Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: 2009 R32 - high fuel trim on bank 1
    Oct 2019
    Middle East
    Hello all,
    I have a 2009 R32 on which I've been trying to track down a high partial fuel trim on Bank 1. It varies from around +12 to +19 at the worst.
    Bank 2 sits steady around +7.
    Idle fuel trims for both banks around +0.2
    It's had:
    • New fuel filter
    • New fuel pumps (both)
    • New CTS
    • New MAF
    • New plugs
    • New pre-cat O2 sensors
    • Transposed the coil packs between bank 1 / bank 2
    I'm running out of ideas... Possibly a false lean from an exhaust gasket leaking under load, or maybe a bad injector?
    There aren't any vacuum leaks and the idle trims suggest that to be the case too.
    If any one has any ideas about how to narrow this down further I would be most grateful.
    Cheers!
    Friday,08,November,2019,19:09:26:09551
    VIN: WVWPM51K99W138436   License Plate:
    Mileage: 173670km-107913mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76
    VIN: WVWPM51K99W138436   Mileage: 173670km-107913miles
    Address 01: Engine        Labels: 022-906-032-BDB.lbl
       Part No SW: 022 906 032 KJ    HW: 022 906 032 GP
       Component: R32-DQ-EU2      G   0696
       Revision: 1QH02---    Serial number: VWX7Z0H83NQ7UC
       Coding: 0000178
       Shop #: WSC 00000 000 08192
       VCID: 5DE79A6DE133DA1F821-8008
    Readiness: 0100 1101
       Part No SW: 02E 300 011 CP    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     431 1812
       Revision: 04843012    Serial number: 00000804301651
       VCID: 5F9BA065EB3FC80F90D-800A
       Revision: 00H45001
       Coding: 143B800D09250002280F01E7901F0041B500
       Shop #: WSC 32782 001 1048576
       VCID: 005983193A0157F7C97-8054
       Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
       Component: ClimatronicPQ35 130 1213
       Revision: 00130023    Serial number: 00000000000000
       VCID: 6D87CAAD1193AA9F121-8038
    01810 - Actuating Motor for Temperature Flap; Right (V159)
       Revision: 00H54000    Serial number: 00000008917194
       Coding: E68F8B27000415004714000014000000000900005C000100000000000000
       VCID: 33331CD537373C6F045-8066
       Component: Wischer 011008 021  0501
       Coding: 00038805
       Shop #: WSC 01357
       Component: RLS     061008 054  0402
       Coding: 00207789
       Shop #: WSC 01357
       Component: 5F AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D0C3GV9
       Coding: 0013638
       VCID: 6C81C7A92A89A39705F-8038
       Subsystem 1 - Serial number: 6332MSME4116165A5
       Subsystem 2 - Serial number: 6342MSME4162585FI
       Subsystem 3 - Serial number: 6352QSME380A352CK
       Subsystem 4 - Serial number: 6362QSME700C4F34N
       Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
       Coding: 0012122
       VCID: 78A9EBF96ED11F37F17-802C
       Part No SW: 1K6 920 874 B    HW: 1K6 920 874 B
       Component: KOMBIINSTRUMENT VDD 2416
       Revision: V0002000    Serial number: VWX7Z0H83NQ7UC
       Coding: 0007107
       Shop #: WSC 32785 001 104857
       VCID: 323D19D1C82D35670F3-8066
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 260908F1001064
       Coding: ED837F0E0002020002
       VCID: 353722CD3943225F2A1-8060
    01304 - Radio
                        Fault Frequency: 20
                        Reset counter: 50
                        Mileage: 173572 km
                        Time: 22:29:20
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 L
       Component: Haldex 4Motion      0116
       VCID: 363525C12445294723B-8062
       Component: IMMO            VDD 2416
       Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
       Component: Tuer-SG         006 1219
       Coding: 0000182
       VCID: 392F2EFD155BC63FCE9-806C
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.141 H08 1901
       Coding: 809002005103087F2D0484057008CFC6E0FC00
       VCID: 03538C1527174CEFD45-8056
       Subsystem 2 - Part No: 1K0 951 178 A
       Component: Neigungssensor  003 0203
       Subsystem 3 - Part No: 1K0 951 178 A
       Component: Innenraumueberw.003 0203
       Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
       Coding: 0000438
       VCID: 3A2D31F1105DCD27C73-806E
       Part No: 1T0 907 357
       Coding: 0000004
       VCID: 74B1DFC972B97B57DDF-8020
    Address 56: Radio
       Component: Tuer-SG         006 1302
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 38292BF92E51DF37317-806C
       Coding: 0000144
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1K0 919 283 A
       Component: 22 Einparkhilfe     0101
       VCID: 2D070AADD1136A9F521-8078
    End----------(Elapsed Time: 01:15, VBatt start/end: 11.9V/12.0V)-----------
  2. Likes Uwe liked this post
  3. #2
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Is the exhaust leak free a the flexi joints? What fuel are you using?
  4. Likes Uwe, Jack@European_Parts, cas liked this post
  5. #3
    Did you crimp off N80 and all intake hoses to isolate?
    Have you done a leak down test of injectors plus look at plug's burn patterns?
  6. Likes dieseldub, cas liked this post
  7. #4
    Nov 2017
    Bay Area, CA
    Strange that your autoscan shows no codes in the engine computer despite the obvious out of range fuel trim you have going on.
    O2 sensor lean code the only fault it sets?
    Does it ever set a fuel pressure code? Most of these direct injected gas engines have a control module for the fuel pump to control in-tank pump output via PWM to better dial in pressure and volumes required for the precise operation that direct injection requires.
    Not at all unusual for the fuel pump control module to flake out and no longer adequately control the in-tank pump (even a new pump).
    A lot of the fuel filters on these cars also have a built in pressure regulator and return. But there are several different ones with different pressures. You have to make doubly sure you get the right filter rated at the correct pressure spec.
  8. Likes cas liked this post
  9. #5
    Do I have to say it because I'm going to?
    FOD and purported by whoever?
  10. Likes cas liked this post
  11. #6
    Quote Originally Posted by dieseldub View Post
    Has the car been chip-tuned?
  12. Likes Uwe, cas, Jack@European_Parts liked this post
  13. #7
    Oct 2019
    Middle East
    Many thanks for the replies everyone
    Quote Originally Posted by Danners74 View Post
    As best as I can tell, the flexi pipes aren't leaking. Took a look when the exhaust was off to replace the prop shaft
    Using 98 or 95, depending on what is available. It doesn't appear to make any difference.
    Capped off the EVAP (also had a new solenoid) to check, and the exhaust flapper. All new lines for the intake manifold changeover plumbing. No signs of leaks anywhere else, plus the idle fuel trims seem OK.
    Not done a leakdown yet... need to find somewhere suitable around these parts. When I pulled the plugs there was nothing untowards there.
    When the fuel pump gave up, I was getting error codes. Since replacing the pumps, there haven't been any codes but I have been keeping an eye on the fuel trims.
    From what I saw, it only flags up if fuel trim maxs out (+25% in my case). It hasn't done that since I swapped the pumps (new, genuine ones).
    I replaced the fuel filter with a new, genuine filter, 4 bar if I recall correctly.
    I've never seen a fuel pressure code, but I will look into the fuel pump control module as I hadn't considered that before. Thank you
    I hope it isn't FOD, at least in the context I understand it!
    Not to my knowledge, but I guess we never really know what previous owners have done to vehicles
  14. #8
    Nov 2014
    New Zealand
    Bare in mind, everybody: this car is EU2 emissions regs. I can't recall the exact differences, but it's possibly only 2 lambdas and a simplified set of codes etc?
    Most people on here are going to be dealing with EU4 versions of this car/drive train, only a few markets got EU2.
    This motor isn't direct injected - though even VW relased official documented discussing it's direct injection It's caused quite some confusion at times!
    A VERY common issue for this, usually IS leaking flexies - they are a concertina design, and it's hard to spot the crack, which open or close depending on engine movement. I'd certainly concentrate some time there, possibly with somebody applying some back pressure to the exhaust outlets (There isn't a lot of restriction in the R32 system)
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  15. #9
    Oct 2019
    Middle East
    Quote Originally Posted by NZDubNurd View Post
    That's very useful, thank you very much. Will try to get it up and take a second look.
  16. #10
    Stupid BUB
    Vehicle Identification No. WVWPM51K99W138436
    Model golf r32
    GOLF
    Date of production 24.10.2008
    Model year 2009
    Sales type 1K14X7
    Engine Code BUB
    Transmission Code KQA
    Emission standard 0GV Emission standard EU2
    (critical vapor pressure)
  17. Likes cas liked this post
