Results 1 to 7 of 7
Thread: 2004 A4 1.8T Engine Misfires
    Nov 2019
    Vernon, British Columbia
    This is my first post here and one of very few forum posts, correct me if I'm doing this wrong. Love my Audi's but need some help.
    Happened Immediately following replacement of a cracked Air / Smog Pump Check Valve
    So a quick back story. Car was noted to run a bit rough on a road trip. Noticed smog pump check valve was cracked and leaking. Duct tape repair got us home nicely running smooth with no issues. Ordered a new part from Rock auto. SKP 058905291K Air / Smog Pump Check Valve (8409.91.0090)CAD$ 2.87 BUT!!! as soon as it was fired up instantly running rough, way worse than with the old cracked (broken barbed hose nipple with 100% leak, prior to duct tape fix!!!). The direction of check valve install double-checked. So it would appear to me, as a total rookie, this was just incredible fluke timing. I also checked all the coils as I just went through a similar rough running (not as rough) of my other (Yes I have 2 same year a4 1.8ts) Anyway this car has fairly high Kms and other major issues such as ABS but I dont want it to end this way. Please help. Here's the codes from the first auto Scan.
    Wednesday,13,November,2019,08:52:08:32812
              67 69 75 76 77
    VIN: WAUVC68E14A226867   Mileage: 313700km-194924miles
    Address 01: Engine        Labels: 06B-909-518-AMB.lbl
       Part No SW: 8E0 909 518 AK    HW: 8E0 909 018 A
       Component: 1.8L R4/5VT     G   0004
       Coding: 0016711
       Shop #: WSC 63251 000 00000
       VCID: 79AFEAADC5C1500F8E9-5160
                P0300 - 008 -  - MIL ON
    16687 - Cylinder 3
                P0303 - 008 - Misfire Detected - MIL ON
    16688 - Cylinder 4
                P0304 - 008 - Misfire Detected - MIL ON
    16686 - Cylinder 2
                P0302 - 008 - Misfire Detected
    17834 - EVAP Purge Valve (N80)
                P1426 - 004 - Open Circuit - Intermittent
    Readiness: 0110 1101
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      3429
       Coding: 04275
       Shop #: WSC 06435
       VCID: 2615F1D161FF0FF793B-51F2
    6 Faults Found:
                35-00 - -
    00273 - ABS Inlet Valve; Rear Right (N133)
                35-10 - - - Intermittent
    00274 - ABS Inlet Valve; Rear Left (N134)
                35-00 - -
    01200 - ABS Valves Supply Voltage
    01421 - High Pressure Switch Valve 2 for Electronic Stability Program (N228)
                30-00 - Open or Short to Plus
       Part No: 8E0 820 043 AD
       Component:   A4 Klimaautomat   1450
       Coding: 00000
       Shop #: WSC 93320
       VCID: 6393A8C5524DBADFB45-513C
    01794 - Control Module - Incorrect Chassis (VIN) Number
                35-00 - -
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  KAN 0517
       Coding: 01014
       Shop #: WSC 63251
       VCID: 3537269DAC59746F2A1-4B1E
                57-00 - Electric Circuit Failure
    02104 - Light Detection Sensor (G399)
                29-10 - Short to Ground - Intermittent
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 K
       Component: Airbag 8.4EP        1001
       Coding: 0010607
       VCID: 3FDB44B59B65BE3FF0D-5184
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 01042
       Shop #: WSC 63251
       VCID: 3E2539B1996FB737FBB-4B1E
       Part No: 8E0 920 900 N
       Component: KOMBI+WEGFAHRS. RB4 D42
       Coding: 01331
       Shop #: WSC 93320
       VCID: 2F3B14F54E054EBF60D-5160
       WAUVC68E14A226867     AUZ6Z0D0045326
       Part No: 8E0 959 433 BB
       Component: Komfortgerát T7B    1612
       Coding: 12044
       Shop #: WSC 93320
       VCID: 72BDDD819DB72357CF3-4B1E
       Component: Tőrsteuer.FS BRM 0004
       Component: Tőrsteuer.BF BRM 0004
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0004
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0004
                35-00 - -
    00955 - Key 1
    01034 - Electric Window Thermal Protection Active; Driver
    01705 - Selection Switch for Mirror-Adjust (E48)
                80-00 - Single-Wire Operation
       Part No: 4Z7 907 357
       Coding: 00060
       Shop #: WSC 63251
       VCID: 04518B59B7331DE7EDF-4B3C
       Part No: 8E0 035 195 G
       Component: symphony II NP2    0410
       Coding: 01001
       Shop #: WSC 27649
       VCID: 2B0300E57A2D329F4C5-5066
    End----(Elapsed Time: 05:35, VBatt start/end: 11.2V/11.0V. VIgn 11.0V)-----
  2. Likes AIB Wolfgang liked this post
  3. #2
    Hello and welcome to the VCDS forum OP!
    N80 being sorted for open circuit would be a good start and qualifying vacuum leaks no?
    Compression check and plugs burn rate condition?
    Any FOD?
    Did you JPPSG yet?
  4. Likes Uwe, AIB Wolfgang liked this post
  5. #3
    Almost 200,000 miles!
    I would hunt down and correct whatever is causing the EVAP Purge Valve - Open Circuit DTC first. That could potentially screw up the fuel trims and cause misfires.
    Next, I would clear faults and watch what happens to the fuel trims immediately thereafter.
  6. #4
    Nov 2019
    Any FOD?
    Did you JPPSG yet?
    Thanks, I have not done anything yet. I was hoping for a quick fix LOL. I will do this diagnosis as suggested. It might take me a couple days to get to this. Stay tuned and thanks for responding.
    Nov 2019
    Thanks UWE, I'll check into the Evap Purge Valve. It may be a couple days before I can get to it.
    Nov 2019
    So checked into this a few days ago. Certainly re-learned my lesson should have just taken a close visual inspection and I would have found this sooner. So the short story is I guess this happened when we were changing oil, shoving arm into unscrew oil filter dislodged(broke it must have been ready to let go and it just needed a little nudge) the vacuum exact part# not yet identified but pretty sure its this one. Vacuum Check Valve Breather 058 133 784 AF, 07C 133 529 A I have temporarily epoxied it back together so just need to source a new one. Looks like it comes as whole assembly. I circled the actual broken bit in red and yellow for what my search turned up as a common assembly.
    https://www.dropbox.com/s/fse7yrdwf3...29.03.jpg?dl=0 It runs fine now with the temp fix. I guess I'll scan again for giggles. Next stop ABS brakes!!! Cheers
  9. Likes Jack@European_Parts, Uwe liked this post
  10. #7
    Thanks for report OP!
    Induced FOD wins!
  11. Likes OKAUDIGUY liked this post
