I have replaced the following 2 modules in my car:
Gateway 5Q0 907 530 AM -> 3Q0 907 530 AA
Instrument cluster 5TA 920 750 A -> 5NA 920 790 D
Everything (keys, immo, acc, lane assist, radio and so on) seems to be working except that it keeps saying that generator is not charging.
Coding of gateway is exact the same for old + new. Also adaptions are the same - for the ones that exists on both gateways.
Saturday,09,November,2019,22:51:47:21529
VIN: WVGZZZ1TZHW038734 License Plate: TOURAN
Mileage: 64242km-39918mi Repair Order:
Chassis Type: 1T-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69 6C
6D A5 BB BC
VIN: WVGZZZ1TZHW038734 Mileage: 64242km-39918miles
Address 01: Engine (J623-CZDA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HQ HW: 04E 907 309 BH
Component: R4 1.4l TFS H25 2484
Revision: R7H25---
Coding: 0125003224741D083000
Shop #: WSC 10818 002 1048576
ASAM Dataset: EV_ECM14TFS01104E906027HQ 001004
ROD: EV_ECM14TFS01104E906027HQ.rod
VCID: 7AADF0DDDC5A1847873-802E
CAN Converter 01:
7158 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [036] - -
[Diagnostic interface for data busRead out DTC]
Mileage: 64242 km
Date: 2019.11.09
Time: 22:39:53
Engine speed: 996.50 /min
Normed load value: 16.9 %
Coolant temperature: 26 °C
Intake air temperature: 12 °C
Voltage terminal 30: 10.059 V
Outside air temperature: 6 °C
Absolute intake pressure: 28 kPa abs
Engine torque: 20.3 Nm
Fuel level: 10.00 l
Oxygen sensor bank 1 sensor 1: specified value: 1.0000
Intake camshaft bank1 active operating mode-Bits 0-7: 0
Overrun cut-off-Bits 0-7: 0
Readiness: 1110 0001
Part No SW: 0CW 300 049 Q HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0907
Revision: 00005025 Serial number: 5ZV01609145673
ROD: EV_TCMDQ200021_VW31.rod
VCID: 4BC36519C34051CF6C5-801E
10810 - Function Restricted due to Insufficient Voltage
U1400 00 [040] - -
Mileage: 64242 km
Date: 2019.11.09
Time: 22:39:40
Engine speed: 11781.75 /min
Engine torque: -100 Nm
Vehicle speed: 61 km/h
Control Module temperature: 64 °C
CURRENT pressure: -9.5 bar
Clutch: primary stat: Driving
selected gear: GANG_6
Driving position: N
Accelerator position: 0.0 %
DTC memory status: 45824
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62296000001561
Coding: 0CEA6AA034231374477E360341C72930562CC8E26C8294753822F07AC22202
VCID: 7BA3F5D9D360214F9C5-802E
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0418113727
Coding: 032C2C070F
VCID: 3C2136C596EEE677D5F-8068
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98077301
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to temp low voltage]
Reset counter: 187
Mileage: 64242 km
Date: 2019.11.09
Time: 22:39:28
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
ZAT_pressed: OFF
Park selector lever position: Engaged and locked
Enabling immobilizer: Condition met
Control Module Voltage: 5.649 V
Vehicle speed: 0.0 km/h
Engine speed: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: coded
Coding information: Not coded
Driver door: Open
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID sensor 1 authentication: status: No response
ID sensor 2 authentication: status: No response
ID sensor 3 authentication: status: No response
ID sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Part No SW: 5G1 907 044 T HW: 5G1 907 044 T
Component: Climatronic H04 1601
Revision: 00001K10
Coding: 08020004200410011105104D0010102A
VCID: 392F2FD199DCD35FCE9-806C
Air quality sensor:
B10CD 00 [009] - -
Reset counter: 147
Mileage: 64242 km
Date: 2019.11.09
Time: 22:40:56
Voltage terminal 30: 10.4 V
CAN input signal(s) status-Back-up light: OFF
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 865821091600J3
Coding: 00071B66C2C102FB57C44018101C172C188A000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 03538D39AB90598FD45-8056
Subsystem 1 - Part No SW: 5TB 955 119 A HW: 5TB 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160817 043 0608
Serial number: 160824082627
Component: RLHS 042 0105
Serial number: S4Y16M09D30H17M16S41
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000035510080
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Serial number: 000308417617172
Coding: 0A71563951
Shop #: WSC 49885 002 104857
ROD: EV_EPHVA2CAU3700000.rod
VCID: 50F972752A667217197-8004
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 32016FCB55FFC428949C804D
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34311EE5BEBE2E371DF-8060
1389 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[FAULT_VBAT_BUSMON_LOW]
Reset counter: 187
Mileage: 64242 km
Date: 2019.11.09
Time: 22:39:41
Control Module temperature: 34 °C
Voltage terminal 15: 9.2 V
Part No SW: 5Q0 959 655 AE HW: 5Q0 959 655 AE
Component: AirbagVW21 005 0130
Serial number: 003NSR25CGM9
Coding: 98CCC0C00C0000005C5450CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X.rod
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 5TB857705E0272Q00803
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 5TB857706E0272Q00021
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 002 709 16
Serial number: 3570000000086145AD1K
Subsystem 4 - Part No SW: ----------- HW: 480 002 709 16
Serial number: 3580000000056BEC9F13
Subsystem 5 - Part No SW: ----------- HW: 480 412 309 16
Component: SideSensor_Dr 003 0189
Serial number: 351001A058EA64927D8K
Subsystem 6 - Part No SW: ----------- HW: 480 412 309 16
Component: SideSensor_Pr 003 0189
Serial number: 352001A058E4A8A0FED-
Subsystem 7 - Part No SW: ----------- HW: 480 402 809 16
Component: FrontSensor_D 000 6149
Serial number: 3550001AB223535272F
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 402 909 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001C3227F923226Z
Subsystem 9 - Part No SW: ----------- HW: 480 402 909 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001A52303C96757/
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 480 402 909 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001A92303C91A67Z
Subsystem 11 - Part No SW: ----------- HW: 480 000 709 16
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000B11149D1
Subsystem 12 - Part No SW: ----------- HW: 480 000 709 16
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000EEAB42E1P
Part No SW: 3Q0 953 521 EJ HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0225
Revision: FF036036 Serial number: 20160703500063
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CA1F6C5D66E267795F-8028
291104 - Temperature Sensor for Heated Steering Wheel
B1455 01 [008] - Electrical Failure
Reset counter: 187
Mileage: 64242 km
Date: 2019.11.09
Time: 22:39:28
Ubat 30 Voltage: 6.50 V
Internal error state: 0
LIN_Temp: 254
Isense: 0
Max.Leistung: 110
PWM: 0
Offset: 245
Slope: 134
kp: 18
OUT: 50
Temperatur Statisch: 30
p_t_soll_0: 34.00 °C
p_t_soll_1: 39.00 °C
p_t_soll_2: 44.00 °C
Part No SW: 5NA 920 790 D HW: 5NA 920 790 D
Component: KOMBI 508 1701
Coding: 05AD01186F000008018800033001000100000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_DashBoardVDDMQBA0 001026
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: 43D34D39EB10998F945-8016
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5364
Serial number: 26021810802796
Coding: 030100343F085700FB00025C1C0F00010001050000000000000000000000
Shop #: WSC 01730 666 28888
ROD: EV_GatewNF.rod
VCID: 6E85CC8D901244E72BB-803A
Component: 2-07-1f-07-1f
Subsystem 2 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 2561612082701199AP2B
Coding: 2F0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 9070731604
8526354 - Generator
P1B01 00 [008] - Electrical Malfunction
Reset counter: 187
Mileage: 64242 km
Date: 2019.11.09
Time: 22:39:49
Supply voltage: Terminal 30: 9.9 V
Terminal 15: On
8526361 - LV Energy Management
B1802 F1 [009] - Warning Triggered
Reset counter: 147
Mileage: 64242 km
Date: 2019.11.09
Time: 22:38:27
Supply voltage: Terminal 30: 10.7 V
Terminal 15: On
Component: ELV-MQBB H05 0032
Serial number: 16000217536010
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD7F1812C5B1F369-8024
Component: TSG FS 020 0041
Serial number: 300716EGU23091
Coding: 001B9320D200048000001000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0001069677
Coding: 01010011005001
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
VCID: 3D273BC18DF4EF7FE21-8068
16648 - Supply voltage
[Dauerhafte Unterspannung]
Reset counter: 187
Mileage: 64242 km
Date: 2019.11.09
Time: 22:50:11
Write only channel
Component: TSG BFS 020 0041
Serial number: 110816EHB14179
Coding: 001B9120DE00048000801000
VCID: 42DD483DF40A90879F3-8016
Component: LWR-ECU 005 0080
Coding: 07CA020009000000
VCID: 75B7E3E1F544773FEA1-8020
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 022 A HW: 5NA 035 022
Component: MU-H-LND-EU H51 1121
Serial number: A846E0HB063189
Coding: 02730801FF0000005111110100880A101F0106C401200400FE
Shop #: WSC 00046 123 12345
VCID: 313F17F141AC1B1F769-8064
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H52 9130
Serial number: VWZ6ZJV1770429
Subsystem 2 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1015
0005 - Antenna Amplifier 1 for Radio
B126D 13 [008] - Open Circuit
Reset counter: 187
Mileage: 64242 km
Date: 2019.11.09
Time: 18:57:50
Voltage terminal 30: 11.4 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
0006 - Antenna Amplifier 2 for Radio
B126E 13 [008] - Open Circuit
Reset counter: 187
Mileage: 64242 km
Date: 2011.01.01
Time: 01:33:22
Voltage terminal 30: 11.5 V
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0427037793
Coding: 0100000202000000
Part No SW: 5Q0 980 568 B HW: 5Q0 980 568 B
Component: RVC Compact+ H07 0250
Coding: 01230601A700201F000068
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 007012
ROD: EV_CamSysRVRVCARPANAMQBAB_007_VW37.rod
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30950586600000
Coding: 03A8
VCID: 3FDB41C987F8FD6FF0D-806A
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 25101611K12644
Coding: 000307080000040100262345C140850098000E230020
Shop #: WSC 00069 790 00048
262144 - Function Restricted due to Insufficient Voltage
U1400 00 [009] - -
[Function_limitation_battery_voltage_temporary_too_low]
Reset counter: 147
Mileage: 64242 km
Date: 2019.11.09
Time: 22:50:38
Control Module temperature: 32 °C
Outside air temperature: 7.0 °C
Vehicle speed: 0.00 km/h
System run time: 24.2 s
Voltage terminal 15: 9.0 V
mid: 00 05
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 170816DHH0229B
Coding: 002091200000048000001000
VCID: 45D75321E524A7BFBA1-8010
Component: TSG HBFS 020 0041
Serial number: 170816DHH02711
End-----(Elapsed Time: 02:20, VBatt start/end: 9.9V/9.0V. VIgn 9.0V)-------
