- Joined
- Oct 13, 2019
- Messages
- 9
- Reaction score
- 0
- Location
- Liverpool, England
- VCDS Serial number
- C?ID=295360
I have bought and fitted This: VW GOLF MK6 GTD 2009-2012 FLAT BOTTOM STEERING WHEEL with DSG Paddles to my: 2011 vw T5GP 7speed DSG shuttle.
Fitted the 2 wires from clock spring pins 9 and 10
Pin 9 on clock spring to an ignition live, To pin 15 on the light switch This works the illumination on the steering wheel with the lights switched On.
Pin 10 on clock spring to pin 17 of the white 73pin plug on the body control module ,
this already has a wire in that position as its the Lin bus, Lilac and white wire I have soldered this connection.
My problem: No buttons work left or right,
What does work: DSG paddles and horn work fine,
All the buttons illuminate,
Can anybody help solve my problem Please?
Regards
Patrick
Regards
Patrick
Monday,11,November,2019,16:50:56:39175
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
VIN: WV2ZZZ7HZBH114478 License Plate:
Mileage: 245200km-152360mi Repair Order: 11-11-19 faults
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 4B 56 0B
VIN: WV2ZZZ7HZBH114478 Mileage: 245200km-152360miles
4B-Multifunc. Module -- Status: Cannot be reached 1100
Address 01: Engine (J623-CCHA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 DH HW: 03L 907 309 K
Component: R4 2,0L EDC X41 9133
Revision: 26X41--- Serial number: 00000000000000
Coding: 0125401A232400080000
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
ROD: EV_ECM20TDI01103L906019DG.rod
VCID: 74B2D67CBE32BFD7DDF-8020
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 045 J HW: 0BH 927 711 C
Component: DSG DQ500-7F H04 1407
Revision: 00H04V01
ROD: EV_TCMDQ500021_VW36.rod
VCID: 3C223E5CD6E23797D5F-8068
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 G HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0105
Revision: 00H43001
Coding: 208724AD09A5049924A69078AA6616
Shop #: WSC 02756 790 49152
VCID: 36362C74E84EEDC723B-8062
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 AJ HW: 7E5 907 047 AJ
Component: Climatic-T5 H11 0203
Revision: 00005001
Coding: 0000000002
Shop #: WSC 02757 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 77A8E170AF44D4CFF8D-8022
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 F HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0230
Revision: BO047001 Serial number: 0396 071110566
Coding: B8B879B86E61261383284ED07EEA9EDCF08041FF60840000300000000000
Shop #: WSC 02754 790 12345
VCID: 37282170EF4414CF38D-8062
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 100311 05 54 0403
Coding: 03302E
Subsystem 2 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3311
Coding: 050000
Subsystem 3 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3311
Coding: 050000
Subsystem 4 - Part No: 7E1 951 171
Subsystem 5 - Part No: 1K0 951 605 C
Subsystem 6 - Part No: 7E1 951 171
Subsystem 7 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0142037
Coding: 830000
Mileage: 245097 km
Date: 2014.04.02
Time: 00:43:37
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 C HW: 7E0 919 475 A
Component: PARKHILFE 8K H11 0011
Revision: -------- Serial number: 47401035600423
Coding: 000102
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_VW75XParkAssis8K A01004
ROD: EV_VW75XParkAssis8K_A01.rod
VCID: 323E106404A6F1E70F3-8066
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H06 0013
Revision: -------- Serial number: 003HL004EFE2
Shop #: WSC 02754 790 50316
VCID: 35342B78F5C8E6DF2A1-8060
Part No SW: 7E0 920 970 C HW: 7E0 920 970 C
Component: KOMBI H20 0220
Coding: 160E00
VCID: 2A0E08042C76B927B73-807E
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 A
Component: J737__Standheizung 0404
Revision: 00085000 Serial number: 09019275D00000
Coding: 0000031
Shop #: WSC 13636 131 88224
VCID: 2310E52047DC686FF45-8076
01444 - Under-Voltage Shut-Off (Automatic)
Mileage: 245097 km
Date: 2014.04.02
Time: 00:50:48
Temperature: 6.0°C
Voltage: 14.01 V
Temperature: 4.0°C
01414 - Combustion-Air Blower (V6)
007 - Short to Ground
Fault Status: 01100111
Mileage: 245099 km
Date: 2014.04.02
Time: 00:54:48
Start
Temperature: 4.0°C
Voltage: 14.28 V
Temperature: 2.0°C
02251 - Heater Unit Locked
Mileage: 245123 km
Date: 2014.04.02
Time: 23:14:50
Malfunction
Temperature: 11.0°C
Voltage: 14.01 V
Temperature: 2.0°C
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 0230
Coding: 040300
VCID: 70BADA6CCAAA83F7397-8024
01304 - Radio
Reset counter: 102
Mileage: 245097 km
Date: 2014.04.02
Time: 00:43:41
03590 - Control Module for Multifunction Module
Reset counter: 102
Mileage: 245097 km
Date: 2014.04.02
Time: 00:43:42
Component: IMMO H20 0220
VCID: 6A8EC804ECF67927773-803E
Address 4B: Multifunc. Module
Address 56: Radio
End----(Elapsed Time: 02:28, VBatt start/end: 11.9V/11.6V. VIgn 11.6V)-----
