Results 1 to 3 of 3
Thread: Skoda Kodiaq MY17, auto-hold connection to driver profile
    Sep 2015
    My Kodiaq has three keys and three different driver profiles attached to those keys. This is nice, since almost every setting is connected to profiles, no need to do manual adjustments to mirrors, seats etc.
    Except for one thing. Auto-hold does not seem to remember it's setting. If you leave it active, it will be active even for another driver. Or vice versa, leave it off and it will be off for all drivers. And when you have one driver who likes to keep it active and another one who really does not, it is somewhat annoying.
    Any guesses, if this behaviour could be altered? It would be really cool, if this was also connected to driver profiles. But so far, I have not been able to figure out how to do so, or if it is even possible. Below is the auto-scan of the car in question.
    Friday,25,October,2019,18:48:33:26429
    VIN: TMBLK7NS9H8028838   License Plate:
    Mileage: 100485km-62438mi   Repair Order:
    Chassis Type: NS-SK37 (3Q0)
    Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 22 29 2B 36 39
              3C 42 44 47 52 55 5F 69 6C 6D 75 A5 CA D6 D7
    VIN: TMBLK7NS9H8028838   Mileage: 100485km-62438miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H25 3916
       Revision: B4H25---
       Coding: 0125003A04761D083000
       Shop #: WSC 33361 790 00063
       ASAM Dataset: EV_ECM20TDI01104L906026EJ 004004
       ROD: EV_ECM20TDI01104L906026EJ_004.rod
       VCID: 76B51B1A48414E67E3B-8022
       Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2014
       Revision: 00H06V07
       VCID: 3333E20E1BB31B4F045-8066
       Revision: 00000000    Serial number: 61297000001199
       Coding: 60076A9F54220B74477F070362CB4906562AD0E2E046927D386150F8E2AA4200002F641A1B13111435351919323200
       VCID: 77AB161E4F4B376FF8D-8022
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0441013672
       Coding: 032C0C0F03
       VCID: 3C21C93236EDD437D5F-8068
       Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
       Component: GEB.F.Heckoef  H17 0904
       Serial number: 58066189
              U1400 00 [008] - -
                        Reset counter: 43
                        Mileage: 100356 km
                        Date: 2019.10.25
                        Time: 15:22:17
                        ZAT_pressed: OFF
                        Control Module Voltage: 8.357 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 111.0 /min
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: closed
                        Front Passenger Door: closed
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Component: Sitzmemory    H08 0021
       Serial number: Y0006QDK24573
       Coding: 0010000000000500018281818181000000008181000000D400
       ASAM Dataset: EV_SeatMemorPasseSide 002021
       ROD: EV_SeatMemorPasseSide.rod
       Part No SW: 565 907 044 AE    HW: 565 907 044 AE
       Revision: 00001K00
       Coding: 16010104004411011105100D0000110A
       Shop #: WSC 73430 790 00063
       VCID: 5EE563BAC0B1E6279BB-800A
       Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
       Component: G238 _AQS  H30 0119
       Serial number: 98189202
       Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 032 0223
       Revision: --------    Serial number: 8658060517000J
       ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
       ROD: EV_BCMBOSCH_017.rod
       VCID: 015F78C6118F79DFC69-8054
       Subsystem 1 - Part No SW: 566 955 119     HW: 566 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS326 170328  051 0907
       Serial number: 887353F0401708700512
       Coding: 164DDD
       Component: RLHS  042 0105
       Serial number: S9Y17M05D08H16M46S45
       Coding: 0088DF
       Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0021
       Serial number: 000405177478022
       Coding: 0231267A51
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       ROD: EV_EPHBO2CVW3260000.rod
       VCID: 3B23CA2E33E3D30FDC5-806E
       Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0156
       Coding: 320147CB50FF8728749C8065304085
       ASAM Dataset: EV_ACCMRRCONTIVW376 001011
       ROD: EV_ACCMRRCONTIVW376_001.rod
    1389 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [FAULT_VBAT_BUSMON_LOW]
                        Reset counter: 43
                        Mileage: 100356 km
                        Date: 2019.10.25
                        Time: 15:22:18
                        Voltage terminal 15: 9.4 V
                        Control Module temperature: 39 °C
                        Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
                        Status_ACC_System: ACC_Init
       Serial number: 18041741350653
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 3829D52202D5F817317-806C
       Part No SW: 3Q0 959 655 AK    HW: 3Q0 959 655 AK
       Component: Airbag VW21   004 0306
       Revision: --------    Serial number: 003R6P84LE5R
       Coding: 98CCC0C0000000005C5400CF004800000065
       ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 074B66DE3FAB47EF88D-8052
       Subsystem 1 - Part No SW: -----------    HW: 454 000 205 17
       Serial number: 3570000000018120A420
       Subsystem 2 - Part No SW: -----------    HW: 454 000 205 17
       Serial number: 35800000000C2C30A42I
       Subsystem 3 - Part No SW: -----------    HW: 454 800 205 17
       Serial number: 3510089F28310000000C
       Subsystem 4 - Part No SW: -----------    HW: 454 800 205 17
       Serial number: 35200735787100000005
       Subsystem 5 - Part No SW: -----------    HW: 454 801 504 17
       Serial number: 35500796DE50F000000$
       Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0245
       Revision: FF036036    Serial number: 20170515500850
       Coding: 6414
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7CA10932766D143795F-8028
    291104 - Temperature Sensor for Heated Steering Wheel
              B1455 01 [008] - Electrical Failure
                        Reset counter: 44
                        Time: 00:00:00
                        Ubat 30 Voltage: 12.40 V
                        Internal error state: 0
                        LIN_Temp: 0
                        Isense: 0
                        Max.Leistung: 110
                        PWM: 0
                        Offset: 16
                        Slope: 134
                        kp: 18
                        OUT: 50
                        Temperatur Statisch: 30
                        p_t_soll_0: 34.00 °C
                        p_t_soll_1: 39.00 °C
                        p_t_soll_2: 44.00 °C
       Part No SW: 565 920 751     HW: 565 920 751
       Component: KOMBI         311 8311
       Coding: 03A5081CFF84000801886B0B5001000800000000
       Shop #: WSC 73430 031 00063
       VCID: 58E975A2A2951817D17-800C
       Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
       Component: STH-MQB       008 0075
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       VCID: 3A2DCF2A3CD9EA07C73-806E
       Component: R64 D208L  004 0401
       Serial number: 00000000000000241622
       Component: GW MQB High   518 5286
       Serial number: 07051710800030
       Coding: 0B01003445087300EB03225A9E0F00010001070000000000000000000000
       Shop #: WSC 33361 790 00114
       ROD: EV_GatewNF.rod
       VCID: 2F3BEE7EF79B3FAF60D-807A
       Subsystem 2 - Part No SW: 3V0 919 719 C    HW: 3V0 919 719 C
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000A1815190417
       Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
       Serial number: 75886100001705040B22
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 H    HW: 5Q0 907 155 H
       Component: U13DCAC  H25 0780
       Serial number: 0013773
       Serial number: HA1-00026.03.17
       Coding: 0101
       VCID: 4ACD9FEA6C397A87573-801E
    Address 29: Left Light (J1018)       Labels: None
       Part No SW: 8V0 907 397 AD    HW: 8V0 907 397 D
       Component: LCM_MLBevoH05 0024
       VCID: 06556BDA38A15EE7F3B-8052
       Serial number: 17000116788015
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BF2806212F695F369-8024
       Serial number: Y0006QDK14886
    Address 39: Right Light (J1023)       Labels: None
       Part No SW: 5Q0 907 686 C    HW: 5Q0 907 686 B
       Component: HRE_Master    H12 0081
       Serial number: 0438592042
       Coding: 02012103
       Shop #: WSC 43324 002 1048576
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D27C4362DF7DD3FE21-8068
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 B
       Component: HRE_Slave  H12 0081
       Serial number: 0440829488
       Coding: 020121
       Component: TSG FS        010 0032
       Serial number: 0000255786274
       Coding: 00150920DE00040000001100
       VCID: 47CBA6DE7F2B87EF48D-8012
       Serial number: 00000000000014679392
       Coding: 010200
       Revision: 00000000    Serial number: 0001644929
       Coding: 01010011004001
       ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
       VCID: 40D9BDC25A05B0D7897-8014
       Part No SW: 81A 035 223     HW: 81A 035 223
       Component: MIB2_amp_P_SK H10 0410
       Revision: 00000001    Serial number: SKZ8Z1HJE01QNAM
       Coding: 0323160000AA002AAA0000000000
       ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
       ROD: EV_AMPMst16C4Gen2ALPI.rod
       VCID: 59EF70A6D99F011FEE9-800C
       Component: TSG BFS       010 0032
       Serial number: 0000257250262
       Coding: 00150120DE00040000001100
       VCID: 46D5ABDA78219EE7B3B-8012
       Serial number: 00000000000014613733
       Coding: 190200
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0070
       Coding: 03E202003D210901
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_SK37.rod
       VCID: 41DFB8C6510FB9DF869-8014
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
       Part No SW: 3V0 035 043 D    HW: 3V0 035 043
       Component: MU-H-N-EU     H50 0942
       Serial number: A677D0HS009230
       Coding: 032316010000000051110002000808232F0300E4012081009E
       VCID: 2C01F972C68D44B745F-8078
       Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
       Component: ABT_Std-2_Nav  H35 8077
       Serial number: SKZ6ZHT1360105
       Subsystem 2 - Part No SW: V03 959 803 TF    HW: -----------
       Component: ECE 2019/2020  --- 0177
       Component: Gracenote2---  --- 1013
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0441297010
       Coding: 0100000202000000
       Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
       Component: Areaview 2    H13 0607
       Serial number: C854707JG014238
       Coding: 04231601A70FA00000604014
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: 31351429200000
       Coding: 1B88
       Part No SW: 5NA 035 284 A    HW: 5NA 035 284 A
       Component: OCULowMQBLGE  H13 0615
       Coding: 03231601EA423A0D3B1C9E020045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 003042
       ROD: EV_OCULowMQBLGE_003_VW25.rod
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 15091712P22800
       Coding: 020307060000040100262355C050A90098000E200020
       Shop #: WSC 39697 001 1048576
       Coding: 008040648202
       Part No SW: 7PP 941 571 AE    HW: 7PP 941 571 A
       Component: LED1L         H09 0007
       VCID: 186935A26215D817117-804C
       Component: LED1R         H09 0007
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    End----------(Elapsed Time: 04:34, VBatt start/end: 13.3V/13.3V)-----------
    Dec 2016
    DE
    There is no way to connect the Auto-Hold to a driver profile.
  3. Likes Mika_M liked this post
    Sep 2015
    Well that's a disappointment. Thanks for the info anyway, no need to dig deeper then.
