Vacuum Sensor (2006 Touareg V10)
nightcasters
Verified VCDS-Lite User
C?ID=341726
brakes went out and I went to check the vacuum hose which looks like it's okay but then I noticed a sensor was just floating around. pretty sure it's the sensor for the vacuum assist. I can't figure out where to put it back any ideas? 2006 Touareg V10
Question does not appear to be VCDS related in any way. Moving to General VW/Audi Repair.
nightcasters
C?ID=341726
Touareg V10 TDI vacuum assist line fails
the vacuum assist lines had cracked and the brakes went out causing near accidents three times already. The first two times the mechanic down the crack and replaced it. and it just happened again. they would have any suggestions on maybe replacing all the lines?
Threads merged. I don't think we need two separate threads regarding the same problem in the same vehicle.
HMC
C?ID=28246
Hi nightcasters,
The question I have is, were the previous repairs not replacements? if the servo hose was just repaired at the point of the crack, then the answer is yes the part should be replaced.
Regards HMC
