Results 1 to 3 of 3
Thread: Aggressive mode or no aggressive mode
    Oct 2019
    Having read a post on another forum about aggressive mode, I conducted a test.
    In aggressive mode, x2 faults were flagged up regarding the NOx sensor showing P2209 and U029D codes.
    However ever with aggressive mode not checked, these codes did not appear and no faults found.
    Log with aggressive box checked
    Monday,11,November,2019,10:42:21:33763
    VIN: WVGZZZ5NZHW827920   License Plate: FL66NYW
    Mileage: 55329km-34379mi   Repair Order: Af
    Chassis Type: 5N-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 22 29 39 42 44 52 55 5F 6C
              6D A5 BB BC CA D6 D7
    VIN: WVGZZZ5NZHW827920   Mileage: 55329km-34379miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 HT    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H24 3030
       Revision: B4H24---
       Coding: 0125003203661D082000
       ASAM Dataset: EV_ECM20TDI01104L906026HT 004002
       ROD: EV_ECM20TDI01104L906026GP_004.rod
       VCID: 035388274B9D262FD45-8056
    9879 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
              P2209 00 [096] - Implausible Signal
                        Fault Frequency: 6
                        Mileage: 54489 km
                        Date: 2019.10.17
                        Time: 12:21:08
                        Engine speed: 1425.50 /min
                        Normed load value: 87.1 %
                        Vehicle speed: 81 km/h
                        Coolant temperature: 65 ∞C
                        Intake air temperature: 58 ∞C
                        Voltage terminal 30: 14.900 V
                        NOx sensor before SCR cat conv: NOx concentration: 187 ppm
                        NOx sensor before SCR catalytic converter: supply voltage: 14560 mV
                        Extern.temp.sens.1 bank 1: raw value: 6.5 ∞C
                        Mean injection quantity: 26.12 mg/stroke
    28991 - No Communications with NOX Sensor 1
              U029D 00 [032] - -
                        Mileage: 55018 km
                        Time: 00:00:00
                        Coolant temperature: 14 ∞C
                        Intake air temperature: 15 ∞C
                        Voltage terminal 30: 11.420 V
                        Cruise Control System (CCS): status-Bits 0-7: 6
                        CAN status - brake control module 1-Bits 0-7: 8
                        selected gear-Bits 0-7: 0
       Part No SW: 0DL 300 011 A    HW: 0DE 927 711
       Component: GSG DQ500     H12 1412
       Revision: 00H12V32
       VCID: 2615F1B3986F330793B-8072
       Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
       Component: ESC           H25 0507
       Revision: 00000000    Serial number: 62316000000777
       Coding: 0AEE929A34220B734780670262C34950492CD0E2E646927D38625078C22A02
       VCID: 78A9EFCB025B75F7F17-802C
       Part No SW: 5NA 907 044 K    HW: 5NA 907 044 K
       Component: AC Automat    H35 4003
       Revision: 20K08000    Serial number: 00000B00213997
       Coding: 0012012420211001110510000010112A
       ASAM Dataset: EV_ACClimaPrehVW37X 002014
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 47CB5C373F25CA0F48D-8012
       Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
       Component: E265KlimaHeck  H02 0201
       Serial number: 00000000000000000000
       Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H34 0236
       Serial number: 02001623903987
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7F5B04D7277542CFB0D-802A
       Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
       Component: 326 RL 160728  033 0372
       Serial number: 00000001607250306391
       Coding: 0E45DD
       Component: RLHS  042 0105
       Serial number: S5Y16M08D31H12M56S12
       Coding: 06A8DD
       Serial number: 000000000ZY161960H5R
       Component: Sirene, DWA  005 0313
       Serial number: 00000000000066838942
       Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H10 0021
       Serial number: 001808167478092
       Coding: 0331563851
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       ROD: EV_EPHBO2CVW3260000.rod
       VCID: 3B2330C773ED9EEFDC5-806E
    13679388 - Databus
              [Lenkhilfe - LH_EPS_01.EPS_PLA_Status - Fehlerspeicher auslesen]
                        Reset counter: 214
                        Mileage: 54575 km
                        Date: 2019.10.19
                        Time: 18:28:29
       Component: ACCCONTIMQB   H01 0233
       Coding: 320067C358FF8728749C8145304087
       VCID: 3E2539D360FF8BC7FBB-806A
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0315
       Serial number: 003TDR228A3B
       Coding: 98CCC0C00C0000005C5400CF008800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 1079B76B0AEB4DB7597-8044
       Belt Pretensioner left:
       Serial number: 5NC857705C0237Q01617
       Coding: 80000D
       Belt Pretensioner right:
       Serial number: 5NC857706C0236Q00996
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 002 608 16
       Serial number: 357000000008D215CD1R
       Subsystem 4 - Part No SW: -----------    HW: 480 002 508 16
       Serial number: 358000000005EB399D1
       Subsystem 5 - Part No SW: -----------    HW: 480 402 908 16
       Serial number: 3510001A72216EE1F2FD
       Subsystem 6 - Part No SW: -----------    HW: 480 400 109 16
       Serial number: 3520001BD22707F19585
       Subsystem 7 - Part No SW: -----------    HW: 480 402 808 16
       Serial number: 3550001AB2216EE3F50B
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 402 608 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001A52216EE364D7
       Subsystem 9 - Part No SW: -----------    HW: 480 402 608 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001AD2216EE1C3EK
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 402 608 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001A52216EE632A
       Subsystem 11 - Part No SW: -----------    HW: 480 002 308 16
       Serial number: I0M000000004C37DDD1K
       Subsystem 12 - Part No SW: -----------    HW: 480 002 308 16
       Serial number: I0N00000000494BC0E1A
       Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20160824400233
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 41DF422F1101F43F869-8014
       Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
       Component: KOMBI         405 2153
       Coding: 27A400086F84260001886B031401000000000000
       Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1265
       Revision: --------    Serial number: 0005238889
       Coding: 030500041F087300FB07225E1E0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA1F3DB366359D795F-8028
       Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
       Serial number: 2231623360302477AS2B
       Coding: 2D0000
       Serial number: 5504621304
    197175 - Control unit for battery monitoring
              U1050 00 [008] - No Communication
              [BDM (LIN#1) Timeout]
                        Reset counter: 214
                        Mileage: 54473 km
                        Date: 2019.10.16
                        Time: 10:35:54
                        Supply voltage: Terminal 30: 11.6 V
                        Terminal 15: On
    66565 - Diagnostic Databus
              U1202 00 [008] - Malfunction
              [Bus defekt CAN-Diagnose]
                        Reset counter: 194
                        Mileage: 54473 km
                        Date: 2019.10.16
                        Time: 16:49:16
                        Supply voltage: Terminal 30: 11.5 V
                        Terminal 15: On
       Serial number: HA1-00019.07.16
       Coding: 0101
       VCID: 4ACD65032C373767573-801E
    Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH07 0014
       VCID: 45D7563F0529D81FBA1-8010
    Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
       Serial number: 060416ED313449
       Coding: 003F0A20D001048000001000
       VCID: 43D348270B1DE62F945-8016
       Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 9307
       ROD: EV_SteerAssisMQB_013.rod
       Serial number: 150816EHE01951
       Coding: 003F0020DE01048000001000
       VCID: 42DD4D231407EF279F3-8016
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0051
       Coding: 08AE00104B200201
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
       Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
       Component: MU-S-ND-ER    840 0757
       Coding: 02730601FF00000051110101008808001F0100E6012000008F
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 313F12EFA1A164BF769-8064
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL038HB
       Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H09 0170
       Coding: 0123060122002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
       VCID: 77ABECF70F457A8FF8D-8022
       Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0253
       Revision: --------    Serial number: 30871625900000
       Coding: 0A00
       VCID: 3FDB44D767F582CFF0D-806A
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0220
       Serial number: 17081611K10276
       Coding: 000307060000040100021344C050A10094000E200040
       VCID: 3A2D35C37CD7A7E7C73-806E
       Serial number: 290716EGS03559
       Coding: 002A00200100048000001000
       Serial number: 290716EGS0325A
       Component: SAD_STG_1     013 0005
       Coding: 308040732602
       VCID: 3D273EDF6DF990DFE21-8068
       Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
       Component: LED1L         H09 0003
       VCID: 1675C173280FA38703B-8042
       Component: LED1R         H09 0003
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    End----(Elapsed Time: 01:58, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Log with aggressive box Not checked
    Monday,11,November,2019,10:45:53:33763
    Mileage: 55329km-34379mi   Repair Order: non agressive
       Revision: B4H24---
       Revision: 00H12V32
       Coding: 0E45DD
       Coding: 06A8DD
       Coding: 0331563851
    13679388 - Databus
                        Reset counter: 214
                        Mileage: 54575 km
                        Date: 2019.10.19
                        Time: 18:28:29
       Coding: 80000D
       Coding: 80000D
       Coding: 0C10
       Coding: 2D0000
                        Reset counter: 214
                        Mileage: 54473 km
                        Date: 2019.10.16
                        Time: 10:35:54
                        Terminal 15: On
                        Reset counter: 194
                        Mileage: 54473 km
                        Date: 2019.10.16
                        Time: 16:49:16
                        Terminal 15: On
       Coding: 0101
       Coding: 9307
       Coding: 0A00
    End(Elapsed Time: 02:03, VBatt start/end: 11.9V/11.8V. VIgn 11.9V, udsna)--
    No real surprise; they are: "Intermittent - Not Confirmed"
    Since they are in 01-Engine, for try the following "for science":
    [OBD-II]
    [Mode 3 Current DTCs] (I'm near certain there won't be any)
    [Mode 7 Pending DTCs] (I'm curious if anything shows up there)
  3. Likes Eric liked this post
    Oct 2019
    I did not have the time, so left it to VW, who carried out a check.
    NOx code remained and the sensor was changed.
    In the past 3 weeks, on a 33k mile vehicle, the NOx and DPF differential sensors have been changed under warranty, which could have been a huge bill !!!!
