Results 1 to 5 of 5
Thread: 2013 Audi Q3, coding start/stop button
    Nov 2019
    Luxembourg
    I wish to code the start/stop button so the engine doesn't stop each time I need to stop the car. Like many others I think is not an useful function.
    I've tried to apply the procedure:
    Module 09 > Security Access > code 20113 > Adaptions > Read channel 34 then
    You have these options:
    - subtract 4 from the value = stop/start off by default
    - add 32 to the value = enable stop/start memory
    - add 64 to the value = invert the light in the stop/start switch (light
    on when stop/start on rather than when off)
    The problem is that my car doesn't accept the security code 20113. Would you please let me know if the procedure is different for this car. Below the scan:
    Thank you
    Friday,08,November,2019,06:04:56:10062
    VIN: WAUZZZ8UXDR1XXXXX   License Plate: XXXX
    Mileage: 45690km-28390mi   Repair Order:
    Chassis Type: 8U-AU21 (8U0)
    Scan: 01 03 08 09 10 15 16 17 19 25 3C 42 44 46 52 53 55 5F 62 72
    VIN: WAUZZZ8UXDR1XXXXX   Mileage: 45690km-28390miles
       Part No SW: 03L 906 018 CN    HW: 03L 906 018 ES
       Component: R4 2.0l TDI   H28 9979
       Revision: 41H28---    Serial number:
       Coding: 00190012042401080000
       Shop #: WSC 40458 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018CN 003009
       ROD: EV_ECM20TDI01103L906018CN.rod
       VCID: 78BCF66AC3F4058F9F-802C
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AF    HW: 5N0 614 109 AF
       Component: J104   C6 450M VD01 0120
       Revision: --H07---    Serial number: 00000006869641
       Coding: 0054660
       Shop #: WSC 00049 770 00241
       VCID: 6FAECD367EBA42374E-803A
    02214 - Tire Pressure Warning
                        Fault Frequency: 6
                        Reset counter: 37
                        Mileage: 45467 km
                        Date: 2019.11.04
                        Time: 06:57:10
                        Speed: 70.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 14.75 V
                        Bin. Bits: 00011111
                        Count: 185
                        Hex Value: 0x0000
       Part No SW: 8U0 820 043 C    HW: 8U0 820 043 C
       Component: E87  Klimavoll      0050
       Revision: 00H03000    Serial number: 8U0820043C
       VCID: 312A0B4EA80E14C718-8064
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 K    HW: 8X0 907 063 K
       Component: BCM PQ35  M   111 0715
       Revision: AH111715
       Coding: 06000A2CA8051AC0201840C02100094C53FF84AA216F912AE408878400C5
       Shop #: WSC 00049 770 00009
       VCID: 44C4529AC7BC916FC3-8010
       Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS316 130407  H36 0085
       Serial number:         130411000924
       Coding: 0047F7
       Serial number: 21213517
       Coding: 02006E
    00332 - Control Circuit for Tank Flap
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 239
                        Mileage: 45095 km
                        Date: 2019.10.24
                        Time: 20:42:08
                            Term 15 Off
                        Voltage: 12.65 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
       Part No SW: 8X0 919 475 N    HW: 4H0 919 475 AG
       Component: PARKHILFE 8K  H01 0050
       Revision: 11001001    Serial number: 61031310800602
       Coding: 08C204
       ASAM Dataset: EV_EPHVA18AU21X0000 003006
       ROD: EV_EPHVA18AU21X0000_003.rod
       VCID: 51EA6BCE00CE74C778-8004
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
       Component: AirbagVW-AU10 H07 0520
       Serial number: 003LRR050T2S
       Coding: 30353132313030303030554A304C38553053
       Shop #: WSC 00049 770 00119
       ASAM Dataset: EV_AirbaAU10SMEAU316 001005
       ROD: EV_AirbaAU10SMEAU316_001.rod
       VCID: 46C04892F980A37FDD-8012
       Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3496KSME764A6224ZZZ.
       Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3506KSME054D5424ZZZP
       Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3516KSME0F686224ZZZW
       Serial number: 3526KSME0B755424ZZZS
       Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3555USME605E5223ZZZ$
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 501 D    HW: 5K0 953 569 H
       Revision: FF010017    Serial number: 20130427101630
       Coding: 1184204000
       VCID: 3B362966B242EE97B2-806E
       Subsystem 1 - Part No SW: 8U0 951 528 E    HW: 8U0 951 528 E
       Component: E221 - MFL  H09 0010
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8U0 920 940 C    HW: 8U0 920 940 C
       Component: KOMBI_COLOUR  H03 0151
       Coding: 12CF01
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
       VCID: 383C366A8374C58F5F-806C
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 L    HW: 8U0 907 468 L
       Component: GAT 5CAN 2L M H13 0059
       Revision: 1U150034    Serial number: 3441U13308006C
       Coding: FBCF1A5A000100610253
       VCID: 4BD679A6EAE25E1702-801E
       Component: J367-BDM  H07 0180
       Serial number: 30120E50221491332449
       Serial number: 13109002110021200181
       Component: IMMO          H03 0151
       Coding: 000002
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 8U0 907 566 B    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0010
       Revision: 00H02000    Serial number: 6PZ 010 316-05
       Coding: 0000101
       VCID: 40CC5E8A13A48D4FE7-8014
       Subsystem 1 - Part No: 8U0 907 568 B
       Component: J770  SWA Slave H02 0010
       Subsystem 2 - Serial number: 6PZ 010 316-25
       Subsystem 3 - Serial number: 5F16.05.1200H020003C130391˙
       Subsystem 4 - Serial number: 130391˙
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H10 0415
       Coding: 011E06201C00000000
       VCID: 52E864C20DC80FDF41-8006
       Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.374 1202
       Revision: 1BH04839    Serial number: 00130870089201
       Coding: 0000258
       VCID: 3FCE5D766E5AF2B79E-806A
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H10 0415
       Coding: 011E06201E00000000
       VCID: 51EA6BCE08CE74C778-8004
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000000937875
       Coding: 0025167
       VCID: 36203852416033FF4D-8062
       Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
       Serial number: 130422-0002-027
       Coding: 1157941010022500
       Shop #: WSC 00049 770 00151
       ROD: EV_HeadlRegulBasic.rod
       VCID: 42C85482D5A89F5FF1-8016
       Part No SW: 8U0 035 193 C    HW: 8U0 035 193 A
       Component: RMC Cnct Nav  H54 0801
       Coding: 0100060002C153070A23020103010000000000
       VCID: 35223F5E9C6638E744-8060
       Subsystem 1 - Part No: 8X0 919 884 E
       Component: P18-50-12.06  0001
       Subsystem 2 - Part No SW: 8U0 919 603     HW: 8U0 919 603
       Component: DUBasic AU316  H41 0018
       Serial number: AUZ8ZDD0603KU2X
       Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
       Component: TSG HL        H07 0415
       Coding: 010E06200000000000
       VCID: 4FEE6DB61EFA62376E-801A
       Component: TSG HR        H07 0415
    End----------(Elapsed Time: 01:15, VBatt start/end: 14.8V/14.7V)-----------
    Address 03: DTCs clearedFriday,08,November,2019,06:10:24:10062
       Coding: 0054660
       Revision: AH111715
       Coding: 0047F7
       Coding: 02006E
                        Reset counter: 239
                        Mileage: 45095 km
                        Date: 2019.10.24
                        Time: 20:42:08
                            Term 15 Off
                        Voltage: 12.65 V
                            Term 50 Off
       Coding: 08C204
       Coding: 1184204000
       Coding: 12CF01
       Coding: 000002
       Coding: 0000101
       Coding: 0000258
       Coding: 0025167
    End----------(Elapsed Time: 01:14, VBatt start/end: 14.8V/14.8V)-----------
    Where did you find the above "procedure"? I do not think it is applicable to your BCM.
    Nov 2019
    Luxembourg
    I found it on some VW related forum, not here anyway. After seeing the security code 20113 isn't accepted by my car I believe you are right. Do you know the right procedure for this car? Thanks
    Feb 2016
    CT, USA
    FYI - If you go the security access spot and hover over the white space where you tried keying in 20113 with no success, it usually will tell you the appropriate code.
    Jun 2017
    Q3 8U is NOT a MLB car. Instructions mentioned is for MLB cars like A6 4G or A4 8K Facelift.
    I say this for the quaddilliontrillion-billionth time: Not possible on Q3 8U.
  7. Likes downtime, Uwe, Dana liked this post
