Results 1 to 7 of 7
Thread: 2010 Q7 Air Suspension problem - rear at max height with flashing yellow signal
    Sep 2015
    Lidingö, Sweden
    Audi Q7 2010 TDI S-Line with an air suspension problem
    Step 1 Tag of PR-Build data picture posted ( Last 6 of VIN can be omitted for privacy )
    Step 2 Status of car stock or modified in any way? If so list!
    Completely stock
    Step 3 "VCDS" COMPLETE Auto-Scan in code tags!
    Monday,11,November,2019,21:12:20:49964
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ4L3AD0#####   License Plate:
    Chassis Type: 4L (4F0)
    Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 28 34 36 3C 42 46 47
              4F 52 55 56 5F 62 69 6C 6D 6F 72 76
    VIN: WAUZZZ4L3AD0#####   Mileage: 149500km-92894miles
    Address 01: Engine (CAS)       Labels:. 059-907-401-CAT1.clb
       Part No SW: 4L1 910 401 D    HW: 4L0 907 401 A
       Component: 3.0TDI EDC17A104AG  0080
       Revision: --H02---    Serial number:
       Coding: 0121002C191F0A68
       Shop #: WSC 40970 222 94360
       VCID: 2447ED83E718D36FE3-8070
    005661 - Glowplug for Cylinder 4 (Q13)
                   P161D - 000 - Open Circuit
                        Mileage: 137842 km
                        Date: 2019.04.02
                        Time: 15:10:00
                        RPM: 882 /min
                        Voltage: 11.17 V
                        Temperature: 22.5°C
                        Lambda: 22.7 %
                        Temperature: 19.8°C
    005663 - Glowplug for Cylinder 6 (Q15)
                   P161F - 000 - Open Circuit
                        Mileage: 137842 km
                        Date: 2019.04.02
                        Time: 15:10:00
                        RPM: 882 /min
                        Voltage: 11.17 V
                        Temperature: 22.5°C
                        Lambda: 22.7 %
                        Temperature: 19.8°C
    005662 - Glowplug for Cylinder 5 (Q15)
                   P161E - 000 - Open Circuit
                        Mileage: 145129 km
                        Date: 2019.08.13
                        Time: 07:11:34
                        RPM: 882 /min
                        Speed: 2.2 km/h
                        Voltage: 11.40 V
                        Temperature: 22.5°C
                        Lambda: 21.9 %
                        Temperature: 18.9°C
    Address 02: Auto Trans        Labels: 09D-927-750.clb
       Part No SW: 09D 927 750 KC    HW: 09D 927 750 KC
       Component: AL 750 6A           1470
       Revision: 00H78000    Serial number:
       Coding: 0000504
       Shop #: WSC 31414 790 00001
       VCID: 79F9ECF7301A7E87E0-802C
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
       Part No SW: 4L0 910 517 K    HW: 4L0 614 517 K
       Component: ESP ALLRAD MK25E1   0020
       Revision: 00H30001
       Coding: 0627841
       VCID: 326B1BDBADEC4DDF61-8066
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Component: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serial number: 10602601405096
       Coding: 0000135
       VCID: 2541F087EC222A67F4-8070
       Subsystem 1 - Part No: 4F0 910 132 G
       Component: FBSAUDIC6 EZS   H03 0020
       Subsystem 2 - Part No: 4F0 910 335 B
       Component: FBSAUDIC6 KSG   H03 0020
    00956 - Key 2
                        Fault Status: 00110010
                        Reset counter: 40
                        Mileage: 146527 km
                        Date: 2019.09.11
                        Time: 19:42:48
       Part No SW: 4L0 910 043 C    HW: 4L0 820 043 AB
       Component: KLIMA 4 ZONEN H12 0030
       Revision: 00---017    Serial number: 00000000212367
       Coding: 040816
       VCID: 2447ED832718D36FE3-8070
       Part No SW: 4F0 910 279 R    HW: 4F0 907 279
       Component: ILM Fahrer      H25 0330
       Coding: 0033221
       VCID: 387F29F34B90A78F5F-806C
       Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H17 0100
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    Address 13: Auto Dist. Reg        Labels: None
       Part No SW: 4L0 910 561 A    HW: 4L0 907 561
       Component: ABSTANDSREGELUNGH06 0160
       Revision: --------    Serial number: 00000000000000
       Coding: 0031161
       VCID: 275DFA8F962E3877C6-8072
    02002 - Heater for Distance Regulation Sensor (Z47)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 184
                        Reset counter: 151
                        Mileage: 133756 km
                        Date: 2019.02.02
                        Time: 17:33:04
                        Temperature: 10.0°C
                        Voltage: 12.93 V
                        Bin. Bits:    00100
                        Hex Value: 0x0931
                        Hex Value: 0x0002
                        Speed: 21.6 km/h
                        Lateral Accel.: 0.00 m/s^2
       Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
       Component: 70 AIRBAG AUDI8RH43 0230
       Revision: 04H43000    Serial number: 00399D065B3G
       Coding: 0014128
       VCID: 2E530FABB9D4693F05-807A
       Subsystem 1 - Serial number: 6332QSME623A191AH
       Subsystem 2 - Serial number: 6342QSME703A32067
       Subsystem 3 - Serial number: 6352QSME4338322CE
       Subsystem 4 - Serial number: 6362QSME623A143AH
       Subsystem 5 - Serial number: 63734SME3136050EX
       Subsystem 6 - Serial number: 63834SME2F364400-
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90026092380094
       Coding: 0002052
       Component: E0221           H02 0030
    Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
       Part No SW: 4L0 920 931 J    HW: 4L0 920 931 J
       Component: KOMBIINSTR.   H08 0144
       Revision: 00000000    Serial number: CNN432799
       Coding: 0F5E63040C010008000000
       VCID: 326B1BDB6DEC4DDF61-8066
    Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
       Part No SW: 4L0 910 105     HW: 4L0 265 105 M
       Component: Heizgeraet      H08 0120
       Revision: 0000000E    Serial number: 00000009014264
       Coding: 0000101
       VCID: 60CFA193B3808F4FC7-8034
       Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0035
       Revision: MB200030    Serial number: 3000M098308025
       Coding: 000303
       VCID: 3A7B33FBB59CB59FA9-806E
       Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
       Component: J367-BDM  H07 0107
       Serial number: 00000000004140159397
                        Fault Status: 01101011
                        Reset counter: 25
                        Mileage: 137842 km
                        Date: 2019.04.02
                        Time: 13:35:01
                        Bin. Bits:    10111
                        Voltage: 11.50 V
                        Count: 7
                        Bin. Bits:    10011
       Part No SW: 4F0 857 511 J    HW: 4F0 857 511 G
       Component: FLA           H04 0004
       Revision: AA001002
       Coding: 02019064747464545425363E
       VCID: 2F6D12AF7EDE60370E-807A
    Address 28: HVAC, Rear        Labels: None
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
       Component: KLIMABETAETIGUNGH06 0060
       Revision: 00---010    Serial number: 00000000352325
       Coding: 0000006
       VCID: 68DFB9B35BB0F70F0F-803C
    00003 - Control Module
                        Fault Status: 00100011
                        Fault Frequency: 8
                        Mileage: 138479 km
                        Date: 2019.04.10
                        Time: 21:17:21
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 H    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7870
       Revision: --H03001    Serial number: 15.1528-0123.2
       Coding: 0015520
       VCID: 2F6D12AFBEDE60370E-807A
    01577 - Turn-Off due to Over-Temp
                        Fault Status: 00100001
                        Reset counter: 38
                        Mileage: 148993 km
                        Date: 2019.11.02
                        Time: 14:50:48
                        Error Code: 68
                        Reset counter: 43
                        Mileage: 148972 km
                        Date: 2019.11.02
                        Time: 12:24:56
                        Error Code: 13
    01400 - Suspension Level Control
                        Fault Frequency: 10
                        Reset counter: 65
                        Mileage: 149424 km
                        Date: 2019.11.11
                        Time: 08:40:42
                        Error Code: 66
    02250 - Function Deactivation; Valve Duty Cycle
                        Reset counter: 63
                        Mileage: 149423 km
                        Date: 2019.11.11
                        Time: 08:38:09
                        Error Code: 46
       Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
       Component: MEM-FS        H08 0062
       Revision: AA000000    Serial number: 00001001346979
       Coding: 00581B00000011110000
       VCID: 316914D768EA76C718-8064
    Address 3C: Lane Change        Labels: None
       Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0040
       Revision: 00H01000    Serial number: 6PZ 009 014-10
       Coding: 0010101
       Subsystem 1 - Part No: 4L0 910 568 C
       Component: J0770_SWA_Slave_H01 0040
       Subsystem 2 - Serial number: 6PZ 009 014-30
       Subsystem 3 - Serial number: 5F21.07.0900H010003C910745ÿ
       Subsystem 4 - Serial number: 910745ÿ
       Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Revision:             Serial number: 0000101820752
       Coding: 011F52205E40440004
       VCID: 4683570BF164C17FDD-8012
       Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
       Component: Komfortgeraet   H09 0100
       Revision: 0100 ---    Serial number: 01219373360000
       Coding: 3549361
       VCID: 356120C75C825AE744-8060
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4L0 035 223 E    HW: 4L0 035 223 E
       Component: BOSE G3 AU716 H01 0100
       Revision: AH001500    Serial number: 00000000008395
       Coding: 0D000000
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Component: ILM Beifahrer   H13 0100
       Revision:             Serial number: 00000000139275
       Coding: 0011101
       VCID: 5EB39F6B89F4B9BFF5-800A
       Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Revision:             Serial number: 0000101847220
       VCID: 45815007CC62CA67D4-8010
    02126 - Central Locking Button; Exterior Door Handle
                008 - Implausible Signal
                        Fault Status: 01101000
                        Fault Frequency: 33
                        Reset counter: 254
                        Mileage: 137842 km
                        Date: 2019.04.02
                        Time: 13:35:43
       Part No SW: 4L0 910 357 A    HW: 4L0 907 357 A
       Component: AFS 1           H01 0030
       Coding: 0000032
       VCID: 2A5B03BB853C051FD9-807E
       Component: AFS-Modul links H07 0004
       Subsystem 2 - Part No: 7L6 941 329 A
       Component: AFS-Modul rechtsH07 0004
       Part No SW: 4F0 035 053 K    HW: 4F0 035 053
       Component: Radio U Basic H45 0074
       Revision: AB001007    Serial number: 341IZ097634851
       Coding: 010003010000000000
       VCID: 2541F0872C222A67F4-8070
       Part No SW: 4L0 035 670 H    HW: 4L0 035 670
       Component: H-BNT-EU      H41 0187
       Revision: --------    Serial number: 474I6097515869
       Coding: 010100060004DBEF71000715EF6300030000
       VCID: 2D5108A774D212273C-8078
       Subsystem 1 - Part No: 8R0 060 884 ED
       Component: EUR 2017  2402
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356IZ091064728
       Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 C
       Component: E0380 Bedient  H05 0060
       Serial number: 00000001400099
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
       Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
       Revision:             Serial number: 0000101862201
       Coding: 010E50204040230004
       VCID: 43854E1FC256F457FA-8016
    Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
       Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
       Revision: 2A001001    Serial number: 00008200327685
       Coding: 0100000000000000
       Shop #: WSC 80093 222 69422
       Part No SW: 4L0 910 441 B    HW: 4L0 907 441 B
       Component: J772__Rearview      0030
       Revision: --H03---    Serial number: 525PA8-J9940CA
       Coding: 1021001
       Part No SW: 4L0 910 945     HW: 4L0 827 851 D
       Component: ValeoHeckdeckel H29 0410
       Revision: --H29001    Serial number: 8K9827852  B
       Shop #: WSC 98765 666 38354
       VCID: 6CD7C5A34F48DB2F6B-8038
       Subsystem 3 - Serial number: RD16.09.09--H29001001A0322ÿ
       Subsystem 4 - Serial number: 1A0322ÿ
       Component: ILM HINTEN 2    H05 0060
       Revision: AAH05061    Serial number: 003881240-----
       Coding: 0003587
       VCID: 2643F78B9124217FFD-8072
       Subsystem 1 - Part No: 4L0 910 591
       Component: J_245_EE16_SKB09H10 0200
       Subsystem 2 - Part No: 4L0 910 591
       Component: J_394_EE16_SKB09H10 0200
       Subsystem 3 - Part No: 4L0 910 591
       Component: J_392_EE16_SKB09H10 0200
       Revision:             Serial number: 0000101862200
                        Fault Frequency: 22
                        Reset counter: 254
                        Mileage: 148816 km
                        Date: 2019.10.27
                        Time: 18:29:16
       Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
       Component: Parkhilfe 8-Kan H02 0100
       Revision: 00H02000    Serial number: 85130925303084
       Coding: 0231166
       VCID: 2C5705A38FC81B2F2B-8078
    End-------------------------(Elapsed Time: 03:50)--------------------------
    Step 4 Describe recent repairs or services, problem at hand, & attempts at repair.
    No recent repairs or services. No attempts at repair. Problem is a flashing yellow air suspension light, and the rear end of the vehicle is jacked up to maximum height. Any attempt to use the button in the trunk area to lower the rear has no effect other than causing the light on the button to flash.
    Step 5 Are parts OEM or AFT? If so, "what", and what origin?
    Original/OEM.
    Step 6 Identify specific issues to be addressed/concerned about, or say ALL.
    I'm only concerned with the Air suspension codes. Not concerned with anything else unless you think it's directly related. I have routinely seen all of the other codes. I haven't cleared it in a LONG time, but I have cleared them in the past and they come back (CAN, door central locking buttons, glo-plugs, distance sensor heater, etc - nothing that either really causes a problem or is worth the cost of fixing).
    Step 7 Now that you jumped through the first few hoops of fire, did you check the FUSES/Battery connections?
    No. I have not checked any fuses yet. There's no indication that the system is not getting power. It seems to be running for too long and getting cut off.
    So, now that all of that is out of the way... It seems I have a LOT of information to point us to the problem, I just don't know how to interpret it all. We have four fault codes, the flashing yellow light (which indicates that the rear suspension is at maximum level), a visual check which confirms that the rear end of the vehicle is jacked up unusually high, and confirmation that I cannot lower the rear of the vehicle using the button in the rear cargo area. No unusual noises or behavior, though with the rear end up like that, it is noticeably impacting handling. This is my main day-to-day family vehicle so I need to get this fixed quickly! I have owned this vehicle for almost two years. It has had intermittent air suspension problems the entire time, but never anything like this. In the past, the problem always went like this: After a startup, the system would drop the suspension all the way down and the green air suspension light (pointing down) would stay on. All air suspension options in MMI would turn gray. I would stop the vehicle, turn it off, restart it, and the problem would go away and not return for weeks or months. The problem I have now is totally new, where the rear end goes all the way up and the yellow light flashes.
    Is there any additional data I can collect? I read something about collecting some measuring blocks, but I didn't see any details on it.
    Thanks in advance all! I will update this thread to its completion.
    John
    Johnathon M. Jones
    2010 Audi Q7 TDI
  2. Likes Uwe, Jack@European_Parts, Gremling liked this post
  3. #2
    Sep 2015
    Lidingö, Sweden
    Another data point I've noticed, now that I've parked on flat surfaces a few times - the upper right of the vehicle is definitely higher than the rest of the vehicle, by about a full inch.
    Johnathon M. Jones
    2010 Audi Q7 TDI
    Sep 2015
    Lidingö, Sweden
    Getting closer to the root cause...
    I found the info on measuring blocks. The height measuring blocks confirm what I'm seeing on the vehicle, so all of the height sensors seem to be good. At least that seems to rule out any problem with the height sensors.
    I also confirmed that the computer attempts to operate the rear valves by viewing the measuring block 7 in Group 34. Here are two excerpts that show the computer operating the valves open and shut. The left rear lowers as I would expect it to do when the rear air valve is ON.
    20:09:56 Group 007:  Status of pneumatic spring valves
      OFF   air spring valve  front left
      OFF   air spring valve  front right
      OFF   air spring valve  rear left
      OFF   air spring valve  rear right
                    Address 34: Level Control  (4L0 910 553 H)
    20:10:25 Group 007:  Status of pneumatic spring valves
      ON   air spring valve  rear left
      ON   air spring valve  rear right
    I also tried numerous things today to rule out other possibilities. I confirmed that the 40amp fuse to the compressor is fine, and I was able to
    raise the vehicle all the way to the top in the LIFT position. I confirmed that all four wheel arches were raised to virtually the exact same height (although the height measuring blocks weren't exactly equal, but at least at the uppermost position shown in the display, the height was exactly where it should be for all four). I could not hear any leaking at all when this occurred. Also, one of the times I was monitoring measuring block 6, I could see 9.11 bar, which seems like pretty high pressure to me. So, this seems to rule out any problem with either the compressor or the ability of the air struts to hold air.
    The next questions are:
    1) Why won't the right rear valve actually open? Could it just be stuck, or possibly a failure of an individual solenoid or relay somewhere?
    2) Where is the valve that controls the release of air from the right rear? Is it one valve, or are there multiple valves involved? Is it in a central valve block such as the one shown here:
    https://www.ecstuning.com/b-genuine-...ion/7l0698014/
    Johnathon M. Jones
    2010 Audi Q7 TDI
  5. Likes Jack@European_Parts liked this post
    Sep 2015
    Lidingö, Sweden
    Bingo! I finally found another thread describing my exact problem:
    https://forums.ross-tech.com/showthr...ension-problem
    So, it might not be a problem with the central valve block. It seems that there are valves on the air shocks themselves that can get stuck. I'll give it a shot and report back.
    Johnathon M. Jones
    2010 Audi Q7 TDI
  7. Likes Jack@European_Parts liked this post
  8. #5
    Sep 2015
    Lidingö, Sweden
    It worked!!! With several taps of a hammer on two long socket extensions to reach up to the valve where the air line enters the top of the air shock, the valve must have loosened up inside and the rear end now completely lowers using the switch at the back of the vehicle. This sounds like a joke, but I really did resolve the problem with a hammer.
    I'm guessing there is some internal corrosion on that valve that caused it to get stuck in the first place, and that I'll need to replace that valve. Looks like a frustrating job - there's very little access into that area.
    Johnathon M. Jones
    2010 Audi Q7 TDI
  9. Likes Uwe, Jack@European_Parts liked this post
  10. #6
    Did you boil it out on kitchen stove with distilled water and then run 90% alcohol afterwards and dry then lube proper ?
    Thank you for self helping yourself with JPPSG and making good use of guides to address your issue.
  11. Likes Uwe liked this post
  12. #7
    Verified VCDS User Gremling's Avatar
    Dec 2017
    Norway, Nordland
    Hi, these valves happens to fail once a while, there is a rep kit for it, not that expensive either. See VAG SelStudyProgram 362 Q7 Running gear pg 33, for position and description. The see hyperlink for explanation of part, I got a valve for my A6 Allroad from another place (can not remember where), but this can give you an idea what to look for. Look at bottom of page, or 2nd page. http://www.air-suspension-shop.com/Repair-Kit_9
    On the Audi A6 Allroad, the procedure is to remove the old valve, this will cause damage to valve (and it differently needs to be replaced), not sure if it is exactly the same on the Q7. On the A6 Allroad a special locking ring is behind the valve, and the design of this locking "device" is what cause a damage to the removed valve. So if similar, ensure you have the correct valve and understanding of job, prior to remove anything.
    Hope this helps, so you do not have to drive around with a hammer :-)
    Regards
    Gremling
  13. Likes Uwe, Jack@European_Parts liked this post
