Results 1 to 8 of 8
Thread: Disable TCS/ESP on 2017 Passat NMS
    Nov 2016
    Bought the Passat last November and got caught in slippery snow storm over the winter. I believe I could have gotten through this with TCS/ESP off button, like I did on my previous Audi A6. So I looked into adding a TCS/ESP defeat button connected to the ABS module. I've since connected everything and verified that ABS module is getting the 12V+ pulse but TCS/ESP does not seem to be turned off when clicking the button either momentarily or after a long press. From what I can gather it will likely require an update to the long coding for the ABS module.
    I've read that 2012-2013 Passat have the following changes to get TCS/ESP defeat. - For some folks it just worked without coding, but for 2014+ required coding.
    MY12 - C54BC0F549288002A31203EB921E0142A61000 - 19 byte - Trying this with VCDS returned values out of range.
    MY14 - C54BC0F549280001A30F03E692190042A1180022 - 20 byte - Have not tried this, because the bytes on my coding is not like on this users original values.
    However those are from vehicles prior to automatic braking and ACC (Active Cruise Control)
    MY17 - C54BC0F549230000A30C03EB921E004100F1F01A - 20 byte This is my default ABS module Long Code,
    Note: This is a 2017 NMS Passat SEL Premium which has the auto braking, auto cruise control, park assist etc....
    Ideally we can find a vehicle with similar equipment and ABS module with ACC/automatic braking that also has the ESP defeat button, to see their coding. Maybe a vehicle from a different market?
    ABS Module Component ESP MK6EC1
    ABS Module information:
       Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
       Component: ESP MK60EC1   H46 0175
       Revision: 00H46001
       Coding: C54BC0F549230000A30C03EB921E004100F1F01A
       Shop #: WSC 09003 957 00200
       VCID: 75A22D83DC6DBDEAEA-8020
    Full Scan Report
    Saturday,24,December,2016,11:51:16:44171
    VCDS Version: 16.8.4.2 (x64)  HEX-NET CB: 0.4323.4
    VIN: 1VWCT7A37HC016175   License Plate:
    Mileage: 900km-559mi   Repair Order:
    Chassis Type: A3 (7N0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 36 3C 42 44 46 47
              4F 52 5F 61 62 72 75 A5
    VIN: 1VWCT7A37HC016175   Mileage: 900km-559miles
    Address 01: Engine (J623-CPRA)       Labels: None
       Part No SW: 06K 906 071 BJ    HW: 06K 907 425 C
       Component: R4 1.8l TFS   H13 3685
       Revision: --H13---
       Coding: 001A0092244400179000
       ASAM Dataset: EV_ECM18TFS02006K906071BJ 001006
       ROD: N/A
       VCID: 74A41087DF17A4E2DD-8020
    No ASAM data for: "EV_ECM18TFS02006K906071BJ" (VW41)
    Readiness: 0000 0100
    Address 02: Auto Trans (J217)       Labels: None
       Part No SW: 09G 927 158 BD    HW: 09G 927 158
       Component: AISIN AG6 G3  202 3121
       ROD: EV_TCMAQ250031_VW31.rod
       VCID: 76A02A8FC96BB6F2E3-8022
       Revision: 00H46001
       Part No SW: 5K0 959 434 H    HW: 5K0 959 434
       Component: VWKESSYPQ35GP 093 1305
       Revision: 00093000    Serial number: 0410221359
       Coding: 132C0C
       ROD: EV_KESSYPQ35G_VW01.rod
       VCID: 3A38FEBFBDF31292C7-806E
       Slave 1:
       Serial number: 93845109
       Part No SW: 561 907 044 BD    HW: 561 907 044 BD
       Component: Climatronic   H08 0910
       Revision: 00001K05
       Coding: 0050019012
       VCID: 5AF85E3F5DB3F292E7-800E
       Part No SW: 5K0 937 087 AL    HW: 5K0 937 087 AL
       Component: BCM PQ35 H++  122 0184
       Revision: BN122001
       Coding: EF200E3BD82B08D409880601340081C002F1000645A00DB0E4806200BC70
       VCID: 7F4ECFABEE51F7BAB0-802A
       Subsystem 1 - Part No: 5K7 955 559 C
       Component: RLS 120716 04  42  0106
       Coding: 0038DD
       Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0480
       Revision: --------    Serial number: 39431617701915
       Coding: 0031165011
       ASAM Dataset: EV_EPHVA2CVW364GP00 001010
       ROD: EV_EPHVA2CVW364GP00.rod
       VCID: 3B36FBBBB2C92B9ADC-806E
    Address 13: Auto Dist. Reg (J428)       Labels: 7N0-907-572.clb
       Part No SW: 7N0 907 572 B    HW: 7N0 907 572
       Component: ACC Bosch PQx H03 0120
       Serial number: 01071677090183
       Coding: 01001002FE0739
       ASAM Dataset: EV_ACCBEGVW361 001005
       ROD: EV_ACCBEGVW361.rod
       VCID: 3522ED8394EDFDEA2A-8060
    Address 15: Airbags (J234)       Labels: 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    008 0210
       Serial number: 003RXM07PVCV
       Coding: 8CCCCC00000000005000001A020800000065
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411.rod
       VCID: 638663DB6AF9335AB4-8036
       Serial number: IBH000000000005PMNYQ
       Coding: 30324A
       Subsystem 2 - Part No SW: -----------    HW: 480 000 107 16
       Serial number: 35700000000040251C1/
       Subsystem 3 - Part No SW: -----------    HW: 480 002 106 16
       Serial number: 358000000005C4B81C1R
       Subsystem 4 - Part No SW: -----------    HW: 480 022 306 16
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001AF210BB1421D
       Subsystem 5 - Part No SW: -----------    HW: 480 020 407 16
       Component: SideSensor_Pr  000 0148
       Serial number: 3520001AB2134BB1647$
       Subsystem 6 - Part No SW: -----------    HW: 480 020 207 16
       Component: FrontSensor_D  000 0189
       Serial number: 3550001B321816E2558.
       Subsystem 7 - Part No SW: -----------    HW: 480 020 307 16
       Component: FrontSensor_P  000 0189
       Serial number: 3560001B321816E3532V
       Part No SW: 1K5 953 521 CS    HW: 5K0 953 569 BF
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20160623301426
       Coding: 2012C40008
       ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 004C4C579BAF8842C9-8054
       Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B
       Serial number: 0041603354100367AE2B
       Coding: 2D0000
       Part No SW: 561 920 981 B    HW: 561 920 981 B
       Component: KOMBI         H03 1104
       Coding: 221E010000
       VCID: 1B761B3B12094B9A3C-804E
       Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1682
       Revision:   H56       Serial number: 17081603010152
       Coding: 461010
       VCID: 7BB63BBBFA49EB9A9C-802E
       Component: IMMO          H03 1104
       Coding: 000007
       VCID: 6A980EFF8DD3621277-803E
       Revision: 00000000    Serial number: 16000122996002
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 312AD9936085D1CA76-8064
       Part No SW: 561 959 760 B    HW: 561 959 760 B
       Component: MEM-FS        H04 0183
       Revision: AA000000    Serial number: 00000198134565
       VCID: 220826DF3D637A52FF-8076
    Address 3C: Lane Change (J1086)       Labels: None
       Serial number: 0410893850
       Coding: 02011102
       ROD: EV_HREntryHella.rod
       VCID: 3C34F8A7B7C72CA2D5-8068
       Part No SW: 561 959 701 C    HW: 3C0 959 793 J
       Component: TUER-SG FT    002 0637
       Revision: 12100010    Serial number: 0010655765
       Coding: 3415FD
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 1E70122F011B5EB2DB-804A
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  022 1472
       Serial number: 14102746160813175156
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 313    3501
       Revision: 00H22000
       VCID: 393AE1B370F5198ACE-806C
       Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
       Component: KonzernAmp10K H09 6831
       Revision: --------    Serial number: EAA098C0096569
       VCID: 281C34F7535F9002A1-807C
    Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
       Component: EZE_2         H56 1682
       Coding: 01030108
       VCID: 6FAE1FEBBE31873A20-803A
       Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
       Component: J245 P05 9BA3  H08 0005
       Serial number: 53388786011612400562
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
       Component: Analoguhr  002 0003
       Part No SW: 561 959 702 C    HW: 3C0 959 792 J
       Component: TUER-SG BT    002 0637
       Revision: 14100010    Serial number: 0010647830
       Coding: 3415FC
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 1F0E2F2B061157BAD0-804A
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  022 1472
       Serial number: 14102747160822022247
       Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
       Component: MU-S-NS-US    H30 0357
       Serial number: VWZAZ2S0385185
       Coding: 02140102AA00000051220003001808009F0100D400200105C6
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 240420C72F7774628D-8070
       Subsystem 1 - Part No SW: 3G0 919 866 AC    HW: -----------
       Component: NAR 2016/17  --- 0445
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
       Component: Batt.regelung H56 1682
       Coding: E1200859
       VCID: 71AA1993A80591CA36-8024
    Address 75: Telematics (J949)       Labels: 12E-035-284.clb
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0158
       Serial number: 000003554140554
       Coding: 02140102C24232107F1606000000
       ASAM Dataset: EV_OCULow 002010
       ROD: EV_OCULow_002.rod
       VCID: 14647007FFD704E27D-8040
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H04 0220
       Serial number: 29061611P20532
       Coding: 000401010001020100201346C080400080000E200000
       ROD: EV_MFKBoschMQBB.rod
    End----------(Elapsed Time: 01:27, VBatt start/end: 12.2V/12.1V)-----------
    Dec 2016
    DE
    Have you checked the advanced measuring values; does the signal reach the module?
    You might also want to try the coding C54BC0F549230000A30C03EB921E004100F1F02A
  3. Likes Uwe liked this post
    Nov 2016
    Thanks TBAx - Yes advanced measuring values shows that the ESP button is active when it is clicked.
    I changed the byte 20 from 1A to 2A which now turns off ASR, but this usually is paired with another byte (for example 2014 uses byte 19 and byte 17). However holding down the button for longer than 3 seconds does not turn off ESP. So this only partially works. Will need to figure out how to turn ESP off. But for now ASR is good enough for the main purpose of gaining some traction in extra slippery conditions.
    Will get back to this if I can figure out the correct byte 17 coding - hopefully that will disable ESP with long press.
    Nov 2016
    OK just went out for a quick spin - It indeed turns off ASR, while ASR is turned off "Front Assist" also shows as not available. So ACC (Active Cruise) and Front Assist (Auto Braking) is turned off when ASR is Off. This is to be expected since it basically disables ABS activation in these scenarios. Makes sense now that I think of it. When I entered the ABS control module using VCDS, it also said ACC not available, so it disables ACC. I was able to test traction control off because it just so happens we have our first day of rain after a few days without it, and the roads around here are supper slippery. With TCS on tire chirps and gets traction pretty quickly. With ASR turned off it allows the wheels to slip and spin but really if I give it a lot more pedal something else seems to kick in to reduce power, not sure if it is the ESP/ESC or something else.
    Hope to figure out ESP off too. Changing byte 18 from F1 to F8 is accepted by the controller, but still does not turn off ESP/ESC. In fact it changes (Extended) Electronic Differential Lock (XDS - PR-UG3/UG4) to active/installed but I don't think the 2017 NMS Passat has XDS installed - although the controller allows this change.
    Nov 2016
    OK after doing some additional investigation, it looks like there are multiple "stages" to this and the pairing byte allows the ESP/ESC to be turned off. Will need to figure out which one is the pairing byte to allow this to be turned into 2 stage, where a single click is ASR-off and a prolonged click is ESP/ESC-off.
    Nov 2016
    OK After some digging the ABS-ESP module is similar to many in Europe. Basically the last byte 20 allows switching between different stages. If you play around with the bits you can see different behavior.
    Byte 20:
    change to 2A = Single Stage - ASR-OFF along with front assist and ACC off
    change to 6A = Double Stage - ESC-Sport (quick press), ESC-OFF (long press)
    change to 7A = Double Stage - ASR-OFF (quick press), ESC-OFF (long press)
    Now I'd really have to double check some of this since only 2A turns off Front Assist and ACC. Changing to 6A and 7A leaves front assist and ACC on, so will need to verify if indeed these are working as displayed on the screen.
  8. Likes D-Dub, Vasco Ferraz liked this post
    Nov 2016
    Quick update with ignition on and engine running, it all works, 6A and 7A works but front assist is disabled as expected when doing this. So all is well. There may be other combinations like ASR and esc-sport 2 stage, but i've found what i was after. For others looking for other settings when you go into long coding and select byte 20, edit the actual bits to figure out different settings.
  10. Likes Uwe liked this post
  11. #8
    Nov 2019
    Massachusetts, USA
    I know this is an old tread but I just found it. I have a 17 Passat with adaptive cruise, parking assist and push button start. It is an SE and I really wanted to add the traction control button. I was wondering if anyone has any updated information. Or updated coding information
    Thanks
    Dave
