manual_Lane_Lock_State,closed,
ENG27119,Selector_Park_Lock_Solenoid_Shiftlock_HSS_Value,On,
ENG07122-ENG32542,Selector_Range_Sensor_Error_Status-Selector_Range_Sensor_Error_Status_Path1,no error,
ENG07122-ENG32543,Selector_Range_Sensor_Error_Status-Selector_Range_Sensor_Error_Status_Path2,no error,
ENG07129-ENG33138,WBS_Calib_Thresholds-Threshold_Init_Marker,EOL Written Thresholds,
ENG07129-ENG33139,WBS_Calib_Thresholds-Threshold_Reserved,00 00 00 00 00 00 00 00 00 00 00 00,
ENG07129-ENG07183,WBS_Calib_Thresholds-VALUE_Threshold_A12,-544,
ENG07129-ENG07186,WBS_Calib_Thresholds-VALUE_Threshold_A1X,-164,
ENG07129-ENG07184,WBS_Calib_Thresholds-VALUE_Threshold_A21,-484,
ENG07129-ENG07190,WBS_Calib_Thresholds-VALUE_Threshold_B12,576,
ENG07129-ENG07187,WBS_Calib_Thresholds-VALUE_Threshold_B1X,196,
ENG07129-ENG07189,WBS_Calib_Thresholds-VALUE_Threshold_B21,516,
ENG07129-ENG07207,WBS_Calib_Thresholds-VALUE_Threshold_CRC,27189,
ENG07129-ENG07193,WBS_Calib_Thresholds-VALUE_Threshold_MTM,240,
ENG07129-ENG07196,WBS_Calib_Thresholds-VALUE_Threshold_MTP,-208,
ENG07129-ENG07191,WBS_Calib_Thresholds-VALUE_Threshold_MX,251,
ENG07129-ENG07197,WBS_Calib_Thresholds-VALUE_Threshold_SA12,-544,
ENG07129-ENG07200,WBS_Calib_Thresholds-VALUE_Threshold_SA1X,-164,
ENG07129-ENG07198,WBS_Calib_Thresholds-VALUE_Threshold_SA21,-484,
ENG07129-ENG07204,WBS_Calib_Thresholds-VALUE_Threshold_SB12,576,
ENG07129-ENG07201,WBS_Calib_Thresholds-VALUE_Threshold_SB1X,196,
ENG07129-ENG07203,WBS_Calib_Thresholds-VALUE_Threshold_SB21,516,
ENG07129-ENG07205,WBS_Calib_Thresholds-VALUE_Threshold_SMX,251,
ENG07129-ENG07199,WBS_Calib_Thresholds-VALUE_Threshold_SXA1,-264,
ENG07129-ENG07202,WBS_Calib_Thresholds-VALUE_Threshold_SXB1,296,
ENG07129-ENG07206,WBS_Calib_Thresholds-VALUE_Threshold_SXM,464,
ENG07129-ENG07194,WBS_Calib_Thresholds-VALUE_Threshold_TMM,180,
ENG07129-ENG07195,WBS_Calib_Thresholds-VALUE_Threshold_TPM,-148,
ENG07129-ENG07208,WBS_Calib_Thresholds-VALUE_Threshold_VersionNumber,02,
ENG07129-ENG07185,WBS_Calib_Thresholds-VALUE_Threshold_XA1,-264,
ENG07129-ENG07188,WBS_Calib_Thresholds-VALUE_Threshold_XB1,296,
ENG07129-ENG07192,WBS_Calib_Thresholds-VALUE_Threshold_XM,464,
ENG07130-ENG07213,WBS_Sensor_Voltage-VALUE_WBS_Sensor_0_Volt,3465, mV
ENG07130-ENG07214,WBS_Sensor_Voltage-VALUE_WBS_Sensor_1_Volt,3465, mV
ENG07130-ENG07223,WBS_Sensor_Voltage-VALUE_WBS_Sensor_10_Volt,3431, mV
ENG07130-ENG07224,WBS_Sensor_Voltage-VALUE_WBS_Sensor_11_Volt,3392, mV
ENG07130-ENG07215,WBS_Sensor_Voltage-VALUE_WBS_Sensor_2_Volt,2815, mV
ENG07130-ENG07216,WBS_Sensor_Voltage-VALUE_WBS_Sensor_3_Volt,1749, mV
ENG07130-ENG07217,WBS_Sensor_Voltage-VALUE_WBS_Sensor_4_Volt,2703, mV
ENG07130-ENG07218,WBS_Sensor_Voltage-VALUE_WBS_Sensor_5_Volt,3411, mV
ENG07130-ENG07219,WBS_Sensor_Voltage-VALUE_WBS_Sensor_6_Volt,3392, mV
ENG07130-ENG07220,WBS_Sensor_Voltage-VALUE_WBS_Sensor_7_Volt,3450, mV
ENG07130-ENG07221,WBS_Sensor_Voltage-VALUE_WBS_Sensor_8_Volt,3455, mV
ENG07130-ENG07222,WBS_Sensor_Voltage-VALUE_WBS_Sensor_9_Volt,3358, mV
ENG07130-ENG07225,WBS_Sensor_Voltage-VALUE_WBS_Sensor_Off_Volt,4936, mV
ENG08636-ENG09212,ZF_Coding_Block-ENUM_ZF_Coding_Ausleuchtung,Audi,
ENG08636-ENG09206,ZF_Coding_Block-ENUM_ZF_Coding_Bordnetz,MLBevo,
ENG08636-ENG09223,ZF_Coding_Block-ENUM_ZF_Coding_CodedFlag,coded,
ENG08636-ENG09208,ZF_Coding_Block-ENUM_ZF_Coding_Dimmnachlauf,Feature activated,
ENG08636-ENG09213,ZF_Coding_Block-ENUM_ZF_Coding_LEDdiag,Feature activated,
ENG08636-ENG09216,ZF_Coding_Block-ENUM_ZF_Coding_MLD,Plus ist vorne,
ENG08636-ENG09209,ZF_Coding_Block-ENUM_ZF_Coding_NHaltephase,Feature activated,
ENG08636-ENG09207,ZF_Coding_Block-ENUM_ZF_Coding_ParkLockSolenoid,Feature activated,
ENG08636-ENG09210,ZF_Coding_Block-ENUM_ZF_Coding_Rueckstellmotor,Feature activated,
ENG08636-ENG09215,ZF_Coding_Block-ENUM_ZF_Coding_SMX,Audi,
ENG08636-ENG09211,ZF_Coding_Block-ENUM_ZF_Coding_Sperrmagnet,Feature activated,
ENG08636-ENG09214,ZF_Coding_Block-ENUM_ZF_Coding_Verpolschutz,Transistor,
ENG08636-ENG09222,ZF_Coding_Block-VALUE_ZF_Coding_CodingVersion,01,
ENG08636-ENG09224,ZF_Coding_Block-VALUE_ZF_Coding_CRC,3E,
ENG08636-ENG33389,ZF_Coding_Block-ZF_Coding_Reserved,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07160-ENG07183,ZF_EOL_WBS_Thresholds-VALUE_Threshold_A12,-544,
ENG07160-ENG07186,ZF_EOL_WBS_Thresholds-VALUE_Threshold_A1X,-164,
ENG07160-ENG07184,ZF_EOL_WBS_Thresholds-VALUE_Threshold_A21,-484,
ENG07160-ENG07190,ZF_EOL_WBS_Thresholds-VALUE_Threshold_B12,576,
ENG07160-ENG07187,ZF_EOL_WBS_Thresholds-VALUE_Threshold_B1X,196,
ENG07160-ENG07189,ZF_EOL_WBS_Thresholds-VALUE_Threshold_B21,516,
ENG07160-ENG07207,ZF_EOL_WBS_Thresholds-VALUE_Threshold_CRC,27189,
ENG07160-ENG07193,ZF_EOL_WBS_Thresholds-VALUE_Threshold_MTM,240,
ENG07160-ENG07196,ZF_EOL_WBS_Thresholds-VALUE_Threshold_MTP,-208,
ENG07160-ENG07191,ZF_EOL_WBS_Thresholds-VALUE_Threshold_MX,251,
ENG07160-ENG07197,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SA12,-544,
ENG07160-ENG07200,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SA1X,-164,
ENG07160-ENG07198,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SA21,-484,
ENG07160-ENG07204,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SB12,576,
ENG07160-ENG07201,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SB1X,196,
ENG07160-ENG07203,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SB21,516,
ENG07160-ENG07205,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SMX,251,
ENG07160-ENG07199,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SXA1,-264,
ENG07160-ENG07202,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SXB1,296,
ENG07160-ENG07206,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SXM,464,
ENG07160-ENG07194,ZF_EOL_WBS_Thresholds-VALUE_Threshold_TMM,180,
ENG07160-ENG07195,ZF_EOL_WBS_Thresholds-VALUE_Threshold_TPM,-148,
ENG07160-ENG07185,ZF_EOL_WBS_Thresholds-VALUE_Threshold_XA1,-264,
ENG07160-ENG07188,ZF_EOL_WBS_Thresholds-VALUE_Threshold_XB1,296,
ENG07160-ENG07192,ZF_EOL_WBS_Thresholds-VALUE_Threshold_XM,464,
ENG07133,ZF_NvM_ResetSafeRamApplErrFlags,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07134,ZF_ResetSafeRamErrFlags,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C5 67 3A 98 00 00 00 00 00 00 00 00 A5 00 00 00 00 00 00 00,
ENG08635-ENG09205,ZF_Software_Version_Number-VALUE_Reserved,20,
ENG08635-ENG09203,ZF_Software_Version_Number-VALUE_ZF_Build_Variante,S,
ENG08635-ENG09201,ZF_Software_Version_Number-VALUE_ZF_Kundenkennung,A1,
ENG08635-ENG09202,ZF_Software_Version_Number-VALUE_ZF_Software_Version,4111,
ENG08635-ENG09204,ZF_Software_Version_Number-VALUE_ZF_Version_Timestamp,160728144816,
Elapsed Time: 00:10
adpmap-81-8W1-713-041-G
;Sunday,10,November,2019,20:43:39:01617
IDE00820-Activating and deactivating all development messages,OFF ,1
Elapsed Time: 00:00
Address [A5]
blockmap-A5-8W0-907-217-C
;SW:8W0-907-217-C   HW:8W0-907-217-C ---  Frt Sens. Drv. Assist
;Component:BVS           H17 0050, Coding:0404090100000201022023A2A50000FC00F0C020C000
;EV_BVSMLBevKOSTAAU736,002026,EV_BVSMLBevKOSTAAU736_AU49.rod
;Sunday,10,November,2019,20:43:42:01617
;VCID: BC3B37B6376D76AF3B-80E8
IDE00018,Voltage terminal 15,14.40, V
IDE00102,Control Module temperature,36, °C
IDE00322,Status of basic setting,not active,
IDE00326-MAS02471,Steering wheel angle-Sign,Negative,
IDE00326,Steering wheel angle,362.90, °
IDE00767,No. of unscheduled ECU resets,0,
IDE00925-MAS02471,Yaw rate-Sign,Negative,
IDE00925,Yaw rate,0.03, °/s
IDE00973,Outside air temperature,26.50, °C
IDE01933-MAS01580,Windshield heater for directional stabilization assistance-Activation,blocked,
IDE01935,Camera operating mode,Normal oper.,
IDE01968,Dynamic calibration: yaw angle offset,0.30, °
IDE01969,Dynamic calibration: pitch angle offset,-0.00, °
IDE01970,Dynamic calibration: roll angle offset,-0.00, °
IDE01971,Lowest recorded control module temperature,1, °C
IDE01972,Highest recorded control module temperature,87, °C
IDE02057,Dynamic calibration: status,active,
IDE03222-IDE02608,Blindness detection-Windshield heater for front sensor system,No,
IDE03222-IDE10398,Blindness detection-Self-glare,No,
IDE03222-MAS02534,Blindness detection-Clear view,detected,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03223,Current static calibration status,End of assembly line OK,
IDE03224-MAS00106,Current static calibration: details-Year,2018,
IDE03224-MAS00107,Current static calibration: details-Month,3,
IDE03224-MAS00108,Current static calibration: details-Day,1,
IDE03224-MAS00109,Current static calibration: details-Hours,22,
IDE03224-MAS00110,Current static calibration: details-Minutes,45,
IDE03224-MAS00111,Current static calibration: details-Seconds,56,
IDE03224-MAS00711,Current static calibration: details-Odometer reading,1, km
IDE03224-MAS01632,Current static calibration: details-Status,No calibration relevant malfunction,
IDE03224-MAS02489,Current static calibration: details-Vehicle Identification Number (VIN),WAUENAF47JA147898,
IDE03224-MAS02541,Current static calibration: details-Rear projection fault,0,
IDE03224-MAS02542,Current static calibration: details-Calibration marks,00000000 ,
IDE03224-MAS03010,Current static calibration: details-Focal length,1532,
IDE03224-MAS03075,Current static calibration: details-Calibration point X coordinates on imaging sensor,633,
IDE03224-MAS03076,Current static calibration: details-Calibration point Y coordinates on imaging sensor,480,
IDE03224,Current static calibration: details,00000000 ,
IDE03225-MAS02545,Last static calibrations: details-Last,No calibration relevant malfunction,
IDE03225-MAS02546,Last static calibrations: details-Second to last,Calibration not yet performed,
IDE03225-MAS02547,Last static calibrations: details-Third to last,Calibration not yet performed,
IDE03225-MAS02548,Last static calibrations: details-Fourth to last,Calibration not yet performed,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS05634,Dynamic calibration: details-Progress,0, %
IDE04036,High beam assistant: status,not active,
IDE04037,High beam recommendation,OFF,
IDE04123,High beam: reason for shut-off,0,
IDE04125,Visibility,Not Used,
IDE04312-MAS00084,System run time-Terminal 15 on,3984.10,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,not calculated,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07214,Dynamic calibration: camera height offset,0, mm
IDE07543,Vehicle speed,0.00, km/h
IDE08447,Driving axis angle,NO VALUE AVAILABLE,
IDE08515-MAS01849,Matrix light: dimming-Left,Initializing,
IDE08515-MAS01850,Matrix light: dimming-Right,Initializing,
IDE08706-MAS06932,Actual angle of ref. segments-Horizontal angle reference segment left,NO VALUE AVAILABLE,
IDE08706-MAS06933,Actual angle of ref. segments-Horizontal angle reference segment right,NO VALUE AVAILABLE,
IDE08706-MAS06934,Actual angle of ref. segments-Vertical angle reference segment left,NO VALUE AVAILABLE,
IDE08706-MAS06935,Actual angle of ref. segments-Vertical angle reference segment right,NO VALUE AVAILABLE,
IDE08713-MAS06936,Matrix light: calculated offset values-Horizontal offset: light left,NO VALUE AVAILABLE,
IDE08713-MAS06937,Matrix light: calculated offset values-Horizontal offset: light right,NO VALUE AVAILABLE,
IDE08713-MAS06938,Matrix light: calculated offset values-Vertical offset: light left,NO VALUE AVAILABLE,
IDE08713-MAS06939,Matrix light: calculated offset values-Vertical offset: light right,NO VALUE AVAILABLE,
IDE08714-MAS06929,Axle offsets-Axle offset front,NO VALUE AVAILABLE,
IDE08714-MAS06930,Axle offsets-Axle offset rear,NO VALUE AVAILABLE,
IDE08715,Func. status matrix high beam,not active,
IDE09390-MAS08938,Object collision warning: function-Setting pre sense pre-warning in MMI,Medium,
IDE09390-MAS08939,Object collision warning: function-Setting pre sense system in MMI,On,
IDE09390-MAS08941,Object collision warning: function-Collision warning: availability,Available,
IDE09390-MAS08942,Object collision warning: function-Pre-warning: quantity,21,
IDE09390-MAS08943,Object collision warning: function-Pre-filling: quantity,12,
IDE09390-MAS08944,Object collision warning: function-Warning jolt: quantity,1,
IDE09390-MAS08945,Object collision warning: function-Pre-filling: operating time,9, s
IDE09424,Number of recognized lane markings,0,
IDE09433-MAS01632,Perception module for light assistant-Status,active,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,1022, m
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,1022, m
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,25.60, °
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,25.60, °
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,35.10, °
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,35.10, °
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,51.10, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,51.10, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,Initializing,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,Initializing,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,Initializing,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,Yes,
IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,6.30, °
IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,6.30, °
IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,6.30, °
IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,6.30, °
IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,6.30, °
IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,6.30, °
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,No object,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,No object,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,active,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Right hand driv.,
IDE10091-MAS08941,Driver warning if risk of collision with pedestrian-Collision warning: availability,Available,
IDE10091-MAS11652,Driver warning if risk of collision with pedestrian-Pedestrian detection adjustment pre-warning in central computer,Medium,
IDE10091-MAS11653,Driver warning if risk of collision with pedestrian-Pedestrian detection adjustment acute warning in central comp.,On,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,31,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,20,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,0,
ENG118139-ENG04086,function_state-Activation_AEB_ped,On,
ENG118139-ENG04087,function_state-Activation_AEB_veh,On,
ENG118139-ENG04088,function_state-Activation_DTEB_ped,On,
ENG118139-ENG04089,function_state-Activation_DTEB_veh,On,
ENG118139-ENG04090,function_state-Activation_ped_at_night,On,
ENG118139-ENG04084,function_state-Activation_prefill_ped,On,
ENG118139-ENG04085,function_state-Activation_prefill_veh,On,
Elapsed Time: 00:27
adpmap-A5-8W0-907-217-C
;Sunday,10,November,2019,20:44:10:01617
IDE02066-Windshield heat. direct. stabilize. assist. activation duration,2 min,1
IDE07358-Distance to calibration field,1500.00 mm,2
IDE08447-Driving axis angle,6 ',1
IDE09375-IDE05717-Axle offset-Front axle transverse position,0.10 mm,4
IDE09375-IDE05718-Axle offset-Rear axle transverse position,0.20 mm,4
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,716.25 mm,8
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,715.25 mm,8
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,721.50 mm,8
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,720.50 mm,8
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,3000.00 mm,24
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,1230.00 mm,24
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1835.00 mm,24
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,3000.00 mm,24
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,1120.00 mm,24
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1835.00 mm,24
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,3000.00 mm,24
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,-1120.00 mm,24
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,1835.00 mm,24
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,3000.00 mm,24
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-1230.00 mm,24
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,1835.00 mm,24
MAS05331-IDE03355-Calibration result-Static calibration: yaw angle,-0.24 °,6
MAS05331-IDE03356-Calibration result-Static calibration: pitch angle,0.25 °,6
MAS05331-IDE03357-Calibration result-Static calibration: roll angle,-0.13 °,6
MAS05331-IDE03358-Calibration result-Static calibration: camera height,1306 mm,6
Elapsed Time: 00:15
Address [BB]
blockmap-BB-4M0-959-795-H
;SW:4M0-959-795-H   HW:4M0-959-795-F ---  Door Rear Drv
;Component:TSG HFS       005 0129, Coding:000F1B2000001080400000A0
;EV_DCU2RearDriveMAXHCONT,001005,EV_DCU2RearDriveMAXHCONT_AU49.rod
;Sunday,10,November,2019,20:44:30:01617
;VCID: C5CD525244A7376754-8090
IDE00310,Outside air temperature,25.50, °C
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,14.40, V
IDE04580,Dimming of inside door handle lighting,58, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not activated,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05725,Terminal 58xs dimmer,58, %
IDE05726,Terminal 58xd dimmer,2, %
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,not active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Power window control standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,0, A
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06621,Driver side rear power window button,not activated,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,127.50, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,active,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,36, °C
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE08795,Button for rear window shade,not installed,
IDE09301-IDE02266,Window lifter control panel driver side rear-Passenger side rear power window button,not installed,
IDE09301-IDE06621,Window lifter control panel driver side rear-Driver side rear power window button,not activated,
IDE09301-MAS08615,Window lifter control panel driver side rear-Rear sunroof,not installed,
IDE09301-MAS08616,Window lifter control panel driver side rear-Rear sunroof shade,not installed,
MAS06010,Ambient light,100, %
Elapsed Time: 00:12
adpmap-BB-4M0-959-795-H
;Sunday,10,November,2019,20:44:43:01617
IDE00001-MAS10864-Production mode-Reduce reverse threshold,Deactivating ,3
IDE00001-MAS10865-Production mode-Power windows operable with terminal 15 off,Deactivating ,3
IDE00001-MAS10866-Production mode-Reduce switch-on time of lighting,Deactivating ,3
IDE00001-MAS10867-Production mode-Deactivate speed control for power windows,Deactivating ,3
IDE00001-MAS10868-Production mode-Deactivate closing aid,Deactivating ,3
IDE00001-MAS10869-Production mode-Activate test mode for the fold-in mirror,Deactivating ,3
IDE00001-MAS10870-Production mode-Activate test mode for power windows,Deactivating ,3
IDE00001-MAS17286-Production mode-Deactivation of actuation of opening assistance motor: e-lock,Deactivating ,3
IDE00001-MAS17291-Production mode-Deactivation of CarWakeUp due to activation of seatbelt feeder,Deactivating ,3
IDE09067-Side window shade: service mode,Deactivating ,1
ENG117299-Reversing_Threshold_Driver_Side_Rear,90 %,1
Elapsed Time: 00:02
Address [BC]
blockmap-BC-4M0-959-795-H
;SW:4M0-959-795-H   HW:4M0-959-795-F ---  Door Rear Pass
;Component:TSG HBFS      005 0129, Coding:000F1B2000001080400000A0
;EV_DCU2RearPasseMAXHCONT,001005,EV_DCU2RearPasseMAXHCONT_AU49.rod
;Sunday,10,November,2019,20:44:50:01617
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,14.30, V
IDE02266,Passenger side rear power window button,not activated,
IDE04580,Dimming of inside door handle lighting,10, %
IDE05725,Terminal 58xs dimmer,100, %
IDE05726,Terminal 58xd dimmer,5, %
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not activated,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,not active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,0, A
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06941,Rear window regulator child lock: frt.pass. side,active,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,36, °C
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,80.50, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
IDE09259-MAS08489,Seat control unit frt. pass. side rear-Seat position,not installed,
IDE09259-MAS08501,Seat control unit frt. pass. side rear-Position of backrest,not installed,
IDE09302-IDE02266,Window lifter control panel frt. pass. side rear-Passenger side rear power window button,not activated,
IDE09302-IDE06621,Window lifter control panel frt. pass. side rear-Driver side rear power window button,not installed,
IDE09302-MAS08615,Window lifter control panel frt. pass. side rear-Rear sunroof,not installed,
IDE09302-MAS08616,Window lifter control panel frt. pass. side rear-Rear sunroof shade,not installed,
Elapsed Time: 00:13
adpmap-BC-4M0-959-795-H
;Sunday,10,November,2019,20:45:03:01617
ENG117300-Reversing_Threshold_Passenger_Side_Rear,90 %,1
Elapsed Time: 00:02
Address [CA]
blockmap-CA-4M0-907-594-H
;SW:4M0-907-594-H   HW:4M0-907-594 ---  Sunroof
;Component:SAD_STG_1     014 0005, Coding:2A8000049100
;EV_SunRoofCONTIAU736,006008,EV_SunRoofCONTIAU736_006.rod
;Sunday,10,November,2019,20:45:08:01617
;VCID: BB3934AA3263719732-80EE
IDE03114-MAS02447,Comfort function-Release,Not Present,
IDE03114-MAS08867,Comfort function-Request open sliding sunroof,not active,
IDE03114-MAS08868,Comfort function-Request close sliding sunroof,not active,
IDE03114-MAS08869,Comfort function-Request open sunroof shade,Not available,
IDE03114-MAS08870,Comfort function-Request close sunroof shade,Not available,
IDE03421-MAS09452,Hall sensors for position detection-Hall sensor for sunroof motor,Not operated,
IDE03421-MAS09453,Hall sensors for position detection-Sunroof motor Hall sensor 2,operated,
IDE03421-MAS09454,Hall sensors for position detection-Hall sensor for roof blind motor,not installed,
IDE03421-MAS09455,Hall sensors for position detection-Hall sensor 2 for roof blind motor,not installed,
IDE09422-MAS02282,Roof Blind-Position,not installed,
IDE09422-MAS05370,Roof Blind-Direction of movement,not installed,
IDE09422-MAS05563,Roof Blind-Norming,not installed,
IDE09422-MAS08536,Roof Blind-Excessive temperature protection,not installed,
IDE09422-MAS08862,Roof Blind-Reversing,not installed,
IDE09422-MAS08866,Roof Blind-Adaption depth,not installed,
IDE09423-MAS02282,Sunroof-Position,0, %
IDE09423-MAS05370,Sunroof-Direction of movement,Not moving,
IDE09423-MAS05563,Sunroof-Norming,normed,
IDE09423-MAS05737,Sunroof-Position,Tilt out posi.,
IDE09423-MAS08536,Sunroof-Excessive temperature protection,not active,
IDE09423-MAS08862,Sunroof-Reversing,not active,
IDE09423-MAS08866,Sunroof-Adaption depth,100, %
IDE09427-MAS08536,Control module counter readings-Excessive temperature protection,0,
IDE09427-MAS08872,Control module counter readings-Resets due to interruption of supply voltage,13,
IDE09427-MAS08873,Control module counter readings-Resets to hardware watchdog,1,
IDE09427-MAS08874,Control module counter readings-Resets due to software watchdog,0,
IDE09428-MAS05563,Sunroof counter readings-Norming,3,
IDE09428-MAS08536,Sunroof counter readings-Excessive temperature protection,0,
IDE09428-MAS08862,Sunroof counter readings-Reversing,1,
IDE09428-MAS10406,Sunroof counter readings-Opening runs: sliding pos.,195,
IDE09428-MAS10407,Sunroof counter readings-Opening runs: tilted pos.,56,
IDE09428-MAS10408,Sunroof counter readings-Closing runs,244,
IDE09429-MAS05563,Sunroof shade counter readings-Norming,not installed,
IDE09429-MAS08536,Sunroof shade counter readings-Excessive temperature protection,not installed,
IDE09429-MAS08862,Sunroof shade counter readings-Reversing,not installed,
IDE09429-MAS08871,Sunroof shade counter readings-Opening cycles,not installed,
IDE09430-MAS00106,History data sunroof reversing-Year,2000,
IDE09430-MAS00107,History data sunroof reversing-Month,2,
IDE09430-MAS00108,History data sunroof reversing-Day,21,
IDE09430-MAS00109,History data sunroof reversing-Hours,0,
IDE09430-MAS00110,History data sunroof reversing-Minutes,29,
IDE09430-MAS00111,History data sunroof reversing-Seconds,14,
IDE09430-MAS00370,History data sunroof reversing-Vehicle speed,655.35, km/h
IDE09430-MAS01453,History data sunroof reversing-Blocking detection,not active,
IDE09430-MAS01634,History data sunroof reversing-Supply voltage,14.00, V
IDE09430-MAS02282,History data sunroof reversing-Position,56, %
IDE09430-MAS02289,History data sunroof reversing-Outside air temperature,25.00, °C
IDE09430-MAS05622,History data sunroof reversing-Cold start,not active,
IDE09430-MAS05737,History data sunroof reversing-Position,Slid.position,
IDE09430-MAS09456,History data sunroof reversing-Counter reading sunroof reversals,1,
IDE09430-MAS10923,History data sunroof reversing-Absolute Position,981,
IDE09430-MAS10991,History data sunroof reversing-Restart,not active,
IDE09430-MAS10992,History data sunroof reversing-Absolute start position,1199,
IDE09492-MAS01155,Temperatures-Control module,23.00, °C
IDE09492-MAS06997,Temperatures-Outside temperature: filtered,25.50, °C
IDE09492-MAS09033,Temperatures-Motor for sunroof,24.00, °C
IDE09492-MAS09047,Temperatures-Roof shade motor,not installed,
IDE09515-MAS08884,Controls-Sunroof button,not activated,
IDE09515-MAS08932,Controls-Sunroof shade button,not installed,
IDE09515-MAS08992,Controls-Button for sliding roof,not activated,
IDE09515-MAS12701,Controls-Search lights,Current cannot be measured,
IDE09516-MAS04194,Status of child safety-Driver side,active,
IDE09516-MAS04195,Status of child safety-Frt. pass. side,active,
IDE09517-IDE00075,Control module-Vehicle speed,0.00, km/h
IDE09517-MAS02447,Control module-Release,present,
IDE09517-MAS07376,Control module-Terminal 58xd,90,
IDE09517-MAS07720,Control module-Terminal 15 via CAN,On,
IDE09517-MAS08536,Control module-Excessive temperature protection,not active,
IDE09517-MAS09820,Control module-Terminal 58xt,90, %
IDE09517-MAS11498,Control module-Panel lighting for controls,81, %
IDE09517-MAS11499,Control module-Rear indicator light for tilting sunroof,not installed,
IDE09518-MAS01634,Voltages and currents-Supply voltage,14.40, V
IDE09518-MAS09048,Voltages and currents-Motor current consumption for sun roof,0.00, A
IDE09518-MAS09049,Voltages and currents-Motor current consumption for roof blind,not installed,
IDE09844-MAS00106,History data sunroof standardization-Year,2018,
IDE09844-MAS00107,History data sunroof standardization-Month,3,
IDE09844-MAS00108,History data sunroof standardization-Day,2,
IDE09844-MAS00109,History data sunroof standardization-Hours,6,
IDE09844-MAS00110,History data sunroof standardization-Minutes,14,
IDE09844-MAS00111,History data sunroof standardization-Seconds,30,
IDE09844-MAS00370,History data sunroof standardization-Vehicle speed,0.00, km/h
IDE09844-MAS01155,History data sunroof standardization-Control module,16.00, °C
IDE09844-MAS01634,History data sunroof standardization-Supply voltage,12.20, V
IDE09844-MAS02289,History data sunroof standardization-Outside air temperature,21.00, °C
IDE09844-MAS04447,History data sunroof standardization-Engine running status,Motor not running,
IDE09844-MAS09458,History data sunroof standardization-Counter reading sunroof calibrations,3,
IDE09846-MAS00106,History data sunroof control point-Year,2019,
IDE09846-MAS00107,History data sunroof control point-Month,11,
IDE09846-MAS00108,History data sunroof control point-Day,3,
IDE09846-MAS00109,History data sunroof control point-Hours,19,
IDE09846-MAS00110,History data sunroof control point-Minutes,8,
IDE09846-MAS00111,History data sunroof control point-Seconds,54,
IDE09846-MAS02282,History data sunroof control point-Position,87, %
IDE09846-MAS05737,History data sunroof control point-Position,Tilt out posi.,
IDE09846-MAS09430,History data sunroof control point-Operating pts.,Sunroof button,
IDE09916-MAS09563,Data set names-Number of data set names,1,
IDE09916-MAS09564,Data set names-Data set ID,71 00,
IDE09916-MAS09565,Data set names-Data set name,049100AU4910,
IDE11840-MAS13333,Operating signals for sunroof/tilt roof and roof blind-Operating signals of roof shade,not activated,
IDE11840-MAS13334,Operating signals for sunroof/tilt roof and roof blind-Front operating signals: rear roof shade,not activated,
IDE11840-MAS13335,Operating signals for sunroof/tilt roof and roof blind-Rear operating signals: rear roof shade,Unknown (255),
IDE11840-MAS13364,Operating signals for sunroof/tilt roof and roof blind-Operating signal sliding/tilting roof,not activated,
Elapsed Time: 00:04
adpmap-CA-4M0-907-594-H
;Sunday,10,November,2019,20:45:13:01617
IDE00001-Production mode,not active ,3
IDE02104-IDE03633-Temperature dependent activation-Close sunroof,not active ,1
IDE02104-MAS09030-Temperature dependent activation-Open sun roof,active ,1
IDE02104-MAS09031-Temperature dependent activation-Open roof blind,not active ,1
IDE02104-MAS09032-Temperature dependent activation-Close roof blind,not active ,1
IDE09435-IDE03633-Speed dependent activation-Close sunroof,not active ,1
IDE09435-MAS09030-Speed dependent activation-Open sun roof,not active ,1
IDE09435-MAS09031-Speed dependent activation-Open roof blind,not active ,1
IDE09435-MAS09032-Speed dependent activation-Close roof blind,not active ,1
IDE09439-MAS08884-Logic switch-over: controls-Sunroof button,not active ,1
IDE09439-MAS08932-Logic switch-over: controls-Sunroof shade button,not active ,1
IDE09439-MAS08992-Logic switch-over: controls-Button for sliding roof,not active ,1
IDE09439-MAS10443-Logic switch-over: controls-Button for sunroof/tilt roof: rear,not active ,1
IDE09439-MAS10444-Logic switch-over: controls-Sunroof shade button: rear,not active ,1
IDE09451-MAS08936-Travel path-Tilted position: max. opening width,not active ,1
IDE09451-MAS08937-Travel path-Sliding position: intermed. pos.,not active ,1
IDE09451-MAS08991-Travel path-Sliding position: reduc. opening width,not active ,1
IDE09451-MAS10725-Travel path-Sunroof shade: interm. position open,not active ,1
IDE09451-MAS10726-Travel path-Sunroof shade: interm. position close,not active ,1
IDE11842-IDE09434-Comfort functions-Target position for comfort opening,Tilt out posi. ,1
IDE11842-MAS13329-Comfort functions-Comfort opening of roof shade,active ,1
IDE11842-MAS13330-Comfort functions-Comfort closing of roof shade,active ,1
IDE11842-MAS14142-Comfort functions-Private sphere mode,not active ,1
ENG146366-Applikationmode deactivate,Deactivating ,1
Elapsed Time: 00:03
Address [CF]
adpmap-CF-4M0-907-590-D
;SW:4M0-907-590-D   HW:4M0-907-590 ---  Lane Chge Asst 2
;Component:MRR1Rear      H18 0410, Coding:0E8002
;EV_RearRadarS2BoschAU736,001022,EV_RearRadarS2BoschAU736.rod
;Sunday,10,November,2019,20:45:20:01617
;VCID: B3291C8A1A33B9D7EA-80E6
Elapsed Time: 00:00
blockmap-CF-4M0-907-590-D
;Sunday,10,November,2019,20:45:18:01617
Group,Description,Actual
IDE00018,Voltage terminal 15,Measured value not available,
IDE00019,Voltage terminal 30,14.20, V
IDE00020,Terminal 15 status,On,
IDE00030,Status of actuator test,not active,
IDE00102,Control Module temperature,64, °C
IDE00323,Security Access: Number of invalid keys,0,
IDE01352,Temperature unit,°C,
IDE01763,Dimming,0,
IDE02486,Data logger triggering,not active,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE09387,Dynamic angle offset lane change assist.,-0.17, °
ENG112308,ECU_Serial_Number,FF EF 02 31 52 65 61 72 20 20 20 20 20 32 42 6F,
Elapsed Time: 00:01
Address [D6]
adpmap-D6-7PP-941-572-AB
;SW:7PP-941-572-AB   HW:7PP-941-572-A ---  Light Ctrl Left 2
;Component:LED1L         H09 0003, Coding:
;EV_LEDModLeftMELCOAU736,001004,EV_LEDModLeftMELCOAU736_VW37.rod
;Sunday,10,November,2019,20:45:28:01617
;VCID: 966FC51E69814CFFED-80C2
Elapsed Time: 00:00
blockmap-D6-7PP-941-572-AB
;Sunday,10,November,2019,20:45:22:01617
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE03680-MAS01468,Supply voltages-Terminal 15,14.60, V
IDE03680-MAS09374,Supply voltages-Terminal 56b,0.60, V
IDE03680-MAS09375,Supply voltages-Terminal 56a,Not Used,
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,14.60, V
IDE03680-MAS10129,Supply voltages-Daytime driving light supply,Not Used,
IDE03680-MAS12194,Supply voltages-Supply for logic,14.60, V
IDE06926-IDE02068,History memory: reset counter-Time stamp,00 00 00 00 00,
IDE06926-MAS09176,History memory: reset counter-Reset reason,Unknown (0),
IDE08742-MAS01155,Operating time-Control module,644.83, H
IDE08742-MAS02923,Operating time-Highway light,42.94, H
IDE08742-MAS02946,Operating time-static AFS light,186.60, H
IDE08742-MAS07013,Operating time-All-weather lights,9.07, H
IDE08742-MAS07014,Operating time-Tourist light,0.00, H
IDE08742-MAS07243,Operating time-Low beam,248.82, H
IDE08742-MAS07249,Operating time-High Beam,31.68, H
IDE09774-MAS02923,Number of activations-Highway light,711,
IDE09774-MAS02946,Number of activations-static AFS light,699,
IDE09774-MAS07013,Number of activations-All-weather lights,54,
IDE09774-MAS07014,Number of activations-Tourist light,0,
IDE09774-MAS07243,Number of activations-Low beam,947,
IDE09774-MAS07249,Number of activations-High Beam,232,
IDE09774-MAS10110,Number of activations-Low beam: excessive temp. protect.,0,
IDE09774-MAS10111,Number of activations-Hi beam: excessive temp. protect.,0,
IDE09774-MAS10112,Number of activations-Low beam: excessive temp.,0,
IDE09774-MAS10113,Number of activations-High beam: excessive temp.,0,
IDE09828-MAS00890,Head lamp variant-via CAN,E0 0F,
IDE09828-MAS01155,Head lamp variant-Control module,E0 0F,
IDE10048-MAS01968,Supply information-Fan,Not Used,
IDE10048-MAS09752,Supply information-LED channel 1,Terminal 56b,
IDE10048-MAS09753,Supply information-LED channel 2,Terminal 15,
IDE10048-MAS09754,Supply information-LED channel 3,Terminal 15,
IDE10048-MAS09755,Supply information-Matrixbeam channels,Not Used,
IDE10048-MAS09756,Supply information-High side channel,Not Used,
IDE10073-MAS02201,Matrix beam channel 1-Temperature,-50, °C
IDE10073-MAS04121,Matrix beam channel 1-Voltage,51.00, V
IDE10073-MAS04136,Matrix beam channel 1-Current,10220, mA
IDE10073-MAS09327,Matrix beam channel 1-LED brightness class,Initializing,
IDE10073-ENG14158,Matrix beam channel 1-Brightness_class_Textual,Initializing,
IDE10073-ENG14157,Matrix beam channel 1-Current_Textual,Channel not used,
IDE10073-ENG14162,Matrix beam channel 1-Voltage_Textual,Channel not used,
IDE10074-MAS02201,Matrix beam channel 2-Temperature,-50, °C
IDE10074-MAS04121,Matrix beam channel 2-Voltage,51.00, V
IDE10074-MAS04136,Matrix beam channel 2-Current,10220, mA
IDE10074-MAS09327,Matrix beam channel 2-LED brightness class,Initializing,
IDE10074-ENG14158,Matrix beam channel 2-Brightness_class_Textual,Initializing,
IDE10074-ENG14157,Matrix beam channel 2-Current_Textual,Channel not used,
IDE10074-ENG14162,Matrix beam channel 2-Voltage_Textual,Channel not used,
IDE10075-MAS02201,Matrix beam channel 3-Temperature,-50, °C
IDE10075-MAS04121,Matrix beam channel 3-Voltage,51.00, V
IDE10075-MAS04136,Matrix beam channel 3-Current,10220, mA
IDE10075-MAS09327,Matrix beam channel 3-LED brightness class,Initializing,
IDE10075-ENG14158,Matrix beam channel 3-Brightness_class_Textual,Initializing,
IDE10075-ENG14157,Matrix beam channel 3-Current_Textual,Channel not used,
IDE10075-ENG14162,Matrix beam channel 3-Voltage_Textual,Channel not used,
IDE10076-MAS02201,Matrix beam channel 4-Temperature,-50, °C
IDE10076-MAS04121,Matrix beam channel 4-Voltage,51.00, V
IDE10076-MAS04136,Matrix beam channel 4-Current,10220, mA
IDE10076-MAS09327,Matrix beam channel 4-LED brightness class,Initializing,
IDE10076-ENG14158,Matrix beam channel 4-Brightness_class_Textual,Initializing,
IDE10076-ENG14157,Matrix beam channel 4-Current_Textual,Channel not used,
IDE10076-ENG14162,Matrix beam channel 4-Voltage_Textual,Channel not used,
IDE10077-MAS02201,Matrix beam channel 5-Temperature,-50, °C
IDE10077-MAS04121,Matrix beam channel 5-Voltage,51.00, V
IDE10077-MAS04136,Matrix beam channel 5-Current,10220, mA
IDE10077-MAS09327,Matrix beam channel 5-LED brightness class,Initializing,
IDE10077-ENG14158,Matrix beam channel 5-Brightness_class_Textual,Initializing,
IDE10077-ENG14157,Matrix beam channel 5-Current_Textual,Channel not used,
IDE10077-ENG14162,Matrix beam channel 5-Voltage_Textual,Channel not used,
IDE10078-MAS02201,Matrix beam channel 6-Temperature,-50, °C
IDE10078-MAS04121,Matrix beam channel 6-Voltage,51.00, V
IDE10078-MAS04136,Matrix beam channel 6-Current,10220, mA
IDE10078-MAS09327,Matrix beam channel 6-LED brightness class,Initializing,
IDE10078-ENG14158,Matrix beam channel 6-Brightness_class_Textual,Initializing,
IDE10078-ENG14157,Matrix beam channel 6-Current_Textual,Channel not used,
IDE10078-ENG14162,Matrix beam channel 6-Voltage_Textual,Channel not used,
IDE10079-MAS02201,Matrix beam channel 7-Temperature,-50, °C
IDE10079-MAS04121,Matrix beam channel 7-Voltage,51.00, V
IDE10079-MAS04136,Matrix beam channel 7-Current,10220, mA
IDE10079-MAS09327,Matrix beam channel 7-LED brightness class,Initializing,
IDE10079-ENG14158,Matrix beam channel 7-Brightness_class_Textual,Initializing,
IDE10079-ENG14157,Matrix beam channel 7-Current_Textual,Channel not used,
IDE10079-ENG14162,Matrix beam channel 7-Voltage_Textual,Channel not used,
IDE10080-MAS02201,Matrix beam channel 8-Temperature,-50, °C
IDE10080-MAS04121,Matrix beam channel 8-Voltage,51.00, V
IDE10080-MAS04136,Matrix beam channel 8-Current,10220, mA
IDE10080-MAS09327,Matrix beam channel 8-LED brightness class,Initializing,
IDE10080-ENG14158,Matrix beam channel 8-Brightness_class_Textual,Initializing,
IDE10080-ENG14157,Matrix beam channel 8-Current_Textual,Channel not used,
IDE10080-ENG14162,Matrix beam channel 8-Voltage_Textual,Channel not used,
IDE10081-MAS02526,High side channel-Activation,Channel not used,
IDE10081-MAS04136,High side channel-Current,Channel not used,
IDE10081-MAS09022,High side channel-PWM value,Channel not used,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,50, °C
IDE10165-MAS04136,LED channel 1: Master 1-Current,0, mA
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,0.00, %
IDE10165-MAS09326,LED channel 1: Master 1-Function,Low beam,
IDE10165-MAS09327,LED channel 1: Master 1-LED brightness class,2,
IDE10166-MAS02201,LED channel 1: Master 2-Temperature,Channel not used,
IDE10166-MAS04136,LED channel 1: Master 2-Current,Channel not used,
IDE10166-MAS09022,LED channel 1: Master 2-PWM value,Channel not used,
IDE10166-MAS09326,LED channel 1: Master 2-Function,no function,
IDE10166-MAS09327,LED channel 1: Master 2-LED brightness class,Channel not used,
IDE10167-MAS02201,LED channel 1: Slave-Temperature,50, °C
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS09022,LED channel 1: Slave-PWM value,0.00, %
IDE10167-MAS09326,LED channel 1: Slave-Function,Low beam,
IDE10167-MAS09327,LED channel 1: Slave-LED brightness class,2,
IDE10168-MAS02201,LED channel 2: Master-Temperature,43, °C
IDE10168-MAS04136,LED channel 2: Master-Current,0, mA
IDE10168-MAS09022,LED channel 2: Master-PWM value,0.00, %
IDE10168-MAS09326,LED channel 2: Master-Function,static AFS light,
IDE10168-MAS09327,LED channel 2: Master-LED brightness class,2,
IDE10169-MAS02201,LED channel 2: Slave-Temperature,Channel not used,
IDE10169-MAS04136,LED channel 2: Slave-Current,Channel not used,
IDE10169-MAS09022,LED channel 2: Slave-PWM value,Channel not used,
IDE10169-MAS09326,LED channel 2: Slave-Function,no function,
IDE10169-MAS09327,LED channel 2: Slave-LED brightness class,Channel not used,
IDE10170-MAS02201,LED channel 3: Master-Temperature,46, °C
IDE10170-MAS04136,LED channel 3: Master-Current,0, mA
IDE10170-MAS09022,LED channel 3: Master-PWM value,0.00, %
IDE10170-MAS09326,LED channel 3: Master-Function,High Beam,
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,1,
IDE10171-MAS02201,LED channel 3: Slave-Temperature,Channel not used,
IDE10171-MAS04136,LED channel 3: Slave-Current,Channel not used,
IDE10171-MAS09022,LED channel 3: Slave-PWM value,Channel not used,
IDE10171-MAS09326,LED channel 3: Slave-Function,no function,
IDE10171-MAS09327,LED channel 3: Slave-LED brightness class,Channel not used,
IDE10172-MAS01482,Matrix light power output stage-Hardwareversion,not installed,
IDE10172-MAS01483,Matrix light power output stage-Softwareversion,not installed,
IDE10173-MAS09336,Operating times in temperature ranges-°C,0.00, H
IDE10173-MAS09337,Operating times in temperature ranges-between 105°C and 115°C,0.00, H
IDE10173-MAS09338,Operating times in temperature ranges-over 115°C,0.00, H
IDE10173-MAS09378,Operating times in temperature ranges-between -40°C and 95°C,644.83, H
IDE10205,Control module version,Max,
IDE10206-MAS09945,Fan for headlight-Fan 1: current,not installed,
IDE10206-MAS09946,Fan for headlight-Fan 2: current,not installed,
IDE10206-MAS11628,Fan for headlight-Fan 1: activation,not installed,
IDE10206-MAS11629,Fan for headlight-Fan 2: activation,not installed,
IDE10217-MAS07118,Temperatures Matrixbeam-Sensor 1,not installed,
IDE10217-MAS07119,Temperatures Matrixbeam-Sensor 2,not installed,
IDE10217-MAS07120,Temperatures Matrixbeam-Sensor 3,not installed,
IDE10218-MAS07118,LED brightness classes Matrixbeam-Sensor 1,not installed,
IDE10218-MAS07119,LED brightness classes Matrixbeam-Sensor 2,not installed,
IDE10218-MAS07120,LED brightness classes Matrixbeam-Sensor 3,not installed,
IDE10218-ENG14159,LED brightness classes Matrixbeam-Sensor_1_Textual,not installed,
IDE10218-ENG14160,LED brightness classes Matrixbeam-Sensor_2_Textual,not installed,
IDE10218-ENG14161,LED brightness classes Matrixbeam-Sensor_3_Textual,not installed,
IDE10282-MAS09752,LED channels: voltages-LED channel 1,0.00, V
IDE10282-MAS09753,LED channels: voltages-LED channel 2,0.00, V
IDE10282-MAS09754,LED channels: voltages-LED channel 3,0.00, V
IDE10864-MAS11561,Control mod. temperatures-Power output stage for LED,62, °C
IDE10864-MAS11562,Control mod. temperatures-Matrix light power output stage,Channel not used,
Elapsed Time: 00:05
Address [D7]
blockmap-D7-7PP-941-572-AB
;SW:7PP-941-572-AB   HW:7PP-941-572-A ---  Light Ctrl Right 2
;Component:LED1R         H09 0003, Coding:
;EV_LEDModRightMELCOAU736,001004,EV_LEDModLeftMELCOAU736_VW37.rod
;Sunday,10,November,2019,20:45:31:01617
IDE03680-MAS01468,Supply voltages-Terminal 15,14.50, V
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,14.50, V
IDE03680-MAS12194,Supply voltages-Supply for logic,14.50, V
IDE08742-MAS01155,Operating time-Control module,644.67, H
IDE08742-MAS02946,Operating time-static AFS light,187.03, H
IDE08742-MAS07243,Operating time-Low beam,248.66, H
IDE09774-MAS02946,Number of activations-static AFS light,690,
IDE09774-MAS07243,Number of activations-Low beam,946,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,41, °C
IDE10167-MAS02201,LED channel 1: Slave-Temperature,41, °C
IDE10168-MAS02201,LED channel 2: Master-Temperature,36, °C
IDE10168-MAS09327,LED channel 2: Master-LED brightness class,3,
IDE10170-MAS02201,LED channel 3: Master-Temperature,38, °C
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,2,
IDE10173-MAS09378,Operating times in temperature ranges-between -40°C and 95°C,644.67, H
IDE10864-MAS11561,Control mod. temperatures-Power output stage for LED,46, °C
Elapsed Time: 00:05
adpmap-D7-7PP-941-572-AB
;Sunday,10,November,2019,20:45:37:01617
Elapsed Time: 00:00
OBD-II
blockmap-OBD
;33-OBD2
;Sunday,10,November,2019,20:45:41:01617
03,Fuel system 1/2 status,Closed loop,,using O2 sensors,Engine off
04,Calculated load value,13.3 %,13.3 %
05,Engine coolant temperature,108 °C,107 °C
06,Short Term Trim - Bank 1,0.0 %
07,Long Term Trim - Bank 1,5.5 %
0B,Intake Manifold Absolute Pressure,32 kPa abs
0C,Engine RPM,798 /min,798 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,5.0 Degrees
0F,Intake air temperature,59 °C
11,Throttle position sensor,11.4 %
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.790 V
1C,OBD Requirements Met,OBD + OBD II
1F,Time since engine start,1638 s
21,Distance travelled with MIL on,0 km
23,Fuel Rail Press (rel),5390 kPa rel
2E,Commanded Evaporative Purge,0.0 %
2F,Fuel Level Input,56.9 %
30,Warm-ups since DTC cleared,0
31,Distance since DTC cleared,0 km
33,Barometric pressure,102 kPa abs
34,Bank 1 Sensor 1 Status,1.004 Lambda,-0.016 mA
3C,B1S1 Cat. Temp.,414.2 °C
42,Control module voltage,12.910 V,13.300 V
43,Absolute Load Value,20 %
44,Commanded Equivalence Ratio,1.004 Lambda
45,Relative Throttle Position,2 %
46,Ambient Air Temp,27 °C
47,Absolute Throttle Position B,11 %
49,Accelerator Pedal Position D,15 %,15 %
4A,Accelerator Pedal Position E,15 %
4C,Commanded Throttle Actuator Control,2 %
51,Fuel type,Gasoline
56,Long term sec. O2 trim bank 1/3,0.0 %
70,Boost Press Ctrl A/B,BP_A act:102 kPa
Type 02 - VIN : WAUENAF47JA147898 (Address E8)
Type 04 - Calibration ID : 8W0259J 0002BVAK (Address E8)
Type 04 - Calibration ID : 8W2155BA00011    (Address E9)
Type 06 - Calibration Verification Number : 94407C3A (Address E8)
Type 06 - Calibration Verification Number : F66A77DF (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 876
    Ignition cycle count : 2481
    Conditions completion count / Specified conditions encountered count
         Catalyst monitor bank 1 : 367 / 876
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 441 / 876
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 111 / 305
         AIR monitor : 0 / 0
         EVAP monitor : 20 / 112
         Secondary O2 Sensor monitor bank 1 : 290 / 876
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
END
drp
Amarton
Europe - Hungary
C?ID=338434
Nice.
Is there a trick to reading the car (open hood or without ignition or other)?
I tried it with VCDS but it was not successful. I see a list of ECUs in the Autosan section, but all the ECU answers are "cannot be reached", excepting
19-Gateway modul.
After trying it with ODIS, it could read all the ECUs.
