First post for a while but wondering if any body has any info please? Car sporadically loses steering with light on ESP lamp lit. Takes a few ignition cycles to clear it. A few recent ish scans. It can go a few months without a hitch. Currently its been absolutely fine. I WILL SCAN AGAIN FIRST THING TOMORROW.
Please id just like any info on this issue. Kind regards Danners74
Monday,20,May,2019,18:22:57:56713
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: TMBBG7NE6E0026157 License Plate: GD14UOE
Mileage: 151488km-94130mi Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBBG7NE6E0026157 Mileage: 151488km-94130miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22---
Coding: 01110012030501090000
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F3AE606479094EF377-807A
U0428 00 [039] - -
Mileage: 151488 km
Date: 2019.05.20
Time: 18:16:49
Engine speed: 845.50 /min
Normed load value: 35.7 %
Coolant temperature: 29 °C
Intake air temperature: 28 °C
Voltage terminal 30: 14.480 V
21125 - Invalid Data Received from Airbag Control Module
U0452 00 [032] - -
Mileage: 151380 km
Date: 2019.05.18
Time: 23:03:08
Engine speed: 1249.50 /min
Normed load value: 68.2 %
Coolant temperature: 91 °C
Intake air temperature: 65 °C
Voltage terminal 30: 13.240 V
Unlearning counter according OBD: 36
Limitation: accelerator pedal: 57.8 Nm
Cruise Control System (CCS): status-Bits 0-7: 0
selected gear-Bits 0-7: 0
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 616430000002C8
Coding: 1A078A91242209720078060541CA245851249000608224F000430070C002
VCID: 4BC29296D348C8CF3BF-801E
0294 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
Reset counter: 60
Mileage: 151488 km
Date: 2019.05.20
Time: 18:16:49
Reset counter: 60
Mileage: 151488 km
Date: 2019.05.20
Time: 18:16:59
Part No SW: 5E0 907 044 HW: 5E0 907 044
Component: Climatronic H02 0604
Revision: 00001K06
Coding: 01110104000100011005000000100000
ROD: EV_ACClimaBHBVW37X_002_SK37.rod
VCID: 629C5F3244C26987E89-8036
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S
Component: BCM MQBAB M H14 0112
Serial number: 00011316401734
Coding: 0F000842424700DB07A04082B10407280000000000000000000000000000
Shop #: WSC 73430 790 00063
ROD: EV_BCMBOSCH_011.rod
VCID: 48C8AD9AC23E23D716D-801C
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 130612 041 0570
Serial number: 130614132916
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY13114297F
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000057118745
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20411109
12307 - License Plate Light
B12CA 01 [008] - Electrical Failure
Reset counter: 96
Mileage: 151290 km
Date: 2019.05.18
Time: 19:54:20
545300 - Databus
[Gateway_78 Datenbus empfangener Fehlerwert EPS_Lastinfo]
Reset counter: 60
Mileage: 151488 km
Date: 2019.05.20
Time: 18:16:49
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831316901243
Coding: 0001050001
ASAM Dataset: EV_EPHVA14AU3700000 002018
VCID: 3828DD5AB2DE535766D-806C
13637426 - Databus
Reset counter: 60
Mileage: 151488 km
Date: 2019.05.20
Time: 18:16:49
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 011 0188
Revision: -------- Serial number: 003P4PBXDEKJ
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5AF646D770A46FE77-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 606 13
Serial number: 3576U000000D53092D0A
Subsystem 2 - Part No SW: ----------- HW: 454 000 606 13
Serial number: 3586U0000009D4C8EC0
Subsystem 3 - Part No SW: ----------- HW: 454 800 506 13
Component: SideSensor_Dr 111 0148
Serial number: 3516RA21B7C010000000
Subsystem 4 - Part No SW: ----------- HW: 454 800 506 13
Component: SideSensor_Pr 111 0148
Serial number: 3526RAAF17A01000000B
Subsystem 5 - Part No SW: ----------- HW: 454 802 403 13
Component: FrontSensor_D 114 0149
Serial number: 3556V5F225300000000$
Part No SW: 5Q0 953 507 AB HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 20061304401359
Coding: 0600
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 76B41362F84AE527B41-8022
Part No SW: 5E0 920 961 D HW: 5E0 920 961 D
Component: KOMBI 233 2210
Coding: 27A402002180A60001082A00000000
VCID: 290E081E7974FADFE93-807C
Part No SW: 5Q0 907 530 K HW: 5Q0 907 530 D
Component: GW MQB Low 123 1144
Revision: -------- Serial number: 0000673783
Coding: 030000040B087300EF000248080F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: 392ED85E89D44A5F993-806C
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 1405400703
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000066303029
Coding: 001000208001020000001100
VCID: 55F674EE058C8E3F9DB-8000
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000284656
Coding: 1D0200
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D26CC4E9DFC767FB5B-8068
15117 - Internal Fault
B200F F0 [008] - Unknown Error Elaboration
[Rotorlage Sensor: Radius Überwachung Radius verkleinert sich um mehr als 40 digits im Uncontrolled-Zustand bei stehendem Rotorwinkel (delta<10°).Ursache kann ein Kurzschluss in Signalen des Sensorelements sein.]
Reset counter: 100
Mileage: 151488 km
Date: 2019.05.20
Time: 18:16:49
Motor status: 01
System status: Driving mode
Supply voltage: 14.25 V
Temperature: 21.0 °C
KFC: 3B
KFA: 00 0D
Environmental conditions: 75
Rotorlagesensorspannung AMR Sinus: 2.579 V
Rotorlagesensorspannung AMR Kosinus: 1.861 V
Rotorlagesensorspannung AMR Sinus 2: 2.682 V
Rotorlagesensorspannung AMR Cosinus 2: 6.823 V
Rotorlagesensorspannung Hall 1: 0.0 V
Rotorlagesensorspannung Hall 2: 0.0 V
Aktueller Sinus-Offset für ASIC: 0.1 mV
Aktueller Cosinus-Offset für ASIC: -0.0 mV
aktuelle Sinusverstärkung für ASIC: 0.145
16132 - Steering Angle Sensor
B1168 F2 [009] - Not Initialized
Reset counter: 60
Mileage: 151488 km
Date: 2019.05.20
Time: 18:16:49
Motor status: 01
Supply voltage: 0.00 V
KFC: 3F
KFA: 00 04
Environmental conditions: 5F
uAdSensI_U5VFiltered_xdu16: 5.05865 V
uioUdNotFilt_xdu16: 0.06 V
uAdSensI_SwitchedKl30_xdu16: 0.07 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 01
Part No SW: 5Q4 959 392 HW: 5Q4 959 392
Component: TSG BFS 007 0006
Serial number: 0000066310638
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000289351
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 842 A HW: 5E0 035 842 A
Component: MU-S-D-ER 040 0421
Serial number: S7E02406130917
Coding: 03730100FF0000001111120100A800002F0000860100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 211E103E0144329FB13-8074
Subsystem 1 - Part No SW: 5E0 919 605 B HW: 5E0 919 605 B
Component: ABT_Std_Plus H50 0022
Serial number: SKZ8Z9NK6001DZ
End----------(Elapsed Time: 01:11, VBatt start/end: 13.3V/13.3V)-----------
Saturday,17,August,2019,14:53:31:56713
VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4508.4
Mileage: 168817km-104898mi Repair Order:
VIN: TMBBG7NE6E0026157 Mileage: 168817km-104898miles
Revision: 84H22---
VCID: 2F3AE606479094EF63B-807A
U0428 00 [040] - -
Mileage: 167654 km
Date: 2019.08.13
Time: 10:07:08
Engine speed: 1191.00 /min
Normed load value: 48.6 %
Coolant temperature: 15 °C
Intake air temperature: 16 °C
Unlearning counter according OBD: 33
21125 - Implausible Data Received from Airbag Control Module
U0452 00 [032] - -
Mileage: 168546 km
Date: 2019.08.15
Time: 22:47:09
Coolant temperature: 92 °C
Intake air temperature: 71 °C
Voltage terminal 30: 12.580 V
Unlearning counter according OBD: 38
Limitation: accelerator pedal: 110.9 Nm
20359 - Internal Control Module
P0606 00 [109] - Processor Fault
Mileage: 152088 km
Date: 2019.05.22
Time: 18:47:35
Intake air temperature: 61 °C
Voltage terminal 30: 9.860 V
Accelerator pedal travel: raw value: 0.00 %
Starter control: Interlock- or P/N-signal-Bits 0-7: 65
Engine status: COENG_READY
ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
VCID: 4BC29296D348C8CF6F3-801E
B1168 16 [008] - Voltage Too Low
Reset counter: 228
Mileage: 153779 km
Date: 2019.05.29
Time: 09:49:18
0297 - Steering angle sensor
Reset counter: 228
Mileage: 153779 km
Date: 2019.05.29
Time: 09:49:31
16389 - TPMS Display
C1146 F1 [008] - Currently Not Available
Fault Frequency: 16
Reset counter: 232
Mileage: 155335 km
Date: 2019.06.06
Time: 22:38:53
Reset counter: 228
Mileage: 167654 km
Date: 2019.08.13
Time: 10:07:18
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 199
Mileage: 163387 km
Date: 2019.07.25
Time: 02:21:00
Revision: 00001K06
ROD: EV_ACClimaBHBVW37X_002_VW37.rod
VCID: 629C5F3244C26987BC5-8036
329476 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [008] - Actuator stuck
Reset counter: 228
Mileage: 167378 km
Date: 2019.08.12
Time: 14:51:41
VCID: 48C8AD9AC23E23D7421-801C
Coding: 065DDD
B12CA 01 [009] - Electrical Failure
Reset counter: 75
Time: 00:00:00
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [008] - Electrical Failure
Reset counter: 233
Mileage: 155964 km
Date: 2019.06.10
Time: 13:29:09
545300 - Databus
Reset counter: 228
Mileage: 167654 km
Date: 2019.08.13
Time: 10:07:08
Coding: 0001050001
VCID: 3828DD5AB2DE5357321-806C
13637426 - Databus
Reset counter: 228
Mileage: 167654 km
Date: 2019.08.13
Time: 10:07:07
VCID: 7F5AF646D770A46FB3B-802A
Coding: 0600
VCID: 76B41362F84AE527E0D-8022
VCID: 290E081E7974FADFBDF-807C
VCID: 392ED85E89D44A5FCDF-806C
VCID: 55F674EE058C8E3FC97-8000
Coding: 1D0200
Coding: 81
VCID: 3D26CC4E9DFC767FE17-8068
Coding: 050200
VCID: 211E103E0144329FE5F-8074
End----------(Elapsed Time: 01:07, VBatt start/end: 14.2V/14.2V)-----------
Saturday,17,August,2019,14:56:24:56713
Revision: 84H22---
Revision: 00001K06
Coding: 065DDD
Address 10: Park/Steer Assist Labels:
VCID: 55F674EE0C0C8E3FC97-FFFE
Coding: 0600
Coding: 1D0200
Coding: 81
Coding: 050200
End----------(Elapsed Time: 01:14, VBatt start/end: 14.5V/14.2V)-----------
