Results 1 to 10 of 10
Thread: Enable DRL Dimming on Indication - VW Jetta MKVII
    Sep 2017
    Brazil
    I enable DRL Dimming on Indication on my 2018 VW Jetta MKVII, following this tweak below:
    (6)-Leuchte2SL VLB10-Dimmwert AB 2 and (6)-Leuchte3SL VRB21-Dimmwert AB 3) is 100
    (12)-Leuchte2SL VLB10-Lichtfunktion E 2 = Blinken links aktiv (beide Phasen)
    (12)-Leuchte3SL VRB21-Lichtfunktion E 3 = Blinken rechts aktiv (beide Phasen)
    (14)-Leuchte3SL VRB21-Dimmwert EF 3 = 26
    (14)-Leuchte2SL VLB10-Dimmwert EF 2 = 26
    (15)-Leuchte2SL VLB10-Dimming Direction EF 2 = minimize
    (15)-Leuchte3SL VRB21-Dimming Direction EF 3 = minimize
    The dimming on indication works well when the light switch is in position "0" but when I turn on the lights (Auto/Positioning Lights/Headlight), I got 2 errors: Check Left and Right DRL.
    Could anybody help me?
    Please find below my Autoscan:
    Monday,11,November,2019,15:19:27:38818
    VIN: 3VWHJ6BU5JM000000   License Plate:
    Mileage: 8073km-5016mi   Repair Order:
    Chassis Type: BU-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 20 2B 42 44 52 5F CA
    VIN: 3VWHJ6BU5JM000000   Mileage: 8073km-5016miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CWLA)       Labels: None
       Part No SW: 04E 906 027 MS    HW: 04E 907 309 BP
       Component: R4 1.4l TFS   H23 6223
       Revision: RDH23---
       Coding: 011A0032236411003000
       Shop #: WSC 00066 790 00389
       ASAM Dataset: EV_ECM14TFS01104E906027MS 002003
       ROD: EV_ECM14TFS01104E906027MS_002.rod
       VCID: 014A7E4F909EA847A8-8054
       Part No SW: 09G 927 158 BQ    HW: 09G 927 158
       Component: AISIN AG6 G3  201 3545
       Coding: 0000000100000000010000000000000000000000
       Shop #: WSC 00066 790 00181
       ASAM Dataset: EV_TCMAQ250031 002009
       ROD: EV_TCMAQ250031_002_VW37.rod
       VCID: 034674478A82BA57BA-8056
       Part No SW: 5Q0 614 517 DA    HW: 5Q0 614 517 AH
       Component: ESC           H62 0753
       Revision: 00000000    Serial number: 51788000000127
       Coding: 70FB6AA124202171C580060560C5250E562484A36006A4723841F0084202430B00000012121212B835351919323200
       Shop #: WSC 01383 790 50316
       VCID: 73A62487DA228AD7AA-8026
       Part No SW: 3Q0 959 435 J    HW: 3Q0 959 435 J
       Component: VWKESSYMQB    037 1104
       Revision: 00037000    Serial number: 0485357502
       Coding: 132C0C0723
       ASAM Dataset: EV_KessyHellaMQBAB 004043
       VCID: 41CABE4FD01E6847E8-8014
       Part No SW: 5GM 907 044 L    HW: 5GM 907 044 L
       Component: Climatronic   H04 2007
       Revision: 00001K04
       Coding: 01020014200108011004004010111008
       ASAM Dataset: EV_ACClimaBHBVW37X 006148
       VCID: 4DD2927F1C46BC271C-8018
       Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 034 0246
       Revision: --------    Serial number: C86402081803HT
       ROD: EV_BCMBOSCH_018.rod
       VCID: 06406D53B9B08F7F9D-8052
       Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
       Component: RLHS  052 0107
       Serial number: S7Y18M07D05H23M22S42
       Coding: 0038DD
       Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
       Serial number: 000000000ZY1814515F8
       Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000099337466
       Steering Column Switch:
       Subsystem 5 - Part No SW: 5Q1 953 521 AS    HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0170
       Serial number: 0300200820180C201655
    18698 - Left LED Module for DRL and Parking Lights
              B12EC F2 [008] - Voltage Supply Open or Short to Plus
                        Reset counter: 140
                        Mileage: 8059 km
                        Date: 2019.11.10
                        Time: 18:43:20
    19210 - Right LED Module for DRL and Parking Lights
              B12ED F2 [008] - Voltage Supply Open or Short to Plus
                        Reset counter: 140
                        Mileage: 8059 km
                        Date: 2019.11.10
                        Time: 18:43:20
       Part No SW: 5QA 919 294 E    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0443
       Serial number: 000145450R18237
       Coding: 0471151811
       VCID: 4ED095731140873F65-801A
       Part No SW: 5Q0 907 572 N    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0681
       Coding: 3200678159FFC428949C810580300600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       VCID: 42C8B143D518735FF1-8016
       Part No SW: 5Q0 959 655 BG    HW: 5Q0 959 655 BG
       Serial number: 003VUM01XBTV
       Coding: 88CCC000000000005C0000CF000800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       Subsystem 1 - Part No SW: -----------    HW: 480 001 307 18
       Serial number: 35700000000A53314031
       Subsystem 2 - Part No SW: -----------    HW: 480 001 507 18
       Serial number: 358000000006F478303J
       Subsystem 3 - Part No SW: -----------    HW: 480 401 107 18
       Component: SideSensor_Dr  003 6149
       Serial number: 3510001AF2A0CC74A1EL
       Subsystem 4 - Part No SW: -----------    HW: 480 401 207 18
       Component: SideSensor_Pr  003 6149
       Serial number: 3520001A32A0CC71E523
       Subsystem 5 - Part No SW: -----------    HW: 480 403 007 18
       Component: FrontSensor_D  003 6149
       Serial number: 3550001C32A0CC759606
       Part No SW: 17A 920 790     HW: 17A 920 790
       Component: KOMBI         516 0620
       Coding: 05A5091826800008018873011001000080000000
       Shop #: WSC 00066 790 00192
       ASAM Dataset: EV_DashBoardVDDMQBA0 001029
       ROD: EV_DashBoardVDDMQBA0_VW37.rod
       VCID: 648457DB6FCC1D6F23-8030
       Component: GW MQB High   518 5323
       Serial number: 11081800842416
       Coding: 030100047F085708FB0002D81C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 383CD3AB83C4298F5F-806C
       Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H17 0052
       Serial number: 33180001119290051439
       Coding: 2CFFFF
       Serial number: 9938066000
    Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
       Part No SW: 3G0 857 511 BA    HW: 3G0 857 511 BA
       Component: FLA           H10 0009
       Revision: AA001001
       Coding: 0404000800000000000000
       ASAM Dataset: EV_HighBeamAssisAU33X 001019
       ROD: EV_HighBeamAssisAU33X_VW37.rod
       VCID: 689C43EB93E4790F0F-803C
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H07 0021
       Serial number: 18000222157010
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 312AEE8F60BEF8C718-8064
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Serial number: 7038823900171
       Coding: 00381A208100028000001000
       VCID: 45C2AA5FC4364467D4-8010
       Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000000718006
       Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
       Component: EPS_MQB_ZFLS  172 1081
       Coding: 811F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 50EC8B0B0B7491CF77-8004
       Serial number: 6038824601802
       Coding: 003810208D00028000001000
       VCID: 46C0AD53F9304F7FDD-8012
       Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000000688631
       Coding: 090000
       Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
       Component: MU-S-N-ER     851 0867
       Coding: 02730103BE00000051220001001828001F0506F401200400CF
       ROD: EV_MUStd4CDELP_VW37.rod
       Component: ABT_Std-2_Nav  252 8130
       Serial number: VWZ6ZMV2305225
       Subsystem 2 - Part No SW: 3G0 919 866 BM    HW: -----------
       Component: MRM2 2018  --- 0915
       Part No SW: 4M0 907 594 K    HW: 4M0 907 594
       Coding: 40800073710B
       VCID: 3E30C5B3A1E017BF95-806A
    End----------(Elapsed Time: 01:22, VBatt start/end: 12.3V/12.3V)-----------
    ^^^^ Without knowing how the remaining channels in the DRL Leuchte-sets are programmed, it's difficult to be precise - but, it sounds like there is a conflict in the priority order of the lighting functions.
    Might be prudent to post-up a complete listing (meaning the full 19 x adaptation channels) for Leuchte2SL VLB10 and Leuchte3SL VRB21.
    Also, what were the previous settings for those channels that you changed (look at the AdpLog.CSV file in the directory C:\Ross-Tech\VCDS\Debug)
  3. Likes Uwe liked this post
    Sep 2017
    Brazil
    Hello Don,
    Thanks for you reponse and suport.
    Please find below a complete listing for Leuchte2SL VLB10 and Leuchte3SL VRB21 and also the AdpLog:
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2   Stored value minimize
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2   Stored value minimize
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2   Stored value maximize
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2   Stored value 100
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2   Stored value 100
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2   Stored value 26
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2   Stored value 0
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2   Stored value 4A
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2   Stored value 48
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2   Stored value 4 - LED Tagfahrlichtmodul Signal
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2   Stored value Always
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2   Stored value Daytime running lights
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2   Stored value not active
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2   Stored value Blinken links aktiv (beide Phasen)
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2   Stored value Nebellicht links
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2   Stored value Blinken links aktiv (beide Phasen)
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2   Stored value Parklicht links (beidseitiges Parklicht aktiviert li && re)
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2   Stored value not active
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2   Stored value not active
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3   Stored value minimize
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3   Stored value minimize
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3   Stored value maximize
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3   Stored value 100
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3   Stored value 100
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3   Stored value 26
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3   Stored value 0
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3   Stored value 4C
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3   Stored value 4C
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3   Stored value 4 - LED Tagfahrlichtmodul Signal
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3   Stored value Always
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3   Stored value Daytime running lights
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3   Stored value not active
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3   Stored value Blinken rechts aktiv (beide Phasen)
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3   Stored value Nebellicht rechts
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3   Stored value Blinken rechts aktiv (beide Phasen)
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3   Stored value Parking light right
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3   Stored value not active
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3   Stored value not active
    AdpLog
    Address 09   5Q0 937 086 BM   channel ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2   adapted from   Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)    to   Blinken links aktiv (beide Phasen)
    Address 09   5Q0 937 086 BM   channel ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3   adapted from   Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)    to   Blinken rechts aktiv (beide Phasen)
    Address 09   5Q0 937 086 BM   channel ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3   adapted from   25   to   26
    Address 09   5Q0 937 086 BM   channel ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2   adapted from   25   to   26
    Address 09   5Q0 937 086 BM   channel ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2   adapted from   maximize    to   minimize
    Address 09   5Q0 937 086 BM   channel ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3   adapted from   maximize    to   minimize
    Dec 2016
    DE
    Revert your changes and then do:
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 > minimize
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 > Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 > 25
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 > minimize
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 > Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    Currently your lights do not react to the "Standlicht allgemein" anymore, while Leuchte4 and Leuchte5 do. Since the signal is not used you'll get the warning in the cluster. Be sure to reflect all changes made in Leuchte2 in Leuchte4 as well. The same goes with Leuchte3 and Leuchte5.
    Sep 2017
    Brazil
    I made all the sugested changes, including Leuchte3 and Leuchte5 and I do not have the errors anymore on the dash, but the dimming on indication does not work anymore.
    Dec 2016
    DE
    Weird since it should. However dimming only is done when in DRL mode. If you have the low beams on it is already dimmed down to 25.
    Sep 2017
    Brazil
    The dimming on indication does not work Even if when the switch light position is in “0”, DRL mode.
  9. #8
    VWTSI: Expanding on TBAx's suggestion - perhaps a "cleaner" way to code these 2 x Leuchte-sets is something like this:
    left-side
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 > 48
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 > 4A
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 > Daytime running lights
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 > not active
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 > 100
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 > Always
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 > Blinken links aktiv (beide Phasen)
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 > not active
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 > 0
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 > minimize
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 > Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 > Parklicht links (beidseitiges Parklicht aktiviert li & re)
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 > 26
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 > maximize
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 > not active
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 > not active
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 > 0
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 > maximize
    Right-side
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 > 4 - LED Tagfahrlichtmodul Signal
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 > 4C
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 > 4C
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 > Daytime running lights
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 > not active
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 > 100
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 > Always
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 > Blinken rechts aktiv (beide Phasen)
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 > not active
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 > 0
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 > minimize
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 > Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 > Parking light right
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 > 26
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 > maximize
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 > not active
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 > not active
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 > 0
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 > maximize
    Ive added Single Side Parking Lights (SSPL) to the code above (because I can! )- but if you don't want this function just change Lichtfunktion F in both Leuchte-sets to not active
  10. Likes Uwe, PetrolDave liked this post
  11. #9
    Sep 2017
    Brazil
    Thank you very much Don and TBAx's for your support, now it works correctly and there is no errors on dashboard. The only thing is the DRL is turning off instead of dimming on indication. Is it possible dimming instead of turning off?
    P.s.: Perfect the tweak for enable single side parking lights!
  12. #10
    Dec 2016
    DE
    Yes, you can.
    Just change the value for:
    from 0 to 26 or any other useful value.
  13. Likes DV52, Uwe liked this post
