Aggressive mode or no aggressive mode
mrlapou
C?ID=42756
Having read a post on another forum about aggressive mode, I conducted a test.
In aggressive mode, x2 faults were flagged up regarding the NOx sensor showing P2209 and U029D codes.
However ever with aggressive mode not checked, these codes did not appear and no faults found.
Log with aggressive box checked
Monday,11,November,2019,10:42:21:33763
VIN: WVGZZZ5NZHW827920   License Plate: FL66NYW
Mileage: 55329km-34379mi   Repair Order: Af
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 29 39 42 44 52 55 5F 6C
          6D A5 BB BC CA D6 D7
VIN: WVGZZZ5NZHW827920   Mileage: 55329km-34379miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HT    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3030
   Revision: B4H24---
   Coding: 0125003203661D082000
   ASAM Dataset: EV_ECM20TDI01104L906026HT 004002
   ROD: EV_ECM20TDI01104L906026GP_004.rod
   VCID: 035388274B9D262FD45-8056
9879 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
          P2209 00 [096] - Implausible Signal
                    Mileage: 54489 km
                    Date: 2019.10.17
                    Time: 12:21:08
                    Engine speed: 1425.50 /min
                    Normed load value: 87.1 %
                    Vehicle speed: 81 km/h
                    Coolant temperature: 65 ∞C
                    Intake air temperature: 58 ∞C
                    Voltage terminal 30: 14.900 V
                    NOx sensor before SCR cat conv: NOx concentration: 187 ppm
                    NOx sensor before SCR catalytic converter: supply voltage: 14560 mV
                    Extern.temp.sens.1 bank 1: raw value: 6.5 ∞C
                    Mean injection quantity: 26.12 mg/stroke
28991 - No Communications with NOX Sensor 1
          U029D 00 [032] - -
                    Mileage: 55018 km
                    Time: 00:00:00
                    Coolant temperature: 14 ∞C
                    Intake air temperature: 15 ∞C
                    Voltage terminal 30: 11.420 V
                    Cruise Control System (CCS): status-Bits 0-7: 6
                    CAN status - brake control module 1-Bits 0-7: 8
                    selected gear-Bits 0-7: 0
   Part No SW: 0DL 300 011 A    HW: 0DE 927 711
   Component: GSG DQ500     H12 1412
   Revision: 00H12V32
   VCID: 2615F1B3986F330793B-8072
   Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
   Component: ESC           H25 0507
   Revision: 00000000    Serial number: 62316000000777
   Coding: 0AEE929A34220B734780670262C34950492CD0E2E646927D38625078C22A02
   VCID: 78A9EFCB025B75F7F17-802C
   Part No SW: 5NA 907 044 K    HW: 5NA 907 044 K
   Component: AC Automat    H35 4003
   Revision: 20K08000    Serial number: 00000B00213997
   Coding: 0012012420211001110510000010112A
   ASAM Dataset: EV_ACClimaPrehVW37X 002014
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 47CB5C373F25CA0F48D-8012
   Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
   Serial number: 00000000000000000000
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001623903987
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5B04D7277542CFB0D-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 160728  033 0372
   Serial number: 00000001607250306391
   Coding: 0E45DD
   Component: RLHS  042 0105
   Serial number: S5Y16M08D31H12M56S12
   Coding: 06A8DD
   Serial number: 000000000ZY161960H5R
   Serial number: 00000000000066838942
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H10 0021
   Serial number: 001808167478092
   Coding: 0331563851
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3B2330C773ED9EEFDC5-806E
13679388 - Databus
          [Lenkhilfe - LH_EPS_01.EPS_PLA_Status - Fehlerspeicher auslesen]
                    Reset counter: 214
                    Mileage: 54575 km
                    Date: 2019.10.19
                    Time: 18:28:29
   Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0233
   Coding: 320067C358FF8728749C8145304087
   VCID: 3E2539D360FF8BC7FBB-806A
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0315
   Serial number: 003TDR228A3B
   Coding: 98CCC0C00C0000005C5400CF008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 1079B76B0AEB4DB7597-8044
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1032
   Serial number: 5NC857705C0237Q01617
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1032
   Serial number: 5NC857706C0236Q00996
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 608 16
   Serial number: 357000000008D215CD1R
   Subsystem 4 - Part No SW: -----------    HW: 480 002 508 16
   Serial number: 358000000005EB399D1
   Subsystem 5 - Part No SW: -----------    HW: 480 402 908 16
   Serial number: 3510001A72216EE1F2FD
   Subsystem 6 - Part No SW: -----------    HW: 480 400 109 16
   Serial number: 3520001BD22707F19585
   Subsystem 7 - Part No SW: -----------    HW: 480 402 808 16
   Serial number: 3550001AB2216EE3F50B
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 608 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001A52216EE364D7
   Subsystem 9 - Part No SW: -----------    HW: 480 402 608 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001AD2216EE1C3EK
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 402 608 16
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001A52216EE632A
   Subsystem 11 - Part No SW: -----------    HW: 480 002 308 16
   Serial number: I0M000000004C37DDD1K
   Subsystem 12 - Part No SW: -----------    HW: 480 002 308 16
   Serial number: I0N00000000494BC0E1A
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160824400233
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41DF422F1101F43F869-8014
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         405 2153
   Coding: 27A400086F84260001886B031401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   Revision: --------    Serial number: 0005238889
   Coding: 030500041F087300FB07225E1E0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA1F3DB366359D795F-8028
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 2231623360302477AS2B
   Coding: 2D0000
   Serial number: 5504621304
197175 - Control unit for battery monitoring
          U1050 00 [008] - No Communication
          [BDM (LIN#1) Timeout]
                    Reset counter: 214
                    Mileage: 54473 km
                    Date: 2019.10.16
                    Time: 10:35:54
                    Supply voltage: Terminal 30: 11.6 V
                    Terminal 15: On
66565 - Diagnostic Databus
          U1202 00 [008] - Malfunction
          [Bus defekt CAN-Diagnose]
                    Reset counter: 194
                    Mileage: 54473 km
                    Date: 2019.10.16
                    Time: 16:49:16
                    Supply voltage: Terminal 30: 11.5 V
                    Terminal 15: On
   Serial number: HA1-00019.07.16
   Coding: 0101
   VCID: 4ACD65032C373767573-801E
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH07 0014
   VCID: 45D7563F0529D81FBA1-8010
   Serial number: 060416ED313449
   Coding: 003F0A20D001048000001000
   VCID: 43D348270B1DE62F945-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   Serial number: 150816EHE01951
   Coding: 003F0020DE01048000001000
   VCID: 42DD4D231407EF279F3-8016
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0051
   Coding: 08AE00104B200201
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0757
   Coding: 02730601FF00000051110101008808001F0100E6012000008F
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 313F12EFA1A164BF769-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL038HB
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0123060122002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
   VCID: 77ABECF70F457A8FF8D-8022
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30871625900000
   Coding: 0A00
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 3FDB44D767F582CFF0D-806A
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 17081611K10276
   Coding: 000307060000040100021344C050A10094000E200040
   VCID: 3A2D35C37CD7A7E7C73-806E
   Serial number: 290716EGS03559
   Coding: 002A00200100048000001000
   Serial number: 290716EGS0325A
   Component: SAD_STG_1     013 0005
   Coding: 308040732602
   VCID: 3D273EDF6DF990DFE21-8068
   VCID: 1675C173280FA38703B-8042
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----(Elapsed Time: 01:58, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Log with aggressive box Not checked
Monday,11,November,2019,10:45:53:33763
Mileage: 55329km-34379mi   Repair Order: non agressive
   Revision: B4H24---
   Revision: 00H12V32
   Coding: 0E45DD
   Coding: 06A8DD
   Coding: 0331563851
13679388 - Databus
                    Reset counter: 214
                    Mileage: 54575 km
                    Date: 2019.10.19
                    Time: 18:28:29
   Coding: 80000D
   Coding: 80000D
   Coding: 0C10
   Coding: 2D0000
                    Reset counter: 214
                    Mileage: 54473 km
                    Date: 2019.10.16
                    Time: 10:35:54
                    Terminal 15: On
                    Reset counter: 194
                    Mileage: 54473 km
                    Date: 2019.10.16
                    Time: 16:49:16
                    Terminal 15: On
   Coding: 0101
   Coding: 9307
   Coding: 0A00
End(Elapsed Time: 02:03, VBatt start/end: 11.9V/11.8V. VIgn 11.9V, udsna)--
No real surprise; they are: "Intermittent - Not Confirmed"
Since they are in 01-Engine, for try the following "for science":
[OBD-II]
[Mode 3 Current DTCs] (I'm near certain there won't be any)
[Mode 7 Pending DTCs] (I'm curious if anything shows up there)
mrlapou
C?ID=42756
I did not have the time, so left it to VW, who carried out a check.
NOx code remained and the sensor was changed.
In the past 3 weeks, on a 33k mile vehicle, the NOx and DPF differential sensors have been changed under warranty, which could have been a huge bill !!!!
