Results 1 to 4 of 4
Thread: VW 2016 Golf MK7 Cruise Control (CCS) wire to Engine Control Unit (ECU)
    Nov 2019
    Morocco
    Question VW 2016 Golf MK7 Cruise Control (CCS) wire to Engine Control Unit (ECU)
    I've looked almost everywhere and only found a reference to a J263, T94/56 which I understand to be a 94 pin connector for the ECU, pin 56. The problem, or my confusion is this ECU has two connectors. A 105 pin and a 91 pin connector. The instructions indicate that the pin-out is engine specific. Am I missing something or looking at the wrong unit? Is their someone that can steer me in the right direction? I found the pin 5 of the J527, T16/5 for the Steering column electronics control unit and have no problem running the wire. I have already installed the MFSW controls in the steering wheel. Fairly simple and straight forward. I would like to resolve this prior to bringing the codes to the dealer to have them activate the CCS. Also, I bought the car at a VW dealer in Morocco without cruise control.
    Thanks,
    Wednesday,13,November,2019,13:55:04:34757
    VIN: WVWZZZAUZGW318884   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F
    VIN: WVWZZZAUZGW318884   Mileage: 4106km-2551miles
    Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 BP    HW: 04L 907 309 R
       Component: R4 2,0L EDC   H22 1198
       Revision: B5H22---
       Coding: 011D0012030401083000
       ASAM Dataset: EV_ECM20TDI01104L906026BP 002002
       ROD: EV_ECM20TDI01104L906026BP_002.rod
       VCID: 79AFED35C9512E9F8E9-802C
       Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4902
       Revision: 06253104    Serial number: TFK01604121265
       ROD: EV_TCMDQ250021.rod
       VCID: 1D67D9A53D39B2BFC21-8048
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 61106000000503
       Coding: 01FA62A124210974057F060841C72980462490A0608294F300620078C202
       Revision: 00021000    Serial number: 0401266553
       Coding: 030C1C
       Shop #: WSC 12345 123 61029
       VCID: 3A2D32398CD7E587C73-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00020114200100011005004000101002
       VCID: 6A8DC279BCF79507773-803E
       Serial number: 01061611301007
       Coding: 00111A46C24122FB4AE44000000C07281800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 04518CC1BE936377EDF-8050
       Component: WWS    160406  043 0551
       Serial number:         160416010852
       Component: RLHS  037 0059
       Serial number: S3Y16M04D27H04M38S11
       Coding: 90A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.403  H03 0004
       Serial number: 0000FST000WMJXY00000
       Coding: 181901
       Revision: --------    Serial number: 39331611600189
       Coding: 0031151011
       VCID: 43D34FDDFB1DA44F945-8016
       Serial number: 003MLR1N4WW-
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F5B032DD77500AFB0D-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34169667D23041650021
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34169668D22041650307
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 004 16
       Serial number: 357670000000A655BA1X
       Subsystem 4 - Part No SW: -----------    HW: 480 002 004 16
       Serial number: 35867000000B1525BA1W
       Subsystem 5 - Part No SW: -----------    HW: 480 402 104 16
       Serial number: 3516502A520414E2C2B3
       Subsystem 6 - Part No SW: -----------    HW: 480 402 104 16
       Serial number: 3526502AF20414E3324%
       Subsystem 7 - Part No SW: -----------    HW: 480 401 604 16
       Serial number: 3556502B520414F100F+
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 20041604220688
       Coding: 0410
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 074B9BCD8FA5486F88D-8052
       Part No SW: 5G1 920 641 A    HW: 5G1 920 641 A
       Component: KOMBI         208 7653
       Coding: 07A519182B80000E02083A001400000000000000
       ASAM Dataset: EV_DashBoardJCIMQBAB 009005
       ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
       VCID: 2411EC411E5383778DF-8070
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1244
       Revision: --------    Serial number: 0004776514
       Coding: 030100041F087300FB00024E1C0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H12 0034
       Serial number: 02120004599160020291
       Coding: 2B0000
       Serial number: 7289390004
    8782084 - Tiptronic Downshift Switch/Paddle in Steering Wheel
              B114E 96 [009] - Component internal failure
                        Reset counter: 88
                        Mileage: 4090 km
                        Date: 2019.11.12
                        Time: 02:16:26
                        Terminal 15: On
    8782085 - Tiptronic Upshift Switch/Paddle in Steering Wheel
              B114F 96 [009] - Component internal failure
                        Reset counter: 88
                        Mileage: 4090 km
                        Date: 2019.11.12
                        Time: 02:16:26
                        Terminal 15: On
    8782090 - Cruise Control Switch
              B1154 96 [009] - Component internal failure
                        Reset counter: 88
                        Mileage: 4090 km
                        Date: 2019.11.12
                        Time: 02:16:26
                        Terminal 15: On
       Revision: 00000000    Serial number: 16000070740010
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34311C01AEB313F71DF-8060
       Serial number: 230216EBM04902
       Coding: 003B1320D000048000001000
       Serial number: 00000000000009805421
       Coding: 110000
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 8103
       VCID: 44D14CC1FE13A377ADF-8010
       Serial number: 120416ED934978
       Coding: 003B1120DE00048000801000
       VCID: 42DD4AD9E407AD479F3-8016
       Serial number: 00000000000009783321
       Coding: 090000
       Coding: 029A00000B000200
       VCID: 40D940D1EA0BBF57897-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 3Q0 035 877 A    HW: 3Q0 035 877 A
       Component: MU-S--ROA     H24 0245
       Serial number: VWZAZ2S0169485
       Coding: 02730000FF00000051110001001028001F0200D40120010001
       ROD: EV_MUStd4CTSAT_VW37.rod
       VCID: 33331F1DABBD14CF045-8066
       Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
       Component: ABT_Std-2  H43 4064
       Serial number: VWZ6Z9S1131601
    End----------(Elapsed Time: 01:45, VBatt start/end: 12.4V/12.4V)-----------
    From a WD for Convenience system, left-hand drive , (L0L) From January 2014 - not sure that it will help. but note the asterix provisos at the bottom of the picture
    PS: Ignore the "Heated steering wheel" reference - I haven't included the J519 connections in the pic
  3. Likes Uwe liked this post
    Nov 2019
    Morocco
    Thank you. Where can someone find this information?
    Sep 2015
  6. Likes sosterman, DV52, Uwe liked this post
