VW 2016 Golf MK7 Cruise Control (CCS) wire to Engine Control Unit (ECU)
I've looked almost everywhere and only found a reference to a J263, T94/56 which I understand to be a 94 pin connector for the ECU, pin 56. The problem, or my confusion is this ECU has two connectors. A 105 pin and a 91 pin connector. The instructions indicate that the pin-out is engine specific. Am I missing something or looking at the wrong unit? Is their someone that can steer me in the right direction? I found the pin 5 of the J527, T16/5 for the Steering column electronics control unit and have no problem running the wire. I have already installed the MFSW controls in the steering wheel. Fairly simple and straight forward. I would like to resolve this prior to bringing the codes to the dealer to have them activate the CCS. Also, I bought the car at a VW dealer in Morocco without cruise control.
Thanks,
Wednesday,13,November,2019,13:55:04:34757
VIN: WVWZZZAUZGW318884 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F
VIN: WVWZZZAUZGW318884 Mileage: 4106km-2551miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BP HW: 04L 907 309 R
Component: R4 2,0L EDC H22 1198
Revision: B5H22---
Coding: 011D0012030401083000
ASAM Dataset: EV_ECM20TDI01104L906026BP 002002
ROD: EV_ECM20TDI01104L906026BP_002.rod
VCID: 79AFED35C9512E9F8E9-802C
Part No SW: 0D9 300 041 H HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4902
Revision: 06253104 Serial number: TFK01604121265
ROD: EV_TCMDQ250021.rod
VCID: 1D67D9A53D39B2BFC21-8048
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 61106000000503
Coding: 01FA62A124210974057F060841C72980462490A0608294F300620078C202
Revision: 00021000 Serial number: 0401266553
Coding: 030C1C
Shop #: WSC 12345 123 61029
VCID: 3A2D32398CD7E587C73-806E
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020114200100011005004000101002
VCID: 6A8DC279BCF79507773-803E
Air quality sensor:
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061611301007
Coding: 00111A46C24122FB4AE44000000C07281800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 04518CC1BE936377EDF-8050
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160406 043 0551
Serial number: 160416010852
Component: RLHS 037 0059
Serial number: S3Y16M04D27H04M38S11
Coding: 90A8DD
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H03 0004
Serial number: 0000FST000WMJXY00000
Coding: 181901
Revision: -------- Serial number: 39331611600189
Coding: 0031151011
VCID: 43D34FDDFB1DA44F945-8016
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR1N4WW-
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F5B032DD77500AFB0D-802A
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169667D23041650021
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169668D22041650307
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 004 16
Serial number: 357670000000A655BA1X
Subsystem 4 - Part No SW: ----------- HW: 480 002 004 16
Serial number: 35867000000B1525BA1W
Subsystem 5 - Part No SW: ----------- HW: 480 402 104 16
Serial number: 3516502A520414E2C2B3
Subsystem 6 - Part No SW: ----------- HW: 480 402 104 16
Serial number: 3526502AF20414E3324%
Subsystem 7 - Part No SW: ----------- HW: 480 401 604 16
Serial number: 3556502B520414F100F+
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 20041604220688
Coding: 0410
ASAM Dataset: EV_SMLSKLOMQB 020001
VCID: 074B9BCD8FA5486F88D-8052
Part No SW: 5G1 920 641 A HW: 5G1 920 641 A
Component: KOMBI 208 7653
Coding: 07A519182B80000E02083A001400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 2411EC411E5383778DF-8070
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004776514
Coding: 030100041F087300FB00024E1C0F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H12 0034
Serial number: 02120004599160020291
Coding: 2B0000
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 7289390004
8782084 - Tiptronic Downshift Switch/Paddle in Steering Wheel
B114E 96 [009] - Component internal failure
Reset counter: 88
Mileage: 4090 km
Date: 2019.11.12
Time: 02:16:26
Terminal 15: On
8782085 - Tiptronic Upshift Switch/Paddle in Steering Wheel
B114F 96 [009] - Component internal failure
Reset counter: 88
Mileage: 4090 km
Date: 2019.11.12
Time: 02:16:26
Terminal 15: On
8782090 - Cruise Control Switch
B1154 96 [009] - Component internal failure
Reset counter: 88
Mileage: 4090 km
Date: 2019.11.12
Time: 02:16:26
Terminal 15: On
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000070740010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34311C01AEB313F71DF-8060
Component: TSG FS 020 0041
Serial number: 230216EBM04902
Coding: 003B1320D000048000001000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000009805421
Coding: 110000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 8103
VCID: 44D14CC1FE13A377ADF-8010
Component: TSG BFS 020 0041
Serial number: 120416ED934978
Coding: 003B1120DE00048000801000
VCID: 42DD4AD9E407AD479F3-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000009783321
Coding: 090000
Component: AFS-ECU H07 0090
Coding: 029A00000B000200
VCID: 40D940D1EA0BBF57897-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3Q0 035 877 A HW: 3Q0 035 877 A
Component: MU-S--ROA H24 0245
Serial number: VWZAZ2S0169485
Coding: 02730000FF00000051110001001028001F0200D40120010001
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 33331F1DABBD14CF045-8066
Subsystem 1 - Part No SW: 3G0 919 605 HW: 3G0 919 605
Component: ABT_Std-2 H43 4064
Serial number: VWZ6Z9S1131601
End----------(Elapsed Time: 01:45, VBatt start/end: 12.4V/12.4V)-----------
From a WD for Convenience system, left-hand drive , (L0L) From January 2014 - not sure that it will help. but note the asterix provisos at the bottom of the picture
PS: Ignore the "Heated steering wheel" reference - I haven't included the J519 connections in the pic
Post Thanks / Like - 1 Likes
Uwe liked this post
Thank you. Where can someone find this information?
Post Thanks / Like - 3 Likes
