Results 1 to 3 of 3
Thread: A6 C7.5 air suspension auto lowering feature
    Mar 2019
    Hi!
    I've been searching for a solution concerning oem air suspension auto lowering feature. I found this on aas vcds lowering thread: "There is an additional setting that will prevent your car from auto-lowering at ~30 mph, as well as allow you to raise the suspension while driving at any speed. Standard settings gray out the "raise" button over a certain speed, and are particularly annoying if your car is lowered via the steps above and you would like to keep it raised for an extended period of time (such as city driving with a lot of dips, bumps, ramps, sloped driveways, etc.)" and so on.
    This mod is done via green menu in MMI. My car is equipped with RMC system (no nav etc.) and green menu enabled in it but there's no "car" menu etc., just some useless engineering stuff.
    Is there a way to do this mod using vcds, not MMI system?
    We'll need to see a full unedited VCDS Auto-Scan to be able to answer your question.
    Mar 2019
    I used my autoscan from previous thread (I'm not at my laptop right now):
    Sunday,03,March,2019,10:01:16:00849
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUZZZ4G6FN056185   License Plate:
    Mileage: 135266km-84050mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 20 28 34 3B 42 44 46 47 52
              53 55 5F 62 69 6D 72 8F 90 AC
    VIN: WAUZZZ4G6FN056185   Mileage: 135266km-84050miles
    17-Instruments -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CRTE)       Labels: Redir Fail!
       Part No SW: 4G2 907 311 C    HW: 4G2 907 401
       Component: 3.0TDI EDC17  H33 0001
       Revision: 92H33---
       Coding: 12254012052601030000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM30TDI0114G2907311C 001001
       ROD: EV_ECM30TDI0114G2907311C.rod
       VCID: 2541FAC824E257628E-8070
       Part No SW: 4G0 927 166 A    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H03 0008
       Revision: --H03---
       Coding: 100001
       ASAM Dataset: EV_TCMDL501021 001021
       ROD: EV_TCMDL501021.rod
       VCID: 2B550CF04206611258-807E
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 17A6DE41E8657B829B00
       ASAM Dataset: EV_ESP9BOSCHAU57X 003019
       ROD: EV_ESP9BOSCHAU57X_003.rod
       VCID: 3F8D48A0A67EEDB2E4-806A
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0560
       Coding: 01A9700E000000000000
       VCID: 7AFBF9B4F5DC089A93-802E
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Serial number: 16011500040338
       Coding: 36021178210000
       VCID: 63C5A4D06A56E952A0-8036
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00000973397501
       Coding: 0105C01441348FE0C901408300001800CF9CE7082E08020100000894E101170200400024030000
       VCID: 71E9DE98A8AA4BC222-8024
       Component: WWS57X 141126  H37 0080
       Serial number:         141206080957
       Coding: 004DF7
       Serial number: 23634322
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 12 01 2015  00001664
       Serial number: 6E99C467000000000001
    Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
       Part No SW: 8X0 035 110 C    HW: 8X0 035 110
       Component: CDC-MP3-Pana  H41 0490
       Revision: 00000008
       VCID: 2D5102E874126F2246-8078
       Revision: --------    Serial number: 003P1002V48V
       Coding: 30333130313730323735554A304C34473053
       VCID: 3B753CB0B266F192C8-806E
       Serial number: 3575HRB40672UKGQ4PCC
       Serial number: 3585HRB405V33HNI5GSE
       Serial number: 3515JRB400Q52RQM91G.
       Serial number: 3525JRB400S52RQMF8TN
       Serial number: 3554VRB405R34JH6K8O8
       Serial number: 3564VRB405R34JH660V.
       Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
       Component: Lenks.Modul   H06 0005
       Revision: C0068538    Serial number: 90862OA9000LF
       Coding: 000015
       VCID: 3B753CB0BA66F192C8-806E
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 02 12 2014  10003232
       Part No SW: 4G8 920 933 Q    HW: 4G8 920 933 Q
       Component: TDieRdw       H07 0043
       Revision: 03001036    Serial number: 658030115596030
       Coding: 03AD12001B410008010000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K.rod
       VCID: 3E7335A4A174E4BAEF-806A
       Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001533347
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUDS 001024
       VCID: 73E5D490DAB679D2D0-8026
       Serial number: 7439435403
       Voltage stabilizer:
       Serial number: 14102900000000000322
    6151 - Instrument Cluster Control Module on Optical Bus
              U10C0 00 [009] - No Communication
                        Reset counter: 132
                        Mileage: 135266 km
                        Date: 2019.03.03
                        Time: 09:50:53
                        Voltage terminal 30: 12.2 V
                        Voltage terminal 15: 12.2 V
                        Control Module temperature: 19 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       Revision: AA001002
       Coding: 04018264747464545425363E00
       VCID: 7CF7FFACFFE836AA81-8028
       Component: KLIMA FOND    H08 0112
       Serial number: 13011500042154
       Coding: 20
       VCID: 3D7132A8AC72FFA2F6-8068
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Coding: 008001
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F6D18E0761E1D3274-807A
       Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA8208ULT6
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 36632D8489442CFA37-8062
       Coding: 011F17014000628002080002
       VCID: 479D5040F6AEA5725C-8012
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0021349405
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       VCID: 336514909A3639D210-8066
       Revision: 00002001    Serial number: 0357772071
       Coding: 0100063820B93000C320090428010F470000000000000000000000000000
       Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
       Component: BOSE-G3-C7    H07 0160
       Revision: CJ007001    Serial number: 00000000163672
       Coding: 030000
       VCID: 1D31D22804B29FA2D6-8048
       Coding: 011F17014400628002080002
       VCID: 46835D44F1A4BC7AA7-8012
       Revision: --------    Serial number: 00000001328127
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D5102E87C126F2246-8078
       Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0081
       Coding: 04FA02102A600200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
       Coding: E01E00
       Coding: E01E00
       Part No SW: 4G1 035 182 A    HW: 4G1 035 182 A
       Component: RMC Cnct Plus H61 0139
       Coding: 0100010101E15B47482B060301020100000000
       VCID: 204FEBDC33C0B24AFD-8074
       Subsystem 1 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9464L%0E2694600
       Subsystem 2 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
       Serial number: 90349OA700114
       Coding: 010F15004000628002080002
       VCID: 49995678E0BA53024A-801C
    Address 69: Trailer (J345)       Labels:. 4H0-907-383-V2.clb
       Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
       Component: ConWys Trailer H07 0072
       Revision: 7B001002    Serial number: 00000133243642
       Coding: 0100000000000000
       VCID: 33651490923639D210-8066
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0150
       Revision: 14005001    Serial number: 356400615
       Coding: 093205C010
       ROD: EV_HDSGAu571.rod
       Coding: 00060000031F030000030801424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 31691E98602A0BC262-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 326B1194652C30DA1B-8066
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 143361261
       ROD: EV_RDCMA00100_008.rod
    End-------------------------(Elapsed Time: 05:05)--------------------------
