Results 1 to 3 of 3
Thread: 2006 Jetta TDI Steering problems.
    Oct 2019
    I am posting this in hopes I can figure out what is going on and what I might have done wrong. My car went red on the steering wheel light so I did a scan and it told me the Controller was bad so I replaced it. I also replaced my clock spring at the same time because it looked like there was something inside that might be causing issues. Now it won't even read that I'm connected to the steering wheel and I am left stumped. I don't know what to do now and I really want my car to drive again since I still have less than 100,000 miles on it. Here is the most recent scan. Please, someone help me.
    Sunday,27,October,2019,15:25:02:31068:facepalm:
    VIN: 3VWRT71K06M710655   License Plate: FREEDE
    Mileage: 145650km-90502mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: 3VWRT71K06M710655   Mileage: 145650km-90502miles
    Address 01: Engine        Labels: 038-906-016-BEW.lbl
       Part No SW: 03G 906 016 AB    HW: 028 101 223 8
       Component: R4 1,9L EDC G000SG  7550
       Revision: --H01---    Serial number: VWZ7Z0E2827737
       Coding: 0050071
       VCID: 6393AD1527522DDFB45-8036
       Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
       Revision: 00T12001
       Coding: 0021122
       Shop #: WSC 00066 551 00000
       VCID: 40D94299968456C7897-8014
       Part No: 1K0 820 047 DK
       Component: Climatic PQ35   090 0505
       VCID: 70B9D259E6A48647397-8024
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000000187748
       Coding: 14010E234004180000140000001400000008730B5C
       Shop #: WSC 23322 444 66617
       VCID: 2A0D003100F8BC97B73-807E
       Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0402
       Coding: 00065493
       Shop #: WSC 23322
       Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
       Component: 1S AIRBAG VW8R  024 6300
       Revision: 03024000    Serial number: 0037KD0217HR
       Coding: 0012627
       VCID: 2E050C213C10D0B76BB-807A
       Subsystem 2 - Serial number: 6332MSME0B3277089
       Subsystem 3 - Serial number: 6342MSME0B33036DB
       Subsystem 4 - Serial number: 6351HSME0834202D%
       Subsystem 5 - Serial number: 6361HSME083E0020
       Subsystem 6 - Serial number: 63727SME08025616V
       Subsystem 7 - Serial number: 63827SME08254B5FB
    Address 16: Steering wheel
       Part No: 1K0 920 952 D
       Component: KOMBIINSTRUMENT 3HL 1212
       Coding: 0023207
       VCID: 2B0305350F02A59F4C5-807E
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 280010590485B7
       Coding: 3D3F0B40071002
       Component: IMMO            3HL 1212
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2377
       Coding: 0001269
       VCID: 36352441C440E87723B-8062
       Part No: 1K1 909 144 J
       Component: EPS_ZFLS Kl.5   D04 1606
       VCID: 323D18512828F4570F3-8066
    00003 - Control Module
                014 - Defective
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AF
       Coding: 137803281B09058F880F048051A0
       Shop #: WSC 00046 412 819200
       VCID: 74B1DE4992BCBA67DDF-8020
       Part No: 1K0 959 702 K
       Coding: 0001269
       VCID: 372B2945C34A117F38D-8062
       Part No SW: 1K0 035 180 D    HW: 1K0 035 180 D
       Component: Radio DE2       011 0014
       Revision: 00011000    Serial number: VWZ4Z7E3052925
       Coding: 0010400
       VCID: 211FE71D7DCE7FCFE69-8074
                014 - Defective
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2434
       Coding: 0000144
       VCID: 313F175D2D2ECF4F769-8064
       Part No: 1K0 959 704 D
       Coding: 0000144
       Revision: 00800000    Serial number:
       VCID: 2D070B2D3116ABAF521-8078
    End----------(Elapsed Time: 01:18, VBatt start/end: 14.5V/14.6V)-----------
    JPPSG?
    FUSES?
    GROUNDS?
    Dallas (McKinney) ,TX ,USA
    Red light is probably because of this problem :
    014 - Defective
    Is it old and new Steering modules same part number including 2 letters at the end?
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  4. Likes Uwe liked this post
