Hi all,
I've made an Autoscan on my wife's Audi Q3 last week-end.
And unexpectedly, I've got the fault code mentioned above :
I don't know:
- What the fault code corresponds to (not found in the database)
- How to erase it (apparently, I've no issue with the system)
Looking into maintenance bills, it correponds to 2 tires replacement in a 'tires replacement shop', where I assume, no Tire Pressure Monitoring System has been done, after new tires installation... I like 'so-called' professionals...
Thanks for your help!
Tuesday,12,November,2019,21:46:26:04899
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8U7FRxxxxxx License Plate:
Mileage: 120290km-74744mi Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 55 5F 62 72
VIN: WAUZZZ8U7FRxxxxxx Mileage: 120290km-74744miles
Address 01: Engine (J623-CUVC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 BG HW: 04L 907 309 K
Component: R4 2.0l TDI H20 2913
Revision: 8AH20---
Coding: 01190012043401080000
Shop #: WSC 12784 002 1048576
ASAM Dataset: EV_ECM20TDI01104L906016BG 004002
ROD: EV_ECM20TDI01104L906016BF_004.rod
VCID: 6FC333B5B68E2F374E-803A
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb
Part No SW: 5N0 614 109 CA HW: 5N0 614 109 CA
Component: ESC-EBC460iV1 H08 0004
Serial number: A00QK2M
Coding: 22F124A10921E374207D440124CB90C704355700F08B4884
Shop #: WSC 00049 770 00154
ASAM Dataset: EV_Brake1ESCEPBTRW 003039
ROD: EV_Brake1ESCEPBTRW_003.rod
VCID: 6CF924B98798D42F6B-8038
0763 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 203
Mileage: 84224 km
Date: 2017.11.04
Time: 13:09:55
Additional_Codes: 28 0A 00 0D 66 7F 00 48 02
DTC: 00 02 FB
Additional2: 05 00 01 08 05 22 46 00 46 00
Part No SW: 8U0 820 043 F HW: 8U0 820 043 F
Component: E87 Klimavoll 0210
Revision: 00H05000 Serial number: 8U0820043F
VCID: 3449FCD957284CEF73-8060
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 AB HW: 8X0 907 063 AB
Component: BCM PQ35 M 113 0817
Revision: AB113817
Coding: 26080A2CA8051AC4201848C10144894C47FF23AA007F912BE400878400C1
Shop #: WSC 00049 770 00099
VCID: 7CD914F9FFF844AFFB-8028
Subsystem 1 - Part No SW: 8U1 955 119 HW: 8U1 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 150107 H37 0090
Serial number: 150119074023
Coding: 0047F7
Component: G397_RLFS H06 0002
Serial number: 23658232
Coding: 02006E
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 AH HW: 4H0 919 475 AG
Component: PARKHILFE 8K H01 0080
Revision: 11001001 Serial number: 61061502601236
Coding: 08C208
Shop #: WSC 00049 770 00117
ASAM Dataset: EV_EPHVA18AU21X0000 003008
ROD: EV_EPHVA18AU21X0000_003.rod
VCID: 0C394439A758742FCB-8058
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 C HW: 8U0 959 655 C
Component: AirbagVW-AU10 H09 0900
Serial number: 003PAR0AAV2W
Coding: 304D3232333030303030554A304C38553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001010
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 47B3BB15FEBED77726-8012
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME23040B34ZZZN
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME2C387834ZZZZ
Serial number: 3516KSME7C160B34ZZZX
Serial number: 3526KSME320F7834ZZZW
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME797A7032ZZZ4
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 D HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0162
Revision: FF010018 Serial number: 20150126300461
Coding: 1184204000
VCID: 3B5BD7E5B2768397B2-806E
Subsystem 1 - Part No SW: 8U0 951 528 G HW: 8U0 951 528 G
Serial number: 10 01 2015 A0025132
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8U0 920 940 H HW: 8U0 920 940 H
Component: KOMBI_COLOUR H02 0350
Coding: 12CF01
VCID: 3D5FD9FDAC628DA78C-8068
Part No SW: 8U0 907 468 AQ HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0090
Revision: 1P140041 Serial number: 4141P1512208B7
Coding: FBCF1A5A000108610253
VCID: 1107554DC87A59C738-8044
Component: J367-BDM H07 0180
Serial number: 42024F25511491416064
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Serial number: 15015003559021200181
Component: IMMO H02 0350
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H11 0415
Coding: 011803201C00000000
VCID: 52859A410DFC62DF41-8006
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.377 1401
Revision: 1BH04841 Serial number: 00150070336701
Coding: 0000258
VCID: 41A7A50D189AE947E8-8014
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H11 0415
Coding: 011803201E00000000
VCID: 5187954D08FA19C778-8004
Part No SW: 8X0 907 357 E HW: 8X0 907 357 B
Serial number: 150124-0002-091
Coding: 11C794101002A500
ROD: EV_HeadlRegulBasic.rod
VCID: 44A9AC19CF88FC6FC3-8010
Part No SW: 8U1 035 193 A HW: 8U1 035 193 A
Component: RMC Cnct Nav H61 0139
Coding: 01000600024153470823020103010000000000
VCID: 3449FCD997284CEF73-8060
Subsystem 1 - Part No: 8X0 919 884 H
Component: P28-50-14.06 0001
Subsystem 2 - Part No SW: 8U0 919 603 A HW: 8U0 919 603 A
Component: DUBasic AU316 H42 0018
Serial number: AUZ8ZDEM502QDVT
Fault Frequency: 6
Reset counter: 199
Mileage: 120239 km
Date: 2019.11.12
Time: 08:59:38
Bin. Bits: 00000000 10000000
Bin. Bits: 00000000 00000000
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H08 0415
Coding: 010003200000000000
VCID: 5081904903F010CF77-8004
Component: TSG HR H08 0415
End-------------------------(Elapsed Time: 02:10)--------------------------
I don't know:
