2018 Caddy Maxi Life / Security Access Code / 09 Cent Elec
AlixKaur
C?ID=198164
Hi All,
I require the security access code for the 09 Cent Elec module on a 2018 Caddy Maxi Life. This is so I can attempt to carry out Adaptations in this module, with the goal of having the driving/fog lights come on while the main beam is on. My reason for wanting this is due to the shortcoming of the H4 bulb which VW have decided to implement in a 2018 vehicle, in that when the main beam is on, the dipped beam turns off, reducing visibility close to the front of the vehicle. My plan is to follow the steps on the below page:
http://www.golfgtiforum.co.uk/index.php?topic=260248.610
However to get to this stage, I require the security code. I have tried 31347 and 20103, none of which worked. Please see full auto scan below. VCDS is fully up to date, as is my HEX-V2 interface. I have removed the VIN for obvious reasons but can of course supply this if required.
Tuesday,12,November,2019,15:25:31:15959
VIN: removed   License Plate:
Mileage: 14480km-8997mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 52 5F 61
VIN: removed   Mileage: 14480km-8997miles
Address 01: Engine (J623-DFSB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 KK    HW: 04L 907 309 AB
   Component: R4 2.0l TDI   H20 6642
   Revision: 8EH20---
   Coding: 011D0032046515090000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI01104L906016KK 004005
   ROD: EV_ECM20TDI01104L906016JE_VW36.rod
   VCID: 7CA1F6BE7668829795F-8028
   Part No SW: 02E 300 066 M    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 5210
   Revision: 06454104    Serial number: 00001812050456
   Shop #: WSC 35110 377 08192
   VCID: 2313EDC2A7D61D6FF45-8076
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 60029000000484
   Coding: 1479409BB268B4872878027F4D882DD379F7F0
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 40D9424E5A002677897-8014
   Part No SW: 1K8 907 426 AS    HW: 1K8 907 426 AS
   Component: AC Manuell    H21 0909
   Revision: 00001002
   Coding: 0010004083
   VCID: 04518E5E0E98FA57EDF-8050
   Part No SW: 5K0 937 086 AD    HW: 5K0 937 086 AD
   Component: BCM PQ35 M+   122 0193
   Revision: BD122001
   Coding: 4F1A0A3E8025E16B088800839440816407D10008426F8720648087000041
   VCID: 76B5E49648C4D8C7E3B-8022
   Subsystem 1 - Part No: 2K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 02011  61  0715
   Coding: 009795
   Subsystem 2 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 090119 05  50  0106
   Coding: 0228DD
   Subsystem 3 - Part No: 7N0 951 172
   Component: Sensor, DWA 0  005 0502
   Subsystem 4 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0009
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0480
   Revision: --------    Serial number: 39461831000162
   Coding: 0131161051
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00_VW36.rod
   VCID: 3B2335A233E645AFDC5-806E
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1001190452AEF3
   Coding: 00001000FE0339
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3635249608C498C723B-8062
   Part No SW: 2K5 959 655 E    HW: 2K5 959 655 E
   Component: VW10Airbag00K 010 0018
   Revision: --------    Serial number: 003EN00269U1
   Coding: 00000000000000000000000000000000304B
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   VCID: 3E253CB620F45087FBB-806A
   Serial number: 3497ARB405J5MM6O3HH0
   Serial number: 3507ARB405P5MJ8IGI1W
   Serial number: 3517ARB405J5MM6OAGK2
   Serial number: 3527ARB40535MJ8KJA08
   Part No SW: 5K0 953 521 FG    HW: 5K0 953 569 BC
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20190108200487
   Coding: 1882C60008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 76B5E4964844D8C7E3B-8022
   Subsystem 1 - Part No SW: 2K0 959 442 A    HW: 2K0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 3511815333801470BC1B
   Coding: 2C0000
   Part No SW: 2K5 920 976 J    HW: 2K5 920 976 J
   Component: KOMBI         H02 2030
   Coding: 110A011200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: 3D273BBA2DF24B9FE21-8068
   Part No SW: 7N0 907 530 BQ    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1691
   Revision:   H56       Serial number: 050119F1001845
   Coding: 357431
   VCID: 0059824E1A00E677C97-8054
   Component: IMMO          H02 2030
   Coding: 000002
   VCID: 6A8DC0E60CFC0C27773-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2144
   Coding: 0131632
   VCID: 71BFD78A2DAAFFFF369-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 315    3501
   Revision: 00H22000
   VCID: 392F2FAA355A77BFCE9-806C
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0131632
   VCID: 72BDD88628ACC4E7CF3-8026
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0475
   Serial number: VWZAZ2W0714335
   Coding: 06330701BE00000011111101008808001F0100D600200100CF
   ROD: EV_MUStd4CTSAT_SK26.rod
   VCID: 2517F3DAA562E35F9A1-8070
   Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Component: Batt.regelung H56 1691
   Coding: 030F7873
   VCID: 71BFD78A21AAFFFF369-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Component: J367-BDMConti  H03 1051
   Serial number: 75885803001812170622
End----(Elapsed Time: 01:17, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
Many thanks.
Jacek
Poland
C?ID=360566
Hello, try S12345.
TBAx
C?ID=287144
The guide linked above will not work on you Caddy, as it is a different platform (Caddy: PQ35, Golf 7: PQ37/MQB).
HMC
C?ID=28246
Hi AlixKaur,
"when the main beam is on, the dipped beam turns off", that might be sensible to stop the headlamp and bulb holder melting.
Regards HMC
AlixKaur
C?ID=198164
AlixKaur
C?ID=198164
Ah ok. I was worried about that. My plan was to get access firstly, then see if the steps worked. I did think to myself there is a chance they wont work, as that post is dated back in 2014, however I thought maybe as it was still a Golf it might have worked. Thanks.
AlixKaur
C?ID=198164
Hi AlixKaur,
Regards HMC
Thanks for your reply but this is not what I am trying to achieve. Im afraid I do not see your point with regards to a bulb holder melting.
langers2k
C?ID=224085
I think HMC is just trying to point out that running both filaments of a H4 bulb will likely damage the bulb or it's holder. Although I suspect you already know this and it's not directly relevant given it's not what you're trying to do...
As for having the high beam stalk turn on both the fogs and high beams, I don't think it's possible on a PQ35 platform vehicle. At least I've never seen any coding, adaption or EEPROM mod that would achieve it :/
Dana
Western PA, USA
This is a Mk6 based / PQ35 BCM so I agree with the guys above. (Mk7 / MQB BCMs are an entirely different animal and they do require a SA code prior to adaptation.)
You already have Byte 14, Bit 2 Fog Lights inactive with High Beams active unchecked but I'm not aware of any way to enable both high and low beams at the same time. You might want to see if enabling some incorrect combination of Xenon Headlights (with or w/o Shutter perhaps) might change the BCM's behavior but I would NOT tweak Byte 18 unless you know the stock value that's hiding under the 00's in your coding.
AlixKaur
C?ID=198164
Correct. Ah I see. Looks like it's a 'no go' then. Thank you for your reply.
AlixKaur
C?ID=198164
Thanks Dana. Yeah. I will maybe just leave well enough alone at this point! As has now been pointed out, even if I could gain access, my planned steps wouldnt have worked anyway. Do you think this is something that could be possible to alter in a future version of VCDS or has VW 'locked' this out permanently?
Thanks.
langers2k
C?ID=224085
It's very much down to the BCM software I'm afraid. VCDS can't add functionally, just enable or tweak features that all already there.
