Audi Q5 7speed dsg cluch adaption fail
Hello. I changed cluch to Q5 and now I have to adapt the cluch. I found from rosstech site basic setting page but I have always failed. If I took Basic setting and erase counter for start and stop processes then it says request out of range. Can someone help me with this issue?
Thanks!
Saturday,09,November,2019,12:37:16:19148
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8R9AA008966 License Plate: ECZ-116
Mileage: 190840km-118582mi Repair Order: AUDO Q5
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72
VIN: WAUZZZ8R9AA008966 Mileage: 190840km-118582miles
02-Auto Trans -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAHA) Labels:| 03L-906-022-CAG.clb
Part No SW: 03L 906 019 AS HW: 03L 906 022 B
Component: R4 2.0l TDI H01 9977
Revision: 11H01---
Coding: 01210023240F2120
Shop #: WSC 00834 002 1048576
ASAM Dataset: EV_ECM20TDI03L906019AS A01011
ROD: EV_ECM20TDI03L906019AR.rod
VCID: 7CA1F4E7166FCB2795F-8028
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [047] - Electrical Fault
Mileage: 190756 km
Date: 2019.10.22
Time: 10:12:05
Engine speed: 870.50 /min
Normed load value: 39.6 %
Coolant temperature: 23 °C
Intake air temperature: 11 °C
Voltage terminal 30: 12.640 V
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Vehicle voltage terminal 30: 11580 mV
Coolant temperature: 7.7 °C
Glow status-Bits 0-7: 0
Preheat time: 2500 ms
Fuel temperature: 7.7 °C
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8R2 927 156 C HW: 0B5 927 156 K
Component: 0B5 20 TDIRdW H07 0005
Revision: --H07--- Serial number: 0000000334
Coding: 000001
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 A03005
ROD: EV_TCMDL501021_A03.rod
VCID: 3D2739E34DF5022FE21-8068
Part No SW: 8R0 907 379 B HW: 8R0 907 379 B
Component: ESP8 quattro H07 0110
Coding: 0D1500
Shop #: WSC 06335 000 00000
VCID: 3FDB43EB4779103FF0D-806A
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0321
Coding: 010500
VCID: 015F8513710DA6CFC69-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000028799007
Component: J764 ELV MLB H36 0042
Serial number: 0209000039931013
Part No SW: 8T1 820 043 AN HW: 8T1 820 043 AN
Component: KLIMA 1 ZONE H08 0160
Revision: A1000000 Serial number: 01100620090334
Coding: 34010000
VCID: 7DA7F9E30DF5C22FA21-8028
Reset counter: 151
Mileage: 190826 km
Date: 2009.04.28
Time: 01:25:05
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000283943
Coding: 2600D0914034AF000001000300001D0D001C470800010101000000
VCID: 3C2134E7566F0B27D5F-8068
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 090602 H10 0041
Serial number: 90243014090528184133
Coding: 01DD13
Component: RLS H04 0003
Serial number: 10498075
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000206090904
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940915606120
Coding: 000105
VCID: 3E253EEF40731937FBB-806A
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 B HW: 8R0 959 655 B
Component: AirbagVW-AU10 H03 0310
Serial number: 003E8D03ZFKP
Coding: 30343131313030303030554A304C38523053
ASAM Dataset: EV_AirbaAU10SMEAU416 001001
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 43D34F1B2B1174DF945-8016
Serial number: 6334MSME4903783AH
Serial number: 6344MSME4905463BG
Serial number: 6352QSME512F1F30J
Serial number: 6362QSME2E304A3ES
Serial number: 63732SME6C2E573CH
Serial number: 63832SME5130091CV
Part No SW: 8K0 953 568 E HW: 8K0 953 568 E
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IE5000G9
Coding: 000007
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 D HW: 8R0 920 930 D
Component: KOMBIINSTR. H09 0253
Revision: 00100000 Serial number: BZ663E969
Coding: 0F06220002000008010000
VCID: 353721C37545DA6F2A1-8060
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0101
Revision: GB500049 Serial number: 4900G095270046
Coding: 00C303
VCID: 50F97057EAE79F47197-8004
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0107
Serial number: 00000000004140543651
Reset counter: 151
Mileage: 190826 km
Date: 2019.10.31
Time: 11:16:14
Bin. Bits: 00000
Voltage: 12.30 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
Component: TSG FA H11 0306
Revision: Serial number: 0000101245710
Coding: 011002204000440004
VCID: 47CB5B0B1FA958FF48D-8012
Revision: 00002001 Serial number: 0118990904
Coding: 01000620203900000420050000000000
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 105
Mileage: 190680 km
Date: 2019.10.18
Time: 14:58:51
02616 - Fuel Tank Cap; Unlock
Reset counter: 105
Mileage: 190680 km
Date: 2019.10.18
Time: 15:43:46
00230 - Transmission Park Selector Switch (F305)
Reset counter: 113
Mileage: 190833 km
Date: 2019.11.04
Time: 09:59:24
Part No SW: 8K0 959 792 J HW: 8K0 959 792 E
Component: TSG BF H11 0306
Revision: Serial number: 0000101249813
VCID: 46D5560F18A341F7B3B-8012
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 00000000385692
VCID: 34311CC77E3FC3671DF-8060
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Coding: 0000006
Shop #: WSC 06334 000 00000
VCID: 34311CC7723FC3671DF-8060
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 105
Mileage: 190680 km
Date: 2019.10.18
Time: 14:44:54
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H03 0310
Revision: 00000006 Serial number: AUZ5Z6I1224224
Coding: 0500048004050100015B070000
VCID: 44D14C072E9F73E7ADF-8010
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101273386
Coding: 010002204000240004
VCID: 42DD4A1F348B7DD79F3-8016
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101273383
End----------(Elapsed Time: 01:15, VBatt start/end: 13.7V/14.4V)-----------
I quess there isnt S/S, thats why
Then I Tried Cluch valve calibration, it goes on but then its aborted safety reasons?
What is your auto trans oil temp when you try to run the transmission basic setting? It has to be over 30 c but under 60 c.
Post Thanks / Like - 2 Likes
Why do you want to do calibration, have you replaced parts ?
Why did you choose "Clutch valve calibration" ?
Copy this file to:
C:\Ross-Tech\VCDS\Scaling
first rename it to: 0B5-EV_TCMDL501021#5.u02
Copy this file to:
C:\Ross-Tech\VCDS\Labels\User
You then get information when you choose basic setting:
"Clutch engagement point adaptation (PKP0) [x] #5"
There was fault from clutch and mechatronic. The mechatronic was replaced at Audis dealer. Then cluch was replaced and I tried to to those basic settings what I founded from rosstech site. Clutch engagement point give me error request out of range. I ried few times. Atf fluid was about 42..44c. Could it be somekind software error? I can post the first autoscan later night. Now the car is ok. I had to go to Audi dealer and there car was 2h and now it works. They said that there was no errors and the basic settings was done by first shot. :S
Hi. cant open the first file? there is only text
IDE00024
IDE00098
IDE04347-ENG101925
IDE04347-ENG101865
ENG107525-ENG98502
ENG107531-ENG98502
ENG110340-ENG98502
You know the use is?
Explained in the yellow help.
Read about loading the file here.
Post Thanks / Like - 1 Likes
Uwe liked this post
