Results 1 to 2 of 2
Thread: Audi 4.2L v8 (BVJ) wacky idle
    Oct 2019
    Cleveland, OH
    Hey guys, this is my first post to the forum and I'm looking to get some help. A little back story on the car: It is a 2007 A6 4.2 V8 that I bought a while ago for $2k because the guy thought it needed a headgasket, but I figured it was just intermediate cooling pipe o-rings (which it was). So I do know how to work on these cars, but this new problem has me stumped. It has 128k miles and runs perfectly aside from the idle.
    The Problem:
    I have a random code for the HP fuel sensor and one for the O2 sensor. They only pop up once a day on the first cold start when it gets to about 640rpm (see AutoScan)
    And this thing idles like a cammed out 70's muscle car when warm at about 640rpm. when cold started it has misfires but the computer does not recognize any (checked adv. blocks in vcds and 0's across the board)
    Things I have done:
    Oil Flush and change 1k miles ago
    Run injector cleaner
    Performed the CRC Intake valve cleaning with the car running (not manual clean) Valves looked fine when I had the intake off but was planning to do a cleaning when it warms up again in the spring.
    New PCV valve
    New Coils
    New Valvecover gaskets
    Fixed all oil leaks
    Things I question:
    Intake runners are operated by two motors, but bank 2 is higher than bank 1 (misaligned?) ..Throttle body adjustment performed, didn't change anything.. There is a high pitched whining sound
    from the actuator motor when the car is turned off. (almost like its stuck, but moves freely when revved)
    Had an intermittent "Bank 1 catalyst Below efficiency" That went away about 6 months ago and hasn't come back (I've heard these cats go bad)
    Runs up the RPM range perfectly with no misfires
    Block 93 has all adjustments between -/+2 except for Bank 2 intake phase position that has no reading (Blank box).
    I removed and regapped all of the spark plugs to 0.028 and it seems to have liked it just slightly more, but the spark plugs are AutoLite Platinum (from what I understand a sub-par spark plug)
    So Just looking to see what would be next recommended as far as what to do, my thoughts were swapping the camshaft sensors to try and get a reading on bank 2 Intake position Phase and then probably inspect the catalytic converter.
    AutoScan:
    Ignore the electrical faults, that was due to a bad Sirius module That was draining the battery. ( battery was and is fully charged now)
    Friday,08,November,2019,09:29:57:10008
    VIN: WAUDV74FX7N053017   License Plate: JJ
    Mileage: 207010km-128630mi   Repair Order:
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
              53 55 56 61 62 65 67 6C 72 76 77
    VIN: WAUDV74FX7N053017   Mileage: 207010km-128630miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    Address 01: Engine        Labels:. 079-907-560-BVJ.clb
       Part No SW: 4F1 910 560 A    HW: 4F1 907 560
       Component: 4.2l V8/4V          0030
       Revision: 74H03---    Serial number:
       Coding: 01050009190F0120
       Shop #: WSC 06117 444 52446
       VCID: 211FE2C4DDCB9B8FE69-8074
    004506 - Fuel Pressure Sensor (G247)
                   P119A - 001 - Malfunction - Intermittent - MIL ON
                        Fault Status: 10100001
                        Mileage: 206846 km
                        Date: 2019.11.05
                        Time: 09:52:12
                        RPM: 671 /min
                        Load: 20.4 %
                        Temperature: 87.0°C
                        Temperature: 6.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 14.224 V
    004369 - Oxygen (Lambda) Sensor Regulation: Bank 1
                   P1111 - 001 - System too Lean
                        Fault Status: 01100001
                        Mileage: 206905 km
                        Date: 2019.11.06
                        Time: 10:19:43
                        RPM: 650 /min
                        Load: 18.0 %
                        Temperature: 84.0°C
                        Temperature: 41.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.605 V
       Part No SW: 4F2 910 156 H    HW: 09L 927 156 C
       Component: AG6 09L 4,2lFSI USA 0010
       Revision: --H01---    Serial number:        4229218
       Shop #: WSC 02325 785 00200
       VCID: 2A0D05E8A0FD58D7B73-807E
    006231 - Load Signal
                   P1857 - 001 - Error Message from ECU - Intermittent
                        Fault Status: 00100001
                        Mileage: 206702 km
                        Date: 2019.10.30
                        Time: 10:36:39
                        RPM: 672 /min
                        RPM: 672 /min
                        (no units): 30.0
                        (no units): 24.0
                        Temperature: 89.0°C
                        T.B. Angle: 0.0°
    Address 03: ABS Brakes        Labels:
       VCID: 55F78614DC03272FCA1-FFFE
       Part No SW: 4F0 910 852 A    HW: 4F0 905 852 C
       Component: FBSAUDIC6 ELVSG H01 0030
       Revision: 31050601    Serial number: 10601200532485
       Coding: 0000007
       Shop #: WSC 02323 785 00200
       VCID: 2411EBD0C2D98EA78DF-8070
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 KSG   H27 0080
    00190 - Driver's Door Handle Touch Sensor (G415)
                        Fault Status: 00111011
                        Reset counter: 172
                        Mileage: 206564 km
                        Date: 2019.10.28
                        Time: 10:54:25
    00192 - Rear Left Door Handle Touch Sensor (G417)
                        Reset counter: 166
                        Mileage: 206842 km
                        Date: 2019.11.04
                        Time: 18:33:14
       Part No SW: 4F0 910 732 R    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 361HO067505326
       Coding: 0000003
       Shop #: WSC 02335 785 00200
       VCID: 323D1D88882D10170F3-8066
       Component: Bedienteil MMIC6H02 0060
       Subsystem 2 - Serial number: 00000000520262
       Subsystem 3 - Serial number: 0108.09.060000000100010997˙
       Subsystem 4 - Serial number: 010997˙
    00384 - Optical Databus
                        Fault Status: 00101011
                        Fault Frequency: 70
                        Reset counter: 164
                        Mileage: 206711 km
                        Date: 2019.10.31
                        Time: 06:31:13
       Part No SW: 4F0 910 043     HW: 4F1 820 043 AC
       Component: KLIMABETAETIGUNGH20 0170
       Revision: 00000031    Serial number: 00000000309961
       Coding: 0532520
       VCID: 5BE3902CBF27F15FFC5-800E
                        Fault Status: 00101010
                        Fault Frequency: 7
                        Reset counter: 173
                        Mileage: 206563 km
                        Date: 2019.10.28
                        Time: 10:42:09
                        Temperature: 24.0°C
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
                        Reset counter: 167
                        Mileage: 206585 km
                        Date: 2019.10.28
                        Time: 13:39:49
                        Voltage: 14.40 V
                        (no units): 221.0
                        (no units): 255.0
       Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
       Coding: 0113123
       VCID: 3039178086212207797-8064
       Subsystem 1 - Part No: 4F1 910 113 B  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0210
       Coding: 00064784
       Shop #: WSC 02335
       Component: REGENLICHTSENSORH12 0090
       Coding: 00146221
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBF8189177
       VCID: 1C61D330FAA9B66735F-8048
    Address 0F: Digital Radio
       Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
       Component: 66 AIRBAG AUDI8RH29 0300
       Revision: 14H29000    Serial number: 00359D0BBX87
       Coding: 0013878
       Subsystem 1 - Part No: 4F0 910 339 A
       Component: BF-Gewichtsens. H02 0050
       Subsystem 2 - Serial number: 6332CSME123F0D22%
       Subsystem 3 - Serial number: 6342CSME131C682E9
       Subsystem 4 - Serial number: 6352QSME110C7A73I
       Subsystem 5 - Serial number: 6362QSME12684D6DV
       Subsystem 6 - Serial number: 63734SME14232D1B
       Subsystem 7 - Serial number: 63834SME45733B0F7
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
       Revision: 00H03000    Serial number: 90025062230448
       Coding: 0012241
       VCID: 270BFCDCB3EF65BFA8D-8072
       Component: E0221           H07 0090
       Part No SW: 4F0 910 930 C    HW: 4F0 920 981 G
       Component: KOMBIINSTR. M73 H18 0110
       Revision: 00400000    Serial number: 5FG78A696
       Coding: 2129263
       Shop #: WSC 41251 067 57207
       VCID: 2313E8CCC7D7899FF45-8076
       Part No SW: 4L0 910 468     HW: 4L0 907 468
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0900B06901800B
       Coding: F5D5DE77307A06
       Shop #: WSC 02334 785 00200
       VCID: 6C81C3F06A8986E705F-8038
    01771 - Control Module for Headlight Range (J431)
                        Reset counter: 113
                        Mileage: 206563 km
                        Date: 2019.10.28
                        Time: 10:42:06
                        Reset counter: 162
                        Mileage: 206721 km
                        Date: 2019.10.31
                        Time: 07:45:35
    02230 - Digital Radio (DAB) (R147)
                        Reset counter: 124
                        Mileage: 206802 km
                        Date: 2019.11.04
                        Time: 09:42:28
       Coding: 0082954
       VCID: 619FA2C49D4BDB8FA69-8034
       Part No SW: 4E0 910 888 C    HW: 4E0 919 887 D
       Component: MNS US          H48 0960
       Revision: 00000000    Serial number: 381HW067504828
       VCID: 2E0509F89C1534F76BB-807A
    02444 - Disk Drive Load / Eject Malfunction
                        Fault Frequency: 130
                        Reset counter: 133
                        Time Indication: 15
       Component: TSG FA          H12 0120
       Revision: 00-00000
       Coding: 0051947
       Shop #: WSC 02327 785 00200
       VCID: 2C0103F0AA0946E745F-8078
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01019348630000
       Coding: 4619421
    01134 - Alarm Horn (H12)
                        Reset counter: 133
                        Mileage: 195260 km
                        Date: 2019.02.14
                        Time: 16:00:28
       Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
       Component: DSP-High C6     H09 0240
       Revision: PROD_01     Serial number: 00000000013231
       Coding: 0000026
       Shop #: WSC 37605 000 1048576
       VCID: 2517F6D4C9E377AF9A1-8070
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000038578
       Coding: 0012014
       VCID: 5EE59938AC35E4779BB-800A
       Component: TSG BF          H12 0120
       Revision: 00-00000
       Coding: 0051947
    Address 53: Parking Brake
    Address 55: Headlight Range
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 H
       Revision: 00000000    Serial number: 394IX067680180
       VCID: 313F12848D2B2B0F769-8064
       Revision: 00000000    Serial number: 00000000101014
       Shop #: WSC 06117 444 64721
       Component: von VA0  2609070297
       Coding: 344630393135313035442056413032363039303730323937
       Shop #: WSC 00000 384 00290
    02256 - Quiescent Current
                        Reset counter: 162
                        Mileage: 206741 km
                        Date: 2019.10.31
                        Time: 21:31:18
       Coding: 0051754
       Revision: 00050100    Serial number: 00000700029445
       Coding: 0062422
       VCID: 221DEDC8D8CD8097FF3-8076
                        Fault Status: 11100010
                        Reset counter: 25
                        Mileage: 203646 km
                        Date: 2019.08.15
                        Time: 08:48:48
                        (no units): 0.0
                        Voltage: 14.30 V
                        (no units): 19.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000609010244
       Shop #: WSC 12336 024 394758
       VCID: 34311B9072391E271DF-8060
       Part No SW: 4F0 910 441     HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J6820IV
       Coding: 1000304
       VCID: 5DE79E34A133FF6F821-8008
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Coding: 0051754
       Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
       Revision: 00H09000    Serial number: 06220624703372
       Coding: 0021206
       Component: Handyvorb2      H13 1130
       Revision: 00000000    Serial number: 00000007541741
       Coding: 0010900
       VCID: 2809FFE0BEF16AC7A17-807C
    End----------(Elapsed Time: 02:04, VBatt start/end: 14.2V/14.6V)-----------
    Welcome to the VCDS forum OP and did you JPPSG yet?
    Maybe induced issue during repairs conducted?
    VVVVVAT Time is it & for air leak repair/trace/HPP mechanical's for inadequate stroke/leak down, injectors being plugged/incorrect atom pattern or HPP or lift FP and to be un pimped to remove the FOD + enhance grounds?
    You mean change parts on these cars right and to your knowledge correctly, maybe recheck work?
