Sunday,10,November,2019,18:21:18:20443
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: 3VWH17AU0KM505639 License Plate:
Mileage: 3062km-1902mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B
52 5F 75 A5 CA D6 D7
VIN: 3VWH17AU0KM505639 Mileage: 3062km-1902miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311D00322466002F1000
Shop #: WSC 00066 790 00223
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: 46C0BFABF9E8367FDD-8012
Part No SW: 0D9 300 018 HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01810111233
ROD: EV_TCMDQ250021.rod
VCID: 59FA64D75856A98780-800C
Part No SW: 5Q0 614 517 DT HW: 5Q0 614 517 BP
Component: ESC H35 0108
Revision: 00000000 Serial number: 53198000000108
Coding: 43FA6AA130200971807D0303A0CC29C2560C9001C005943436435050F0A94B0B0040010312121212B435351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 06407FABB968F67F9D-8052
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0501826337
Coding: 132C0C0723
VCID: 43C6A6BFCADA0357FA-8016
Part No SW: 5GM 907 044 G HW: 5GM 907 044 G
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 0202002420011800010400001211140A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
VCID: 48DCB193F3FC200F2F-801C
Part No SW: 5Q0 937 087 BA HW: 5Q0 937 087 BA
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: C86410121801KL
Shop #: WSC 00066 790 00248
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7BB61E5FF2AABB97F2-802E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 181015 043 0551
Serial number: 97022066181025162033
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SAY18M09D28H15M27S10
Coding: 00A8DD
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 M HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0300311220180C204692
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000137089R18327
Coding: 0271167811
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000.rod
VCID: 51EA9CF700A6E1C778-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 350000C141FFC728949C810520401600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
VCID: 44C4A5A3CFD4046FC3-8010
Component: AirbagVW20 010 0830
Serial number: 003GCR0AKW5$
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47DEB2AFFEE22F7726-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH00000000000ARN0R4
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 002 909 18
Serial number: 35700000000868A4543K
Subsystem 3 - Part No SW: ----------- HW: 480 001 310 18
Serial number: 358000000008E2DCF431
Subsystem 4 - Part No SW: ----------- HW: 480 402 108 18
Component: SideSensor_Dr 004 6149
Serial number: 3510001302B78F25E2B4
Subsystem 5 - Part No SW: ----------- HW: 480 400 709 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001A12BD5EC105ED
Subsystem 6 - Part No SW: ----------- HW: 480 401 911 18
Component: FrontSensor_D 004 6149
Serial number: 3550001162B75362670R
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 911 18
Component: FrontSensor_P 004 6149
Serial number: 35600010C2B81A91C588
Part No SW: 5G1 920 840 D HW: 5G1 920 840 D
Component: KOMBI 252 2500
Coding: 0BA4101DED88CF0502886A0B5001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009065
VCID: 281C111353BCC00FCF-807C
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 17121800841258
Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000
Shop #: WSC 00066 790 00160
ROD: EV_GatewNF.rod
VCID: 6E90270BB1D8DE3F45-803A
Component: 0-00-0d-00-04
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 33180001718320061439
Coding: 2CFFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: U13DCAC H25 0780
Serial number: 0009788
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00022.10.18
Coding: 0001
VCID: 4CD48D83E784CC2F0B-8018
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H07 0021
Serial number: 18000331166008
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 312AFC77606681C718-8064
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0497282424
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D32D047AC3E75A78C-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0501866583
Coding: 020111
Part No SW: 5Q4 959 593 M HW: 5Q4 959 593 F
Component: TSG FS 006 0247
Serial number: 42038833801766
Coding: 003A13200000040000000000
VCID: 4FEE9A8F1692F7376E-801A
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000001368269
Coding: 011000
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 172 1081
Coding: 930A0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 50EC99F30BACE8CF77-8004
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1JMD03NTQJ
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E10E70B71589E3F05-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 18121800840126
Coding: 000000050900211200110F01030000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3522C867940EADE744-8060
Part No SW: 5Q4 959 592 M HW: 5Q4 959 592 F
Component: TSG BFS 006 0247
Serial number: 46038835100044
VCID: 4ED0878B1198FE3F65-801A
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000001365337
Coding: 091000
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 853 0890
Coding: 027312020000000041220002001808009F0508F401200505C6
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 3326F67F9A7AB3D76A-8066
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav 252 8130
Serial number: VWZ6ZMV3525116
Subsystem 2 - Part No SW: 5NA 919 866 E HW: -----------
Component: NAR 2018/19 --- 0810
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02730202C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0610
Serial number: 31101815P12171
Coding: 000307020002020100221354C150490084000E20012000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002_VW37.rod
VCID: 40CCA9B3DBCC184FE7-8014
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 00804073720C
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 393AC457B8164987A0-806C
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
0800 - Bulb for Low-Beam Headlamp
C1198 F6 [040] - Over-Temp Protection Active
Reset counter: 0
Mileage: 534 km
Date: 2019.08.28
Time: 15:18:58
End----------(Elapsed Time: 01:47, VBatt start/end: 12.5V/12.4V)-----------
