Results 1 to 2 of 2
Thread: Vw 2011 T5GP 7speed DSG Shuttle fitting MFSW
    Oct 2019
    Liverpool, England
    I have bought and fitted This: VW GOLF MK6 GTD 2009-2012 FLAT BOTTOM STEERING WHEEL with DSG Paddles to my: 2011 vw T5GP 7speed DSG shuttle.
    Fitted the 2 wires from clock spring pins 9 and 10
    Pin 9 on clock spring to an ignition live, To pin 15 on the light switch This works the illumination on the steering wheel with the lights switched On.
    Pin 10 on clock spring to pin 17 of the white 73pin plug on the body control module ,
    this already has a wire in that position as its the Lin bus, Lilac and white wire I have soldered this connection.
    My problem: No buttons work left or right,
    What does work: DSG paddles and horn work fine,
    All the buttons illuminate,
    Can anybody help solve my problem Please?
    Regards
    Patrick
    Monday,11,November,2019,16:50:56:39175
    VIN: WV2ZZZ7HZBH114478   License Plate:
    Mileage: 245200km-152360mi   Repair Order: 11-11-19 faults
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 02 03 04 08 09 10 15 17 18 19 25 4B 56 0B
    VIN: WV2ZZZ7HZBH114478   Mileage: 245200km-152360miles
    4B-Multifunc. Module -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CCHA)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 DH    HW: 03L 907 309 K
       Component: R4 2,0L EDC   X41 9133
       Revision: 26X41---    Serial number: 00000000000000
       Coding: 0125401A232400080000
       Shop #: WSC 26214 051 00000
       ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
       ROD: EV_ECM20TDI01103L906019DG.rod
       VCID: 74B2D67CBE32BFD7DDF-8020
       Part No SW: 0BT 300 045 J    HW: 0BH 927 711 C
       Component: DSG DQ500-7F  H04 1407
       Revision: 00H04V01
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: 3C223E5CD6E23797D5F-8068
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0105
       Revision: 00H43001
       Coding: 208724AD09A5049924A69078AA6616
       Shop #: WSC 02756 790 49152
       VCID: 36362C74E84EEDC723B-8062
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E5 907 047 AJ    HW: 7E5 907 047 AJ
       Component: Climatic-T5   H11 0203
       Revision: 00005001
       Coding: 0000000002
       Shop #: WSC 02757 790 50316
       ROD: EV_ClimaT5Basis.rod
       VCID: 77A8E170AF44D4CFF8D-8022
       Part No SW: 7H0 937 087 F    HW: 7H0 937 087
       Component: BCM T5GP H+4  H47 0230
       Revision: BO047001    Serial number: 0396 071110566
       Coding: B8B879B86E61261383284ED07EEA9EDCF08041FF60840000300000000000
       Shop #: WSC 02754 790 12345
       VCID: 37282170EF4414CF38D-8062
       Component: RLS 100311 05  54  0403
       Coding: 03302E
       Subsystem 2 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  003 3311
       Coding: 050000
       Subsystem 3 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  003 3311
       Coding: 050000
       Subsystem 4 - Part No: 7E1 951 171
       Subsystem 5 - Part No: 1K0 951 605 C
       Subsystem 6 - Part No: 7E1 951 171
       Subsystem 7 - Part No SW: 5K0 959 542     HW: 5K0 959 542
       Serial number: 0142037
       Coding: 830000
                        Mileage: 245097 km
                        Date: 2014.04.02
                        Time: 00:43:37
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 C    HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H11 0011
       Revision: --------    Serial number: 47401035600423
       Coding: 000102
       Shop #: WSC 02756 790 50316
       ASAM Dataset: EV_VW75XParkAssis8K A01004
       ROD: EV_VW75XParkAssis8K_A01.rod
       VCID: 323E106404A6F1E70F3-8066
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H06 0013
       Revision: --------    Serial number: 003HL004EFE2
       Shop #: WSC 02754 790 50316
       VCID: 35342B78F5C8E6DF2A1-8060
       Part No SW: 7E0 920 970 C    HW: 7E0 920 970 C
       Component: KOMBI         H20 0220
       Coding: 160E00
       VCID: 2A0E08042C76B927B73-807E
    Address 18: Aux. Heat        Labels: None
       Part No: 7E0 815 071 A
       Component: J737__Standheizung  0404
       Revision: 00085000    Serial number: 09019275D00000
       Coding: 0000031
       Shop #: WSC 13636 131 88224
       VCID: 2310E52047DC686FF45-8076
    01444 - Under-Voltage Shut-Off (Automatic)
                        Mileage: 245097 km
                        Date: 2014.04.02
                        Time: 00:50:48
                        Temperature: 6.0C
                        Voltage: 14.01 V
                        Temperature: 4.0C
    01414 - Combustion-Air Blower (V6)
                007 - Short to Ground
                        Fault Status: 01100111
                        Mileage: 245099 km
                        Date: 2014.04.02
                        Time: 00:54:48
                            Start
                        Temperature: 4.0C
                        Voltage: 14.28 V
                        Temperature: 2.0C
    02251 - Heater Unit Locked
                        Mileage: 245123 km
                        Date: 2014.04.02
                        Time: 23:14:50
                            Malfunction
                        Temperature: 11.0C
                        Voltage: 14.01 V
                        Temperature: 2.0C
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 0230
       Coding: 040300
       VCID: 70BADA6CCAAA83F7397-8024
    01304 - Radio
                        Reset counter: 102
                        Mileage: 245097 km
                        Date: 2014.04.02
                        Time: 00:43:41
    03590 - Control Module for Multifunction Module
                        Reset counter: 102
                        Mileage: 245097 km
                        Date: 2014.04.02
                        Time: 00:43:42
       Component: IMMO          H20 0220
       VCID: 6A8EC804ECF67927773-803E
    Address 4B: Multifunc. Module
    Address 56: Radio
    End----(Elapsed Time: 02:28, VBatt start/end: 11.9V/11.6V. VIgn 11.6V)-----
    Please refrain from spamming the forum with multiple threads containing exactly the same question.
    This thread is closed.
    Carry on here:
    https://forums.ross-tech.com/showthread.php?20769
