sas
New Member
Hello people, how are you?
This is my first post and english is not my native language, so i'm open to suggestions and corrections.
Let's start with my car: Its a Volkswagen Up! 2017 and had some (small) damage at the front of the car, replaced components like Bumper and steer-airbag.
The airbag sensor behind the front bumper generated a error code: P160900 (crash activation).
My buddy with VCDS and a HEX-V2 (+ experience) said he can clear the code.. and he did following whis tutorial
[https://www.youtube.com/watch?v=J3IYx--0TK0]
now the power steering works but the car has still this error (under this story)
0360 - Steering angle sensor not calibrated. AND the dashboard shows: ESP braking error (yellow car light goes on)
Ok this can't be that hard to do... so i went to the ABS module and followed the steps like this manual:
[http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1J)_Brake_Electronics_(MK60)#Basic_Setting]
Then VCDS gave a error that the calibrations was not possible to continue
Tried it again with ODIS Software but same story. tried a lot of times with 3 different people and both software but no luck.
But i don't give up! so i went to the interwebs and search.
Some may suggest that the steering angle sensor is broken. i thinks that's not the case because VCDS shows correct values when i rotate the steerwheel.
The airbag module still shows: IDE01555 Number of frontal crashes = 1.
(can this be the case? Someone said that might be the cause of the error but i want to know for sure (and why? Why does the airbag module cause you to not calibrate the steering wheel?)
Also VCDS shows the voltage to the powersteering is a bit low so i tried it with another battery connected but no luck either.
Maybe dissconenct the airbag module? or the ABS module? i'm hoping this could help calibrating the steeringwheel (but idk its a suggestion)
Does someone know a answer?
Saturday,02,November,2019,11:18:21:01206
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4513.4
Workshop Code: 000 54322 000000
VIN: WVWZZZAAZJD103832 License Plate:
Mileage: 54030km-33572mi Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 09 15 17 19 25 44 5F 61 AD
VIN: WVWZZZAAZJD103832 Mileage: 54030km-33572miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 020 EN HW: 04C 907 309 P
Component: R3 1.0l MPI H24 3171
Revision: UNH24---
Coding: 00110014020401000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM10MPI01104C906020EN 002002
ROD: EV_ECM10MPI_VW12.rod
VCID: 6B823684E305BB3F0C5-803E
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 L HW: 1S0 614 517 L
Component: EBC 460 ESP H16 0023
Serial number: A01I02O
Coding: 12BF247129AD02F3480124F994AA40505FB100
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
VCID: 3828D9C8E2D3C0A7317-806C
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 1S0 937 090 H HW: 1S0 937 090 H
Component: BCM PQ25 1MX4 H82 0752
Revision: BW082001 Serial number: 5000 137170890
Coding: 62B82B0000010000010007D02CEB8EC07940704C60432D602101000B0900
VCID: 3828D9C8E253C0A7317-806C
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 110517 04 42 0106
Coding: 0228DD
Part No SW: 1S0 959 655 C HW: 1S0 959 655 C
Component: VW10Airbag02N H03 0007
Revision: -------- Serial number: 003UB0021TE4
Coding: 00000000000000000000000000000000324E
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
VCID: 3E24CFD0C0F7FE97FBB-806A
Serial number: 3497ARB405V4OAOEBHOO
Serial number: 3507ARB404R4OIFUB8QJ
Serial number: 3557BRB405N4AVKIGQ1C
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1S0 920 870 HW: 1S0 920 870
Component: KOMBI H05 0010
Revision: X0005001 Serial number: 00000000000000
Coding: 114A010000
ASAM Dataset: EV_KombiUDSMM9RM10 A05808
ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
VCID: 6E843F90D0174E172BB-803A
Part No SW: 1S0 909 901 HW: 1S0 937 090 H
Component: GW-K-CAN TP20 H82 0752
Revision: BW082001
Coding: 001201
VCID: 70B821E8CAA358E7397-8024
Part No SW: 5K0 953 234 HW: 1S0 920 870
Component: IMMO H05 0010
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A8C3380ECFFA237773-803E
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AN HW: 6R1 909 144 E
Component: EPS_TRW_ALow 313 3150
Serial number: CH5T0279
Coding: 000300
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 03527E24EB95537FD45-8056
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1S0 035 869 B HW: 1S0 035 869 B
Component: MU-E-D-EU 068 7288
Serial number: 15051700021689
Coding: 022100002800000041111101008002001F0002C40001010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
VCID: 3536D0FCF5C13DCF2A1-8060
Part No SW: 1S0 907 534 HW: 1S0 937 090 H
Component: Batt.regelung H82 0752
Coding: 032B7864
Subsystem 1 - Part No SW: 1S0 915 181 C HW: 1S0 915 181 C
Component: J367-BDM H08 0270
Serial number: 64123621585861412708
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 A HW: 1S0 907 201 A
Component: CV-SENSOR H08 0460
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: 2808098832735027A17-807C
End----(Elapsed Time: 00:45, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
