Results 1 to 3 of 3
Thread: VW Passat 3C and EPB/ABS coding problem
    Feb 2017
    Oulu, Finland
    Hey!
    Again, there would be a problem that requires the help of the wisest.
    The car's current owner bought that car a couple of days ago. The previous owner has replaced the abs control unit for that car. The original abs control unit and its encodings are no longer available. After replacing the ABS control unit, the instrument lights have started to illuminate. The workshop has not been able to fix the problem. Electronic Handbrake + Handbrake button works. Dashboard malfunctions only interfere with driving.
    Sunday,10,November,2019,18:13:52:00464
    Dealer/Shop Name: J.P
    VIN: WVWZZZ3CZ7P137854   License Plate: VW PASSAT
    Mileage: 312000km-193867mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 18 19 22 25 42 44 46 47 52 53 56 62 72
              76
    VIN: WVWZZZ3CZ7P137854   Mileage: 312000km-193867miles
    Address 01: Engine        Labels: 03G-906-018-BKP.clb
       Part No SW: 03G 906 018 CE    HW: 03G 906 018 CE
       Component: R4 2.0l PPD1.5 G    9707
       Revision: --H45---    Serial number: VWZCZ000000000
       Coding: 0000172
       Shop #: WSC 66565 257 00032
       VCID: 6A8DC2BFB07FF457773-803E
                   P1653 - 008 -
                        Fault Status: 11101000
                        Reset counter: 40
                        Mileage: 311379 km
                        Date: 2019.09.04
                        Time: 08:20:47
                        Torque: 0.0 Nm
                            0.00 %
                        Voltage: 11.87 V
                        Bin. Bits: 00000100
                        Torque: 1016.0 Nm
    Readiness: N/A
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 109     HW: 3C0 614 109
       Component: ESP 440 C4     H018 0001
       Revision:  H018       Serial number: 0775140884
       Coding: 0010000
       Shop #: WSC 11300 205 67446
       VCID: 5BE3977B6F259DDFFC5-800E
                        Fault Frequency: 13
                        Reset counter: 13
                        Mileage: 311799 km
                        Date: 2019.11.09
                        Time: 15:01:45
                        Reset counter: 54
                        Mileage: 311799 km
                        Date: 2019.11.09
                        Time: 15:25:46
                        Reset counter: 54
                        Mileage: 311799 km
                        Date: 2019.11.09
                        Time: 15:25:46
                        Reset counter: 54
                        Mileage: 311799 km
                        Date: 2019.11.09
                        Time: 15:25:46
                        Reset counter: 54
                        Mileage: 311799 km
                        Date: 2019.11.09
                        Time: 15:25:46
                        Reset counter: 54
                        Mileage: 311799 km
                        Date: 2019.11.09
                        Time: 15:25:46
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AJ    HW: 3C0 907 044 AJ
       Component: ClimatronicPQ46 050 0505
       Revision: 00050005    Serial number: 00000000000000
       VCID: 698FBDB3B579FF4F7E9-803C
       Part No SW: 3C0 937 049 AG    HW: 3C0 937 049 AG
       Revision: 00H52000    Serial number: 00000004759596
       Coding: 01828F0700041A00470A00000F000000000C5D435C0001
       Shop #: WSC 11300 205 76641
       VCID: 6E85CEAF8C9718772BB-803A
       Subsystem 1 - Part No: 3C1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 310107 022  0601
       Coding: 00046997
       Shop #: WSC 11300
                        Fault Status: 01101100
                        Reset counter: 16
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 10.75 V
                        Fault Status: 00101100
                        Reset counter: 49
                        Mileage: 311387 km
                        Date: 2019.09.15
                        Time: 01:29:00
                        Voltage: 11.30 V
                        Fault Status: 00101010
                        Reset counter: 50
                        Mileage: 311387 km
                        Date: 2019.09.15
                        Time: 00:01:00
                        Voltage: 11.95 V
       Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
       Component: 0B AIRBAG VW8   031 2522
       Revision: 11031000    Serial number: 003B1P31JV2A
       Coding: 0012354
       Shop #: WSC 00028 028 00001
       VCID: 303910D756234E87797-8064
       Subsystem 1 - Serial number: 6332MSME171F0671
       Subsystem 2 - Serial number: 6342MSME17026238
       Subsystem 3 - Serial number: 6351HTS6S4COI5L6
       Subsystem 4 - Serial number: 6361HTS6S4CK65B6
    00532 - Supply Voltage B+
       Part No SW: 3C0 953 549 M    HW: 3C0 953 549 M
       Component: J0527               0015
       Revision: 00006000    Serial number: 3C5953507AG
       Coding: 0000111
       VCID: 363526CFB44760B723B-8062
       Part No SW: 3C0 920 871     HW: 3C0 920 871
       Component: KOMBIINSTRUMENT VD1 1614
       Revision: V0007000    Serial number: 00000000000000
       Coding: 0007105
       Shop #: WSC 80093 222 69422
       VCID: 619FA5934D49B70FA69-8034
                        Reset counter: 46
                        Mileage: 311379 km
                        Date: 2019.09.04
                        Time: 08:15:04
                        Reset counter: 47
                        Mileage: 311386 km
                        Date: 2019.09.15
                        Time: 19:31:22
                        Reset counter: 47
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 1K0 815 071 T
       Component: Zuheizer        050 2504
       Revision: 00050000    Serial number: 09009839000000
       Coding: 0000012
    00664 - Fuel gauge
                        Fault Frequency: 11
                        Reset counter: 139
                        Mileage: 194122 km
                        Date: 2017.03.22
                        Time: 12:40:30
    01406 - No Flame
                        Fault Frequency: 6
                        Reset counter: 144
                        Mileage: 194137 km
                        Date: 2017.03.22
                        Time: 17:42:15
                            Start
                        Temperature: 81.0°C
                        Temperature: 78.0°C
                        Voltage: 14.60 V
    02251 - Heater Unit Locked
                        Reset counter: 104
                        Mileage: 194205 km
                        Date: 2017.03.23
                        Time: 15:14:40
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C0722007AB
       Coding: BDFD1C14CA1002
       Shop #: WSC 11300 205 176858
       VCID: 211FE5930DC9F70FE69-8074
                        Reset counter: 48
                        Mileage: 311387 km
                        Date: 2019.09.15
                        Time: 00:07:53
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 K
       Component: Haldex 4Motion      1118
       Coding: 0000001
       VCID: 353721C3A9416BAF2A1-8060
    01316 - ABS Control Module
                013 - Check DTC Memory
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Shop #: WSC 11300 205 84992
       VCID: 392F2DF385598FCFCE9-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                        Reset counter: 47
                        Mileage: 311386 km
    02818 - Steering Column Lock; Enabling for Electronic Ignition Lock
                        Fault Status: 00101001
                        Reset counter: 54
                        Mileage: 311640 km
                        Date: 2019.11.09
                        Time: 10:38:07
       Component: J386  TUER-SG FT    1131
       Revision: 32008001    Serial number: 00000093378216
       Coding: 0000181
       VCID: 3B2337FB8F65BDDFDC5-806E
                        Fault Status: 00100101
                        Reset counter: 48
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.136 H07 1806
       VCID: 34311CC7A23B72A71DF-8060
       Component:    KSG PQ46 ELV 042 0472
       Coding: 00910A0001860E763004941570084F0B607C01
    Address 47: Sound System        Labels: 3C0-035-456.clb
       Part No: 3C0 035 456 D
       Component: 08K Audioverst.     0005
       Revision: 00002000    Serial number: 00000004102124
       Component: J387  TUER-SG BT    1131
       Revision: 32008001    Serial number: 00000061078216
       Coding: 0000180
       VCID: 3C2134E78A6BBAE7D5F-8068
       Part No SW: 3C0 907 801 E    HW: 3C0 907 801 E
       Component: EPB  VC8HC003   013 0003
       Revision:   013
       Coding: 0010000
       VCID: 2411EC8712DBE2278DF-8070
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
                        Fault Status: 00111011
                        Reset counter: 51
                        Voltage: 12.32 V
                        Count: 117
                        Fault Status: 00111100
                        Reset counter: 51
                        Mileage: 311536 km
                        Date: 2019.11.08
                        Time: 13:09:33
                        Voltage: 14.18 V
                        Count: 87
                        Fault Status: 11101101
                        Reset counter: 16
                        Mileage: 311384 km
                        Date: 2019.09.15
                        Time: 19:35:34
                        Voltage: 10.14 V
                        Count: 236
                000 - - - MIL ON
                        Fault Status: 11100000
                        Fault Frequency: 74
                        Reset counter: 7
                        Voltage: 11.39 V
                        Count: 171
    02431 - Right Parking Brake Motor (V283) Resistance to Movement
                        Fault Status: 00111110
                        Reset counter: 51
                        Mileage: 311632 km
                        Date: 2019.11.08
                        Time: 18:36:53
                        Voltage: 12.42 V
                        Count: 17
       Part No SW: 3C0 035 195 B    HW: 3C0 035 195 B
       Component: Radio PM6       009 0018
       Revision: 00009000    Serial number: VWZ5Z7G1061819
       Coding: 0010010
       VCID: 1F1BE36B3BBDC1FFD0D-804A
                        Reset counter: 47
                        Mileage: 311386 km
                        Date: 2019.09.15
                        Time: 19:31:30
       Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1118
       Revision: 11006001    Serial number: 00000001353342
       Coding: 0000144
       VCID: 3D2739E39171B3EFE21-8068
       Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1118
       Revision: 11006001    Serial number: 00000001357818
       Coding: 0000144
       VCID: 3E253EEF9C77A8F7FBB-806A
    Address 76: Park Assist        Labels: 3C0-919-283.lbl
       Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
       Component: Parkhilfe 8-Kan 004 0013
       Revision: 00004000    Serial number: 90630704805854
       Coding: 0010014
       Shop #: WSC 73000 205 61054
       VCID: 290FFDB375F93F4FBE9-807C
                        Reset counter: 47
    01517 - Control Module for Trailer/Towing Sensor (J345)
                        Fault Frequency: 38
                        Reset counter: 16
                        Mileage: 311379 km
                        Date: 2019.09.04
                        Time: 07:59:20
                        Reset counter: 47
                        Mileage: 311386 km
                        Date: 2019.09.15
                        Time: 19:35:11
    01626 - Sensor for Parking-Aid; Front Right (G252)
                        Reset counter: 46
                        Mileage: 311379 km
                        Date: 2019.09.04
                        Time: 09:18:29
    End----------(Elapsed Time: 01:34, VBatt start/end: 12.3V/12.3V)-----------
    I then checked the encodings with the abs unit. I was trying to change a setting at long coding when the bit type was missing the engine type code and gearbox type code. After that I saved the data and tried Auto-Scan again.
    Sunday,10,November,2019,18:54:31:00464
    VIN: WVWZZZ3CZ7P137854   License Plate: VW PASSAT VOL. 2
              76
       Coding: 0000172
                   P1653 - 008 -
                        Reset counter: 40
                        Mileage: 311379 km
                        Date: 2019.09.04
                        Time: 08:20:47
                        Torque: 0.0 Nm
                            0.00 %
                        Voltage: 11.87 V
                        Bin. Bits: 00000100
                        Torque: 1016.0 Nm
    Readiness: N/A
       Coding: 0010018
    01324 - Control Module for All Wheel Drive (J492)
                        Reset counter: 15
                        Mileage: 312002 km
                        Date: 2019.11.10
                        Time: 18:51:42
                        Reset counter: 15
                        Mileage: 312002 km
                        Date: 2019.11.10
                        Time: 18:51:42
                        Reset counter: 15
                        Mileage: 312002 km
                        Date: 2019.11.10
                        Time: 18:51:42
                        Reset counter: 15
                        Mileage: 312002 km
                        Date: 2019.11.10
                        Time: 18:51:42
                        Reset counter: 15
                        Mileage: 312002 km
                        Date: 2019.11.10
                        Time: 18:51:42
                        Reset counter: 15
                        Mileage: 312002 km
                        Date: 2019.11.10
                        Time: 18:51:42
       Coding: 00046997
       Shop #: WSC 11300
       Coding: 0012354
       Coding: 0000111
       Coding: 0007105
       Coding: 0000012
    00664 - Fuel gauge
                        Fault Frequency: 11
                        Reset counter: 139
                        Mileage: 194122 km
                        Date: 2017.03.22
                        Time: 12:40:30
    01406 - No Flame
                        Fault Frequency: 6
                        Reset counter: 144
                        Mileage: 194137 km
                        Date: 2017.03.22
                        Time: 17:42:15
                            Start
                        Temperature: 81.0°C
                        Temperature: 78.0°C
                        Voltage: 14.60 V
                        Reset counter: 104
                        Mileage: 194205 km
                        Date: 2017.03.23
                        Time: 15:14:40
       Coding: 0000001
       Coding: 0000181
       Coding: 0000180
       Revision:   013
       Coding: 0000012
                        Reset counter: 16
                        Mileage: 311384 km
                        Date: 2019.09.15
                        Time: 19:35:34
                        Voltage: 10.14 V
                        Count: 236
                000 - - - MIL ON
                        Reset counter: 16
                        Mileage: 312000 km
                        Date: 2019.11.10
                        Time: 18:13:35
                        Voltage: 12.11 V
                        Count: 170
       Coding: 0010010
       Coding: 0000144
       Coding: 0000144
       Coding: 0010014
                        Reset counter: 16
                        Mileage: 312002 km
                        Date: 2019.11.10
                        Time: 18:13:37
    End----------(Elapsed Time: 01:28, VBatt start/end: 12.2V/12.2V)-----------
    I also checked the original sticker of the car, which shows the equipment installed on the car.
    X1B = National sales program Finland
    B0A = Component parts set without country-specific design requirement
    C1G = Steel wheels 6.5J x 16
    G0L = 6-speed manual transmission for four-wheel drive vehicle
    HJ7 = Tires 215/55 R16 97W x1
    J1D = Battery 380 A (72 Ah)
    D3X = 4-cyl. turbo diesel eng.2.0 L/103 kW 16VTDI with pump-jet injection system base engine: T9G/TB3/TM0/TP0/TC3/TD3/TQ0
    V0A = Tires w/o specification of tire brand
    1AT = Electronic stabilization program (ESP)
    1G2 = Steel spare wheel with original equipment tires
    2ZB = Leather multi-function steering wheel
    5RQ = Right exterior mirror: convex
    5SL = Left exterior mirror: aspherical
    TB3 = 4-cylinder diesel engine 2.0 L unit 03G.B
    3S0 = Without roof rails/roof load rack
    8T2 = Cruise control system (CCS) electronic
    QG1 = Service interval prolongation
    8AN = Radio with CD/MP3
    8GV = Alternator 180 A
    1LH = Disc brakes, front
    L30 = Suspension range 30 installation control only, no requirement forecast
    0YF = Weight range 6 installation control only, no requirement forecast
    G07 = Front shock absorption
    0GG = Emission standard EU4
    1JA = Rear shock absorption, basic design 1
    After that, the ideas ran out. Where should this problem be resolved first?
    VCDS Distributor NEtech's Avatar
    Try this coding for ABS: 0013614
    More information here.
    It seems [76] has not Trailer coding removed, use this coding: 0000014
    Use a battery charger.
  3. Likes Uwe, Jack@European_Parts liked this post
    Feb 2017
    Oulu, Finland
    Both of these tips worked to address this issue. Thanks for the help
