Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Halogen to xenon conversion vw golf gt
    Nov 2016
    2104 golf....fitted all the loom and xenon headlamps with drl factory ones.
    was originally halogen,now xenon.
    they flicker when coming on,then go off.
    can someone advise on what needs to be done now .....as far as the customer has told me is the above.
    Wednesday,13,November,2019,16:07:06:07086
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZAUZEW274749   License Plate: 14 GOLF GT
    Mileage: 153586km-95433mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZEW274749   Mileage: 153586km-95433miles
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 5520
       Revision: 83H22---
       Coding: 011D0012034505082000
       Shop #: WSC 56055 001 104857
       ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
       ROD: EV_ECM20TDI01104L906021DT_002.rod
       VCID: 7AF1E1A6FDC4F79FE9-802E
    17156 - Databus
              U1123 00 [047] - Received Error Message
                        Fault Frequency: 61
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:53
                        Engine speed: 771.00 /min
                        Normed load value: 22.7 %
                        Coolant temperature: 75 °C
                        Intake air temperature: 55 °C
                        Voltage terminal 30: 14.580 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 0
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Acceleration: 0.000 m/s²
       Part No SW: 0D9 300 040 N    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H52 4305
       Revision: 05852204    Serial number: TFK01401100385
       ROD: EV_TCMDQ250021.rod
       VCID: 2241F9C635D45F5F91-8076
    11 Faults Found:
    21153 - Gear 1
              P072C 00 [002] - Not Selectable
    21154 - Gear 2
              P072D 00 [002] - Not Selectable
    21155 - Gear 3
              P072E 00 [002] - Not Selectable
    21156 - Gear 4
              P072F 00 [002] - Not Selectable
    21157 - Gear 5
              P073A 00 [002] - Not Selectable
    21158 - Gear 6
              P073B 00 [002] - Not Selectable
    21159 - Gear R
              P072B 00 [002] - Not Selectable
    10731 - Valve 3 in Transmission Part 1
              P174A 00 [002] - Electrical malfunction
    10732 - Valve 3 in Transmission Part 2
              P174E 00 [002] - Electrical malfunction
    21207 - Pressure Control Solenoid 3
              P0797 00 [002] - Stuck ON
    10906 - Cooling Oil Valve
              P179D 00 [002] - Electrical Malfunction
       Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
       Component: ESC           H31 0557
       Revision: 00000000    Serial number: 600840000002BA
       Coding: 01FA8AA124270970037E060441CC2980512490C0608294F3F8625078C202
       VCID: 7CFDE7BEF7F0C9AFFB-8028
    8309 - Engine Control Module Incorrectly Coded
              P1612 00 [009] - -
                        Fault Frequency: 62
                        Reset counter: 73
                        Date: 2018.07.19
                        Time: 02:07:12
    32951 - Control Module for Electronic Parking Brake
              C10E2 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 67
                        Date: 2018.07.19
                        Time: 02:07:12
       Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
       Component: AC Manuell    H01 0705
       Revision: 00001K06
       Coding: 00120104202100001000000000000000
       VCID: 356B329A945AD8E744-8060
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:53
                        Outside air temperature: 16.5 °C
                        Engine speed: 700 /min
                        Temperature after evaporator: 19.3 °C
                        System run time-Engine running time: 255 s
                        System run time-Terminal 15 on: 255 s
              B10CD 00 [008] - -
                        Fault Frequency: 16
                        Reset counter: 113
                        Mileage: 153575 km
                        Date: 2018.09.29
                        Time: 04:25:58
                        Voltage terminal 30: 10.7 V
       Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
       Component: BCM MQBAB M   H16 0124
       Serial number: 00011402101731
       Coding: 03001842C241027B0BA44080B10403281000000000000000000000000000
       ROD: EV_BCMBOSCH_012.rod
       VCID: 79F3FEAAF8C2FC87E0-802C
       Component: WWS    140113  042 0551
       Serial number:         140115152225
       Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
       Component: RLS  024 0042
       Serial number: Y14M01D28H09M50S48S6
       Coding: 00A8DD
       Serial number: 000000000ZY163083DWY
    10762 - Bulb for Right Tail Light
              B12BF 15 [009] - Open or Short to Plus
                        Reset counter: 74
                        Mileage: 153586 km
                        Date: 2018.10.21
                        Time: 01:29:15
    12307 - License Plate Light
              B12CA 01 [009] - Electrical Failure
                        Reset counter: 74
                        Mileage: 153586 km
                        Date: 2018.10.21
                        Time: 01:29:15
    267012 - No Communications with Anti-Theft Siren / Alarm Horn
              U10F3 00 [009] - -
                        Reset counter: 74
                        Mileage: 153586 km
                        Date: 2018.10.21
                        Time: 01:29:09
       Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0142
       Revision: --------    Serial number: 39331402002548
       Coding: 0071051011
       VCID: 3E792DB6A16C1BBF95-806A
       Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0620
       Coding: 2B00608151FFC728949C810560400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002005
       VCID: 3C7D27BEB77009AFBB-8068
    8 Faults Found:
    2185 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:54
                        Control Module temperature: 39 °C
                        Voltage terminal 15: 14.3 V
                        Status_ACC_System: ACC_irreversible error
    0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:54
              U1101 00 [009] - Active
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:54
    1074 - Databus
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:54
                        Voltage terminal 15: 14.4 V
    1227 - Databus
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:54
    1127 - Databus
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:54
    1218 - Databus
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:54
    1219 - Databus
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:54
       Component: AirbagVW20    014 0386
       Serial number: 003MLR030GBH
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F0710B2E6E6D2B7DE-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34169677B27101540506
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34169676B26101540020
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 112 16
       Serial number: 3576700000044201EE1P
       Subsystem 4 - Part No SW: -----------    HW: 480 000 512 16
       Serial number: 35867000000309053028
       Subsystem 5 - Part No SW: -----------    HW: 480 401 701 14
       Serial number: 3516502B312FAE351214
       Subsystem 6 - Part No SW: -----------    HW: 480 401 801 14
       Serial number: 3526502A513013E3637-
       Subsystem 7 - Part No SW: -----------    HW: 480 402 105 14
       Serial number: 3556502A5156E9F181ET
    9447251 - Seat Occupied Sensor; Passenger's Side
              B1027 53 [009] - Deactivated
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:55
    9634901 - Control Module for Front Left Belt Tensioner
              B1304 55 [009] - Not configured
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:53
    9635157 - Control Module for Front Right Belt Tensioner
              B1305 55 [009] - Not configured
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:54
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 18011404221220
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 7BFFE4A2F2FECE97F2-802E
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
    617752 - ROD - Unknown Error Code
              - 00 [024]
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Reset counter: 111
                        Mileage: 153540 km
                        Date: 2018.07.19
                        Time: 19:33:42
       Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
       Component: KOMBI         204 3390
       Coding: 27A419082780260001886A01040000
       ASAM Dataset: EV_DashBoardJCIMQBAB 008011
       ROD: EV_DashBoardJCIMQBAB_008.rod
       VCID: 2855EBEE53E8B50FCF-807C
    16776960 - Databus
                        Reset counter: 112
                        Mileage: 153574 km
                        Date: 2018.09.26
                        Time: 03:36:23
    16776962 - Databus
                        Reset counter: 112
                        Mileage: 153574 km
                        Date: 2018.09.26
                        Time: 03:36:23
    16776964 - Databus
                        Reset counter: 112
                        Mileage: 153574 km
                        Date: 2018.09.26
                        Time: 03:36:24
    16776961 - Databus
                        Reset counter: 112
                        Mileage: 153574 km
                        Date: 2018.09.26
                        Time: 03:36:23
    16777018 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 111
                        Mileage: 153574 km
                        Date: 2018.09.25
                        Time: 00:39:54
       Revision: --------    Serial number: 0001451211
       Coding: 030100040B087300EF00005C1C0F00010001000000000000000000000000
       ROD: EV_GatewLear_010.rod
       VCID: 3F8750B2A66612B79E-806A
       Serial number: 27160003150250046483
       Coding: 2DFFFF
       Serial number: 3749282303
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:54
                        Supply voltage: Terminal 30: 14.4 V
                        Terminal 15: On
       Serial number: 191116EKI29844
       Coding: 003F1220D001048000001000
       VCID: 438F5C42CA8E7657FA-8016
       Serial number: 00000000000012491354
       Coding: 0D0000
    65799 - Door Warning / Entry Lighting
              B1775 01 [009] - Electrical Failure
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:06:53
       Coding: 8103
       Shop #: WSC 56055 001 1048576
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 4183564AD0926447E8-8014
       Serial number: 201116EKJ2206A
       Coding: 003F1020DE01048000801000
       VCID: 42815946D5947F5FF1-8016
       Serial number: 00000000000012416054
       Coding: 150000
                        Reset counter: 67
                        Mileage: 153521 km
                        Date: 2018.07.19
                        Time: 02:12:23
       Part No SW: 5G0 035 874     HW: 5G0 035 874
       Component: MU-S-ND-ER    040 0430
       Serial number: V7F01301140661
       Coding: 02730001FF00000021111201002800001F0100060100010045
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 67D7A8D29E767A7706-8032
       Component: ABT_Std_Nav  H51 0022
       Serial number: VWZ8Z9PJ903BTA
       Subsystem 2 - Part No SW: 5G0 919 866 F    HW: -----------
       Component:  ECE 2014  --- 0036
    End-------------------------(Elapsed Time: 03:59)--------------------------
    Oct 2014
    For starters, the retrofit should be completed as it appears there is no headlight range module (address 55, AFS master) fitted...
  3. Likes Uwe liked this post
    Nov 2016
    Where is this fitted /located?
    Oct 2014
    I think the stock location would be in the dashboard near the CAN gateway but I'm not sure.
    It's probably also missing the suspension level sensor(s).
    Nov 2016
    Thanks, I suppose that's why they not working properly, il let the guy know.
    hmm......... how were the Leuchte-sets in the BCM re-programmed to accommodation the new HID lamps?
    Retrofitted looms are always problematic in these projects because they can cross-wire the factory arrangement on the BCM connectors. This will have the effect of negating the factory assignment of the Leucthe-sets to particular lamps. The other confounder with retro-fitted (read, third-party) light fittings is that they vary greatly in their ability to be plug-and-play. This can result in highly unpredictable (and completely individual) symptoms.
    But perhaps, reviewing how the car was re-coded after the physical retrofit would be a good starting-point (maybe)?
    EDIT: what's the story on the Component Protection error on hex13 module (with a matching DTC on the CP master module)? Has this car been in an accident - or was the front radar sensor retrofitted as well?
    EDIT 2: .... and as to Langers2K question - was a leveling sensor fitted to the rear axel on the car (is this a legal requirement in UK)?
    Nov 2016
    Cars been accident repaired.
    Also spoke to the guy about xenon, he said he has fitted the kufutec xenon plug and play loom
  9. #8
    Nov 2016
    Don't know, anything else, all I know it's been in an accident, been repaired, xenon headlamps all been off a donor car and fitted to this, with kufutec loom, plug and play
  10. #9
    Quote Originally Posted by vw754 View Post
    Except it's not plug and play since the retrofit isn't working - not unknown for Kufatec 'kits'
    In the UK retrofitting Xenon headlamps is a legal tangle - strictly speaking (under the Road Vehicle Lighting Regulations) Xenon headlamps (except very dim ones like fitted to the Skoda Rapid) are required to have both self levelling and headlamp washers BUT the MOT test only checks that self levelling and headlamps washers work IF FITTED. However, the MOT tester (starting in May 2018) is supposed to check that the headlamps are suitable for Xenon use (which if you have swapped the complete headlamp assembly they will be).
  11. Likes Uwe, DV52 liked this post
  12. #10
    "Plug & Play".
    Kufatec keeps using that phrase.
    I don't think it means what they think it means.
  13. Likes PetrolDave, downtime, NZDubNurd liked this post
