Results 1 to 6 of 6
Thread: Touran 5T: Generator is not charging after gw/instrument change
    Aug 2014
    I have replaced the following 2 modules in my car:
    Gateway 5Q0 907 530 AM -> 3Q0 907 530 AA
    Instrument cluster 5TA 920 750 A -> 5NA 920 790 D
    Everything (keys, immo, acc, lane assist, radio and so on) seems to be working except that it keeps saying that generator is not charging.
    Coding of gateway is exact the same for old + new. Also adaptions are the same - for the ones that exists on both gateways.
    Saturday,09,November,2019,22:51:47:21529
    VIN: WVGZZZ1TZHW038734   License Plate: TOURAN
    Mileage: 64242km-39918mi   Repair Order:
    Chassis Type: 1T-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69 6C
              6D A5 BB BC
    VIN: WVGZZZ1TZHW038734   Mileage: 64242km-39918miles
    Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HQ    HW: 04E 907 309 BH
       Component: R4 1.4l TFS   H25 2484
       Revision: R7H25---
       Coding: 0125003224741D083000
       Shop #: WSC 10818 002 1048576
       ASAM Dataset: EV_ECM14TFS01104E906027HQ 001004
       ROD: EV_ECM14TFS01104E906027HQ.rod
       VCID: 7AADF0DDDC5A1847873-802E
       CAN Converter 01:
    7158 - Please Check DTC Memory in CAN Gateway (J533)
              U1008 00 [036] - -
              [Diagnostic interface for data busRead out DTC]
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:39:53
                        Engine speed: 996.50 /min
                        Normed load value: 16.9 %
                        Coolant temperature: 26 °C
                        Intake air temperature: 12 °C
                        Voltage terminal 30: 10.059 V
                        Outside air temperature: 6 °C
                        Absolute intake pressure: 28 kPa abs
                        Engine torque: 20.3 Nm
                        Fuel level: 10.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                        Intake camshaft bank1 active operating mode-Bits 0-7: 0
                        Overrun cut-off-Bits 0-7: 0
    Readiness: 1110 0001
       Part No SW: 0CW 300 049 Q    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 0907
       Revision: 00005025    Serial number: 5ZV01609145673
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 4BC36519C34051CF6C5-801E
    10810 - Function Restricted due to Insufficient Voltage
              U1400 00 [040] - -
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:39:40
                        Engine speed: 11781.75 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 61 km/h
                        Control Module temperature: 64 °C
                        CURRENT pressure: -9.5 bar
                        Clutch: primary stat: Driving
                        selected gear: GANG_6
                        Driving position: N
                        Accelerator position: 0.0 %
                        DTC memory status: 45824
       Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
       Component: ESC           H62 0736
       Revision: 00000000    Serial number: 62296000001561
       Coding: 0CEA6AA034231374477E360341C72930562CC8E26C8294753822F07AC22202
       VCID: 7BA3F5D9D360214F9C5-802E
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0418113727
       Coding: 032C2C070F
       VCID: 3C2136C596EEE677D5F-8068
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98077301
    65794 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Function restriction due to temp low voltage]
                        Reset counter: 187
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:39:28
                        Terminal_15_Kessy_specified_value: On
                        Terminal_15_Kessy_actual_value: On
                        Terminal_15_central electric_actual_value: On
                        Terminal_15red_Kessy_specified_value: On
                        Terminal_15red_Kessy_actual_value: On
                        Terminal_S_Kessy_specified_value: On
                        Terminal_S_Kessy_actual_value: On
                        Terminal_S_central electric_actual_value: On
                        ZAT_pressed: OFF
                        Park selector lever position: Engaged and locked
                        Enabling immobilizer: Condition met
                        Control Module Voltage: 5.649 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Status of vehicle locking: Vehicle unlocked
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: Open
                        Front Passenger Door: closed
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        ID sensor 1 authentication: status: No response
                        ID sensor 2 authentication: status: No response
                        ID sensor 3 authentication: status: No response
                        ID sensor 4 authentication: status: No response
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Part No SW: 5G1 907 044 T    HW: 5G1 907 044 T
       Component: Climatronic   H04 1601
       Revision: 00001K10
       Coding: 08020004200410011105104D0010102A
       VCID: 392F2FD199DCD35FCE9-806C
       Air quality sensor:
              B10CD 00 [009] - -
                        Reset counter: 147
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:40:56
                        Voltage terminal 30: 10.4 V
                        CAN input signal(s) status-Back-up light: OFF
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Revision: --------    Serial number: 865821091600J3
       Coding: 00071B66C2C102FB57C44018101C172C188A000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 03538D39AB90598FD45-8056
       Subsystem 1 - Part No SW: 5TB 955 119 A    HW: 5TB 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    160817  043 0608
       Serial number:         160824082627
       Component: RLHS  042 0105
       Serial number: S4Y16M09D30H17M16S41
       Coding: 00A8DD
       Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Component: Sirene, DWA  005 0313
       Serial number: 00000000000035510080
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417617172
       Coding: 0A71563951
       Shop #: WSC 49885 002 104857
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 50F972752A667217197-8004
       Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
       Component: ACC BOSCH MQB H04 0194
       Coding: 32016FCB55FFC428949C804D
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 34311EE5BEBE2E371DF-8060
    1389 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [FAULT_VBAT_BUSMON_LOW]
                        Reset counter: 187
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:39:41
                        Control Module temperature: 34 °C
                        Voltage terminal 15: 9.2 V
       Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
       Component: AirbagVW21    005 0130
       Serial number: 003NSR25CGM9
       Coding: 98CCC0C00C0000005C5450CF004800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
       ROD: EV_AirbaVW20SMEVW37X.rod
       Belt Pretensioner left:
       Serial number: 5TB857705E0272Q00803
       Coding: 80000D
       Belt Pretensioner right:
       Serial number: 5TB857706E0272Q00021
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 002 709 16
       Serial number: 3570000000086145AD1K
       Subsystem 4 - Part No SW: -----------    HW: 480 002 709 16
       Serial number: 3580000000056BEC9F13
       Subsystem 5 - Part No SW: -----------    HW: 480 412 309 16
       Component: SideSensor_Dr  003 0189
       Serial number: 351001A058EA64927D8K
       Subsystem 6 - Part No SW: -----------    HW: 480 412 309 16
       Component: SideSensor_Pr  003 0189
       Serial number: 352001A058E4A8A0FED-
       Subsystem 7 - Part No SW: -----------    HW: 480 402 809 16
       Serial number: 3550001AB223535272F
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 402 909 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001C3227F923226Z
       Subsystem 9 - Part No SW: -----------    HW: 480 402 909 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001A52303C96757/
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 402 909 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001A92303C91A67Z
       Subsystem 11 - Part No SW: -----------    HW: 480 000 709 16
       Serial number: I0M00000000B11149D1
       Subsystem 12 - Part No SW: -----------    HW: 480 000 709 16
       Serial number: I0N00000000EEAB42E1P
       Part No SW: 3Q0 953 521 EJ    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0225
       Revision: FF036036    Serial number: 20160703500063
       Coding: 0410
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7CA1F6C5D66E267795F-8028
    291104 - Temperature Sensor for Heated Steering Wheel
              B1455 01 [008] - Electrical Failure
                        Reset counter: 187
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:39:28
                        Ubat 30 Voltage: 6.50 V
                        Internal error state: 0
                        LIN_Temp: 254
                        Isense: 0
                        Max.Leistung: 110
                        PWM: 0
                        Offset: 245
                        Slope: 134
                        kp: 18
                        OUT: 50
                        Temperatur Statisch: 30
                        p_t_soll_0: 34.00 °C
                        p_t_soll_1: 39.00 °C
                        p_t_soll_2: 44.00 °C
       Part No SW: 5NA 920 790 D    HW: 5NA 920 790 D
       Component: KOMBI         508 1701
       Coding: 05AD01186F000008018800033001000100000000
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_DashBoardVDDMQBA0 001026
       ROD: EV_DashBoardVDDMQBA0_VW37.rod
       VCID: 43D34D39EB10998F945-8016
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5364
       Serial number: 26021810802796
       Coding: 030100343F085700FB00025C1C0F00010001050000000000000000000000
       Shop #: WSC 01730 666 28888
       ROD: EV_GatewNF.rod
       VCID: 6E85CC8D901244E72BB-803A
       Component: 2-07-1f-07-1f
       Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
       Serial number: 2561612082701199AP2B
       Coding: 2F0000
       Serial number: 9070731604
    8526354 - Generator
              P1B01 00 [008] - Electrical Malfunction
                        Reset counter: 187
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:39:49
                        Supply voltage: Terminal 30: 9.9 V
                        Terminal 15: On
    8526361 - LV Energy Management
              B1802 F1 [009] - Warning Triggered
                        Reset counter: 147
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:38:27
                        Supply voltage: Terminal 30: 10.7 V
                        Terminal 15: On
       Serial number: 16000217536010
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD7F1812C5B1F369-8024
       Serial number: 300716EGU23091
       Coding: 001B9320D200048000001000
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0001069677
       Coding: 01010011005001
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
       VCID: 3D273BC18DF4EF7FE21-8068
    16648 - Supply voltage
              [Dauerhafte Unterspannung]
                        Reset counter: 187
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:50:11
                        Write only channel
       Serial number: 110816EHB14179
       Coding: 001B9120DE00048000801000
       VCID: 42DD483DF40A90879F3-8016
       Coding: 07CA020009000000
       VCID: 75B7E3E1F544773FEA1-8020
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 5NA 035 022 A    HW: 5NA 035 022
       Component: MU-H-LND-EU   H51 1121
       Serial number: A846E0HB063189
       Coding: 02730801FF0000005111110100880A101F0106C401200400FE
       Shop #: WSC 00046 123 12345
       VCID: 313F17F141AC1B1F769-8064
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H52 9130
       Serial number: VWZ6ZJV1770429
       Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote2  --- 1015
    0005 - Antenna Amplifier 1 for Radio
              B126D 13 [008] - Open Circuit
                        Reset counter: 187
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 18:57:50
                        Voltage terminal 30: 11.4 V
                        Status of antenna 1 for radio-Antenna current: 0 mA
                        Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
    0006 - Antenna Amplifier 2 for Radio
              B126E 13 [008] - Open Circuit
                        Reset counter: 187
                        Mileage: 64242 km
                        Date: 2011.01.01
                        Time: 01:33:22
                        Voltage terminal 30: 11.5 V
                        Status of antenna 2 for radio-Antenna current: 0 mA
                        Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0427037793
       Coding: 0100000202000000
       Part No SW: 5Q0 980 568 B    HW: 5Q0 980 568 B
       Component: RVC Compact+  H07 0250
       Coding: 01230601A700201F000068
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 007012
       ROD: EV_CamSysRVRVCARPANAMQBAB_007_VW37.rod
       Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0253
       Revision: --------    Serial number: 30950586600000
       Coding: 03A8
       VCID: 3FDB41C987F8FD6FF0D-806A
       Component: MQB_B_MFK     H07 0272
       Serial number: 25101611K12644
       Coding: 000307080000040100262345C140850098000E230020
       Shop #: WSC 00069 790 00048
    262144 - Function Restricted due to Insufficient Voltage
              U1400 00 [009] - -
              [Function_limitation_battery_voltage_temporary_too_low]
                        Reset counter: 147
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:50:38
                        Control Module temperature: 32 °C
                        Outside air temperature: 7.0 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 24.2 s
                        Voltage terminal 15: 9.0 V
                        mid: 00 05
                        Status of camera: operational
                        Engine_Running_Info: 0
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Serial number: 170816DHH0229B
       Coding: 002091200000048000001000
       VCID: 45D75321E524A7BFBA1-8010
       Serial number: 170816DHH02711
    End-----(Elapsed Time: 02:20, VBatt start/end: 9.9V/9.0V. VIgn 9.0V)-------
    Quote Originally Posted by diskoboy View Post
    First charge the battery.
    Maybe try Coding for [19-CAN Gateway] Byte 4 Bit 6
  3. Likes Uwe liked this post
    May 2014
    hmm...... notwithstanding (or, because of) the litany of low/insufficient voltage DTC s, why wouldn't attending to this (below) be a good way to proceed (instead of considering coding issues)? That is, test the heath of the generator - as a first step - perhaps?
    8526354 - Generator
                        Reset counter: 187
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:39:49
                        Terminal 15: On
    How did you deal with Component Protection DTC s after the retrofit?
    Aug 2014
    It works perfect. Thanks
  6. Likes Uwe liked this post
    Aug 2014
    Coding was done online. I don't know what you mean?
    Aug 2014
    I was a bit to fast the other day - it's quite strange error.
    Did the coding Sunday - charging whole day. Monday no problem (did 2 small trips for max 7-8 minutes each)
    Tuesday (today) - did 2 small trips - max 15 min. each. Both trips said there is a problem with the alternator after approx 10 minutes. Message disappear in cluster after approx 20 seconds. Problem is that I really don't know if I can continue driving ?
    Both new and old gateway logs are here. The original log (5Q0 gateway) was translated from Danish, but the message is the same.
    The new GW recognize the alternator with a special number that I have no idea what is. Is it a serial number?
    My best guess is if I replace the new one with the old one, I don't have any problems at all (- perhaps new problems with the cluster.)
    Address 19: CAN Gateway (J533)     Labels:| NEZ\5Q0-907-530-V1.clb
       Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1265
       Revision	: --------    Serial number: 0005350389
       Codning	: 030100343F085700FB00025C1C0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA1F6C5D66E2677961-8028
       Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: NEZ\3C8-959-537.CLB
       Serial number : 2561612082701199AP2B
       Kodning	: 2F0000
       Coding: 030100347F085700FB00025C1C0F00010001050000000000000000000000
       ROD: EV_GatewNF.rod
       Coding: 2F0000
    8526354 - Generator
                        Reset counter: 187
                        Mileage: 64242 km
                        Date: 2019.11.09
                        Time: 22:39:49
                        Terminal 15: On
